楼主 #1 2020-05-13 01:04:42
sven1234
已发帖子: 41
分享一个自己做的wifi时钟代码
买了个VFD屏,无聊做了个时钟,但感觉用RTC自己跑时间久了总是不准,所以用ESP8266做了个NTP Client并且分解了年月日。
代码如下。写得有点粗糙见笑了。刚入坛,多见谅。
#include <ESP8266WiFi.h>
#include <WiFiUdp.h>
char ssid[] = "SSID";  //  your network SSID (name)
char pass[] = "password";       // your network password
unsigned int localPort = 2390;      // local port to listen for UDP packets
IPAddress timeServerIP;
const char* ntpServerName = "202.118.1.130";//"1.cn.pool.ntp.org";
const int NTP_PACKET_SIZE = 48; // NTP time stamp is in the first 48 bytes of the message
byte packetBuffer[ NTP_PACKET_SIZE]; //buffer to hold incoming and outgoing packets
WiFiUDP udp;
// send an NTP request to the time server at the given address
unsigned long sendNTPpacket(IPAddress& address)
  Serial.println("sending NTP packet...");
  // set all bytes in the buffer to 0
  memset(packetBuffer, 0, NTP_PACKET_SIZE);
  // Initialize values needed to form NTP request
  // (see URL above for details on the packets)
  packetBuffer[0] = 0b11100011;   // LI, Version, Mode
  packetBuffer[1] = 0;     // Stratum, or type of clock
  packetBuffer[2] = 6;     // Polling Interval
  packetBuffer[3] = 0xEC;  // Peer Clock Precision
  // 8 bytes of zero for Root Delay & Root Dispersion
  packetBuffer[12]  = 49;
  packetBuffer[13]  = 0x4E;
  packetBuffer[14]  = 49;
  packetBuffer[15]  = 52;
  // all NTP fields have been given values, now
  // you can send a packet requesting a timestamp:
  udp.beginPacket(address, 123); //NTP requests are to port 123
  udp.write(packetBuffer, NTP_PACKET_SIZE);
  udp.endPacket();
void setup()
  Serial.begin(9600);
  Serial.println();
  Serial.println();
  // We start by connecting to a WiFi network
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, pass);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  Serial.println(WiFi.localIP());
  Serial.println("Starting UDP");
  udp.begin(localPort);
  Serial.print("Local port: ");
  Serial.println(udp.localPort());
unsigned char rmdp[12]={0,31,59,90,120,151,181,212,243,273,304,334};
unsigned char rmdr[12]={0,31,60,91,121,152,181,213,244,274,305,335};
void loop()
  //get a random server from the pool
  WiFi.hostByName(ntpServerName, timeServerIP);
  sendNTPpacket(timeServerIP); // send an NTP packet to a time server
  // wait to see if a reply is available
  delay(1000);
  int cb = udp.parsePacket();
  if (!cb) {
    Serial.println("no packet yet");
  else {
    Serial.print("packet received, length=");
    Serial.println(cb);
    // We've received a packet, read the data from it
    udp.read(packetBuffer, NTP_PACKET_SIZE); // read the packet into the buffer
    //the timestamp starts at byte 40 of the received packet and is four bytes,
    // or two words, long. First, esxtract the two words:
    unsigned long highWord = word(packetBuffer[40], packetBuffer[41]);
    unsigned long lowWord = word(packetBuffer[42], packetBuffer[43]);
    // combine the four bytes (two words) into a long integer
    // this is NTP time (seconds since Jan 1 1900):
    unsigned long secsSince1900 = highWord << 16 | lowWord;
    secsSince1900=secsSince1900+28800;
    Serial.print("Seconds since Jan 1 1900 = " );
    Serial.println(secsSince1900);
    unsigned long second=secsSince1900%60;
    unsigned long minute=secsSince1900/60%60;
    unsigned long hour=secsSince1900/3600%24;
    unsigned long num_date=secsSince1900/86400;
    unsigned long num_four_year=(num_date-365)/1461;
    unsigned long last_date=(num_date-365)%1461;
    unsigned long last_num_year=last_date/365;
    unsigned long last_year_date=last_date-last_num_year*365;
    unsigned long year=1901+num_four_year*4+last_num_year;
    unsigned long month=last_year_date/30+1;
    unsigned long date=0;
    if(last_num_year==3){
      date=last_year_date-rmdr[month-1]+1;
    }else{
      date=last_year_date-rmdp[month-1]+1;
    unsigned long day=num_date%7+1;
    Serial.print(year);
    Serial.print("-");
    Serial.print(month);
    Serial.print("-");
    Serial.print(date);
    Serial.print("  ");
    Serial.print(day);
    Serial.print("  ");
    Serial.print(hour);
    Serial.print(":");
    Serial.print(minute);
    Serial.print(":");
    Serial.println(second);
    Serial.print("CMD");
    Serial.write(year%100/10);Serial.write(year%10);
    Serial.write(month/10);Serial.write(month%10);
    Serial.write(date/10);Serial.write(date%10);
    Serial.write(day);
    Serial.write(hour/10);Serial.write(hour%10);
    Serial.write(minute/10);Serial.write(minute%10);
    Serial.write(second/10);Serial.write(second%10);
    Serial.write(0x0d);Serial.write(0x0a);
  // wait ten seconds before asking for the time again
  delay(10000);
#2 2020-05-13 10:13:18
642242855
已发帖子: 213
Re: 分享一个自己做的wifi时钟代码
标记下
#3 2020-05-13 10:23:37
已发帖子: 3,393
感谢支持, 有没有靓照?
#4 2020-05-13 10:27:18
夏雨夜寐
已发帖子: 85
又不爆照……
楼主 #5 2020-05-13 20:41:43
sven1234
已发帖子: 41
应广大坛友要求晒上丑陋的高清大照……
#6 2020-05-15 15:26:03
hzqlz
已发帖子: 173
这飞线技术了得!
#7 2020-05-23 23:11:22
hyghyg1234
现在做板子那么便宜,还飞线。
#8 2020-05-24 20:57:42
sunshine11140
很有参考价值,跟着学习一下
#9 2020-05-31 14:57:24
TDA2030
这才是真正的DIY,这么多板子用飞线连接,楼主厉害呀
#10 2021-01-01 20:09:47
kiss
看着像老外的手艺 哈哈
#11 2021-01-01 20:56:59
EE
已发帖子: 106
kiss 说:
看着像老外的手艺 哈哈
+1
氖光就更赞了
#12 2021-05-19 14:15:38
duanhnhy
已发帖子: 33
能做出来就非常不错了,赞一个。。。
#13 2021-05-20 16:18:36
xrff_z
已发帖子: 26
  • 不通过:与技术无关
