板子买的是荔枝派Nano ,spi-flash的,烧写的16M的,因为flash芯片不是默认支持的,芯片型号xt25f128b,改动了下
参考
https://whycan.cn/t_3138.html
uboot修改:
1.
/u-boot/include/configs/suniv.h
#define CONFIG_BOOTCOMMAND "sf probe 0 50000000; " \
"sf read 0x80C00000 0x100000 0x4000; " \
"sf read 0x80008000 0x110000 0x400000; " \
"bootz 0x80008000 - 0x80C00000"
2.
因为使用的flash为xt25f128b
所以修改
/u-boot/drivers/mtd/spi/spi_flash_ids.c
{"w25q128fw", INFO(0xef6018, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP | SECT_4K) },
{"xt25f128b", INFO(0x0b4018, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP | SECT_4K) },
3.
/linux/arch/arm/boot/dts/suniv-f1c100s-licheepi-nano.dts
修改flash名称
compatible = "winbond,xt25f128b", "jedec,spi-nor";
linux修改
1.
/linux/drivers/mtd/devies/m25p80.c
搜jedec 在最后增加xt25定义
{"w25q80bl"}, {"w25q128"}, {"w25q256"}, {"xt25f128b"}
2.
/linux/drivers/mtd/spi-nor
flash_info spi_nor_ids[]中
{ "w25q128", INFO(0xef4018, 0, 64 * 1024, 256, SECT_4K) },
{ "w25q128", INFO(0xef4018, 0, 64 * 1024, 256, 0) },
{ "xt25f128b", INFO(0x0b4018, 0, 64 * 1024, 256, 0) },
编译都很顺利,生成16M的Nano_flash_800480.bin 文件,启动的时候停在Waiting for root device /dev/mmcblk0p2... ,盼高手指点下怎么回事?串口信息如下:
U-Boot SPL 2018.01-05679-g013ca45-dirty (May 17 2020 - 07:46:50)
DRAM: 32 MiB
Trying to boot from MMC1
mmc_init: -95, time 22
Trying to boot from sunxi SPI
U-Boot 2018.01-05679-g013ca45-dirty (May 17 2020 - 07:46:50 +0000) Allwinner Technology
Model: Lichee Pi Nano
DRAM: 32 MiB
MMC: SUNXI SD/MMC: 0
SF: Detected xt25f128b with page size 256 Bytes, erase size 4 KiB, total 16 MiB
In: serial@1c25000
Out: serial@1c25000
Err: serial@1c25000
Net: No ethernet found.
No controllers found
Hit any key to stop autoboot: 2 1 0
Loading Device Tree to 816fb000, end 816ffda6 ... OK
[ 0.000000] Linux version 4.15.0-rc8-licheepi-nano+ (root@535337fc15c2) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #2 Sat May 16 18:22:06 UTC 2020
[ 0.000000] random: fast init done
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 8128
[ 0.000000] Kernel command line: console=tty0 console=ttyS0,115200 panic=5 rootwait root=/dev/mmcblk0p2 rw
[ 0.000000] Memory: 22684K/32768K available (6144K kernel code, 236K rwdata, 1388K rodata, 1024K init, 244K bss, 10084K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] vmalloc : 0xc2800000 - 0xff800000 ( 976 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc2000000 ( 32 MB)
[ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (7136 kB)
[ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (1024 kB)
[ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 237 kB)
[ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 245 kB)
[ 0.000045] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000110] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000634] Console: colour dummy device 80x30
[ 0.001541] console [tty0] enabled
[ 0.001646] Calibrating delay loop... 203.16 BogoMIPS (lpj=1015808)
[ 0.070281] pid_max: default: 32768 minimum: 301
[ 0.070623] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.070715] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.072161] CPU: Testing write buffer coherency: ok
[ 0.073859] Setting up static identity map for 0x80100000 - 0x80100058
[ 0.076444] devtmpfs: initialized
[ 0.082696] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.082858] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.083155] pinctrl core: initialized pinctrl subsystem
[ 0.085146] NET: Registered protocol family 16
[ 0.086577] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.088410] cpuidle: using governor menu
[ 0.113508] SCSI subsystem initialized
[ 0.113912] usbcore: registered new interface driver usbfs
[ 0.114116] usbcore: registered new interface driver hub
[ 0.114375] usbcore: registered new device driver usb
[ 0.114856] pps_core: LinuxPPS API ver. 1 registered
[ 0.114938] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.115058] PTP clock support registered
[ 0.115540] Advanced Linux Sound Architecture Driver Initialized.
[ 0.117077] clocksource: Switched to clocksource timer
[ 0.143015] NET: Registered protocol family 2
[ 0.144470] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.144623] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.144712] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.145021] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.145126] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.145639] NET: Registered protocol family 1
[ 0.146906] RPC: Registered named UNIX socket transport module.
[ 0.147020] RPC: Registered udp transport module.
[ 0.147194] RPC: Registered tcp transport module.
[ 0.147261] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.149443] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.151268] Initialise system trusted keyrings
[ 0.151864] workingset: timestamp_bits=30 max_order=13 bucket_order=0
[ 0.168873] NFS: Registering the id_resolver key type
[ 0.169024] Key type id_resolver registered
[ 0.169078] Key type id_legacy registered
[ 0.182350] Key type asymmetric registered
[ 0.182460] Asymmetric key parser 'x509' registered
[ 0.182692] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.182787] io scheduler noop registered
[ 0.182831] io scheduler deadline registered
[ 0.183604] io scheduler cfq registered (default)
[ 0.183699] io scheduler mq-deadline registered
[ 0.183753] io scheduler kyber registered
[ 0.184855] sun4i-usb-phy 1c13400.phy: Couldn't request ID GPIO
[ 0.194288] suniv-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.362642] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.369357] console [ttyS0] disabled
[ 0.389671] 1c25000.serial: ttyS0 at MMIO 0x1c25000 (irq = 23, base_baud = 6250000) is a 16550A
[ 0.860777] console [ttyS0] enabled
[ 0.871240] panel-simple panel: panel supply power not found, using dummy regulator
[ 0.880705] SCSI Media Changer driver v0.25
[ 0.886290] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.893020] ehci-platform: EHCI generic platform driver
[ 0.898641] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.904918] ohci-platform: OHCI generic platform driver
[ 0.910669] usbcore: registered new interface driver usb-storage
[ 0.917756] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[ 0.926784] i2c /dev entries driver
[ 0.987203] sunxi-mmc 1c0f000.mmc: base:0xbbc83b35 irq:19
[ 0.994660] usbcore: registered new interface driver usbhid
[ 1.000423] usbhid: USB HID core driver
[ 1.021999] NET: Registered protocol family 17
[ 1.026754] Key type dns_resolver registered
[ 1.033349] Loading compiled-in X.509 certificates
[ 1.048555] sun4i-drm display-engine: bound 1e60000.display-backend (ops 0xc0739498)
[ 1.057561] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc073877c)
[ 1.065313] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.072053] [drm] No driver support for vblank timestamp query.
[ 1.126126] Console: switching to colour frame buffer device 60x34
[ 1.149816] sun4i-drm display-engine: fb0: frame buffer device
[ 1.157371] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[ 1.179038] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 1.209729] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.228422] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 1.251441] hub 1-0:1.0: USB hub found
[ 1.262062] hub 1-0:1.0: 1 port detected
[ 1.274116] using random self ethernet address
[ 1.285124] using random host ethernet address
[ 1.297901] usb0: HOST MAC f6:78:01:33:ec:48
[ 1.308732] usb0: MAC 4e:ae:b8:0d:c6:fc
[ 1.318915] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[ 1.338659] g_cdc gadget: g_cdc ready
[ 1.349432] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 1.379790] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 1.399107] vcc3v3: disabling
[ 1.408430] ALSA device list:
[ 1.417591] #0: Loopback 1
[ 1.427485] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 1.448238] cfg80211: failed to load regulatory.db
[ 1.459747] Waiting for root device /dev/mmcblk0p2...
[ 202.947207] random: crng init done最近编辑记录 heiheizi (2020-05-17 16:47:33)
你的 bootargs 错了,
而且你的log也没有打印发现 mtd 分区.
大神,正确的应该怎么改?
照着改了下还是不行,串口信息如下:
U-Boot SPL 2018.01-05679-g013ca45-dirty (May 17 2020 - 13:55:07)
DRAM:Card did not respond to voltage select!
U-Boot 2018.01-05679-g013ca45-dirty (May 17 2020 - 13:55:07 +0000) Allwinner Technology
DRAM: 32 MiB
In: serial@1c25000
Out: serial@1c25000
Err: serial@1c25000
[ 0.000107] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000625] Console: colour dummy device 80x30
[ 0.001468] console [tty0] enabled
[ 0.001561] Calibrating delay loop... 203.16 BogoMIPS (lpj=1015808)
[ 0.070275] pid_max: default: 32768 minimum: 301
[ 0.070611] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.070701] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.072263] CPU: Testing write buffer coherency: ok
[ 0.073977] Setting up static identity map for 0x80100000 - 0x80100058
[ 0.076336] devtmpfs: initialized
[ 0.081895] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.082063] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.082361] pinctrl core: initialized pinctrl subsystem
[ 0.084202] random: get_random_u32 called from bucket_table_alloc+0x80/0x1a4 with crng_init=0
[ 0.084534] NET: Registered protocol family 16
[ 0.085595] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.087420] cpuidle: using governor menu
[ 0.111901] SCSI subsystem initialized
[ 0.112304] usbcore: registered new interface driver usbfs
[ 0.112518] usbcore: registered new interface driver hub
[ 0.112772] usbcore: registered new device driver usb
[ 0.113259] pps_core: LinuxPPS API ver. 1 registered
[ 0.113343] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.113466] PTP clock support registered
[ 0.113958] Advanced Linux Sound Architecture Driver Initialized.
[ 0.115169] clocksource: Switched to clocksource timer
[ 0.141346] NET: Registered protocol family 2
[ 0.142804] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.142956] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.143045] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.143358] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.143461] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.143965] NET: Registered protocol family 1
[ 0.145327] RPC: Registered named UNIX socket transport module.
[ 0.145441] RPC: Registered udp transport module.
[ 0.145490] RPC: Registered tcp transport module.
[ 0.145534] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.147371] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.149189] Initialise system trusted keyrings
[ 0.149787] workingset: timestamp_bits=30 max_order=13 bucket_order=0
[ 0.166846] NFS: Registering the id_resolver key type
[ 0.166999] Key type id_resolver registered
[ 0.167058] Key type id_legacy registered
[ 0.169865] random: fast init done
[ 0.180566] Key type asymmetric registered
[ 0.180675] Asymmetric key parser 'x509' registered
[ 0.180909] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.181004] io scheduler noop registered
[ 0.181049] io scheduler deadline registered
[ 0.181814] io scheduler cfq registered (default)
[ 0.181912] io scheduler mq-deadline registered
[ 0.181964] io scheduler kyber registered
[ 0.183069] sun4i-usb-phy 1c13400.phy: Couldn't request ID GPIO
[ 0.192508] suniv-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.362433] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.389339] 1c25000.serial: ttyS0 at MMIO 0x1c25000 (irq = 23, base_baud = 6250000) is a 16550A
[ 0.859011] console [ttyS0] enabled
[ 0.869497] panel-simple panel: panel supply power not found, using dummy regulator
[ 0.878969] SCSI Media Changer driver v0.25
[ 0.884529] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.891252] ehci-platform: EHCI generic platform driver
[ 0.896876] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.903149] ohci-platform: OHCI generic platform driver
[ 0.908891] usbcore: registered new interface driver usb-storage
[ 0.916015] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[ 0.925039] i2c /dev entries driver
[ 0.985289] sunxi-mmc 1c0f000.mmc: base:0x(ptrval) irq:19
[ 0.992755] usbcore: registered new interface driver usbhid
[ 0.998521] usbhid: USB HID core driver
[ 1.020212] NET: Registered protocol family 17
[ 1.024976] Key type dns_resolver registered
[ 1.031240] Loading compiled-in X.509 certificates
[ 1.046227] sun4i-drm display-engine: bound 1e60000.display-backend (ops 0xc0739498)
[ 1.055082] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc073877c)
[ 1.062962] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.069682] [drm] No driver support for vblank timestamp query.
[ 1.123718] Console: switching to colour frame buffer device 60x34
[ 1.147418] sun4i-drm display-engine: fb0: frame buffer device
[ 1.154808] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[ 1.176514] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 1.207227] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.225900] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 1.249010] hub 1-0:1.0: USB hub found
[ 1.259642] hub 1-0:1.0: 1 port detected
[ 1.271721] using random self ethernet address
[ 1.282713] using random host ethernet address
[ 1.295470] usb0: HOST MAC 8e:f3:a8:71:5e:31
[ 1.306294] usb0: MAC 4a:b8:46:88:a3:34
[ 1.316460] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[ 1.336197] g_cdc gadget: g_cdc ready
[ 1.346966] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 1.377278] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 1.396594] vcc3v3: disabling
[ 1.405919] ALSA device list:
[ 1.414987] #0: Loopback 1
[ 1.424828] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 1.445560] cfg80211: failed to load regulatory.db
[ 1.457291] VFS: Cannot open root device "(null)" or unknown-block(0,0): error -6
[ 1.476944] Please append a correct "root=" boot option; here are the available partitions:
[ 1.497407] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[ 1.517646] CPU: 0 PID: 1 Comm: swapper Not tainted 4.15.0-rc8-licheepi-nano+ #2
[ 1.536901] Hardware name: Allwinner suniv Family
[ 1.547670] [<c010e550>] (unwind_backtrace) from [<c010b6a8>] (show_stack+0x10/0x14)
[ 1.567281] [<c010b6a8>] (show_stack) from [<c0116878>] (panic+0xb8/0x230)
[ 1.585984] [<c0116878>] (panic) from [<c0901190>] (mount_block_root+0x170/0x250)
[ 1.605357] [<c0901190>] (mount_block_root) from [<c0901364>] (mount_root+0xf4/0x120)
[ 1.625463] [<c0901364>] (mount_root) from [<c09014b8>] (prepare_namespace+0x128/0x188)
[ 1.646234] [<c09014b8>] (prepare_namespace) from [<c0900dc0>] (kernel_init_freeable+0x174/0x1b8)
[ 1.668187] [<c0900dc0>] (kernel_init_freeable) from [<c064fa70>] (kernel_init+0x8/0x10c)
[ 1.689533] [<c064fa70>] (kernel_init) from [<c0107dc0>] (ret_from_fork+0x14/0x34)
[ 1.710300] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)最近编辑记录 heiheizi (2020-05-17 22:56:53)
sun4i sun6i sun8i spi驱动勾选了吗?
sun6i 驱动有了,增加spi驱动就报错,截图如下
报错信息:
include/configs/suniv.h:19:0: warning: "CONFIG_BOOTCOMMAND" redefined
#define CONFIG_BOOTCOMMAND "setenv bootargs console=tty0 console=ttyS0,115200 panic=5 rootwait root=/dev/mmcblk0p2 rw "\
In file included from ././include/linux/kconfig.h:4:0,
from <command-line>:0:
include/generated/autoconf.h:144:0: note: this is the location of the previous definition
#define CONFIG_BOOTCOMMAND "run distro_bootcmd"
LD spl/drivers/mmc/built-in.o
scripts/Makefile.spl:349: recipe for target 'spl/drivers' failed
make[1]: *** [spl/drivers] Error 2
make[1]: *** Waiting for unfinished jobs....
