buildroot-2019.08 配置文件:
# Buildroot 2019.08 Configuration
BR2_HAVE_DOT_CONFIG=y
BR2_HOST_GCC_AT_LEAST_4_5=y
BR2_HOST_GCC_AT_LEAST_4_6=y
BR2_HOST_GCC_AT_LEAST_4_7=y
BR2_HOST_GCC_AT_LEAST_4_8=y
BR2_HOST_GCC_AT_LEAST_4_9=y
BR2_HOST_GCC_AT_LEAST_5=y
BR2_HOST_GCC_AT_LEAST_6=y
BR2_HOST_GCC_AT_LEAST_7=y
# Target options
BR2_SOFT_FLOAT=y
BR2_ARCH_HAS_MMU_OPTIONAL=y
# BR2_arcle is not set
# BR2_arceb is not set
BR2_arm=y
# BR2_armeb is not set
# BR2_aarch64 is not set
# BR2_aarch64_be is not set
# BR2_csky is not set
# BR2_i386 is not set
# BR2_m68k is not set
# BR2_microblazeel is not set
# BR2_microblazebe is not set
# BR2_mips is not set
# BR2_mipsel is not set
# BR2_mips64 is not set
# BR2_mips64el is not set
# BR2_nds32 is not set
# BR2_nios2 is not set
# BR2_or1k is not set
# BR2_powerpc is not set
# BR2_powerpc64 is not set
# BR2_powerpc64le is not set
# BR2_riscv is not set
# BR2_sh is not set
# BR2_sparc is not set
# BR2_sparc64 is not set
# BR2_x86_64 is not set
# BR2_xtensa is not set
BR2_ARCH_HAS_TOOLCHAIN_BUILDROOT=y
BR2_ARCH="arm"
BR2_ENDIAN="LITTLE"
BR2_GCC_TARGET_ABI="aapcs-linux"
BR2_GCC_TARGET_CPU="arm926ej-s"
BR2_GCC_TARGET_FLOAT_ABI="soft"
BR2_GCC_TARGET_MODE="arm"
BR2_BINFMT_SUPPORTS_SHARED=y
BR2_READELF_ARCH_NAME="ARM"
BR2_BINFMT_ELF=y
BR2_ARM_CPU_MAYBE_HAS_FPU=y
BR2_ARM_CPU_MAYBE_HAS_VFPV2=y
BR2_ARM_CPU_HAS_ARM=y
BR2_ARM_CPU_HAS_THUMB=y
BR2_ARM_CPU_ARMV5=y
# armv4 cores
# BR2_arm920t is not set
# BR2_arm922t is not set
# BR2_fa526 is not set
# BR2_strongarm is not set
# armv5 cores
BR2_arm926t=y
# BR2_iwmmxt is not set
# BR2_xscale is not set
# armv6 cores
# BR2_arm1136j_s is not set
# BR2_arm1136jf_s is not set
# BR2_arm1176jz_s is not set
# BR2_arm1176jzf_s is not set
# BR2_arm11mpcore is not set
# armv7a cores
# BR2_cortex_a5 is not set
# BR2_cortex_a7 is not set
# BR2_cortex_a8 is not set
# BR2_cortex_a9 is not set
# BR2_cortex_a12 is not set
# BR2_cortex_a15 is not set
# BR2_cortex_a15_a7 is not set
# BR2_cortex_a17 is not set
# BR2_cortex_a17_a7 is not set
# BR2_pj4 is not set
# armv7m cores
# BR2_cortex_m3 is not set
# BR2_cortex_m4 is not set
# BR2_cortex_m7 is not set
# armv8 cores
# BR2_cortex_a32 is not set
# BR2_cortex_a35 is not set
# BR2_cortex_a53 is not set
# BR2_cortex_a57 is not set
# BR2_cortex_a57_a53 is not set
# BR2_cortex_a72 is not set
# BR2_cortex_a72_a53 is not set
# BR2_cortex_a73 is not set
# BR2_cortex_a73_a35 is not set
# BR2_cortex_a73_a53 is not set
# BR2_exynos_m1 is not set
# BR2_xgene1 is not set
# armv8.1a cores
# armv8.2a cores
# BR2_cortex_a76 is not set
# BR2_cortex_a76_a55 is not set
# BR2_neoverse_n1 is not set
# armv8.4a cores
# BR2_ARM_ENABLE_VFP is not set
BR2_ARM_EABI=y
BR2_ARM_SOFT_FLOAT=y
BR2_ARM_INSTRUCTIONS_ARM=y
# BR2_ARM_INSTRUCTIONS_THUMB is not set
# Build options
# Commands
BR2_WGET="wget --passive-ftp -nd -t 3"
BR2_SVN="svn --non-interactive"
BR2_BZR="bzr"
BR2_GIT="git"
BR2_CVS="cvs"
BR2_LOCALFILES="cp"
BR2_SCP="scp"
BR2_HG="hg"
BR2_ZCAT="gzip -d -c"
BR2_BZCAT="bzcat"
BR2_XZCAT="xzcat"
BR2_LZCAT="lzip -d -c"
BR2_TAR_OPTIONS=""
BR2_DEFCONFIG="$(CONFIG_DIR)/defconfig"
BR2_DL_DIR="$(TOPDIR)/dl"
BR2_HOST_DIR="$(BASE_DIR)/host"
# Mirrors and Download locations
BR2_PRIMARY_SITE=""
BR2_BACKUP_SITE="http://sources.buildroot.net"
BR2_KERNEL_MIRROR="https://cdn.kernel.org/pub"
BR2_GNU_MIRROR="http://ftpmirror.gnu.org"
BR2_LUAROCKS_MIRROR="http://rocks.moonscript.org"
BR2_CPAN_MIRROR="http://cpan.metacpan.org"
BR2_JLEVEL=0
# BR2_CCACHE is not set
# BR2_ENABLE_DEBUG is not set
BR2_STRIP_strip=y
BR2_STRIP_EXCLUDE_FILES=""
BR2_STRIP_EXCLUDE_DIRS=""
# BR2_OPTIMIZE_0 is not set
# BR2_OPTIMIZE_1 is not set
# BR2_OPTIMIZE_2 is not set
# BR2_OPTIMIZE_3 is not set
# BR2_OPTIMIZE_G is not set
BR2_OPTIMIZE_S=y
# BR2_OPTIMIZE_FAST is not set
# BR2_GOOGLE_BREAKPAD_ENABLE is not set
# BR2_STATIC_LIBS is not set
BR2_SHARED_LIBS=y
# BR2_SHARED_STATIC_LIBS is not set
BR2_PACKAGE_OVERRIDE_FILE="$(CONFIG_DIR)/local.mk"
BR2_GLOBAL_PATCH_DIR=""
# Advanced
BR2_COMPILER_PARANOID_UNSAFE_PATH=y
# BR2_FORCE_HOST_BUILD is not set
# BR2_REPRODUCIBLE is not set
# Security Hardening Options
# BR2_PIC_PIE is not set
# Stack Smashing Protection needs a toolchain w/ SSP
BR2_RELRO_NONE=y
# BR2_RELRO_PARTIAL is not set
# BR2_RELRO_FULL is not set
# Fortify Source needs a glibc toolchain and optimization
# Toolchain
BR2_TOOLCHAIN=y
BR2_TOOLCHAIN_USES_UCLIBC=y
BR2_TOOLCHAIN_BUILDROOT=y
# BR2_TOOLCHAIN_EXTERNAL is not set
# Toolchain Buildroot Options
BR2_TOOLCHAIN_BUILDROOT_VENDOR="buildroot"
BR2_TOOLCHAIN_BUILDROOT_UCLIBC=y
# BR2_TOOLCHAIN_BUILDROOT_GLIBC is not set
# BR2_TOOLCHAIN_BUILDROOT_MUSL is not set
BR2_TOOLCHAIN_BUILDROOT_LIBC="uclibc"
# Kernel Header Options
# BR2_KERNEL_HEADERS_4_4 is not set
BR2_KERNEL_HEADERS_4_9=y
# BR2_KERNEL_HEADERS_4_14 is not set
# BR2_KERNEL_HEADERS_4_19 is not set
# BR2_KERNEL_HEADERS_5_1 is not set
# BR2_KERNEL_HEADERS_5_2 is not set
# BR2_KERNEL_HEADERS_VERSION is not set
# BR2_KERNEL_HEADERS_CUSTOM_TARBALL is not set
# BR2_KERNEL_HEADERS_CUSTOM_GIT is not set
BR2_DEFAULT_KERNEL_HEADERS="4.9.190"
BR2_PACKAGE_LINUX_HEADERS=y
# uClibc Options
BR2_PACKAGE_UCLIBC=y
BR2_UCLIBC_CONFIG="package/uclibc/uClibc-ng.config"
BR2_UCLIBC_CONFIG_FRAGMENT_FILES=""
BR2_TOOLCHAIN_BUILDROOT_WCHAR=y
# BR2_TOOLCHAIN_BUILDROOT_LOCALE is not set
BR2_PTHREADS_NATIVE=y
# BR2_PTHREADS is not set
# BR2_PTHREADS_NONE is not set
# BR2_PTHREAD_DEBUG is not set
# BR2_TOOLCHAIN_BUILDROOT_USE_SSP is not set
BR2_UCLIBC_INSTALL_UTILS=y
BR2_UCLIBC_TARGET_ARCH="arm"
# Binutils Options
BR2_PACKAGE_HOST_BINUTILS_SUPPORTS_CFI=y
# BR2_BINUTILS_VERSION_2_30_X is not set
BR2_BINUTILS_VERSION_2_31_X=y
# BR2_BINUTILS_VERSION_2_32_X is not set
BR2_BINUTILS_VERSION="2.31.1"
BR2_BINUTILS_EXTRA_CONFIG_OPTIONS=""
# GCC Options
# BR2_GCC_VERSION_5_X is not set
# BR2_GCC_VERSION_7_X is not set
BR2_GCC_VERSION_8_X=y
# BR2_GCC_VERSION_9_X is not set
BR2_GCC_VERSION="8.3.0"
BR2_EXTRA_GCC_CONFIG_OPTIONS=""
BR2_TOOLCHAIN_BUILDROOT_CXX=y
# BR2_TOOLCHAIN_BUILDROOT_FORTRAN is not set
# BR2_GCC_ENABLE_LTO is not set
# BR2_GCC_ENABLE_OPENMP is not set
# BR2_GCC_ENABLE_GRAPHITE is not set
BR2_PACKAGE_HOST_GDB_ARCH_SUPPORTS=y
# Host GDB Options
# BR2_PACKAGE_HOST_GDB is not set
# Toolchain Generic Options
BR2_TOOLCHAIN_SUPPORTS_VARIADIC_MI_THUNK=y
BR2_USE_WCHAR=y
BR2_INSTALL_LIBSTDCPP=y
BR2_TOOLCHAIN_HAS_THREADS=y
BR2_TOOLCHAIN_HAS_THREADS_NPTL=y
BR2_TOOLCHAIN_HAS_UCONTEXT=y
BR2_TOOLCHAIN_SUPPORTS_PIE=y
BR2_USE_MMU=y
BR2_TARGET_OPTIMIZATION=""
BR2_TARGET_LDFLAGS=""
# BR2_ECLIPSE_REGISTER is not set
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_0=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_1=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_2=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_3=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_4=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_5=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_6=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_7=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_8=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_9=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_10=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_11=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_12=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_13=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_14=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_15=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_16=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_17=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_18=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_19=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_0=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_1=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_2=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_3=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_4=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_5=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_6=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_7=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_8=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_9=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST="4.9"
BR2_TOOLCHAIN_GCC_AT_LEAST_4_3=y
BR2_TOOLCHAIN_GCC_AT_LEAST_4_4=y
BR2_TOOLCHAIN_GCC_AT_LEAST_4_5=y
BR2_TOOLCHAIN_GCC_AT_LEAST_4_6=y
BR2_TOOLCHAIN_GCC_AT_LEAST_4_7=y
BR2_TOOLCHAIN_GCC_AT_LEAST_4_8=y
BR2_TOOLCHAIN_GCC_AT_LEAST_4_9=y
BR2_TOOLCHAIN_GCC_AT_LEAST_5=y
BR2_TOOLCHAIN_GCC_AT_LEAST_6=y
BR2_TOOLCHAIN_GCC_AT_LEAST_7=y
BR2_TOOLCHAIN_GCC_AT_LEAST_8=y
BR2_TOOLCHAIN_GCC_AT_LEAST="8"
BR2_TOOLCHAIN_HAS_MNAN_OPTION=y
BR2_TOOLCHAIN_HAS_SYNC_1=y
BR2_TOOLCHAIN_HAS_SYNC_2=y
BR2_TOOLCHAIN_HAS_SYNC_4=y
BR2_TOOLCHAIN_HAS_LIBATOMIC=y
BR2_TOOLCHAIN_HAS_ATOMIC=y
# System configuration
BR2_ROOTFS_SKELETON_DEFAULT=y
# BR2_ROOTFS_SKELETON_CUSTOM is not set
BR2_TARGET_GENERIC_HOSTNAME="buildroot"
BR2_TARGET_GENERIC_ISSUE="Welcome to Buildroot"
BR2_TARGET_GENERIC_PASSWD_SHA256=y
# BR2_TARGET_GENERIC_PASSWD_SHA512 is not set
BR2_TARGET_GENERIC_PASSWD_METHOD="sha-256"
BR2_INIT_BUSYBOX=y
# BR2_INIT_SYSV is not set
# BR2_INIT_OPENRC is not set
# systemd needs a glibc toolchain w/ SSP, headers >= 3.10
# BR2_INIT_NONE is not set
# BR2_ROOTFS_DEVICE_CREATION_STATIC is not set
BR2_ROOTFS_DEVICE_CREATION_DYNAMIC_DEVTMPFS=y
# BR2_ROOTFS_DEVICE_CREATION_DYNAMIC_MDEV is not set
# BR2_ROOTFS_DEVICE_CREATION_DYNAMIC_EUDEV is not set
BR2_ROOTFS_DEVICE_TABLE="system/device_table.txt"
# BR2_ROOTFS_DEVICE_TABLE_SUPPORTS_EXTENDED_ATTRIBUTES is not set
# BR2_ROOTFS_MERGED_USR is not set
BR2_TARGET_ENABLE_ROOT_LOGIN=y
BR2_TARGET_GENERIC_ROOT_PASSWD=""
BR2_SYSTEM_BIN_SH_BUSYBOX=y
# bash, dash, mksh, zsh need BR2_PACKAGE_BUSYBOX_SHOW_OTHERS
# BR2_SYSTEM_BIN_SH_NONE is not set
BR2_TARGET_GENERIC_GETTY=y
BR2_TARGET_GENERIC_GETTY_PORT="console"
BR2_TARGET_GENERIC_GETTY_BAUDRATE_KEEP=y
# BR2_TARGET_GENERIC_GETTY_BAUDRATE_9600 is not set
# BR2_TARGET_GENERIC_GETTY_BAUDRATE_19200 is not set
# BR2_TARGET_GENERIC_GETTY_BAUDRATE_38400 is not set
# BR2_TARGET_GENERIC_GETTY_BAUDRATE_57600 is not set
# BR2_TARGET_GENERIC_GETTY_BAUDRATE_115200 is not set
BR2_TARGET_GENERIC_GETTY_BAUDRATE="0"
BR2_TARGET_GENERIC_GETTY_TERM="vt100"
BR2_TARGET_GENERIC_GETTY_OPTIONS=""
BR2_TARGET_GENERIC_REMOUNT_ROOTFS_RW=y
BR2_SYSTEM_DHCP=""
BR2_SYSTEM_DEFAULT_PATH="/bin:/sbin:/usr/bin:/usr/sbin"
BR2_ENABLE_LOCALE_PURGE=y
BR2_ENABLE_LOCALE_WHITELIST="C en_US"
# BR2_SYSTEM_ENABLE_NLS is not set
# BR2_TARGET_TZ_INFO is not set
BR2_ROOTFS_USERS_TABLES=""
BR2_ROOTFS_OVERLAY=""
BR2_ROOTFS_POST_BUILD_SCRIPT=""
BR2_ROOTFS_POST_FAKEROOT_SCRIPT=""
BR2_ROOTFS_POST_IMAGE_SCRIPT=""
# Kernel
# BR2_LINUX_KERNEL is not set
# Target packages
BR2_PACKAGE_BUSYBOX=y
BR2_PACKAGE_BUSYBOX_CONFIG="package/busybox/busybox.config"
BR2_PACKAGE_BUSYBOX_CONFIG_FRAGMENT_FILES=""
# BR2_PACKAGE_BUSYBOX_SHOW_OTHERS is not set
# BR2_PACKAGE_BUSYBOX_INDIVIDUAL_BINARIES is not set
# BR2_PACKAGE_BUSYBOX_WATCHDOG is not set
BR2_PACKAGE_SKELETON=y
BR2_PACKAGE_HAS_SKELETON=y
BR2_PACKAGE_PROVIDES_SKELETON="skeleton-init-sysv"
BR2_PACKAGE_SKELETON_INIT_COMMON=y
BR2_PACKAGE_SKELETON_INIT_SYSV=y
# Audio and video applications
# BR2_PACKAGE_ALSA_UTILS is not set
# BR2_PACKAGE_ATEST is not set
# BR2_PACKAGE_AUMIX is not set
# BR2_PACKAGE_BELLAGIO is not set
# BR2_PACKAGE_BLUEZ_ALSA is not set
# BR2_PACKAGE_DVBLAST is not set
# BR2_PACKAGE_DVDAUTHOR is not set
# BR2_PACKAGE_DVDRW_TOOLS is not set
# BR2_PACKAGE_ESPEAK is not set
# BR2_PACKAGE_FAAD2 is not set
BR2_PACKAGE_FFMPEG_ARCH_SUPPORTS=y
# BR2_PACKAGE_FFMPEG is not set
# BR2_PACKAGE_FLAC is not set
# BR2_PACKAGE_FLITE is not set
# BR2_PACKAGE_GMRENDER_RESURRECT is not set
# BR2_PACKAGE_GSTREAMER is not set
# BR2_PACKAGE_GSTREAMER1 is not set
# BR2_PACKAGE_JACK1 is not set
# BR2_PACKAGE_JACK2 is not set
BR2_PACKAGE_KODI_ARCH_SUPPORTS=y
# kodi needs python w/ .py modules, a uClibc or glibc toolchain w/ C++, threads, wchar, dynamic library, gcc >= 4.8, host gcc >= 4.6
# kodi needs an OpenGL EGL backend with OpenGL support
# BR2_PACKAGE_LAME is not set
# BR2_PACKAGE_MADPLAY is not set
# BR2_PACKAGE_MIMIC is not set
# miraclecast needs systemd and a glibc toolchain w/ threads and wchar
# BR2_PACKAGE_MJPEGTOOLS is not set
# BR2_PACKAGE_MODPLUGTOOLS is not set
# BR2_PACKAGE_MOTION is not set
# BR2_PACKAGE_MPD is not set
# BR2_PACKAGE_MPD_MPC is not set
# BR2_PACKAGE_MPG123 is not set
# BR2_PACKAGE_MPV is not set
# BR2_PACKAGE_MULTICAT is not set
# BR2_PACKAGE_MUSEPACK is not set
# BR2_PACKAGE_NCMPC is not set
# on2-8170-libs needs a glibc toolchain and a Linux kernel to be built
# BR2_PACKAGE_OPUS_TOOLS is not set
BR2_PACKAGE_PULSEAUDIO_HAS_ATOMIC=y
# BR2_PACKAGE_PULSEAUDIO is not set
# BR2_PACKAGE_SOX is not set
# BR2_PACKAGE_SQUEEZELITE is not set
# BR2_PACKAGE_TOVID is not set
# BR2_PACKAGE_TSTOOLS is not set
# BR2_PACKAGE_TWOLAME is not set
# BR2_PACKAGE_UDPXY is not set
# BR2_PACKAGE_UPMPDCLI is not set
# BR2_PACKAGE_V4L2GRAB is not set
# v4l2loopback needs a Linux kernel to be built
# BR2_PACKAGE_VLC is not set
# BR2_PACKAGE_VORBIS_TOOLS is not set
# BR2_PACKAGE_WAVPACK is not set
# BR2_PACKAGE_YAVTA is not set
# BR2_PACKAGE_YMPD is not set
# Compressors and decompressors
# BR2_PACKAGE_BROTLI is not set
# BR2_PACKAGE_BZIP2 is not set
# BR2_PACKAGE_LZ4 is not set
# BR2_PACKAGE_LZIP is not set
# BR2_PACKAGE_LZOP is not set
# BR2_PACKAGE_P7ZIP is not set
# BR2_PACKAGE_PIGZ is not set
# BR2_PACKAGE_PIXZ is not set
# BR2_PACKAGE_UNRAR is not set
# BR2_PACKAGE_XZ is not set
# BR2_PACKAGE_ZIP is not set
# BR2_PACKAGE_ZSTD is not set
# Debugging, profiling and benchmark
# BR2_PACKAGE_BLKTRACE is not set
# BR2_PACKAGE_BONNIE is not set
# BR2_PACKAGE_CACHE_CALIBRATOR is not set
# clinfo needs an OpenCL provider
# dacapo needs OpenJDK
# BR2_PACKAGE_DHRYSTONE is not set
# BR2_PACKAGE_DIEHARDER is not set
# BR2_PACKAGE_DMALLOC is not set
# BR2_PACKAGE_DROPWATCH is not set
# BR2_PACKAGE_DSTAT is not set
# BR2_PACKAGE_DT is not set
# BR2_PACKAGE_DUMA is not set
# BR2_PACKAGE_FIO is not set
BR2_PACKAGE_GDB_ARCH_SUPPORTS=y
# gdb/gdbserver needs a toolchain w/ threads, threads debug
BR2_PACKAGE_GOOGLE_BREAKPAD_ARCH_SUPPORTS=y
# BR2_PACKAGE_GOOGLE_BREAKPAD is not set
# BR2_PACKAGE_IOZONE is not set
# BR2_PACKAGE_KEXEC is not set
# ktap needs a Linux kernel to be built
# BR2_PACKAGE_LATENCYTOP is not set
# BR2_PACKAGE_LMBENCH is not set
BR2_PACKAGE_LTP_TESTSUITE_ARCH_SUPPORTS=y
# BR2_PACKAGE_LTP_TESTSUITE is not set
BR2_PACKAGE_LTRACE_ARCH_SUPPORTS=y
# BR2_PACKAGE_LTRACE is not set
# BR2_PACKAGE_LTTNG_BABELTRACE is not set
# lttng-modules needs a Linux kernel to be built
# BR2_PACKAGE_LTTNG_TOOLS is not set
# BR2_PACKAGE_MEMSTAT is not set
# BR2_PACKAGE_NETPERF is not set
# BR2_PACKAGE_NETSNIFF_NG is not set
# nmon needs a glibc toolchain
BR2_PACKAGE_OPROFILE_ARCH_SUPPORTS=y
# BR2_PACKAGE_OPROFILE is not set
# BR2_PACKAGE_PAX_UTILS is not set
# piglit needs glibc or musl
# BR2_PACKAGE_PV is not set
# BR2_PACKAGE_RAMSMP is not set
# BR2_PACKAGE_RAMSPEED is not set
# BR2_PACKAGE_RT_TESTS is not set
# BR2_PACKAGE_SPIDEV_TEST is not set
# BR2_PACKAGE_STRACE is not set
# BR2_PACKAGE_STRESS is not set
# BR2_PACKAGE_STRESS_NG is not set
# sysdig needs a glibc or uclibc toolchain w/ C++, gcc >= 4.8, dynamic library and a Linux kernel to be built
# BR2_PACKAGE_TCF_AGENT is not set
BR2_PACKAGE_TCF_AGENT_ARCH="arm"
BR2_PACKAGE_TCF_AGENT_ARCH_SUPPORTS=y
# BR2_PACKAGE_TINYMEMBENCH is not set
# BR2_PACKAGE_TRACE_CMD is not set
BR2_PACKAGE_TRINITY_ARCH_SUPPORTS=y
# BR2_PACKAGE_TRINITY is not set
# BR2_PACKAGE_UCLIBC_NG_TEST is not set
# BR2_PACKAGE_VMTOUCH is not set
# BR2_PACKAGE_WHETSTONE is not set
# Development tools
# BR2_PACKAGE_BINUTILS is not set
# BR2_PACKAGE_BSDIFF is not set
# BR2_PACKAGE_CHECK is not set
BR2_PACKAGE_CMAKE_ARCH_SUPPORTS=y
# BR2_PACKAGE_CMAKE_CTEST is not set
# BR2_PACKAGE_CPPUNIT is not set
# BR2_PACKAGE_CUNIT is not set
# BR2_PACKAGE_CVS is not set
# BR2_PACKAGE_CXXTEST is not set
# BR2_PACKAGE_FLEX is not set
# BR2_PACKAGE_GETTEXT is not set
BR2_PACKAGE_PROVIDES_HOST_GETTEXT="host-gettext-tiny"
