注:864MHz 以上会死机
Default CPU clock:
2K performance run parameters for coremark.
CoreMark Size : 666
Total ticks : 13316
Total time (secs): 13.316000
Iterations/Sec : 826.073896
Iterations : 11000
Compiler version : GCC9.3.0
Compiler flags : -O2 -DPERFORMANCE_RUN=1 -lrt
Memory location : Please put data memory location here
(e.g. code in flash, data on heap etc)
seedcrc : 0xe9f5
[0]crclist : 0xe714
[0]crcmatrix : 0x1fd7
[0]crcstate : 0x8e3a
[0]crcfinal : 0x33ff
Correct operation validated. See README.md for run and reporting rules.
CoreMark 1.0 : 826.073896 / GCC9.3.0 -O2 -DPERFORMANCE_RUN=1 -lrt / Heap
Set CPU clock: 200(0x90001802)
# /root/coremark
CoreMark Size : 666
Total ticks : 14852
Total time (secs): 14.852000
Iterations/Sec : 403.985995
Iterations : 6000
seedcrc : 0xe9f5
[0]crclist : 0xe714
[0]crcfinal : 0xa14c
CoreMark 1.0 : 403.985995 / GCC9.3.0 -O2 -DPERFORMANCE_RUN=1 -lrt / Heap
Set CPU clock: 408(0x90001022)
# /root/coremark
CoreMark Size : 666
Total ticks : 13319
Total time (secs): 13.319000
Iterations/Sec : 825.887829
Iterations : 11000
seedcrc : 0xe9f5
[0]crclist : 0xe714
CoreMark 1.0 : 825.887829 / GCC9.3.0 -O2 -DPERFORMANCE_RUN=1 -lrt / Heap
Set CPU clock: 702(0x90001532)
# /root/coremark
CoreMark Size : 666
Total ticks : 14009
Total time (secs): 14.009000
Iterations/Sec : 1427.653651
Iterations : 20000
seedcrc : 0xe9f5
[0]crclist : 0xe714
[0]crcfinal : 0x382f
CoreMark 1.0 : 1427.653651 / GCC9.3.0 -O2 -DPERFORMANCE_RUN=1 -lrt / Heap
Set CPU clock: 744(0x90001e00)
# /root/coremark
CoreMark Size : 666
Total ticks : 13255
Total time (secs): 13.255000
Iterations/Sec : 1508.864579
Iterations : 20000
seedcrc : 0xe9f5
[0]crclist : 0xe714
CoreMark 1.0 : 1508.864579 / GCC9.3.0 -O2 -DPERFORMANCE_RUN=1 -lrt / Heap
Set CPU clock: 800(0x90001832)
# /root/coremark
CoreMark Size : 666
Total ticks : 12326
Total time (secs): 12.326000
Iterations/Sec : 1622.586403
Iterations : 20000
seedcrc : 0xe9f5
[0]crclist : 0xe714
CoreMark 1.0 : 1622.586403 / GCC9.3.0 -O2 -DPERFORMANCE_RUN=1 -lrt / Heap
Set CPU clock: 816(0x90001031)
# /root/coremark
CoreMark Size : 666
Total ticks : 12082
Total time (secs): 12.082000
Iterations/Sec : 1655.355074
Iterations : 20000
seedcrc : 0xe9f5
[0]crclist : 0xe714
CoreMark 1.0 : 1655.355074 / GCC9.3.0 -O2 -DPERFORMANCE_RUN=1 -lrt / Heap
Set CPU clock: 832(0x90001932)
# /root/coremark
CoreMark Size : 666
Total ticks : 17778
Total time (secs): 17.778000
Iterations/Sec : 1687.478907
Iterations : 30000
seedcrc : 0xe9f5
[0]crclist : 0xe714
[0]crcfinal : 0x5275
CoreMark 1.0 : 1687.478907 / GCC9.3.0 -O2 -DPERFORMANCE_RUN=1 -lrt / Heap离线
比较一下: 120M的STM32F2得分400, 180M的STM32F4得分600, 200M的STM32F7得分1000
arm9就是弱。
看来新的架构吊打老的啊
200M的STM32F7和600M的一样分数了,400M的H7系列看来更加厉害
谁说单片机性能差来的?
LZ能不能测测V3S这个A7架构的分数对比一下?
凑个热闹,用sysbench 测得https://whycan.cn/t_3148.html
看到了
V3S 比超频到700M的F1C200S快了3倍
X86锐龙2700(虚拟机里)跑 比V3S 快了70倍
看来架构很重要啊 频率次之
有没有STM32H7系列的测试数据啊?
看到了
V3S 比超频到700M的F1C200S快了3倍X86锐龙2700(虚拟机里)跑 比V3S 快了70倍
看来架构很重要啊 频率次之
有没有STM32H7系列的测试数据啊?
参考List of ARM microarchitectures(需fq
F1C100s用的是ARM926EJ-S,大致是1.1 DMIPS/MHz,V3(Cortex-A7)是1.9 DMIPS/MHz,而Cortex-M系列最高端的Cortex-M7(对应STM32F7/H7系列)则达到了2.14 DMIPS/MHz。
这个COREMARK主要考核的是运算能力,ARM9作为系统处理器主要任务是系统调度处理而不是运算况且F1C100S超频到800M也有1500以上的分数,足以应付系统调度处理之余的的少量运算需求。F1C100S设定到600M, 作为轻量级系统处理器优雅而完美。对于F1C100S唯一遗憾的是没有内置以太网。
864MHz 以上 要提高CPU电压, 1.3v, 或者更高一些