In file included from include/config.h:5:0,
from include/common.h:21,
from lib/rand.c:11:
CC spl/lib/panic.o
from lib/panic.c:12:
CC spl/lib/strto.o
from lib/strto.c:12:
LD spl/lib/built-in.o
Makefile:1400: recipe for target 'spl/u-boot-spl' failed
make: *** [spl/u-boot-spl] Error 2离线
不,我说的是linux
最近编辑记录 有梦的地方 (2020-05-18 11:21:13)
linux是已经有了的
linux是已经有了的
不对,你的linux log根本没有spi
可以明确下是哪个配置项吗?我这边看spi的勾了呀
这是我的linux 的config文件内容
# Linux/arm 4.15.0-rc8 Kernel Configuration
CONFIG_ARM=y
CONFIG_ARM_HAS_SG_CHAIN=y
CONFIG_MIGHT_HAVE_PCI=y
CONFIG_SYS_SUPPORTS_APM_EMULATION=y
CONFIG_HAVE_PROC_CPU=y
CONFIG_STACKTRACE_SUPPORT=y
CONFIG_LOCKDEP_SUPPORT=y
CONFIG_TRACE_IRQFLAGS_SUPPORT=y
CONFIG_RWSEM_XCHGADD_ALGORITHM=y
CONFIG_FIX_EARLYCON_MEM=y
CONFIG_GENERIC_HWEIGHT=y
CONFIG_GENERIC_CALIBRATE_DELAY=y
CONFIG_NEED_DMA_MAP_STATE=y
CONFIG_ARCH_SUPPORTS_UPROBES=y
CONFIG_ARM_PATCH_PHYS_VIRT=y
CONFIG_GENERIC_BUG=y
CONFIG_PGTABLE_LEVELS=2
CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config"
CONFIG_IRQ_WORK=y
CONFIG_BUILDTIME_EXTABLE_SORT=y
# General setup
CONFIG_BROKEN_ON_SMP=y
CONFIG_INIT_ENV_ARG_LIMIT=32
CONFIG_CROSS_COMPILE=""
# CONFIG_COMPILE_TEST is not set
CONFIG_LOCALVERSION="-licheepi-nano"
# CONFIG_LOCALVERSION_AUTO is not set
CONFIG_HAVE_KERNEL_GZIP=y
CONFIG_HAVE_KERNEL_LZMA=y
CONFIG_HAVE_KERNEL_XZ=y
CONFIG_HAVE_KERNEL_LZO=y
CONFIG_HAVE_KERNEL_LZ4=y
CONFIG_KERNEL_GZIP=y
# CONFIG_KERNEL_LZMA is not set
# CONFIG_KERNEL_XZ is not set
# CONFIG_KERNEL_LZO is not set
# CONFIG_KERNEL_LZ4 is not set
CONFIG_DEFAULT_HOSTNAME="(none)"
CONFIG_SWAP=y
# CONFIG_SYSVIPC is not set
# CONFIG_POSIX_MQUEUE is not set
CONFIG_CROSS_MEMORY_ATTACH=y
# CONFIG_USELIB is not set
# CONFIG_AUDIT is not set
# IRQ subsystem
CONFIG_GENERIC_IRQ_PROBE=y
CONFIG_GENERIC_IRQ_SHOW=y
CONFIG_GENERIC_IRQ_SHOW_LEVEL=y
CONFIG_HARDIRQS_SW_RESEND=y
CONFIG_GENERIC_IRQ_CHIP=y
CONFIG_IRQ_DOMAIN=y
CONFIG_HANDLE_DOMAIN_IRQ=y
# CONFIG_IRQ_DOMAIN_DEBUG is not set
CONFIG_IRQ_FORCED_THREADING=y
CONFIG_SPARSE_IRQ=y
# CONFIG_GENERIC_IRQ_DEBUGFS is not set
CONFIG_ARCH_CLOCKSOURCE_DATA=y
CONFIG_GENERIC_CLOCKEVENTS=y
# Timers subsystem
CONFIG_TICK_ONESHOT=y
CONFIG_NO_HZ_COMMON=y
# CONFIG_HZ_PERIODIC is not set
CONFIG_NO_HZ_IDLE=y
CONFIG_NO_HZ=y
CONFIG_HIGH_RES_TIMERS=y
# CPU/Task time and stats accounting
CONFIG_TICK_CPU_ACCOUNTING=y
# CONFIG_VIRT_CPU_ACCOUNTING_GEN is not set
# CONFIG_IRQ_TIME_ACCOUNTING is not set
# CONFIG_BSD_PROCESS_ACCT is not set
# CONFIG_TASKSTATS is not set
# RCU Subsystem
CONFIG_TINY_RCU=y
# CONFIG_RCU_EXPERT is not set
CONFIG_SRCU=y
CONFIG_TINY_SRCU=y
# CONFIG_TASKS_RCU is not set
# CONFIG_RCU_STALL_COMMON is not set
# CONFIG_RCU_NEED_SEGCBLIST is not set
# CONFIG_BUILD_BIN2C is not set
# CONFIG_IKCONFIG is not set
CONFIG_LOG_BUF_SHIFT=17
CONFIG_PRINTK_SAFE_LOG_BUF_SHIFT=13
CONFIG_GENERIC_SCHED_CLOCK=y
CONFIG_CGROUPS=y
# CONFIG_MEMCG is not set
# CONFIG_BLK_CGROUP is not set
# CONFIG_CGROUP_SCHED is not set
# CONFIG_CGROUP_PIDS is not set
# CONFIG_CGROUP_RDMA is not set
# CONFIG_CGROUP_FREEZER is not set
# CONFIG_CGROUP_DEVICE is not set
# CONFIG_CGROUP_CPUACCT is not set
# CONFIG_CGROUP_PERF is not set
# CONFIG_CGROUP_DEBUG is not set
# CONFIG_SOCK_CGROUP_DATA is not set
CONFIG_NAMESPACES=y
CONFIG_UTS_NS=y
# CONFIG_USER_NS is not set
CONFIG_PID_NS=y
CONFIG_NET_NS=y
# CONFIG_SCHED_AUTOGROUP is not set
# CONFIG_SYSFS_DEPRECATED is not set
# CONFIG_RELAY is not set
CONFIG_BLK_DEV_INITRD=y
CONFIG_INITRAMFS_SOURCE=""
CONFIG_RD_GZIP=y
CONFIG_RD_BZIP2=y
CONFIG_RD_LZMA=y
CONFIG_RD_XZ=y
CONFIG_RD_LZO=y
CONFIG_RD_LZ4=y
CONFIG_CC_OPTIMIZE_FOR_PERFORMANCE=y
# CONFIG_CC_OPTIMIZE_FOR_SIZE is not set
CONFIG_SYSCTL=y
CONFIG_ANON_INODES=y
CONFIG_HAVE_UID16=y
CONFIG_BPF=y
# CONFIG_EXPERT is not set
CONFIG_UID16=y
CONFIG_MULTIUSER=y
# CONFIG_SGETMASK_SYSCALL is not set
CONFIG_SYSFS_SYSCALL=y
# CONFIG_SYSCTL_SYSCALL is not set
CONFIG_FHANDLE=y
CONFIG_POSIX_TIMERS=y
CONFIG_PRINTK=y
CONFIG_PRINTK_NMI=y
CONFIG_BUG=y
CONFIG_ELF_CORE=y
CONFIG_BASE_FULL=y
CONFIG_FUTEX=y
CONFIG_FUTEX_PI=y
CONFIG_EPOLL=y
CONFIG_SIGNALFD=y
CONFIG_TIMERFD=y
CONFIG_EVENTFD=y
CONFIG_SHMEM=y
CONFIG_AIO=y
CONFIG_ADVISE_SYSCALLS=y
CONFIG_MEMBARRIER=y
# CONFIG_CHECKPOINT_RESTORE is not set
CONFIG_KALLSYMS=y
# CONFIG_KALLSYMS_ALL is not set
# CONFIG_KALLSYMS_ABSOLUTE_PERCPU is not set
CONFIG_KALLSYMS_BASE_RELATIVE=y
# CONFIG_BPF_SYSCALL is not set
# CONFIG_USERFAULTFD is not set
# CONFIG_EMBEDDED is not set
CONFIG_HAVE_PERF_EVENTS=y
CONFIG_PERF_USE_VMALLOC=y
# CONFIG_PC104 is not set
# Kernel Performance Events And Counters
CONFIG_PERF_EVENTS=y
# CONFIG_DEBUG_PERF_USE_VMALLOC is not set
CONFIG_VM_EVENT_COUNTERS=y
CONFIG_SLUB_DEBUG=y
CONFIG_COMPAT_BRK=y
# CONFIG_SLAB is not set
CONFIG_SLUB=y
CONFIG_SLAB_MERGE_DEFAULT=y
# CONFIG_SLAB_FREELIST_RANDOM is not set
# CONFIG_SLAB_FREELIST_HARDENED is not set
CONFIG_SYSTEM_DATA_VERIFICATION=y
# CONFIG_PROFILING is not set
CONFIG_HAVE_OPROFILE=y
# CONFIG_KPROBES is not set
# CONFIG_JUMP_LABEL is not set
# CONFIG_UPROBES is not set
# CONFIG_HAVE_64BIT_ALIGNED_ACCESS is not set
CONFIG_ARCH_USE_BUILTIN_BSWAP=y
CONFIG_HAVE_KPROBES=y
CONFIG_HAVE_KRETPROBES=y
CONFIG_HAVE_OPTPROBES=y
CONFIG_HAVE_NMI=y
CONFIG_HAVE_ARCH_TRACEHOOK=y
CONFIG_HAVE_DMA_CONTIGUOUS=y
CONFIG_GENERIC_SMP_IDLE_THREAD=y
CONFIG_GENERIC_IDLE_POLL_SETUP=y
CONFIG_ARCH_HAS_SET_MEMORY=y
CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y
CONFIG_HAVE_CLK=y
CONFIG_HAVE_DMA_API_DEBUG=y
CONFIG_HAVE_PERF_REGS=y
CONFIG_HAVE_PERF_USER_STACK_DUMP=y
CONFIG_HAVE_ARCH_JUMP_LABEL=y
CONFIG_ARCH_WANT_IPC_PARSE_VERSION=y
CONFIG_HAVE_GCC_PLUGINS=y
# CONFIG_GCC_PLUGINS is not set
CONFIG_HAVE_CC_STACKPROTECTOR=y
# CONFIG_CC_STACKPROTECTOR is not set
CONFIG_CC_STACKPROTECTOR_NONE=y
# CONFIG_CC_STACKPROTECTOR_REGULAR is not set
# CONFIG_CC_STACKPROTECTOR_STRONG is not set
CONFIG_THIN_ARCHIVES=y
CONFIG_HAVE_CONTEXT_TRACKING=y
CONFIG_HAVE_VIRT_CPU_ACCOUNTING_GEN=y
CONFIG_HAVE_IRQ_TIME_ACCOUNTING=y
CONFIG_HAVE_MOD_ARCH_SPECIFIC=y
CONFIG_MODULES_USE_ELF_REL=y
CONFIG_ARCH_HAS_ELF_RANDOMIZE=y
CONFIG_HAVE_ARCH_MMAP_RND_BITS=y
CONFIG_HAVE_EXIT_THREAD=y
CONFIG_ARCH_MMAP_RND_BITS_MIN=8
CONFIG_ARCH_MMAP_RND_BITS_MAX=16
CONFIG_ARCH_MMAP_RND_BITS=8
# CONFIG_HAVE_ARCH_HASH is not set
# CONFIG_ISA_BUS_API is not set
CONFIG_CLONE_BACKWARDS=y
CONFIG_OLD_SIGSUSPEND3=y
CONFIG_OLD_SIGACTION=y
# CONFIG_CPU_NO_EFFICIENT_FFS is not set
# CONFIG_HAVE_ARCH_VMAP_STACK is not set
CONFIG_ARCH_OPTIONAL_KERNEL_RWX=y
# CONFIG_ARCH_OPTIONAL_KERNEL_RWX_DEFAULT is not set
CONFIG_ARCH_HAS_STRICT_KERNEL_RWX=y
CONFIG_STRICT_KERNEL_RWX=y
CONFIG_ARCH_HAS_STRICT_MODULE_RWX=y
CONFIG_STRICT_MODULE_RWX=y
# CONFIG_REFCOUNT_FULL is not set
# GCOV-based kernel profiling
# CONFIG_GCOV_KERNEL is not set
CONFIG_ARCH_HAS_GCOV_PROFILE_ALL=y
CONFIG_HAVE_GENERIC_DMA_COHERENT=y
CONFIG_RT_MUTEXES=y
CONFIG_BASE_SMALL=0
CONFIG_MODULES=y
# CONFIG_MODULE_FORCE_LOAD is not set
CONFIG_MODULE_UNLOAD=y
# CONFIG_MODULE_FORCE_UNLOAD is not set
# CONFIG_MODVERSIONS is not set
# CONFIG_MODULE_SRCVERSION_ALL is not set
# CONFIG_MODULE_SIG is not set
# CONFIG_MODULE_COMPRESS is not set
# CONFIG_TRIM_UNUSED_KSYMS is not set
CONFIG_MODULES_TREE_LOOKUP=y
CONFIG_BLOCK=y
CONFIG_LBDAF=y
CONFIG_BLK_SCSI_REQUEST=y
CONFIG_BLK_DEV_BSG=y
# CONFIG_BLK_DEV_BSGLIB is not set
# CONFIG_BLK_DEV_INTEGRITY is not set
# CONFIG_BLK_DEV_ZONED is not set
# CONFIG_BLK_CMDLINE_PARSER is not set
# CONFIG_BLK_WBT is not set
CONFIG_BLK_DEBUG_FS=y
# CONFIG_BLK_SED_OPAL is not set
# Partition Types
# CONFIG_PARTITION_ADVANCED is not set
CONFIG_MSDOS_PARTITION=y
CONFIG_EFI_PARTITION=y
# IO Schedulers
CONFIG_IOSCHED_NOOP=y
CONFIG_IOSCHED_DEADLINE=y
CONFIG_IOSCHED_CFQ=y
# CONFIG_DEFAULT_DEADLINE is not set
CONFIG_DEFAULT_CFQ=y
# CONFIG_DEFAULT_NOOP is not set
CONFIG_DEFAULT_IOSCHED="cfq"
CONFIG_MQ_IOSCHED_DEADLINE=y
CONFIG_MQ_IOSCHED_KYBER=y
# CONFIG_IOSCHED_BFQ is not set
CONFIG_ASN1=y
CONFIG_INLINE_SPIN_UNLOCK_IRQ=y
CONFIG_INLINE_READ_UNLOCK=y
CONFIG_INLINE_READ_UNLOCK_IRQ=y
CONFIG_INLINE_WRITE_UNLOCK=y
CONFIG_INLINE_WRITE_UNLOCK_IRQ=y
CONFIG_ARCH_SUPPORTS_ATOMIC_RMW=y
CONFIG_FREEZER=y
# System Type
CONFIG_MMU=y
CONFIG_ARCH_MULTIPLATFORM=y
# CONFIG_ARCH_EBSA110 is not set
# CONFIG_ARCH_EP93XX is not set
# CONFIG_ARCH_FOOTBRIDGE is not set
# CONFIG_ARCH_NETX is not set
# CONFIG_ARCH_IOP13XX is not set
# CONFIG_ARCH_IOP32X is not set
# CONFIG_ARCH_IOP33X is not set
# CONFIG_ARCH_IXP4XX is not set
# CONFIG_ARCH_DOVE is not set
# CONFIG_ARCH_KS8695 is not set
# CONFIG_ARCH_W90X900 is not set
# CONFIG_ARCH_LPC32XX is not set
# CONFIG_ARCH_PXA is not set
# CONFIG_ARCH_RPC is not set
# CONFIG_ARCH_SA1100 is not set
# CONFIG_ARCH_S3C24XX is not set
# CONFIG_ARCH_DAVINCI is not set
# CONFIG_ARCH_OMAP1 is not set
# Multiple platform selection
# CPU Core family selection
# CONFIG_ARCH_MULTI_V4 is not set
# CONFIG_ARCH_MULTI_V4T is not set
CONFIG_ARCH_MULTI_V5=y
CONFIG_ARCH_MULTI_V4_V5=y
# CONFIG_ARCH_MULTI_V6 is not set
# CONFIG_ARCH_MULTI_V7 is not set
CONFIG_ARCH_MULTI_CPU_AUTO=y
# CONFIG_ARCH_MVEBU is not set
# CONFIG_MACH_ASM9260 is not set
# CONFIG_ARCH_AT91 is not set
# CONFIG_ARCH_INTEGRATOR is not set
# CONFIG_ARCH_ASPEED is not set
# CONFIG_ARCH_MV78XX0 is not set
# CONFIG_ARCH_MXC is not set
# CONFIG_ARCH_MXS is not set
# CONFIG_ARCH_NOMADIK is not set
# CONFIG_ARCH_NSPIRE is not set
# CONFIG_ARCH_ORION5X is not set
# CONFIG_ARCH_MMP is not set
# CONFIG_ARCH_OXNAS is not set
# CONFIG_ARCH_REALVIEW is not set
# CONFIG_PLAT_SPEAR is not set
CONFIG_ARCH_SUNXI=y
# CONFIG_ARCH_SUNXI_V7 is not set
CONFIG_ARCH_SUNXI_V5=y
CONFIG_MACH_SUNIV=y
# CONFIG_ARCH_U300 is not set
# CONFIG_ARCH_VERSATILE is not set
# CONFIG_ARCH_WM8505 is not set
# Processor Type
CONFIG_CPU_ARM926T=y
CONFIG_CPU_THUMB_CAPABLE=y
CONFIG_CPU_32v5=y
CONFIG_CPU_ABRT_EV5TJ=y
CONFIG_CPU_PABRT_LEGACY=y
CONFIG_CPU_CACHE_VIVT=y
CONFIG_CPU_COPY_V4WB=y
CONFIG_CPU_TLB_V4WBI=y
CONFIG_CPU_CP15=y
CONFIG_CPU_CP15_MMU=y
CONFIG_CPU_USE_DOMAINS=y
# Processor Features
# CONFIG_ARCH_PHYS_ADDR_T_64BIT is not set
CONFIG_ARM_THUMB=y
# CONFIG_CPU_ICACHE_DISABLE is not set
# CONFIG_CPU_DCACHE_DISABLE is not set
# CONFIG_CPU_DCACHE_WRITETHROUGH is not set
# CONFIG_CPU_CACHE_ROUND_ROBIN is not set
CONFIG_NEED_KUSER_HELPERS=y
CONFIG_KUSER_HELPERS=y
# CONFIG_CACHE_L2X0 is not set
CONFIG_ARM_L1_CACHE_SHIFT=5
CONFIG_DEBUG_ALIGN_RODATA=y
CONFIG_MULTI_IRQ_HANDLER=y
# Bus support
# CONFIG_PCI is not set
# CONFIG_PCI_DOMAINS_GENERIC is not set
# CONFIG_PCI_SYSCALL is not set
# DesignWare PCI Core Support
# PCI Endpoint
# CONFIG_PCI_ENDPOINT is not set
# CONFIG_PCCARD is not set
# Kernel Features
CONFIG_VMSPLIT_3G=y
# CONFIG_VMSPLIT_3G_OPT is not set
# CONFIG_VMSPLIT_2G is not set
# CONFIG_VMSPLIT_1G is not set
CONFIG_PAGE_OFFSET=0xC0000000
CONFIG_ARCH_NR_GPIO=416
CONFIG_PREEMPT_NONE=y
# CONFIG_PREEMPT_VOLUNTARY is not set
# CONFIG_PREEMPT is not set
CONFIG_HZ_FIXED=0
CONFIG_HZ_100=y
# CONFIG_HZ_200 is not set
# CONFIG_HZ_250 is not set
# CONFIG_HZ_300 is not set
# CONFIG_HZ_500 is not set
# CONFIG_HZ_1000 is not set
CONFIG_HZ=100
CONFIG_SCHED_HRTICK=y
CONFIG_AEABI=y
CONFIG_OABI_COMPAT=y
# CONFIG_ARCH_SPARSEMEM_DEFAULT is not set
# CONFIG_ARCH_SELECT_MEMORY_MODEL is not set
CONFIG_HAVE_ARCH_PFN_VALID=y
CONFIG_HIGHMEM=y
CONFIG_HIGHPTE=y
CONFIG_CPU_SW_DOMAIN_PAN=y
CONFIG_HW_PERF_EVENTS=y
CONFIG_ARCH_WANT_GENERAL_HUGETLB=y
# CONFIG_ARM_MODULE_PLTS is not set
CONFIG_FLATMEM=y
CONFIG_FLAT_NODE_MEM_MAP=y
CONFIG_HAVE_MEMBLOCK=y
CONFIG_NO_BOOTMEM=y
# CONFIG_HAVE_BOOTMEM_INFO_NODE is not set
CONFIG_SPLIT_PTLOCK_CPUS=999999
CONFIG_COMPACTION=y
CONFIG_MIGRATION=y
# CONFIG_PHYS_ADDR_T_64BIT is not set
CONFIG_BOUNCE=y
# CONFIG_KSM is not set
CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
# CONFIG_ARCH_WANTS_THP_SWAP is not set
CONFIG_NEED_PER_CPU_KM=y
# CONFIG_CLEANCACHE is not set
# CONFIG_FRONTSWAP is not set
# CONFIG_CMA is not set
# CONFIG_ZPOOL is not set
# CONFIG_ZBUD is not set
# CONFIG_ZSMALLOC is not set
CONFIG_GENERIC_EARLY_IOREMAP=y
# CONFIG_IDLE_PAGE_TRACKING is not set
# CONFIG_PERCPU_STATS is not set
# CONFIG_GUP_BENCHMARK is not set
CONFIG_FORCE_MAX_ZONEORDER=11
CONFIG_ALIGNMENT_TRAP=y
# CONFIG_UACCESS_WITH_MEMCPY is not set
# CONFIG_SECCOMP is not set
CONFIG_SWIOTLB=y
CONFIG_IOMMU_HELPER=y
# CONFIG_PARAVIRT is not set
# CONFIG_PARAVIRT_TIME_ACCOUNTING is not set
# Boot options
CONFIG_USE_OF=y
