楼主 #1 2018-04-17 11:45:53
step by step 用mingw 编译 xboot
  1. 安装 64bit 编译工具链
    sudo apt-get install mingw-w64
    sudo apt-get install binutils-mingw-w64
  2. 下载编译安装 libiconv:
    #wget https://ftp.gnu.org/pub/gnu/libiconv/libiconv-1.15.tar.gz
    #tar xvf libiconv-1.15.tar.gz
    #cd libiconv-1.15/
    #./configure --host=x86_64-w64-mingw32 --prefix=/usr/x86_64-w64-mingw32/
    #make
    #sudo make install
  3. 下载编译libSDL2 (同上)
  4. 下载xboot
    #git clone https://github.com/xboot/xboot.git
  5. 打补丁
    # cd src/arch/x64/mach-sandbox/libsandbox/
    # wget https://raw.githubusercontent.com/LuaDist/libarchive/master/libarchive/archive_windows.h
  6. 修改 src/arch/x64/mach-sandbox/libsandbox/sandbox-file.c
    添加
#include "archive_windows.h"
150行附件
flags = fcntl(fd, F_GETFL);
改为
flags = fcntl(fd, F_GETFL, 0);
  1. 修改 src/arch/x64/mach-sandbox/libsandbox/sandbox-stdio.c
#include <stdio.h>
#include <stdlib.h>
#include <stdint.h>
//#include <termios.h>
#include <sandbox.h>
//static struct termios __term_config;
void sandbox_stdio_init(void)
#if 0
	struct termios termvi;
	tcgetattr(0, &__term_config);
	termvi = __term_config;
	termvi.c_lflag &= (~ICANON & ~ECHO & ~ISIG);
	termvi.c_iflag &= (~IXON & ~ICRNL);
	termvi.c_oflag |= (ONLCR);
	termvi.c_cc[VMIN] = 1;
	termvi.c_cc[VTIME] = 0;
	tcsetattr(0, TCSANOW, &termvi);
void sandbox_stdio_exit(void)
#if 0
	fflush(stdout);
	tcsetattr(0, TCSANOW, &__term_config);
ssize_t sandbox_stdio_read(void * buf, size_t count)
#if 0
	return sandbox_file_read_nonblock(fileno(stdin), buf, count);
ssize_t sandbox_stdio_write(void * buf, size_t count)
#if 0
	return sandbox_file_write(fileno(stdout), buf, count);
  1. 开始编译
    #cd xboot
    #CROSS_COMPILE=x86_64-w64-mingw32- PLATFORM=sandbox make
楼主 #2 2018-04-17 11:45:59
Re: step by step 用mingw 编译 xboot
[LD] Linking ../output/xboot
Error in `/usr/bin/x86_64-w64-mingw32-ld': free(): invalid pointer: 0x0000000003698818
collect2: error: ld terminated with signal 6 [Aborted], core dumped
make[1]: *** [../output/xboot] Error 1
make[1]: Leaving directory `/disk5/xboot/src'
make: *** [all] Error 2
只有最后一个链接问题, 解决这个问题就可以在windows跑sandbox了
楼主 #3 2018-04-17 11:46:01
占位
楼主 #4 2018-04-17 11:46:02
占位
楼主 #5 2018-04-17 11:46:04
占位
楼主 #6 2018-04-17 11:46:06
占位
楼主 #7 2018-04-17 11:46:08
占位
#8 2018-04-17 13:28:32
kgp0213
已发帖子: 149
期待成功~