# BR2_PACKAGE_GIT is not set
# BR2_PACKAGE_GIT_CRYPT is not set
# BR2_PACKAGE_GPERF is not set
# BR2_PACKAGE_JO is not set
# BR2_PACKAGE_JQ is not set
# BR2_PACKAGE_LIBTOOL is not set
# BR2_PACKAGE_MAKE is not set
# BR2_PACKAGE_PKGCONF is not set
# BR2_PACKAGE_SUBVERSION is not set
# BR2_PACKAGE_TREE is not set
# Filesystem and flash utilities
# BR2_PACKAGE_ABOOTIMG is not set
# aufs-util needs a linux kernel and a toolchain w/ threads
# BR2_PACKAGE_AUTOFS is not set
# BR2_PACKAGE_BTRFS_PROGS is not set
# BR2_PACKAGE_CIFS_UTILS is not set
# BR2_PACKAGE_CPIO is not set
# BR2_PACKAGE_CRAMFS is not set
# BR2_PACKAGE_CURLFTPFS is not set
# BR2_PACKAGE_DAVFS2 is not set
# BR2_PACKAGE_DOSFSTOOLS is not set
# BR2_PACKAGE_E2FSPROGS is not set
# BR2_PACKAGE_E2TOOLS is not set
# BR2_PACKAGE_ECRYPTFS_UTILS is not set
# BR2_PACKAGE_EXFAT is not set
# BR2_PACKAGE_EXFAT_UTILS is not set
# BR2_PACKAGE_F2FS_TOOLS is not set
# BR2_PACKAGE_FLASHBENCH is not set
# BR2_PACKAGE_FSCRYPTCTL is not set
# BR2_PACKAGE_FWUP is not set
# BR2_PACKAGE_GENEXT2FS is not set
# BR2_PACKAGE_GENPART is not set
# BR2_PACKAGE_GENROMFS is not set
# BR2_PACKAGE_IMX_USB_LOADER is not set
# BR2_PACKAGE_MMC_UTILS is not set
# BR2_PACKAGE_MTD is not set
# BR2_PACKAGE_MTOOLS is not set
# BR2_PACKAGE_NFS_UTILS is not set
# BR2_PACKAGE_NILFS_UTILS is not set
# BR2_PACKAGE_NTFS_3G is not set
# BR2_PACKAGE_SP_OOPS_EXTRACT is not set
# BR2_PACKAGE_SQUASHFS is not set
# BR2_PACKAGE_SSHFS is not set
# BR2_PACKAGE_SUNXI_TOOLS is not set
# BR2_PACKAGE_UDFTOOLS is not set
# BR2_PACKAGE_UNIONFS is not set
# BR2_PACKAGE_XFSPROGS is not set
# Fonts, cursors, icons, sounds and themes
# Cursors
# BR2_PACKAGE_COMIX_CURSORS is not set
# BR2_PACKAGE_OBSIDIAN_CURSORS is not set
# Fonts
# BR2_PACKAGE_BITSTREAM_VERA is not set
# BR2_PACKAGE_CANTARELL is not set
# BR2_PACKAGE_DEJAVU is not set
# BR2_PACKAGE_FONT_AWESOME is not set
# BR2_PACKAGE_GHOSTSCRIPT_FONTS is not set
# BR2_PACKAGE_INCONSOLATA is not set
BR2_PACKAGE_LIBERATION=y
BR2_PACKAGE_LIBERATION_MONO=y
BR2_PACKAGE_LIBERATION_SANS=y
BR2_PACKAGE_LIBERATION_SERIF=y
# Icons
# BR2_PACKAGE_GOOGLE_MATERIAL_DESIGN_ICONS is not set
# BR2_PACKAGE_HICOLOR_ICON_THEME is not set
# Sounds
# BR2_PACKAGE_SOUND_THEME_BOREALIS is not set
# BR2_PACKAGE_SOUND_THEME_FREEDESKTOP is not set
# Themes
# Games
# BR2_PACKAGE_ASCII_INVADERS is not set
# BR2_PACKAGE_CHOCOLATE_DOOM is not set
# BR2_PACKAGE_FLARE_ENGINE is not set
# BR2_PACKAGE_GNUCHESS is not set
# BR2_PACKAGE_LBREAKOUT2 is not set
# BR2_PACKAGE_LTRIS is not set
# minetest needs X11 and an OpenGL provider
# BR2_PACKAGE_OPENTYRIAN is not set
# BR2_PACKAGE_PRBOOM is not set
# BR2_PACKAGE_SL is not set
# solarus needs OpenGL and a toolchain w/ C++, gcc >= 4.8, NPTL, dynamic library
# BR2_PACKAGE_STELLA is not set
# Graphic libraries and applications (graphic/text)
# Graphic applications
# cog needs wpewebkit and a toolchain w/ threads
# BR2_PACKAGE_FSWEBCAM is not set
# BR2_PACKAGE_GHOSTSCRIPT is not set
# glmark2 needs an OpenGL or an openGL ES and EGL backend provided by mesa3d
# BR2_PACKAGE_GNUPLOT is not set
# BR2_PACKAGE_JHEAD is not set
# BR2_PACKAGE_LIBVA_UTILS is not set
BR2_PACKAGE_NETSURF_ARCH_SUPPORTS=y
# BR2_PACKAGE_NETSURF is not set
# BR2_PACKAGE_PNGQUANT is not set
# qt5cinex needs an Open(E)GL-capable backend
# BR2_PACKAGE_RRDTOOL is not set
# stellarium needs Qt5 and an OpenGL provider
# BR2_PACKAGE_TESSERACT_OCR is not set
# Graphic libraries
# BR2_PACKAGE_CEGUI06 is not set
# BR2_PACKAGE_DIRECTFB is not set
# BR2_PACKAGE_EFL is not set
# BR2_PACKAGE_FB_TEST_APP is not set
# BR2_PACKAGE_FBDUMP is not set
# BR2_PACKAGE_FBGRAB is not set
# fbterm needs a toolchain w/ C++, wchar, locale
BR2_PACKAGE_FBV=y
BR2_PACKAGE_FBV_PNG=y
BR2_PACKAGE_FBV_JPEG=y
BR2_PACKAGE_FBV_GIF=y
# BR2_PACKAGE_FREERDP is not set
# BR2_PACKAGE_IMAGEMAGICK is not set
# linux-fusion needs a Linux kernel to be built
# BR2_PACKAGE_MESA3D is not set
# BR2_PACKAGE_OCRAD is not set
# BR2_PACKAGE_PSPLASH is not set
# BR2_PACKAGE_SDL is not set
# BR2_PACKAGE_SDL2 is not set
# Other GUIs
BR2_PACKAGE_QT5_JSCORE_AVAILABLE=y
BR2_PACKAGE_QT5=y
BR2_PACKAGE_QT5_VERSION_LATEST=y
# BR2_PACKAGE_QT5_VERSION_5_6 is not set
# qt53d module needs an OpenGL-capable backend
BR2_PACKAGE_QT5BASE=y
BR2_PACKAGE_QT5BASE_CUSTOM_CONF_OPTS=""
BR2_PACKAGE_QT5BASE_CONFIG_FILE=""
# BR2_PACKAGE_QT5BASE_EXAMPLES is not set
BR2_PACKAGE_QT5BASE_NETWORK=y
# BR2_PACKAGE_QT5BASE_CONCURRENT is not set
BR2_PACKAGE_QT5BASE_SQL=y
# BR2_PACKAGE_QT5BASE_MYSQL is not set
# BR2_PACKAGE_QT5BASE_PSQL is not set
BR2_PACKAGE_QT5BASE_SQLITE_NONE=y
# BR2_PACKAGE_QT5BASE_SQLITE_QT is not set
# BR2_PACKAGE_QT5BASE_SQLITE_SYSTEM is not set
BR2_PACKAGE_QT5BASE_TEST=y
BR2_PACKAGE_QT5BASE_XML=y
BR2_PACKAGE_QT5BASE_GUI=y
BR2_PACKAGE_QT5BASE_WIDGETS=y
# OpenGL support needs an OpenGL-capable backend
BR2_PACKAGE_QT5BASE_LINUXFB=y
# directfb backend available if directfb is enabled
# X.org XCB backend available if X.org is enabled
# eglfs backend available if OpenGL and EGL are enabled
BR2_PACKAGE_QT5BASE_DEFAULT_QPA=""
BR2_PACKAGE_QT5BASE_PRINTSUPPORT=y
# BR2_PACKAGE_QT5BASE_FONTCONFIG is not set
# BR2_PACKAGE_QT5BASE_HARFBUZZ is not set
# BR2_PACKAGE_QT5BASE_GIF is not set
# BR2_PACKAGE_QT5BASE_JPEG is not set
# BR2_PACKAGE_QT5BASE_PNG is not set
# BR2_PACKAGE_QT5BASE_DBUS is not set
# BR2_PACKAGE_QT5BASE_ICU is not set
BR2_PACKAGE_QT5BASE_OPENSSL=y
BR2_PACKAGE_QT5BASE_TSLIB=y
# qt5canvas3d needs an OpenGL-capable backend
BR2_PACKAGE_QT5CHARTS=y
# qt5connectivity needs neard and/or bluez(5)_utils
# BR2_PACKAGE_QT5DECLARATIVE is not set
# BR2_PACKAGE_QT5ENGINIO is not set
# qt5graphicaleffects needs an OpenGL-capable backend
# BR2_PACKAGE_QT5IMAGEFORMATS is not set
# BR2_PACKAGE_QT5LOCATION is not set
# BR2_PACKAGE_QT5MULTIMEDIA is not set
# BR2_PACKAGE_QT5QUICKCONTROLS is not set
# BR2_PACKAGE_QT5QUICKCONTROLS2 is not set
# BR2_PACKAGE_QT5SCRIPT is not set
# BR2_PACKAGE_QT5SCXML is not set
# BR2_PACKAGE_QT5SENSORS is not set
BR2_PACKAGE_QT5SERIALBUS=y
BR2_PACKAGE_QT5SERIALPORT=y
BR2_PACKAGE_QT5SVG=y
# BR2_PACKAGE_QT5TOOLS is not set
# qt5virtualkeyboard needs an OpenGL-capable backend
# BR2_PACKAGE_QT5VIRTUALKEYBOARD is not set
# qt5wayland needs an OpenGL-capable backend
# BR2_PACKAGE_QT5WEBCHANNEL is not set
# BR2_PACKAGE_QT5WEBKIT is not set
BR2_PACKAGE_QT5WEBENGINE_ARCH_SUPPORTS=y
# qt5webengine needs udev /dev management and a glibc toolchain w/ gcc >= 4.8, host gcc >= 4.8, threads, wchar
# qt5webengine needs an OpenGL and EGL-capable backend
# BR2_PACKAGE_QT5WEBSOCKETS is not set
# BR2_PACKAGE_QT5XMLPATTERNS is not set
# QT libraries and helper libraries
# BR2_PACKAGE_CUTELYST is not set
# BR2_PACKAGE_GRANTLEE is not set
# BR2_PACKAGE_KF5 is not set
# BR2_PACKAGE_QEXTSERIALPORT is not set
# BR2_PACKAGE_QJSON is not set
# BR2_PACKAGE_QUAZIP is not set
# BR2_PACKAGE_QWT is not set
# tekui needs a Lua interpreter and a toolchain w/ threads, dynamic library
# weston needs udev and a toolchain w/ locale, threads, dynamic library, headers >= 3.0
# BR2_PACKAGE_XORG7 is not set
# midori needs libgtk3 and a glibc toolchain w/ C++, gcc >= 6, host gcc >= 4.8
# BR2_PACKAGE_QT_WEBKIT_KIOSK is not set
# vte needs an OpenGL or an OpenGL-EGL/wayland backend
# BR2_PACKAGE_XKEYBOARD_CONFIG is not set
# Hardware handling
# Firmware
# BR2_PACKAGE_AM33X_CM3 is not set
# BR2_PACKAGE_ARMBIAN_FIRMWARE is not set
# BR2_PACKAGE_B43_FIRMWARE is not set
# BR2_PACKAGE_LINUX_FIRMWARE is not set
# BR2_PACKAGE_MURATA_CYW_FW is not set
# BR2_PACKAGE_RPI_BT_FIRMWARE is not set
# BR2_PACKAGE_RPI_FIRMWARE is not set
# BR2_PACKAGE_RPI_WIFI_FIRMWARE is not set
# BR2_PACKAGE_SUNXI_BOARDS is not set
# BR2_PACKAGE_TS4900_FPGA is not set
# BR2_PACKAGE_UX500_FIRMWARE is not set
# BR2_PACKAGE_WILC1000_FIRMWARE is not set
# BR2_PACKAGE_WILINK_BT_FIRMWARE is not set
# BR2_PACKAGE_ZD1211_FIRMWARE is not set
# BR2_PACKAGE_18XX_TI_UTILS is not set
# a10disp needs a Linux kernel to be built
# BR2_PACKAGE_ACPICA is not set
# BR2_PACKAGE_ACPID is not set
# BR2_PACKAGE_ACPITOOL is not set
# BR2_PACKAGE_AER_INJECT is not set
# BR2_PACKAGE_AM335X_PRU_PACKAGE is not set
# BR2_PACKAGE_AVRDUDE is not set
# bcache-tools needs udev /dev management
# brickd needs udev /dev management, a toolchain w/ threads, wchar
# BR2_PACKAGE_BRLTTY is not set
# BR2_PACKAGE_CBOOTIMAGE is not set
# BR2_PACKAGE_CC_TOOL is not set
# BR2_PACKAGE_CDRKIT is not set
# BR2_PACKAGE_CRYPTSETUP is not set
# BR2_PACKAGE_CWIID is not set
# dahdi-linux needs a Linux kernel to be built
# dahdi-tools needs a toolchain w/ threads and a Linux kernel to be built
# BR2_PACKAGE_DBUS is not set
# BR2_PACKAGE_DFU_UTIL is not set
# BR2_PACKAGE_DMRAID is not set
# dt-utils needs udev /dev management
# BR2_PACKAGE_DTV_SCAN_TABLES is not set
# BR2_PACKAGE_DUMP1090 is not set
# BR2_PACKAGE_DVB_APPS is not set
# BR2_PACKAGE_DVBSNOOP is not set
# BR2_PACKAGE_EDID_DECODE is not set
# eudev needs eudev /dev management
# BR2_PACKAGE_EVEMU is not set
BR2_PACKAGE_EVTEST=y
# BR2_PACKAGE_FAN_CTRL is not set
# BR2_PACKAGE_FCONFIG is not set
# BR2_PACKAGE_FIS is not set
BR2_PACKAGE_FLASHROM_ARCH_SUPPORTS=y
# BR2_PACKAGE_FLASHROM is not set
# BR2_PACKAGE_FMTOOLS is not set
# BR2_PACKAGE_FREESCALE_IMX is not set
# BR2_PACKAGE_FXLOAD is not set
# BR2_PACKAGE_GADGETFS_TEST is not set
# BR2_PACKAGE_GPM is not set
# BR2_PACKAGE_GPSD is not set
# BR2_PACKAGE_GPTFDISK is not set
# BR2_PACKAGE_GVFS is not set
# BR2_PACKAGE_HWDATA is not set
# BR2_PACKAGE_HWLOC is not set
# BR2_PACKAGE_INPUT_EVENT_DAEMON is not set
# BR2_PACKAGE_IOSTAT is not set
# BR2_PACKAGE_IPMITOOL is not set
# BR2_PACKAGE_IRDA_UTILS is not set
# BR2_PACKAGE_KBD is not set
# BR2_PACKAGE_LCDPROC is not set
# BR2_PACKAGE_LIBUBOOTENV is not set
# BR2_PACKAGE_LIBUIO is not set
# linux-backports needs a Linux kernel to be built
# BR2_PACKAGE_LINUXCONSOLETOOLS is not set
# BR2_PACKAGE_LIRC_TOOLS is not set
# BR2_PACKAGE_LM_SENSORS is not set
# BR2_PACKAGE_LSHW is not set
# BR2_PACKAGE_LSSCSI is not set
# BR2_PACKAGE_LSUIO is not set
# BR2_PACKAGE_LUKSMETA is not set
# BR2_PACKAGE_LVM2 is not set
# mali-t76x needs a glibc toolchain with armhf enabled
# BR2_PACKAGE_MDADM is not set
# BR2_PACKAGE_MEMTESTER is not set
# BR2_PACKAGE_MEMTOOL is not set
# BR2_PACKAGE_MINICOM is not set
# BR2_PACKAGE_NANOCOM is not set
# BR2_PACKAGE_NEARD is not set
# BR2_PACKAGE_NVME is not set
# BR2_PACKAGE_OFONO is not set
# on2-8170-modules needs a Linux kernel to be built
# BR2_PACKAGE_OPEN2300 is not set
# BR2_PACKAGE_OPENIPMI is not set
# BR2_PACKAGE_OPENOCD is not set
# owl-linux needs a Linux kernel to be built
# BR2_PACKAGE_PARTED is not set
# BR2_PACKAGE_PCIUTILS is not set
# BR2_PACKAGE_PDBG is not set
BR2_PACKAGE_PICOCOM=y
# BR2_PACKAGE_PIFMRDS is not set
# BR2_PACKAGE_PIGPIO is not set
# BR2_PACKAGE_POWERTOP is not set
# BR2_PACKAGE_PPS_TOOLS is not set
# BR2_PACKAGE_PRU_SOFTWARE_SUPPORT is not set
# pulseview needs a toolchain w/ locale, wchar, threads, dynamic library, C++, gcc >= 4.9
# BR2_PACKAGE_READ_EDID is not set
# BR2_PACKAGE_RNG_TOOLS is not set
# BR2_PACKAGE_RPI_USERLAND is not set
# BR2_PACKAGE_RS485CONF is not set
# BR2_PACKAGE_RTC_TOOLS is not set
# rtl8188eu needs a Linux kernel to be built
# rtl8189fs needs a Linux kernel to be built
# rtl8723bs needs a Linux kernel to be built
# rtl8723bu needs a Linux kernel to be built
# rtl8821au needs a Linux kernel to be built
# BR2_PACKAGE_SANE_BACKENDS is not set
# BR2_PACKAGE_SDPARM is not set
BR2_PACKAGE_SEDUTIL_ARCH_SUPPORTS=y
# BR2_PACKAGE_SEDUTIL is not set
# BR2_PACKAGE_SETSERIAL is not set
# BR2_PACKAGE_SG3_UTILS is not set
# sigrok-cli needs a toolchain w/ locale, wchar, threads, dynamic library, gcc >= 4.7
# BR2_PACKAGE_SISPMCTL is not set
# BR2_PACKAGE_SMARTMONTOOLS is not set
# BR2_PACKAGE_SMSTOOLS3 is not set
# BR2_PACKAGE_SPI_TOOLS is not set
# BR2_PACKAGE_SREDIRD is not set
# BR2_PACKAGE_STATSERIAL is not set
# BR2_PACKAGE_STM32FLASH is not set
# sunxi-cedarx needs a glibc toolchain
# sunxi-mali needs an EABIhf glibc toolchain
# BR2_PACKAGE_SYSSTAT is not set
# BR2_PACKAGE_TARGETCLI_FB is not set
# ti-gfx needs a glibc toolchain and a Linux kernel to be built
# ti-sgx-km needs a Linux kernel to be built
# ti-sgx-um needs the ti-sgx-km driver
# ti-sgx-um needs a glibc toolchain w/ threads
# BR2_PACKAGE_TI_UIM is not set
# BR2_PACKAGE_TI_UTILS is not set
# BR2_PACKAGE_TRIGGERHAPPY is not set
# BR2_PACKAGE_UBOOT_TOOLS is not set
# BR2_PACKAGE_UBUS is not set
# uccp420wlan needs a Linux kernel >= 4.2 to be built
# udisks needs udev /dev management
# udisks needs a glibc toolchain w/ wchar, threads, dynamic library
# BR2_PACKAGE_UHUBCTL is not set
# upower needs udev /dev management
# BR2_PACKAGE_USB_MODESWITCH is not set
# BR2_PACKAGE_USB_MODESWITCH_DATA is not set
# usbmount requires udev to be enabled
# usbutils needs udev /dev management and toolchain w/ threads
# BR2_PACKAGE_W_SCAN is not set
# BR2_PACKAGE_WIPE is not set
# BR2_PACKAGE_XORRISO is not set
# xr819-xradio driver needs a Linux kernel to be built
# Interpreter languages and scripting
# BR2_PACKAGE_4TH is not set
# BR2_PACKAGE_ENSCRIPT is not set
BR2_PACKAGE_HOST_ERLANG_ARCH_SUPPORTS=y
BR2_PACKAGE_ERLANG_ARCH_SUPPORTS=y
# BR2_PACKAGE_ERLANG is not set
# BR2_PACKAGE_EXECLINE is not set
# BR2_PACKAGE_FICL is not set
BR2_PACKAGE_GAUCHE_ARCH_SUPPORTS=y
# BR2_PACKAGE_GAUCHE is not set
# BR2_PACKAGE_GUILE is not set
# BR2_PACKAGE_HASERL is not set
BR2_PACKAGE_JAMVM_ARCH_SUPPORTS=y
# BR2_PACKAGE_JAMVM is not set
# BR2_PACKAGE_JIMTCL is not set
# BR2_PACKAGE_LUA is not set
BR2_PACKAGE_PROVIDES_HOST_LUAINTERPRETER="host-lua"
BR2_PACKAGE_LUAJIT_ARCH_SUPPORTS=y
# BR2_PACKAGE_LUAJIT is not set
# BR2_PACKAGE_MICROPYTHON is not set
# BR2_PACKAGE_MOARVM is not set
BR2_PACKAGE_HOST_MONO_ARCH_SUPPORTS=y
BR2_PACKAGE_MONO_ARCH_SUPPORTS=y
# BR2_PACKAGE_MONO is not set
BR2_PACKAGE_HOST_OPENJDK_BIN_ARCH_SUPPORTS=y
BR2_PACKAGE_OPENJDK_ARCH_SUPPORTS=y
# openjdk needs X.Org
# openjdk needs glibc, and a toolchain w/ wchar, dynamic library, threads, C++
# openjdk does not support soft float configurations
# BR2_PACKAGE_PERL is not set
# BR2_PACKAGE_PHP is not set
# BR2_PACKAGE_PYTHON is not set
BR2_PACKAGE_PYTHON3=y
# BR2_PACKAGE_PYTHON3_PY_ONLY is not set
BR2_PACKAGE_PYTHON3_PYC_ONLY=y
# BR2_PACKAGE_PYTHON3_PY_PYC is not set
# core python3 modules
# The following modules are unusual or require extra libraries
# BR2_PACKAGE_PYTHON3_BZIP2 is not set
# BR2_PACKAGE_PYTHON3_CODECSCJK is not set
# BR2_PACKAGE_PYTHON3_CURSES is not set
# BR2_PACKAGE_PYTHON3_DECIMAL is not set
# BR2_PACKAGE_PYTHON3_OSSAUDIODEV is not set
# BR2_PACKAGE_PYTHON3_READLINE is not set
# BR2_PACKAGE_PYTHON3_SSL is not set
BR2_PACKAGE_PYTHON3_UNICODEDATA=y
# BR2_PACKAGE_PYTHON3_SQLITE is not set
# BR2_PACKAGE_PYTHON3_PYEXPAT is not set
# BR2_PACKAGE_PYTHON3_XZ is not set
# BR2_PACKAGE_PYTHON3_ZLIB is not set
# External python modules
# BR2_PACKAGE_PYTHON_AIOBLESCAN is not set
# BR2_PACKAGE_PYTHON_AIOCOAP is not set
# BR2_PACKAGE_PYTHON_AIOCONSOLE is not set
# BR2_PACKAGE_PYTHON_AIODNS is not set
# BR2_PACKAGE_PYTHON_AIOHTTP is not set
# BR2_PACKAGE_PYTHON_AIOHTTP_CORS is not set
# BR2_PACKAGE_PYTHON_AIOHTTP_JINJA2 is not set
# BR2_PACKAGE_PYTHON_AIOHTTP_REMOTES is not set
# BR2_PACKAGE_PYTHON_AIOHTTP_SECURITY is not set
# BR2_PACKAGE_PYTHON_AIOHTTP_SESSION is not set
# BR2_PACKAGE_PYTHON_AIOHTTP_SSE is not set
# BR2_PACKAGE_PYTHON_AIOJOBS is not set
# BR2_PACKAGE_PYTHON_AIOMONITOR is not set
# BR2_PACKAGE_PYTHON_AIORWLOCK is not set
# BR2_PACKAGE_PYTHON_ALSAAUDIO is not set
# BR2_PACKAGE_PYTHON_ARGH is not set
# BR2_PACKAGE_PYTHON_ARROW is not set
# BR2_PACKAGE_PYTHON_ASN1CRYPTO is not set
# BR2_PACKAGE_PYTHON_ASYNC_TIMEOUT is not set
# BR2_PACKAGE_PYTHON_ATTRS is not set
# BR2_PACKAGE_PYTHON_AUTOBAHN is not set
# BR2_PACKAGE_PYTHON_AUTOMAT is not set
# BR2_PACKAGE_PYTHON_BABEL is not set
# BR2_PACKAGE_PYTHON_BACKCALL is not set
# BR2_PACKAGE_PYTHON_BCRYPT is not set
# BR2_PACKAGE_PYTHON_BEAUTIFULSOUP4 is not set
# BR2_PACKAGE_PYTHON_BITSTRING is not set
# BR2_PACKAGE_PYTHON_BOTTLE is not set
# BR2_PACKAGE_PYTHON_CACHED_PROPERTY is not set
# BR2_PACKAGE_PYTHON_CAN is not set
# BR2_PACKAGE_PYTHON_CBOR is not set
# BR2_PACKAGE_PYTHON_CCHARDET is not set
# BR2_PACKAGE_PYTHON_CERTIFI is not set
# BR2_PACKAGE_PYTHON_CFFI is not set
# BR2_PACKAGE_PYTHON_CHARACTERISTIC is not set
# BR2_PACKAGE_PYTHON_CHARDET is not set
# BR2_PACKAGE_PYTHON_CHEROOT is not set
# BR2_PACKAGE_PYTHON_CHERRYPY is not set
# BR2_PACKAGE_PYTHON_CLICK is not set
# BR2_PACKAGE_PYTHON_COLORAMA is not set
# BR2_PACKAGE_PYTHON_CONFIGSHELL_FB is not set
# BR2_PACKAGE_PYTHON_CONSTANTLY is not set
# BR2_PACKAGE_PYTHON_COUCHDB is not set
# BR2_PACKAGE_PYTHON_CRCMOD is not set
# BR2_PACKAGE_PYTHON_CROSSBAR is not set
# BR2_PACKAGE_PYTHON_CRYPTOGRAPHY is not set
# BR2_PACKAGE_PYTHON_CSSSELECT is not set
# BR2_PACKAGE_PYTHON_CSSUTILS is not set
# BR2_PACKAGE_PYTHON_CYCLER is not set
# BR2_PACKAGE_PYTHON_DAEMON is not set
# BR2_PACKAGE_PYTHON_DAEMONIZE is not set
# BR2_PACKAGE_PYTHON_DATAPROPERTY is not set
# BR2_PACKAGE_PYTHON_DATEUTIL is not set
# BR2_PACKAGE_PYTHON_DECORATOR is not set
# BR2_PACKAGE_PYTHON_DIALOG3 is not set
# BR2_PACKAGE_PYTHON_DICTTOXML is not set
# BR2_PACKAGE_PYTHON_DJANGO is not set
# BR2_PACKAGE_PYTHON_DOCKER is not set
# BR2_PACKAGE_PYTHON_DOCKER_PYCREDS is not set
# BR2_PACKAGE_PYTHON_DOCKERPTY is not set
# BR2_PACKAGE_PYTHON_DOCOPT is not set
# BR2_PACKAGE_PYTHON_DOCUTILS is not set
# BR2_PACKAGE_PYTHON_DOMINATE is not set
# BR2_PACKAGE_PYTHON_ECDSA is not set
# BR2_PACKAGE_PYTHON_ENGINEIO is not set
# BR2_PACKAGE_PYTHON_FALCON is not set
# BR2_PACKAGE_PYTHON_FIRE is not set
# BR2_PACKAGE_PYTHON_FLASK is not set
# BR2_PACKAGE_PYTHON_FLASK_BABEL is not set
# BR2_PACKAGE_PYTHON_FLASK_CORS is not set
# BR2_PACKAGE_PYTHON_FLASK_JSONRPC is not set
# BR2_PACKAGE_PYTHON_FLASK_LOGIN is not set
# BR2_PACKAGE_PYTHON_FLASK_SQLALCHEMY is not set
# BR2_PACKAGE_PYTHON_GOBJECT is not set
# BR2_PACKAGE_PYTHON_GUNICORN is not set
# BR2_PACKAGE_PYTHON_H2 is not set
# BR2_PACKAGE_PYTHON_HIREDIS is not set
# BR2_PACKAGE_PYTHON_HPACK is not set
# BR2_PACKAGE_PYTHON_HTML5LIB is not set
# BR2_PACKAGE_PYTHON_HTTPLIB2 is not set
# BR2_PACKAGE_PYTHON_HUMANIZE is not set
# BR2_PACKAGE_PYTHON_HYPERFRAME is not set
# BR2_PACKAGE_PYTHON_HYPERLINK is not set
# BR2_PACKAGE_PYTHON_IBMIOTF is not set
# BR2_PACKAGE_PYTHON_IDNA is not set
# BR2_PACKAGE_PYTHON_IFADDR is not set
# BR2_PACKAGE_PYTHON_INCREMENTAL is not set
# BR2_PACKAGE_PYTHON_INFLECTION is not set
# BR2_PACKAGE_PYTHON_INFLUXDB is not set
# BR2_PACKAGE_PYTHON_IOWAIT is not set
# BR2_PACKAGE_PYTHON_IPTABLES is not set
# BR2_PACKAGE_PYTHON_IPYTHON is not set
# BR2_PACKAGE_PYTHON_IPYTHON_GENUTILS is not set
# BR2_PACKAGE_PYTHON_ISO8601 is not set
# BR2_PACKAGE_PYTHON_ITSDANGEROUS is not set
# BR2_PACKAGE_PYTHON_JARACO_CLASSES is not set
# BR2_PACKAGE_PYTHON_JEDI is not set
# BR2_PACKAGE_PYTHON_JINJA2 is not set
# BR2_PACKAGE_PYTHON_JSON_SCHEMA_VALIDATOR is not set
# BR2_PACKAGE_PYTHON_JSONMODELS is not set
# BR2_PACKAGE_PYTHON_JSONSCHEMA is not set
# BR2_PACKAGE_PYTHON_KEYRING is not set
# BR2_PACKAGE_PYTHON_LIBCONFIG is not set
# BR2_PACKAGE_PYTHON_LIBUSB1 is not set
# BR2_PACKAGE_PYTHON_LMDB is not set
# BR2_PACKAGE_PYTHON_LOGBOOK is not set
# BR2_PACKAGE_PYTHON_LXML is not set
# BR2_PACKAGE_PYTHON_M2R is not set
# BR2_PACKAGE_PYTHON_MAKO is not set
# BR2_PACKAGE_PYTHON_MARKDOWN is not set
# BR2_PACKAGE_PYTHON_MARKDOWN2 is not set
# BR2_PACKAGE_PYTHON_MARKUPSAFE is not set
# python-matplotlib needs glibc or musl
# BR2_PACKAGE_PYTHON_MBSTRDECODER is not set
# BR2_PACKAGE_PYTHON_MELD3 is not set
# BR2_PACKAGE_PYTHON_MIMEPARSE is not set
# BR2_PACKAGE_PYTHON_MISTUNE is not set
# BR2_PACKAGE_PYTHON_MORE_ITERTOOLS is not set
# BR2_PACKAGE_PYTHON_MSGPACK is not set
# BR2_PACKAGE_PYTHON_MULTIDICT is not set
# BR2_PACKAGE_PYTHON_MUTAGEN is not set
# BR2_PACKAGE_PYTHON_MWCLIENT is not set
# BR2_PACKAGE_PYTHON_MWSCRAPE2SLOB is not set
# BR2_PACKAGE_PYTHON_NETADDR is not set
# BR2_PACKAGE_PYTHON_NETIFACES is not set
# BR2_PACKAGE_PYTHON_NETWORKX is not set
BR2_PACKAGE_PYTHON_NUMPY_ARCH_SUPPORTS=y
