楼主 #1 2018-11-03 14:51:44
试一试用MDK ARMCC 编译全志官方f1c100s sdk --- melis
看到 Q群上面有人把 melis 给跑起来, 还可以播放视频,垂涎三尺,但是人家就装x一下就走了。
手册: Melis2.0 用户手册.pdf
2019-03-01 更新:
直接本站下载melis打包工具: eStudio.7z
楼主 #2 2018-11-03 14:53:03
Re: 试一试用MDK ARMCC 编译全志官方f1c100s sdk --- melis
@assert QQ发消息给我说用 MDK 成功编译了 melis, 于是按他教我的方法试一试.
楼主 #3 2018-11-03 14:53:58
  1. 解压 MELIS100A.7z
  2. 打开 MELIS100A\includes\cfgs\CROSSTOOL.CFG, RVDSPATH 修改成你的 MDK 路径:
这是我的配置:
RVDSPATH = "C:/Keil_v5/ARM/ARMCC/bin/"
  1. 在 MELIS100A 目录执行 make
楼主 #4 2018-11-03 14:58:45
正在愉快的编译
楼主 #5 2018-11-03 15:00:50
"rat/rat_npl.c", line 436: Warning: #177-D: variable "ret" was declared but never referenced
__s32 ret;
"rat/rat_npl.c", line 534: Warning: #177-D: variable "pScanEntry" was declared but never referenced
ScanedEntry_t * pScanEntry;
"rat/rat_npl.c", line 535: Warning: #177-D: variable "n" was declared but never referenced
__s32 n;
"rat/rat_npl.c", line 536: Warning: #177-D: variable "ret" was declared but never referenced
__s32 ret;
rat/rat_npl.c: 11 warnings, 0 errors
"C:/Keil_v5/ARM/ARMCC/bin/"/armar -r elibs_ex.a anole/anole.o robin/robin_i.o robin/robin.o robin/ab/robin_ab.o robin/channel/rob in_channel.o robin/disp_output/robin_disp_output.o robin/eq/robin_eq.o robin/ff_rr_speed/robin_ff_rr_speed.o robin/foundation/rob in_feedbackQ.o robin/foundation/robin_cmd_mutex.o robin/foundation/robin_monitor.o robin/foundation/cmdQ.o robin/foundation/robin _cedar_mutex.o robin/foundation/robin_syn_op.o robin/fsm_ctrl/robin_fsm_ctrl.o robin/lib/robin_misc.o robin/lyric/robin_lyric.o r obin/media_info/robin_media_info.o robin/npl/robin_npl.o robin/palette/robin_palette.o robin/play_mode/robin_play_mode.o robin/pl ay_speed/robin_play_speed.o robin/spectrum/robin_spectrum.o robin/star/robin_star.o robin/subtitle/robin_subtitle.o robin/track/r obin_track.o robin/video_layer/robin_video_layer.o robin/video_win/robin_video_win.o robin/vision_effect/robin_vision_effect.o ro bin/volume/robin_volume.o robin/zoom/robin_zoom.o rat/rat_npl.o rat/rat_partition.o rat/rat_miniature.o rat/rat.o rat/scanfile/Sc an.o rat/scanfile/ScanStack.o rat/scanfile/OAL.o
cp elibs_ex.a ./../../../../libs/suniv/elibs_ex.a
lib ex build finish!
make[4]: 警告:检测到时钟错误。您的构建版本可能是不完整的。
make[4]: 离开目录“/d/Downloads/MELIS100A/livedesk/beetles/elibs/lib_ex”
make[3]: 警告:检测到时钟错误。您的构建版本可能是不完整的。
make[3]: 离开目录“/d/Downloads/MELIS100A/livedesk/beetles/elibs”
make -C res
make[3]: 进入目录“/d/Downloads/MELIS100A/livedesk/beetles/res”
make -C lang
make[4]: 进入目录“/d/Downloads/MELIS100A/livedesk/beetles/res/lang”
./../../../../../eStudio/Softwares/LangBuild/LangOSDBuild.exe ./lang.xml
make[4]:./../../../../../eStudio/Softwares/LangBuild/LangOSDBuild.exe:命令未找到
make[4]: *** [makefile:27:buildlang] 错误 127
make[4]: 离开目录“/d/Downloads/MELIS100A/livedesk/beetles/res/lang”
make[3]: *** [makefile:28:buildres] 错误 2
make[3]: 离开目录“/d/Downloads/MELIS100A/livedesk/beetles/res”
make[2]: *** [makefile:24:all] 错误 2
make[2]: 离开目录“/d/Downloads/MELIS100A/livedesk/beetles”
make[1]: *** [makefile:23:all] 错误 2
make[1]: 离开目录“/d/Downloads/MELIS100A/livedesk”
make: *** [makefile:25:all] 错误 2
编译完成
但是缺少可执行文件,导致打包不能进行。
楼主 #6 2018-11-03 16:08:23
弄来的两个SDK都有这个问题。
楼主 #7 2018-11-03 16:08:51
然后用 make image 命令, 会出现打包错误.
楼主 #8 2018-11-03 16:09:08
#9 2018-11-05 11:31:40
dgtg
已发帖子: 276
强烈关注啊,如果MDK能编译melis,并且能实现播放H264视频,那真是太赞了!!!
#10 2018-11-05 11:38:56
lcfmax
已发帖子: 330
感兴趣,强烈关注
楼主 #11 2018-11-05 11:51:08
用 MDK 编译 melis SDK倒是没有问题, 打包的时候挂了, 可能缺少 eDragonEx220, 我电脑上只发现 eDragonEx200。
#12 2018-11-05 13:45:52
lcfmax
已发帖子: 330
编译环境的搭建跟SDK能否分享一下,我也想试试?
楼主 #13 2018-11-05 13:46:45
Q上发信息给我, 我发给你。
#14 2018-11-05 14:14:47
dgtg
已发帖子: 276
晕哥,是不是可以直接将eDragonEx200 rename成eDragonEx220 ?