CONFIG_ATAGS=y
# CONFIG_DEPRECATED_PARAM_STRUCT is not set
CONFIG_ZBOOT_ROM_TEXT=0
CONFIG_ZBOOT_ROM_BSS=0
CONFIG_ARM_APPENDED_DTB=y
CONFIG_ARM_ATAG_DTB_COMPAT=y
CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_FROM_BOOTLOADER=y
# CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_EXTEND is not set
CONFIG_CMDLINE=""
# CONFIG_KEXEC is not set
# CONFIG_CRASH_DUMP is not set
CONFIG_AUTO_ZRELADDR=y
# CONFIG_EFI is not set
# CPU Power Management
# CPU Frequency scaling
CONFIG_CPU_FREQ=y
# CONFIG_CPU_FREQ_STAT is not set
CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE=y
# CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set
CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
# CONFIG_CPU_FREQ_GOV_POWERSAVE is not set
# CONFIG_CPU_FREQ_GOV_USERSPACE is not set
# CONFIG_CPU_FREQ_GOV_ONDEMAND is not set
# CONFIG_CPU_FREQ_GOV_CONSERVATIVE is not set
# CPU frequency scaling drivers
CONFIG_CPUFREQ_DT=y
CONFIG_CPUFREQ_DT_PLATDEV=y
# CONFIG_ARM_KIRKWOOD_CPUFREQ is not set
# CONFIG_QORIQ_CPUFREQ is not set
# CPU Idle
CONFIG_CPU_IDLE=y
CONFIG_CPU_IDLE_MULTIPLE_DRIVERS=y
# CONFIG_CPU_IDLE_GOV_LADDER is not set
CONFIG_CPU_IDLE_GOV_MENU=y
CONFIG_DT_IDLE_STATES=y
# ARM CPU Idle Drivers
CONFIG_ARM_CPUIDLE=y
# CONFIG_ARCH_NEEDS_CPU_IDLE_COUPLED is not set
# Floating point emulation
# At least one emulation must be selected
CONFIG_FPE_NWFPE=y
# CONFIG_FPE_NWFPE_XP is not set
# CONFIG_FPE_FASTFPE is not set
# CONFIG_VFP is not set
# Userspace binary formats
CONFIG_BINFMT_ELF=y
# CONFIG_BINFMT_ELF_FDPIC is not set
CONFIG_ELFCORE=y
CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS=y
CONFIG_BINFMT_SCRIPT=y
# CONFIG_BINFMT_FLAT is not set
# CONFIG_HAVE_AOUT is not set
# CONFIG_BINFMT_MISC is not set
CONFIG_COREDUMP=y
# Power management options
CONFIG_SUSPEND=y
CONFIG_SUSPEND_FREEZER=y
# CONFIG_HIBERNATION is not set
CONFIG_PM_SLEEP=y
# CONFIG_PM_AUTOSLEEP is not set
# CONFIG_PM_WAKELOCKS is not set
CONFIG_PM=y
# CONFIG_PM_DEBUG is not set
# CONFIG_APM_EMULATION is not set
CONFIG_PM_CLK=y
# CONFIG_WQ_POWER_EFFICIENT_DEFAULT is not set
CONFIG_CPU_PM=y
CONFIG_ARCH_SUSPEND_POSSIBLE=y
CONFIG_ARM_CPU_SUSPEND=y
CONFIG_ARCH_HIBERNATION_POSSIBLE=y
CONFIG_NET=y
# Networking options
CONFIG_PACKET=y
# CONFIG_PACKET_DIAG is not set
CONFIG_UNIX=y
# CONFIG_UNIX_DIAG is not set
# CONFIG_TLS is not set
# CONFIG_XFRM_USER is not set
# CONFIG_NET_KEY is not set
CONFIG_INET=y
# CONFIG_IP_MULTICAST is not set
# CONFIG_IP_ADVANCED_ROUTER is not set
CONFIG_IP_PNP=y
CONFIG_IP_PNP_DHCP=y
CONFIG_IP_PNP_BOOTP=y
# CONFIG_IP_PNP_RARP is not set
# CONFIG_NET_IPIP is not set
# CONFIG_NET_IPGRE_DEMUX is not set
# CONFIG_NET_IP_TUNNEL is not set
# CONFIG_SYN_COOKIES is not set
# CONFIG_NET_UDP_TUNNEL is not set
# CONFIG_NET_FOU is not set
# CONFIG_INET_AH is not set
# CONFIG_INET_ESP is not set
# CONFIG_INET_IPCOMP is not set
# CONFIG_INET_XFRM_TUNNEL is not set
# CONFIG_INET_TUNNEL is not set
# CONFIG_INET_XFRM_MODE_TRANSPORT is not set
# CONFIG_INET_XFRM_MODE_TUNNEL is not set
# CONFIG_INET_XFRM_MODE_BEET is not set
# CONFIG_INET_DIAG is not set
# CONFIG_TCP_CONG_ADVANCED is not set
CONFIG_TCP_CONG_CUBIC=y
CONFIG_DEFAULT_TCP_CONG="cubic"
# CONFIG_TCP_MD5SIG is not set
# CONFIG_IPV6 is not set
# CONFIG_NETWORK_SECMARK is not set
CONFIG_NET_PTP_CLASSIFY=y
# CONFIG_NETWORK_PHY_TIMESTAMPING is not set
# CONFIG_NETFILTER is not set
# CONFIG_IP_DCCP is not set
# CONFIG_IP_SCTP is not set
# CONFIG_RDS is not set
# CONFIG_TIPC is not set
# CONFIG_ATM is not set
# CONFIG_L2TP is not set
# CONFIG_BRIDGE is not set
CONFIG_HAVE_NET_DSA=y
# CONFIG_NET_DSA is not set
# CONFIG_VLAN_8021Q is not set
# CONFIG_DECNET is not set
# CONFIG_LLC2 is not set
# CONFIG_IPX is not set
# CONFIG_ATALK is not set
# CONFIG_X25 is not set
# CONFIG_LAPB is not set
# CONFIG_PHONET is not set
# CONFIG_IEEE802154 is not set
# CONFIG_NET_SCHED is not set
# CONFIG_DCB is not set
CONFIG_DNS_RESOLVER=y
# CONFIG_BATMAN_ADV is not set
# CONFIG_OPENVSWITCH is not set
# CONFIG_VSOCKETS is not set
# CONFIG_NETLINK_DIAG is not set
# CONFIG_MPLS is not set
# CONFIG_NET_NSH is not set
# CONFIG_HSR is not set
# CONFIG_NET_SWITCHDEV is not set
# CONFIG_NET_L3_MASTER_DEV is not set
# CONFIG_NET_NCSI is not set
# CONFIG_CGROUP_NET_PRIO is not set
# CONFIG_CGROUP_NET_CLASSID is not set
CONFIG_NET_RX_BUSY_POLL=y
CONFIG_BQL=y
# CONFIG_BPF_JIT is not set
# Network testing
# CONFIG_NET_PKTGEN is not set
# CONFIG_HAMRADIO is not set
# CONFIG_CAN is not set
# CONFIG_BT is not set
# CONFIG_AF_RXRPC is not set
# CONFIG_AF_KCM is not set
# CONFIG_STREAM_PARSER is not set
CONFIG_WIRELESS=y
CONFIG_WIRELESS_EXT=y
CONFIG_WEXT_CORE=y
CONFIG_WEXT_PROC=y
CONFIG_WEXT_PRIV=y
CONFIG_CFG80211=y
# CONFIG_NL80211_TESTMODE is not set
# CONFIG_CFG80211_DEVELOPER_WARNINGS is not set
CONFIG_CFG80211_REQUIRE_SIGNED_REGDB=y
CONFIG_CFG80211_USE_KERNEL_REGDB_KEYS=y
CONFIG_CFG80211_DEFAULT_PS=y
# CONFIG_CFG80211_DEBUGFS is not set
CONFIG_CFG80211_CRDA_SUPPORT=y
CONFIG_CFG80211_WEXT=y
# CONFIG_LIB80211 is not set
CONFIG_MAC80211=y
CONFIG_MAC80211_HAS_RC=y
CONFIG_MAC80211_RC_MINSTREL=y
CONFIG_MAC80211_RC_MINSTREL_HT=y
# CONFIG_MAC80211_RC_MINSTREL_VHT is not set
CONFIG_MAC80211_RC_DEFAULT_MINSTREL=y
CONFIG_MAC80211_RC_DEFAULT="minstrel_ht"
# CONFIG_MAC80211_MESH is not set
CONFIG_MAC80211_LEDS=y
# CONFIG_MAC80211_DEBUGFS is not set
# CONFIG_MAC80211_MESSAGE_TRACING is not set
# CONFIG_MAC80211_DEBUG_MENU is not set
CONFIG_MAC80211_STA_HASH_MAX_SIZE=0
# CONFIG_WIMAX is not set
# CONFIG_RFKILL is not set
# CONFIG_NET_9P is not set
# CONFIG_CAIF is not set
# CONFIG_CEPH_LIB is not set
# CONFIG_NFC is not set
# CONFIG_PSAMPLE is not set
# CONFIG_NET_IFE is not set
# CONFIG_LWTUNNEL is not set
# CONFIG_DST_CACHE is not set
# CONFIG_GRO_CELLS is not set
# CONFIG_NET_DEVLINK is not set
CONFIG_MAY_USE_DEVLINK=y
CONFIG_HAVE_EBPF_JIT=y
# Device Drivers
# Generic Driver Options
CONFIG_UEVENT_HELPER=y
CONFIG_UEVENT_HELPER_PATH=""
CONFIG_DEVTMPFS=y
CONFIG_DEVTMPFS_MOUNT=y
CONFIG_STANDALONE=y
CONFIG_PREVENT_FIRMWARE_BUILD=y
CONFIG_FW_LOADER=y
CONFIG_FIRMWARE_IN_KERNEL=y
CONFIG_EXTRA_FIRMWARE=""
# CONFIG_FW_LOADER_USER_HELPER_FALLBACK is not set
CONFIG_ALLOW_DEV_COREDUMP=y
# CONFIG_DEBUG_DRIVER is not set
# CONFIG_DEBUG_DEVRES is not set
# CONFIG_DEBUG_TEST_DRIVER_REMOVE is not set
# CONFIG_TEST_ASYNC_DRIVER_PROBE is not set
# CONFIG_SYS_HYPERVISOR is not set
# CONFIG_GENERIC_CPU_DEVICES is not set
CONFIG_GENERIC_CPU_AUTOPROBE=y
CONFIG_REGMAP=y
CONFIG_REGMAP_I2C=y
CONFIG_REGMAP_SPI=y
CONFIG_REGMAP_MMIO=y
CONFIG_REGMAP_IRQ=y
CONFIG_DMA_SHARED_BUFFER=y
# CONFIG_DMA_FENCE_TRACE is not set
# Bus devices
# CONFIG_ARM_CCN is not set
# CONFIG_BRCMSTB_GISB_ARB is not set
# CONFIG_SIMPLE_PM_BUS is not set
CONFIG_SUNXI_RSB=y
# CONFIG_VEXPRESS_CONFIG is not set
# CONFIG_CONNECTOR is not set
CONFIG_MTD=y
# CONFIG_MTD_TESTS is not set
# CONFIG_MTD_REDBOOT_PARTS is not set
# CONFIG_MTD_CMDLINE_PARTS is not set
# CONFIG_MTD_AFS_PARTS is not set
CONFIG_MTD_OF_PARTS=y
# CONFIG_MTD_AR7_PARTS is not set
# Partition parsers
# User Modules And Translation Layers
# CONFIG_MTD_BLOCK is not set
# CONFIG_MTD_BLOCK_RO is not set
# CONFIG_FTL is not set
# CONFIG_NFTL is not set
# CONFIG_INFTL is not set
# CONFIG_RFD_FTL is not set
# CONFIG_SSFDC is not set
# CONFIG_SM_FTL is not set
# CONFIG_MTD_OOPS is not set
# CONFIG_MTD_SWAP is not set
# CONFIG_MTD_PARTITIONED_MASTER is not set
# RAM/ROM/Flash chip drivers
# CONFIG_MTD_CFI is not set
# CONFIG_MTD_JEDECPROBE is not set
CONFIG_MTD_MAP_BANK_WIDTH_1=y
CONFIG_MTD_MAP_BANK_WIDTH_2=y
CONFIG_MTD_MAP_BANK_WIDTH_4=y
# CONFIG_MTD_MAP_BANK_WIDTH_8 is not set
# CONFIG_MTD_MAP_BANK_WIDTH_16 is not set
# CONFIG_MTD_MAP_BANK_WIDTH_32 is not set
CONFIG_MTD_CFI_I1=y
CONFIG_MTD_CFI_I2=y
# CONFIG_MTD_CFI_I4 is not set
# CONFIG_MTD_CFI_I8 is not set
# CONFIG_MTD_RAM is not set
# CONFIG_MTD_ROM is not set
# CONFIG_MTD_ABSENT is not set
# Mapping drivers for chip access
# CONFIG_MTD_COMPLEX_MAPPINGS is not set
# CONFIG_MTD_PLATRAM is not set
# Self-contained MTD device drivers
# CONFIG_MTD_DATAFLASH is not set
CONFIG_MTD_M25P80=y
# CONFIG_MTD_MCHP23K256 is not set
# CONFIG_MTD_SST25L is not set
# CONFIG_MTD_SLRAM is not set
# CONFIG_MTD_PHRAM is not set
# CONFIG_MTD_MTDRAM is not set
# CONFIG_MTD_BLOCK2MTD is not set
# Disk-On-Chip Device Drivers
# CONFIG_MTD_DOCG3 is not set
# CONFIG_MTD_NAND is not set
# CONFIG_MTD_ONENAND is not set
# LPDDR & LPDDR2 PCM memory drivers
# CONFIG_MTD_LPDDR is not set
# CONFIG_MTD_LPDDR2_NVM is not set
CONFIG_MTD_SPI_NOR=y
# CONFIG_MTD_MT81xx_NOR is not set
CONFIG_MTD_SPI_NOR_USE_4K_SECTORS=y
# CONFIG_SPI_CADENCE_QUADSPI is not set
# CONFIG_MTD_UBI is not set
CONFIG_DTC=y
CONFIG_OF=y
# CONFIG_OF_UNITTEST is not set
CONFIG_OF_FLATTREE=y
CONFIG_OF_EARLY_FLATTREE=y
CONFIG_OF_KOBJ=y
CONFIG_OF_ADDRESS=y
CONFIG_OF_IRQ=y
CONFIG_OF_NET=y
CONFIG_OF_RESERVED_MEM=y
# CONFIG_OF_OVERLAY is not set
CONFIG_ARCH_MIGHT_HAVE_PC_PARPORT=y
# CONFIG_PARPORT is not set
CONFIG_BLK_DEV=y
# CONFIG_BLK_DEV_NULL_BLK is not set
# CONFIG_BLK_DEV_COW_COMMON is not set
# CONFIG_BLK_DEV_LOOP is not set
# CONFIG_BLK_DEV_DRBD is not set
# CONFIG_BLK_DEV_NBD is not set
# CONFIG_BLK_DEV_RAM is not set
# CONFIG_CDROM_PKTCDVD is not set
# CONFIG_ATA_OVER_ETH is not set
# CONFIG_BLK_DEV_RBD is not set
# NVME Support
# CONFIG_NVME_FC is not set
# CONFIG_NVME_TARGET is not set
# Misc devices
# CONFIG_SENSORS_LIS3LV02D is not set
# CONFIG_AD525X_DPOT is not set
# CONFIG_DUMMY_IRQ is not set
# CONFIG_ICS932S401 is not set
# CONFIG_ENCLOSURE_SERVICES is not set
# CONFIG_APDS9802ALS is not set
# CONFIG_ISL29003 is not set
# CONFIG_ISL29020 is not set
# CONFIG_SENSORS_TSL2550 is not set
# CONFIG_SENSORS_BH1770 is not set
# CONFIG_SENSORS_APDS990X is not set
# CONFIG_HMC6352 is not set
# CONFIG_DS1682 is not set
# CONFIG_USB_SWITCH_FSA9480 is not set
# CONFIG_LATTICE_ECP3_CONFIG is not set
# CONFIG_SRAM is not set
# CONFIG_C2PORT is not set
# EEPROM support
# CONFIG_EEPROM_AT24 is not set
# CONFIG_EEPROM_AT25 is not set
# CONFIG_EEPROM_LEGACY is not set
# CONFIG_EEPROM_MAX6875 is not set
# CONFIG_EEPROM_93CX6 is not set
# CONFIG_EEPROM_93XX46 is not set
# CONFIG_EEPROM_IDT_89HPESX is not set
# Texas Instruments shared transport line discipline
# CONFIG_TI_ST is not set
# CONFIG_SENSORS_LIS3_SPI is not set
# CONFIG_SENSORS_LIS3_I2C is not set
# CONFIG_ALTERA_STAPL is not set
# Intel MIC & related support
# Intel MIC Bus Driver
# SCIF Bus Driver
# VOP Bus Driver
# Intel MIC Host Driver
# Intel MIC Card Driver
# SCIF Driver
# Intel MIC Coprocessor State Management (COSM) Drivers
# VOP Driver
# CONFIG_ECHO is not set
# CONFIG_CXL_BASE is not set
# CONFIG_CXL_AFU_DRIVER_OPS is not set
# CONFIG_CXL_LIB is not set
# SCSI device support
CONFIG_SCSI_MOD=y
# CONFIG_RAID_ATTRS is not set
CONFIG_SCSI=y
CONFIG_SCSI_DMA=y
# CONFIG_SCSI_NETLINK is not set
# CONFIG_SCSI_MQ_DEFAULT is not set
CONFIG_SCSI_PROC_FS=y
# SCSI support type (disk, tape, CD-ROM)
CONFIG_BLK_DEV_SD=y
# CONFIG_CHR_DEV_ST is not set
# CONFIG_CHR_DEV_OSST is not set
# CONFIG_BLK_DEV_SR is not set
CONFIG_CHR_DEV_SG=y
CONFIG_CHR_DEV_SCH=y
# CONFIG_SCSI_CONSTANTS is not set
# CONFIG_SCSI_LOGGING is not set
# CONFIG_SCSI_SCAN_ASYNC is not set
# SCSI Transports
# CONFIG_SCSI_SPI_ATTRS is not set
# CONFIG_SCSI_FC_ATTRS is not set
# CONFIG_SCSI_ISCSI_ATTRS is not set
# CONFIG_SCSI_SAS_ATTRS is not set
# CONFIG_SCSI_SAS_LIBSAS is not set
# CONFIG_SCSI_SRP_ATTRS is not set
CONFIG_SCSI_LOWLEVEL=y
# CONFIG_ISCSI_TCP is not set
# CONFIG_ISCSI_BOOT_SYSFS is not set
# CONFIG_SCSI_UFSHCD is not set
# CONFIG_SCSI_DEBUG is not set
# CONFIG_SCSI_DH is not set
# CONFIG_SCSI_OSD_INITIATOR is not set
# CONFIG_ATA is not set
# CONFIG_MD is not set
# CONFIG_TARGET_CORE is not set
CONFIG_NETDEVICES=y
CONFIG_MII=m
CONFIG_NET_CORE=y
# CONFIG_BONDING is not set
# CONFIG_DUMMY is not set
# CONFIG_EQUALIZER is not set
# CONFIG_NET_TEAM is not set
# CONFIG_MACVLAN is not set
# CONFIG_VXLAN is not set
# CONFIG_MACSEC is not set
# CONFIG_NETCONSOLE is not set
# CONFIG_NETPOLL is not set
# CONFIG_NET_POLL_CONTROLLER is not set
# CONFIG_TUN is not set
# CONFIG_TUN_VNET_CROSS_LE is not set
# CONFIG_VETH is not set
# CONFIG_NLMON is not set
# CAIF transport drivers
# Distributed Switch Architecture drivers
# CONFIG_ETHERNET is not set
CONFIG_MDIO_DEVICE=y
