楼主 #1 2018-12-26 22:19:34
已发帖子: 9,444
自动定时备份 debugdump(whycan) 数据库并发送到邮箱
1. 数据库备份
mysqldump -u root -p bb -ppasswd > /tmp/backup_debugdump.txt
2. 安装 sendmail:
sudo apt-get install sendmail
命令行测试发送邮件: echo “邮件正文” | mail -s 邮件主题 516333132@qq.com
3. 安装定时任务软件
sudo apt-get install cron
service cron restart
4. 编写定时执行脚本 /usr/bin/backup_db.sh:
echo `date` >> /tmp/cron.log
echo “数据库备份” | mail -s 数据库备份 -a /tmp/backup_debugdump.txt 516333132@qq.com
5. 编辑定时任务, 5分钟执行一次 /usr/bin/backup_db.sh
# m h  dom mon dow   command
*/5 * * * * /usr/bin/backup_db.sh
楼主 #2 2018-12-26 22:25:48
已发帖子: 9,444
Re: 自动定时备份 debugdump(whycan) 数据库并发送到邮箱
楼主 #3 2018-12-27 09:31:02
已发帖子: 9,444
*/59 * * * * /usr/bin/backup_db.sh
奇怪了,以上配置,会在59分和00分都执行一次:
root@ubuntu:~# cat /tmp/cron.log
Wed Dec 26 19:59:01 EST 2018
Wed Dec 26 20:00:02 EST 2018
Wed Dec 26 20:59:01 EST 2018
Wed Dec 26 21:00:02 EST 2018
#4 2018-12-27 10:49:07
雷龙发展q2852826868
已发帖子: 157
支持下晕哥。
楼主 #5 2019-02-09 23:56:41
已发帖子: 9,444
mail 命令没有搞定发件人, 继续试一试 sendmail:
dbus-daemon --system
hostnamectl set-hostname whycan.cn
sendmail   -t -f'noreply@whycan.cn' << EOF
Sender:noreply
To:admin@whycan.cn
Cc:516333132@qq.com
Subject: 挖坑网测试邮件
This is the mail content ...
debugdump
挖坑网发送邮件
EOF
楼主 #6 2019-02-10 11:06:21
已发帖子: 9,444
mail 命令所有的参数都在这里: http://manpages.ubuntu.com/manpages/bionic/man1/bsd-mailx.1.html
ds and backwards, or simply enter a message number to
     move directly.
   Disposing of mail
     After examining a message you can delete (d) or reply (r) to it.  Deletion causes the mail
     program to forget about the message.  This is not irreversible; the message can be undeleted
     (u) by giving its number, or the mail session can be aborted by giving the exit (x) command.
     Deleted messages, however, will usually disappear, never to be seen again.
   Specifying messages
     Commands such as print and delete can be given a list of message numbers as arguments to
     apply to a number of messages at once.  Thus delete 1 2 deletes messages 1 and 2, while
     delete 1-5 deletes messages 1 through 5.
     Messages may also be selected using one of the following categories:
           *       all messages
           $       last message
           :d      deleted messages
           :n      new messages
           :o      old messages
           :r      read messages
           :u      unread messages
     Thus the command top, which prints the first few lines of a message, could be used in top *
     to print the first few lines of all messages.
   Replying to or originating mail
     You can use the reply command to set up a response to a message, sending it back to the
     person who it was from.  Text you then type in, up to an end-of-file, defines the contents
     of the message.  While you are composing a message, mail treats lines beginning with the
     tilde (‘~’) character specially.  For instance, typing ~m (alone on a line) will place a
     copy of the current message into the response, right shifting it by a single tab-stop (see
     the indentprefix variable, below).  Other escapes will set up subject fields, add and delete
     recipients to the message, and allow you to escape to an editor to revise the message or to
     a shell to run some commands.  (These options are given in the summary below.)
   Ending a mail processing session
     You can end a mail session with the quit (q) command.  Messages which have been examined go
     to your mbox file unless they have been deleted, in which case they are discarded.
     Unexamined messages go back to the post office (see the -f option above).
   Personal and system wide distribution lists
     It is also possible to create personal distribution lists so that, for instance, you can
     send mail to “cohorts” and have it go to a group of people.  Such lists can be defined by
     placing a line like
           alias cohorts bill ozalp jkf mark kridle@ucbcory
     in the file .mailrc in your home directory.  The current list of such aliases can be
     displayed with the alias command in mail.  System wide distribution lists can be created by
     editing /etc/aliases, (see aliases(5)); these are kept in a different syntax.  In mail you
     send, personal aliases will be expanded in mail sent to others so that they will be able to
     reply to the recipients.  System wide aliases are not expanded when the mail is sent, but
     any reply returned to the machine will have the system wide alias expanded as all mail goes
     through an MTA.
