楼主 #1 2020-03-07 22:09:21
异乡是故乡
已发帖子: 74
请问为什么AIR720 4G模块插入到V3s linux4.13系统, 只有一个 RNDIS 设备, 确没有像 Windows再多四个串口
只有一个 RNDIS 设备,
确没有像 Windows再多四个串口.
这是为什么呢?
楼主 #2 2020-03-07 22:10:09
异乡是故乡
已发帖子: 74
Re: 请问为什么AIR720 4G模块插入到V3s linux4.13系统, 只有一个 RNDIS 设备, 确没有像 Windows再多四个串口
[  595.249458] usb 1-1: new high-speed USB device number 2 using ehci-platform
[  595.446965] rndis_host 1-1:1.0 eth1: register 'rndis_host' at usb-1c1a000.usb-1, RNDIS device, ac:a9:de:f8:f1:75
这是驱动输出的记录.
楼主 #3 2020-03-07 22:12:38
异乡是故乡
已发帖子: 74
插入 ubuntu 18.04 也是这样:
[699934.369537] usb 3-2.1: USB disconnect, device number 19
[699934.369614] rndis_host 3-2.1:1.0 enxaca9def8f175: unregister 'rndis_host' usb-0000:03:00.0-2.1, RNDIS device
[699936.475885] usb 3-2.1: new high-speed USB device number 20 using xhci_hcd
[699936.689810] usb 3-2.1: New USB device found, idVendor=1286, idProduct=4e3d, bcdDevice= 1.00
[699936.689812] usb 3-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[699936.689813] usb 3-2.1: Product: Mobile Composite Device Bus
[699936.689814] usb 3-2.1: Manufacturer: Marvell
[699936.689815] usb 3-2.1: SerialNumber: 200806006809080000
[699936.702012] rndis_host 3-2.1:1.0 eth0: register 'rndis_host' at usb-0000:03:00.0-2.1, RNDIS device, ac:a9:de:f8:f1:75
[699936.749105] rndis_host 3-2.1:1.0 enxaca9def8f175: renamed from eth0
楼主 #4 2020-03-07 22:27:03
异乡是故乡
已发帖子: 74
终于找到官方的文档了,
原来要打开 /dev/ttyUSB* 需要修改内核配置和源码:
https://ask.openluat.com/article/79
上面链接的云备份: air720_linux_rndis_ttyUSB.pdf
楼主 #5 2020-03-07 23:14:26
异乡是故乡
已发帖子: 74
费了九牛二虎之力终于搞定.
[   44.119061] usb 1-1: new high-speed USB device number 2 using ehci-platform
[   44.317009] rndis_host 1-1:1.0 eth1: register 'rndis_host' at usb-1c1a000.usb-1, RNDIS device, ac:92:48:f9:ea:08
[   44.380705] option 1-1:1.2: GSM modem (1-port) converter detected
[   44.411618] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB0
[   44.445448] option 1-1:1.3: GSM modem (1-port) converter detected
[   44.474551] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB1
[   44.491664] option 1-1:1.4: GSM modem (1-port) converter detected
[   44.524489] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB2
先按这个改: https://ask.openluat.com/article/37
再按这个改: https://ask.openluat.com/article/79
#6 2020-03-23 06:22:45
有梦的地方
已发帖子: 284
感觉步骤有点复杂,不过还好参考楼主终于改好了,只是还有一个问题,为什么要这样改呢?
#7 2020-03-23 08:48:07
晕哥小弟
已发帖子: 309
昨天刷抖音,刷到一个视频,说是这个4G模块,在遇到物联网卡的时候,会有点乱.具体不详.
#8 2020-05-16 11:09:55
流氓兔
已发帖子: 121
AIR724插到我的A64板子也是只能显示RNDIS设备, 那几个虚拟串口没有哦,可以用这个方法改出来吗?
#9 2020-06-03 08:17:54
CAT.1
传一个 Q群的 Ubuntu 16.04 4.4.0内核的修改: v4_4_1.7z
这样就不用完全编译内核,
只要编译这个模块就行了:
make & make install
#10 2020-06-03 15:09:41
8629002
正好需要这些的资料,找了好久终于找到了
#11 2021-04-06 10:52:32
所在地: 你猜
已发帖子: 3,387
modprobe usbserial
echo 1782 4e00 > /sys/bus/usb-serial/drivers/generic/new_id
查看设备:
# ls /dev/ttyUSB* -l
crw-rw----    1 root     dialout   188,   0 Jan  1 00:01 /dev/ttyUSB0
crw-rw----    1 root     dialout   188,   1 Jan  1 00:01 /dev/ttyUSB1
crw--w----    1 root     root      188,   2 Jan  1 00:01 /dev/ttyUSB2
crw--w----    1 root     root      188,   3 Jan  1 00:01 /dev/ttyUSB3
#12 2021-04-06 13:59:42
sy373466062
已发帖子: 130
modprobe usbserial
查看设备:
这个好,不用改内核代码。
