get_ifm reg_val=7
===i2c gpio === 22777722
axp read fail, maybe no pmu
set pmu vol failed,maybe no pmu
DRAM DRIVE INFO: V0.7
DRAM Type = 2 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3)
DRAM CLK = 408 MHz
DRAM zq value: 000039bb
DRAM size = 64 MB
Succeed in reading Boot1 file head.
Jump to secend Boot.
[ 0.088]
U-Boot 2011.09-rc1-00000-g79832e3-dirty (Mar 23 2018 - 20:45:30) Allwinner Technology
[ 0.098]version: 1.1.0
[ 0.103]pmbus:
ready
axp read error
probe axp20x failed
axp_probe fail,run clock=912
set power on vol to default
axp_set_power_supply_output dcdc2_vol = 1250
axp set dcdc2_vol to 1250 failed
axp_set_power_supply_output dcdc3_vol = 3300
axp set dcdc3_vol to 3300 failed
axp_set_power_supply_output aldo2_vol = 2500
axp set aldo2_vol to 2500 failed
axp_set_power_supply_output aldo3_vol = 3000
axp set aldo3_vol to 3000 failed
axp_set_power_supply_output ldo1_vol = 3300
axp set ldo1_vol to 3300 failed
axp_set_power_supply_output ldo2_vol = 3000
axp set ldo2_vol to 3000 failed
axp_set_power_supply_output ldo3_vol = 3000
axp set ldo3_vol to 3000 failed
fel key new mode
run key detect
no key found
[ 0.184]DRAM: 64 MiB
[debug_jaosn]:use the clock in sys_config
OK
[ 0.206]sunxi flash init ok
hello @flash_speed=1
env_relocate_spec storage_type = 3
In: serial
Out: serial
Err: serial
WORK_MODE_BOOT
read bootlogo partition successful,start_block=0x71a0,rblock=0x100 ,ret=256
Use decode 2x2 sampling
sunxi_read_bootlogo: jpg convert argb
[ 0.329]Hit any key to stop autoboot: 0
read boot or recovery all
try to read all
[ 0.617]sunxi flash read :offset 4000, 4194304 bytes OK
## Booting kernel from Legacy Image at 40007fc0 ...
Image Name: Linux-3.4.39
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2614776 Bytes = 2.5 MiB
Load Address: 40008000
Entry Point: 40008000
Verifying Checksum ... OK
XIP Kernel Image ... OK
OK
[ 0.671]
[ 0.000000] Booting Linux on physical CPU 0
[ 0.000000] Linux version 3.4.39 (hexing@ubuntu) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #345 Fri Mar 23 20:52:32 CST 2018
[ 0.000000] Machine: sun8i
[ 0.000000] Initialized persistent memory from 41d00800-41d107ff
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 16384
[ 0.000000] free_area_init_node: node 0, pgdat c0522b24, node_mem_map c05b1000
[ 0.000000] Normal zone: 128 pages used for memmap
[ 0.000000] Normal zone: 16256 pages, LIFO batch:3
[ 0.000000] script_init enter!
[ 0.000000] script_init exit!
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: console=ttyS0,115200 root=/dev/mtdblock2 init=/linuxrc loglevel=8 partitions= mac_addr= uid=1234567890 kmemleak=on rootfstype=jffs2
[ 0.000000] Memory: 64MB = 64MB total
[ 0.000000] Memory: 29292k/29292k available, 36244k reserved, 0K highmem
[ 0.000000] vmalloc : 0xc4800000 - 0xff000000 ( 936 MB)
[ 0.000000] .text : 0xc0008000 - 0xc048f000 (4636 kB)
[ 0.000000] .init : 0xc048f000 - 0xc04b2000 ( 140 kB)
[ 0.000000] .data : 0xc04b2000 - 0xc0523260 ( 453 kB)
[ 0.000000] .bss : 0xc0523284 - 0xc05b0a64 ( 566 kB)
[ 0.000000] NR_IRQS:544
[ 0.000000] 524 ahb1 set parent pll_periph0d2
[ 0.000000] Architected local timer running at 24.00MHz.
