如题
终端打印
[ 0.000000] Linux version 5.2.0-licheepi-zero+ (paulwu@paulwu-virtual-machine) (gcc version 7.5.0 (Ubuntu/Linaro 7.5.0-3ubuntu1~18.04)) #41 SMP Tue Mar 10 23:13:46 PDT 2020
[ 0.000000] OF: fdt: Machine model: Lichee Pi Zero with Dock
[ 0.000000] percpu: Embedded 16 pages/cpu s34508 r8192 d22836 u65536
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16129
[ 0.000000] Kernel command line: console=tty0 console=ttyS0,115200 panic=5 rootwait root=/dev/mmcblk0p2 earlyprintk rw vt.global_cursor_default=0
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.000000] Memory: 51424K/65024K available (8192K kernel code, 319K rwdata, 2016K rodata, 1024K init, 269K bss, 13600K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] random: get_random_bytes called from start_kernel+0x2fc/0x488 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[ 0.000019] Switching to timer-based delay loop, resolution 41ns
[ 0.000204] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000441] Console: colour dummy device 80x30
[ 0.000738] printk: console [tty0] enabled
[ 0.000793] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000823] pid_max: default: 32768 minimum: 301
[ 0.000991] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.001022] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.001835] CPU: Testing write buffer coherency: ok
[ 0.002401] /cpus/cpu@0 missing clock-frequency property
[ 0.002449] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.003303] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.003560] rcu: Hierarchical SRCU implementation.
[ 0.004134] smp: Bringing up secondary CPUs ...
[ 0.004175] smp: Brought up 1 node, 1 CPU
[ 0.004193] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.004207] CPU: All CPU(s) started in SVC mode.
[ 0.005287] devtmpfs: initialized
[ 0.008934] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.009282] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.009333] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[ 0.009587] pinctrl core: initialized pinctrl subsystem
[ 0.010726] NET: Registered protocol family 16
[ 0.011316] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.012617] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.012665] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.038941] SCSI subsystem initialized
[ 0.039258] usbcore: registered new interface driver usbfs
[ 0.039340] usbcore: registered new interface driver hub
[ 0.039462] usbcore: registered new device driver usb
[ 0.039737] mc: Linux media interface: v0.10
[ 0.039792] videodev: Linux video capture interface: v2.00
[ 0.040093] Advanced Linux Sound Architecture Driver Initialized.
[ 0.042095] clocksource: Switched to clocksource arch_sys_counter
[ 0.053867] NET: Registered protocol family 2
[ 0.054698] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.054769] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.054807] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.054840] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.054995] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.055058] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.055385] NET: Registered protocol family 1
[ 0.056331] RPC: Registered named UNIX socket transport module.
[ 0.056376] RPC: Registered udp transport module.
[ 0.056390] RPC: Registered tcp transport module.
[ 0.056402] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.058959] Initialise system trusted keyrings
[ 0.059390] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.067757] NFS: Registering the id_resolver key type
[ 0.067841] Key type id_resolver registered
[ 0.067857] Key type id_legacy registered
[ 0.067887] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.103864] Key type asymmetric registered
[ 0.103911] Asymmetric key parser 'x509' registered
[ 0.104022] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.104052] io scheduler mq-deadline registered
[ 0.104067] io scheduler kyber registered
[ 0.109259] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.109731] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pb not found, using dummy regulator
[ 0.110592] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[ 0.179327] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.182706] printk: console [ttyS0] disabled
[ 0.203025] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 36, base_baud = 1500000) is a U6_16550A
[ 0.764809] printk: console [ttyS0] enabled
[ 0.790741] 1c28800.serial: ttyS1 at MMIO 0x1c28800 (irq = 37, base_baud = 1500000) is a U6_16550A