CONFIG_MDIO_BUS=y
# CONFIG_MDIO_BITBANG is not set
# CONFIG_MDIO_SUN4I is not set
# CONFIG_PHYLIB is not set
# CONFIG_MICREL_KS8995MA is not set
# CONFIG_PPP is not set
# CONFIG_SLIP is not set
CONFIG_USB_NET_DRIVERS=m
# CONFIG_USB_CATC is not set
# CONFIG_USB_KAWETH is not set
# CONFIG_USB_PEGASUS is not set
CONFIG_USB_RTL8150=m
# CONFIG_USB_RTL8152 is not set
# CONFIG_USB_LAN78XX is not set
# CONFIG_USB_USBNET is not set
# CONFIG_USB_IPHETH is not set
CONFIG_WLAN=y
# CONFIG_WLAN_VENDOR_ADMTEK is not set
# CONFIG_WLAN_VENDOR_ATH is not set
# CONFIG_WLAN_VENDOR_ATMEL is not set
# CONFIG_WLAN_VENDOR_BROADCOM is not set
# CONFIG_WLAN_VENDOR_CISCO is not set
# CONFIG_WLAN_VENDOR_INTEL is not set
# CONFIG_WLAN_VENDOR_INTERSIL is not set
# CONFIG_WLAN_VENDOR_MARVELL is not set
# CONFIG_WLAN_VENDOR_MEDIATEK is not set
# CONFIG_WLAN_VENDOR_RALINK is not set
# CONFIG_WLAN_VENDOR_REALTEK is not set
# CONFIG_WLAN_VENDOR_RSI is not set
# CONFIG_WLAN_VENDOR_ST is not set
# CONFIG_WLAN_VENDOR_TI is not set
# CONFIG_WLAN_VENDOR_ZYDAS is not set
# CONFIG_WLAN_VENDOR_QUANTENNA is not set
# CONFIG_MAC80211_HWSIM is not set
# CONFIG_USB_NET_RNDIS_WLAN is not set
# Enable WiMAX (Networking options) to see the WiMAX drivers
# CONFIG_WAN is not set
# CONFIG_ISDN is not set
# Input device support
CONFIG_INPUT=y
CONFIG_INPUT_LEDS=y
# CONFIG_INPUT_FF_MEMLESS is not set
CONFIG_INPUT_POLLDEV=y
# CONFIG_INPUT_SPARSEKMAP is not set
# CONFIG_INPUT_MATRIXKMAP is not set
# Userland interfaces
# CONFIG_INPUT_MOUSEDEV is not set
# CONFIG_INPUT_JOYDEV is not set
CONFIG_INPUT_EVDEV=y
# CONFIG_INPUT_EVBUG is not set
# Input Device Drivers
CONFIG_INPUT_KEYBOARD=y
# CONFIG_KEYBOARD_ADP5588 is not set
# CONFIG_KEYBOARD_ADP5589 is not set
# CONFIG_KEYBOARD_ATKBD is not set
# CONFIG_KEYBOARD_QT1070 is not set
# CONFIG_KEYBOARD_QT2160 is not set
# CONFIG_KEYBOARD_DLINK_DIR685 is not set
# CONFIG_KEYBOARD_LKKBD is not set
# CONFIG_KEYBOARD_GPIO is not set
# CONFIG_KEYBOARD_GPIO_POLLED is not set
# CONFIG_KEYBOARD_TCA6416 is not set
# CONFIG_KEYBOARD_TCA8418 is not set
# CONFIG_KEYBOARD_MATRIX is not set
# CONFIG_KEYBOARD_LM8323 is not set
# CONFIG_KEYBOARD_LM8333 is not set
# CONFIG_KEYBOARD_MAX7359 is not set
# CONFIG_KEYBOARD_MCS is not set
# CONFIG_KEYBOARD_MPR121 is not set
# CONFIG_KEYBOARD_NEWTON is not set
# CONFIG_KEYBOARD_OPENCORES is not set
# CONFIG_KEYBOARD_SAMSUNG is not set
# CONFIG_KEYBOARD_STOWAWAY is not set
# CONFIG_KEYBOARD_SUNKBD is not set
CONFIG_KEYBOARD_SUN4I_LRADC=y
# CONFIG_KEYBOARD_OMAP4 is not set
# CONFIG_KEYBOARD_TM2_TOUCHKEY is not set
# CONFIG_KEYBOARD_XTKBD is not set
# CONFIG_KEYBOARD_CAP11XX is not set
# CONFIG_KEYBOARD_BCM is not set
# CONFIG_INPUT_MOUSE is not set
# CONFIG_INPUT_JOYSTICK is not set
# CONFIG_INPUT_TABLET is not set
CONFIG_INPUT_TOUCHSCREEN=y
CONFIG_TOUCHSCREEN_PROPERTIES=y
# CONFIG_TOUCHSCREEN_ADS7846 is not set
# CONFIG_TOUCHSCREEN_AD7877 is not set
# CONFIG_TOUCHSCREEN_AD7879 is not set
# CONFIG_TOUCHSCREEN_AR1021_I2C is not set
# CONFIG_TOUCHSCREEN_ATMEL_MXT is not set
# CONFIG_TOUCHSCREEN_AUO_PIXCIR is not set
# CONFIG_TOUCHSCREEN_BU21013 is not set
# CONFIG_TOUCHSCREEN_CHIPONE_ICN8318 is not set
# CONFIG_TOUCHSCREEN_CY8CTMG110 is not set
# CONFIG_TOUCHSCREEN_CYTTSP_CORE is not set
# CONFIG_TOUCHSCREEN_CYTTSP4_CORE is not set
# CONFIG_TOUCHSCREEN_DYNAPRO is not set
# CONFIG_TOUCHSCREEN_HAMPSHIRE is not set
# CONFIG_TOUCHSCREEN_EETI is not set
# CONFIG_TOUCHSCREEN_EGALAX is not set
# CONFIG_TOUCHSCREEN_EGALAX_SERIAL is not set
# CONFIG_TOUCHSCREEN_EXC3000 is not set
# CONFIG_TOUCHSCREEN_FUJITSU is not set
CONFIG_TOUCHSCREEN_GOODIX=m
# CONFIG_TOUCHSCREEN_HIDEEP is not set
# CONFIG_TOUCHSCREEN_ILI210X is not set
# CONFIG_TOUCHSCREEN_S6SY761 is not set
# CONFIG_TOUCHSCREEN_GUNZE is not set
# CONFIG_TOUCHSCREEN_EKTF2127 is not set
# CONFIG_TOUCHSCREEN_ELAN is not set
# CONFIG_TOUCHSCREEN_ELO is not set
# CONFIG_TOUCHSCREEN_WACOM_W8001 is not set
# CONFIG_TOUCHSCREEN_WACOM_I2C is not set
# CONFIG_TOUCHSCREEN_MAX11801 is not set
# CONFIG_TOUCHSCREEN_MCS5000 is not set
# CONFIG_TOUCHSCREEN_MMS114 is not set
# CONFIG_TOUCHSCREEN_MELFAS_MIP4 is not set
# CONFIG_TOUCHSCREEN_MTOUCH is not set
# CONFIG_TOUCHSCREEN_IMX6UL_TSC is not set
# CONFIG_TOUCHSCREEN_INEXIO is not set
# CONFIG_TOUCHSCREEN_MK712 is not set
# CONFIG_TOUCHSCREEN_PENMOUNT is not set
# CONFIG_TOUCHSCREEN_EDT_FT5X06 is not set
# CONFIG_TOUCHSCREEN_TOUCHRIGHT is not set
# CONFIG_TOUCHSCREEN_TOUCHWIN is not set
# CONFIG_TOUCHSCREEN_PIXCIR is not set
# CONFIG_TOUCHSCREEN_WDT87XX_I2C is not set
# CONFIG_TOUCHSCREEN_USB_COMPOSITE is not set
# CONFIG_TOUCHSCREEN_TOUCHIT213 is not set
# CONFIG_TOUCHSCREEN_TSC_SERIO is not set
# CONFIG_TOUCHSCREEN_TSC2004 is not set
# CONFIG_TOUCHSCREEN_TSC2005 is not set
# CONFIG_TOUCHSCREEN_TSC2007 is not set
# CONFIG_TOUCHSCREEN_RM_TS is not set
# CONFIG_TOUCHSCREEN_SILEAD is not set
# CONFIG_TOUCHSCREEN_SIS_I2C is not set
# CONFIG_TOUCHSCREEN_ST1232 is not set
# CONFIG_TOUCHSCREEN_STMFTS is not set
# CONFIG_TOUCHSCREEN_SURFACE3_SPI is not set
# CONFIG_TOUCHSCREEN_SX8654 is not set
# CONFIG_TOUCHSCREEN_TPS6507X is not set
# CONFIG_TOUCHSCREEN_ZET6223 is not set
# CONFIG_TOUCHSCREEN_ZFORCE is not set
# CONFIG_TOUCHSCREEN_ROHM_BU21023 is not set
CONFIG_INPUT_MISC=y
# CONFIG_INPUT_AD714X is not set
# CONFIG_INPUT_ATMEL_CAPTOUCH is not set
# CONFIG_INPUT_BMA150 is not set
# CONFIG_INPUT_E3X0_BUTTON is not set
# CONFIG_INPUT_MMA8450 is not set
# CONFIG_INPUT_GP2A is not set
# CONFIG_INPUT_GPIO_BEEPER is not set
# CONFIG_INPUT_GPIO_TILT_POLLED is not set
# CONFIG_INPUT_GPIO_DECODER is not set
# CONFIG_INPUT_ATI_REMOTE2 is not set
# CONFIG_INPUT_KEYSPAN_REMOTE is not set
# CONFIG_INPUT_KXTJ9 is not set
# CONFIG_INPUT_POWERMATE is not set
# CONFIG_INPUT_YEALINK is not set
# CONFIG_INPUT_CM109 is not set
# CONFIG_INPUT_REGULATOR_HAPTIC is not set
# CONFIG_INPUT_AXP20X_PEK is not set
# CONFIG_INPUT_UINPUT is not set
# CONFIG_INPUT_PCF8574 is not set
# CONFIG_INPUT_PWM_BEEPER is not set
# CONFIG_INPUT_PWM_VIBRA is not set
# CONFIG_INPUT_GPIO_ROTARY_ENCODER is not set
# CONFIG_INPUT_ADXL34X is not set
# CONFIG_INPUT_IMS_PCU is not set
# CONFIG_INPUT_CMA3000 is not set
# CONFIG_INPUT_DRV260X_HAPTICS is not set
# CONFIG_INPUT_DRV2665_HAPTICS is not set
# CONFIG_INPUT_DRV2667_HAPTICS is not set
# CONFIG_RMI4_CORE is not set
# Hardware I/O ports
CONFIG_SERIO=y
# CONFIG_SERIO_SERPORT is not set
# CONFIG_SERIO_LIBPS2 is not set
# CONFIG_SERIO_RAW is not set
# CONFIG_SERIO_ALTERA_PS2 is not set
# CONFIG_SERIO_PS2MULT is not set
# CONFIG_SERIO_ARC_PS2 is not set
# CONFIG_SERIO_APBPS2 is not set
# CONFIG_SERIO_SUN4I_PS2 is not set
# CONFIG_SERIO_GPIO_PS2 is not set
# CONFIG_USERIO is not set
# CONFIG_GAMEPORT is not set
# Character devices
CONFIG_TTY=y
CONFIG_VT=y
CONFIG_CONSOLE_TRANSLATIONS=y
CONFIG_VT_CONSOLE=y
CONFIG_VT_CONSOLE_SLEEP=y
CONFIG_HW_CONSOLE=y
CONFIG_VT_HW_CONSOLE_BINDING=y
CONFIG_UNIX98_PTYS=y
CONFIG_LEGACY_PTYS=y
CONFIG_LEGACY_PTY_COUNT=256
# CONFIG_SERIAL_NONSTANDARD is not set
# CONFIG_N_GSM is not set
# CONFIG_TRACE_SINK is not set
CONFIG_DEVMEM=y
# CONFIG_DEVKMEM is not set
# Serial drivers
CONFIG_SERIAL_EARLYCON=y
CONFIG_SERIAL_8250=y
CONFIG_SERIAL_8250_DEPRECATED_OPTIONS=y
# CONFIG_SERIAL_8250_FINTEK is not set
CONFIG_SERIAL_8250_CONSOLE=y
CONFIG_SERIAL_8250_DMA=y
CONFIG_SERIAL_8250_NR_UARTS=8
CONFIG_SERIAL_8250_RUNTIME_UARTS=8
# CONFIG_SERIAL_8250_EXTENDED is not set
# CONFIG_SERIAL_8250_ASPEED_VUART is not set
CONFIG_SERIAL_8250_FSL=y
CONFIG_SERIAL_8250_DW=y
# CONFIG_SERIAL_8250_EM is not set
# CONFIG_SERIAL_8250_RT288X is not set
CONFIG_SERIAL_OF_PLATFORM=y
# Non-8250 serial port support
# CONFIG_SERIAL_EARLYCON_ARM_SEMIHOST is not set
# CONFIG_SERIAL_MAX3100 is not set
# CONFIG_SERIAL_MAX310X is not set
# CONFIG_SERIAL_UARTLITE is not set
CONFIG_SERIAL_CORE=y
CONFIG_SERIAL_CORE_CONSOLE=y
# CONFIG_SERIAL_SCCNXP is not set
# CONFIG_SERIAL_SC16IS7XX is not set
# CONFIG_SERIAL_BCM63XX is not set
# CONFIG_SERIAL_ALTERA_JTAGUART is not set
# CONFIG_SERIAL_ALTERA_UART is not set
# CONFIG_SERIAL_IFX6X60 is not set
# CONFIG_SERIAL_XILINX_PS_UART is not set
# CONFIG_SERIAL_ARC is not set
# CONFIG_SERIAL_FSL_LPUART is not set
# CONFIG_SERIAL_CONEXANT_DIGICOLOR is not set
# CONFIG_SERIAL_ST_ASC is not set
# CONFIG_SERIAL_DEV_BUS is not set
# CONFIG_HVC_DCC is not set
# CONFIG_IPMI_HANDLER is not set
# CONFIG_HW_RANDOM is not set
# CONFIG_R3964 is not set
# CONFIG_RAW_DRIVER is not set
# CONFIG_TCG_TPM is not set
# CONFIG_XILLYBUS is not set
# I2C support
CONFIG_I2C=y
CONFIG_I2C_BOARDINFO=y
CONFIG_I2C_COMPAT=y
CONFIG_I2C_CHARDEV=y
# CONFIG_I2C_MUX is not set
CONFIG_I2C_HELPER_AUTO=y
CONFIG_I2C_ALGOBIT=y
# I2C Hardware Bus support
# I2C system bus drivers (mostly embedded / system-on-chip)
# CONFIG_I2C_CBUS_GPIO is not set
# CONFIG_I2C_DESIGNWARE_PLATFORM is not set
# CONFIG_I2C_EMEV2 is not set
# CONFIG_I2C_GPIO is not set
CONFIG_I2C_MV64XXX=y
# CONFIG_I2C_OCORES is not set
# CONFIG_I2C_PCA_PLATFORM is not set
# CONFIG_I2C_PXA_PCI is not set
# CONFIG_I2C_RK3X is not set
# CONFIG_I2C_SIMTEC is not set
# CONFIG_I2C_XILINX is not set
# External I2C/SMBus adapter drivers
# CONFIG_I2C_DIOLAN_U2C is not set
# CONFIG_I2C_PARPORT_LIGHT is not set
# CONFIG_I2C_ROBOTFUZZ_OSIF is not set
# CONFIG_I2C_TAOS_EVM is not set
# CONFIG_I2C_TINY_USB is not set
# Other I2C/SMBus bus drivers
# CONFIG_I2C_STUB is not set
# CONFIG_I2C_SLAVE is not set
# CONFIG_I2C_DEBUG_CORE is not set
# CONFIG_I2C_DEBUG_ALGO is not set
# CONFIG_I2C_DEBUG_BUS is not set
CONFIG_SPI=y
# CONFIG_SPI_DEBUG is not set
CONFIG_SPI_MASTER=y
# SPI Master Controller Drivers
# CONFIG_SPI_ALTERA is not set
# CONFIG_SPI_AXI_SPI_ENGINE is not set
CONFIG_SPI_BITBANG=y
# CONFIG_SPI_CADENCE is not set
# CONFIG_SPI_DESIGNWARE is not set
CONFIG_SPI_GPIO=y
# CONFIG_SPI_FSL_SPI is not set
# CONFIG_SPI_OC_TINY is not set
# CONFIG_SPI_PXA2XX_PCI is not set
# CONFIG_SPI_ROCKCHIP is not set
# CONFIG_SPI_SC18IS602 is not set
CONFIG_SPI_SUN6I=y
# CONFIG_SPI_XCOMM is not set
# CONFIG_SPI_XILINX is not set
# CONFIG_SPI_ZYNQMP_GQSPI is not set
# SPI Protocol Masters
CONFIG_SPI_SPIDEV=y
# CONFIG_SPI_LOOPBACK_TEST is not set
# CONFIG_SPI_TLE62X0 is not set
# CONFIG_SPI_SLAVE is not set
# CONFIG_SPMI is not set
# CONFIG_HSI is not set
CONFIG_PPS=y
# CONFIG_PPS_DEBUG is not set
# PPS clients support
# CONFIG_PPS_CLIENT_KTIMER is not set
# CONFIG_PPS_CLIENT_LDISC is not set
# CONFIG_PPS_CLIENT_GPIO is not set
# PPS generators support
# PTP clock support
CONFIG_PTP_1588_CLOCK=y
# Enable PHYLIB and NETWORK_PHY_TIMESTAMPING to see the additional clocks.
CONFIG_PINCTRL=y
CONFIG_PINMUX=y
CONFIG_PINCONF=y
CONFIG_GENERIC_PINCONF=y
# CONFIG_DEBUG_PINCTRL is not set
# CONFIG_PINCTRL_AMD is not set
# CONFIG_PINCTRL_MCP23S08 is not set
# CONFIG_PINCTRL_SINGLE is not set
# CONFIG_PINCTRL_SX150X is not set
CONFIG_PINCTRL_SUNXI=y
CONFIG_PINCTRL_SUNIV=y
# CONFIG_PINCTRL_SUN4I_A10 is not set
# CONFIG_PINCTRL_SUN5I is not set
# CONFIG_PINCTRL_SUN6I_A31 is not set
# CONFIG_PINCTRL_SUN6I_A31_R is not set
# CONFIG_PINCTRL_SUN8I_A23 is not set
# CONFIG_PINCTRL_SUN8I_A33 is not set
# CONFIG_PINCTRL_SUN8I_A83T is not set
# CONFIG_PINCTRL_SUN8I_A83T_R is not set
# CONFIG_PINCTRL_SUN8I_A23_R is not set
# CONFIG_PINCTRL_SUN8I_H3 is not set
# CONFIG_PINCTRL_SUN8I_H3_R is not set
# CONFIG_PINCTRL_SUN8I_V3S is not set
# CONFIG_PINCTRL_SUN9I_A80 is not set
# CONFIG_PINCTRL_SUN9I_A80_R is not set
# CONFIG_PINCTRL_SUN50I_A64 is not set
# CONFIG_PINCTRL_SUN50I_A64_R is not set
# CONFIG_PINCTRL_SUN50I_H5 is not set
CONFIG_ARCH_HAVE_CUSTOM_GPIO_H=y
CONFIG_GPIOLIB=y
CONFIG_OF_GPIO=y
# CONFIG_DEBUG_GPIO is not set
CONFIG_GPIO_SYSFS=y