[ 0.000000] Switching to timer-based delay loop
[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000156] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=24000000)
[ 0.000179] pid_max: default: 32768 minimum: 301
[ 0.000329] Mount-cache hash table entries: 512
[ 0.000849] CPU: Testing write buffer coherency: ok
[ 0.001113] Setting up static identity map for 0x40367798 - 0x403677f0
[ 0.001769] devtmpfs: initialized
[ 0.003674] pinctrl core: initialized pinctrl subsystem
[ 0.004171] NET: Registered protocol family 16
[ 0.004542] DMA: preallocated 128 KiB pool for atomic coherent allocations
[ 0.004594] script_sysfs_init success
[ 0.004630] sunxi_dump_init success
[ 0.005386] gpiochip_add: registered GPIOs 0 to 223 on device: sunxi-pinctrl
[ 0.006314] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver
[ 0.006668] gpiochip_add: registered GPIOs 1024 to 1031 on device: axp-pinctrl
[ 0.007348] tsc2003 device registered
[ 0.007631] persistent_ram: uncorrectable error in header
[ 0.007645] persistent_ram: no valid data in buffer (sig = 0x00000003)
[ 0.014120] console [ram-1] enabled
[ 0.014538] [sunxi-module]: [sunxi-module.0] probe success
[ 0.014767] ++axp20_board_init!
[ 0.014959] axp driver uning configuration failed(801)
[ 0.015071] axp driver uning configuration failed(808)
[ 0.015550] script config pll_isp to 360 Mhz
[ 0.015688] Not Found clk pll_video in script
[ 0.015893] script config pll_ve to 360 Mhz
[ 0.016015] Not Found clk pll_periph0 in script
[ 0.016123] Not Found clk pll_de in script
[ 0.016320] sunxi_default_clk_init
[ 0.016428] try to set pll6ahb1 to 200000000
[ 0.016539] Error not get clk pll6ahb1
[ 0.016741] Error not get clk pll6ahb1try to set ahb1 to 200000000
[ 0.016961] try to set apb1 to 100000000
[ 0.017452] ===fe3o4==== sunxi_root_procfs_attach ret:0
[ 0.021302] bio: create slab <bio-0> at 0
[ 0.021668] pwm module init!
[ 0.023481] ion_mem.size = 30408704
[ 0.024168] SCSI subsystem initialized
[ 0.024505] usbcore: registered new interface driver usbfs
[ 0.024776] usbcore: registered new interface driver hub
[ 0.025029] usbcore: registered new device driver usb
[ 0.025363] twi_chan_cfg()342 - [twi0] has no twi_speed!
[ 0.025479] twi_chan_cfg()353 - [twi0] has no twi_regulator.
[ 0.025682] twi_chan_cfg()342 - [twi1] has no twi_speed!
[ 0.025792] twi_chan_cfg()353 - [twi1] has no twi_regulator.
[ 0.025993] sunxi_i2c_adap_init()1563 - Sunxi I2C init channel 0
[ 0.026219] sunxi_i2c_adap_init()1563 - Sunxi I2C init channel 1
[ 0.026526] ++sunxi_i2c_probe
[ 0.026681] twi_request_gpio()406 - Pinctrl init 0 ... [twi0]
[ 0.026987] twi_clk_write_reg()241 - twi_clk_write_reg: clk_n = 0, clk_m = 5
[ 0.027320] ++axp_i2c_probe!
[ 0.027617] sunxi_i2c_do_xfer()998 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x34)
[ 0.027829] axp20_board 0-0034: failed reading at 0x03
[ 0.028027] [AXP20-MFD] try to read chip id failed = -70!