楼主 #15 2018-11-05 14:25:42
我就是这么测试的,到最后仍然打包失败。
#16 2018-11-05 14:58:18
lcfmax
已发帖子: 330
应该是少了"eStudio" 这个目录,这个应该有一些图片编译,打包的工具在里面
#17 2018-11-05 16:11:33
强烈关注,放视频,识别成U盘这两个功能很有用
楼主 #18 2018-11-05 16:22:55
如果真的可以用 MDK 链接, 直接把 lib 和 include 加到 xboot 工程,应该可以直接跑的.
但是以前加到 MDK 工程链接出错, 不知道怎么回事。
#19 2018-11-05 17:40:29
dgtg
已发帖子: 276
晕哥,今天在Q群有人把c100s的TV in功能在meils上搞定了,放了一张照片出来,还说效果不错...
可惜问对方都不回复...
楼主 #20 2018-11-05 19:48:45
可惜问对方都不回复...
我跟他聊了, 他不是专门搞技术的,所以有可能回答不了你的问题。
他们做倒车影像的,这个芯片确实挺适合的,连视频ADC采集芯片都免了。
#21 2018-11-05 20:15:15
可惜问对方都不回复...
用在车子上都可以,这芯片抗干扰这么牛
#22 2018-11-05 20:21:40
沉鱼
已发帖子: 161
达克罗德 wrote:
用在车子上都可以,这芯片抗干扰这么牛
这种不影响行车安全的电子产品, 估计怎么省钱怎么来了吧?
#23 2018-11-05 21:09:52
用在车子上都可以,这芯片抗干扰这么牛
这种后装设备应该也不至于一点要求没有
#24 2018-11-05 21:45:26
cityf
已发帖子: 195
达克罗德 wrote:
这种后装设备应该也不至于一点要求没有
还真是没什么要求的,五年前我朋友帮人做过一个小车插CAN调试口的小玩意,比如车速超过30码can bus通知中控锁车.
这玩意什么认证都没有, 在4s照样卖得很好,
记得有一次调试,把行车电脑都搞死了,只能熄火扒蓄电池重启。
#25 2018-11-05 23:44:59
tanphy
晕哥,用MDK编译的melis可以脱离linux裸机跑吗
楼主 #26 2018-11-06 08:05:55
对,melis和linux已经没有半毛钱关系了。
melis用realview或者mdk编译.
#27 2018-11-07 09:54:46
dgtg
已发帖子: 276
找到以前的帖子,https://whycan.cn/t_1603.html
哈哈,A20的代码里面有TV decoder:
https://github.com/naggety/sunxi-tv-decoder ,看来可以搞一搞了
楼主 #28 2018-11-07 09:56:21
melis 应该是已经驱动了 tv
楼主 #29 2018-11-07 09:59:57
#30 2019-01-06 13:08:45
Ken
已发帖子: 59
晕哥,这个有新的进展吗?
#31 2019-01-31 09:11:29
mianhua
坐等更新:D
#32 2019-02-18 17:13:31
九霄云外
已发帖子: 100
好像不能发贴还是不知道怎么发,借这个主题发个信息打个硬广:
1、melis有问题原厂现在基本只支持代理了,而且已经很成熟稳定的产品原厂基本不需要投入了,熟悉melis的原厂基本不超过5个人,一半以上还转linux和管理了
2、对代理商开放的源码也是很有限的,必然造成代理技术有限,有问题时一是不清楚,二是没量有时就是不想鸟你,三代理也是人少也要做方案做项目啊,问题反馈不及时也是必然的
3、你们说的编译环境的搭建啥的,AVIN 、U盘\SD卡\硬盘播放音视频(几乎是全格式的等)、图片、AVIN\CSI录像、定格这些、甚至带XR819的网络播放功能我们都是有的相关的产品
4、做产品方案的兄弟们,我就想问下,如果我给你们提供技术支持和SDK、适当收取个3 5K的出货保证金,IC价格也就市场价,有人要找我吗,还是打算骂我呢?创业不易、生活不易,说实话,不是黑,全志官方的MELIS SDK给到你做产品,能把你气出翔来!
5、只是单纯搞技术做开源的兄弟,如果你真的有兴趣,有关于系统或IC方面的问题,可以@下我,技术不说啥样,资料齐全、走过的坑无数这方面还是有点点料的
6、在论坛里看到无数的牛人,基本啥资料都没有,还是搞出了不少很多NB的事,实在是佩服;可说实话,很多东西离真正的产品还是有点远。真实的案例是有不少我自己的客户,他们在自己的领域无人能及,可因为全志系统的封闭,资源少,本来一两个月能搞好的产品,搞了一年半载啥都没结果的真的不在少数;合作才能共赢
7、最后想说一点自己对melis的看法,其实就是ucos的核修改过来的内核+类linux的驱动架构+miniGUI/orangeGUI+全志自己的音视频播放编解码中间件cedar
#33 2019-02-18 17:35:02
@九霄云外 如何收费?
#34 2019-02-18 19:39:37
melis有对应gcc的版本吗?
楼主 #35 2019-02-18 20:17:37
达克罗德 wrote:
melis有对应gcc的版本吗?
应该没有, 而且官方的文档是用 RealView 编译的 (发展顺序是: ADS ==> RealView ==> MDK)
所以那些 lib 不太可能会去支持 gcc
#36 2019-02-19 09:36:16
九霄云外
已发帖子: 100
有支持gcc的SDK的,那是全志新改的基于RTOS内核的SDK,但没推起来,
原因是基于UCOS的SDK已经稳定量产,再推RTOS内核的在代理商和方案商层面推不动。
所以后面F1C100S就不推基于RTOS的GCC SDK环境了
#37 2019-02-19 09:43:03
九霄云外
已发帖子: 100
smartcar wrote:
@九霄云外 如何收费?
收费不收费不是主要的,重要的是想找能长期稳定的客户合作
#38 2019-02-19 09:52:40
jimmy
已发帖子: 316
看起来大神以前在全志内部干过的了
#39 2019-02-19 11:02:31
jlau
已发帖子: 217
说要一统IOT的melis 3.0呢?不是基于RTThread和Zephyr的吗?没戏了吗?