# python-numpy needs glibc or musl
# BR2_PACKAGE_PYTHON_OAUTHLIB is not set
# BR2_PACKAGE_PYTHON_PAHO_MQTT is not set
# BR2_PACKAGE_PYTHON_PARAMIKO is not set
# BR2_PACKAGE_PYTHON_PARSO is not set
# BR2_PACKAGE_PYTHON_PASSLIB is not set
# BR2_PACKAGE_PYTHON_PATHPY is not set
# BR2_PACKAGE_PYTHON_PATHTOOLS is not set
# BR2_PACKAGE_PYTHON_PATHVALIDATE is not set
# BR2_PACKAGE_PYTHON_PERIPHERY is not set
# BR2_PACKAGE_PYTHON_PEXPECT is not set
# BR2_PACKAGE_PYTHON_PICKLESHARE is not set
# BR2_PACKAGE_PYTHON_PIGPIO is not set
# BR2_PACKAGE_PYTHON_PILLOW is not set
# BR2_PACKAGE_PYTHON_PIP is not set
# BR2_PACKAGE_PYTHON_PLY is not set
# BR2_PACKAGE_PYTHON_PORTEND is not set
# BR2_PACKAGE_PYTHON_POSIX_IPC is not set
# BR2_PACKAGE_PYTHON_PRIORITY is not set
# BR2_PACKAGE_PYTHON_PROMPT_TOOLKIT is not set
# BR2_PACKAGE_PYTHON_PROTOBUF is not set
# BR2_PACKAGE_PYTHON_PSUTIL is not set
# BR2_PACKAGE_PYTHON_PSYCOPG2 is not set
# BR2_PACKAGE_PYTHON_PTYPROCESS is not set
# BR2_PACKAGE_PYTHON_PUDB is not set
# BR2_PACKAGE_PYTHON_PY is not set
# BR2_PACKAGE_PYTHON_PYASN is not set
# BR2_PACKAGE_PYTHON_PYASN_MODULES is not set
# BR2_PACKAGE_PYTHON_PYASN1 is not set
# BR2_PACKAGE_PYTHON_PYASN1_MODULES is not set
# BR2_PACKAGE_PYTHON_PYCAIRO is not set
# BR2_PACKAGE_PYTHON_PYCARES is not set
# BR2_PACKAGE_PYTHON_PYCLI is not set
# BR2_PACKAGE_PYTHON_PYCPARSER is not set
# BR2_PACKAGE_PYTHON_PYCRYPTO is not set
# BR2_PACKAGE_PYTHON_PYCRYPTODOMEX is not set
# BR2_PACKAGE_PYTHON_PYDAL is not set
# BR2_PACKAGE_PYTHON_PYELFTOOLS is not set
# BR2_PACKAGE_PYTHON_PYFTPDLIB is not set
# BR2_PACKAGE_PYTHON_PYGAME is not set
# BR2_PACKAGE_PYTHON_PYGMENTS is not set
# BR2_PACKAGE_PYTHON_PYHAMCREST is not set
# BR2_PACKAGE_PYTHON_PYICU is not set
# BR2_PACKAGE_PYTHON_PYINOTIFY is not set
# BR2_PACKAGE_PYTHON_PYJWT is not set
# BR2_PACKAGE_PYTHON_PYLIBFTDI is not set
# BR2_PACKAGE_PYTHON_PYLRU is not set
# BR2_PACKAGE_PYTHON_PYMODBUS is not set
# BR2_PACKAGE_PYTHON_PYMYSQL is not set
# BR2_PACKAGE_PYTHON_PYNACL is not set
# BR2_PACKAGE_PYTHON_PYOPENSSL is not set
# BR2_PACKAGE_PYTHON_PYPARSING is not set
# BR2_PACKAGE_PYTHON_PYPARTED is not set
# BR2_PACKAGE_PYTHON_PYQRCODE is not set
BR2_PACKAGE_PYTHON_PYQT5=y
# BR2_PACKAGE_PYTHON_PYRATEMP is not set
# BR2_PACKAGE_PYTHON_PYROUTE2 is not set
# BR2_PACKAGE_PYTHON_PYSENDFILE is not set
# BR2_PACKAGE_PYTHON_PYSMB is not set
# BR2_PACKAGE_PYTHON_PYSMI is not set
# BR2_PACKAGE_PYTHON_PYSNMP is not set
# BR2_PACKAGE_PYTHON_PYSNMP_APPS is not set
# BR2_PACKAGE_PYTHON_PYSNMP_MIBS is not set
# BR2_PACKAGE_PYTHON_PYSOCKS is not set
# BR2_PACKAGE_PYTHON_PYTABLEREADER is not set
# BR2_PACKAGE_PYTHON_PYTABLEWRITER is not set
# BR2_PACKAGE_PYTHON_PYTRIE is not set
# BR2_PACKAGE_PYTHON_PYTZ is not set
# python-pyudev needs udev /dev management
# BR2_PACKAGE_PYTHON_PYUSB is not set
# BR2_PACKAGE_PYTHON_PYXB is not set
# BR2_PACKAGE_PYTHON_PYYAML is not set
# BR2_PACKAGE_PYTHON_PYZMQ is not set
# BR2_PACKAGE_PYTHON_RAVEN is not set
# BR2_PACKAGE_PYTHON_REDIS is not set
# BR2_PACKAGE_PYTHON_REENTRY is not set
# BR2_PACKAGE_PYTHON_REMI is not set
# BR2_PACKAGE_PYTHON_REQUEST_ID is not set
# BR2_PACKAGE_PYTHON_REQUESTS is not set
# BR2_PACKAGE_PYTHON_REQUESTS_OAUTHLIB is not set
# BR2_PACKAGE_PYTHON_REQUESTS_TOOLBELT is not set
# BR2_PACKAGE_PYTHON_RPI_GPIO is not set
# BR2_PACKAGE_PYTHON_RTSLIB_FB is not set
# BR2_PACKAGE_PYTHON_SCANDIR is not set
# BR2_PACKAGE_PYTHON_SCAPY is not set
# BR2_PACKAGE_PYTHON_SCAPY3K is not set
# BR2_PACKAGE_PYTHON_SCHEDULE is not set
# BR2_PACKAGE_PYTHON_SDNOTIFY is not set
# BR2_PACKAGE_PYTHON_SECRETSTORAGE is not set
# BR2_PACKAGE_PYTHON_SEE is not set
# BR2_PACKAGE_PYTHON_SEMVER is not set
# BR2_PACKAGE_PYTHON_SENTRY_SDK is not set
# BR2_PACKAGE_PYTHON_SERIAL is not set
# BR2_PACKAGE_PYTHON_SERIAL_ASYNCIO is not set
# BR2_PACKAGE_PYTHON_SERVICE_IDENTITY is not set
# BR2_PACKAGE_PYTHON_SETPROCTITLE is not set
# BR2_PACKAGE_PYTHON_SETUPTOOLS is not set
# BR2_PACKAGE_PYTHON_SH is not set
# BR2_PACKAGE_PYTHON_SHUTILWHICH is not set
# BR2_PACKAGE_PYTHON_SIMPLEAUDIO is not set
# BR2_PACKAGE_PYTHON_SIMPLEGENERIC is not set
# BR2_PACKAGE_PYTHON_SIMPLEJSON is not set
# BR2_PACKAGE_PYTHON_SIMPLESQLITE is not set
BR2_PACKAGE_PYTHON_SIP=y
# BR2_PACKAGE_PYTHON_SIX is not set
# BR2_PACKAGE_PYTHON_SLOB is not set
# BR2_PACKAGE_PYTHON_SMBUS_CFFI is not set
# BR2_PACKAGE_PYTHON_SOCKETIO is not set
# BR2_PACKAGE_PYTHON_SORTEDCONTAINERS is not set
# BR2_PACKAGE_PYTHON_SPIDEV is not set
# BR2_PACKAGE_PYTHON_SQLALCHEMY is not set
# python-systemd needs systemd
# BR2_PACKAGE_PYTHON_TABLEDATA is not set
# BR2_PACKAGE_PYTHON_TEMPORA is not set
# BR2_PACKAGE_PYTHON_TERMCOLOR is not set
# BR2_PACKAGE_PYTHON_TERMINALTABLES is not set
# BR2_PACKAGE_PYTHON_TEXTTABLE is not set
# BR2_PACKAGE_PYTHON_TINYRPC is not set
# BR2_PACKAGE_PYTHON_TOMAKO is not set
# BR2_PACKAGE_PYTHON_TOML is not set
# BR2_PACKAGE_PYTHON_TORNADO is not set
# BR2_PACKAGE_PYTHON_TRAITLETS is not set
# BR2_PACKAGE_PYTHON_TREQ is not set
# BR2_PACKAGE_PYTHON_TWISTED is not set
# BR2_PACKAGE_PYTHON_TXAIO is not set
# BR2_PACKAGE_PYTHON_TXDBUS is not set
# BR2_PACKAGE_PYTHON_TXTORCON is not set
# BR2_PACKAGE_PYTHON_TYPEPY is not set
# BR2_PACKAGE_PYTHON_U_MSGPACK is not set
# BR2_PACKAGE_PYTHON_UBJSON is not set
# BR2_PACKAGE_PYTHON_UJSON is not set
# BR2_PACKAGE_PYTHON_URLLIB3 is not set
# BR2_PACKAGE_PYTHON_URWID is not set
# BR2_PACKAGE_PYTHON_UVLOOP is not set
# BR2_PACKAGE_PYTHON_VALIDATORS is not set
# BR2_PACKAGE_PYTHON_VERSIONTOOLS is not set
# BR2_PACKAGE_PYTHON_VISITOR is not set
# BR2_PACKAGE_PYTHON_WATCHDOG is not set
# BR2_PACKAGE_PYTHON_WCWIDTH is not set
# BR2_PACKAGE_PYTHON_WEB2PY is not set
# BR2_PACKAGE_PYTHON_WEBOB is not set
# BR2_PACKAGE_PYTHON_WEBSOCKET_CLIENT is not set
# BR2_PACKAGE_PYTHON_WEBSOCKETS is not set
# BR2_PACKAGE_PYTHON_WERKZEUG is not set
# BR2_PACKAGE_PYTHON_WHOOSH is not set
# BR2_PACKAGE_PYTHON_WRAPT is not set
# BR2_PACKAGE_PYTHON_WS4PY is not set
# BR2_PACKAGE_PYTHON_WSACCEL is not set
# BR2_PACKAGE_PYTHON_WTFORMS is not set
# BR2_PACKAGE_PYTHON_XLIB is not set
# BR2_PACKAGE_PYTHON_XLRD is not set
# BR2_PACKAGE_PYTHON_XLSXWRITER is not set
# BR2_PACKAGE_PYTHON_XLUTILS is not set
# BR2_PACKAGE_PYTHON_XLWT is not set
# BR2_PACKAGE_PYTHON_XMLTODICT is not set
# BR2_PACKAGE_PYTHON_YARL is not set
# BR2_PACKAGE_PYTHON_ZEROCONF is not set
# BR2_PACKAGE_PYTHON_ZOPE_INTERFACE is not set
# BR2_PACKAGE_RUBY is not set
# BR2_PACKAGE_TCL is not set
# Libraries
# Audio/Sound
# BR2_PACKAGE_ALSA_LIB is not set
# BR2_PACKAGE_AUBIO is not set
BR2_PACKAGE_AUDIOFILE=y
# BR2_PACKAGE_BCG729 is not set
# BR2_PACKAGE_CELT051 is not set
BR2_PACKAGE_FDK_AAC_ARCH_SUPPORTS=y
# BR2_PACKAGE_FDK_AAC is not set
# BR2_PACKAGE_LIBAO is not set
# BR2_PACKAGE_LIBASPLIB is not set
# BR2_PACKAGE_LIBBROADVOICE is not set
# BR2_PACKAGE_LIBCDAUDIO is not set
# BR2_PACKAGE_LIBCDDB is not set
# BR2_PACKAGE_LIBCDIO is not set
# BR2_PACKAGE_LIBCDIO_PARANOIA is not set
# BR2_PACKAGE_LIBCODEC2 is not set
# BR2_PACKAGE_LIBCUE is not set
# BR2_PACKAGE_LIBCUEFILE is not set
# BR2_PACKAGE_LIBEBUR128 is not set
# BR2_PACKAGE_LIBG7221 is not set
# BR2_PACKAGE_LIBGSM is not set
# BR2_PACKAGE_LIBID3TAG is not set
# BR2_PACKAGE_LIBILBC is not set
# BR2_PACKAGE_LIBLO is not set
# BR2_PACKAGE_LIBMAD is not set
# BR2_PACKAGE_LIBMODPLUG is not set
# BR2_PACKAGE_LIBMPD is not set
# BR2_PACKAGE_LIBMPDCLIENT is not set
# BR2_PACKAGE_LIBREPLAYGAIN is not set
# BR2_PACKAGE_LIBSAMPLERATE is not set
# BR2_PACKAGE_LIBSIDPLAY2 is not set
# BR2_PACKAGE_LIBSILK is not set
# BR2_PACKAGE_LIBSNDFILE is not set
# BR2_PACKAGE_LIBSOUNDTOUCH is not set
# BR2_PACKAGE_LIBSOXR is not set
# BR2_PACKAGE_LIBVORBIS is not set
# BR2_PACKAGE_MP4V2 is not set
BR2_PACKAGE_OPENAL_ARCH_SUPPORTS=y
# BR2_PACKAGE_OPENAL is not set
# BR2_PACKAGE_OPENCORE_AMR is not set
# BR2_PACKAGE_OPUS is not set
# BR2_PACKAGE_OPUSFILE is not set
# BR2_PACKAGE_PORTAUDIO is not set
# BR2_PACKAGE_SBC is not set
# BR2_PACKAGE_SPANDSP is not set
# BR2_PACKAGE_SPEEX is not set
# BR2_PACKAGE_SPEEXDSP is not set
# BR2_PACKAGE_TAGLIB is not set
BR2_PACKAGE_TINYALSA=y
# BR2_PACKAGE_TREMOR is not set
# BR2_PACKAGE_VO_AACENC is not set
BR2_PACKAGE_WEBRTC_AUDIO_PROCESSING_ARCH_SUPPORTS=y
# BR2_PACKAGE_WEBRTC_AUDIO_PROCESSING is not set
# Compression and decompression
# BR2_PACKAGE_LIBARCHIVE is not set
# BR2_PACKAGE_LIBSQUISH is not set
# BR2_PACKAGE_LIBZIP is not set
BR2_PACKAGE_LZO=y
# BR2_PACKAGE_MINIZIP is not set
# BR2_PACKAGE_SNAPPY is not set
# BR2_PACKAGE_SZIP is not set
BR2_PACKAGE_ZLIB_NG_ARCH_SUPPORTS=y
BR2_PACKAGE_ZLIB=y
BR2_PACKAGE_LIBZLIB=y
# BR2_PACKAGE_ZLIB_NG is not set
BR2_PACKAGE_HAS_ZLIB=y
BR2_PACKAGE_PROVIDES_ZLIB="libzlib"
BR2_PACKAGE_PROVIDES_HOST_ZLIB="host-libzlib"
# BR2_PACKAGE_ZZIPLIB is not set
# Crypto
# BR2_PACKAGE_BEECRYPT is not set
BR2_PACKAGE_BOTAN_ARCH_SUPPORTS=y
# BR2_PACKAGE_BOTAN is not set
# BR2_PACKAGE_CA_CERTIFICATES is not set
# cryptodev needs a Linux kernel to be built
# BR2_PACKAGE_GCR is not set
# BR2_PACKAGE_GNUTLS is not set
# BR2_PACKAGE_LIBASSUAN is not set
# BR2_PACKAGE_LIBGCRYPT is not set
BR2_PACKAGE_LIBGPG_ERROR_ARCH_SUPPORTS=y
# BR2_PACKAGE_LIBGPG_ERROR is not set
BR2_PACKAGE_LIBGPG_ERROR_SYSCFG="arm-unknown-linux-gnueabi"
# BR2_PACKAGE_LIBGPGME is not set
# BR2_PACKAGE_LIBKCAPI is not set
# BR2_PACKAGE_LIBKSBA is not set
# BR2_PACKAGE_LIBMCRYPT is not set
# BR2_PACKAGE_LIBMHASH is not set
# BR2_PACKAGE_LIBNSS is not set
# BR2_PACKAGE_LIBP11 is not set
# BR2_PACKAGE_LIBSCRYPT is not set
# BR2_PACKAGE_LIBSECRET is not set
# BR2_PACKAGE_LIBSHA1 is not set
# BR2_PACKAGE_LIBSODIUM is not set
# BR2_PACKAGE_LIBSSH is not set
# BR2_PACKAGE_LIBSSH2 is not set
# BR2_PACKAGE_LIBTOMCRYPT is not set
# BR2_PACKAGE_LIBUECC is not set
# BR2_PACKAGE_MBEDTLS is not set
# BR2_PACKAGE_NETTLE is not set
BR2_PACKAGE_OPENSSL=y
BR2_PACKAGE_LIBOPENSSL=y
# BR2_PACKAGE_LIBOPENSSL_BIN is not set
# BR2_PACKAGE_LIBOPENSSL_ENGINES is not set
# BR2_PACKAGE_LIBRESSL is not set
BR2_PACKAGE_HAS_OPENSSL=y
BR2_PACKAGE_PROVIDES_OPENSSL="libopenssl"
BR2_PACKAGE_PROVIDES_HOST_OPENSSL="host-libopenssl"
# BR2_PACKAGE_RHASH is not set
# BR2_PACKAGE_TINYDTLS is not set
# BR2_PACKAGE_TPM2_TSS is not set
# BR2_PACKAGE_TROUSERS is not set
# BR2_PACKAGE_USTREAM_SSL is not set
# BR2_PACKAGE_WOLFSSL is not set
# Database
# BR2_PACKAGE_BERKELEYDB is not set
# BR2_PACKAGE_GDBM is not set
# BR2_PACKAGE_HIREDIS is not set
# BR2_PACKAGE_KOMPEXSQLITE is not set
# BR2_PACKAGE_LEVELDB is not set
# BR2_PACKAGE_LIBGIT2 is not set
# BR2_PACKAGE_MYSQL is not set
# BR2_PACKAGE_POSTGRESQL is not set
# BR2_PACKAGE_REDIS is not set
# BR2_PACKAGE_SQLCIPHER is not set
# BR2_PACKAGE_SQLITE is not set
# BR2_PACKAGE_UNIXODBC is not set
# Filesystem
# BR2_PACKAGE_GAMIN is not set
# BR2_PACKAGE_LIBCONFIG is not set
# BR2_PACKAGE_LIBCONFUSE is not set
# BR2_PACKAGE_LIBFUSE is not set
# BR2_PACKAGE_LIBLOCKFILE is not set
# BR2_PACKAGE_LIBNFS is not set
# BR2_PACKAGE_LIBSYSFS is not set
# BR2_PACKAGE_LOCKDEV is not set
# BR2_PACKAGE_PHYSFS is not set
# Graphics
# BR2_PACKAGE_ASSIMP is not set
# at-spi2-atk depends on X.org
# at-spi2-core depends on X.org
# BR2_PACKAGE_ATK is not set
# BR2_PACKAGE_ATKMM is not set
# BR2_PACKAGE_BULLET is not set
# BR2_PACKAGE_CAIRO is not set
# BR2_PACKAGE_CAIROMM is not set
# chipmunk needs an OpenGL backend
# BR2_PACKAGE_EXEMPI is not set
# BR2_PACKAGE_EXIV2 is not set
# BR2_PACKAGE_FONTCONFIG is not set
BR2_PACKAGE_FREETYPE=y
# BR2_PACKAGE_GD is not set
# BR2_PACKAGE_GDK_PIXBUF is not set
BR2_PACKAGE_GIFLIB=y
# granite needs libgtk3 and a toolchain w/ wchar, threads
# BR2_PACKAGE_GRAPHITE2 is not set
# gtkmm3 needs libgtk3 and a toolchain w/ C++, wchar, threads, gcc >= 4.9, host gcc >= 4.8
# BR2_PACKAGE_HARFBUZZ is not set
# BR2_PACKAGE_IJS is not set
# BR2_PACKAGE_IMLIB2 is not set
# irrlicht needs X11 and an OpenGL provider
# BR2_PACKAGE_JASPER is not set
BR2_PACKAGE_JPEG=y
# BR2_PACKAGE_LIBJPEG is not set
BR2_PACKAGE_JPEG_TURBO=y
BR2_PACKAGE_HAS_JPEG=y
BR2_PACKAGE_PROVIDES_JPEG="jpeg-turbo"
# BR2_PACKAGE_KMSXX is not set
# BR2_PACKAGE_LCMS2 is not set
# BR2_PACKAGE_LENSFUN is not set
# BR2_PACKAGE_LEPTONICA is not set
# BR2_PACKAGE_LIBART is not set
# BR2_PACKAGE_LIBDMTX is not set
# BR2_PACKAGE_LIBDRM is not set
# libepoxy needs an OpenGL and/or OpenGL EGL backend
# BR2_PACKAGE_LIBEXIF is not set
# libfm needs X.org and a toolchain w/ wchar, threads, C++, gcc >= 4.8
# BR2_PACKAGE_LIBFM_EXTRA is not set
# libfreeglut depends on X.org and needs an OpenGL backend
# BR2_PACKAGE_LIBFREEIMAGE is not set
# BR2_PACKAGE_LIBGEOTIFF is not set
# libglew depends on X.org and needs an OpenGL backend
# libglfw depends on X.org and needs an OpenGL backend
# libglu needs an OpenGL backend
# BR2_PACKAGE_LIBGTA is not set
# libgtk3 needs an OpenGL or an OpenGL-EGL/wayland backend
# BR2_PACKAGE_LIBMEDIAART is not set
# BR2_PACKAGE_LIBMNG is not set
BR2_PACKAGE_LIBPNG=y
# BR2_PACKAGE_LIBQRENCODE is not set
# BR2_PACKAGE_LIBRAW is not set
# BR2_PACKAGE_LIBRSVG is not set
# libsoil needs an OpenGL backend and a toolchain w/ dynamic library
# BR2_PACKAGE_LIBSVG is not set
# BR2_PACKAGE_LIBSVG_CAIRO is not set
# BR2_PACKAGE_LIBSVGTINY is not set
# BR2_PACKAGE_LIBVA is not set
# BR2_PACKAGE_LIBVIPS is not set
# libwpe needs a toolchain w/ C++, dynamic library and an OpenEGL-capable backend
# BR2_PACKAGE_MENU_CACHE is not set
# BR2_PACKAGE_OPENCV is not set
# BR2_PACKAGE_OPENCV3 is not set
BR2_PACKAGE_OPENJPEG=y
# BR2_PACKAGE_PANGO is not set
# BR2_PACKAGE_PANGOMM is not set
# BR2_PACKAGE_PIXMAN is not set
# BR2_PACKAGE_POPPLER is not set
# BR2_PACKAGE_TIFF is not set
# BR2_PACKAGE_WAYLAND is not set
BR2_PACKAGE_WEBKITGTK_ARCH_SUPPORTS=y
# webkitgtk needs libgtk3 and a glibc toolchain w/ C++, gcc >= 6, host gcc >= 4.8
# BR2_PACKAGE_WEBP is not set
# BR2_PACKAGE_WOFF2 is not set
# wpebackend-fdo needs a toolchain w/ C++, wchar, threads, dynamic library and an OpenEGL-capable Wayland backend
BR2_PACKAGE_WPEWEBKIT_ARCH_SUPPORTS=y
# wpewebkit needs an OpenGL ES w/ EGL-capable Wayland backend
# BR2_PACKAGE_ZBAR is not set
# BR2_PACKAGE_ZXING_CPP is not set
# Hardware handling
# BR2_PACKAGE_ACSCCID is not set
# BR2_PACKAGE_BCM2835 is not set
# BR2_PACKAGE_C_PERIPHERY is not set
# BR2_PACKAGE_CCID is not set
# BR2_PACKAGE_DTC is not set
BR2_PACKAGE_GNU_EFI_ARCH_SUPPORTS=y