[ 0.028137] axp mfd register failed
[ 0.028257] axp20_board: probe of 0-0034 failed with error -70
[ 0.028468] sunxi_i2c_probe()1250 - I2C: i2c-0: sunxi I2C adapter
[ 0.028582] sunxi_i2c_probe()1251 - TWI_CTL 0xf1c2ac0c: 0x00000040
[ 0.028785] sunxi_i2c_probe()1252 - TWI_STAT 0xf1c2ac10: 0x000000f8
[ 0.028987] sunxi_i2c_probe()1253 - TWI_CLK 0xf1c2ac14: 0x00000028
[ 0.029099] sunxi_i2c_probe()1254 - TWI_SRST 0xf1c2ac18: 0x00000000
[ 0.029301] sunxi_i2c_probe()1255 - TWI_EFR 0xf1c2ac1c: 0x00000000
[ 0.029429] ++sunxi_i2c_probe
[ 0.029575] twi_request_gpio()406 - Pinctrl init 1 ... [twi1]
[ 0.029776] twi_clk_write_reg()241 - twi_clk_write_reg: clk_n = 0, clk_m = 11
[ 0.030209] sunxi_i2c_probe()1250 - I2C: i2c-1: sunxi I2C adapter
[ 0.030329] sunxi_i2c_probe()1251 - TWI_CTL 0xf1c2b00c: 0x00000040
[ 0.030532] sunxi_i2c_probe()1252 - TWI_STAT 0xf1c2b010: 0x000000f8
[ 0.030645] sunxi_i2c_probe()1253 - TWI_CLK 0xf1c2b014: 0x00000058
[ 0.030848] sunxi_i2c_probe()1254 - TWI_SRST 0xf1c2b018: 0x00000000
[ 0.030960] sunxi_i2c_probe()1255 - TWI_EFR 0xf1c2b01c: 0x00000000
[ 0.031196] Linux video capture interface: v2.00
[ 0.031409] gpiochip_add: gpios 1024..1028 (axp_pin) failed to register
[ 0.031611] axp pinctrl used,skip
[ 0.032026] Advanced Linux Sound Architecture Driver Version 1.0.25.
[ 0.033160] cfg80211: Calling CRDA to update world regulatory domain
[ 0.034245] Switching to clocksource arch_sys_counter
[ 0.039940] NET: Registered protocol family 2
[ 0.039940] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.040560] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.040717] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.040937] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.041139] TCP: reno registered
[ 0.041252] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.041375] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.041841] NET: Registered protocol family 1
[ 0.042345] [pm]aw_pm_init!
[ 0.042555] standby_mode = 1.
[ 0.042665] wakeup src cnt is : 3.
[ 0.042779] pmu name: pmu1_para .
[ 0.042892] pmu1_enable = 0x1.
[ 0.043090] pmux_id = 0x1.
[ 0.043200] pmu name: pmu2_para .
[ 0.043309] config_pmux_para: script_parser_fetch err.
[ 0.043507] pmu2_enable = 0x0.
[ 0.043618] add_sys_pwr_dm: get ldo name failed
[ 0.043726] add_sys_pwr_dm: get ldo name failed
[ 0.043924] add_sys_pwr_dm: get ldo name failed
[ 0.044033] add_sys_pwr_dm: get ldo name failed
[ 0.044231] add_sys_pwr_dm: get ldo name failed
[ 0.044341] add_sys_pwr_dm: get ldo name failed
[ 0.044450] add_sys_pwr_dm: get ldo name failed
[ 0.044649] add_sys_pwr_dm: get ldo name failed
[ 0.044760] add_sys_pwr_dm: get ldo name failed
[ 0.044960] add_sys_pwr_dm: get ldo name failed
[ 0.045068] after inited: sys_mask config = 0x0.
[ 0.045178] dynamic_standby enalbe = 0x0.
[ 0.045422] sunxi_reg_init enter
[ 0.047254] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.047512] jffs2: version 2.2. (NAND) (SUMMARY) 漏 2001-2006 Red Hat, Inc.
[ 0.047819] msgmni has been set to 57
[ 0.048835] io scheduler noop registered
[ 0.049046] io scheduler deadline registered
[ 0.049222] io scheduler cfq registered (default)
[ 0.049834] [DISP]disp_module_init
[ 0.050418] cmdline,disp=
[ 0.051059] rotation_sw module is config as no used
[ 0.051282] [DISP] disp_get_rotation_sw,line:68:disp 0 out of range? g_rot_sw=0
[ 0.051498] [DISP] disp_init_connections,line:289:NULL pointer: 0, 0
[ 0.051875] disp_fb_to_var:format = 0
[ 0.051992] fb_para.width = 480,fb_para.height = 272,fb_para.buffer_num = 2
[ 0.052200] gen_pool_alloc:nbits = 255,size = 1044480,order = 12
[ 0.052312] chunk->start_addr = 0x42300000,chunk->end_addr = 0x43ffffffchunk->avail = 30408704
[ 0.052615] end_bit = 7424
[ 0.056445] [DISP] disp_sys_power_enable,line:387:some error happen, fail to get regulator
[ 0.056770] [DISP] disp_sys_gpio_set_value,line:374:OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[ 0.057734] [DISP]disp_module_init finish
[ 0.058159] sw_uart_get_devinfo()1503 - uart2 has no uart_regulator.