#40 2019-02-19 11:41:21
九霄云外
已发帖子: 100
目前来看是melis 3.0在100s上是没戏了,成熟的2.0在量产的客户那里肯定推不动,
所以注意3.0只能在新客户里面推,那就意味着没量,没量原厂还推?
#41 2019-02-19 11:52:08
jlau
已发帖子: 217
我们是新客户,我们有量,我们更熟悉linux环境,但是被代理商吓唬说3.0有很多还没解决的bug,他们不愿意问全志拿,然后被迫用回他们手上的2.0了。而且代理商对这个melis的支持水平差到啊,比全志A系列的支持还差。吐吐吐 mad
#42 2019-02-19 12:03:44
pypzx
话说,新客户可以找你推进么?
#43 2019-02-19 13:53:17
九霄云外
已发帖子: 100
这个怎么说呢,也不能说代理商吓唬你,BUG确实不少,主要集中在视频兼容性这块;
以前2.0没有问题的视频或已经解决的问题,3.0就又回来了或出现了,你说这个让代理商和方案商怎么跟终端客户交待呢?
另外,如果觉得代理支持不行,你找我哈
#44 2019-02-19 14:09:05
九霄云外
已发帖子: 100
pypzx wrote:
话说,新客户可以找你推进么?
这个不是说不行,只是涉及到音视频兼容这块除了确实只能找原厂,
而原厂对100S推3.0的态度已经发生了根本性的变化,而且已经有了定论,这事挺麻烦
#45 2019-02-19 15:05:21
jlau
已发帖子: 217
另外,如果觉得代理支持不行,你找我哈
视频兼容性指什么,视频硬件编解码模块?
全志对3.0的定论是啥?不继续了吗?
最近编辑记录 jlau (2019-02-19 15:06:31)
#46 2019-02-19 15:11:46
山无棱
已发帖子: 116
这么说melis是基于ucos?
#47 2019-02-19 15:18:28
九霄云外
已发帖子: 100
jlau wrote:
视频兼容性指什么,视频硬件编解码模块?
全志对3.0的定论是啥?不继续了吗?
f1c100s不再推3.0了,也没支持了。 3.0在新IC上推,如芯片C800,价格20几块,没什么优势
视频兼容性就是一堆视频中,突然有一个或一些视频不能播放、但竞争对手的可以,以前2.0的也可以
这东西就像新产品出来了,功能都有了,但没经过市场的验证,出大量的代理商也不想冒风险在原有稳定的基础上再去弄这么个不熟悉的SDK
那小的方案商还要支持啊,僵持呗。最后肯定还是出货量大的有话语权吧
#48 2019-02-19 15:21:53
九霄云外
已发帖子: 100
山无棱 wrote:
这么说melis是基于ucos?
官方说的是melis,懂的人会懂,不做评论,我说了不算
#49 2019-02-19 15:26:10
jlau
已发帖子: 217
我们只要jpeg编解码,哈哈哈。
IOT产品有几何需要那么多视频解码,奇了怪了。
这些bug的解决只是时间问题,全志不愿意投入资源也不愿开放出来,只能是死局。
最近编辑记录 jlau (2019-02-19 15:28:39)
#50 2019-02-19 15:35:13
九霄云外
已发帖子: 100
jlau wrote:
我们只要jpeg编解码,哈哈哈。
然而它还活着
#51 2019-02-19 15:46:15
九霄云外
已发帖子: 100
jlau wrote:
我们只要jpeg编解码,哈哈哈。
而且你也不想想,全志主要靠这个IC赚钱吗?这是全志最低端的IC
这个IC从14年出来卖了多少年?现在每个月还有接近1KK的量, 除了IC出来前期投入大些,现在还在投入几个人?
跟你说可能你不信,你用一个拳头都数得过来,还嫌多了
#52 2019-02-19 15:54:25
山无棱
已发帖子: 116
确实,这个f1c100s确实性价比超级高,
外设齐全价格适中,封装够亲民。
在有些场合真是可以秒杀各种台产或国外MCU
#53 2019-02-19 16:25:55
九霄云外
已发帖子: 100
而且,这个IC面对的市场本身就不是全志特很重视的,后期投入1个是1KK,投入10个人能变成10KK?
不会的,顶多就从1KK变成1.1KK,那还投那么多人干嘛呢,没别的事情做了吗?
前段时间荔枝派为什么会被全志发律师函?
荔枝派的一些关于这个IC的资料为什么下架了?
全志真希望做开源吗?
再看看全志的客户,有小米、有阿里、有格力……
这个IC对全志来说算个P啊,哪一天全志把它砍了,好嗨哟~
#54 2019-02-19 17:08:11
九霄云外
已发帖子: 100
我就是这么测试的,到最后仍然打包失败。
你这个打包问题解决了吗?
你这只是缺了几个打包用到的工具,问题不大,没有加我QQ我可以发给你
#55 2019-02-19 21:08:50
gdfsli
已发帖子: 28
打包工具能否发到Q群共享?
#56 2019-02-21 09:35:48
九霄云外
已发帖子: 100
圈子真小,这里遇到不少老朋友
#57 2019-02-22 13:53:12
siwen
我们公司想要开发一款C800方案的产品,由于是初次接触全志方案,不知道能否提供成熟的技术支持。联系方式:QQ723763648
#58 2019-02-27 17:31:00
yuxs204
九霄云外 wrote:
然而它还活着
我想要用F1C100S做一个产品,就是解码海思H264的视频流,不知道这个IC支持不。请教一下!
#59 2019-02-27 17:38:54
mfkiwl
已发帖子: 53
关注晕哥好久了,今天特意注册一个账号
#60 2019-02-27 19:43:43
九霄云外
已发帖子: 100
支持H264的,但1080P只是部分支持,高碼率可能内存和带宽会不够
#61 2019-02-28 22:26:34
wubingqing
九霄云外 在?
#62 2019-02-28 22:35:48
wubingqing
晕哥 可以把estudio 文件 发给我
#63 2019-03-01 09:34:07
wubingqing
晕哥 早上好
楼主 #64 2019-03-01 09:58:55
你加 @九霄云外 的qq吧,记得有单也找他
#65 2019-03-01 10:25:32
九霄云外
已发帖子: 100
eStudio,网站有限制文件20M,所以上传到网盘了
链接:https://pan.baidu.com/s/119oF-7wD3ui-ZInCrNNTpA
提取码:bwkr
复制这段内容后打开百度网盘手机App,操作更方便哦
#66 2019-03-01 10:42:17
wubingqing
九霄云外 谢谢!