# BR2_PACKAGE_GNU_EFI is not set
# BR2_PACKAGE_HACKRF is not set
# hidapi needs udev /dev management and a toolchain w/ NPTL threads
# BR2_PACKAGE_LCDAPI is not set
# BR2_PACKAGE_LET_ME_CREATE is not set
# BR2_PACKAGE_LIBAIO is not set
# libatasmart requires udev to be enabled
# BR2_PACKAGE_LIBCEC is not set
# BR2_PACKAGE_LIBFREEFARE is not set
# BR2_PACKAGE_LIBFTDI is not set
# BR2_PACKAGE_LIBFTDI1 is not set
# BR2_PACKAGE_LIBGPHOTO2 is not set
# BR2_PACKAGE_LIBGPIOD is not set
# libgudev needs udev /dev handling and a toolchain w/ wchar, threads
# BR2_PACKAGE_LIBHID is not set
# BR2_PACKAGE_LIBIIO is not set
# libinput needs udev /dev management and a toolchain w/ locale
# BR2_PACKAGE_LIBIQRF is not set
# BR2_PACKAGE_LIBLLCP is not set
# BR2_PACKAGE_LIBMBIM is not set
# BR2_PACKAGE_LIBNFC is not set
# BR2_PACKAGE_LIBPCIACCESS is not set
# BR2_PACKAGE_LIBPHIDGET is not set
# libpri needs a kernel to be built
# BR2_PACKAGE_LIBQMI is not set
# BR2_PACKAGE_LIBRAW1394 is not set
# BR2_PACKAGE_LIBRTLSDR is not set
# BR2_PACKAGE_LIBSERIAL is not set
# BR2_PACKAGE_LIBSERIALPORT is not set
# libsigrok needs a toolchain w/ wchar, locale, threads, dynamic library, gcc >= 4.7
# BR2_PACKAGE_LIBSIGROKDECODE is not set
# BR2_PACKAGE_LIBSOC is not set
# libss7 needs a kernel to be built
# BR2_PACKAGE_LIBUSB is not set
# BR2_PACKAGE_LIBUSBGX is not set
# BR2_PACKAGE_LIBV4L is not set
# BR2_PACKAGE_LIBXKBCOMMON is not set
# BR2_PACKAGE_MRAA is not set
# BR2_PACKAGE_MTDEV is not set
# ne10 needs a toolchain w/ neon
# BR2_PACKAGE_NEARDAL is not set
# BR2_PACKAGE_OWFS is not set
# BR2_PACKAGE_PCSC_LITE is not set
BR2_PACKAGE_TSLIB=y
# BR2_PACKAGE_URG is not set
# BR2_PACKAGE_WIRINGPI is not set
# Javascript
# BR2_PACKAGE_ANGULARJS is not set
# BR2_PACKAGE_BOOTSTRAP is not set
# BR2_PACKAGE_DUKTAPE is not set
# BR2_PACKAGE_EXPLORERCANVAS is not set
# BR2_PACKAGE_FLOT is not set
# BR2_PACKAGE_JQUERY is not set
# BR2_PACKAGE_JSMIN is not set
# BR2_PACKAGE_JSON_JAVASCRIPT is not set
# JSON/XML
# BR2_PACKAGE_BENEJSON is not set
# BR2_PACKAGE_CJSON is not set
# BR2_PACKAGE_EXPAT is not set
# BR2_PACKAGE_EZXML is not set
# BR2_PACKAGE_JANSSON is not set
# BR2_PACKAGE_JOSE is not set
# BR2_PACKAGE_JSMN is not set
# BR2_PACKAGE_JSON_C is not set
# BR2_PACKAGE_JSON_FOR_MODERN_CPP is not set
# BR2_PACKAGE_JSON_GLIB is not set
# BR2_PACKAGE_JSONCPP is not set
# BR2_PACKAGE_LIBBSON is not set
# BR2_PACKAGE_LIBFASTJSON is not set
# BR2_PACKAGE_LIBJSON is not set
# BR2_PACKAGE_LIBROXML is not set
# BR2_PACKAGE_LIBUCL is not set
# BR2_PACKAGE_LIBXML2 is not set
# BR2_PACKAGE_LIBXMLPP is not set
# BR2_PACKAGE_LIBXMLRPC is not set
# BR2_PACKAGE_LIBXSLT is not set
# BR2_PACKAGE_LIBYAML is not set
# BR2_PACKAGE_MXML is not set
# BR2_PACKAGE_PUGIXML is not set
# BR2_PACKAGE_RAPIDJSON is not set
# BR2_PACKAGE_RAPIDXML is not set
# BR2_PACKAGE_RAPTOR is not set
# BR2_PACKAGE_TINYXML is not set
# BR2_PACKAGE_TINYXML2 is not set
# BR2_PACKAGE_VALIJSON is not set
# BR2_PACKAGE_XERCES is not set
# BR2_PACKAGE_YAJL is not set
# BR2_PACKAGE_YAML_CPP is not set
# Logging
# BR2_PACKAGE_EVENTLOG is not set
# BR2_PACKAGE_GLOG is not set
# BR2_PACKAGE_LIBLOG4C_LOCALTIME is not set
# BR2_PACKAGE_LIBLOGGING is not set
# BR2_PACKAGE_LOG4CPLUS is not set
# BR2_PACKAGE_LOG4CPP is not set
# BR2_PACKAGE_LOG4CXX is not set
# BR2_PACKAGE_OPENTRACING_CPP is not set
# BR2_PACKAGE_SPDLOG is not set
# BR2_PACKAGE_ZLOG is not set
# Multimedia
# BR2_PACKAGE_BITSTREAM is not set
# BR2_PACKAGE_KVAZAAR is not set
# BR2_PACKAGE_LIBAACS is not set
# BR2_PACKAGE_LIBASS is not set
# BR2_PACKAGE_LIBBDPLUS is not set
# BR2_PACKAGE_LIBBLURAY is not set
# libcamera needs udev and a toolchain w/ C++, threads, gcc >= 5
# BR2_PACKAGE_LIBDCADEC is not set
# BR2_PACKAGE_LIBDVBCSA is not set
# BR2_PACKAGE_LIBDVBPSI is not set
# BR2_PACKAGE_LIBDVBSI is not set
# BR2_PACKAGE_LIBDVDCSS is not set
# BR2_PACKAGE_LIBDVDNAV is not set
# BR2_PACKAGE_LIBDVDREAD is not set
# BR2_PACKAGE_LIBEBML is not set
# BR2_PACKAGE_LIBHDHOMERUN is not set
# libimxvpuapi needs an i.MX platform with VPU support
# BR2_PACKAGE_LIBMATROSKA is not set
# BR2_PACKAGE_LIBMMS is not set
# BR2_PACKAGE_LIBMPEG2 is not set
# BR2_PACKAGE_LIBOGG is not set
BR2_PACKAGE_LIBOPENH264_ARCH_SUPPORTS=y
# BR2_PACKAGE_LIBOPENH264 is not set
# BR2_PACKAGE_LIBOPUSENC is not set
# BR2_PACKAGE_LIBPLAYER is not set
# BR2_PACKAGE_LIBTHEORA is not set
# BR2_PACKAGE_LIBVPX is not set
BR2_PACKAGE_LIBYUV=y
# BR2_PACKAGE_LIVE555 is not set
# BR2_PACKAGE_MEDIASTREAMER is not set
# BR2_PACKAGE_X264 is not set
# BR2_PACKAGE_X265 is not set
# Networking
# BR2_PACKAGE_AGENTPP is not set
# BR2_PACKAGE_ALLJOYN is not set
# BR2_PACKAGE_ALLJOYN_BASE is not set
# BR2_PACKAGE_ALLJOYN_TCL is not set
# BR2_PACKAGE_ALLJOYN_TCL_BASE is not set
# BR2_PACKAGE_AZMQ is not set
# BR2_PACKAGE_AZURE_IOT_SDK_C is not set
# batman-adv needs a Linux kernel to be built
# BR2_PACKAGE_C_ARES is not set
BR2_PACKAGE_CANFESTIVAL_ARCH_SUPPORTS=y
# BR2_PACKAGE_CANFESTIVAL is not set
# BR2_PACKAGE_CGIC is not set
# BR2_PACKAGE_CPPZMQ is not set
# BR2_PACKAGE_CURLPP is not set
# BR2_PACKAGE_CZMQ is not set
# BR2_PACKAGE_DAQ is not set
# BR2_PACKAGE_DAVICI is not set
# BR2_PACKAGE_ENET is not set
# BR2_PACKAGE_FILEMQ is not set
# BR2_PACKAGE_FLICKCURL is not set
# BR2_PACKAGE_FREERADIUS_CLIENT is not set
# BR2_PACKAGE_GEOIP is not set
# BR2_PACKAGE_GLIB_NETWORKING is not set
# BR2_PACKAGE_GRPC is not set
# BR2_PACKAGE_GSSDP is not set
# BR2_PACKAGE_GUPNP is not set
# BR2_PACKAGE_GUPNP_AV is not set
# BR2_PACKAGE_GUPNP_DLNA is not set
# BR2_PACKAGE_IBRCOMMON is not set
# BR2_PACKAGE_IBRDTN is not set
# BR2_PACKAGE_LIBCGI is not set
# BR2_PACKAGE_LIBCGICC is not set
# BR2_PACKAGE_LIBCOAP is not set
# BR2_PACKAGE_LIBCPPRESTSDK is not set
BR2_PACKAGE_LIBCURL=y
BR2_PACKAGE_CURL=y
BR2_PACKAGE_LIBCURL_VERBOSE=y
BR2_PACKAGE_LIBCURL_PROXY_SUPPORT=y
BR2_PACKAGE_LIBCURL_COOKIES_SUPPORT=y
BR2_PACKAGE_LIBCURL_EXTRA_PROTOCOLS_FEATURES=y
BR2_PACKAGE_LIBCURL_TLS_SUPPORT=y
BR2_PACKAGE_LIBCURL_OPENSSL=y
# BR2_PACKAGE_LIBDNET is not set
# BR2_PACKAGE_LIBEXOSIP2 is not set
# BR2_PACKAGE_LIBFCGI is not set
# BR2_PACKAGE_LIBGSASL is not set
# BR2_PACKAGE_LIBHTP is not set
# BR2_PACKAGE_LIBHTTPPARSER is not set
# BR2_PACKAGE_LIBIDN is not set
# BR2_PACKAGE_LIBIDN2 is not set
# BR2_PACKAGE_LIBISCSI is not set
# BR2_PACKAGE_LIBKRB5 is not set
# BR2_PACKAGE_LIBLDNS is not set
# BR2_PACKAGE_LIBMAXMINDDB is not set
# BR2_PACKAGE_LIBMBUS is not set
# BR2_PACKAGE_LIBMEMCACHED is not set
# BR2_PACKAGE_LIBMICROHTTPD is not set
# BR2_PACKAGE_LIBMINIUPNPC is not set
# BR2_PACKAGE_LIBMNL is not set
BR2_PACKAGE_LIBMODBUS=y
# BR2_PACKAGE_LIBNATPMP is not set
# BR2_PACKAGE_LIBNDP is not set
# BR2_PACKAGE_LIBNET is not set
# BR2_PACKAGE_LIBNETFILTER_ACCT is not set
# BR2_PACKAGE_LIBNETFILTER_CONNTRACK is not set
# BR2_PACKAGE_LIBNETFILTER_CTHELPER is not set
# BR2_PACKAGE_LIBNETFILTER_CTTIMEOUT is not set
# BR2_PACKAGE_LIBNETFILTER_LOG is not set
# BR2_PACKAGE_LIBNETFILTER_QUEUE is not set
# BR2_PACKAGE_LIBNFNETLINK is not set
# BR2_PACKAGE_LIBNFTNL is not set
# BR2_PACKAGE_LIBNICE is not set
BR2_PACKAGE_LIBNL=y
# BR2_PACKAGE_LIBNL_TOOLS is not set
# BR2_PACKAGE_LIBOAUTH is not set
# BR2_PACKAGE_LIBOPING is not set
# BR2_PACKAGE_LIBOSIP2 is not set
# BR2_PACKAGE_LIBPAGEKITE is not set
# BR2_PACKAGE_LIBPCAP is not set
# BR2_PACKAGE_LIBPJSIP is not set
# BR2_PACKAGE_LIBRSYNC is not set
# BR2_PACKAGE_LIBSHAIRPLAY is not set
# BR2_PACKAGE_LIBSHOUT is not set
# BR2_PACKAGE_LIBSOCKETCAN is not set
# BR2_PACKAGE_LIBSOUP is not set
# BR2_PACKAGE_LIBSRTP is not set
# BR2_PACKAGE_LIBSTROPHE is not set
# BR2_PACKAGE_LIBTIRPC is not set
# BR2_PACKAGE_LIBTORRENT is not set
# BR2_PACKAGE_LIBTORRENT_RASTERBAR is not set
# BR2_PACKAGE_LIBUPNP is not set
# BR2_PACKAGE_LIBUPNP18 is not set
# BR2_PACKAGE_LIBUPNPP is not set
# BR2_PACKAGE_LIBURIPARSER is not set
BR2_PACKAGE_LIBVNCSERVER=y
# BR2_PACKAGE_LIBVNCSERVER_TIGHTPNG is not set
# BR2_PACKAGE_LIBWEBSOCK is not set
# BR2_PACKAGE_LIBWEBSOCKETS is not set
# BR2_PACKAGE_LKSCTP_TOOLS is not set
# BR2_PACKAGE_MONGOOSE is not set
# BR2_PACKAGE_NANOMSG is not set
# BR2_PACKAGE_NEON is not set
# BR2_PACKAGE_NGHTTP2 is not set
# BR2_PACKAGE_NORM is not set
# nss-myhostname needs a glibc toolchain
# nss-pam-ldapd needs a glibc toolchain
# BR2_PACKAGE_OMNIORB is not set
# BR2_PACKAGE_OPENLDAP is not set
# BR2_PACKAGE_OPENMPI is not set
# BR2_PACKAGE_OPENPGM is not set
# BR2_PACKAGE_OPENZWAVE is not set
# BR2_PACKAGE_ORTP is not set
# BR2_PACKAGE_PAHO_MQTT_C is not set
# BR2_PACKAGE_PAHO_MQTT_CPP is not set
# BR2_PACKAGE_QDECODER is not set
# BR2_PACKAGE_QPID_PROTON is not set
# BR2_PACKAGE_RABBITMQ_C is not set
# BR2_PACKAGE_RTMPDUMP is not set
# BR2_PACKAGE_SLIRP is not set
# BR2_PACKAGE_SNMPPP is not set
# BR2_PACKAGE_SOFIA_SIP is not set
# BR2_PACKAGE_THRIFT is not set
# BR2_PACKAGE_USBREDIR is not set
# BR2_PACKAGE_WAMPCC is not set
# BR2_PACKAGE_WEBSOCKETPP is not set
# BR2_PACKAGE_ZEROMQ is not set
# BR2_PACKAGE_ZMQPP is not set
# BR2_PACKAGE_ZYRE is not set
# Other
# BR2_PACKAGE_APR is not set
# BR2_PACKAGE_APR_UTIL is not set
# BR2_PACKAGE_ARGP_STANDALONE is not set
# BR2_PACKAGE_ARMADILLO is not set
# BR2_PACKAGE_ATF is not set
# BR2_PACKAGE_BCTOOLBOX is not set
# BR2_PACKAGE_BDWGC is not set
# BR2_PACKAGE_BOOST is not set
# BR2_PACKAGE_C_CAPNPROTO is not set
# BR2_PACKAGE_CAPNPROTO is not set
# BR2_PACKAGE_CLANG is not set
# BR2_PACKAGE_CLAPACK is not set
BR2_PACKAGE_CLASSPATH_ARCH_SUPPORTS=y
# BR2_PACKAGE_CLASSPATH is not set
# BR2_PACKAGE_CMOCKA is not set
# BR2_PACKAGE_CPPCMS is not set
# BR2_PACKAGE_CRACKLIB is not set
# BR2_PACKAGE_DAWGDIC is not set
# BR2_PACKAGE_DING_LIBS is not set
# BR2_PACKAGE_EIGEN is not set
# BR2_PACKAGE_ELFUTILS is not set
# BR2_PACKAGE_ELL is not set
# BR2_PACKAGE_FFTW is not set
# BR2_PACKAGE_FLANN is not set
# BR2_PACKAGE_FLATBUFFERS is not set
# BR2_PACKAGE_FLATCC is not set
# BR2_PACKAGE_GCONF is not set
# BR2_PACKAGE_GFLAGS is not set
# BR2_PACKAGE_GLI is not set
# BR2_PACKAGE_GLIBMM is not set
# BR2_PACKAGE_GLM is not set
# BR2_PACKAGE_GMP is not set
# BR2_PACKAGE_GSL is not set
# BR2_PACKAGE_GTEST is not set
BR2_PACKAGE_JEMALLOC_ARCH_SUPPORTS=y
# BR2_PACKAGE_JEMALLOC is not set
# lapack/blas needs a toolchain w/ fortran
# BR2_PACKAGE_LIBARGTABLE2 is not set
BR2_PACKAGE_LIBATOMIC_OPS_ARCH_SUPPORTS=y
# BR2_PACKAGE_LIBATOMIC_OPS is not set
# BR2_PACKAGE_LIBB64 is not set
BR2_PACKAGE_LIBBSD_ARCH_SUPPORTS=y
# BR2_PACKAGE_LIBBSD is not set
# BR2_PACKAGE_LIBCAP is not set
# BR2_PACKAGE_LIBCAP_NG is not set
# libcgroup needs a glibc toolchain w/ C++
# BR2_PACKAGE_LIBCLC is not set
# BR2_PACKAGE_LIBCOFI is not set
# BR2_PACKAGE_LIBCORRECT is not set
# BR2_PACKAGE_LIBCROCO is not set
# BR2_PACKAGE_LIBCROSSGUID is not set
# BR2_PACKAGE_LIBCSV is not set
# BR2_PACKAGE_LIBDAEMON is not set
# BR2_PACKAGE_LIBEE is not set
# BR2_PACKAGE_LIBEV is not set
# BR2_PACKAGE_LIBEVDEV is not set
# BR2_PACKAGE_LIBEVENT is not set
BR2_PACKAGE_LIBFFI=y
# BR2_PACKAGE_LIBGEE is not set
# BR2_PACKAGE_LIBGLIB2 is not set
# BR2_PACKAGE_LIBGLOB is not set
# BR2_PACKAGE_LIBICAL is not set
# BR2_PACKAGE_LIBITE is not set
# BR2_PACKAGE_LIBLINEAR is not set
# BR2_PACKAGE_LIBLOKI is not set
# BR2_PACKAGE_LIBNPTH is not set
BR2_PACKAGE_LIBNSPR_ARCH_SUPPORT=y
# BR2_PACKAGE_LIBNSPR is not set
# BR2_PACKAGE_LIBPFM4 is not set
# BR2_PACKAGE_LIBPLIST is not set
# BR2_PACKAGE_LIBPTHREAD_STUBS is not set
# BR2_PACKAGE_LIBPTHSEM is not set
# BR2_PACKAGE_LIBPWQUALITY is not set
BR2_PACKAGE_LIBSECCOMP_ARCH_SUPPORTS=y
# BR2_PACKAGE_LIBSECCOMP is not set
# BR2_PACKAGE_LIBSIGC is not set
BR2_PACKAGE_LIBSIGSEGV_ARCH_SUPPORTS=y
# BR2_PACKAGE_LIBSIGSEGV is not set
# BR2_PACKAGE_LIBSPATIALINDEX is not set
# BR2_PACKAGE_LIBTASN1 is not set
# BR2_PACKAGE_LIBTOMMATH is not set
# BR2_PACKAGE_LIBTPL is not set
# BR2_PACKAGE_LIBUBOX is not set
# BR2_PACKAGE_LIBUCI is not set
BR2_PACKAGE_LIBUNWIND_ARCH_SUPPORTS=y
# BR2_PACKAGE_LIBUNWIND is not set
BR2_PACKAGE_LIBURCU_ARCH_SUPPORTS=y
# BR2_PACKAGE_LIBURCU is not set
# BR2_PACKAGE_LIBUV is not set
# BR2_PACKAGE_LIGHTNING is not set
# linux-pam needs a uClibc or glibc toolchain w/ wchar, locale, dynamic library
# liquid-dsp requires a glibc or musl toolchain w/ dynamic library
BR2_PACKAGE_LLVM_ARCH_SUPPORTS=y
BR2_PACKAGE_LLVM_TARGET_ARCH="ARM"
# BR2_PACKAGE_LLVM is not set
# BR2_PACKAGE_LTTNG_LIBUST is not set
# BR2_PACKAGE_MPC is not set
# BR2_PACKAGE_MPDECIMAL is not set
# BR2_PACKAGE_MPFR is not set
# BR2_PACKAGE_MPIR is not set
# BR2_PACKAGE_MSGPACK is not set
# BR2_PACKAGE_MTDEV2TUIO is not set
BR2_PACKAGE_OPENBLAS_DEFAULT_TARGET="ARMV5"
BR2_PACKAGE_OPENBLAS_ARCH_SUPPORTS=y
# BR2_PACKAGE_OPENBLAS is not set
# BR2_PACKAGE_ORC is not set
# BR2_PACKAGE_P11_KIT is not set
# BR2_PACKAGE_POCO is not set
BR2_PACKAGE_PROTOBUF_ARCH_SUPPORTS=y
# BR2_PACKAGE_PROTOBUF is not set
# BR2_PACKAGE_PROTOBUF_C is not set
# BR2_PACKAGE_QHULL is not set
# BR2_PACKAGE_QLIBC is not set
# BR2_PACKAGE_RIEMANN_C_CLIENT is not set
# BR2_PACKAGE_SHAPELIB is not set
# BR2_PACKAGE_SKALIBS is not set
# BR2_PACKAGE_SPHINXBASE is not set
# BR2_PACKAGE_TINYCBOR is not set
# BR2_PACKAGE_XAPIAN is not set
# Security
# libselinux needs a glibc toolchain w/ threads, dynamic library
# libsemanage needs a glibc toolchain w/ threads, dynamic library
# BR2_PACKAGE_LIBSEPOL is not set
# BR2_PACKAGE_SAFECLIB is not set
# Text and terminal handling
# BR2_PACKAGE_AUGEAS is not set
# BR2_PACKAGE_ENCHANT is not set
# BR2_PACKAGE_FMT is not set
# BR2_PACKAGE_ICU is not set
# BR2_PACKAGE_LIBCLI is not set
# BR2_PACKAGE_LIBEDIT is not set
# BR2_PACKAGE_LIBENCA is not set
# BR2_PACKAGE_LIBESTR is not set
# BR2_PACKAGE_LIBFRIBIDI is not set
# BR2_PACKAGE_LIBICONV is not set
# BR2_PACKAGE_LIBUNISTRING is not set
# BR2_PACKAGE_LINENOISE is not set
BR2_PACKAGE_NCURSES=y
BR2_PACKAGE_NCURSES_WCHAR=y
BR2_PACKAGE_NCURSES_TARGET_PROGS=y
BR2_PACKAGE_NCURSES_ADDITIONAL_TERMINFO=""
# BR2_PACKAGE_NEWT is not set
# BR2_PACKAGE_ONIGURUMA is not set
# BR2_PACKAGE_PCRE is not set
BR2_PACKAGE_PCRE2=y
BR2_PACKAGE_PCRE2_16=y
# BR2_PACKAGE_PCRE2_32 is not set
BR2_PACKAGE_PCRE2_JIT_ARCH_SUPPORTS=y
# BR2_PACKAGE_PCRE2_JIT is not set
# BR2_PACKAGE_POPT is not set
# BR2_PACKAGE_READLINE is not set
# BR2_PACKAGE_SLANG is not set
# BR2_PACKAGE_TCLAP is not set
# BR2_PACKAGE_USTR is not set
# Mail
# BR2_PACKAGE_DOVECOT is not set
# BR2_PACKAGE_EXIM is not set
# BR2_PACKAGE_FETCHMAIL is not set
# BR2_PACKAGE_HEIRLOOM_MAILX is not set
# BR2_PACKAGE_LIBESMTP is not set
# BR2_PACKAGE_MSMTP is not set
# BR2_PACKAGE_MUTT is not set
# Miscellaneous
# BR2_PACKAGE_AESPIPE is not set
# BR2_PACKAGE_BC is not set
# BR2_PACKAGE_CLAMAV is not set
# BR2_PACKAGE_COLLECTD is not set
# domoticz needs lua 5.3 and a toolchain w/ C++, gcc >= 4.8, NPTL, wchar, dynamic library
# BR2_PACKAGE_EMPTY is not set
# BR2_PACKAGE_GOOGLEFONTDIRECTORY is not set
# BR2_PACKAGE_GSETTINGS_DESKTOP_SCHEMAS is not set
# BR2_PACKAGE_HAVEGED is not set
# BR2_PACKAGE_LINUX_SYSCALL_SUPPORT is not set
# BR2_PACKAGE_MCRYPT is not set
# BR2_PACKAGE_MOBILE_BROADBAND_PROVIDER_INFO is not set
# BR2_PACKAGE_PROJ is not set
BR2_PACKAGE_QEMU_ARCH_SUPPORTS_TARGET=y
# BR2_PACKAGE_QEMU is not set
# BR2_PACKAGE_QPDF is not set
# BR2_PACKAGE_SHARED_MIME_INFO is not set
# BR2_PACKAGE_TASKD is not set
# BR2_PACKAGE_XUTIL_UTIL_MACROS is not set
# Networking applications
# BR2_PACKAGE_AIRCRACK_NG is not set
# BR2_PACKAGE_AOETOOLS is not set
# BR2_PACKAGE_APACHE is not set
# BR2_PACKAGE_ARGUS is not set
# BR2_PACKAGE_ARP_SCAN is not set
# BR2_PACKAGE_ARPTABLES is not set
# BR2_PACKAGE_ASTERISK is not set
# BR2_PACKAGE_ATFTP is not set
# BR2_PACKAGE_AUTOSSH is not set
# BR2_PACKAGE_AVAHI is not set
# BR2_PACKAGE_AXEL is not set
# BR2_PACKAGE_BABELD is not set
# BR2_PACKAGE_BANDWIDTHD is not set
# BR2_PACKAGE_BATCTL is not set
# BR2_PACKAGE_BCUSDK is not set
# BR2_PACKAGE_BIND is not set
# BR2_PACKAGE_BIRD is not set
# BR2_PACKAGE_BLUEZ_UTILS is not set
# BR2_PACKAGE_BLUEZ5_UTILS is not set
# BR2_PACKAGE_BMON is not set
# BR2_PACKAGE_BOA is not set
# BR2_PACKAGE_BOINC is not set
# BR2_PACKAGE_BRCM_PATCHRAM_PLUS is not set
# BR2_PACKAGE_BRIDGE_UTILS is not set
# BR2_PACKAGE_BWM_NG is not set
# BR2_PACKAGE_C_ICAP is not set
# BR2_PACKAGE_CAN_UTILS is not set
# BR2_PACKAGE_CANNELLONI is not set
# BR2_PACKAGE_CHRONY is not set
# BR2_PACKAGE_CIVETWEB is not set
# BR2_PACKAGE_CONNMAN is not set
# connman-gtk needs libgtk3 and a glibc or uClibc toolchain w/ wchar, threads, resolver, dynamic library
# BR2_PACKAGE_CONNTRACK_TOOLS is not set
# BR2_PACKAGE_CORKSCREW is not set
# BR2_PACKAGE_CRDA is not set
# BR2_PACKAGE_CTORRENT is not set
# BR2_PACKAGE_CUPS is not set
# BR2_PACKAGE_DANTE is not set
# BR2_PACKAGE_DARKHTTPD is not set
# BR2_PACKAGE_DEHYDRATED is not set
# BR2_PACKAGE_DHCPCD is not set
# BR2_PACKAGE_DHCPDUMP is not set
BR2_PACKAGE_DNSMASQ=y
BR2_PACKAGE_DNSMASQ_TFTP=y
BR2_PACKAGE_DNSMASQ_DHCP=y
# BR2_PACKAGE_DNSMASQ_DNSSEC is not set
# BR2_PACKAGE_DNSMASQ_IDN is not set
# BR2_PACKAGE_DNSMASQ_CONNTRACK is not set
# BR2_PACKAGE_DRBD_UTILS is not set
BR2_PACKAGE_DROPBEAR=y
BR2_PACKAGE_DROPBEAR_CLIENT=y
# BR2_PACKAGE_DROPBEAR_DISABLE_REVERSEDNS is not set
BR2_PACKAGE_DROPBEAR_SMALL=y
# BR2_PACKAGE_DROPBEAR_WTMP is not set
# BR2_PACKAGE_DROPBEAR_LASTLOG is not set
# BR2_PACKAGE_DROPBEAR_LEGACY_CRYPTO is not set
BR2_PACKAGE_DROPBEAR_LOCALOPTIONS_FILE=""