[ 0.058714] uart2: ttyS0 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[ 0.058835] sw_uart_pm()890 - uart2 clk is already enable
[ 0.059048] sw_console_setup()1233 - console setup baud 115200 parity n bits 8, flow n
[ 0.155036] console [ttyS0] enabled
[ 1.077551] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
[ 1.085399] spi spi0: master is unqueued, this is deprecated
[ 1.092050] m25p_probe()966 - Use the Dual Mode Read.
[ 1.097861] NorFlash ID: 0xef4019 - 0x0
[ 1.102351] m25p80 spi0.0: unrecognized JEDEC id ef4019
[ 1.108534] priv->phy_ext = INT_PHY
[ 1.113738] Failed to alloc md5
[ 1.117377] eth0: Use random mac address
[ 1.121939] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.149495] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.158558] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1
[ 1.167297] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000
[ 1.174103] [DISP] disp_lcd_pwm_enable,line:1022:pwm device hdl is NULL
[ 1.200039] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00
[ 1.207548] hub 1-0:1.0: USB hub found
[ 1.211950] hub 1-0:1.0: 1 port detected
[ 1.216858] sunxi-ehci sunxi-ehci.1: remove, state 1
[ 1.222612] usb usb1: USB disconnect, device number 1
[ 1.512667] sunxi-ehci sunxi-ehci.1: USB bus 1 deregistered
[ 1.529153] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.556214] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
[ 1.564968] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 1
[ 1.573627] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400
[ 1.644644] hub 1-0:1.0: USB hub found
[ 1.649020] hub 1-0:1.0: 1 port detected
[ 1.653981] sunxi-ohci sunxi-ohci.1: remove, state 1
[ 1.659607] usb usb1: USB disconnect, device number 1
[ 1.666021] sunxi-ohci sunxi-ohci.1: USB bus 1 deregistered
[ 1.682449] Initializing USB Mass Storage driver...
[ 1.688144] usbcore: registered new interface driver usb-storage
[ 1.694933] USB Mass Storage support registered.
[ 1.700597] file system registered
[ 1.706060] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 1.713860] android_usb gadget: Number of LUNs=1
[ 1.719087] lun0: LUN: removable file: (no medium)
[ 1.725109] android_usb gadget: android_usb ready
[ 1.730685] sunxikbd_script_init: key para not found, used default para.
[ 1.738906] tsc2003_ts_init
[ 1.742248] =====ctp_fetch_sysconfig_para=====.
[ 1.747480] ctp_fetch_sysconfig_para: ctp_power_ldo script_get_item err.
[ 1.755218] ctp_fetch_sysconfig_para: ctp_power_ldo_vol script_get_item err.
[ 1.763260] ctp_fetch_sysconfig_para: ctp_power_io script_get_item err.
[ 1.770896] script_get_item ctp_wakeup err
[ 1.775549] ctp_irq gpio number is 36
[ 1.779831] wakeup gpio_request is failed
[ 1.784449] =============GT82x Probe==================
[ 1.791012] sunxi_i2c_do_xfer()998 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x48)
[ 1.800414] i2c_write_bytes error -70
[ 1.804591] tsc2003: probe of 1-0048 failed with error -70
[ 1.811460] sunxi-rtc sunxi-rtc: rtc core: registered sunxi-rtc as rtc0
[ 1.819081] sunxi cedar version 0.1
[ 1.823325] [cedar]: install start!!!
[ 1.827768] [cedar]: install end!!!