楼主 #67 2019-03-01 11:12:01
提取码:bwkr
谢谢 @九霄云外
压成7z, 缩小了30%, 直接本站下载: eStudio.7z
#68 2019-03-01 13:19:42
www220
已发帖子: 46
高手就是高手,看来拿全志的fc100和v3s这类芯片做小东西的心可以死了,全志果然不是给小客户玩的
#69 2019-03-01 16:23:14
九霄云外
已发帖子: 100
melis还是挺适合人力少低投入的小公司的,软件一两个人就能做产品
#70 2019-03-04 11:52:28
yuxs204
第一次用全志的IC。
有没有做这个IC比较厉害的供应商提供。想要更进一步的评估。或者是您有支持就最好了
#71 2019-03-04 15:24:17
九霄云外
已发帖子: 100
yuxs204 wrote:
第一次用全志的IC。
加我Q:610943940
#72 2019-03-06 12:37:46
ippen
已发帖子: 345
九霄云外 wrote:
加我Q:610943940
能对linux系统的支持?
#73 2019-03-08 09:43:48
九霄云外
已发帖子: 100
ippen wrote:
能对linux系统的支持?
linux系统暂时没人投入
#74 2019-04-14 21:06:07
wzlxy
@九霄云外 就算你给了完整编译工具和system缺的那几个dll文件,源码里还是封装了很多东西的,能做的应用程序还是很有限的。。
楼主 #75 2019-04-14 21:08:31
就是酱紫的, melis 提供的都是库, 据说(小道消息)后面会提供源码版本.
#76 2019-07-10 09:20:31
hzpyl
已发帖子: 80
F1C100S,爱你不容易啊。
请问,带视频的,用什么开发? RT-Thread 还是 Melis ?
#77 2019-07-10 15:36:02
hzpyl wrote:
F1C100S,爱你不容易啊。
加油 ,共勉,搞定F1C200S
#78 2019-07-13 14:38:52
zdl229892205
@九霄云外 请问melis支持从SD卡启动不?
#79 2019-07-22 00:50:39
萧哥
Q上发信息给我, 我发给你。
我也想要sdk,是否可以发来呢
#80 2019-09-10 09:52:31
古城砖头
/files/members/3/20181103145947.png
编译完成
但是缺少可执行文件,导致打包不能进行。
晕哥,这个编译错误的问题,刚好我前几天在编译一个Melis的例子工程时也碰到" LangOSBuilder.exe:命令未找到"的编译错误,后来发现是 includes/cfgs/CROSSTOOL.CFG文件中的一个定义不对, 将这个文件打开后,把其中的ESUDIOROOT = $(SDKROOT)/../eStudio修改为ESUDIOROOT = $(SDKROOT)/eStudio即可,这个编译错误就没了。
再一个,请问下,本帖子中你编译的这个 MELIS100A.7z从哪里下载呢?
楼主 #81 2019-09-10 11:23:32
MELIS100A.7z 在 QQ群 516836432 附件下载
#82 2019-09-12 08:34:20
古城砖头
谢谢了!还没加入QQ群,一会加入看看。:)=)
#83 2019-09-13 15:09:18
风无欲
晕哥,是不是Melis已经支持f1c100的vidio IN ,如果能将melis编译通过,烧入荔枝nano中,就能开发类似倒车影像的系统了?现在问题卡在哪了呢?
楼主 #84 2019-09-13 16:08:19
其实全志其他soc的tv驱动早有了, 估计只要稍微调一下即可: https://whycan.cn/t_1603.html#p8843
#85 2019-12-12 23:19:34
Biftor
已发帖子: 34
Hi brother, i have downloaded the MELIS100A.7z .
I don't know this is correct or not.
I did exactly what you said in first posts, but there is error in beginning.
can i share you the MELIS100A.7z to check?
or do you mind to send the Melis sdk that you have to me.
as what i see here i can't share it here, and also i dont have QQ and i cant make it.
can you contact me with Telegram? @Biftor
I really need to run this device
thanks
最近编辑记录 Biftor (2019-12-12 23:20:18)
#86 2019-12-14 04:56:59
Biftor
已发帖子: 34
我几乎完成了此操作,但我陷入了这个错误。
有人知道吗?
I have almost done it, but i am stuck on this error.
is there anybody know?
make image begin...
argc = 2
input name ..\eFex\sys_config.fex
Script 1 source file Path=F:\melis\melis2\workspace\suniv\phoenix\..\eFex\sys_config.fex
Script 1 bin file Path=F:\melis\melis2\workspace\suniv\phoenix\..\eFex\sys_config.bin
parser 1 file ok
        1 file(s) copied.
        1 file(s) copied.
argc = 2
input name part_config.fex
Script 1 source file Path=F:\melis\melis2\workspace\suniv\phoenix\part_config.fex
Script 1 bin file Path=F:\melis\melis2\workspace\suniv\phoenix\part_config.bin
parser 1 file ok
..\..\..\..\eStudio\Softwares\eDragonEx200\compile: image.cfg:1: unexpected symbol near ';'
make image finished...
Press any key to continue . . .
#87 2019-12-14 06:18:09
Ken
已发帖子: 59
@Biftor, that's it. Although there is the error of "unexpected symbol near ';'", the image file (ePDKv100.img) should has already been created under the folder of "Melis100A\workspace\suniv\beetles".
#88 2019-12-14 08:14:28
nuvoton
已发帖子: 59
估计打包脚本没写好, 不管前面有没有错误, 都会显示 "make image finished..."