# Memory mapped GPIO drivers
# CONFIG_GPIO_74XX_MMIO is not set
# CONFIG_GPIO_ALTERA is not set
# CONFIG_GPIO_AXP209 is not set
# CONFIG_GPIO_DWAPB is not set
# CONFIG_GPIO_FTGPIO010 is not set
# CONFIG_GPIO_GENERIC_PLATFORM is not set
# CONFIG_GPIO_GRGPIO is not set
# CONFIG_GPIO_MB86S7X is not set
# CONFIG_GPIO_MOCKUP is not set
# CONFIG_GPIO_MPC8XXX is not set
# CONFIG_GPIO_SYSCON is not set
# CONFIG_GPIO_XILINX is not set
# CONFIG_GPIO_ZEVIO is not set
# I2C GPIO expanders
# CONFIG_GPIO_ADP5588 is not set
# CONFIG_GPIO_ADNP is not set
# CONFIG_GPIO_MAX7300 is not set
# CONFIG_GPIO_MAX732X is not set
# CONFIG_GPIO_PCA953X is not set
# CONFIG_GPIO_PCF857X is not set
# CONFIG_GPIO_TPIC2810 is not set
# MFD GPIO expanders
# CONFIG_HTC_EGPIO is not set
# SPI GPIO expanders
# CONFIG_GPIO_74X164 is not set
# CONFIG_GPIO_MAX3191X is not set
# CONFIG_GPIO_MAX7301 is not set
# CONFIG_GPIO_MC33880 is not set
# CONFIG_GPIO_PISOSR is not set
# CONFIG_GPIO_XRA1403 is not set
# USB GPIO expanders
# CONFIG_W1 is not set
# CONFIG_POWER_AVS is not set
# CONFIG_POWER_RESET is not set
CONFIG_POWER_SUPPLY=y
# CONFIG_POWER_SUPPLY_DEBUG is not set
# CONFIG_PDA_POWER is not set
# CONFIG_TEST_POWER is not set
# CONFIG_BATTERY_DS2780 is not set
# CONFIG_BATTERY_DS2781 is not set
# CONFIG_BATTERY_DS2782 is not set
# CONFIG_BATTERY_SBS is not set
# CONFIG_CHARGER_SBS is not set
# CONFIG_BATTERY_BQ27XXX is not set
# CONFIG_BATTERY_MAX17040 is not set
# CONFIG_BATTERY_MAX17042 is not set
# CONFIG_CHARGER_ISP1704 is not set
# CONFIG_CHARGER_MAX8903 is not set
# CONFIG_CHARGER_LP8727 is not set
# CONFIG_CHARGER_GPIO is not set
# CONFIG_CHARGER_MANAGER is not set
# CONFIG_CHARGER_LTC3651 is not set
# CONFIG_CHARGER_DETECTOR_MAX14656 is not set
# CONFIG_CHARGER_BQ2415X is not set
# CONFIG_CHARGER_BQ24190 is not set
# CONFIG_CHARGER_BQ24257 is not set
# CONFIG_CHARGER_BQ24735 is not set
# CONFIG_CHARGER_BQ25890 is not set
# CONFIG_CHARGER_SMB347 is not set
# CONFIG_BATTERY_GAUGE_LTC2941 is not set
# CONFIG_CHARGER_RT9455 is not set
# CONFIG_HWMON is not set
CONFIG_THERMAL=y
CONFIG_THERMAL_EMERGENCY_POWEROFF_DELAY_MS=0
CONFIG_THERMAL_OF=y
# CONFIG_THERMAL_WRITABLE_TRIPS is not set
CONFIG_THERMAL_DEFAULT_GOV_STEP_WISE=y
# CONFIG_THERMAL_DEFAULT_GOV_FAIR_SHARE is not set
# CONFIG_THERMAL_DEFAULT_GOV_USER_SPACE is not set
# CONFIG_THERMAL_DEFAULT_GOV_POWER_ALLOCATOR is not set
# CONFIG_THERMAL_GOV_FAIR_SHARE is not set
CONFIG_THERMAL_GOV_STEP_WISE=y
# CONFIG_THERMAL_GOV_BANG_BANG is not set
# CONFIG_THERMAL_GOV_USER_SPACE is not set
# CONFIG_THERMAL_GOV_POWER_ALLOCATOR is not set
CONFIG_CPU_THERMAL=y
# CONFIG_CLOCK_THERMAL is not set
# CONFIG_THERMAL_EMULATION is not set
# CONFIG_QORIQ_THERMAL is not set
# ACPI INT340X thermal drivers
# CONFIG_WATCHDOG is not set
CONFIG_SSB_POSSIBLE=y
# Sonics Silicon Backplane
# CONFIG_SSB is not set
CONFIG_BCMA_POSSIBLE=y
# CONFIG_BCMA is not set
# Multifunction device drivers
CONFIG_MFD_CORE=y
# CONFIG_MFD_ACT8945A is not set
# CONFIG_MFD_SUN4I_GPADC is not set
# CONFIG_MFD_AS3711 is not set
# CONFIG_MFD_AS3722 is not set
# CONFIG_PMIC_ADP5520 is not set
# CONFIG_MFD_AAT2870_CORE is not set
# CONFIG_MFD_ATMEL_FLEXCOM is not set
# CONFIG_MFD_ATMEL_HLCDC is not set
# CONFIG_MFD_BCM590XX is not set
# CONFIG_MFD_BD9571MWV is not set
# CONFIG_MFD_AC100 is not set
CONFIG_MFD_AXP20X=y
CONFIG_MFD_AXP20X_I2C=y
CONFIG_MFD_AXP20X_RSB=y
# CONFIG_MFD_CROS_EC is not set
# CONFIG_MFD_ASIC3 is not set
# CONFIG_PMIC_DA903X is not set
# CONFIG_MFD_DA9052_SPI is not set
# CONFIG_MFD_DA9052_I2C is not set
# CONFIG_MFD_DA9055 is not set
# CONFIG_MFD_DA9062 is not set
# CONFIG_MFD_DA9063 is not set
# CONFIG_MFD_DA9150 is not set
# CONFIG_MFD_DLN2 is not set
# CONFIG_MFD_MC13XXX_SPI is not set
# CONFIG_MFD_MC13XXX_I2C is not set
# CONFIG_MFD_HI6421_PMIC is not set
# CONFIG_HTC_PASIC3 is not set
# CONFIG_HTC_I2CPLD is not set
# CONFIG_MFD_KEMPLD is not set
# CONFIG_MFD_88PM800 is not set
# CONFIG_MFD_88PM805 is not set
# CONFIG_MFD_88PM860X is not set
# CONFIG_MFD_MAX14577 is not set
# CONFIG_MFD_MAX77620 is not set
# CONFIG_MFD_MAX77686 is not set
# CONFIG_MFD_MAX77693 is not set
# CONFIG_MFD_MAX77843 is not set
# CONFIG_MFD_MAX8907 is not set
# CONFIG_MFD_MAX8925 is not set
# CONFIG_MFD_MAX8997 is not set
# CONFIG_MFD_MAX8998 is not set
# CONFIG_MFD_MT6397 is not set
# CONFIG_MFD_MENF21BMC is not set
# CONFIG_EZX_PCAP is not set
# CONFIG_MFD_CPCAP is not set
# CONFIG_MFD_VIPERBOARD is not set
# CONFIG_MFD_RETU is not set
# CONFIG_MFD_PCF50633 is not set
# CONFIG_MFD_PM8XXX is not set
# CONFIG_MFD_RT5033 is not set
# CONFIG_MFD_RTSX_USB is not set
# CONFIG_MFD_RC5T583 is not set
# CONFIG_MFD_RK808 is not set
# CONFIG_MFD_RN5T618 is not set
# CONFIG_MFD_SEC_CORE is not set
# CONFIG_MFD_SI476X_CORE is not set
# CONFIG_MFD_SM501 is not set
# CONFIG_MFD_SKY81452 is not set
# CONFIG_MFD_SMSC is not set
# CONFIG_ABX500_CORE is not set
# CONFIG_MFD_STMPE is not set
CONFIG_MFD_SUN6I_PRCM=y
CONFIG_MFD_SYSCON=y
# CONFIG_MFD_TI_AM335X_TSCADC is not set
# CONFIG_MFD_LP3943 is not set
# CONFIG_MFD_LP8788 is not set
# CONFIG_MFD_TI_LMU is not set
# CONFIG_MFD_PALMAS is not set
# CONFIG_TPS6105X is not set
# CONFIG_TPS65010 is not set
# CONFIG_TPS6507X is not set
# CONFIG_MFD_TPS65086 is not set
# CONFIG_MFD_TPS65090 is not set
# CONFIG_MFD_TPS65217 is not set
# CONFIG_MFD_TI_LP873X is not set
# CONFIG_MFD_TI_LP87565 is not set
# CONFIG_MFD_TPS65218 is not set
# CONFIG_MFD_TPS6586X is not set
# CONFIG_MFD_TPS65910 is not set
# CONFIG_MFD_TPS65912_I2C is not set
# CONFIG_MFD_TPS65912_SPI is not set
# CONFIG_MFD_TPS80031 is not set
# CONFIG_TWL4030_CORE is not set
# CONFIG_TWL6040_CORE is not set
# CONFIG_MFD_WL1273_CORE is not set
# CONFIG_MFD_LM3533 is not set
# CONFIG_MFD_TC3589X is not set
# CONFIG_MFD_TMIO is not set
# CONFIG_MFD_T7L66XB is not set
# CONFIG_MFD_TC6387XB is not set
# CONFIG_MFD_TC6393XB is not set
# CONFIG_MFD_ARIZONA_I2C is not set
# CONFIG_MFD_ARIZONA_SPI is not set
# CONFIG_MFD_WM8400 is not set
# CONFIG_MFD_WM831X_I2C is not set
# CONFIG_MFD_WM831X_SPI is not set
# CONFIG_MFD_WM8350_I2C is not set
# CONFIG_MFD_WM8994 is not set
CONFIG_REGULATOR=y
# CONFIG_REGULATOR_DEBUG is not set
CONFIG_REGULATOR_FIXED_VOLTAGE=y
# CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set
# CONFIG_REGULATOR_USERSPACE_CONSUMER is not set
# CONFIG_REGULATOR_ACT8865 is not set
# CONFIG_REGULATOR_AD5398 is not set
# CONFIG_REGULATOR_ANATOP is not set
# CONFIG_REGULATOR_AXP20X is not set
# CONFIG_REGULATOR_DA9210 is not set
# CONFIG_REGULATOR_DA9211 is not set
# CONFIG_REGULATOR_FAN53555 is not set
# CONFIG_REGULATOR_GPIO is not set
# CONFIG_REGULATOR_ISL9305 is not set
# CONFIG_REGULATOR_ISL6271A is not set
# CONFIG_REGULATOR_LP3971 is not set
# CONFIG_REGULATOR_LP3972 is not set
# CONFIG_REGULATOR_LP872X is not set
# CONFIG_REGULATOR_LP8755 is not set
# CONFIG_REGULATOR_LTC3589 is not set
# CONFIG_REGULATOR_LTC3676 is not set
# CONFIG_REGULATOR_MAX1586 is not set
# CONFIG_REGULATOR_MAX8649 is not set
# CONFIG_REGULATOR_MAX8660 is not set
# CONFIG_REGULATOR_MAX8952 is not set
# CONFIG_REGULATOR_MAX8973 is not set
# CONFIG_REGULATOR_MT6311 is not set
# CONFIG_REGULATOR_PFUZE100 is not set
# CONFIG_REGULATOR_PV88060 is not set
# CONFIG_REGULATOR_PV88080 is not set
# CONFIG_REGULATOR_PV88090 is not set
# CONFIG_REGULATOR_PWM is not set
# CONFIG_REGULATOR_TPS51632 is not set
# CONFIG_REGULATOR_TPS62360 is not set
# CONFIG_REGULATOR_TPS65023 is not set
# CONFIG_REGULATOR_TPS6507X is not set
# CONFIG_REGULATOR_TPS65132 is not set
# CONFIG_REGULATOR_TPS6524X is not set
# CONFIG_REGULATOR_VCTRL is not set
# CONFIG_RC_CORE is not set
CONFIG_MEDIA_SUPPORT=y
# Multimedia core support
# CONFIG_MEDIA_CAMERA_SUPPORT is not set
# CONFIG_MEDIA_ANALOG_TV_SUPPORT is not set
# CONFIG_MEDIA_DIGITAL_TV_SUPPORT is not set
# CONFIG_MEDIA_RADIO_SUPPORT is not set
# CONFIG_MEDIA_SDR_SUPPORT is not set
# CONFIG_MEDIA_CEC_SUPPORT is not set
# CONFIG_VIDEO_ADV_DEBUG is not set
# CONFIG_VIDEO_FIXED_MINOR_RANGES is not set
# CONFIG_TTPCI_EEPROM is not set
# Media drivers
# CONFIG_MEDIA_USB_SUPPORT is not set
# Supported MMC/SDIO adapters
# CONFIG_CYPRESS_FIRMWARE is not set
# Media ancillary drivers (tuners, sensors, i2c, spi, frontends)
# Customise DVB Frontends
# Tools to develop new frontends
# Graphics support
# CONFIG_IMX_IPUV3_CORE is not set
CONFIG_DRM=y
# CONFIG_DRM_DP_AUX_CHARDEV is not set
# CONFIG_DRM_DEBUG_MM is not set
# CONFIG_DRM_DEBUG_MM_SELFTEST is not set
CONFIG_DRM_KMS_HELPER=y
CONFIG_DRM_KMS_FB_HELPER=y
CONFIG_DRM_FBDEV_EMULATION=y
CONFIG_DRM_FBDEV_OVERALLOC=100
# CONFIG_DRM_LOAD_EDID_FIRMWARE is not set
CONFIG_DRM_GEM_CMA_HELPER=y
CONFIG_DRM_KMS_CMA_HELPER=y
# I2C encoder or helper chips
# CONFIG_DRM_I2C_CH7006 is not set
# CONFIG_DRM_I2C_SIL164 is not set
# CONFIG_DRM_I2C_NXP_TDA998X is not set
# CONFIG_DRM_HDLCD is not set
# CONFIG_DRM_MALI_DISPLAY is not set
# ACP (Audio CoProcessor) Configuration
# AMD Library routines
# CONFIG_CHASH is not set
# CONFIG_DRM_VGEM is not set
# CONFIG_DRM_EXYNOS is not set
# CONFIG_DRM_UDL is not set
# CONFIG_DRM_ARMADA is not set
# CONFIG_DRM_RCAR_DW_HDMI is not set
CONFIG_DRM_SUN4I=y
CONFIG_DRM_SUN4I_HDMI=y
# CONFIG_DRM_SUN4I_HDMI_CEC is not set
CONFIG_DRM_SUN4I_BACKEND=y
CONFIG_DRM_SUN8I_MIXER=y
# CONFIG_DRM_OMAP is not set
# CONFIG_DRM_TILCDC is not set
# CONFIG_DRM_FSL_DCU is not set
# CONFIG_DRM_STM is not set
CONFIG_DRM_PANEL=y
# Display Panels
# CONFIG_DRM_PANEL_LVDS is not set
CONFIG_DRM_PANEL_SIMPLE=y
# CONFIG_DRM_PANEL_SAMSUNG_LD9040 is not set
# CONFIG_DRM_PANEL_LG_LG4573 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E8AA0 is not set
# CONFIG_DRM_PANEL_SEIKO_43WVF1G is not set
# CONFIG_DRM_PANEL_SITRONIX_ST7789V is not set
CONFIG_DRM_BRIDGE=y
CONFIG_DRM_PANEL_BRIDGE=y
# Display Interface Bridges
# CONFIG_DRM_ANALOGIX_ANX78XX is not set
CONFIG_DRM_DUMB_VGA_DAC=y
# CONFIG_DRM_LVDS_ENCODER is not set
# CONFIG_DRM_MEGACHIPS_STDPXXXX_GE_B850V3_FW is not set
# CONFIG_DRM_NXP_PTN3460 is not set
# CONFIG_DRM_PARADE_PS8622 is not set
# CONFIG_DRM_SII902X is not set
# CONFIG_DRM_SII9234 is not set
# CONFIG_DRM_TOSHIBA_TC358767 is not set
# CONFIG_DRM_TI_TFP410 is not set
# CONFIG_DRM_I2C_ADV7511 is not set
# CONFIG_DRM_STI is not set
# CONFIG_DRM_ARCPGU is not set
# CONFIG_DRM_MXSFB is not set
# CONFIG_DRM_TINYDRM is not set
# CONFIG_DRM_PL111 is not set
# CONFIG_DRM_LEGACY is not set
# CONFIG_DRM_LIB_RANDOM is not set
# Frame buffer Devices
CONFIG_FB=y
# CONFIG_FIRMWARE_EDID is not set
CONFIG_FB_CMDLINE=y
CONFIG_FB_NOTIFY=y
# CONFIG_FB_DDC is not set
# CONFIG_FB_BOOT_VESA_SUPPORT is not set
CONFIG_FB_CFB_FILLRECT=y
CONFIG_FB_CFB_COPYAREA=y
CONFIG_FB_CFB_IMAGEBLIT=y
# CONFIG_FB_CFB_REV_PIXELS_IN_BYTE is not set
CONFIG_FB_SYS_FILLRECT=y
CONFIG_FB_SYS_COPYAREA=y
CONFIG_FB_SYS_IMAGEBLIT=y
# CONFIG_FB_PROVIDE_GET_FB_UNMAPPED_AREA is not set
# CONFIG_FB_FOREIGN_ENDIAN is not set
CONFIG_FB_SYS_FOPS=y
CONFIG_FB_DEFERRED_IO=y
# CONFIG_FB_SVGALIB is not set
# CONFIG_FB_MACMODES is not set
CONFIG_FB_BACKLIGHT=y
# CONFIG_FB_MODE_HELPERS is not set
# CONFIG_FB_TILEBLITTING is not set
# Frame buffer hardware drivers
# CONFIG_FB_OPENCORES is not set
# CONFIG_FB_S1D13XXX is not set
# CONFIG_FB_SMSCUFX is not set
# CONFIG_FB_UDL is not set
# CONFIG_FB_IBM_GXT4500 is not set
# CONFIG_FB_VIRTUAL is not set
# CONFIG_FB_METRONOME is not set
# CONFIG_FB_BROADSHEET is not set
# CONFIG_FB_AUO_K190X is not set
CONFIG_FB_SIMPLE=y
CONFIG_FB_SSD1307=y
CONFIG_BACKLIGHT_LCD_SUPPORT=y
CONFIG_LCD_CLASS_DEVICE=m
# CONFIG_LCD_L4F00242T03 is not set
# CONFIG_LCD_LMS283GF05 is not set
# CONFIG_LCD_LTV350QV is not set
# CONFIG_LCD_ILI922X is not set
# CONFIG_LCD_ILI9320 is not set
# CONFIG_LCD_TDO24M is not set
# CONFIG_LCD_VGG2432A4 is not set
# CONFIG_LCD_PLATFORM is not set
# CONFIG_LCD_S6E63M0 is not set
# CONFIG_LCD_LD9040 is not set
# CONFIG_LCD_AMS369FG06 is not set
# CONFIG_LCD_LMS501KF03 is not set
# CONFIG_LCD_HX8357 is not set
CONFIG_BACKLIGHT_CLASS_DEVICE=y
CONFIG_BACKLIGHT_GENERIC=y
CONFIG_BACKLIGHT_PWM=y
# CONFIG_BACKLIGHT_PM8941_WLED is not set
# CONFIG_BACKLIGHT_ADP8860 is not set
# CONFIG_BACKLIGHT_ADP8870 is not set
# CONFIG_BACKLIGHT_LM3630A is not set
# CONFIG_BACKLIGHT_LM3639 is not set
# CONFIG_BACKLIGHT_LP855X is not set
# CONFIG_BACKLIGHT_GPIO is not set
# CONFIG_BACKLIGHT_LV5207LP is not set
# CONFIG_BACKLIGHT_BD6107 is not set
# CONFIG_BACKLIGHT_ARCXCNN is not set
# CONFIG_VGASTATE is not set
CONFIG_VIDEOMODE_HELPERS=y
CONFIG_HDMI=y
# Console display driver support
CONFIG_DUMMY_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY=y
# CONFIG_FRAMEBUFFER_CONSOLE_ROTATION is not set
# CONFIG_LOGO is not set
CONFIG_SOUND=y
CONFIG_SOUND_OSS_CORE=y
CONFIG_SOUND_OSS_CORE_PRECLAIM=y
CONFIG_SND=y