# BR2_PACKAGE_EBTABLES is not set
# ejabberd needs erlang, toolchain w/ C++
# BR2_PACKAGE_ETHTOOL is not set
# BR2_PACKAGE_FAIFA is not set
# BR2_PACKAGE_FASTD is not set
# BR2_PACKAGE_FCGIWRAP is not set
# BR2_PACKAGE_FLANNEL is not set
# BR2_PACKAGE_FPING is not set
# BR2_PACKAGE_FREESWITCH is not set
# BR2_PACKAGE_GERBERA is not set
# BR2_PACKAGE_GESFTPSERVER is not set
# BR2_PACKAGE_GLORYTUN is not set
# gupnp-tools needs libgtk3
# BR2_PACKAGE_HANS is not set
BR2_PACKAGE_HAPROXY_ARCH_SUPPORTS=y
# BR2_PACKAGE_HAPROXY is not set
# BR2_PACKAGE_HIAWATHA is not set
BR2_PACKAGE_HOSTAPD=y
BR2_PACKAGE_HOSTAPD_DRIVER_HOSTAP=y
BR2_PACKAGE_HOSTAPD_DRIVER_NL80211=y
# BR2_PACKAGE_HOSTAPD_DRIVER_RTW is not set
# BR2_PACKAGE_HOSTAPD_DRIVER_WIRED is not set
BR2_PACKAGE_HOSTAPD_HAS_WIFI_DRIVERS=y
BR2_PACKAGE_HOSTAPD_ACS=y
# BR2_PACKAGE_HOSTAPD_EAP is not set
# BR2_PACKAGE_HOSTAPD_WPS is not set
BR2_PACKAGE_HOSTAPD_VLAN=y
BR2_PACKAGE_HOSTAPD_VLAN_DYNAMIC=y
BR2_PACKAGE_HOSTAPD_VLAN_NETLINK=y
# BR2_PACKAGE_HTTPING is not set
# BR2_PACKAGE_I2PD is not set
# BR2_PACKAGE_IBRDTN_TOOLS is not set
# BR2_PACKAGE_IBRDTND is not set
# BR2_PACKAGE_IFMETRIC is not set
# BR2_PACKAGE_IFTOP is not set
BR2_PACKAGE_IFUPDOWN_SCRIPTS=y
# BR2_PACKAGE_IGD2_FOR_LINUX is not set
# igh-ethercat needs a Linux kernel to be built
# BR2_PACKAGE_IGMPPROXY is not set
# BR2_PACKAGE_INADYN is not set
# BR2_PACKAGE_IODINE is not set
# BR2_PACKAGE_IPERF is not set
# BR2_PACKAGE_IPERF3 is not set
# BR2_PACKAGE_IPROUTE2 is not set
# BR2_PACKAGE_IPSEC_TOOLS is not set
# BR2_PACKAGE_IPSET is not set
# BR2_PACKAGE_IPTABLES is not set
# BR2_PACKAGE_IPTRAF_NG is not set
# BR2_PACKAGE_IPUTILS is not set
# BR2_PACKAGE_IRSSI is not set
BR2_PACKAGE_IW=y
# BR2_PACKAGE_IWD is not set
# BR2_PACKAGE_JANUS_GATEWAY is not set
# BR2_PACKAGE_KEEPALIVED is not set
# BR2_PACKAGE_KISMET is not set
# BR2_PACKAGE_KNOCK is not set
# BR2_PACKAGE_LEAFNODE2 is not set
# BR2_PACKAGE_LFT is not set
# BR2_PACKAGE_LFTP is not set
# BR2_PACKAGE_LIGHTTPD is not set
# BR2_PACKAGE_LINKNX is not set
# BR2_PACKAGE_LINKS is not set
# BR2_PACKAGE_LINPHONE is not set
# BR2_PACKAGE_LINUX_ZIGBEE is not set
# BR2_PACKAGE_LINUXPTP is not set
# BR2_PACKAGE_LLDPD is not set
# BR2_PACKAGE_LRZSZ is not set
# BR2_PACKAGE_LYNX is not set
# BR2_PACKAGE_MACCHANGER is not set
# BR2_PACKAGE_MEMCACHED is not set
# BR2_PACKAGE_MII_DIAG is not set
# BR2_PACKAGE_MINI_SNMPD is not set
# BR2_PACKAGE_MINIDLNA is not set
# BR2_PACKAGE_MINISSDPD is not set
# BR2_PACKAGE_MJPG_STREAMER is not set
# BR2_PACKAGE_MODEM_MANAGER is not set
BR2_PACKAGE_MONGREL2_LIBC_SUPPORTS=y
# BR2_PACKAGE_MONGREL2 is not set
# BR2_PACKAGE_MONKEY is not set
# BR2_PACKAGE_MOSH is not set
# BR2_PACKAGE_MOSQUITTO is not set
# BR2_PACKAGE_MROUTED is not set
# BR2_PACKAGE_MTR is not set
# BR2_PACKAGE_NBD is not set
# BR2_PACKAGE_NCFTP is not set
# BR2_PACKAGE_NDISC6 is not set
# BR2_PACKAGE_NETATALK is not set
# BR2_PACKAGE_NETPLUG is not set
# BR2_PACKAGE_NETSNMP is not set
# BR2_PACKAGE_NETSTAT_NAT is not set
# NetworkManager needs udev /dev management and a glibc toolchain w/ headers >= 3.2, dynamic library
# BR2_PACKAGE_NFACCT is not set
# BR2_PACKAGE_NFTABLES is not set
# BR2_PACKAGE_NGINX is not set
# BR2_PACKAGE_NGIRCD is not set
# BR2_PACKAGE_NGREP is not set
# BR2_PACKAGE_NLOAD is not set
# BR2_PACKAGE_NMAP is not set
# BR2_PACKAGE_NOIP is not set
# BR2_PACKAGE_NTP is not set
# BR2_PACKAGE_NUTTCP is not set
# BR2_PACKAGE_ODHCP6C is not set
# BR2_PACKAGE_ODHCPLOC is not set
# BR2_PACKAGE_OLSR is not set
# BR2_PACKAGE_OPEN_LLDP is not set
# BR2_PACKAGE_OPEN_PLC_UTILS is not set
# BR2_PACKAGE_OPENNTPD is not set
# BR2_PACKAGE_OPENOBEX is not set
# BR2_PACKAGE_OPENRESOLV is not set
# BR2_PACKAGE_OPENSSH is not set
# BR2_PACKAGE_OPENSWAN is not set
# BR2_PACKAGE_OPENVPN is not set
# BR2_PACKAGE_P910ND is not set
# BR2_PACKAGE_PHIDGETWEBSERVICE is not set
# BR2_PACKAGE_PHYTOOL is not set
# BR2_PACKAGE_PIMD is not set
# BR2_PACKAGE_PIXIEWPS is not set
# BR2_PACKAGE_POUND is not set
# BR2_PACKAGE_PPPD is not set
# BR2_PACKAGE_PPTP_LINUX is not set
# BR2_PACKAGE_PRIVOXY is not set
# BR2_PACKAGE_PROFTPD is not set
# prosody needs the lua interpreter, dynamic library
# BR2_PACKAGE_PROXYCHAINS_NG is not set
# BR2_PACKAGE_PTPD is not set
# BR2_PACKAGE_PTPD2 is not set
# BR2_PACKAGE_PURE_FTPD is not set
# BR2_PACKAGE_PUTTY is not set
# BR2_PACKAGE_QUAGGA is not set
# rabbitmq-server needs erlang
# BR2_PACKAGE_RADVD is not set
# BR2_PACKAGE_REAVER is not set
# BR2_PACKAGE_RP_PPPOE is not set
# BR2_PACKAGE_RPCBIND is not set
# BR2_PACKAGE_RSH_REDONE is not set
# BR2_PACKAGE_RSYNC is not set
# BR2_PACKAGE_RTORRENT is not set
# BR2_PACKAGE_RTPTOOLS is not set
# BR2_PACKAGE_RYGEL is not set
# BR2_PACKAGE_S6_DNS is not set
# BR2_PACKAGE_S6_NETWORKING is not set
# BR2_PACKAGE_SAMBA4 is not set
# BR2_PACKAGE_SCONESERVER is not set
# BR2_PACKAGE_SER2NET is not set
# BR2_PACKAGE_SHADOWSOCKS_LIBEV is not set
# BR2_PACKAGE_SHAIRPORT_SYNC is not set
# BR2_PACKAGE_SHELLINABOX is not set
# BR2_PACKAGE_SMCROUTE is not set
# BR2_PACKAGE_SNGREP is not set
# BR2_PACKAGE_SNORT is not set
# BR2_PACKAGE_SOCAT is not set
# BR2_PACKAGE_SOCKETCAND is not set
# BR2_PACKAGE_SOFTETHER is not set
# BR2_PACKAGE_SPAWN_FCGI is not set
# BR2_PACKAGE_SPICE_PROTOCOL is not set
# BR2_PACKAGE_SQUID is not set
# BR2_PACKAGE_SSHGUARD is not set
# BR2_PACKAGE_SSHPASS is not set
# BR2_PACKAGE_SSLH is not set
# BR2_PACKAGE_STRONGSWAN is not set
# BR2_PACKAGE_STUNNEL is not set
# BR2_PACKAGE_SURICATA is not set
# BR2_PACKAGE_TCPDUMP is not set
# BR2_PACKAGE_TCPING is not set
# BR2_PACKAGE_TCPREPLAY is not set
# BR2_PACKAGE_THTTPD is not set
# BR2_PACKAGE_TINC is not set
# BR2_PACKAGE_TINYHTTPD is not set
# BR2_PACKAGE_TOR is not set
# BR2_PACKAGE_TRACEROUTE is not set
# BR2_PACKAGE_TRANSMISSION is not set
# BR2_PACKAGE_TUNCTL is not set
# BR2_PACKAGE_TVHEADEND is not set
# BR2_PACKAGE_UDPCAST is not set
# BR2_PACKAGE_UFTP is not set
# BR2_PACKAGE_UHTTPD is not set
# BR2_PACKAGE_ULOGD is not set
# BR2_PACKAGE_USHARE is not set
# BR2_PACKAGE_USSP_PUSH is not set
# BR2_PACKAGE_VDE2 is not set
# vdr needs a glibc toolchain w/ C++, dynamic library, NPTL, wchar, headers >= 3.9
# BR2_PACKAGE_VNSTAT is not set
# BR2_PACKAGE_VPNC is not set
# BR2_PACKAGE_VSFTPD is not set
# BR2_PACKAGE_VTUN is not set
# BR2_PACKAGE_WAVEMON is not set
# BR2_PACKAGE_WIREGUARD is not set
# BR2_PACKAGE_WIRELESS_REGDB is not set
# BR2_PACKAGE_WIRELESS_TOOLS is not set
# BR2_PACKAGE_WIRESHARK is not set
BR2_PACKAGE_WPA_SUPPLICANT=y
BR2_PACKAGE_WPA_SUPPLICANT_NL80211=y
# BR2_PACKAGE_WPA_SUPPLICANT_AP_SUPPORT is not set
# BR2_PACKAGE_WPA_SUPPLICANT_AUTOSCAN is not set
# BR2_PACKAGE_WPA_SUPPLICANT_EAP is not set
# BR2_PACKAGE_WPA_SUPPLICANT_HOTSPOT is not set
# BR2_PACKAGE_WPA_SUPPLICANT_DEBUG_SYSLOG is not set
# BR2_PACKAGE_WPA_SUPPLICANT_WPS is not set
BR2_PACKAGE_WPA_SUPPLICANT_CLI=y
# BR2_PACKAGE_WPA_SUPPLICANT_WPA_CLIENT_SO is not set
# BR2_PACKAGE_WPA_SUPPLICANT_PASSPHRASE is not set
# BR2_PACKAGE_WPAN_TOOLS is not set
# BR2_PACKAGE_XINETD is not set
# BR2_PACKAGE_XL2TP is not set
# xtables-addons needs a Linux kernel to be built
# BR2_PACKAGE_ZNC is not set
# Package managers
# Please note:
# - Buildroot does *not* generate binary packages,
# - Buildroot does *not* install any package database.
# It is up to you to provide those by yourself if you
# want to use any of those package managers.
# See the manual:
# http://buildroot.org/manual.html#faq-no-binary-packages
# BR2_PACKAGE_OPKG is not set
# Real-Time
BR2_PACKAGE_XENOMAI_COBALT_ARCH_SUPPORTS=y
# BR2_PACKAGE_XENOMAI is not set
# Security
# checkpolicy needs a glibc toolchain w/ threads, dynamic library
# BR2_PACKAGE_OPTEE_BENCHMARK is not set
# BR2_PACKAGE_OPTEE_CLIENT is not set
# paxtest needs a glibc toolchain
# policycoreutils needs a glibc toolchain w/ threads, dynamic library
# refpolicy needs a glibc toolchain w/ threads, dynamic library
# restorecond needs a toolchain w/ wchar, threads, dynamic library
# BR2_PACKAGE_SELINUX_PYTHON is not set
# BR2_PACKAGE_SEMODULE_UTILS is not set
# setools needs a glibc toolchain w/ threads, C++, wchar, dynamic library
# Shell and utilities
# Shells
# BR2_PACKAGE_MKSH is not set
# BR2_PACKAGE_ZSH is not set
# Utilities
# BR2_PACKAGE_AT is not set
# BR2_PACKAGE_CCRYPT is not set
# BR2_PACKAGE_DIALOG is not set
# BR2_PACKAGE_DTACH is not set
# BR2_PACKAGE_EASY_RSA is not set
# BR2_PACKAGE_FILE is not set
# BR2_PACKAGE_GNUPG is not set
# BR2_PACKAGE_GNUPG2 is not set
# BR2_PACKAGE_INOTIFY_TOOLS is not set
# BR2_PACKAGE_LOCKFILE_PROGS is not set
# BR2_PACKAGE_LOGROTATE is not set
# BR2_PACKAGE_LOGSURFER is not set
# BR2_PACKAGE_PDMENU is not set
# BR2_PACKAGE_PINENTRY is not set
# BR2_PACKAGE_RANGER is not set
# BR2_PACKAGE_SCREEN is not set
# BR2_PACKAGE_SUDO is not set
# BR2_PACKAGE_TINI is not set
# tmux needs a toolchain w/ wchar, locale
# BR2_PACKAGE_XMLSTARLET is not set
# BR2_PACKAGE_XXHASH is not set
# System tools
# BR2_PACKAGE_ACL is not set
BR2_PACKAGE_ANDROID_TOOLS=y
BR2_PACKAGE_ANDROID_TOOLS_FASTBOOT_GOOD_KERNEL_HEADERS=y
# fastboot needs a glibc toolchain w/ threads, dynamic library
# BR2_PACKAGE_ANDROID_TOOLS_ADB is not set
BR2_PACKAGE_ANDROID_TOOLS_ADBD=y
# BR2_PACKAGE_ATOP is not set
# BR2_PACKAGE_ATTR is not set
BR2_PACKAGE_AUDIT_ARCH_SUPPORTS=y
# BR2_PACKAGE_AUDIT is not set
# BR2_PACKAGE_CGROUPFS_MOUNT is not set
# BR2_PACKAGE_CIRCUS is not set
# BR2_PACKAGE_CPULOAD is not set
# BR2_PACKAGE_DAEMON is not set
# BR2_PACKAGE_DC3DD is not set
# BR2_PACKAGE_DDRESCUE is not set
# BR2_PACKAGE_DOCKER_CLI is not set
# BR2_PACKAGE_DOCKER_COMPOSE is not set
# docker-containerd needs a glibc or musl toolchain w/ threads
# docker-engine needs a glibc or musl toolchain w/ threads
# BR2_PACKAGE_DOCKER_PROXY is not set
# BR2_PACKAGE_EFIBOOTMGR is not set
BR2_PACKAGE_EFIVAR_ARCH_SUPPORTS=y
# BR2_PACKAGE_EFIVAR is not set
# emlog needs a Linux kernel to be built
# BR2_PACKAGE_FTOP is not set
# BR2_PACKAGE_GETENT is not set
# BR2_PACKAGE_HTOP is not set
BR2_PACKAGE_INITSCRIPTS=y
# BR2_PACKAGE_IOTOP is not set
# BR2_PACKAGE_IPRUTILS is not set
# BR2_PACKAGE_IRQBALANCE is not set
# BR2_PACKAGE_KEYUTILS is not set
# BR2_PACKAGE_KMOD is not set
# kvmtool needs a glibc or musl toolchain w/ dynamic library
# BR2_PACKAGE_LIBOSTREE is not set
# BR2_PACKAGE_LXC is not set
# BR2_PACKAGE_MENDER is not set
# BR2_PACKAGE_MONIT is not set
# BR2_PACKAGE_NCDU is not set
# BR2_PACKAGE_NUT is not set
# pamtester depends on linux-pam
# BR2_PACKAGE_PROCRANK_LINUX is not set
# BR2_PACKAGE_PWGEN is not set
# BR2_PACKAGE_QUOTA is not set
# BR2_PACKAGE_QUOTATOOL is not set
# BR2_PACKAGE_RAUC is not set
# BR2_PACKAGE_S6 is not set
# BR2_PACKAGE_S6_LINUX_INIT is not set
# BR2_PACKAGE_S6_LINUX_UTILS is not set
# BR2_PACKAGE_S6_PORTABLE_UTILS is not set
# BR2_PACKAGE_S6_RC is not set
# BR2_PACKAGE_SCRUB is not set
# BR2_PACKAGE_SCRYPT is not set
# BR2_PACKAGE_SMACK is not set
# supervisor needs the python interpreter
# BR2_PACKAGE_SWUPDATE is not set
BR2_PACKAGE_SYSTEMD_ARCH_SUPPORTS=y
BR2_PACKAGE_SYSTEMD_BOOTCHART_ARCH_SUPPORTS=y
# BR2_PACKAGE_TPM_TOOLS is not set
# BR2_PACKAGE_TPM2_ABRMD is not set
# BR2_PACKAGE_TPM2_TOOLS is not set
# BR2_PACKAGE_TPM2_TOTP is not set
# unscd needs a glibc toolchain
# BR2_PACKAGE_UTIL_LINUX is not set
BR2_PACKAGE_XVISOR_ARCH_SUPPORTS=y
# BR2_PACKAGE_XVISOR is not set
# Text editors and viewers
# BR2_PACKAGE_ED is not set
# BR2_PACKAGE_JOE is not set
# BR2_PACKAGE_MC is not set
# BR2_PACKAGE_MOST is not set
# BR2_PACKAGE_NANO is not set
# BR2_PACKAGE_UEMACS is not set
# Filesystem images
# BR2_TARGET_ROOTFS_AXFS is not set
# BR2_TARGET_ROOTFS_BTRFS is not set
# BR2_TARGET_ROOTFS_CLOOP is not set
# BR2_TARGET_ROOTFS_CPIO is not set
# BR2_TARGET_ROOTFS_CRAMFS is not set
# BR2_TARGET_ROOTFS_EXT2 is not set
# BR2_TARGET_ROOTFS_F2FS is not set
# initramfs needs a Linux kernel to be built
# BR2_TARGET_ROOTFS_JFFS2 is not set
# BR2_TARGET_ROOTFS_ROMFS is not set
# BR2_TARGET_ROOTFS_SQUASHFS is not set
BR2_TARGET_ROOTFS_TAR=y
BR2_TARGET_ROOTFS_TAR_NONE=y
# BR2_TARGET_ROOTFS_TAR_GZIP is not set
# BR2_TARGET_ROOTFS_TAR_BZIP2 is not set
# BR2_TARGET_ROOTFS_TAR_LZ4 is not set
# BR2_TARGET_ROOTFS_TAR_LZMA is not set
# BR2_TARGET_ROOTFS_TAR_LZO is not set
# BR2_TARGET_ROOTFS_TAR_XZ is not set
BR2_TARGET_ROOTFS_TAR_OPTIONS=""
# BR2_TARGET_ROOTFS_UBI is not set
# BR2_TARGET_ROOTFS_UBIFS is not set
# BR2_TARGET_ROOTFS_YAFFS2 is not set
# Bootloaders
# BR2_TARGET_AFBOOT_STM32 is not set
# BR2_TARGET_AT91BOOTSTRAP is not set
# BR2_TARGET_AT91BOOTSTRAP3 is not set
# BR2_TARGET_AT91DATAFLASHBOOT is not set
# BR2_TARGET_BAREBOX is not set
BR2_TARGET_GRUB2_ARCH_SUPPORTS=y
# BR2_TARGET_GRUB2 is not set
# BR2_TARGET_LPC32XXCDL is not set
# BR2_TARGET_MXS_BOOTLETS is not set
# BR2_TARGET_S500_BOOTLOADER is not set
# BR2_TARGET_UBOOT is not set
# Host utilities
# BR2_PACKAGE_HOST_AESPIPE is not set
BR2_PACKAGE_HOST_ANDROID_TOOLS=y
# BR2_PACKAGE_HOST_ANDROID_TOOLS_FASTBOOT is not set
BR2_PACKAGE_HOST_ANDROID_TOOLS_ADB=y
# BR2_PACKAGE_HOST_ANDROID_TOOLS_EXT4_UTILS is not set
# BR2_PACKAGE_HOST_BTRFS_PROGS is not set
# BR2_PACKAGE_HOST_CARGO is not set
# BR2_PACKAGE_HOST_CBOOTIMAGE is not set
# BR2_PACKAGE_HOST_CHECKPOLICY is not set
# BR2_PACKAGE_HOST_CHECKSEC is not set
# BR2_PACKAGE_HOST_CMAKE is not set
# BR2_PACKAGE_HOST_CRAMFS is not set
# BR2_PACKAGE_HOST_CRYPTSETUP is not set
# BR2_PACKAGE_HOST_DBUS_PYTHON is not set
# BR2_PACKAGE_HOST_DFU_UTIL is not set
# BR2_PACKAGE_HOST_DOS2UNIX is not set
# BR2_PACKAGE_HOST_DOSFSTOOLS is not set
# BR2_PACKAGE_HOST_DTC is not set
# BR2_PACKAGE_HOST_E2FSPROGS is not set
# BR2_PACKAGE_HOST_E2TOOLS is not set
# BR2_PACKAGE_HOST_F2FS_TOOLS is not set
# BR2_PACKAGE_HOST_FAKETIME is not set
# BR2_PACKAGE_HOST_FATCAT is not set
# BR2_PACKAGE_HOST_FWUP is not set
# BR2_PACKAGE_HOST_GENEXT2FS is not set
# BR2_PACKAGE_HOST_GENIMAGE is not set
# BR2_PACKAGE_HOST_GENPART is not set
# BR2_PACKAGE_HOST_GNUPG is not set
BR2_PACKAGE_HOST_GO_TARGET_ARCH_SUPPORTS=y
BR2_PACKAGE_HOST_GO_TARGET_CGO_LINKING_SUPPORTS=y
BR2_PACKAGE_HOST_GO_HOST_ARCH_SUPPORTS=y
BR2_PACKAGE_HOST_GO_BOOTSTRAP_ARCH_SUPPORTS=y
BR2_PACKAGE_HOST_GOOGLE_BREAKPAD_ARCH_SUPPORTS=y
# BR2_PACKAGE_HOST_GPTFDISK is not set
# BR2_PACKAGE_HOST_IMAGEMAGICK is not set
# BR2_PACKAGE_HOST_IMX_MKIMAGE is not set
# BR2_PACKAGE_HOST_IMX_USB_LOADER is not set
# BR2_PACKAGE_HOST_JQ is not set
# BR2_PACKAGE_HOST_JSMIN is not set
# BR2_PACKAGE_HOST_LIBP11 is not set
# BR2_PACKAGE_HOST_LPC3250LOADER is not set
# BR2_PACKAGE_HOST_LTTNG_BABELTRACE is not set
# BR2_PACKAGE_HOST_MENDER_ARTIFACT is not set
# BR2_PACKAGE_HOST_MFGTOOLS is not set
# BR2_PACKAGE_HOST_MKPASSWD is not set
# BR2_PACKAGE_HOST_MTD is not set
# BR2_PACKAGE_HOST_MTOOLS is not set
# BR2_PACKAGE_HOST_MXSLDR is not set
# BR2_PACKAGE_HOST_OMAP_U_BOOT_UTILS is not set
# BR2_PACKAGE_HOST_OPENOCD is not set
# BR2_PACKAGE_HOST_OPKG_UTILS is not set
# BR2_PACKAGE_HOST_PARTED is not set
BR2_PACKAGE_HOST_PATCHELF=y
# BR2_PACKAGE_HOST_PKGCONF is not set
# BR2_PACKAGE_HOST_PRU_SOFTWARE_SUPPORT is not set
# BR2_PACKAGE_HOST_PWGEN is not set
# BR2_PACKAGE_HOST_PYTHON_CYTHON is not set
# BR2_PACKAGE_HOST_PYTHON_LXML is not set
# BR2_PACKAGE_HOST_PYTHON_SIX is not set
# BR2_PACKAGE_HOST_PYTHON_XLRD is not set
BR2_PACKAGE_HOST_QEMU_ARCH_SUPPORTS=y