这种情况只能跟踪脚本了。
#89 2019-12-14 16:49:21
Biftor
已发帖子: 34
thanks.
but when i flash the image result (PHOENIXv100.img) to sdcard with PhoenixCard there is nothing
serial log
BOOT0 is starting
init dram , base        is 0x80000000
init dram , clk         is 120
init dram , access_mode is 1
init dram , cs_num      is 1
init dram , ddr8_remap  is 0
init dram , sdr_ddr     is 1
init dram , bwidth      is 16
init dram , col_width   is 10
init dram , row_width   is 13
init dram , bank_size   is 4
init dram , cas         is 3
init dram , size        is 0
dram init successed,size is 32
succeed in loading BOOT1
jump to BOOT1
begin to init file system
card_no = 0,line_sel = 4, bootcard_offset =40960
0
jump to kernal
port=4,port_num=1,mul_sel=6 eint_num=1 trigger=2
Mount Parts Thread running.....
SDC 0 init...
SD card found
SDC 0 identified successfully
SDC 0 err, cmd 18,  SBE
SDC 0 err, cmd 18,  RTO
update new build log
BOOT0 is starting
jump to BOOT1
0
jump to kernal
SDC 0 init...
SD card found
partition [D] plug in..
Mount Parts Thread work now.....
partition [E] plug in..
Mount Parts Thread work end....
.Start Shell from partion 'c'...................................................
&&&addr=0x6969637765....
*****0x6969637765 data fail....
&&&&&&&&&&&&0x6972 addr error&&&&&&&&&&
最近编辑记录 Biftor (2019-12-14 17:18:42)
#90 2019-12-14 16:52:21
firstman
已发帖子: 279
感觉是卡和boot不兼容的问题, sd卡初始化错误了,先换张卡试一试。
#91 2019-12-14 17:19:58
Biftor
已发帖子: 34
I tried other sdcards but the result was same.
I made new build and now the log is :
BOOT0 is starting
jump to BOOT1
0
jump to kernal
SDC 0 init...
SD card found
#92 2019-12-14 17:28:27
jimmy
已发帖子: 316
看起来跑起来了啊,鼓掌!
有没有一步一步的教程,我也跟着学习一下。
#93 2019-12-14 17:54:41
Biftor
已发帖子: 34
jimmy wrote:
看起来跑起来了啊,鼓掌!
is it okay?
if yes then, how to config lcd?
最近编辑记录 Biftor (2019-12-14 17:57:06)
#94 2019-12-14 18:06:06
jimmy
已发帖子: 316
Biftor wrote:
is it okay?
看起来启动了,我没有玩过melis,不知道如何修改。
#95 2019-12-15 00:22:53
九霄云外
已发帖子: 100
see drv_display -> lcd_panel_cfg.c -> LCD_cfg_panel_info()
#96 2019-12-18 18:42:42
feysan
实践证明,mdk编译失败的原因是eStudio文件夹没有放到sdk目录下导致的,哈哈
#97 2019-12-27 15:21:01
staunchheart
已发帖子: 232
我的产没有生成ePDKv100.img,提示如下
make image begin......
.\..\eFex\sys_version.fex
.\..\eFex\sys_config.fex
已复制         1 个文件。
已复制         1 个文件。
                      update.bat
argc = 2
input name .\..\eFex\sys_config.fex
Script 1 source file Path=J:\wsl\f1c100s\melis\MELIS100A\workspace\suniv\beetles\.\..\eFex\sys_config.fex
Script 1 bin file Path=J:\wsl\f1c100s\melis\MELIS100A\workspace\suniv\beetles\.\..\eFex\sys_config.bin
parser 1 file ok
argc = 2
input name .\..\eFex\sys_partition.fex
Script 1 source file Path=J:\wsl\f1c100s\melis\MELIS100A\workspace\suniv\beetles\.\..\eFex\sys_partition.fex
Script 1 bin file Path=J:\wsl\f1c100s\melis\MELIS100A\workspace\suniv\beetles\.\..\eFex\sys_partition.bin
parser 1 file ok
argc = 2
input name .\rootfs\app_config.fex
Script 1 source file Path=J:\wsl\f1c100s\melis\MELIS100A\workspace\suniv\beetles\.\rootfs\app_config.fex
Script 1 bin file Path=J:\wsl\f1c100s\melis\MELIS100A\workspace\suniv\beetles\.\rootfs\app_config.bin
parser 1 file ok
                      update boot0\boot1
已复制         1 个文件。
已复制         1 个文件。
                      update fes1 uboot
make minfs image file [J:\wsl\f1c100s\melis\MELIS100A\workspace\suniv\beetles\.\\rootfs\\ramdisk.iso] succeeded
image config size  : [  131072]
image used   size  : [  109888]
DEntry count       : [      17]
DEntry length      : [    2176]
FData  length      : [  106816]
make minfs image file [J:\wsl\f1c100s\melis\MELIS100A\workspace\suniv\beetles\rootfs.iso] succeeded
image config size  : [15360000]
image used   size  : [ 3832316]
DEntry count       : [     106]
DEntry length      : [   13720]
FData  length      : [ 3817980]
boot0.bin
boot1.bin
mbr.bin
rootfs.iso
udisk.iso
FileLengthx=15639552
..\..\..\..\eStudio\Softwares\eDragonEx220\compile: image.cfg:1: unexpected symbol near ';'
make image finished....