CONFIG_SND_TIMER=y
CONFIG_SND_PCM=y
CONFIG_SND_DMAENGINE_PCM=y
CONFIG_SND_JACK=y
CONFIG_SND_JACK_INPUT_DEV=y
CONFIG_SND_OSSEMUL=y
CONFIG_SND_MIXER_OSS=y
CONFIG_SND_PCM_OSS=y
CONFIG_SND_PCM_OSS_PLUGINS=y
CONFIG_SND_PCM_TIMER=y
# CONFIG_SND_HRTIMER is not set
# CONFIG_SND_DYNAMIC_MINORS is not set
CONFIG_SND_SUPPORT_OLD_API=y
CONFIG_SND_PROC_FS=y
CONFIG_SND_VERBOSE_PROCFS=y
# CONFIG_SND_VERBOSE_PRINTK is not set
# CONFIG_SND_DEBUG is not set
# CONFIG_SND_SEQUENCER is not set
# CONFIG_SND_OPL3_LIB_SEQ is not set
# CONFIG_SND_OPL4_LIB_SEQ is not set
CONFIG_SND_DRIVERS=y
# CONFIG_SND_DUMMY is not set
CONFIG_SND_ALOOP=y
# CONFIG_SND_MTPAV is not set
# CONFIG_SND_SERIAL_U16550 is not set
# CONFIG_SND_MPU401 is not set
# HD-Audio
CONFIG_SND_HDA_PREALLOC_SIZE=64
CONFIG_SND_ARM=y
# CONFIG_SND_SPI is not set
CONFIG_SND_USB=y
# CONFIG_SND_USB_AUDIO is not set
# CONFIG_SND_USB_UA101 is not set
# CONFIG_SND_USB_CAIAQ is not set
# CONFIG_SND_USB_6FIRE is not set
# CONFIG_SND_USB_HIFACE is not set
# CONFIG_SND_BCD2000 is not set
# CONFIG_SND_USB_POD is not set
# CONFIG_SND_USB_PODHD is not set
# CONFIG_SND_USB_TONEPORT is not set
# CONFIG_SND_USB_VARIAX is not set
CONFIG_SND_SOC=y
CONFIG_SND_SOC_GENERIC_DMAENGINE_PCM=y
# CONFIG_SND_SOC_AMD_ACP is not set
# CONFIG_SND_ATMEL_SOC is not set
# CONFIG_SND_DESIGNWARE_I2S is not set
# SoC Audio for Freescale CPUs
# Common SoC Audio options for Freescale CPUs:
# CONFIG_SND_SOC_FSL_ASRC is not set
# CONFIG_SND_SOC_FSL_SAI is not set
# CONFIG_SND_SOC_FSL_SSI is not set
# CONFIG_SND_SOC_FSL_SPDIF is not set
# CONFIG_SND_SOC_FSL_ESAI is not set
# CONFIG_SND_SOC_IMX_AUDMUX is not set
# CONFIG_SND_I2S_HI6210_I2S is not set
# CONFIG_SND_SOC_IMG is not set
# STMicroelectronics STM32 SOC audio support
# Allwinner SoC Audio support
CONFIG_SND_SUN4I_CODEC=y
CONFIG_SND_SUN4I_I2S=y
CONFIG_SND_SUN4I_SPDIF=y
# CONFIG_SND_SOC_XTFPGA_I2S is not set
# CONFIG_ZX_TDM is not set
CONFIG_SND_SOC_I2C_AND_SPI=y
# CODEC drivers
# CONFIG_SND_SOC_AC97_CODEC is not set
# CONFIG_SND_SOC_ADAU1701 is not set
# CONFIG_SND_SOC_ADAU1761_I2C is not set
# CONFIG_SND_SOC_ADAU1761_SPI is not set
# CONFIG_SND_SOC_ADAU7002 is not set
# CONFIG_SND_SOC_AK4104 is not set
# CONFIG_SND_SOC_AK4554 is not set
# CONFIG_SND_SOC_AK4613 is not set
# CONFIG_SND_SOC_AK4642 is not set
# CONFIG_SND_SOC_AK5386 is not set
# CONFIG_SND_SOC_ALC5623 is not set
# CONFIG_SND_SOC_BT_SCO is not set
# CONFIG_SND_SOC_CS35L32 is not set
# CONFIG_SND_SOC_CS35L33 is not set
# CONFIG_SND_SOC_CS35L34 is not set
# CONFIG_SND_SOC_CS35L35 is not set
# CONFIG_SND_SOC_CS42L42 is not set
# CONFIG_SND_SOC_CS42L51_I2C is not set
# CONFIG_SND_SOC_CS42L52 is not set
# CONFIG_SND_SOC_CS42L56 is not set
# CONFIG_SND_SOC_CS42L73 is not set
# CONFIG_SND_SOC_CS4265 is not set
# CONFIG_SND_SOC_CS4270 is not set
# CONFIG_SND_SOC_CS4271_I2C is not set
# CONFIG_SND_SOC_CS4271_SPI is not set
# CONFIG_SND_SOC_CS42XX8_I2C is not set
# CONFIG_SND_SOC_CS43130 is not set
# CONFIG_SND_SOC_CS4349 is not set
# CONFIG_SND_SOC_CS53L30 is not set
# CONFIG_SND_SOC_DIO2125 is not set
# CONFIG_SND_SOC_ES7134 is not set
# CONFIG_SND_SOC_ES8316 is not set
# CONFIG_SND_SOC_ES8328_I2C is not set
# CONFIG_SND_SOC_ES8328_SPI is not set
# CONFIG_SND_SOC_GTM601 is not set
# CONFIG_SND_SOC_INNO_RK3036 is not set
# CONFIG_SND_SOC_MAX98504 is not set
# CONFIG_SND_SOC_MAX98927 is not set
# CONFIG_SND_SOC_MAX9860 is not set
# CONFIG_SND_SOC_MSM8916_WCD_DIGITAL is not set
# CONFIG_SND_SOC_PCM1681 is not set
# CONFIG_SND_SOC_PCM179X_I2C is not set
# CONFIG_SND_SOC_PCM179X_SPI is not set
# CONFIG_SND_SOC_PCM3168A_I2C is not set
# CONFIG_SND_SOC_PCM3168A_SPI is not set
# CONFIG_SND_SOC_PCM512x_I2C is not set
# CONFIG_SND_SOC_PCM512x_SPI is not set
# CONFIG_SND_SOC_RT5514_SPI_BUILTIN is not set
# CONFIG_SND_SOC_RT5616 is not set
# CONFIG_SND_SOC_RT5631 is not set
# CONFIG_SND_SOC_RT5677_SPI is not set
# CONFIG_SND_SOC_SGTL5000 is not set
# CONFIG_SND_SOC_SIRF_AUDIO_CODEC is not set
# CONFIG_SND_SOC_SPDIF is not set
# CONFIG_SND_SOC_SSM2602_SPI is not set
# CONFIG_SND_SOC_SSM2602_I2C is not set
# CONFIG_SND_SOC_SSM4567 is not set
# CONFIG_SND_SOC_STA32X is not set
# CONFIG_SND_SOC_STA350 is not set
# CONFIG_SND_SOC_STI_SAS is not set
# CONFIG_SND_SOC_TAS2552 is not set
# CONFIG_SND_SOC_TAS5086 is not set
# CONFIG_SND_SOC_TAS571X is not set
# CONFIG_SND_SOC_TAS5720 is not set
# CONFIG_SND_SOC_TFA9879 is not set
# CONFIG_SND_SOC_TLV320AIC23_I2C is not set
# CONFIG_SND_SOC_TLV320AIC23_SPI is not set
# CONFIG_SND_SOC_TLV320AIC31XX is not set
# CONFIG_SND_SOC_TLV320AIC3X is not set
# CONFIG_SND_SOC_TS3A227E is not set
# CONFIG_SND_SOC_WM8510 is not set
# CONFIG_SND_SOC_WM8523 is not set
# CONFIG_SND_SOC_WM8524 is not set
# CONFIG_SND_SOC_WM8580 is not set
# CONFIG_SND_SOC_WM8711 is not set
# CONFIG_SND_SOC_WM8728 is not set
# CONFIG_SND_SOC_WM8731 is not set
# CONFIG_SND_SOC_WM8737 is not set
# CONFIG_SND_SOC_WM8741 is not set
# CONFIG_SND_SOC_WM8750 is not set
# CONFIG_SND_SOC_WM8753 is not set
# CONFIG_SND_SOC_WM8770 is not set
# CONFIG_SND_SOC_WM8776 is not set
# CONFIG_SND_SOC_WM8804_I2C is not set
# CONFIG_SND_SOC_WM8804_SPI is not set
# CONFIG_SND_SOC_WM8903 is not set
# CONFIG_SND_SOC_WM8960 is not set
# CONFIG_SND_SOC_WM8962 is not set
# CONFIG_SND_SOC_WM8974 is not set
# CONFIG_SND_SOC_WM8978 is not set
# CONFIG_SND_SOC_WM8985 is not set
# CONFIG_SND_SOC_ZX_AUD96P22 is not set
# CONFIG_SND_SOC_NAU8540 is not set
# CONFIG_SND_SOC_NAU8810 is not set
# CONFIG_SND_SOC_NAU8824 is not set
# CONFIG_SND_SOC_TPA6130A2 is not set
CONFIG_SND_SIMPLE_CARD_UTILS=y
CONFIG_SND_SIMPLE_CARD=y
# CONFIG_SND_SIMPLE_SCU_CARD is not set
# CONFIG_SND_AUDIO_GRAPH_CARD is not set
# CONFIG_SND_AUDIO_GRAPH_SCU_CARD is not set
# HID support
CONFIG_HID=y
# CONFIG_HID_BATTERY_STRENGTH is not set
# CONFIG_HIDRAW is not set
# CONFIG_UHID is not set
CONFIG_HID_GENERIC=y
# Special HID drivers
CONFIG_HID_A4TECH=y
# CONFIG_HID_ACCUTOUCH is not set
# CONFIG_HID_ACRUX is not set
CONFIG_HID_APPLE=y
# CONFIG_HID_APPLEIR is not set
# CONFIG_HID_ASUS is not set
# CONFIG_HID_AUREAL is not set
CONFIG_HID_BELKIN=y
# CONFIG_HID_BETOP_FF is not set
CONFIG_HID_CHERRY=y
CONFIG_HID_CHICONY=y
# CONFIG_HID_CORSAIR is not set
# CONFIG_HID_PRODIKEYS is not set
# CONFIG_HID_CMEDIA is not set
CONFIG_HID_CYPRESS=y
# CONFIG_HID_DRAGONRISE is not set
# CONFIG_HID_EMS_FF is not set
# CONFIG_HID_ELECOM is not set
# CONFIG_HID_ELO is not set
CONFIG_HID_EZKEY=y
# CONFIG_HID_GEMBIRD is not set
# CONFIG_HID_GFRM is not set
# CONFIG_HID_HOLTEK is not set
# CONFIG_HID_GT683R is not set
# CONFIG_HID_KEYTOUCH is not set
# CONFIG_HID_KYE is not set
# CONFIG_HID_UCLOGIC is not set
# CONFIG_HID_WALTOP is not set
# CONFIG_HID_GYRATION is not set
# CONFIG_HID_ICADE is not set
CONFIG_HID_ITE=y
# CONFIG_HID_TWINHAN is not set
CONFIG_HID_KENSINGTON=y
# CONFIG_HID_LCPOWER is not set
# CONFIG_HID_LED is not set
# CONFIG_HID_LENOVO is not set
CONFIG_HID_LOGITECH=y
# CONFIG_HID_LOGITECH_HIDPP is not set
# CONFIG_LOGITECH_FF is not set
# CONFIG_LOGIRUMBLEPAD2_FF is not set
# CONFIG_LOGIG940_FF is not set
# CONFIG_LOGIWHEELS_FF is not set
# CONFIG_HID_MAGICMOUSE is not set
# CONFIG_HID_MAYFLASH is not set
CONFIG_HID_MICROSOFT=y
CONFIG_HID_MONTEREY=y
# CONFIG_HID_MULTITOUCH is not set
# CONFIG_HID_NTI is not set
# CONFIG_HID_NTRIG is not set
# CONFIG_HID_ORTEK is not set
# CONFIG_HID_PANTHERLORD is not set
# CONFIG_HID_PENMOUNT is not set
# CONFIG_HID_PETALYNX is not set
# CONFIG_HID_PICOLCD is not set
# CONFIG_HID_PLANTRONICS is not set
# CONFIG_HID_PRIMAX is not set
# CONFIG_HID_RETRODE is not set
# CONFIG_HID_ROCCAT is not set
# CONFIG_HID_SAITEK is not set
# CONFIG_HID_SAMSUNG is not set
# CONFIG_HID_SONY is not set
# CONFIG_HID_SPEEDLINK is not set
# CONFIG_HID_STEELSERIES is not set
# CONFIG_HID_SUNPLUS is not set
# CONFIG_HID_RMI is not set
# CONFIG_HID_GREENASIA is not set
# CONFIG_HID_SMARTJOYPLUS is not set
# CONFIG_HID_TIVO is not set
# CONFIG_HID_TOPSEED is not set
# CONFIG_HID_THINGM is not set
# CONFIG_HID_THRUSTMASTER is not set
# CONFIG_HID_UDRAW_PS3 is not set
# CONFIG_HID_WACOM is not set
# CONFIG_HID_WIIMOTE is not set
# CONFIG_HID_XINMO is not set
# CONFIG_HID_ZEROPLUS is not set
# CONFIG_HID_ZYDACRON is not set
# CONFIG_HID_SENSOR_HUB is not set
# CONFIG_HID_ALPS is not set
# USB HID support
CONFIG_USB_HID=y
# CONFIG_HID_PID is not set
CONFIG_USB_HIDDEV=y
# I2C HID support
# CONFIG_I2C_HID is not set
CONFIG_USB_OHCI_LITTLE_ENDIAN=y
CONFIG_USB_SUPPORT=y
CONFIG_USB_COMMON=y
CONFIG_USB_ARCH_HAS_HCD=y
CONFIG_USB=y
# CONFIG_USB_ANNOUNCE_NEW_DEVICES is not set
# Miscellaneous USB options
CONFIG_USB_DEFAULT_PERSIST=y
CONFIG_USB_DYNAMIC_MINORS=y
CONFIG_USB_OTG=y
# CONFIG_USB_OTG_WHITELIST is not set
# CONFIG_USB_OTG_BLACKLIST_HUB is not set
# CONFIG_USB_OTG_FSM is not set
# CONFIG_USB_LEDS_TRIGGER_USBPORT is not set
CONFIG_USB_MON=m
# CONFIG_USB_WUSB_CBAF is not set
# USB Host Controller Drivers
# CONFIG_USB_C67X00_HCD is not set
# CONFIG_USB_XHCI_HCD is not set
CONFIG_USB_EHCI_HCD=y
# CONFIG_USB_EHCI_ROOT_HUB_TT is not set
# CONFIG_USB_EHCI_TT_NEWSCHED is not set
CONFIG_USB_EHCI_HCD_PLATFORM=y
# CONFIG_USB_OXU210HP_HCD is not set
# CONFIG_USB_ISP116X_HCD is not set
# CONFIG_USB_ISP1362_HCD is not set
# CONFIG_USB_FOTG210_HCD is not set
# CONFIG_USB_MAX3421_HCD is not set
CONFIG_USB_OHCI_HCD=y
CONFIG_USB_OHCI_HCD_PLATFORM=y
# CONFIG_USB_SL811_HCD is not set
# CONFIG_USB_R8A66597_HCD is not set
# CONFIG_USB_HCD_TEST_MODE is not set
# USB Device Class drivers
# CONFIG_USB_ACM is not set
# CONFIG_USB_PRINTER is not set
# CONFIG_USB_WDM is not set
# CONFIG_USB_TMC is not set
# NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may
# also be needed; see USB_STORAGE Help for more info
CONFIG_USB_STORAGE=y
# CONFIG_USB_STORAGE_DEBUG is not set
# CONFIG_USB_STORAGE_REALTEK is not set
# CONFIG_USB_STORAGE_DATAFAB is not set
# CONFIG_USB_STORAGE_FREECOM is not set
# CONFIG_USB_STORAGE_ISD200 is not set
# CONFIG_USB_STORAGE_USBAT is not set
# CONFIG_USB_STORAGE_SDDR09 is not set
# CONFIG_USB_STORAGE_SDDR55 is not set
# CONFIG_USB_STORAGE_JUMPSHOT is not set
# CONFIG_USB_STORAGE_ALAUDA is not set
# CONFIG_USB_STORAGE_ONETOUCH is not set
# CONFIG_USB_STORAGE_KARMA is not set
# CONFIG_USB_STORAGE_CYPRESS_ATACB is not set
# CONFIG_USB_STORAGE_ENE_UB6250 is not set
# CONFIG_USB_UAS is not set
# USB Imaging devices
# CONFIG_USB_MDC800 is not set
# CONFIG_USB_MICROTEK is not set
# CONFIG_USBIP_CORE is not set
CONFIG_USB_MUSB_HDRC=y
# CONFIG_USB_MUSB_HOST is not set
# CONFIG_USB_MUSB_GADGET is not set
CONFIG_USB_MUSB_DUAL_ROLE=y
# Platform Glue Layer
CONFIG_USB_MUSB_SUNXI=y
# MUSB DMA mode
# CONFIG_MUSB_PIO_ONLY is not set
# CONFIG_USB_DWC3 is not set
# CONFIG_USB_DWC2 is not set
# CONFIG_USB_CHIPIDEA is not set
# CONFIG_USB_ISP1760 is not set
# USB port drivers
# CONFIG_USB_SERIAL is not set
# USB Miscellaneous drivers
# CONFIG_USB_EMI62 is not set
# CONFIG_USB_EMI26 is not set
# CONFIG_USB_ADUTUX is not set
# CONFIG_USB_SEVSEG is not set
# CONFIG_USB_RIO500 is not set
# CONFIG_USB_LEGOTOWER is not set
# CONFIG_USB_LCD is not set
# CONFIG_USB_CYPRESS_CY7C63 is not set
# CONFIG_USB_CYTHERM is not set
# CONFIG_USB_IDMOUSE is not set
# CONFIG_USB_FTDI_ELAN is not set
# CONFIG_USB_APPLEDISPLAY is not set
# CONFIG_USB_SISUSBVGA is not set
# CONFIG_USB_LD is not set
# CONFIG_USB_TRANCEVIBRATOR is not set
# CONFIG_USB_IOWARRIOR is not set
# CONFIG_USB_TEST is not set
# CONFIG_USB_EHSET_TEST_FIXTURE is not set
# CONFIG_USB_ISIGHTFW is not set
# CONFIG_USB_YUREX is not set
# CONFIG_USB_EZUSB_FX2 is not set
# CONFIG_USB_HUB_USB251XB is not set
# CONFIG_USB_HSIC_USB3503 is not set
# CONFIG_USB_HSIC_USB4604 is not set
# CONFIG_USB_LINK_LAYER_TEST is not set
# USB Physical Layer drivers
CONFIG_USB_PHY=y
CONFIG_NOP_USB_XCEIV=y
# CONFIG_AM335X_PHY_USB is not set
# CONFIG_USB_GPIO_VBUS is not set
# CONFIG_USB_ISP1301 is not set
# CONFIG_USB_ULPI is not set
CONFIG_USB_GADGET=y
# CONFIG_USB_GADGET_DEBUG is not set
# CONFIG_USB_GADGET_DEBUG_FILES is not set
# CONFIG_USB_GADGET_DEBUG_FS is not set
CONFIG_USB_GADGET_VBUS_DRAW=500
CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=2