[ 1.832253] platform reg-20-cs-dcdc2: Driver reg-20-cs-dcdc2 requests probe deferral
[ 1.841231] platform reg-20-cs-dcdc3: Driver reg-20-cs-dcdc3 requests probe deferral
[ 1.850175] platform reg-20-cs-ldo1: Driver reg-20-cs-ldo1 requests probe deferral
[ 1.858812] platform reg-20-cs-ldo2: Driver reg-20-cs-ldo2 requests probe deferral
[ 1.867560] platform reg-20-cs-ldo3: Driver reg-20-cs-ldo3 requests probe deferral
[ 1.876296] platform reg-20-cs-ldo4: Driver reg-20-cs-ldo4 requests probe deferral
[ 1.884953] platform reg-20-cs-ldoio0: Driver reg-20-cs-ldoio0 requests probe deferral
[ 1.893960] sunxi_wdt_init_module: sunxi WatchDog Timer Driver v1.0
[ 1.901311] sunxi_wdt_probe: devm_ioremap return wdt_reg 0xf1c20ca0, res->start 0x01c20ca0, res->end 0x01c20cbf
[ 1.912734] sunxi_wdt_probe: initialized (g_timeout=16s, g_nowayout=0)
[ 1.920405] wdt_enable, write reg 0xf1c20cb8 val 0x00000000
[ 1.926794] wdt_set_tmout, write 0x000000b0 to mode reg 0xf1c20cb8, actual timeout 16 sec
[ 1.936535] [mmc]: SD/MMC/SDIO Host Controller Driver(v1.114 2015-6-2 10:21) Compiled in Mar 23 2018 at 20:51:16
[ 1.948113] [mmc]: get mmc0's sdc_power failed
[ 1.953267] [mmc]: get mmc1's sdc_power failed
[ 1.958306] [mmc]: MMC host used card: 0x3, boot card: 0x0, io_card 2
[ 1.966531] [mmc]: sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 1.979850] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 1.992763] sunxi_leds_fetch_sysconfig_para leds is not used in config
[ 2.000252] =========script_get_err============
[ 2.005578] usbcore: registered new interface driver usbhid
[ 2.011991] usbhid: USB HID core driver
[ 2.016980] ashmem: initialized
[ 2.020758] logger: created 256K log 'log_main'
[ 2.026088] logger: created 32K log 'log_events'
[ 2.031491] logger: created 32K log 'log_radio'
[ 2.036746] logger: created 32K log 'log_system'
[ 2.043514] script_get_item return audio_pa_ctrl type err
[ 2.050493] asoc: sndcodec <-> sunxi-codec mapping ok
[ 2.058343] TCP: cubic registered
[ 2.062209] NET: Registered protocol family 17
[ 2.067459] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 2.076193] ThumbEE CPU extension supported.
[ 2.081156] Registering SWP/SWPB emulation handler
[ 2.087636] platform reg-20-cs-ldoio0: Driver reg-20-cs-ldoio0 requests probe deferral
[ 2.096796] platform reg-20-cs-ldo4: Driver reg-20-cs-ldo4 requests probe deferral
[ 2.105368] platform reg-20-cs-ldo3: Driver reg-20-cs-ldo3 requests probe deferral
[ 2.114021] platform reg-20-cs-ldo2: Driver reg-20-cs-ldo2 requests probe deferral
[ 2.122666] platform reg-20-cs-ldo1: Driver reg-20-cs-ldo1 requests probe deferral
[ 2.131222] platform reg-20-cs-dcdc3: Driver reg-20-cs-dcdc3 requests probe deferral
[ 2.140055] platform reg-20-cs-dcdc2: Driver reg-20-cs-dcdc2 requests probe deferral
[ 2.148955] sunxi-rtc sunxi-rtc: setting system clock to 1970-01-01 00:07:24 UTC (444)
[ 2.159193] [wifi module_pm]: select module num is 6
[ 2.164993] [wifi module_pm]: step [0] failed to fetch module_power0
[ 2.172162] [wifi module_pm]: mod has no chip_en gpio
[ 2.177956] [wifi module_pm]: failed to fetch lpo_use_apclk
[ 2.184600] [wifi_pm]: wifi gpio init is OK !!
[ 2.189831] platform reg-20-cs-dcdc2: Driver reg-20-cs-dcdc2 requests probe deferral
[ 2.198639]
[ 2.198642] *****Mar 23 2018 20:51:22 EAGLE DRIVER VER:75be56bfbaf7*****
[ 2.198649]
[ 2.209842] platform reg-20-cs-dcdc3: Driver reg-20-cs-dcdc3 requests probe deferral
[ 2.218773] =======================================================
[ 2.225943] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 2.233015] =======================================================
[ 2.240168] Espressif ESP8089 SDIO WiFi driver (Powered by Rockchip, Ver2.25(01/22/2016),Drv: 2.26) init.
[ 2.250997] [wifi_pm]: set wl_reg_on 1 !
[ 2.355623] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 2.365611] platform reg-20-cs-ldo1: Driver reg-20-cs-ldo1 requests probe deferral
[ 2.374165] [mmc]: sdc1 power_supply is null
[ 2.380350] platform reg-20-cs-ldo2: Driver reg-20-cs-ldo2 requests probe deferral
[ 2.388905] platform reg-20-cs-ldo3: Driver reg-20-cs-ldo3 requests probe deferral
[ 2.397664] platform reg-20-cs-ldo4: Driver reg-20-cs-ldo4 requests probe deferral
[ 2.406332] platform reg-20-cs-ldoio0: Driver reg-20-cs-ldoio0 requests probe deferral
[ 2.415252] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 2.442358] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 52, RTO !!