[ 0.801761] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pe not found, using dummy regulator
[ 0.837510] panel-simple panel: panel supply power not found, using dummy regulator
[ 0.847024] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
[ 0.858930] libphy: Fixed MDIO Bus: probed
[ 0.863847] PPP generic driver version 2.4.2
[ 0.868510] PPP BSD Compression module registered
[ 0.873305] PPP Deflate Compression module registered
[ 0.878379] PPP MPPE Compression module registered
[ 0.883200] NET: Registered protocol family 24
[ 0.887935] usbcore: registered new interface driver asix
[ 0.893497] usbcore: registered new interface driver ax88179_178a
[ 0.899639] usbcore: registered new interface driver cdc_ether
[ 0.905563] usbcore: registered new interface driver net1080
[ 0.911289] usbcore: registered new interface driver cdc_subset
[ 0.917286] usbcore: registered new interface driver zaurus
[ 0.922949] usbcore: registered new interface driver simcom_wwan
[ 0.929005] usbcore: registered new interface driver sierra_net
[ 0.935007] usbcore: registered new interface driver cdc_ncm
[ 0.940670] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.947219] ehci-platform: EHCI generic platform driver
[ 0.952774] ehci-platform 1c1a000.usb: EHCI Host Controller
[ 0.958406] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[ 0.966415] ehci-platform 1c1a000.usb: irq 27, io mem 0x01c1a000
[ 1.002069] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[ 1.009320] hub 1-0:1.0: USB hub found
[ 1.013292] hub 1-0:1.0: 1 port detected
[ 1.017959] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.024315] ohci-platform: OHCI generic platform driver
[ 1.029892] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[ 1.036640] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[ 1.044637] ohci-platform 1c1a400.usb: irq 28, io mem 0x01c1a400
[ 1.117149] hub 2-0:1.0: USB hub found
[ 1.121007] hub 2-0:1.0: 1 port detected
[ 1.128676] usbcore: registered new interface driver usb-storage
[ 1.135003] usbcore: registered new interface driver usbserial_generic
[ 1.141589] usbserial: USB Serial support registered for generic
[ 1.147713] usbcore: registered new interface driver option
[ 1.153369] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.160540] usbcore: registered new interface driver qcserial
[ 1.166416] usbserial: USB Serial support registered for Qualcomm USB modem
[ 1.173983] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 1.185512] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.191302] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[ 1.200748] hub 3-0:1.0: USB hub found
[ 1.204758] hub 3-0:1.0: 1 port detected
[ 1.210938] sun6i-rtc 1c20400.rtc: registered as rtc0
[ 1.216144] sun6i-rtc 1c20400.rtc: RTC enabled
[ 1.220799] i2c /dev entries driver
[ 1.225748] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pe not found, using dummy regulator
[ 1.237260] bm_cw2015_init
[ 1.240090] cw2015_probe...
[ 1.334045] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.342889] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
[ 1.379753] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[ 1.387079] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
[ 1.422170] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB
[ 1.430471] usbcore: registered new interface driver usbhid
[ 1.436157] usbhid: USB HID core driver
[ 1.442488] sun4i-codec 1c22c00.codec: ASoC: codec-analog@01c23000 not registered
[ 1.450024] sun4i-codec 1c22c00.codec: Failed to register our card
[ 1.457620] Initializing XFRM netlink socket
[ 1.461953] NET: Registered protocol family 17
[ 1.467009] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 1.474727] Key type dns_resolver registered
[ 1.479265] Registering SWP/SWPB emulation handler
[ 1.485481] Loading compiled-in X.509 certificates
[ 1.495734] simple-framebuffer 43f80000.framebuffer: framebuffer at 0x43f80000, 0x7f800 bytes, mapped to 0x(ptrval)
[ 1.506357] simple-framebuffer 43f80000.framebuffer: format=x8r8g8b8, mode=480x272x32, linelength=1920
[ 1.518828] Console: switching to colour frame buffer device 60x34
[ 1.527445] simple-framebuffer 43f80000.framebuffer: fb0: simplefb registered!
[ 1.537766] sun4i-drm display-engine: bound 1100000.mixer (ops 0xc094b380)
[ 1.549167] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc094867c)
[ 1.560714] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.571172] [drm] No driver support for vblank timestamp query.