# CONFIG_U_SERIAL_CONSOLE is not set
# USB Peripheral Controller
# CONFIG_USB_FUSB300 is not set
# CONFIG_USB_FOTG210_UDC is not set
# CONFIG_USB_GR_UDC is not set
# CONFIG_USB_R8A66597 is not set
# CONFIG_USB_PXA27X is not set
# CONFIG_USB_MV_UDC is not set
# CONFIG_USB_MV_U3D is not set
# CONFIG_USB_SNP_UDC_PLAT is not set
# CONFIG_USB_M66592 is not set
# CONFIG_USB_BDC_UDC is not set
# CONFIG_USB_NET2272 is not set
# CONFIG_USB_GADGET_XILINX is not set
# CONFIG_USB_DUMMY_HCD is not set
CONFIG_USB_LIBCOMPOSITE=y
CONFIG_USB_F_ACM=y
CONFIG_USB_U_SERIAL=y
CONFIG_USB_U_ETHER=y
CONFIG_USB_F_ECM=y
# CONFIG_USB_CONFIGFS is not set
# CONFIG_USB_ZERO is not set
# CONFIG_USB_AUDIO is not set
# CONFIG_USB_ETH is not set
# CONFIG_USB_G_NCM is not set
# CONFIG_USB_GADGETFS is not set
# CONFIG_USB_FUNCTIONFS is not set
# CONFIG_USB_MASS_STORAGE is not set
# CONFIG_USB_G_SERIAL is not set
# CONFIG_USB_MIDI_GADGET is not set
# CONFIG_USB_G_PRINTER is not set
CONFIG_USB_CDC_COMPOSITE=y
# CONFIG_USB_G_ACM_MS is not set
# CONFIG_USB_G_MULTI is not set
# CONFIG_USB_G_HID is not set
# CONFIG_USB_G_DBGP is not set
# CONFIG_TYPEC is not set
# CONFIG_USB_LED_TRIG is not set
# CONFIG_USB_ULPI_BUS is not set
# CONFIG_UWB is not set
CONFIG_MMC=y
CONFIG_PWRSEQ_EMMC=y
CONFIG_PWRSEQ_SIMPLE=y
CONFIG_MMC_BLOCK=y
CONFIG_MMC_BLOCK_MINORS=8
# CONFIG_SDIO_UART is not set
# CONFIG_MMC_TEST is not set
# MMC/SD/SDIO Host Controller Drivers
# CONFIG_MMC_DEBUG is not set
# CONFIG_MMC_SDHCI is not set
# CONFIG_MMC_SPI is not set
# CONFIG_MMC_DW is not set
# CONFIG_MMC_VUB300 is not set
# CONFIG_MMC_USHC is not set
# CONFIG_MMC_USDHI6ROL0 is not set
CONFIG_MMC_SUNXI=y
# CONFIG_MMC_MTK is not set
# CONFIG_MEMSTICK is not set
CONFIG_NEW_LEDS=y
CONFIG_LEDS_CLASS=y
# CONFIG_LEDS_CLASS_FLASH is not set
# CONFIG_LEDS_BRIGHTNESS_HW_CHANGED is not set
# LED drivers
# CONFIG_LEDS_BCM6328 is not set
# CONFIG_LEDS_BCM6358 is not set
# CONFIG_LEDS_LM3530 is not set
# CONFIG_LEDS_LM3642 is not set
# CONFIG_LEDS_PCA9532 is not set
CONFIG_LEDS_GPIO=y
# CONFIG_LEDS_LP3944 is not set
# CONFIG_LEDS_LP3952 is not set
# CONFIG_LEDS_LP5521 is not set
# CONFIG_LEDS_LP5523 is not set
# CONFIG_LEDS_LP5562 is not set
# CONFIG_LEDS_LP8501 is not set
# CONFIG_LEDS_LP8860 is not set
# CONFIG_LEDS_PCA955X is not set
# CONFIG_LEDS_PCA963X is not set
# CONFIG_LEDS_DAC124S085 is not set
# CONFIG_LEDS_PWM is not set
# CONFIG_LEDS_REGULATOR is not set
# CONFIG_LEDS_BD2802 is not set
# CONFIG_LEDS_LT3593 is not set
# CONFIG_LEDS_TCA6507 is not set
# CONFIG_LEDS_TLC591XX is not set
# CONFIG_LEDS_LM355x is not set
# CONFIG_LEDS_IS31FL319X is not set
# CONFIG_LEDS_IS31FL32XX is not set
# LED driver for blink(1) USB RGB LED is under Special HID drivers (HID_THINGM)
# CONFIG_LEDS_BLINKM is not set
# CONFIG_LEDS_SYSCON is not set
# CONFIG_LEDS_USER is not set
# LED Triggers
CONFIG_LEDS_TRIGGERS=y
# CONFIG_LEDS_TRIGGER_TIMER is not set
# CONFIG_LEDS_TRIGGER_ONESHOT is not set
# CONFIG_LEDS_TRIGGER_MTD is not set
CONFIG_LEDS_TRIGGER_HEARTBEAT=y
# CONFIG_LEDS_TRIGGER_BACKLIGHT is not set
# CONFIG_LEDS_TRIGGER_CPU is not set
# CONFIG_LEDS_TRIGGER_ACTIVITY is not set
# CONFIG_LEDS_TRIGGER_GPIO is not set
CONFIG_LEDS_TRIGGER_DEFAULT_ON=y
# iptables trigger is under Netfilter config (LED target)
# CONFIG_LEDS_TRIGGER_TRANSIENT is not set
# CONFIG_LEDS_TRIGGER_CAMERA is not set
# CONFIG_LEDS_TRIGGER_PANIC is not set
# CONFIG_ACCESSIBILITY is not set
# CONFIG_INFINIBAND is not set
CONFIG_EDAC_ATOMIC_SCRUB=y
CONFIG_EDAC_SUPPORT=y
CONFIG_RTC_LIB=y
# CONFIG_RTC_CLASS is not set
CONFIG_DMADEVICES=y
# CONFIG_DMADEVICES_DEBUG is not set
# DMA Devices
CONFIG_DMA_ENGINE=y
CONFIG_DMA_OF=y
# CONFIG_ALTERA_MSGDMA is not set
# CONFIG_FSL_EDMA is not set
# CONFIG_INTEL_IDMA64 is not set
# CONFIG_NBPFAXI_DMA is not set
# CONFIG_QCOM_HIDMA_MGMT is not set
# CONFIG_QCOM_HIDMA is not set
# CONFIG_DW_DMAC is not set
# DMA Clients
# CONFIG_ASYNC_TX_DMA is not set
# CONFIG_DMATEST is not set
# DMABUF options
CONFIG_SYNC_FILE=y
# CONFIG_SW_SYNC is not set
# CONFIG_AUXDISPLAY is not set
# CONFIG_UIO is not set
# CONFIG_VIRT_DRIVERS is not set
# Virtio drivers
# CONFIG_VIRTIO_MMIO is not set
# Microsoft Hyper-V guest support
# CONFIG_HYPERV_TSCPAGE is not set
CONFIG_STAGING=y
# CONFIG_IRDA is not set
# CONFIG_PRISM2_USB is not set
# CONFIG_COMEDI is not set
# CONFIG_RTLLIB is not set
CONFIG_RTL8723BS=m
# CONFIG_R8712U is not set
# CONFIG_R8188EU is not set
# CONFIG_VT6656 is not set
# Speakup console speech
# CONFIG_SPEAKUP is not set
# CONFIG_STAGING_MEDIA is not set
# Android
# CONFIG_STAGING_BOARD is not set
# CONFIG_LTE_GDM724X is not set
# CONFIG_LNET is not set
# CONFIG_GS_FPGABOOT is not set
# CONFIG_COMMON_CLK_XLNX_CLKWZRD is not set
CONFIG_FB_TFT=y
# CONFIG_FB_TFT_AGM1264K_FL is not set
# CONFIG_FB_TFT_BD663474 is not set
# CONFIG_FB_TFT_HX8340BN is not set
# CONFIG_FB_TFT_HX8347D is not set
# CONFIG_FB_TFT_HX8353D is not set
# CONFIG_FB_TFT_HX8357D is not set
# CONFIG_FB_TFT_ILI9163 is not set
# CONFIG_FB_TFT_ILI9320 is not set
# CONFIG_FB_TFT_ILI9325 is not set
# CONFIG_FB_TFT_ILI9340 is not set
# CONFIG_FB_TFT_ILI9341 is not set
# CONFIG_FB_TFT_ILI9481 is not set
# CONFIG_FB_TFT_ILI9486 is not set
# CONFIG_FB_TFT_PCD8544 is not set
# CONFIG_FB_TFT_RA8875 is not set
# CONFIG_FB_TFT_S6D02A1 is not set
# CONFIG_FB_TFT_S6D1121 is not set
# CONFIG_FB_TFT_SH1106 is not set
# CONFIG_FB_TFT_SSD1289 is not set
# CONFIG_FB_TFT_SSD1305 is not set
# CONFIG_FB_TFT_SSD1306 is not set
# CONFIG_FB_TFT_SSD1325 is not set
# CONFIG_FB_TFT_SSD1331 is not set
# CONFIG_FB_TFT_SSD1351 is not set
# CONFIG_FB_TFT_ST7735R is not set
# CONFIG_FB_TFT_ST7789V is not set
# CONFIG_FB_TFT_TINYLCD is not set
# CONFIG_FB_TFT_TLS8204 is not set
# CONFIG_FB_TFT_UC1611 is not set
# CONFIG_FB_TFT_UC1701 is not set
# CONFIG_FB_TFT_UPD161704 is not set
# CONFIG_FB_TFT_WATTEROTT is not set
CONFIG_FB_FLEX=y
# CONFIG_FB_TFT_FBTFT_DEVICE is not set
# CONFIG_WILC1000_SDIO is not set
# CONFIG_WILC1000_SPI is not set
# CONFIG_MOST is not set
# CONFIG_KS7010 is not set
# CONFIG_GREYBUS is not set
# CONFIG_CRYPTO_DEV_CCREE is not set
# USB Power Delivery and Type-C drivers
# CONFIG_PI433 is not set
# CONFIG_GOLDFISH is not set
# CONFIG_CHROME_PLATFORMS is not set
CONFIG_CLKDEV_LOOKUP=y
CONFIG_HAVE_CLK_PREPARE=y
CONFIG_COMMON_CLK=y
# Common Clock Framework
# CONFIG_CLK_HSDK is not set
# CONFIG_COMMON_CLK_SI5351 is not set
# CONFIG_COMMON_CLK_SI514 is not set
# CONFIG_COMMON_CLK_SI570 is not set
# CONFIG_COMMON_CLK_CDCE706 is not set
# CONFIG_COMMON_CLK_CDCE925 is not set
# CONFIG_COMMON_CLK_CS2000_CP is not set
# CONFIG_CLK_QORIQ is not set
# CONFIG_COMMON_CLK_NXP is not set
# CONFIG_COMMON_CLK_PWM is not set
# CONFIG_COMMON_CLK_PXA is not set
# CONFIG_COMMON_CLK_PIC32 is not set
# CONFIG_COMMON_CLK_VC5 is not set
CONFIG_SUNXI_CCU=y
CONFIG_SUNIV_CCU=y
CONFIG_SUN8I_A83T_CCU=y
CONFIG_SUN8I_DE2_CCU=y
CONFIG_SUN8I_R_CCU=y
# CONFIG_HWSPINLOCK is not set
# Clock Source drivers
CONFIG_TIMER_OF=y
CONFIG_TIMER_PROBE=y
CONFIG_CLKSRC_MMIO=y
CONFIG_SUN4I_TIMER=y
# CONFIG_ARM_TIMER_SP804 is not set
# CONFIG_ATMEL_PIT is not set
# CONFIG_SH_TIMER_CMT is not set
# CONFIG_SH_TIMER_MTU2 is not set
# CONFIG_SH_TIMER_TMU is not set
# CONFIG_EM_TIMER_STI is not set
# CONFIG_MAILBOX is not set
# CONFIG_IOMMU_SUPPORT is not set
# Remoteproc drivers
# CONFIG_REMOTEPROC is not set
# Rpmsg drivers
# CONFIG_RPMSG_VIRTIO is not set
# SOC (System On Chip) specific Drivers
# Amlogic SoC drivers
# Broadcom SoC drivers
# CONFIG_SOC_BRCMSTB is not set
# i.MX SoC drivers
# Qualcomm SoC drivers
CONFIG_SUNXI_SRAM=y
# CONFIG_SOC_TI is not set
# CONFIG_PM_DEVFREQ is not set
CONFIG_EXTCON=y
# Extcon Device Drivers
# CONFIG_EXTCON_AXP288 is not set
# CONFIG_EXTCON_GPIO is not set
# CONFIG_EXTCON_MAX3355 is not set
# CONFIG_EXTCON_RT8973A is not set
# CONFIG_EXTCON_SM5502 is not set
# CONFIG_EXTCON_USB_GPIO is not set
# CONFIG_MEMORY is not set
# CONFIG_IIO is not set
CONFIG_PWM=y
CONFIG_PWM_SYSFS=y
# CONFIG_PWM_FSL_FTM is not set
# CONFIG_PWM_PCA9685 is not set
CONFIG_PWM_SUN4I=y
# IRQ chip support
CONFIG_IRQCHIP=y
CONFIG_ARM_GIC_MAX_NR=1
# CONFIG_ARM_GIC_V3_ITS is not set
# CONFIG_IPACK_BUS is not set
CONFIG_ARCH_HAS_RESET_CONTROLLER=y
CONFIG_RESET_CONTROLLER=y
# CONFIG_RESET_ATH79 is not set
# CONFIG_RESET_AXS10X is not set
# CONFIG_RESET_BERLIN is not set
# CONFIG_RESET_IMX7 is not set
# CONFIG_RESET_LANTIQ is not set
# CONFIG_RESET_LPC18XX is not set
# CONFIG_RESET_MESON is not set
# CONFIG_RESET_PISTACHIO is not set
CONFIG_RESET_SIMPLE=y
CONFIG_RESET_SUNXI=y
# CONFIG_RESET_TI_SYSCON is not set
# CONFIG_RESET_ZYNQ is not set
# CONFIG_RESET_TEGRA_BPMP is not set
# CONFIG_FMC is not set
# PHY Subsystem
CONFIG_GENERIC_PHY=y
CONFIG_PHY_SUN4I_USB=y
# CONFIG_PHY_SUN9I_USB is not set
# CONFIG_BCM_KONA_USB2_PHY is not set
# CONFIG_PHY_PXA_28NM_HSIC is not set
# CONFIG_PHY_PXA_28NM_USB2 is not set
# CONFIG_POWERCAP is not set
# CONFIG_MCB is not set
# Performance monitor support
CONFIG_ARM_PMU=y
# CONFIG_RAS is not set
# Android
# CONFIG_ANDROID is not set
# CONFIG_DAX is not set
CONFIG_NVMEM=y
CONFIG_NVMEM_SUNXI_SID=y
# CONFIG_STM is not set
# CONFIG_INTEL_TH is not set
# CONFIG_FPGA is not set
# FSI support
# CONFIG_FSI is not set
CONFIG_PM_OPP=y
# Firmware Drivers
# CONFIG_FIRMWARE_MEMMAP is not set
# CONFIG_FW_CFG_SYSFS is not set
# CONFIG_GOOGLE_FIRMWARE is not set
# Tegra firmware driver
# File systems
CONFIG_FS_IOMAP=y
CONFIG_EXT2_FS=y
# CONFIG_EXT2_FS_XATTR is not set
CONFIG_EXT3_FS=y
# CONFIG_EXT3_FS_POSIX_ACL is not set
# CONFIG_EXT3_FS_SECURITY is not set
CONFIG_EXT4_FS=y
# CONFIG_EXT4_FS_POSIX_ACL is not set
# CONFIG_EXT4_FS_SECURITY is not set
# CONFIG_EXT4_ENCRYPTION is not set
# CONFIG_EXT4_DEBUG is not set
CONFIG_JBD2=y
# CONFIG_JBD2_DEBUG is not set
CONFIG_FS_MBCACHE=y
# CONFIG_REISERFS_FS is not set
# CONFIG_JFS_FS is not set
# CONFIG_XFS_FS is not set
# CONFIG_GFS2_FS is not set
# CONFIG_OCFS2_FS is not set
# CONFIG_BTRFS_FS is not set
# CONFIG_NILFS2_FS is not set
# CONFIG_F2FS_FS is not set
CONFIG_FS_POSIX_ACL=y
CONFIG_EXPORTFS=y
# CONFIG_EXPORTFS_BLOCK_OPS is not set
CONFIG_FILE_LOCKING=y
CONFIG_MANDATORY_FILE_LOCKING=y
# CONFIG_FS_ENCRYPTION is not set
CONFIG_FSNOTIFY=y
CONFIG_DNOTIFY=y
CONFIG_INOTIFY_USER=y
# CONFIG_FANOTIFY is not set
# CONFIG_QUOTA is not set
# CONFIG_QUOTACTL is not set
# CONFIG_AUTOFS4_FS is not set
# CONFIG_FUSE_FS is not set
# CONFIG_OVERLAY_FS is not set
# Caches
# CONFIG_FSCACHE is not set
# CD-ROM/DVD Filesystems
# CONFIG_ISO9660_FS is not set
# CONFIG_UDF_FS is not set
# DOS/FAT/NT Filesystems
CONFIG_FAT_FS=y
# CONFIG_MSDOS_FS is not set
CONFIG_VFAT_FS=y
CONFIG_FAT_DEFAULT_CODEPAGE=437
CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
# CONFIG_FAT_DEFAULT_UTF8 is not set
# CONFIG_NTFS_FS is not set
# Pseudo filesystems
CONFIG_PROC_FS=y
CONFIG_PROC_SYSCTL=y
CONFIG_PROC_PAGE_MONITOR=y
# CONFIG_PROC_CHILDREN is not set
CONFIG_KERNFS=y
CONFIG_SYSFS=y
CONFIG_TMPFS=y
# CONFIG_TMPFS_POSIX_ACL is not set
# CONFIG_TMPFS_XATTR is not set
# CONFIG_HUGETLB_PAGE is not set
CONFIG_CONFIGFS_FS=y
CONFIG_MISC_FILESYSTEMS=y
# CONFIG_ORANGEFS_FS is not set
# CONFIG_ADFS_FS is not set
# CONFIG_AFFS_FS is not set
# CONFIG_ECRYPT_FS is not set
# CONFIG_HFS_FS is not set
# CONFIG_HFSPLUS_FS is not set
# CONFIG_BEFS_FS is not set
# CONFIG_BFS_FS is not set
# CONFIG_EFS_FS is not set
# CONFIG_JFFS2_FS is not set
# CONFIG_CRAMFS is not set
# CONFIG_SQUASHFS is not set
# CONFIG_VXFS_FS is not set
# CONFIG_MINIX_FS is not set
# CONFIG_OMFS_FS is not set
# CONFIG_HPFS_FS is not set
# CONFIG_QNX4FS_FS is not set
# CONFIG_QNX6FS_FS is not set
# CONFIG_ROMFS_FS is not set
# CONFIG_PSTORE is not set
# CONFIG_SYSV_FS is not set
# CONFIG_UFS_FS is not set
CONFIG_NETWORK_FILESYSTEMS=y
CONFIG_NFS_FS=y
CONFIG_NFS_V2=y
CONFIG_NFS_V3=y
CONFIG_NFS_V3_ACL=y
CONFIG_NFS_V4=y
# CONFIG_NFS_SWAP is not set
# CONFIG_NFS_V4_1 is not set
CONFIG_ROOT_NFS=y
# CONFIG_NFS_USE_LEGACY_DNS is not set
CONFIG_NFS_USE_KERNEL_DNS=y
# CONFIG_NFSD is not set
CONFIG_GRACE_PERIOD=y
CONFIG_LOCKD=y
CONFIG_LOCKD_V4=y
CONFIG_NFS_ACL_SUPPORT=y
CONFIG_NFS_COMMON=y
CONFIG_SUNRPC=y
CONFIG_SUNRPC_GSS=y
# CONFIG_SUNRPC_DEBUG is not set
# CONFIG_CEPH_FS is not set
# CONFIG_CIFS is not set
# CONFIG_NCP_FS is not set
# CONFIG_CODA_FS is not set
# CONFIG_AFS_FS is not set
CONFIG_NLS=y
CONFIG_NLS_DEFAULT="iso8859-1"