BR2_PACKAGE_HOST_QEMU_SYSTEM_ARCH_SUPPORTS=y
BR2_PACKAGE_HOST_QEMU_USER_ARCH_SUPPORTS=y
# BR2_PACKAGE_HOST_QEMU is not set
# BR2_PACKAGE_HOST_RASPBERRYPI_USBBOOT is not set
# BR2_PACKAGE_HOST_RAUC is not set
# BR2_PACKAGE_HOST_RCW is not set
BR2_PACKAGE_HOST_RUSTC_ARCH_SUPPORTS=y
BR2_PACKAGE_HOST_RUSTC_ARCH="arm"
BR2_PACKAGE_HOST_RUSTC_ABI="eabi"
# BR2_PACKAGE_HOST_RUSTC is not set
BR2_PACKAGE_PROVIDES_HOST_RUSTC="host-rust-bin"
# BR2_PACKAGE_HOST_SAM_BA is not set
# BR2_PACKAGE_HOST_SQUASHFS is not set
# BR2_PACKAGE_HOST_SUNXI_TOOLS is not set
# BR2_PACKAGE_HOST_SWIG is not set
# BR2_PACKAGE_HOST_TEGRARCM is not set
BR2_PACKAGE_HOST_TI_CGT_PRU_ARCH_SUPPORTS=y
# BR2_PACKAGE_HOST_TI_CGT_PRU is not set
# BR2_PACKAGE_HOST_UBOOT_TOOLS is not set
# BR2_PACKAGE_HOST_UTIL_LINUX is not set
# BR2_PACKAGE_HOST_UTP_COM is not set
# BR2_PACKAGE_HOST_VBOOT_UTILS is not set
# BR2_PACKAGE_HOST_XORRISO is not set
# BR2_PACKAGE_HOST_ZIP is not set
# BR2_PACKAGE_HOST_ZSTD is not set
# Legacy config options
# Legacy options removed in 2019.08
# BR2_TARGET_TS4800_MBRBOOT is not set
# BR2_PACKAGE_LIBAMCODEC is not set
# BR2_PACKAGE_ODROID_SCRIPTS is not set
# BR2_PACKAGE_ODROID_MALI is not set
# BR2_PACKAGE_KODI_PLATFORM_AML is not set
# BR2_GCC_VERSION_6_X is not set
# BR2_GCC_VERSION_4_9_X is not set
# BR2_GDB_VERSION_7_12 is not set
# BR2_PACKAGE_XAPP_MKFONTDIR is not set
# BR2_GDB_VERSION_8_0 is not set
# BR2_KERNEL_HEADERS_4_20 is not set
# BR2_KERNEL_HEADERS_5_0 is not set
# Legacy options removed in 2019.05
# BR2_CSKY_DSP is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_COMPOSITOR is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_IQA is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_OPENCV is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_STEREO is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_VCD is not set
# BR2_PACKAGE_LUNIT is not set
# BR2_PACKAGE_FFMPEG_FFSERVER is not set
# BR2_PACKAGE_LIBUMP is not set
# BR2_PACKAGE_SUNXI_MALI is not set
# BR2_BINUTILS_VERSION_2_29_X is not set
# BR2_BINUTILS_VERSION_2_28_X is not set
# BR2_PACKAGE_GST_PLUGINS_BAD_PLUGIN_APEXSINK is not set
# Legacy options removed in 2019.02
# BR2_PACKAGE_QT is not set
# BR2_PACKAGE_QTUIO is not set
# BR2_PACKAGE_PINENTRY_QT4 is not set
# BR2_PACKAGE_POPPLER_QT is not set
# BR2_PACKAGE_OPENCV3_WITH_QT is not set
# BR2_PACKAGE_OPENCV_WITH_QT is not set
# BR2_PACKAGE_AMD_CATALYST_CCCLE is not set
# BR2_PACKAGE_SDL_QTOPIA is not set
# BR2_PACKAGE_PYTHON_PYQT is not set
# BR2_PACKAGE_GNURADIO_QTGUI is not set
# BR2_PACKAGE_LUACRYPTO is not set
# BR2_PACKAGE_TN5250 is not set
# BR2_PACKAGE_BOOST_SIGNALS is not set
# BR2_PACKAGE_FFTW_PRECISION_SINGLE is not set
# BR2_PACKAGE_FFTW_PRECISION_DOUBLE is not set
# BR2_PACKAGE_LUA_5_2 is not set
# BR2_TARGET_GENERIC_PASSWD_MD5 is not set
# Legacy options removed in 2018.11
# BR2_TARGET_XLOADER is not set
# BR2_PACKAGE_TIDSP_BINARIES is not set
# BR2_PACKAGE_DSP_TOOLS is not set
# BR2_PACKAGE_GST_DSP is not set
# BR2_PACKAGE_BOOTUTILS is not set
# BR2_PACKAGE_EXPEDITE is not set
# BR2_PACKAGE_MESA3D_OPENGL_TEXTURE_FLOAT is not set
# BR2_KERNEL_HEADERS_4_10 is not set
# BR2_KERNEL_HEADERS_4_11 is not set
# BR2_KERNEL_HEADERS_4_12 is not set
# BR2_KERNEL_HEADERS_4_13 is not set
# BR2_KERNEL_HEADERS_4_15 is not set
# BR2_KERNEL_HEADERS_4_17 is not set
# BR2_PACKAGE_LIBNFTNL_XML is not set
# BR2_KERNEL_HEADERS_3_2 is not set
# BR2_KERNEL_HEADERS_4_1 is not set
# BR2_KERNEL_HEADERS_4_16 is not set
# BR2_KERNEL_HEADERS_4_18 is not set
# Legacy options removed in 2018.08
# BR2_PACKAGE_DOCKER_ENGINE_STATIC_CLIENT is not set
# BR2_PACKAGE_XSERVER_XORG_SERVER_V_1_19 is not set
# BR2_PACKAGE_XPROTO_APPLEWMPROTO is not set
# BR2_PACKAGE_XPROTO_BIGREQSPROTO is not set
# BR2_PACKAGE_XPROTO_COMPOSITEPROTO is not set
# BR2_PACKAGE_XPROTO_DAMAGEPROTO is not set
# BR2_PACKAGE_XPROTO_DMXPROTO is not set
# BR2_PACKAGE_XPROTO_DRI2PROTO is not set
# BR2_PACKAGE_XPROTO_DRI3PROTO is not set
# BR2_PACKAGE_XPROTO_FIXESPROTO is not set
# BR2_PACKAGE_XPROTO_FONTCACHEPROTO is not set
# BR2_PACKAGE_XPROTO_FONTSPROTO is not set
# BR2_PACKAGE_XPROTO_GLPROTO is not set
# BR2_PACKAGE_XPROTO_INPUTPROTO is not set
# BR2_PACKAGE_XPROTO_KBPROTO is not set
# BR2_PACKAGE_XPROTO_PRESENTPROTO is not set
# BR2_PACKAGE_XPROTO_RANDRPROTO is not set
# BR2_PACKAGE_XPROTO_RECORDPROTO is not set
# BR2_PACKAGE_XPROTO_RENDERPROTO is not set
# BR2_PACKAGE_XPROTO_RESOURCEPROTO is not set
# BR2_PACKAGE_XPROTO_SCRNSAVERPROTO is not set
# BR2_PACKAGE_XPROTO_VIDEOPROTO is not set
# BR2_PACKAGE_XPROTO_WINDOWSWMPROTO is not set
# BR2_PACKAGE_XPROTO_XCMISCPROTO is not set
# BR2_PACKAGE_XPROTO_XEXTPROTO is not set
# BR2_PACKAGE_XPROTO_XF86BIGFONTPROTO is not set
# BR2_PACKAGE_XPROTO_XF86DGAPROTO is not set
# BR2_PACKAGE_XPROTO_XF86DRIPROTO is not set
# BR2_PACKAGE_XPROTO_XF86VIDMODEPROTO is not set
# BR2_PACKAGE_XPROTO_XINERAMAPROTO is not set
# BR2_PACKAGE_XPROTO_XPROTO is not set
# BR2_PACKAGE_XPROTO_XPROXYMANAGEMENTPROTOCOL is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_LIB_OPENGL_OPENGL is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_LIB_OPENGL_GLES2 is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_LIB_OPENGL_GLX is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_LIB_OPENGL_EGL is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_LIB_OPENGL_X11 is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_LIB_OPENGL_WAYLAND is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_LIB_OPENGL_DISPMANX is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_AUDIOMIXER is not set
# BR2_PACKAGE_GST1_PLUGINS_UGLY_PLUGIN_LAME is not set
# BR2_PACKAGE_GST1_PLUGINS_UGLY_PLUGIN_MPG123 is not set
# BR2_GDB_VERSION_7_11 is not set
# BR2_GDB_VERSION_7_10 is not set
# Legacy options removed in 2018.05
# BR2_PACKAGE_MEDIAART_BACKEND_NONE is not set
# BR2_PACKAGE_MEDIAART_BACKEND_GDK_PIXBUF is not set
# BR2_PACKAGE_TI_SGX_AM335X is not set
# BR2_PACKAGE_TI_SGX_AM437X is not set
# BR2_PACKAGE_TI_SGX_AM4430 is not set
# BR2_PACKAGE_TI_SGX_AM5430 is not set
# BR2_PACKAGE_JANUS_AUDIO_BRIDGE is not set
# BR2_PACKAGE_JANUS_ECHO_TEST is not set
# BR2_PACKAGE_JANUS_RECORDPLAY is not set
# BR2_PACKAGE_JANUS_SIP_GATEWAY is not set
# BR2_PACKAGE_JANUS_STREAMING is not set
# BR2_PACKAGE_JANUS_TEXT_ROOM is not set
# BR2_PACKAGE_JANUS_VIDEO_CALL is not set
# BR2_PACKAGE_JANUS_VIDEO_ROOM is not set
# BR2_PACKAGE_JANUS_MQTT is not set
# BR2_PACKAGE_JANUS_RABBITMQ is not set
# BR2_PACKAGE_JANUS_REST is not set
# BR2_PACKAGE_JANUS_UNIX_SOCKETS is not set
# BR2_PACKAGE_JANUS_WEBSOCKETS is not set
# BR2_PACKAGE_IPSEC_SECCTX_DISABLE is not set
# BR2_PACKAGE_IPSEC_SECCTX_ENABLE is not set
# BR2_PACKAGE_IPSEC_SECCTX_KERNEL is not set
# BR2_PACKAGE_LIBTFDI_CPP is not set
# BR2_PACKAGE_JQUERY_UI_THEME_BLACK_TIE is not set
# BR2_PACKAGE_JQUERY_UI_THEME_BLITZER is not set
# BR2_PACKAGE_JQUERY_UI_THEME_CUPERTINO is not set
# BR2_PACKAGE_JQUERY_UI_THEME_DARK_HIVE is not set
# BR2_PACKAGE_JQUERY_UI_THEME_DOT_LUV is not set
# BR2_PACKAGE_JQUERY_UI_THEME_EGGPLANT is not set
# BR2_PACKAGE_JQUERY_UI_THEME_EXCITE_BIKE is not set
# BR2_PACKAGE_JQUERY_UI_THEME_FLICK is not set
# BR2_PACKAGE_JQUERY_UI_THEME_HOT_SNEAKS is not set
# BR2_PACKAGE_JQUERY_UI_THEME_HUMANITY is not set
# BR2_PACKAGE_JQUERY_UI_THEME_LE_FROG is not set
# BR2_PACKAGE_JQUERY_UI_THEME_MINT_CHOC is not set
# BR2_PACKAGE_JQUERY_UI_THEME_OVERCAST is not set
# BR2_PACKAGE_JQUERY_UI_THEME_PEPPER_GRINDER is not set
# BR2_PACKAGE_JQUERY_UI_THEME_REDMOND is not set
# BR2_PACKAGE_JQUERY_UI_THEME_SMOOTHNESS is not set
# BR2_PACKAGE_JQUERY_UI_THEME_SOUTH_STREET is not set
# BR2_PACKAGE_JQUERY_UI_THEME_START is not set
# BR2_PACKAGE_JQUERY_UI_THEME_SUNNY is not set
# BR2_PACKAGE_JQUERY_UI_THEME_SWANKY_PURSE is not set
# BR2_PACKAGE_JQUERY_UI_THEME_TRONTASTIC is not set
# BR2_PACKAGE_JQUERY_UI_THEME_UI_DARKNESS is not set
# BR2_PACKAGE_JQUERY_UI_THEME_UI_LIGHTNESS is not set
# BR2_PACKAGE_JQUERY_UI_THEME_VADER is not set
# BR2_PACKAGE_BLUEZ5_PLUGINS_HEALTH is not set
# BR2_PACKAGE_BLUEZ5_PLUGINS_MIDI is not set
# BR2_PACKAGE_BLUEZ5_PLUGINS_NFC is not set
# BR2_PACKAGE_BLUEZ5_PLUGINS_SAP is not set
# BR2_PACKAGE_BLUEZ5_PLUGINS_SIXAXIS is not set
# BR2_PACKAGE_TRANSMISSION_REMOTE is not set
# BR2_PACKAGE_LIBKCAPI_APPS is not set
# BR2_PACKAGE_MPLAYER is not set
# BR2_PACKAGE_MPLAYER_MPLAYER is not set
# BR2_PACKAGE_MPLAYER_MENCODER is not set
# BR2_PACKAGE_LIBPLAYER_MPLAYER is not set
# BR2_PACKAGE_IQVLINUX is not set
# BR2_BINFMT_FLAT_SEP_DATA is not set
# BR2_bfin is not set
# BR2_PACKAGE_KODI_ADSP_BASIC is not set
# BR2_PACKAGE_KODI_ADSP_FREESURROUND is not set
# Legacy options removed in 2018.02
# BR2_KERNEL_HEADERS_3_4 is not set
# BR2_KERNEL_HEADERS_3_10 is not set
# BR2_KERNEL_HEADERS_3_12 is not set
# BR2_BINUTILS_VERSION_2_27_X is not set
# BR2_PACKAGE_EEPROG is not set
# BR2_PACKAGE_GNUPG2_GPGV2 is not set
# BR2_PACKAGE_IMX_GPU_VIV_APITRACE is not set
# BR2_PACKAGE_IMX_GPU_VIV_G2D is not set
# Legacy options removed in 2017.11
# BR2_PACKAGE_RFKILL is not set
# BR2_PACKAGE_UTIL_LINUX_RESET is not set
# BR2_PACKAGE_POLICYCOREUTILS_AUDIT2ALLOW is not set
# BR2_PACKAGE_POLICYCOREUTILS_RESTORECOND is not set
# BR2_PACKAGE_SEPOLGEN is not set
# BR2_PACKAGE_OPENOBEX_BLUEZ is not set
# BR2_PACKAGE_OPENOBEX_LIBUSB is not set
# BR2_PACKAGE_OPENOBEX_APPS is not set
# BR2_PACKAGE_OPENOBEX_SYSLOG is not set
# BR2_PACKAGE_OPENOBEX_DUMP is not set
# BR2_PACKAGE_AICCU is not set
# BR2_PACKAGE_UTIL_LINUX_LOGIN_UTILS is not set
# Legacy options removed in 2017.08
# BR2_TARGET_GRUB is not set
# BR2_PACKAGE_SIMICSFS is not set
# BR2_BINUTILS_VERSION_2_26_X is not set
BR2_XTENSA_OVERLAY_DIR=""
BR2_XTENSA_CUSTOM_NAME=""
# BR2_PACKAGE_HOST_MKE2IMG is not set
BR2_TARGET_ROOTFS_EXT2_BLOCKS=0
BR2_TARGET_ROOTFS_EXT2_EXTRA_INODES=0
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_CDXAPARSE is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_DATAURISRC is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_DCCP is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_HDVPARSE is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_MVE is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_NUVDEMUX is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_PATCHDETECT is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_SDI is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_TTA is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_VIDEOMEASURE is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_APEXSINK is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_SDL is not set
# BR2_PACKAGE_GST1_PLUGINS_UGLY_PLUGIN_MAD is not set
# BR2_STRIP_none is not set
# BR2_PACKAGE_BEECRYPT_CPP is not set
# BR2_PACKAGE_SPICE_CLIENT is not set
# BR2_PACKAGE_SPICE_GUI is not set
# BR2_PACKAGE_SPICE_TUNNEL is not set
# BR2_PACKAGE_INPUT_TOOLS is not set
# BR2_PACKAGE_INPUT_TOOLS_INPUTATTACH is not set
# BR2_PACKAGE_INPUT_TOOLS_JSCAL is not set
# BR2_PACKAGE_INPUT_TOOLS_JSTEST is not set
# BR2_TOOLCHAIN_EXTERNAL_CODESOURCERY_SH is not set
# BR2_TOOLCHAIN_EXTERNAL_CODESOURCERY_X86 is not set
# BR2_GCC_VERSION_4_8_X is not set
# Legacy options removed in 2017.05
# BR2_PACKAGE_SUNXI_MALI_R2P4 is not set
# BR2_PACKAGE_NODEJS_MODULES_COFFEESCRIPT is not set
# BR2_PACKAGE_NODEJS_MODULES_EXPRESS is not set
# BR2_PACKAGE_BLUEZ5_UTILS_GATTTOOL is not set
# BR2_PACKAGE_OPENOCD_FT2XXX is not set
# BR2_PACKAGE_KODI_RTMPDUMP is not set
# BR2_PACKAGE_KODI_VISUALISATION_FOUNTAIN is not set
# BR2_PACKAGE_PORTMAP is not set
# BR2_BINUTILS_VERSION_2_25_X is not set
# BR2_TOOLCHAIN_BUILDROOT_INET_RPC is not set
BR2_TARGET_ROOTFS_EXT2_EXTRA_BLOCKS=0
# BR2_PACKAGE_SYSTEMD_KDBUS is not set
# BR2_PACKAGE_POLARSSL is not set
# BR2_NBD_CLIENT is not set
# BR2_NBD_SERVER is not set
# BR2_PACKAGE_GMOCK is not set
# BR2_KERNEL_HEADERS_4_8 is not set
# BR2_KERNEL_HEADERS_3_18 is not set
# BR2_GLIBC_VERSION_2_22 is not set
# Legacy options removed in 2017.02
# BR2_PACKAGE_PERL_DB_FILE is not set
# BR2_KERNEL_HEADERS_4_7 is not set
# BR2_KERNEL_HEADERS_4_6 is not set
# BR2_KERNEL_HEADERS_4_5 is not set
# BR2_KERNEL_HEADERS_3_14 is not set
# BR2_TOOLCHAIN_EXTERNAL_MUSL_CROSS is not set
# BR2_UCLIBC_INSTALL_TEST_SUITE is not set
# BR2_TOOLCHAIN_EXTERNAL_BLACKFIN_UCLINUX is not set
# BR2_PACKAGE_MAKEDEVS is not set
# BR2_TOOLCHAIN_EXTERNAL_ARAGO_ARMV7A is not set
# BR2_TOOLCHAIN_EXTERNAL_ARAGO_ARMV5TE is not set
# BR2_PACKAGE_SNOWBALL_HDMISERVICE is not set
# BR2_PACKAGE_SNOWBALL_INIT is not set
# BR2_GDB_VERSION_7_9 is not set
# Legacy options removed in 2016.11
# BR2_PACKAGE_PHP_SAPI_CLI_CGI is not set
# BR2_PACKAGE_PHP_SAPI_CLI_FPM is not set
# BR2_PACKAGE_WVSTREAMS is not set
# BR2_PACKAGE_WVDIAL is not set
# BR2_PACKAGE_WEBKITGTK24 is not set
# BR2_PACKAGE_TORSMO is not set
# BR2_PACKAGE_SSTRIP is not set
# BR2_KERNEL_HEADERS_4_3 is not set
# BR2_KERNEL_HEADERS_4_2 is not set
# BR2_PACKAGE_KODI_ADDON_XVDR is not set
# BR2_PACKAGE_IPKG is not set
# BR2_GCC_VERSION_4_7_X is not set
# BR2_BINUTILS_VERSION_2_24_X is not set
# BR2_PACKAGE_WESTON_RPI is not set
# BR2_GCC_VERSION_4_8_ARC is not set
# BR2_KERNEL_HEADERS_4_0 is not set
# BR2_KERNEL_HEADERS_3_19 is not set
# BR2_PACKAGE_LIBEVAS_GENERIC_LOADERS is not set
# BR2_PACKAGE_ELEMENTARY is not set
# BR2_LINUX_KERNEL_CUSTOM_LOCAL is not set
# Legacy options removed in 2016.08
# BR2_PACKAGE_EFL_JP2K is not set
# BR2_PACKAGE_SYSTEMD_COMPAT is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_LIVEADDER is not set
# BR2_PACKAGE_LIBFSLVPUWRAP is not set
# BR2_PACKAGE_LIBFSLPARSER is not set
# BR2_PACKAGE_LIBFSLCODEC is not set
# BR2_PACKAGE_UBOOT_TOOLS_MKIMAGE_FIT_SIGNATURE_SUPPORT is not set
# BR2_PTHREADS_OLD is not set
# BR2_BINUTILS_VERSION_2_23_X is not set
# BR2_TOOLCHAIN_BUILDROOT_EGLIBC is not set
# BR2_GDB_VERSION_7_8 is not set
# Legacy options removed in 2016.05
# BR2_PACKAGE_OPENVPN_CRYPTO_POLARSSL is not set
# BR2_PACKAGE_NGINX_HTTP_SPDY_MODULE is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_RTP is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_MPG123 is not set
# BR2_TOOLCHAIN_EXTERNAL_CODESOURCERY_POWERPC is not set
# BR2_TOOLCHAIN_EXTERNAL_CODESOURCERY_POWERPC_E500V2 is not set
# BR2_x86_i386 is not set
# BR2_PACKAGE_QT5QUICK1 is not set
BR2_TARGET_UBOOT_CUSTOM_PATCH_DIR=""
# BR2_PACKAGE_XDRIVER_XF86_INPUT_VOID is not set
# BR2_KERNEL_HEADERS_3_17 is not set
# BR2_GDB_VERSION_7_7 is not set
# BR2_PACKAGE_FOOMATIC_FILTERS is not set
# BR2_PACKAGE_SAMBA is not set
# BR2_PACKAGE_KODI_WAVPACK is not set
# BR2_PACKAGE_KODI_RSXS is not set
# BR2_PACKAGE_KODI_GOOM is not set
# BR2_PACKAGE_SYSTEMD_ALL_EXTRAS is not set
# BR2_GCC_VERSION_4_5_X is not set
# BR2_PACKAGE_SQLITE_READLINE is not set
# Legacy options removed in 2016.02
# BR2_PACKAGE_DOVECOT_BZIP2 is not set
# BR2_PACKAGE_DOVECOT_ZLIB is not set
# BR2_PACKAGE_E2FSPROGS_FINDFS is not set
# BR2_PACKAGE_OPENPOWERLINK_DEBUG_LEVEL is not set
# BR2_PACKAGE_OPENPOWERLINK_KERNEL_MODULE is not set
# BR2_PACKAGE_OPENPOWERLINK_LIBPCAP is not set
# BR2_LINUX_KERNEL_SAME_AS_HEADERS is not set
# BR2_PACKAGE_CUPS_PDFTOPS is not set
# BR2_KERNEL_HEADERS_3_16 is not set
# BR2_PACKAGE_PYTHON_PYXML is not set
# BR2_ENABLE_SSP is not set
# BR2_PACKAGE_DIRECTFB_CLE266 is not set
# BR2_PACKAGE_DIRECTFB_UNICHROME is not set
# BR2_PACKAGE_LIBELEMENTARY is not set
# BR2_PACKAGE_LIBEINA is not set
# BR2_PACKAGE_LIBEET is not set
# BR2_PACKAGE_LIBEVAS is not set
# BR2_PACKAGE_LIBECORE is not set
# BR2_PACKAGE_LIBEDBUS is not set
# BR2_PACKAGE_LIBEFREET is not set
# BR2_PACKAGE_LIBEIO is not set
# BR2_PACKAGE_LIBEMBRYO is not set
# BR2_PACKAGE_LIBEDJE is not set
# BR2_PACKAGE_LIBETHUMB is not set
# BR2_PACKAGE_INFOZIP is not set
# BR2_BR2_PACKAGE_NODEJS_0_10_X is not set
# BR2_BR2_PACKAGE_NODEJS_0_12_X is not set
# BR2_BR2_PACKAGE_NODEJS_4_X is not set
# Legacy options removed in 2015.11
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_REAL is not set