[ 2.451597] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 52, RTO !!
[ 2.459940] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 2.472709] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 2.484978] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 8, RTO !!
[ 2.493310] *******************Try sdio*******************
[ 2.500301] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5, RTO !!
[ 2.509429] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5, RTO !!
[ 2.518578] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5, RTO !!
[ 2.527623] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5, RTO !!
[ 2.535945] *******************Try sd *******************
[ 2.542856] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55, RTO !!
[ 2.552078] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55, RTO !!
[ 2.561303] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55, RTO !!
[ 2.570431] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55, RTO !!
[ 2.578852] *******************Try mmc*******************
[ 2.584953] [mmc]: sdc1 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 2.596223] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 1, RTO !!
[ 2.604553] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 2.614670] [mmc]: sdc1 power_supply is null
[ 2.622107] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 2.633482] [mmc]: sdc1 power_supply is null
[ 2.650035] [mmc]: sdc1 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 2.682603] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 52, RTO !!
[ 2.692101] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 52, RTO !!
[ 2.700434] [mmc]: sdc1 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 2.713403] [mmc]: sdc1 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 2.725962] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 8, RTO !!
[ 2.734196] *******************Try sdio*******************
[ 2.741555] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5, RTO !!
[ 2.750945] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5, RTO !!
[ 2.760248] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5, RTO !!
[ 2.769638] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5, RTO !!
[ 2.777976] *******************Try sd *******************
[ 2.785148] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55, RTO !!
[ 2.794642] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55, RTO !!
[ 2.804038] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55, RTO !!
[ 2.813532] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55, RTO !!
[ 2.821949] *******************Try mmc*******************
[ 2.823503] [mmc]: sdc1 set ios: clk 300000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 2.839592] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 1, RTO !!
[ 2.847926] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 2.857942] [mmc]: sdc1 power_supply is null
[ 2.865478] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 2.876754] [mmc]: sdc1 power_supply is null
[ 2.900022] [mmc]: sdc1 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 2.933135] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 52, RTO !!
[ 2.943074] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 52, RTO !!
[ 2.951506] [mmc]: sdc1 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 2.969751] [mmc]: sdc1 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 2.982860] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 8, RTO !!
[ 2.991095] *******************Try sdio*******************
[ 2.998980] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5, RTO !!
[ 3.008825] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5, RTO !!
[ 3.018755] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5, RTO !!
[ 3.028680] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5, RTO !!
[ 3.036917] *******************Try sd *******************
[ 3.044717] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55, RTO !!
[ 3.054686] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55, RTO !!
[ 3.064710] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55, RTO !!
[ 3.074736] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55, RTO !!
[ 3.083070] *******************Try mmc*******************
[ 3.084693] [mmc]: sdc1 set ios: clk 200000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 3.101372] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 1, RTO !!
[ 3.109610] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 3.119726] [mmc]: sdc1 power_supply is null
[ 3.127170] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 3.138544] [mmc]: sdc1 power_supply is null
[ 3.160029] [mmc]: sdc1 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 3.192603] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 52, RTO !!
[ 3.202100] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 52, RTO !!
[ 3.210522] [mmc]: sdc1 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 3.223401] [mmc]: sdc1 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 3.235965] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 8, RTO !!
[ 3.244287] *******************Try sdio*******************
[ 3.251555] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5, RTO !!
[ 3.265023] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5, RTO !!
[ 3.274425] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5, RTO !!
[ 3.283724] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5, RTO !!
[ 3.292052] *******************Try sd *******************
[ 3.299211] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55, RTO !!
[ 3.308701] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55, RTO !!
[ 3.318188] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55, RTO !!
[ 3.327588] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55, RTO !!
[ 3.336024] *******************Try mmc*******************
[ 3.342219] [mmc]: sdc1 set ios: clk 150000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 3.353672] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 1, RTO !!
[ 3.362003] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 3.372114] [mmc]: sdc1 power_supply is null
串口2输出正常了!