CONFIG_NLS_CODEPAGE_437=y
# CONFIG_NLS_CODEPAGE_737 is not set
# CONFIG_NLS_CODEPAGE_775 is not set
# CONFIG_NLS_CODEPAGE_850 is not set
# CONFIG_NLS_CODEPAGE_852 is not set
# CONFIG_NLS_CODEPAGE_855 is not set
# CONFIG_NLS_CODEPAGE_857 is not set
# CONFIG_NLS_CODEPAGE_860 is not set
# CONFIG_NLS_CODEPAGE_861 is not set
# CONFIG_NLS_CODEPAGE_862 is not set
# CONFIG_NLS_CODEPAGE_863 is not set
# CONFIG_NLS_CODEPAGE_864 is not set
# CONFIG_NLS_CODEPAGE_865 is not set
# CONFIG_NLS_CODEPAGE_866 is not set
# CONFIG_NLS_CODEPAGE_869 is not set
# CONFIG_NLS_CODEPAGE_936 is not set
# CONFIG_NLS_CODEPAGE_950 is not set
# CONFIG_NLS_CODEPAGE_932 is not set
# CONFIG_NLS_CODEPAGE_949 is not set
# CONFIG_NLS_CODEPAGE_874 is not set
# CONFIG_NLS_ISO8859_8 is not set
# CONFIG_NLS_CODEPAGE_1250 is not set
# CONFIG_NLS_CODEPAGE_1251 is not set
# CONFIG_NLS_ASCII is not set
CONFIG_NLS_ISO8859_1=y
# CONFIG_NLS_ISO8859_2 is not set
# CONFIG_NLS_ISO8859_3 is not set
# CONFIG_NLS_ISO8859_4 is not set
# CONFIG_NLS_ISO8859_5 is not set
# CONFIG_NLS_ISO8859_6 is not set
# CONFIG_NLS_ISO8859_7 is not set
# CONFIG_NLS_ISO8859_9 is not set
# CONFIG_NLS_ISO8859_13 is not set
# CONFIG_NLS_ISO8859_14 is not set
# CONFIG_NLS_ISO8859_15 is not set
# CONFIG_NLS_KOI8_R is not set
# CONFIG_NLS_KOI8_U is not set
# CONFIG_NLS_MAC_ROMAN is not set
# CONFIG_NLS_MAC_CELTIC is not set
# CONFIG_NLS_MAC_CENTEURO is not set
# CONFIG_NLS_MAC_CROATIAN is not set
# CONFIG_NLS_MAC_CYRILLIC is not set
# CONFIG_NLS_MAC_GAELIC is not set
# CONFIG_NLS_MAC_GREEK is not set
# CONFIG_NLS_MAC_ICELAND is not set
# CONFIG_NLS_MAC_INUIT is not set
# CONFIG_NLS_MAC_ROMANIAN is not set
# CONFIG_NLS_MAC_TURKISH is not set
# CONFIG_NLS_UTF8 is not set
# CONFIG_DLM is not set
# Kernel hacking
# printk and dmesg options
CONFIG_PRINTK_TIME=y
CONFIG_CONSOLE_LOGLEVEL_DEFAULT=7
CONFIG_MESSAGE_LOGLEVEL_DEFAULT=4
# CONFIG_BOOT_PRINTK_DELAY is not set
# CONFIG_DYNAMIC_DEBUG is not set
# Compile-time checks and compiler options
# CONFIG_DEBUG_INFO is not set
CONFIG_ENABLE_WARN_DEPRECATED=y
CONFIG_ENABLE_MUST_CHECK=y
CONFIG_FRAME_WARN=1024
# CONFIG_STRIP_ASM_SYMS is not set
# CONFIG_READABLE_ASM is not set
# CONFIG_UNUSED_SYMBOLS is not set
# CONFIG_PAGE_OWNER is not set
CONFIG_DEBUG_FS=y
# CONFIG_HEADERS_CHECK is not set
# CONFIG_DEBUG_SECTION_MISMATCH is not set
CONFIG_SECTION_MISMATCH_WARN_ONLY=y
# CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set
# CONFIG_MAGIC_SYSRQ is not set
CONFIG_DEBUG_KERNEL=y
# Memory Debugging
# CONFIG_PAGE_EXTENSION is not set
# CONFIG_DEBUG_PAGEALLOC is not set
# CONFIG_PAGE_POISONING is not set
# CONFIG_DEBUG_RODATA_TEST is not set
# CONFIG_DEBUG_OBJECTS is not set
# CONFIG_SLUB_DEBUG_ON is not set
# CONFIG_SLUB_STATS is not set
CONFIG_HAVE_DEBUG_KMEMLEAK=y
# CONFIG_DEBUG_KMEMLEAK is not set
# CONFIG_DEBUG_STACK_USAGE is not set
# CONFIG_DEBUG_VM is not set
CONFIG_ARCH_HAS_DEBUG_VIRTUAL=y
# CONFIG_DEBUG_VIRTUAL is not set
CONFIG_DEBUG_MEMORY_INIT=y
# CONFIG_DEBUG_HIGHMEM is not set
# CONFIG_DEBUG_SHIRQ is not set
# Debug Lockups and Hangs
# CONFIG_SOFTLOCKUP_DETECTOR is not set
# CONFIG_DETECT_HUNG_TASK is not set
# CONFIG_WQ_WATCHDOG is not set
# CONFIG_PANIC_ON_OOPS is not set
CONFIG_PANIC_ON_OOPS_VALUE=0
CONFIG_PANIC_TIMEOUT=0
CONFIG_SCHED_DEBUG=y
# CONFIG_SCHED_INFO is not set
# CONFIG_SCHEDSTATS is not set
# CONFIG_SCHED_STACK_END_CHECK is not set
# CONFIG_DEBUG_TIMEKEEPING is not set
# Lock Debugging (spinlocks, mutexes, etc...)
# CONFIG_DEBUG_RT_MUTEXES is not set
# CONFIG_DEBUG_SPINLOCK is not set
# CONFIG_DEBUG_MUTEXES is not set
# CONFIG_DEBUG_WW_MUTEX_SLOWPATH is not set
# CONFIG_DEBUG_LOCK_ALLOC is not set
# CONFIG_PROVE_LOCKING is not set
# CONFIG_LOCK_STAT is not set
# CONFIG_DEBUG_ATOMIC_SLEEP is not set
# CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set
# CONFIG_LOCK_TORTURE_TEST is not set
# CONFIG_WW_MUTEX_SELFTEST is not set
CONFIG_STACKTRACE=y
# CONFIG_WARN_ALL_UNSEEDED_RANDOM is not set
# CONFIG_DEBUG_KOBJECT is not set
CONFIG_DEBUG_BUGVERBOSE=y
# CONFIG_DEBUG_LIST is not set
# CONFIG_DEBUG_PI_LIST is not set
# CONFIG_DEBUG_SG is not set
# CONFIG_DEBUG_NOTIFIERS is not set
# CONFIG_DEBUG_CREDENTIALS is not set
# RCU Debugging
# CONFIG_PROVE_RCU is not set
# CONFIG_TORTURE_TEST is not set
# CONFIG_RCU_PERF_TEST is not set
# CONFIG_RCU_TORTURE_TEST is not set
CONFIG_RCU_TRACE=y
# CONFIG_RCU_EQS_DEBUG is not set
# CONFIG_DEBUG_WQ_FORCE_RR_CPU is not set
# CONFIG_DEBUG_BLOCK_EXT_DEVT is not set
# CONFIG_NOTIFIER_ERROR_INJECTION is not set
# CONFIG_FAULT_INJECTION is not set
# CONFIG_LATENCYTOP is not set
CONFIG_HAVE_FUNCTION_TRACER=y
CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y
CONFIG_HAVE_DYNAMIC_FTRACE=y
CONFIG_HAVE_DYNAMIC_FTRACE_WITH_REGS=y
CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y
CONFIG_HAVE_SYSCALL_TRACEPOINTS=y
CONFIG_HAVE_C_RECORDMCOUNT=y
CONFIG_TRACE_CLOCK=y
CONFIG_TRACING_SUPPORT=y
# CONFIG_FTRACE is not set
# CONFIG_DMA_API_DEBUG is not set
# Runtime Testing
# CONFIG_LKDTM is not set
# CONFIG_TEST_LIST_SORT is not set
# CONFIG_TEST_SORT is not set
# CONFIG_BACKTRACE_SELF_TEST is not set
# CONFIG_RBTREE_TEST is not set
# CONFIG_INTERVAL_TREE_TEST is not set
# CONFIG_PERCPU_TEST is not set
# CONFIG_ATOMIC64_SELFTEST is not set
# CONFIG_TEST_HEXDUMP is not set
# CONFIG_TEST_STRING_HELPERS is not set
# CONFIG_TEST_KSTRTOX is not set
# CONFIG_TEST_PRINTF is not set
# CONFIG_TEST_BITMAP is not set
# CONFIG_TEST_UUID is not set
# CONFIG_TEST_RHASHTABLE is not set
# CONFIG_TEST_HASH is not set
# CONFIG_TEST_LKM is not set
# CONFIG_TEST_USER_COPY is not set
# CONFIG_TEST_BPF is not set
# CONFIG_TEST_FIND_BIT is not set
# CONFIG_TEST_FIRMWARE is not set
# CONFIG_TEST_SYSCTL is not set
# CONFIG_TEST_UDELAY is not set
# CONFIG_TEST_STATIC_KEYS is not set
# CONFIG_TEST_KMOD is not set
# CONFIG_MEMTEST is not set
# CONFIG_BUG_ON_DATA_CORRUPTION is not set
# CONFIG_SAMPLES is not set
CONFIG_HAVE_ARCH_KGDB=y
# CONFIG_KGDB is not set
# CONFIG_ARCH_WANTS_UBSAN_NO_NULL is not set
# CONFIG_UBSAN is not set
CONFIG_ARCH_HAS_DEVMEM_IS_ALLOWED=y
# CONFIG_STRICT_DEVMEM is not set
# CONFIG_ARM_PTDUMP is not set
CONFIG_ARM_UNWIND=y
# CONFIG_DEBUG_USER is not set
# CONFIG_DEBUG_LL is not set
CONFIG_DEBUG_LL_INCLUDE="mach/debug-macro.S"
# CONFIG_DEBUG_UART_8250 is not set
CONFIG_UNCOMPRESS_INCLUDE="debug/uncompress.h"
# CONFIG_CORESIGHT is not set
# Security options
CONFIG_KEYS=y
# CONFIG_PERSISTENT_KEYRINGS is not set
# CONFIG_BIG_KEYS is not set
# CONFIG_ENCRYPTED_KEYS is not set
# CONFIG_KEY_DH_OPERATIONS is not set
# CONFIG_SECURITY_DMESG_RESTRICT is not set
# CONFIG_SECURITY is not set
# CONFIG_SECURITYFS is not set
CONFIG_HAVE_HARDENED_USERCOPY_ALLOCATOR=y
# CONFIG_HARDENED_USERCOPY is not set
# CONFIG_STATIC_USERMODEHELPER is not set
CONFIG_DEFAULT_SECURITY_DAC=y
CONFIG_DEFAULT_SECURITY=""
CONFIG_CRYPTO=y
# Crypto core or helper
CONFIG_CRYPTO_ALGAPI=y
CONFIG_CRYPTO_ALGAPI2=y
CONFIG_CRYPTO_AEAD=y
CONFIG_CRYPTO_AEAD2=y
CONFIG_CRYPTO_BLKCIPHER=y
CONFIG_CRYPTO_BLKCIPHER2=y
CONFIG_CRYPTO_HASH=y
CONFIG_CRYPTO_HASH2=y
CONFIG_CRYPTO_RNG=y
CONFIG_CRYPTO_RNG2=y
CONFIG_CRYPTO_RNG_DEFAULT=y
CONFIG_CRYPTO_AKCIPHER2=y
CONFIG_CRYPTO_AKCIPHER=y
CONFIG_CRYPTO_KPP2=y
CONFIG_CRYPTO_ACOMP2=y
CONFIG_CRYPTO_RSA=y
# CONFIG_CRYPTO_DH is not set
# CONFIG_CRYPTO_ECDH is not set
CONFIG_CRYPTO_MANAGER=y
CONFIG_CRYPTO_MANAGER2=y
# CONFIG_CRYPTO_USER is not set
CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y
CONFIG_CRYPTO_GF128MUL=y
CONFIG_CRYPTO_NULL=y
CONFIG_CRYPTO_NULL2=y
CONFIG_CRYPTO_WORKQUEUE=y
# CONFIG_CRYPTO_CRYPTD is not set
# CONFIG_CRYPTO_MCRYPTD is not set
# CONFIG_CRYPTO_AUTHENC is not set
# CONFIG_CRYPTO_TEST is not set
# Authenticated Encryption with Associated Data
CONFIG_CRYPTO_CCM=y
CONFIG_CRYPTO_GCM=y
# CONFIG_CRYPTO_CHACHA20POLY1305 is not set
CONFIG_CRYPTO_SEQIV=y
CONFIG_CRYPTO_ECHAINIV=m
# Block modes
# CONFIG_CRYPTO_CBC is not set
CONFIG_CRYPTO_CTR=y
# CONFIG_CRYPTO_CTS is not set
# CONFIG_CRYPTO_ECB is not set
# CONFIG_CRYPTO_LRW is not set
# CONFIG_CRYPTO_PCBC is not set
# CONFIG_CRYPTO_XTS is not set
# CONFIG_CRYPTO_KEYWRAP is not set
# Hash modes
CONFIG_CRYPTO_CMAC=y
CONFIG_CRYPTO_HMAC=y
# CONFIG_CRYPTO_XCBC is not set
# CONFIG_CRYPTO_VMAC is not set
# Digest
CONFIG_CRYPTO_CRC32C=y
# CONFIG_CRYPTO_CRC32 is not set
# CONFIG_CRYPTO_CRCT10DIF is not set
CONFIG_CRYPTO_GHASH=y
# CONFIG_CRYPTO_POLY1305 is not set
# CONFIG_CRYPTO_MD4 is not set
CONFIG_CRYPTO_MD5=y
# CONFIG_CRYPTO_MICHAEL_MIC is not set
# CONFIG_CRYPTO_RMD128 is not set
# CONFIG_CRYPTO_RMD160 is not set
# CONFIG_CRYPTO_RMD256 is not set
# CONFIG_CRYPTO_RMD320 is not set
CONFIG_CRYPTO_SHA1=y
CONFIG_CRYPTO_SHA256=y
# CONFIG_CRYPTO_SHA512 is not set
# CONFIG_CRYPTO_SHA3 is not set
# CONFIG_CRYPTO_SM3 is not set
# CONFIG_CRYPTO_TGR192 is not set
# CONFIG_CRYPTO_WP512 is not set
# Ciphers
CONFIG_CRYPTO_AES=y
# CONFIG_CRYPTO_AES_TI is not set
# CONFIG_CRYPTO_ANUBIS is not set
CONFIG_CRYPTO_ARC4=y
# CONFIG_CRYPTO_BLOWFISH is not set
# CONFIG_CRYPTO_CAMELLIA is not set
# CONFIG_CRYPTO_CAST5 is not set
# CONFIG_CRYPTO_CAST6 is not set
CONFIG_CRYPTO_DES=y
# CONFIG_CRYPTO_FCRYPT is not set
# CONFIG_CRYPTO_KHAZAD is not set
# CONFIG_CRYPTO_SALSA20 is not set
# CONFIG_CRYPTO_CHACHA20 is not set
# CONFIG_CRYPTO_SEED is not set
# CONFIG_CRYPTO_SERPENT is not set
# CONFIG_CRYPTO_TEA is not set
# CONFIG_CRYPTO_TWOFISH is not set
# Compression
# CONFIG_CRYPTO_DEFLATE is not set
# CONFIG_CRYPTO_LZO is not set
# CONFIG_CRYPTO_842 is not set
# CONFIG_CRYPTO_LZ4 is not set
# CONFIG_CRYPTO_LZ4HC is not set
# Random Number Generation
# CONFIG_CRYPTO_ANSI_CPRNG is not set
CONFIG_CRYPTO_DRBG_MENU=y
CONFIG_CRYPTO_DRBG_HMAC=y
# CONFIG_CRYPTO_DRBG_HASH is not set
# CONFIG_CRYPTO_DRBG_CTR is not set
CONFIG_CRYPTO_DRBG=y
CONFIG_CRYPTO_JITTERENTROPY=y
# CONFIG_CRYPTO_USER_API_HASH is not set
# CONFIG_CRYPTO_USER_API_SKCIPHER is not set
# CONFIG_CRYPTO_USER_API_RNG is not set
# CONFIG_CRYPTO_USER_API_AEAD is not set
CONFIG_CRYPTO_HASH_INFO=y
CONFIG_CRYPTO_HW=y
# CONFIG_CRYPTO_DEV_FSL_CAAM_CRYPTO_API_DESC is not set
CONFIG_CRYPTO_DEV_SUN4I_SS=y
# CONFIG_CRYPTO_DEV_SUN4I_SS_PRNG is not set
CONFIG_ASYMMETRIC_KEY_TYPE=y
CONFIG_ASYMMETRIC_PUBLIC_KEY_SUBTYPE=y
CONFIG_X509_CERTIFICATE_PARSER=y
CONFIG_PKCS7_MESSAGE_PARSER=y
# CONFIG_PKCS7_TEST_KEY is not set
# CONFIG_SIGNED_PE_FILE_VERIFICATION is not set
# Certificates for signature checking
CONFIG_SYSTEM_TRUSTED_KEYRING=y
CONFIG_SYSTEM_TRUSTED_KEYS=""
# CONFIG_SYSTEM_EXTRA_CERTIFICATE is not set
# CONFIG_SECONDARY_TRUSTED_KEYRING is not set
# CONFIG_SYSTEM_BLACKLIST_KEYRING is not set
# CONFIG_ARM_CRYPTO is not set
# CONFIG_BINARY_PRINTF is not set
# Library routines
CONFIG_BITREVERSE=y
# CONFIG_HAVE_ARCH_BITREVERSE is not set
CONFIG_RATIONAL=y
CONFIG_GENERIC_STRNCPY_FROM_USER=y
CONFIG_GENERIC_STRNLEN_USER=y
CONFIG_GENERIC_NET_UTILS=y
CONFIG_GENERIC_PCI_IOMAP=y
CONFIG_ARCH_USE_CMPXCHG_LOCKREF=y
# CONFIG_CRC_CCITT is not set
CONFIG_CRC16=y
# CONFIG_CRC_T10DIF is not set
# CONFIG_CRC_ITU_T is not set
CONFIG_CRC32=y
# CONFIG_CRC32_SELFTEST is not set
CONFIG_CRC32_SLICEBY8=y
# CONFIG_CRC32_SLICEBY4 is not set
# CONFIG_CRC32_SARWATE is not set
# CONFIG_CRC32_BIT is not set
# CONFIG_CRC4 is not set
# CONFIG_CRC7 is not set
# CONFIG_LIBCRC32C is not set
# CONFIG_CRC8 is not set
# CONFIG_AUDIT_ARCH_COMPAT_GENERIC is not set
# CONFIG_RANDOM32_SELFTEST is not set
CONFIG_ZLIB_INFLATE=y
CONFIG_LZO_DECOMPRESS=y
CONFIG_LZ4_DECOMPRESS=y
CONFIG_XZ_DEC=y
CONFIG_XZ_DEC_X86=y
CONFIG_XZ_DEC_POWERPC=y
CONFIG_XZ_DEC_IA64=y
CONFIG_XZ_DEC_ARM=y
CONFIG_XZ_DEC_ARMTHUMB=y
CONFIG_XZ_DEC_SPARC=y
CONFIG_XZ_DEC_BCJ=y
# CONFIG_XZ_DEC_TEST is not set
CONFIG_DECOMPRESS_GZIP=y
CONFIG_DECOMPRESS_BZIP2=y
CONFIG_DECOMPRESS_LZMA=y
CONFIG_DECOMPRESS_XZ=y
CONFIG_DECOMPRESS_LZO=y
CONFIG_DECOMPRESS_LZ4=y
CONFIG_GENERIC_ALLOCATOR=y
CONFIG_ASSOCIATIVE_ARRAY=y
CONFIG_HAS_IOMEM=y
CONFIG_HAS_IOPORT_MAP=y
CONFIG_HAS_DMA=y
# CONFIG_DMA_NOOP_OPS is not set
# CONFIG_DMA_VIRT_OPS is not set
CONFIG_DQL=y
CONFIG_NLATTR=y
CONFIG_GENERIC_ATOMIC64=y
CONFIG_CLZ_TAB=y
# CONFIG_CORDIC is not set
# CONFIG_DDR is not set
# CONFIG_IRQ_POLL is not set
CONFIG_MPILIB=y
CONFIG_LIBFDT=y
CONFIG_OID_REGISTRY=y
CONFIG_FONT_SUPPORT=y
# CONFIG_FONTS is not set
CONFIG_FONT_8x8=y
CONFIG_FONT_8x16=y
# CONFIG_SG_SPLIT is not set
CONFIG_SG_POOL=y
CONFIG_ARCH_HAS_SG_CHAIN=y
CONFIG_SBITMAP=y
# CONFIG_STRING_SELFTEST is not set
# CONFIG_VIRTUALIZATION is not set离线
dts的内容
/dts-v1/;
#include "suniv-f1c100s.dtsi"
model = "Lichee Pi Nano";
compatible = "licheepi,licheepi-nano", "allwinner,suniv-f1c100s",
"allwinner,suniv";
aliases {
serial0 = &uart0;
spi0 = &spi0;
chosen {
panel: panel {
compatible = "qiaodian,qd43003c0-40", "simple-panel";
#address-cells = <1>;
#size-cells = <0>;
enable-gpios = <&pio 4 6 GPIO_ACTIVE_HIGH>;
port@0 {
reg = <0>;
#size-cells = <0>;
panel_input: endpoint@0 {
reg = <0>;
reg_vcc3v3: vcc3v3 {
regulator-name = "vcc3v3";
&de {
&mmc0 {
vmmc-supply = <®_vcc3v3>;
bus-width = <4>;
broken-cd;
&otg_sram {
&spi0 {
pinctrl-names = "default";
pinctrl-0 = <&spi0_pins_a>;
flash@0 {
#size-cells = <1>;
compatible = "winbond,xt25f128b,w25q128", "jedec,spi-nor,spi-nor";
reg = <0>;
&tcon0 {
pinctrl-0 = <&lcd_rgb666_pins>;
&tcon0_out {
tcon0_out_lcd: endpoint@0 {
reg = <0>;
&uart0 {
pinctrl-0 = <&uart0_pins_a>;
&usb_otg {
dr_mode = "otg";
&usbphy {
};离线
大佬config文件还有不。。今天按照荔枝派的教程里面哪个linux的config文件下载不了,直接403/。。。
已经做成功了,谢谢大神们的帮助
U-Boot 2018.01-05679-g013ca45-dirty (May 18 2020 - 12:37:41 +0000) Allwinner Technology
Model: Lichee Pi Nano
DRAM: 32 MiB
MMC: SUNXI SD/MMC: 0
SF: Detected xt25f128b with page size 256 Bytes, erase size 4 KiB, total 16 MiB
In: serial
Out: serial
Err: serial
Net: No ethernet found.
No controllers found
Hit any key to stop autoboot: 2 1 0
sf - SPI flash sub-system
Usage:
sf probe [[bus:]cs] [hz] [mode] - init flash device on given SPI bus
and chip select
sf read addr offset|partition len - read `len' bytes starting at
`offset' or from start of mtd
`partition'to memory at `addr'
sf write addr offset|partition len - write `len' bytes from memory
at `addr' to flash at `offset'
or to start of mtd `partition'
sf erase offset|partition [+]len - erase `len' bytes from `offset'
or from start of mtd `partition'
`+len' round up `len' to block size
sf update addr offset|partition len - erase and write `len' bytes from memory
sf protect lock/unlock sector len - protect/unprotect 'len' bytes starting
at address 'sector'
Loading Device Tree to 816fb000, end 816fff2e ... OK
[ 0.000000] Linux version 4.15.0-rc8-licheepi-nano+ (root@535337fc15c2) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #6 Mon May 18 12:48:52 UTC 2020
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 8128
[ 0.000000] Kernel command line: panic=5 rootwait root=/dev/mtdblock3 rw rootfstype=jffs2
[ 0.000000] Memory: 22672K/32768K available (6144K kernel code, 238K rwdata, 1420K rodata, 1024K init, 246K bss, 10096K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] vmalloc : 0xc2800000 - 0xff800000 ( 976 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc2000000 ( 32 MB)
[ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (7136 kB)
[ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (1024 kB)
[ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 239 kB)
[ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 247 kB)
[ 0.000044] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000109] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000631] Console: colour dummy device 80x30
[ 0.001496] console [tty0] enabled
[ 0.001591] Calibrating delay loop... 203.16 BogoMIPS (lpj=1015808)
[ 0.070282] pid_max: default: 32768 minimum: 301
[ 0.070616] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.070712] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.072180] CPU: Testing write buffer coherency: ok
[ 0.073872] Setting up static identity map for 0x80100000 - 0x80100058
[ 0.076437] devtmpfs: initialized
[ 0.082851] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.083022] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.083321] pinctrl core: initialized pinctrl subsystem
[ 0.085202] random: get_random_u32 called from bucket_table_alloc+0x80/0x1a4 with crng_init=0
[ 0.085534] NET: Registered protocol family 16
[ 0.086877] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.088746] cpuidle: using governor menu
[ 0.113739] SCSI subsystem initialized
[ 0.114188] usbcore: registered new interface driver usbfs
[ 0.114411] usbcore: registered new interface driver hub
[ 0.114670] usbcore: registered new device driver usb
[ 0.115142] pps_core: LinuxPPS API ver. 1 registered
[ 0.115223] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.115357] PTP clock support registered
[ 0.115895] Advanced Linux Sound Architecture Driver Initialized.
[ 0.117411] clocksource: Switched to clocksource timer
[ 0.143793] NET: Registered protocol family 2
[ 0.145260] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.145415] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.145504] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.145816] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.145923] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.146430] NET: Registered protocol family 1
[ 0.147822] RPC: Registered named UNIX socket transport module.
[ 0.147934] RPC: Registered udp transport module.
[ 0.147983] RPC: Registered tcp transport module.
[ 0.148027] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.150137] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.152026] Initialise system trusted keyrings
[ 0.152643] workingset: timestamp_bits=30 max_order=13 bucket_order=0
[ 0.167775] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.170107] NFS: Registering the id_resolver key type
[ 0.170267] Key type id_resolver registered
[ 0.170323] Key type id_legacy registered
[ 0.170471] jffs2: version 2.2. (NAND) (SUMMARY) 漏 2001-2006 Red Hat, Inc.
[ 0.172315] random: fast init done
[ 0.185289] Key type asymmetric registered
[ 0.185396] Asymmetric key parser 'x509' registered
[ 0.185632] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.185733] io scheduler noop registered
[ 0.185782] io scheduler deadline registered
[ 0.186608] io scheduler cfq registered (default)
[ 0.186702] io scheduler mq-deadline registered
[ 0.186754] io scheduler kyber registered
[ 0.188012] sun4i-usb-phy 1c13400.phy: Couldn't request ID GPIO
[ 0.197660] suniv-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.367856] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.394699] 1c25000.serial: ttyS0 at MMIO 0x1c25000 (irq = 23, base_baud = 6250000) is a 16550A
[ 0.882148] console [ttyS0] enabled
[ 0.892675] panel-simple panel: panel supply power not found, using dummy regulator
[ 0.902150] SCSI Media Changer driver v0.25
[ 0.910177] m25p80 spi0.0: xt25f128b (16384 Kbytes)
[ 0.915202] 4 ofpart partitions found on MTD device spi0.0
[ 0.920842] Creating 4 MTD partitions on "spi0.0":
[ 0.925693] 0x000000000000-0x000000100000 : "u-boot"
[ 0.933358] 0x000000100000-0x000000110000 : "dtb"
[ 0.940689] 0x000000110000-0x000000510000 : "kernel"
[ 0.948275] 0x000000510000-0x000001000000 : "rootfs"
[ 0.956297] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.963028] ehci-platform: EHCI generic platform driver
[ 0.968669] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.974949] ohci-platform: OHCI generic platform driver
[ 0.980703] usbcore: registered new interface driver usb-storage
[ 0.987831] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[ 0.996859] i2c /dev entries driver
[ 1.057527] sunxi-mmc 1c0f000.mmc: base:0x(ptrval) irq:19
[ 1.065022] usbcore: registered new interface driver usbhid
[ 1.070793] usbhid: USB HID core driver
[ 1.092476] NET: Registered protocol family 17
[ 1.097229] Key type dns_resolver registered
[ 1.103908] Loading compiled-in X.509 certificates
[ 1.119140] sun4i-drm display-engine: bound 1e60000.display-backend (ops 0xc073a218)
[ 1.128181] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc07394fc)
[ 1.135933] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.142690] [drm] No driver support for vblank timestamp query.
[ 1.196683] Console: switching to colour frame buffer device 60x34
[ 1.220368] sun4i-drm display-engine: fb0: frame buffer device
[ 1.227934] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[ 1.248852] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 1.278572] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.296632] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 1.319530] hub 1-0:1.0: USB hub found
[ 1.330142] hub 1-0:1.0: 1 port detected
[ 1.342192] using random self ethernet address
[ 1.353207] using random host ethernet address
[ 1.365857] usb0: HOST MAC 0a:d7:7a:9d:43:0b
[ 1.376636] usb0: MAC 76:97:3d:15:c0:cd
[ 1.386783] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[ 1.406477] g_cdc gadget: g_cdc ready
[ 1.417336] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 1.447215] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 1.466486] vcc3v3: disabling
[ 1.475758] ALSA device list:
[ 1.484906] #0: Loopback 1
[ 1.494720] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 1.515418] cfg80211: failed to load regulatory.db
[ 1.629576] random: crng init done
[ 3.044875] jffs2: notice: (1) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[ 3.082921] VFS: Mounted root (jffs2 filesystem) on device 31:3.
[ 3.102623] devtmpfs: mounted
[ 3.116321] Freeing unused kernel memory: 1024K
Starting logging: OK
Starting network: OK
Welcome to Buildroot
nano login: 离线
是怎么解决的?
好几个地方要注意,我改天写个详细操作步骤!
刚买的ZERO开发板,我好晕啊,没有一点头绪,这个开发板的资料真的好少唉
靠你了大佬。我的tiny还在编译linux系统的阶段。。。