# BR2_PACKAGE_MEDIA_CTL is not set
# BR2_PACKAGE_SCHIFRA is not set
# BR2_PACKAGE_ZXING is not set
# BR2_PACKAGE_BLACKBOX is not set
# BR2_KERNEL_HEADERS_3_0 is not set
# BR2_KERNEL_HEADERS_3_11 is not set
# BR2_KERNEL_HEADERS_3_13 is not set
# BR2_KERNEL_HEADERS_3_15 is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_ANDI is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_BLTLOAD is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_CPULOAD is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_DATABUFFER is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_DIOLOAD is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_DOK is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_DRIVERTEST is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_FIRE is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_FLIP is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_FONTS is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_INPUT is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_JOYSTICK is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_KNUCKLES is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_LAYER is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_MATRIX is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_MATRIX_WATER is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_NEO is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_NETLOAD is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_PALETTE is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_PARTICLE is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_PORTER is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_STRESS is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_TEXTURE is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_VIDEO is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_VIDEO_PARTICLE is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_WINDOW is not set
# BR2_PACKAGE_KOBS_NG is not set
# BR2_PACKAGE_SAWMAN is not set
# BR2_PACKAGE_DIVINE is not set
# Legacy options removed in 2015.08
# BR2_PACKAGE_KODI_PVR_ADDONS is not set
# BR2_BINUTILS_VERSION_2_23_2 is not set
# BR2_BINUTILS_VERSION_2_24 is not set
# BR2_BINUTILS_VERSION_2_25 is not set
# BR2_PACKAGE_PERF is not set
# BR2_BINUTILS_VERSION_2_22 is not set
# BR2_PACKAGE_GPU_VIV_BIN_MX6Q is not set
# BR2_TARGET_UBOOT_NETWORK is not set
# Legacy options removed in 2015.05
# BR2_TARGET_ROOTFS_JFFS2_NANDFLASH_512_16K is not set
# BR2_TARGET_ROOTFS_JFFS2_NANDFLASH_2K_128K is not set
# BR2_PACKAGE_MONO_20 is not set
# BR2_PACKAGE_MONO_40 is not set
# BR2_PACKAGE_MONO_45 is not set
# BR2_CIVETWEB_WITH_LUA is not set
# BR2_PACKAGE_TIFF_TIFF2PDF is not set
# BR2_PACKAGE_TIFF_TIFFCP is not set
# BR2_LINUX_KERNEL_EXT_RTAI_PATCH is not set
# BR2_TARGET_GENERIC_PASSWD_DES is not set
# BR2_PACKAGE_GTK2_THEME_HICOLOR is not set
# BR2_PACKAGE_VALGRIND_PTRCHECK is not set
# Legacy options removed in 2015.02
# BR2_PACKAGE_LIBGC is not set
# BR2_PACKAGE_WDCTL is not set
# BR2_PACKAGE_UTIL_LINUX_ARCH is not set
# BR2_PACKAGE_UTIL_LINUX_DDATE is not set
# BR2_PACKAGE_RPM_BZIP2_PAYLOADS is not set
# BR2_PACKAGE_RPM_XZ_PAYLOADS is not set
# BR2_PACKAGE_M4 is not set
# BR2_PACKAGE_FLEX_BINARY is not set
# BR2_PACKAGE_BISON is not set
# BR2_PACKAGE_GOB2 is not set
# BR2_PACKAGE_DISTCC is not set
# BR2_PACKAGE_HASERL_VERSION_0_8_X is not set
# BR2_PACKAGE_STRONGSWAN_TOOLS is not set
# BR2_PACKAGE_XBMC_ADDON_XVDR is not set
# BR2_PACKAGE_XBMC_PVR_ADDONS is not set
# BR2_PACKAGE_XBMC is not set
# BR2_PACKAGE_XBMC_ALSA_LIB is not set
# BR2_PACKAGE_XBMC_AVAHI is not set
# BR2_PACKAGE_XBMC_DBUS is not set
# BR2_PACKAGE_XBMC_LIBBLURAY is not set
# BR2_PACKAGE_XBMC_GOOM is not set
# BR2_PACKAGE_XBMC_RSXS is not set
# BR2_PACKAGE_XBMC_LIBCEC is not set
# BR2_PACKAGE_XBMC_LIBMICROHTTPD is not set
# BR2_PACKAGE_XBMC_LIBNFS is not set
# BR2_PACKAGE_XBMC_RTMPDUMP is not set
# BR2_PACKAGE_XBMC_LIBSHAIRPLAY is not set
# BR2_PACKAGE_XBMC_LIBSMBCLIENT is not set
# BR2_PACKAGE_XBMC_LIBTHEORA is not set
# BR2_PACKAGE_XBMC_LIBUSB is not set
# BR2_PACKAGE_XBMC_LIBVA is not set
# BR2_PACKAGE_XBMC_WAVPACK is not set
# BR2_PREFER_STATIC_LIB is not set
# Legacy options removed in 2014.11
# BR2_x86_generic is not set
# BR2_GCC_VERSION_4_4_X is not set
# BR2_sparc_sparchfleon is not set
# BR2_sparc_sparchfleonv8 is not set
# BR2_sparc_sparcsfleon is not set
# BR2_sparc_sparcsfleonv8 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_XC5000 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_CXGB4 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_IWLWIFI_3160_7260_7 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_IWLWIFI_3160_7260_8 is not set
# Legacy options removed in 2014.08
# BR2_PACKAGE_LIBELF is not set
# BR2_KERNEL_HEADERS_3_8 is not set
# BR2_PACKAGE_GETTEXT_TOOLS is not set
# BR2_PACKAGE_PROCPS is not set
# BR2_BINUTILS_VERSION_2_20_1 is not set
# BR2_BINUTILS_VERSION_2_21 is not set
# BR2_BINUTILS_VERSION_2_23_1 is not set
# BR2_UCLIBC_VERSION_0_9_32 is not set
# BR2_GCC_VERSION_4_3_X is not set
# BR2_GCC_VERSION_4_6_X is not set
# BR2_GDB_VERSION_7_4 is not set
# BR2_GDB_VERSION_7_5 is not set
# BR2_BUSYBOX_VERSION_1_19_X is not set
# BR2_BUSYBOX_VERSION_1_20_X is not set
# BR2_BUSYBOX_VERSION_1_21_X is not set
# BR2_PACKAGE_LIBV4L_DECODE_TM6000 is not set
# BR2_PACKAGE_LIBV4L_IR_KEYTABLE is not set
# BR2_PACKAGE_LIBV4L_V4L2_COMPLIANCE is not set
# BR2_PACKAGE_LIBV4L_V4L2_CTL is not set
# BR2_PACKAGE_LIBV4L_V4L2_DBG is not set
# Legacy options removed in 2014.05
# BR2_PACKAGE_EVTEST_CAPTURE is not set
# BR2_KERNEL_HEADERS_3_6 is not set
# BR2_KERNEL_HEADERS_3_7 is not set
# BR2_PACKAGE_VALA is not set
BR2_PACKAGE_TZDATA_ZONELIST=""
# BR2_PACKAGE_LUA_INTERPRETER_EDITING_NONE is not set
# BR2_PACKAGE_LUA_INTERPRETER_READLINE is not set
# BR2_PACKAGE_LUA_INTERPRETER_LINENOISE is not set
# BR2_PACKAGE_DVB_APPS_UTILS is not set
# BR2_KERNEL_HEADERS_SNAP is not set
# BR2_ROOTFS_DEVICE_CREATION_DYNAMIC_UDEV is not set
# BR2_PACKAGE_UDEV is not set
# BR2_PACKAGE_UDEV_RULES_GEN is not set
# BR2_PACKAGE_UDEV_ALL_EXTRAS is not set
# Legacy options removed in 2014.02
# BR2_sh2 is not set
# BR2_sh3 is not set
# BR2_sh3eb is not set
# BR2_KERNEL_HEADERS_3_1 is not set
# BR2_KERNEL_HEADERS_3_3 is not set
# BR2_KERNEL_HEADERS_3_5 is not set
# BR2_GDB_VERSION_7_2 is not set
# BR2_GDB_VERSION_7_3 is not set
# BR2_PACKAGE_CCACHE is not set
# BR2_HAVE_DOCUMENTATION is not set
# BR2_PACKAGE_AUTOMAKE is not set
# BR2_PACKAGE_AUTOCONF is not set
# BR2_PACKAGE_XSTROKE is not set
# BR2_PACKAGE_LZMA is not set
# BR2_PACKAGE_TTCP is not set
# BR2_PACKAGE_LIBNFC_LLCP is not set
# BR2_PACKAGE_MYSQL_CLIENT is not set
# BR2_PACKAGE_SQUASHFS3 is not set
# BR2_TARGET_ROOTFS_SQUASHFS3 is not set
# BR2_PACKAGE_NETKITBASE is not set
# BR2_PACKAGE_NETKITTELNET is not set
# BR2_PACKAGE_LUASQL is not set
# BR2_PACKAGE_LUACJSON is not set
# Legacy options removed in 2013.11
# BR2_PACKAGE_LVM2_DMSETUP_ONLY is not set
# BR2_PACKAGE_QT_JAVASCRIPTCORE is not set
# BR2_PACKAGE_MODULE_INIT_TOOLS is not set
BR2_TARGET_UBOOT_CUSTOM_GIT_REPO_URL=""
BR2_TARGET_UBOOT_CUSTOM_GIT_VERSION=""
BR2_LINUX_KERNEL_CUSTOM_GIT_REPO_URL=""
BR2_LINUX_KERNEL_CUSTOM_GIT_VERSION=""
# Legacy options removed in 2013.08
# BR2_ARM_OABI is not set
# BR2_PACKAGE_DOSFSTOOLS_DOSFSCK is not set
# BR2_PACKAGE_DOSFSTOOLS_DOSFSLABEL is not set
# BR2_PACKAGE_DOSFSTOOLS_MKDOSFS is not set
# BR2_ELF2FLT is not set
# BR2_VFP_FLOAT is not set
# BR2_PACKAGE_GCC_TARGET is not set
# BR2_HAVE_DEVFILES is not set
buildroot服务器下载: buildroot-2019.08.tar.gz
执行命令:
QT_QPA_GENERIC_PLUGINS=evdevkeyboard:/dev/input/event0 QT_QPA_FONTDIR=/usr/share/fonts/ python BubbleTips.py -platform linuxfb:fb="/dev/fb1"
https://github.com/PyQt5/PyQt/blob/master/Demo/CircleLine.py
#!/usr/bin/env python
# -*- coding: utf-8 -*-
Created on 2019年3月19日
@author: Irony
@site: https://pyqt5.com https://github.com/892768447
@email: 892768447@qq.com
@file: CircleLine
@description:
from math import floor, pi, cos, sin
from random import random, randint
from time import time
from PyQt5.QtCore import QTimer, Qt
from PyQt5.QtGui import QColor, QPainter, QPainterPath, QPen
from PyQt5.QtWidgets import QWidget
__Author__ = 'Irony'
__Copyright__ = 'Copyright (c) 2019'
# 最小和最大半径、半径阈值和填充圆的百分比
radMin = 10
radMax = 80
filledCircle = 30 # 填充圆的百分比
concentricCircle = 60 # 同心圆百分比
radThreshold = 25 # IFF special, over this radius concentric, otherwise filled
# 最小和最大移动速度
speedMin = 0.3
speedMax = 0.6
# 每个圆和模糊效果的最大透明度
maxOpacity = 0.6
colors = [
QColor(52, 168, 83),
QColor(117, 95, 147),
QColor(199, 108, 23),
QColor(194, 62, 55),
QColor(0, 172, 212),
QColor(120, 120, 120)
circleBorder = 10
backgroundLine = colors[0]
backgroundColor = QColor(38, 43, 46)
backgroundMlt = 0.85
lineBorder = 2.5
# 最重要的是:包含它们的整个圆和数组的数目
maxCircles = 8
points = []
# 实验变量
circleExp = 1
circleExpMax = 1.003
circleExpMin = 0.997
circleExpSp = 0.00004
circlePulse = False
# 生成随机整数 a<=x<=b
def randint(a, b):
return floor(random() * (b - a + 1) + a)
# 生成随机小数
def randRange(a, b):
return random() * (b - a) + a
# 生成接近a的随机小数
def hyperRange(a, b):
return random() * random() * random() * (b - a) + a
class Circle:
def __init__(self, background, width, height):
self.background = background
self.x = randRange(-width / 2, width / 2)
self.y = randRange(-height / 2, height / 2)
self.radius = hyperRange(radMin, radMax)
self.filled = (False if randint(
0, 100) > concentricCircle else 'full') if self.radius < radThreshold else (
False if randint(0, 100) > concentricCircle else 'concentric')
self.color = colors[randint(0, len(colors) - 1)]
self.borderColor = colors[randint(0, len(colors) - 1)]
self.opacity = 0.05
self.speed = randRange(speedMin, speedMax) # * (radMin / self.radius)
self.speedAngle = random() * 2 * pi
self.speedx = cos(self.speedAngle) * self.speed
self.speedy = sin(self.speedAngle) * self.speed
spacex = abs((self.x - (-1 if self.speedx < 0 else 1) *
(width / 2 + self.radius)) / self.speedx)
spacey = abs((self.y - (-1 if self.speedy < 0 else 1) *
(height / 2 + self.radius)) / self.speedy)
self.ttl = min(spacex, spacey)
class CircleLineWindow(QWidget):
def __init__(self, *args, **kwargs):
super(CircleLineWindow, self).__init__(*args, **kwargs)
# 设置背景颜色
palette = self.palette()
palette.setColor(palette.Background, backgroundColor)
self.setAutoFillBackground(True)
self.setPalette(palette)
# 获取屏幕大小
geometry = QApplication.instance().desktop().availableGeometry()
self.screenWidth = geometry.width()
self.screenHeight = geometry.height()
self._canDraw = True
self._firstDraw = True
self._timer = QTimer(self, timeout=self.update)
self.init()
def init(self):
points.clear()
# 链接的最小距离
self.linkDist = min(self.screenWidth, self.screenHeight) / 2.4
# 初始化点
for _ in range(maxCircles * 3):
points.append(Circle('', self.screenWidth, self.screenHeight))
self.update()
def showEvent(self, event):
super(CircleLineWindow, self).showEvent(event)
def hideEvent(self, event):
super(CircleLineWindow, self).hideEvent(event)
# 窗口最小化要停止绘制, 减少cpu占用
self._canDraw = False
def paintEvent(self, event):
super(CircleLineWindow, self).paintEvent(event)
if not self._canDraw:
return
painter = QPainter(self)
painter.setRenderHint(QPainter.Antialiasing)
painter.setRenderHint(QPainter.SmoothPixmapTransform)
self.draw(painter)
def draw(self, painter):
if circlePulse:
if circleExp < circleExpMin or circleExp > circleExpMax:
circleExpSp *= -1
circleExp += circleExpSp
painter.translate(self.screenWidth / 2, self.screenHeight / 2)
if self._firstDraw:
t = time()
self.renderPoints(painter, points)
if self._firstDraw:
self._firstDraw = False
# 此处有个比例关系用于设置timer的时间,如果初始窗口很小,没有比例会导致动画很快
t = (time() - t) * 1000 * 2
# 比例最大不能超过1920/800
t = int(min(2.4, self.screenHeight / self.height()) * t) - 1
t = t if t > 15 else 15 # 不能小于15s
print('start timer(%d msec)' % t)
# 开启定时器
self._timer.start(t)
def drawCircle(self, painter, circle):
# circle.radius *= circleExp
if circle.background:
else:
circle.radius /= circleExp
radius = circle.radius
r = radius * circleExp
# 边框颜色设置透明度
c = QColor(circle.borderColor)
c.setAlphaF(circle.opacity)
painter.save()
if circle.filled == 'full':
# 设置背景刷
painter.setBrush(c)
painter.setPen(Qt.NoPen)
else:
# 设置画笔
painter.setPen(
QPen(c, max(1, circleBorder * (radMin - circle.radius) / (radMin - radMax))))
# 画实心圆或者圆圈
painter.drawEllipse(circle.x - r, circle.y - r, 2 * r, 2 * r)
painter.restore()
if circle.filled == 'concentric':
r = radius / 2
# 画圆圈
painter.save()
painter.setBrush(Qt.NoBrush)
painter.setPen(
painter.restore()
circle.x += circle.speedx
circle.y += circle.speedy
if (circle.opacity < maxOpacity):
circle.opacity += 0.01
circle.ttl -= 1
def renderPoints(self, painter, circles):
for i, circle in enumerate(circles):
if circle.ttl < -20:
# 重新初始化一个
circle = Circle('', self.screenWidth, self.screenHeight)
circles[i] = circle
self.drawCircle(painter, circle)
circles_len = len(circles)
for i in range(circles_len - 1):
for j in range(i + 1, circles_len):
deltax = circles[i].x - circles[j].x
deltay = circles[i].y - circles[j].y
dist = pow(pow(deltax, 2) + pow(deltay, 2), 0.5)
# if the circles are overlapping, no laser connecting them
if dist <= circles[i].radius + circles[j].radius:
continue
# otherwise we connect them only if the dist is < linkDist
if dist < self.linkDist:
xi = (1 if circles[i].x < circles[j].x else -
1) * abs(circles[i].radius * deltax / dist)
yi = (1 if circles[i].y < circles[j].y else -
1) * abs(circles[i].radius * deltay / dist)
xj = (-1 if circles[i].x < circles[j].x else 1) * \
abs(circles[j].radius * deltax / dist)
yj = (-1 if circles[i].y < circles[j].y else 1) * \
abs(circles[j].radius * deltay / dist)
path = QPainterPath()
path.moveTo(circles[i].x + xi, circles[i].y + yi)
path.lineTo(circles[j].x + xj, circles[j].y + yj)
# samecolor = circles[i].color == circles[j].color
c = QColor(circles[i].borderColor)
c.setAlphaF(min(circles[i].opacity, circles[j].opacity)
* ((self.linkDist - dist) / self.linkDist))
painter.setPen(QPen(c, (
lineBorder * backgroundMlt if circles[i].background else lineBorder) * (
(self.linkDist - dist) / self.linkDist)))
painter.drawPath(path)
if __name__ == '__main__':
import sys
from PyQt5.QtWidgets import QApplication
app = QApplication(sys.argv)
w = CircleLineWindow()
w.resize(800, 600)
w.show()
sys.exit(app.exec_())
执行命令:
QT_QPA_GENERIC_PLUGINS=evdevkeyboard:/dev/input/event0 QT_QPA_FONTDIR=/usr/share/fonts/ python CircleLine.py -platform linuxfb:fb="/dev/fb1"
卡片电脑淘宝下架了?