[ 1.580971] fb0: switching to sun4i-drm-fb from simple
[ 1.589204] Console: switching to colour dummy device 80x30
[ 1.596013] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[ 1.606920] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.618850] mmc0: new high speed SDHC card at address aaaa
[ 1.620818] mmcblk0: mmc0:aaaa SA08G 7.40 GiB
[ 1.623423] mmcblk0: p1 p2
[ 1.626888] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.628393] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.629887] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.632578] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.646592] random: fast init done
[ 1.647213] mmc1: new high speed SDIO card at address 0001
[ 1.650913] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43362-sdio for chip BCM43362/1
[ 1.651144] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43362-sdio.bin failed with error -2
[ 1.704014] usb-storage 1-1:1.0: USB Mass Storage device detected
[ 1.704648] scsi host0: usb-storage 1-1:1.0
[ 1.931135] Console: switching to colour frame buffer device 128x37
[ 2.069133] sun4i-drm display-engine: fb0: sun4i-drmdrmfb frame buffer device
[ 2.081121] debugfs: Directory '1c22c00.codec' with parent 'V3s Audio Codec' already present!
[ 2.093528] sun4i-codec 1c22c00.codec: ASoC: Failed to create component debugfs directory: -17
[ 2.107517] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[ 2.119907] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01T01:56:29 UTC (6989)
[ 2.132272] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 2.147666] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 2.158272] vcc3v0: disabling
[ 2.165068] vcc5v0: disabling
[ 2.171658] ALSA device list:
[ 2.178208] #0: V3s Audio Codec
[ 2.185926] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 2.198381] cfg80211: failed to load regulatory.db
[ 2.252896] EXT4-fs (mmcblk0p2): warning: mounting fs with errors, running e2fsck is recommended
[ 2.269809] EXT4-fs (mmcblk0p2): recovery complete
[ 2.280318] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.292399] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 2.304252] devtmpfs: mounted
[ 2.312396] Freeing unused kernel memory: 1024K
[ 2.320927] Run /sbin/init as init process
[ 2.458899] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)brcmfmac43362-sdio.bin 和brcmfmac43362-sdio.txt都放到lib/firmware/brcm里了
https://blog.csdn.net/mike8825/article/details/51171055
https://github.com/torvalds/linux/blob/master/include/uapi/asm-generic/errno-base.h
/* SPDX-License-Identifier: GPL-2.0 WITH Linux-syscall-note */
#ifndef _ASM_GENERIC_ERRNO_BASE_H
#define _ASM_GENERIC_ERRNO_BASE_H
#define EPERM 1 /* Operation not permitted */
#define ENOENT 2 /* No such file or directory */
#define ESRCH 3 /* No such process */
#define EINTR 4 /* Interrupted system call */
#define EIO 5 /* I/O error */
#define ENXIO 6 /* No such device or address */
#define E2BIG 7 /* Argument list too long */
#define ENOEXEC 8 /* Exec format error */
#define EBADF 9 /* Bad file number */
#define ECHILD 10 /* No child processes */
#define EAGAIN 11 /* Try again */
#define ENOMEM 12 /* Out of memory */
#define EACCES 13 /* Permission denied */
#define EFAULT 14 /* Bad address */
#define ENOTBLK 15 /* Block device required */
#define EBUSY 16 /* Device or resource busy */
#define EEXIST 17 /* File exists */
#define EXDEV 18 /* Cross-device link */
#define ENODEV 19 /* No such device */
#define ENOTDIR 20 /* Not a directory */
#define EISDIR 21 /* Is a directory */
#define EINVAL 22 /* Invalid argument */
#define ENFILE 23 /* File table overflow */
#define EMFILE 24 /* Too many open files */
#define ENOTTY 25 /* Not a typewriter */
#define ETXTBSY 26 /* Text file busy */
