我参考的是 @晕哥的打包脚本: 分享全志主线u-boot/linux 打包 TF/SD/SDNAND 镜像脚本
本站下载打包脚本和二进制文件: x3pack_20200511.tgz
这是经过pack.sh打包后的TF卡镜像文件: x3-smallwit-card-taurus.7z
pack.sh 脚本:
#!/bin/bash
_UBOOT_SIZE=1
###第一个分区(FAT)大小,单位MiB##
_P1_SIZE=16
###TF卡镜像文件名称###
_IMG_FILE='x3-smallwit-card-taurus.img'
###TF卡镜像文件大小, 单位MiB###
_IMG_SIZE=120
temp_root_dir=$PWD
_UBOOT_FILE="${temp_root_dir}/data/u-boot-sunxi-with-spl.bin"
_SPLASH_BMP_FILE="${temp_root_dir}/data/splash.bmp"
_BOOT_SCR_FILE="${temp_root_dir}/data/boot.scr"
_KERNEL_IMAGE_FILE="${temp_root_dir}/data/zImage"
_DTB_FILE="${temp_root_dir}/data/sun8i-x3-smallwit-card-taurus.dtb"
_ROOTFS_TGZ_FILE="${temp_root_dir}/data/rootfs.tar"
###初始化镜像文件###
dd if=/dev/zero of=$_IMG_FILE bs=1M count=$_IMG_SIZE
###判断镜像文件是否初始化成功###
if [ $? -ne 0 ]
then
echo "getting error in creating dd img!"
exit
fi
###获取一个循环设备###
_LOOP_DEV=$(sudo losetup -f)
#echo ${_LOOP_DEV}
##再次判断此设备是否存在###
if [ -z $_LOOP_DEV ]
then
echo "can not find a loop device!"
exit
fi
###把镜像文件和循环设备关联###
sudo losetup $_LOOP_DEV $_IMG_FILE
if [ $? -ne 0 ]
then
echo "dd img --> $_LOOP_DEV error!"
sudo losetup -d $_LOOP_DEV >/dev/null 2>&1 && exit
fi
echo "--->creating partitions for tf image ..."
#blockdev --rereadpt $_LOOP_DEV >/dev/null 2>&1
# size only can be integer
###分区###
cat <<EOT |sudo sfdisk ${_IMG_FILE}
${_UBOOT_SIZE}M,${_P1_SIZE}M,c
,,L
EOT
###格式化###
sleep 2
sudo partx -u $_LOOP_DEV
sudo mkfs.vfat ${_LOOP_DEV}p1 ||exit
sudo mkfs.ext4 ${_LOOP_DEV}p2 ||exit
if [ $? -ne 0 ]
then
echo "error in creating partitions"
#sudo partprobe $_LOOP_DEV >/dev/null 2>&1 && exit
fi
###u-boot写到TF卡8K偏移处###
#pack uboot
echo "--->writing u-boot-sunxi-with-spl to $_LOOP_DEV"
# sudo dd if=/dev/zero of=$_LOOP_DEV bs=1K seek=1 count=1023 # clear except mbr
sudo dd if=$_UBOOT_FILE of=$_LOOP_DEV bs=1024 seek=8
if [ $? -ne 0 ]
then
echo "writing u-boot error!"
fi
###新建 p1,p2 目录,并挂载TF卡两个分区###
sudo sync
mkdir -p ${temp_root_dir}/output/p1 >/dev/null 2>&1
mkdir -p ${temp_root_dir}/output/p2 > /dev/null 2>&1
sudo mount ${_LOOP_DEV}p1 ${temp_root_dir}/output/p1
sudo mount ${_LOOP_DEV}p2 ${temp_root_dir}/output/p2
echo "--->copy boot and rootfs files..."
sudo rm -rf ${temp_root_dir}/output/p1/* && sudo rm -rf ${temp_root_dir}/output/p2/*
###复制zImage, dtb, boot.scr, splash.bmp 等文件到第一分区 ###
sudo cp ${_KERNEL_IMAGE_FILE} ${temp_root_dir}/output/p1/zImage &&\
sudo cp ${_DTB_FILE} ${temp_root_dir}/output/p1/ &&\
sudo cp ${_BOOT_SCR_FILE} ${temp_root_dir}/output/p1/ &&\
sudo cp ${_SPLASH_BMP_FILE} ${temp_root_dir}/output/p1/ &&\
echo "--->p1 done~"
###解压 rootfs.tgz 到第二分区###
sudo tar xvf ${_ROOTFS_TGZ_FILE} -C ${temp_root_dir}/output/p2/ &&\
echo "--->p2 done~"
###同步, 等待, 卸载, 退出###
sudo sync
sleep 2
sudo umount ${temp_root_dir}/output/p1 ${temp_root_dir}/output/p2 && sudo losetup -d $_LOOP_DEV
if [ $? -ne 0 ]
then
echo "umount or losetup -d error!!"
exit
fi离线
对了, 这个 pack.sh 脚本不能在 ubuntu 14.04 运行, 可以在 ubuntu 18.04 运行, 其他版本未测.
文件系统用的是 @晕哥 荔枝派Zero V3s开发板入坑记录 (TF/SD卡启动)(主线Linux,主线u-boot)的 这是我编译好的uboot, linux&dtb, rootfs: V3s_TFCard.7z
学习了,感谢感谢
谢谢分享,下来试一下看看呢
请教楼主,这个支持荔枝派吗?为什么我使用你的镜像文件烧录后在荔枝派zero上启动没有任何反应呀~
镜像文件不支持荔枝派。
嗯,谢谢指导!
楼主这个一键打包脚本太好用了,我以前都是从TF卡读回生成镜像文件, 现在想想真是太笨了。