楼主 #98 2019-12-27 15:26:31
奇怪, @Biftor 怎么生成了 ePDKv100.img 呢 ? 是不是你打开的文件夹不对, 用 everything 搜一下。
#99 2019-12-27 16:30:26
staunchheart
已发帖子: 232
感谢Wind Rises,搞好了。
没有装MFC库放到windows/system下,一定要放到system下,不是system32
另外,也可以直接拷到eDragonEx220目录下。
MFC库在本站有
/files/members/1377/none_20190225-1007.rar
#100 2019-12-27 17:43:01
伍零壹
已发帖子: 161
已复制         1 个文件。
已复制         1 个文件。
                      update.bat
argc = 2
Script 1 source file Path=G:\MELIS100A\workspace\suniv\beetles\.\..\eFex\sys_config.fex
Script 1 bin file Path=G:\MELIS100A\workspace\suniv\beetles\.\..\eFex\sys_config.bin
parser 1 file ok
argc = 2
Script 1 source file Path=G:\MELIS100A\workspace\suniv\beetles\.\..\eFex\sys_partition.fex
Script 1 bin file Path=G:\MELIS100A\workspace\suniv\beetles\.\..\eFex\sys_partition.bin
parser 1 file ok
argc = 2
Script 1 source file Path=G:\MELIS100A\workspace\suniv\beetles\.\rootfs\app_config.fex
Script 1 bin file Path=G:\MELIS100A\workspace\suniv\beetles\.\rootfs\app_config.bin
parser 1 file ok
                      update boot0\boot1
boot0 file Path=G:\MELIS100A\workspace\suniv\beetles\Boot0.bin
script file Path=G:\MELIS100A\workspace\suniv\beetles\..\eFex\sys_config.bin
script update boot0 ok
boot1 file Path=G:\MELIS100A\workspace\suniv\beetles\Boot1.bin
length = 71168 Error Code = 0, No error
length=71168
boot: = eGON.BT1jn徊   magic = eGON.BT1
boot: = eGON.BT1髿伮   magic = eGON.BT1
mbr count = 4
partitation file Path=G:\MELIS100A\workspace\suniv\beetles\sys_partition.bin
mbr_name file Path=G:\MELIS100A\workspace\suniv\beetles\sunxi_mbr.fex
download_name file Path=G:\MELIS100A\workspace\suniv\beetles\dlinfo.fex
mbr size = 16
mbr magic softw411
main_key->main_name = mbr
main_key->main_name = partition_start
disk name=ROOTFS
disk name=SYSDATAFS
this is not a partition key
update_for_part_info 0
crc 0 = eb4ce7ad
crc 1 = 9958f9ff
crc 2 = f64db09
crc 3 = 7d70c55b
crc32_total= ae8f68d8
update mbr file ok
已复制         1 个文件。
已复制         1 个文件。
                      update fes1 uboot
fes1 file Path=G:\MELIS100A\workspace\suniv\beetles\fes1.fex
script update fes1 ok
uboot file Path=G:\MELIS100A\workspace\suniv\beetles\u-boot.fex
length = 193272 Error Code = 0, No error
length=193272
boot: = uboot   magic = uboot
source length = 193272  align_size = 16384
source_uboot_name=G:\MELIS100A\workspace\suniv\beetles\u-boot.fex total length = 196608
make minfs image file [G:\MELIS100A\workspace\suniv\beetles\.\\rootfs\\ramdisk.iso] succeeded
image config size  : [  106496]
image used   size  : [  102932]
DEntry count       : [      16]
DEntry length      : [    1888]
FData  length      : [  100372]
make minfs image file [G:\MELIS100A\workspace\suniv\beetles\rootfs.iso] succeeded
image config size  : [ 8109056]
image used   size  : [ 3785780]
DEntry length      : [   13528]
FData  length      : [ 3771444]
boot0.bin
boot1.bin
mbr.bin
rootfs.iso
udisk.iso
FileLengthx=8388608
请按任意键继续. . .
我和97楼的朋友出现相同的问题 make没有问题 打包没有生产ePAK100.img文件
请问97楼的朋友搞定这个了么
楼主 #101 2019-12-27 17:52:01
解决方案在99楼
#102 2019-12-27 17:56:27
伍零壹
已发帖子: 161
解决方案在99楼
收到,我发帖子的时候竟然没看到99楼!
#103 2019-12-27 18:09:22
伍零壹
已发帖子: 161
按照楼上的方法试了 还是不行。我再琢磨琢磨
#104 2019-12-27 19:37:48
wecandump
新人报道,过来学习,已有芯片,等待进坑
#105 2020-01-02 16:45:48
伍零壹
已发帖子: 161
解决方案在99楼
搞定了 是99的方法 自己挖了个坑
#106 2020-01-02 16:51:53
异乡是故乡
已发帖子: 74
伍零壹 wrote:
搞定了 是99的方法 自己挖了个坑
可以显示了吗?
#107 2020-01-02 17:06:11
伍零壹
已发帖子: 161
异乡是故乡 wrote:
可以显示了吗?
我没有接LCD 烧录和输出都可以了
#108 2020-01-02 17:07:17
异乡是故乡
已发帖子: 74
伍零壹 wrote:
我没有接LCD 烧录和输出都可以了
烧录到TF卡还是flash?
#109 2020-01-03 09:07:00
伍零壹
已发帖子: 161
异乡是故乡 wrote:
烧录到TF卡还是flash?