#define EFBIG 27 /* File too large */
#define ENOSPC 28 /* No space left on device */
#define ESPIPE 29 /* Illegal seek */
#define EROFS 30 /* Read-only file system */
#define EMLINK 31 /* Too many links */
#define EPIPE 32 /* Broken pipe */
#define EDOM 33 /* Math argument out of domain of func */
#define ERANGE 34 /* Math result not representable */
#endif看起来是目录或文件不存在: No such file or directory
/* SPDX-License-Identifier: GPL-2.0 WITH Linux-syscall-note */ #ifndef _ASM_GENERIC_ERRNO_BASE_H #define _ASM_GENERIC_ERRNO_BASE_H #define EPERM 1 /* Operation not permitted */ #define ENOENT 2 /* No such file or directory */ #define ESRCH 3 /* No such process */ #define EINTR 4 /* Interrupted system call */ #define EIO 5 /* I/O error */ #define ENXIO 6 /* No such device or address */ #define E2BIG 7 /* Argument list too long */ #define ENOEXEC 8 /* Exec format error */ #define EBADF 9 /* Bad file number */ #define ECHILD 10 /* No child processes */ #define EAGAIN 11 /* Try again */ #define ENOMEM 12 /* Out of memory */ #define EACCES 13 /* Permission denied */ #define EFAULT 14 /* Bad address */ #define ENOTBLK 15 /* Block device required */ #define EBUSY 16 /* Device or resource busy */ #define EEXIST 17 /* File exists */ #define EXDEV 18 /* Cross-device link */ #define ENODEV 19 /* No such device */ #define ENOTDIR 20 /* Not a directory */ #define EISDIR 21 /* Is a directory */ #define EINVAL 22 /* Invalid argument */ #define ENFILE 23 /* File table overflow */ #define EMFILE 24 /* Too many open files */ #define ENOTTY 25 /* Not a typewriter */ #define ETXTBSY 26 /* Text file busy */ #define EFBIG 27 /* File too large */ #define ENOSPC 28 /* No space left on device */ #define ESPIPE 29 /* Illegal seek */ #define EROFS 30 /* Read-only file system */ #define EMLINK 31 /* Too many links */ #define EPIPE 32 /* Broken pipe */ #define EDOM 33 /* Math argument out of domain of func */ #define ERANGE 34 /* Math result not representable */ #endif看起来是目录或文件不存在: No such file or directory
晕哥,我目录和文件都对的
楼主现在可以了吗?
问题已找到,是驱动早于rootfs加载,所以驱动不能编译到内核,只能编译为模块,然后加载,否则就会找不到固件
# [ 232.527064] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43362-sdio for chip BCM43362/1
# [ 235.282051] brcmfmac: brcmf_sdio_bus_rxctl: resumed on timeout
[ 235.291898] ieee80211 phy1: brcmf_bus_started: failed: -110
[ 235.301435] ieee80211 phy1: brcmf_attach: dongle is not responding: err=-110
[ 235.313568] brcmfmac: brcmf_sdio_firmware_callback: brcmf_attach failed
新问题又来了
linux 5.X 内核wifi有bug, 请大家注意。具体请看
https://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211.git/commit/?id=91046d6364afde646734c7ead1f649d253c386e9
终于驱动起来了
brcmf: wifi@1 {
reg = <1>;
compatible = "brcm,bcm4329-fmac";
最后不要中断,否则会出现超时
最近编辑记录 wupaul2001 (2020-03-12 16:52:29)
也就是说wifi驱动没有bug,设备树配置修改就可以了?
不是,内核,驱动,设备树配置都得改
# modprobe b43
[ 400.918519] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 400.932915] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 400.939866] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 400.948587] cfg80211: failed to load regulatory.db
[ 401.006569] Broadcom 43xx driver loaded [ Features: NLS ]哪位朋友 AP6212 出现这个错误的?请问怎么解决呢?
搞定了 http://cpp.io/blog/viewpost.do?p=4745
linux wifi regulatory database在新版本kernel中的更改
Date: 2018-04-25 12:37
更新linux kernel后经常会遇到这样的错误信息:“Direct firmware load for regulatory.db failed”
这是因为新版本的kernel更改了load regulatory.db 的方式
解决办法是手动从https://mirrors.edge.kernel.org/pub/software/network/wireless-regdb/ 下载最新的包,解压缩后把regulatory.db regulatory.db.p7s 复制到/lib/firmware即可然后reboot,看到这样的信息就对了
"cfg80211: Loading compiled-in X.509 certificates for regulatory database"参考:https://wireless.wiki.kernel.org/en/developers/regulatory/wireless-regdb
但是网卡还是不能正常工作。
原来如此, 怪不得一般WIFI驱动都用模块ko形式加载呢。