晕哥,固件烧录只烧录了4s就显示成功了,是啥情况啊
leozlee 说:晕哥,固件烧录只烧录了4s就显示成功了,是啥情况啊
可以接调试串口, 通过调试串口可以看到错误信息。
官方的烧录软件是先把 u-boot 下载到dram, 把u-boot跑起来再和烧录软件通讯。
U-Boot 2011.09-rc1-dirty (Jun 16 2015 - 13:24:29) Allwinner Technology
[ 2.233]version: 1.1.0
[ 2.238]pmbus:
===i2c gpio === 22777777
ready
axp read error
probe axp20x failed
axp_probe fail,run clock=1008
axp_set_power_supply_output dcdc2_vol = 1200
axp set dcdc2_vol to 1200 failed
[ 2.299]DRAM: 64 MiB
save config for small mem_size
workmode = 16
OK
spinor id is 0
try nor successed
sunxi sprite has installed spi function
read flash error
In: serial
Out: serial
Err: serial
mbr not exist
[ 2.374]Hit any key to stop autoboot: 0
work mode=0x10
run usb efex
delay time 2500
usb init ok
set address 0x3e
SUNXI_EFEX_ERASE_TAG
erase_flag = 0x0
FEX_CMD_fes_verify_status
FEX_CMD_fes_verify last err=0
sunxi spinor is already inited
flash size =16 M
algin 512 byte fullimg_size 13697024
before sunxi_sprite_setdata_finish
spinor_datafinish
spinor id = 0x0
_spinor_wrsr status is 0
begin to erase all ..
status = 0
count = 1134783053
spinor has erasered
total write bytes = 13697024
start = 0x0, cnt=0x6880
nor_page_cnt=53504
nor_page_cnt=511
nor_page_cnt=1023
nor_page_cnt=1535
nor_page_cnt=2047
nor_page_cnt=2559
nor_page_cnt=3071
nor_page_cnt=3583
nor_page_cnt=4095
nor_page_cnt=4607
nor_page_cnt=5119
nor_page_cnt=5631
nor_page_cnt=6143
nor_page_cnt=6655
nor_page_cnt=7167
nor_page_cnt=7679
nor_page_cnt=8191
nor_page_cnt=8703
nor_page_cnt=9215
nor_page_cnt=9727
nor_page_cnt=10239
nor_page_cnt=10751
nor_page_cnt=11263
nor_page_cnt=11775
nor_page_cnt=12287
nor_page_cnt=12799
nor_page_cnt=13311
nor_page_cnt=13823
nor_page_cnt=14335
nor_page_cnt=14847
nor_page_cnt=15359
nor_page_cnt=15871
nor_page_cnt=16383
nor_page_cnt=16895
nor_page_cnt=17407
nor_page_cnt=17919
nor_page_cnt=18431
nor_page_cnt=18943
nor_page_cnt=19455
nor_page_cnt=19967
nor_page_cnt=20479
nor_page_cnt=20991
nor_page_cnt=21503
nor_page_cnt=22015
nor_page_cnt=22527
nor_page_cnt=23039
nor_page_cnt=23551
nor_page_cnt=24063
nor_page_cnt=24575
nor_page_cnt=25087
nor_page_cnt=25599
nor_page_cnt=26111
nor_page_cnt=26623
nor_page_cnt=27135
nor_page_cnt=27647
nor_page_cnt=28159
nor_page_cnt=28671
nor_page_cnt=29183
nor_page_cnt=29695
nor_page_cnt=30207
nor_page_cnt=30719
nor_page_cnt=31231
nor_page_cnt=31743
nor_page_cnt=32255
nor_page_cnt=32767
nor_page_cnt=33279
nor_page_cnt=33791
nor_page_cnt=34303
nor_page_cnt=34815
nor_page_cnt=35327
nor_page_cnt=35839
nor_page_cnt=36351
nor_page_cnt=36863
nor_page_cnt=37375
nor_page_cnt=37887
nor_page_cnt=38399
nor_page_cnt=38911
nor_page_cnt=39423
nor_page_cnt=39935
nor_page_cnt=40447
nor_page_cnt=40959
nor_page_cnt=41471
nor_page_cnt=41983
nor_page_cnt=42495
nor_page_cnt=43007
nor_page_cnt=43519
nor_page_cnt=44031
nor_page_cnt=44543
nor_page_cnt=45055
nor_page_cnt=45567
nor_page_cnt=46079
nor_page_cnt=46591
nor_page_cnt=47103
nor_page_cnt=47615
nor_page_cnt=48127
nor_page_cnt=48639
nor_page_cnt=49151
nor_page_cnt=49663
nor_page_cnt=50175
nor_page_cnt=50687
nor_page_cnt=51199
nor_page_cnt=51711
nor_page_cnt=52223
nor_page_cnt=52735
nor_page_cnt=53247
spinor download data ok
sunxi_efex_next_action=2
exit usb
next work 2
SUNXI_UPDATE_NEXT_ACTION_REBOOT
set next mode 14
drv_disp_exit
[ 9.306][mmc]: MMC Device 2 not found
[ 9.310][mmc]: mmc Wot find,so not exit
sunxi spinor has not inited
beign to init dram
DRAM CLK = 360 MHz
DRAM size = 64 MB
init dram ok
fes1 reg_val=7
[ 2.238]
查看串口发现一直在这个过程
后来我用另外一个软件(PhoenixCard_V310),制作了一张启动卡,可以看到和你贴出的log一样的信息,不过好像没有出现那几个 摄像头模式的按钮?