SPI Fflash TF卡我烧录失败
#110 2020-02-02 13:48:21
Sam
已发帖子: 55
@晕哥 新手一名,安装了cygwin64 编译meils,提示FIND:参数格式错误,求助晕哥
make -C elibs
make[1]: Entering directory `E:/linux/MELIS100A/elibs'
make -C libc
make[2]: Entering directory `E:/linux/MELIS100A/elibs/libc'
make -f makelib
FIND: 参数格式不正确
FIND: 参数格式不正确
FIND: 参数格式不正确
FIND: 参数格式不正确
FIND: 参数格式不正确
FIND: 参数格式不正确
FIND: 参数格式不正确
FIND: 参数格式不正确
make[3]: Entering directory `E:/linux/MELIS100A/elibs/libc'
"D:\Program Files\ARM\RVCT\Programs\4.0\400\win_32-pentium"/armar -r elibs.a  ./
mediainfo/GetAudio_format.a
chmod 777 elibs.a
rm ./../../libs/suniv/elibs.a
cp elibs.a ./../../libs/suniv/elibs.a
chmod 777 ./../../libs/suniv/elibs.a
make -C abilib
FIND: 参数格式不正确
FIND: 参数格式不正确
FIND: 参数格式不正确
FIND: 参数格式不正确
make[4]: Entering directory `E:/linux/MELIS100A/elibs/libc/abilib'
"D:\Program Files\ARM\RVCT\Programs\4.0\400\win_32-pentium"/armar -r aeabi.a
cp aeabi.a ./../../../libs/suniv/aeabi.a
cp: 无法获取'aeabi.a' 的文件状态(stat): No such file or directory
make[4]: *** [all] Error 1
make[4]: Leaving directory `E:/linux/MELIS100A/elibs/libc/abilib'
make[3]: *** [all] Error 2
make[3]: Leaving directory `E:/linux/MELIS100A/elibs/libc'
make[2]: *** [all] Error 2
make[2]: Leaving directory `E:/linux/MELIS100A/elibs/libc'
make[1]: *** [all] Error 2
make[1]: Leaving directory `E:/linux/MELIS100A/elibs'
make: *** [all] Error 2
楼主 #111 2020-02-02 14:49:14
貌似你的 cygwin64 find 命令和批处理里面的命令不兼容,
我的用的是git自带的msys shell和MDK编译的:
https://git-scm.com/download/win
https://download.tortoisegit.org/tgit/2.9.0.0/TortoiseGit-2.9.0.0-32bit.msi
https://download.tortoisegit.org/tgit/2.9.0.0/TortoiseGit-2.9.0.0-64bit.msi
#112 2020-02-02 16:28:56
Sam
已发帖子: 55
感谢@晕哥,删除了Cygwin 后重新安装了一边,make选择了一下版本,现在可以编译了。编译时间有些长,各种警告,但是没有错误。。。 成功后再总结 tongue
#113 2020-02-07 19:13:56
xidaole
已发帖子: 28
wind10 64bit
安装git, TortoiseGit 64bit
进入 MELIS100A 目录
bash here
make 后,
bash: make: command not found
不知道我是那里错了呢
#114 2020-03-10 08:43:50
xrff_z
已发帖子: 26
求助@晕哥
按照晕哥和九霄天外的帖子,用cygwin,mdk 成功编译和打包了。也正常刷入flash了,但启动后lcd没有画面,串口输出如下:
BOOT0 is starting
DBG: init jtag OK
dram init successed,size is 64
DBG: init heap OK, base address is 0x80000000, size is 0x00100000
DBG: load boot1 from spinor
DBG: init spinor OK
DBG: the size of BOOT1 is 71168
DBG: src_sum = 0x0xc7eb64fd
DBG: sum = 0x0xc7eb64fd
jump to BOOT1
DBG: boot1 starting!
DBG: init heap OK, base address is 0x80800000, size is 0x00100000
DBG: init block device OK
DBG: init mini file system OK
DBG: mount c partition OK
0
jump to kernal
然后就没有了。看了下晕哥的贴子里面的信息, jump to kernal后面应该是Mount Parts Thread running.....
用melis包里面的img和sam编译的img,会出现real的画面一段时间后自动黑屏,自己编译的不出现real画面。
对melis包里的文件,不编译只修改sys_config.fex修改串口后,也会出现real画面,串口出来的信息也是一样。
板子不是nano,是F1c500的,没有TF卡,没有按键,有触摸。 原来的固件可以正常启动的。
想请教下晕哥启动出了什么问题?
下载的melis的包里面,好多bmp文件电脑上都打不开,自己编译后没有显示与这个有关吗?
最近编辑记录 xrff_z (2020-03-10 09:22:24)
#115 2020-03-10 20:51:01
九霄云外
已发帖子: 100
SDK软硬件有限制的,不是melis的SDK在所有平台上都能跑,应用方向不同,SDK不同;
你用的C100A的SDK,那是100S早期的前身,不带DDR; 所以C500跑不起来是正常的,能跑起来才不正常
#116 2020-03-10 22:40:10
midnight
已发帖子: 26
也在上Keil MDK来build
#117 2020-03-11 07:59:30
xrff_z
已发帖子: 26
谢谢回复,明白了。
#118 2020-04-08 16:39:35
mcu1234mcu
我是meils小白,这个编译,打包,运行都成功后能在这个基础上做出自己个性的东西来吗?
#119 2020-04-08 17:24:07
当然可以,只是部分不开源而已,以lib形式提供。
#120 2020-04-09 08:54:35
mcu1234mcu
/files/members/3210/QQ%E5%9B%BE%E7%89%8720200409084704.png
晕哥我用MDK5编译了,结果提示可能是不完整的,这个编译结果对吗?
楼主 #121 2020-04-09 09:04:12
看有没有生成img文件,如果有一般就没问题。那个提示是文件时间不对的问题,可能那些lib显示成2024年什么的
#122 2020-04-09 09:42:35
mcu1234mcu
$ make image
make: *** 没有规则可制作目标“image”。 停止。
又碰到这个问题,是不是meils的包里缺少文件造成的?
#123 2020-04-09 11:19:11
mcu1234mcu
xidaole wrote:
wind10 64bit
进入 MELIS100A 目录
bash here
make 后,
不知道我是那里错了呢
cygwin没有装make的插件,删除重新安装选上make插键即可了
#124 2020-04-09 11:54:26
mcu1234mcu
mcu1234mcu wrote:
$ make image
请原谅我是小白,原来不是这么操作的,需要打开SDK->workspace->suniv->beetles,点击image.bat,我按照99楼的做了但是出现下面的问题
'wmic' 不是内部或外部命令,也不是可运行的程序
或批处理文件。
'findstr' 不是内部或外部命令,也不是可运行的程序
或批处理文件。
或批处理文件。
或批处理文件。
已复制 1 个文件。
已复制 1 个文件。
update.bat
'xcopy' 不是内部或外部命令,也不是可运行的程序
或批处理文件。
或批处理文件。
argc = 2
Script 1 source file Path=I:\meils\SDK\workspace\suniv\beetles\.\..\eFex\sys_config.fex
Script 1 bin file Path=I:\meils\SDK\workspace\suniv\beetles\.\..\eFex\sys_config.bin
parser 1 file ok
argc = 2
Script 1 source file Path=I:\meils\SDK\workspace\suniv\beetles\.\..\eFex\sys_partition.fex
Script 1 bin file Path=I:\meils\SDK\workspace\suniv\beetles\.\..\eFex\sys_partition.bin
parser 1 file ok
argc = 2
Script 1 source file Path=I:\meils\SDK\workspace\suniv\beetles\.\rootfs\app_config.fex
Script 1 bin file Path=I:\meils\SDK\workspace\suniv\beetles\.\rootfs\app_config.bin
parser 1 file ok
update boot0\boot1
已复制 1 个文件。
已复制 1 个文件。
update fes1 uboot
image file have no free space
load module file [I:\meils\SDK\workspace\suniv\beetles\ramfs\mod\slib.mod] failed
make image failed when file [I:\meils\SDK\workspace\suniv\beetles\ramfs\mod\slib.mod]
process diretory [I:\meils\SDK\workspace\suniv\beetles\ramfs\mod] failed
make image failed when directory [I:\meils\SDK\workspace\suniv\beetles\ramfs\mod]
make minfs image failed
make minfs image [I:\meils\SDK\workspace\suniv\beetles\.\\rootfs\\ramdisk.iso] failed
make minfs image file [I:\meils\SDK\workspace\suniv\beetles\rootfs.iso] succeeded
image used size : [ 3801136]
FData length : [ 3786800]
系统找不到指定的路径。
boot0.bin
boot1.bin
mbr.bin
rootfs.iso
系统找不到指定的文件。
处理: udisk.iso 时出错。
系统找不到指定的路径。
系统找不到指定的路径。
系统找不到指定的路径。
找不到 I:\meils\SDK\workspace\suniv\beetles\udisk.iso
请按任意键继续. . .
