楼主 #1 2020-05-30 15:15:16
无情一刀
已发帖子: 716
使用实现r8723bs已经记载了驱动 ,但是wlan0 就是UP不了
我看了路由器 里面没有用完IP地址  但是我去ifconfig wlan0 up的时候就是报错出现
ifconfig: SIOCSIFFLAGS: Operation not permitted这样的
Could not set interface wlan0 flags (UP): Operation not permitted
nl80211: Could not set interface 'wlan0' UP
nl80211: deinit ifname=wlan0 disabled_11b_rates=0
nl80211: Remove monitor interface: refcount=0
netlink: Operstate: ifindex=4 linkmode=0 (kernel-control), operstate=6 (IF_OPER_UP)
nl80211: Set mode ifindex 4 iftype 2 (STATION)
nl80211: Unsubscribe mgmt frames handle 0x889105e1 (mode change)
wlan0: Failed to initialize driver interface
Failed to add interface wlan0
wlan0: Cancelling scan request
wlan0: Cancelling authentication timeout
Off-channel: Clear pending Action frame TX (pending_action_tx=(nil)
udhcpc: started, v1.29.2
udhcpc: sending discover
udhcpc: sendto: Network is down
楼主 #2 2020-05-30 15:17:58
无情一刀
已发帖子: 716
Re: 使用实现r8723bs已经记载了驱动 ,但是wlan0 就是UP不了
但是用ifconfig -a  下面又有wlan0
# ifconfig -a
eth0      Link encap:Ethernet  HWaddr 02:01:46:EC:EC:AA
          inet addr:192.168.0.10  Bcast:192.168.255.255  Mask:255.255.0.0
          BROADCAST MULTICAST  MTU:1500  Metric:1
          collisions:0 txqueuelen:1000
          Interrupt:38
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:4 errors:0 dropped:0 overruns:0 frame:0
          TX packets:4 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:352 (352.0 B)  TX bytes:352 (352.0 B)
usb0      Link encap:Ethernet  HWaddr 82:9E:1C:3B:22:52
wlan0     Link encap:Ethernet  HWaddr 00:E0:4C:B7:23:00
#3 2020-05-30 15:22:53
有梦的地方
已发帖子: 284
多点信息啊,加载驱动是什么情况。
#4 2020-05-30 15:27:42
所在地: 你猜
已发帖子: 3,388
是不是没有加载固件: https://whycan.cn/t_652.html#p13049
以前可以吗?
楼主 #5 2020-05-30 15:28:28
无情一刀
已发帖子: 716
有梦的地方 说:
多点信息啊,加载驱动是什么情况。
[   14.695000] r8723bs: module is from the staging directory, the quality is unknown, you have been warned.
[   14.712216] RTL8723BS: module init start
[   14.716157] RTL8723BS: rtl8723bs v4.3.5.5_12290.20140916_BTCOEX20140507-4E40
[   14.723295] RTL8723BS: rtl8723bs BT-Coex version = BTCOEX20140507-4E40
[   14.743011] pnetdev = c30f7000
[   17.062401] RTL8723BS: rtw_ndev_init(wlan0)
[   17.138082] RTL8723BS: module init ret =0
和这个帖子是一样的情况 但是不知道 我要弄什么文件进去
https://whycan.cn/t_604_27.html
楼主 #6 2020-05-30 15:28:52
无情一刀
已发帖子: 716
以前可以吗?
以前是可以的  上一次就是把路由器重启后 有可以了 ,
楼主 #7 2020-05-30 15:30:21
无情一刀
已发帖子: 716
rtl8723bs_nic.bin这个文件我也有啊  在rtlwifi目录下有的
最近编辑记录 无情一刀 (2020-05-30 15:31:43)
#8 2020-05-30 15:44:43
所在地: 你猜
已发帖子: 3,388
这个问题感觉和路由器没有关系。
楼主 #9 2020-05-30 15:46:25
无情一刀
已发帖子: 716
这个问题感觉和路由器没有关系。
在/lib/firmware/rtlwifi文件下也有rtl8723bs_nic.bin这个文件
楼主 #10 2020-06-01 10:00:41
无情一刀
已发帖子: 716
使用wifi如果是当前里面设置了密码错误,下一次启动的时候 就会是一直在连接导致程序不能执行和触摸
[  173.980781] RTL8723BS: nolinked power save leave
[  175.639335] RTL8723BS: nolinked power save enter
[  180.860817] RTL8723BS: nolinked power save leave
[  182.519460] RTL8723BS: nolinked power save enter
[  187.740708] RTL8723BS: nolinked power save leave
[  189.399334] RTL8723BS: nolinked power save enter
[  194.620788] RTL8723BS: nolinked power save leave
[  196.279352] RTL8723BS: nolinked power save enter
[  201.500849] RTL8723BS: nolinked power save leave
[  203.159462] RTL8723BS: nolinked power save enter
[  208.380802] RTL8723BS: nolinked power save leave
[  210.039339] RTL8723BS: nolinked power save enter
#11 2020-06-01 10:06:13
所在地: 你猜
已发帖子: 3,388
udhcpc 进程塞住了,加 & 后台运行符号
楼主 #12 2020-06-01 10:10:25
无情一刀
已发帖子: 716
也就是当前热点没有开启的时候 会一直连接 导致 程序里面不会往下执行
楼主 #13 2020-06-01 10:11:13
无情一刀
已发帖子: 716
是.conf里面的wifi名称没有开启,
#14 2020-06-01 10:14:25
所在地: 你猜
已发帖子: 3,388
无情一刀 说:
没看懂
楼主 #15 2020-06-01 10:20:51
无情一刀
已发帖子: 716
没看懂
就是我的wpa_supplicant.conf文件的设置的wifi名称我没有开启 然后程序就会自动连接这个wpa_supplicant.conf里面wifi名称,导致一直处于连接 ,程序也没有往下执行,
#16 2020-06-01 10:29:08
所在地: 你猜
已发帖子: 3,388
无情一刀 说:
命令行是啥?
楼主 #17 2020-06-01 10:39:04
无情一刀
已发帖子: 716
命令行是啥?
system("ifconfig wlan0 up");
    system("wpa_supplicant -B -d -i wlan0 -c /etc/wpa_supplicant.conf");
    Delay_MSec(10);
    system("udhcpc -i wlan0");
这里我就是开机启动自动连接去 ,
不知道什么弄成  连接多少次之后 没有成功就不连了
#18 2020-06-01 11:05:49
有梦的地方
已发帖子: 284
11楼你不看的么?
楼主 #19 2020-06-01 11:14:45
无情一刀
已发帖子: 716
就是如果是开机启动自动连接时候,是否可以设置为连接多少次之后 ,就不连接了
#20 2020-06-01 11:17:13
所在地: 你猜
已发帖子: 3,388
无情一刀 说:
shell脚本里面弄个计数器,满了就退出。
楼主 #21 2020-06-01 11:26:11
无情一刀
已发帖子: 716
我在这里面加了这个country 不起作用,在脚本里面写没有连接成功的 不是很懂 ,麻烦你说的详细点哦哦
# cat /etc/wpa_supplicant.conf
ctrl_interface_group=0
update_config=1
country=10
network={
   ssid="iPhone7p"
        psk="wo1003676315"
        key_mgmt=WPA-PSK WPA-EAP IEEE8021X NONE
        priority=5
楼主 #22 2020-06-01 13:51:54
无情一刀
已发帖子: 716
看了不知道怎么去关联起来
#23 2022-01-24 11:31:29
如花*莫
请问楼主解决了吗。我现在是报同样的错误