你的是 V3s 还是 S3 ?
V3s
leozlee 说:后来我用另外一个软件(PhoenixCard_V310),制作了一张启动卡,可以看到和你贴出的log一样的信息,不过好像没有出现那几个 摄像头模式的按钮?
哪个按钮?
就是显示屏上的那三个button
是的
你的那个固件是只能用flash启动的吗?
对, 应该只支持 flash
我直接用PhoenixCard.exe这个软件做了一个启动卡,然后查到核心板的tf卡卡槽,
最后启动到下面就卡住了。
[ 57.278196] init: processing action 0x1e481c8 (boot)
[ 57.284247] init: command 'ifup' r=0
[ 57.288574] init: command 'hostname' r=0
[ 57.293137] init: command 'domainname' r=0
[ 57.297806] init: command 'setrlimit' r=0
[ 57.302563] init: command 'chown' r=0
[ 57.306763] init: cannot find '/system/bin/servicemanager', disabling 'servicemanager'
[ 57.315902] init: cannot find '/system/bin/vold', disabling 'vold'
[ 57.322911] init: cannot find '/system/bin/mediaserver', disabling 'media'
[ 57.330803] init: cannot find '/system/bin/startup_music', disabling 'startupSound'
[ 57.339509] init: command 'class_start' r=0
[ 57.344297] init: cannot find '/system/bin/ccdr', disabling 'ccdr'
[ 57.351281] init: command 'class_start' r=0
[ 57.356029] init: processing action 0x1e48fd0 (boot)
[ 57.361665] init: starting 'adbd'
[ 57.365907] init: command 'start' r=0
[ 57.370540] init: Created socket '/dev/socket/adbd' with mode '660', user '1000', group '1000'
[ 57.380550] init: cannot find '/system/bin/debuggerd', disabling 'debuggerd'
[ 57.388498] init: command 'start' r=0
[ 57.394427] adb_open
[ 57.397170] init: cannot find '/system/bin/standbyservice', disabling 'standby'
[ 57.406115] init: command 'start' r=0
[ 57.410464] init: processing action 0x1e4a4f8 (queue_property_triggers)
[ 57.417973] init: command 'queue_property_triggers' r=0
[ 57.424003] init: processing action 0x1e484a8 (property:ro.debuggable=1)
[ 57.431614] init: cannot find '/system/bin/sh', disabling 'console'
[ 57.438762] init: command 'start' r=0
看起来好像是缺文件,是不是烧录不完整
看起来好像是缺文件,是不是烧录不完整
我是直接烧录在一个tf卡上的,不知道有没有关系
您好,我想给v3s烧固件,选择文件后提示固件文件打开失败,这个是什么原因造成的?
可能是固件不完整, 打包有问题。
可能是固件不完整, 打包有问题。
固件是我用fel从v3s的flash中读出来的,文件名为XXX.img,请问这样有什么问题吗?
从flash读出来应该用sunxi-fel烧录: https://whycan.cn/t_444.html
不能用官方烧录软件了。
好的,如果要用PhoneixSuit烧固件的话,固件应该怎么打包呢?
晕哥,固件烧录只烧录了4s就显示成功了,是啥情况啊 遇到相同问题不知怎么解决 V3S
S2键在哪里呀
有点旧了的版本