   Recipient address specifications
     Recipient addresses (any of the “To”, “Cc” or “Bcc” header fields) are subject to expansion
     when the expandaddr option is set.
     An address may be expanded as follows:
     ·       An address that starts with a pipe (‘|’) character is treated as a command to run.
             The command immediately following the ‘|’ is executed with the message as its
             standard input.
     ·       An address that starts with a ‘+’ character is treated as a folder.
     ·       An address that contains a ‘/’ character but no ‘!’, ‘%’, or ‘@’ characters is also
     ·       If none of the above apply, the recipient is treated as a local or network mail
             address.
     If the expandaddr option is not set (the default), no expansion is performed and the
     recipient is treated as a local or network mail address.
   Character sets and MIME
     Generally mail does not handle neither different character sets nor any other MIME feature.
     Especially it does not perform any any conversions between character sets while displaying
     or sending mails.
     Starting from April 2017, however, as a Debian extension this version of mail adds a few
     MIME headers to every outgoing mail in order to indicate that the mail is sent as 8-bit
     plain text data that uses character set encoding detected from the current locale(7)
     settings.  The -a command-line option can be used to override those headers, for example:
           $ mail -a 'Content-Type: text/plain; charset="ISO-8859-1"'
     sets header indicating legacy character encoding.
   Network mail (ARPA, UUCP, Berknet)
     See mailaddr(7) for a description of network addresses.
     mail has a number of options which can be set in the .mailrc file to alter its behavior;
     thus set askcc enables the askcc feature.  (These options are summarized below.)
其中 -r 参数就是发件人地址了.
这个命令可以设置发件人:
echo “邮件正文” | mail -s 邮件主题 -r noreply@whycan.cn 516333132@qq.com
如果要显示发件人名就这样:
echo “邮件正文” | mail -s 邮件主题 -r "noreply@whycan.cn(无需回复)" 516333132@qq.com
楼主 #7 2019-02-10 21:57:31
已发帖子: 9,444
找到一个脚本,可以用来打包一天内更新的文件:
https://stackoverflow.com/questions/848293/shell-script-get-all-files-modified-after-date/848323
find . -mtime -1 | xargs tar --no-recursion -czf myfile.tgz
再配合前面的 mail 命令, 配合cron非常轻松完成网站数据库和文件定时备份了
#8 2020-04-17 23:52:02
X3
已发帖子: 85
sudo apt-get install sendmail mailutils -y
echo “邮件正文” | mail -s 邮件主题 -r noreply@xxx.com yyyyyyy@qq.com
为何我的阿里云服务器安装 sendmail 之后, 使用mail命令死活发不出邮件?难道是被锁住了吗?如何解锁呢?
但是用搬瓦工可以哦。
#9 2020-04-18 00:30:22
gmfzk2008
厉害。。。
#10 2020-04-18 13:43:12
liuchangyin
已发帖子: 204
定时备份,防患于未然
#11 2020-04-18 13:49:58
Andylyu
感谢分享!向大佬们学习!!
#12 2020-04-18 14:03:57
已发帖子: 856
备份文件多大呀!时间长了,邮箱会不会爆掉,
楼主 #13 2020-04-18 14:37:30
已发帖子: 9,444
kekemuyu 说:
不会,连续两年每小时备份一次数据163和qq邮箱都没有爆。
#14 2020-04-19 15:07:44
LC123456
这个功能非常好啊
#15 2020-04-19 18:45:34
liuchangyin
已发帖子: 204
QQ邮箱有那种无限容量
#16 2020-04-20 09:07:21
HackforFun
坛主,论坛什么时候考虑支持下 Markdown呀。
楼主 #17 2020-04-20 09:08:25
已发帖子: 9,444
HackforFun 说:
感谢建议,小本本先记下来。
#18 2020-04-25 08:59:18
拉轰的脚踏车
已发帖子: 288
kekemuyu 说:
哎呀,96G了, 我这个126邮箱就爆了, 以前能找到扩容的按钮,现在找不到了, 貌似要升级VIP才行。
#19 2020-04-25 19:40:55
liuchangyin
已发帖子: 204
拉轰的脚踏车 说:
https://whycan.cn/files/members/3438/2020-04-25_085631.png
QQ邮箱有那种无限容量,可以看看,扩容一段时间后可以再次扩容,直到无限容量