#125 2020-04-09 11:58:31
歌以咏志
已发帖子: 219
提示很明显了啊,wmic,findstr,xcopy这些命令都找不到,I:\meils\SDK\workspace\suniv\beetles\udisk.iso 这个文件也找不到
#126 2020-04-09 12:48:10
mcu1234mcu
对,这些命令在哪里可以找到呢?:rolleyes
#127 2020-04-09 16:05:54
路人甲
已发帖子: 202
wmic.exe | findstr.exe | xcopy.exe
这些是 Windows 内置命令
#128 2020-04-10 05:54:18
mcu1234mcu
路人甲 wrote:
/files/members/25/2020-04-09_160441.png
这些是 Windows 内置命令
是的,我发现我的windows下也有这些命令,但是打包的时候还是出现那样的提示,我用的windows10
#129 2020-04-10 08:55:44
xrff_z
已发帖子: 26
设置下系统path变量 增加C:\Windows\System32 试试
#130 2020-04-10 09:01:16
歌以咏志
已发帖子: 219
你用 cygwin shell ? 有可能你的 shell有问题,建议用晕哥一楼用的 git 自带的shell
#131 2020-06-03 11:30:16
mwin
已发帖子: 30
这个错误后面是安装 eDragonEx220 .解决吗?
我现在也出现这个错误但我加了 eDragonEx220.也出现如你的这个问题.
#132 2020-07-07 15:42:16
Bill123
已发帖子: 0
加油 ,共勉,搞定F1C200S
#133 2020-07-09 14:56:24
39035605
入坑来试试。。
#134 2020-07-09 17:29:58
mwin
已发帖子: 30
Bill123 wrote:
加油 ,共勉,搞定F1C200S
有显示了吗?还是只是串口可以收发数据?用的是那一个的包.
#135 2020-07-19 23:52:59
xiaoerge
学习一下,做个标记先,准备玩玩F1C200S
#136 2020-07-25 22:57:33
tianyingkeji
所在地: beijing
melis tv out又玩起来的没,求配置流程
#137 2020-07-27 10:59:00
Delei
每月都要过来看看,最新进展,看来真的要学Linux了
#138 2020-10-14 23:29:21
tcy641
按照文中的教程做了一遍发现编译出现如下错误:
img=
#139 2020-10-15 11:52:04
xrff_z
已发帖子: 26
试试 在livedesk\beetles目录下编译
#140 2020-10-16 10:55:55
沉成林
另外,如果觉得代理支持不行,你找我哈
大佬,C800方案接不?
#141 2020-10-16 12:03:48
gverhw
厉害,有空多学习学习
#142 2021-08-24 04:29:47
hoel
已发帖子: 96
Q上发信息给我, 我发给你。
您好,能否请您分享 MDK 项目,我有兴趣尝试使用 MELIS 和 MDK 播放视频
#143 2021-08-24 22:31:53
kanemsn
  • 不通过:与技术无关
#144 2021-09-13 16:38:27
大明明哥
已发帖子: 19
  • 不通过:与技术无关
#145 2022-02-05 23:30:55
sniper33
已发帖子: 19
编译发现确实estudio文件,源码根本就没有,不知道帖子里的这个是不是
#146 2022-02-06 23:09:39
sniper33
已发帖子: 19
eStudio是对了,最后一步打包还是得在论坛找答案,melis的资料太少了
#147 2022-02-19 11:57:28
chan
已发帖子: 29
  • 不通过:其他
#148 2022-02-19 13:51:56
bigbat
已发帖子: 71
全志这个f1c100s的芯片,就是把新塘的给打的够呛,不过听说新塘出了个a35的核产品,新塘的nuc792一颗30几块,都不赚钱不知道全志的10几块是怎么来的。
#149 2022-04-26 18:34:45
aozima
已发帖子: 489
看做屏的喜欢用全志的多,做控制的用新塘的多。
#150 2022-07-19 08:55:19
青木城池
这是啥情况啊?
\0partition [D] plug in..
\0Mount Parts Thread work now.....
\0.Start Shell from partion 'c'..................................................................................
\0Mount Parts Thread work end....
\0&&&addr=0x6969637765....
\0*0x6969637765 data fail....
\0&&&&&&&&&&&&0x6972 addr error&&&&&&&&&&
#152 2024-12-03 10:58:10
memory
已发帖子: 725
F1C100s / F1C200s melis 固件修改工具: ImageModify_20190225.rar
#153 2024-12-06 20:09:39
memory
已发帖子: 725
这样修改调试串口改到 UART2 (PE7,PE8)
F1C200S_Melis_V1.7_mdk\melis2.0-sdk-release\workspace\suniv\eFex\sys_config.fex
[uart_para]
uart_debug_port = 2
uart_debug_tx   = port:PE7<3>
uart_debug_rx   = port:PE8<3>
#154 2025-02-10 16:28:30
fubaojun2006
@九霄云外
又是几年过去了,说的很中肯实在。而且还是在疫情前说的。