卡片电脑淘宝下架了?
没有下架,淘宝地址:https://item.taobao.com/item.htm?ft=t&id=589990576029
不错哦。 有这么多玩家,我刚刚开始玩这个
这个玩法有创意,用记事本就可以写程序了。
能用Python+Qt写简单的UI, 能支持触控确实比较好玩
pyqt入门应该很快吧。。脚本编程语言开发还是更容易很多
用这个配置,没有调出来汉字显示,会是差哪儿了呢?
buildroot-2019.08 配置文件:
# # Automatically generated file; DO NOT EDIT. # Buildroot 2019.08 Configuration # BR2_HAVE_DOT_CONFIG=y BR2_HOST_GCC_AT_LEAST_4_5=y BR2_HOST_GCC_AT_LEAST_4_6=y BR2_HOST_GCC_AT_LEAST_4_7=y BR2_HOST_GCC_AT_LEAST_4_8=y BR2_HOST_GCC_AT_LEAST_4_9=y BR2_HOST_GCC_AT_LEAST_5=y BR2_HOST_GCC_AT_LEAST_6=y BR2_HOST_GCC_AT_LEAST_7=y # # Target options # BR2_SOFT_FLOAT=y BR2_ARCH_HAS_MMU_OPTIONAL=y # BR2_arcle is not set # BR2_arceb is not set BR2_arm=y # BR2_armeb is not set # BR2_aarch64 is not set # BR2_aarch64_be is not set # BR2_csky is not set # BR2_i386 is not set # BR2_m68k is not set # BR2_microblazeel is not set # BR2_microblazebe is not set # BR2_mips is not set # BR2_mipsel is not set # BR2_mips64 is not set # BR2_mips64el is not set # BR2_nds32 is not set # BR2_nios2 is not set # BR2_or1k is not set # BR2_powerpc is not set # BR2_powerpc64 is not set # BR2_powerpc64le is not set # BR2_riscv is not set # BR2_sh is not set # BR2_sparc is not set # BR2_sparc64 is not set # BR2_x86_64 is not set # BR2_xtensa is not set BR2_ARCH_HAS_TOOLCHAIN_BUILDROOT=y BR2_ARCH="arm" BR2_ENDIAN="LITTLE" BR2_GCC_TARGET_ABI="aapcs-linux" BR2_GCC_TARGET_CPU="arm926ej-s" BR2_GCC_TARGET_FLOAT_ABI="soft" BR2_GCC_TARGET_MODE="arm" BR2_BINFMT_SUPPORTS_SHARED=y BR2_READELF_ARCH_NAME="ARM" BR2_BINFMT_ELF=y BR2_ARM_CPU_MAYBE_HAS_FPU=y BR2_ARM_CPU_MAYBE_HAS_VFPV2=y BR2_ARM_CPU_HAS_ARM=y BR2_ARM_CPU_HAS_THUMB=y BR2_ARM_CPU_ARMV5=y # # armv4 cores # # BR2_arm920t is not set # BR2_arm922t is not set # BR2_fa526 is not set # BR2_strongarm is not set # # armv5 cores # BR2_arm926t=y # BR2_iwmmxt is not set # BR2_xscale is not set # # armv6 cores # # BR2_arm1136j_s is not set # BR2_arm1136jf_s is not set # BR2_arm1176jz_s is not set # BR2_arm1176jzf_s is not set # BR2_arm11mpcore is not set # # armv7a cores # # BR2_cortex_a5 is not set # BR2_cortex_a7 is not set # BR2_cortex_a8 is not set # BR2_cortex_a9 is not set # BR2_cortex_a12 is not set # BR2_cortex_a15 is not set # BR2_cortex_a15_a7 is not set # BR2_cortex_a17 is not set # BR2_cortex_a17_a7 is not set # BR2_pj4 is not set # # armv7m cores # # BR2_cortex_m3 is not set # BR2_cortex_m4 is not set # BR2_cortex_m7 is not set # # armv8 cores # # BR2_cortex_a32 is not set # BR2_cortex_a35 is not set # BR2_cortex_a53 is not set # BR2_cortex_a57 is not set # BR2_cortex_a57_a53 is not set # BR2_cortex_a72 is not set # BR2_cortex_a72_a53 is not set # BR2_cortex_a73 is not set # BR2_cortex_a73_a35 is not set # BR2_cortex_a73_a53 is not set # BR2_exynos_m1 is not set # BR2_xgene1 is not set # # armv8.1a cores # # # armv8.2a cores # # BR2_cortex_a76 is not set # BR2_cortex_a76_a55 is not set # BR2_neoverse_n1 is not set # # armv8.4a cores # # BR2_ARM_ENABLE_VFP is not set BR2_ARM_EABI=y BR2_ARM_SOFT_FLOAT=y BR2_ARM_INSTRUCTIONS_ARM=y # BR2_ARM_INSTRUCTIONS_THUMB is not set # # Build options # # # Commands # BR2_WGET="wget --passive-ftp -nd -t 3" BR2_SVN="svn --non-interactive" BR2_BZR="bzr" BR2_GIT="git" BR2_CVS="cvs" BR2_LOCALFILES="cp" BR2_SCP="scp" BR2_HG="hg" BR2_ZCAT="gzip -d -c" BR2_BZCAT="bzcat" BR2_XZCAT="xzcat" BR2_LZCAT="lzip -d -c" BR2_TAR_OPTIONS="" BR2_DEFCONFIG="$(CONFIG_DIR)/defconfig" BR2_DL_DIR="$(TOPDIR)/dl" BR2_HOST_DIR="$(BASE_DIR)/host" # # Mirrors and Download locations # BR2_PRIMARY_SITE="" BR2_BACKUP_SITE="http://sources.buildroot.net" BR2_KERNEL_MIRROR="https://cdn.kernel.org/pub" BR2_GNU_MIRROR="http://ftpmirror.gnu.org" BR2_LUAROCKS_MIRROR="http://rocks.moonscript.org" BR2_CPAN_MIRROR="http://cpan.metacpan.org" BR2_JLEVEL=0 # BR2_CCACHE is not set # BR2_ENABLE_DEBUG is not set BR2_STRIP_strip=y BR2_STRIP_EXCLUDE_FILES="" BR2_STRIP_EXCLUDE_DIRS="" # BR2_OPTIMIZE_0 is not set # BR2_OPTIMIZE_1 is not set # BR2_OPTIMIZE_2 is not set # BR2_OPTIMIZE_3 is not set # BR2_OPTIMIZE_G is not set BR2_OPTIMIZE_S=y # BR2_OPTIMIZE_FAST is not set # BR2_GOOGLE_BREAKPAD_ENABLE is not set # BR2_STATIC_LIBS is not set BR2_SHARED_LIBS=y # BR2_SHARED_STATIC_LIBS is not set BR2_PACKAGE_OVERRIDE_FILE="$(CONFIG_DIR)/local.mk" BR2_GLOBAL_PATCH_DIR="" # # Advanced # BR2_COMPILER_PARANOID_UNSAFE_PATH=y # BR2_FORCE_HOST_BUILD is not set # BR2_REPRODUCIBLE is not set # # Security Hardening Options # # BR2_PIC_PIE is not set # # Stack Smashing Protection needs a toolchain w/ SSP # BR2_RELRO_NONE=y # BR2_RELRO_PARTIAL is not set # BR2_RELRO_FULL is not set # # Fortify Source needs a glibc toolchain and optimization # # # Toolchain # BR2_TOOLCHAIN=y BR2_TOOLCHAIN_USES_UCLIBC=y BR2_TOOLCHAIN_BUILDROOT=y # BR2_TOOLCHAIN_EXTERNAL is not set # # Toolchain Buildroot Options # BR2_TOOLCHAIN_BUILDROOT_VENDOR="buildroot" BR2_TOOLCHAIN_BUILDROOT_UCLIBC=y # BR2_TOOLCHAIN_BUILDROOT_GLIBC is not set # BR2_TOOLCHAIN_BUILDROOT_MUSL is not set BR2_TOOLCHAIN_BUILDROOT_LIBC="uclibc" # # Kernel Header Options # # BR2_KERNEL_HEADERS_4_4 is not set BR2_KERNEL_HEADERS_4_9=y # BR2_KERNEL_HEADERS_4_14 is not set # BR2_KERNEL_HEADERS_4_19 is not set # BR2_KERNEL_HEADERS_5_1 is not set # BR2_KERNEL_HEADERS_5_2 is not set # BR2_KERNEL_HEADERS_VERSION is not set # BR2_KERNEL_HEADERS_CUSTOM_TARBALL is not set # BR2_KERNEL_HEADERS_CUSTOM_GIT is not set BR2_DEFAULT_KERNEL_HEADERS="4.9.190" BR2_PACKAGE_LINUX_HEADERS=y # # uClibc Options # BR2_PACKAGE_UCLIBC=y BR2_UCLIBC_CONFIG="package/uclibc/uClibc-ng.config" BR2_UCLIBC_CONFIG_FRAGMENT_FILES="" BR2_TOOLCHAIN_BUILDROOT_WCHAR=y # BR2_TOOLCHAIN_BUILDROOT_LOCALE is not set BR2_PTHREADS_NATIVE=y # BR2_PTHREADS is not set # BR2_PTHREADS_NONE is not set # BR2_PTHREAD_DEBUG is not set # BR2_TOOLCHAIN_BUILDROOT_USE_SSP is not set BR2_UCLIBC_INSTALL_UTILS=y BR2_UCLIBC_TARGET_ARCH="arm" # # Binutils Options # BR2_PACKAGE_HOST_BINUTILS_SUPPORTS_CFI=y # BR2_BINUTILS_VERSION_2_30_X is not set BR2_BINUTILS_VERSION_2_31_X=y # BR2_BINUTILS_VERSION_2_32_X is not set BR2_BINUTILS_VERSION="2.31.1" BR2_BINUTILS_EXTRA_CONFIG_OPTIONS="" # # GCC Options # # BR2_GCC_VERSION_5_X is not set # BR2_GCC_VERSION_7_X is not set BR2_GCC_VERSION_8_X=y # BR2_GCC_VERSION_9_X is not set BR2_GCC_VERSION="8.3.0" BR2_EXTRA_GCC_CONFIG_OPTIONS="" BR2_TOOLCHAIN_BUILDROOT_CXX=y # BR2_TOOLCHAIN_BUILDROOT_FORTRAN is not set # BR2_GCC_ENABLE_LTO is not set # BR2_GCC_ENABLE_OPENMP is not set # BR2_GCC_ENABLE_GRAPHITE is not set BR2_PACKAGE_HOST_GDB_ARCH_SUPPORTS=y # # Host GDB Options # # BR2_PACKAGE_HOST_GDB is not set # # Toolchain Generic Options # BR2_TOOLCHAIN_SUPPORTS_VARIADIC_MI_THUNK=y BR2_USE_WCHAR=y BR2_INSTALL_LIBSTDCPP=y BR2_TOOLCHAIN_HAS_THREADS=y BR2_TOOLCHAIN_HAS_THREADS_NPTL=y BR2_TOOLCHAIN_HAS_UCONTEXT=y BR2_TOOLCHAIN_SUPPORTS_PIE=y BR2_USE_MMU=y BR2_TARGET_OPTIMIZATION="" BR2_TARGET_LDFLAGS="" # BR2_ECLIPSE_REGISTER is not set BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_0=y BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_1=y BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_2=y BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_3=y BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_4=y BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_5=y BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_6=y BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_7=y BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_8=y BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_9=y BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_10=y BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_11=y BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_12=y BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_13=y BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_14=y BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_15=y BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_16=y BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_17=y BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_18=y BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_19=y BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_0=y BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_1=y BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_2=y BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_3=y BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_4=y BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_5=y BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_6=y BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_7=y BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_8=y BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_9=y BR2_TOOLCHAIN_HEADERS_AT_LEAST="4.9" BR2_TOOLCHAIN_GCC_AT_LEAST_4_3=y BR2_TOOLCHAIN_GCC_AT_LEAST_4_4=y BR2_TOOLCHAIN_GCC_AT_LEAST_4_5=y BR2_TOOLCHAIN_GCC_AT_LEAST_4_6=y BR2_TOOLCHAIN_GCC_AT_LEAST_4_7=y BR2_TOOLCHAIN_GCC_AT_LEAST_4_8=y BR2_TOOLCHAIN_GCC_AT_LEAST_4_9=y BR2_TOOLCHAIN_GCC_AT_LEAST_5=y BR2_TOOLCHAIN_GCC_AT_LEAST_6=y BR2_TOOLCHAIN_GCC_AT_LEAST_7=y BR2_TOOLCHAIN_GCC_AT_LEAST_8=y BR2_TOOLCHAIN_GCC_AT_LEAST="8" BR2_TOOLCHAIN_HAS_MNAN_OPTION=y BR2_TOOLCHAIN_HAS_SYNC_1=y BR2_TOOLCHAIN_HAS_SYNC_2=y BR2_TOOLCHAIN_HAS_SYNC_4=y BR2_TOOLCHAIN_HAS_LIBATOMIC=y BR2_TOOLCHAIN_HAS_ATOMIC=y # # System configuration # BR2_ROOTFS_SKELETON_DEFAULT=y # BR2_ROOTFS_SKELETON_CUSTOM is not set BR2_TARGET_GENERIC_HOSTNAME="buildroot" BR2_TARGET_GENERIC_ISSUE="Welcome to Buildroot" BR2_TARGET_GENERIC_PASSWD_SHA256=y # BR2_TARGET_GENERIC_PASSWD_SHA512 is not set BR2_TARGET_GENERIC_PASSWD_METHOD="sha-256" BR2_INIT_BUSYBOX=y # BR2_INIT_SYSV is not set # BR2_INIT_OPENRC is not set # # systemd needs a glibc toolchain w/ SSP, headers >= 3.10 # # BR2_INIT_NONE is not set # BR2_ROOTFS_DEVICE_CREATION_STATIC is not set BR2_ROOTFS_DEVICE_CREATION_DYNAMIC_DEVTMPFS=y # BR2_ROOTFS_DEVICE_CREATION_DYNAMIC_MDEV is not set # BR2_ROOTFS_DEVICE_CREATION_DYNAMIC_EUDEV is not set BR2_ROOTFS_DEVICE_TABLE="system/device_table.txt" # BR2_ROOTFS_DEVICE_TABLE_SUPPORTS_EXTENDED_ATTRIBUTES is not set # BR2_ROOTFS_MERGED_USR is not set BR2_TARGET_ENABLE_ROOT_LOGIN=y BR2_TARGET_GENERIC_ROOT_PASSWD="" BR2_SYSTEM_BIN_SH_BUSYBOX=y # # bash, dash, mksh, zsh need BR2_PACKAGE_BUSYBOX_SHOW_OTHERS # # BR2_SYSTEM_BIN_SH_NONE is not set BR2_TARGET_GENERIC_GETTY=y BR2_TARGET_GENERIC_GETTY_PORT="console" BR2_TARGET_GENERIC_GETTY_BAUDRATE_KEEP=y # BR2_TARGET_GENERIC_GETTY_BAUDRATE_9600 is not set # BR2_TARGET_GENERIC_GETTY_BAUDRATE_19200 is not set # BR2_TARGET_GENERIC_GETTY_BAUDRATE_38400 is not set # BR2_TARGET_GENERIC_GETTY_BAUDRATE_57600 is not set # BR2_TARGET_GENERIC_GETTY_BAUDRATE_115200 is not set BR2_TARGET_GENERIC_GETTY_BAUDRATE="0" BR2_TARGET_GENERIC_GETTY_TERM="vt100" BR2_TARGET_GENERIC_GETTY_OPTIONS="" BR2_TARGET_GENERIC_REMOUNT_ROOTFS_RW=y BR2_SYSTEM_DHCP="" BR2_SYSTEM_DEFAULT_PATH="/bin:/sbin:/usr/bin:/usr/sbin" BR2_ENABLE_LOCALE_PURGE=y BR2_ENABLE_LOCALE_WHITELIST="C en_US" # BR2_SYSTEM_ENABLE_NLS is not set # BR2_TARGET_TZ_INFO is not set BR2_ROOTFS_USERS_TABLES="" BR2_ROOTFS_OVERLAY="" BR2_ROOTFS_POST_BUILD_SCRIPT="" BR2_ROOTFS_POST_FAKEROOT_SCRIPT="" BR2_ROOTFS_POST_IMAGE_SCRIPT="" # # Kernel # # BR2_LINUX_KERNEL is not set # # Target packages # BR2_PACKAGE_BUSYBOX=y BR2_PACKAGE_BUSYBOX_CONFIG="package/busybox/busybox.config" BR2_PACKAGE_BUSYBOX_CONFIG_FRAGMENT_FILES="" # BR2_PACKAGE_BUSYBOX_SHOW_OTHERS is not set # BR2_PACKAGE_BUSYBOX_INDIVIDUAL_BINARIES is not set # BR2_PACKAGE_BUSYBOX_WATCHDOG is not set BR2_PACKAGE_SKELETON=y BR2_PACKAGE_HAS_SKELETON=y BR2_PACKAGE_PROVIDES_SKELETON="skeleton-init-sysv" BR2_PACKAGE_SKELETON_INIT_COMMON=y BR2_PACKAGE_SKELETON_INIT_SYSV=y # # Audio and video applications # # BR2_PACKAGE_ALSA_UTILS is not set # BR2_PACKAGE_ATEST is not set # BR2_PACKAGE_AUMIX is not set # BR2_PACKAGE_BELLAGIO is not set # BR2_PACKAGE_BLUEZ_ALSA is not set # BR2_PACKAGE_DVBLAST is not set # BR2_PACKAGE_DVDAUTHOR is not set # BR2_PACKAGE_DVDRW_TOOLS is not set # BR2_PACKAGE_ESPEAK is not set # BR2_PACKAGE_FAAD2 is not set BR2_PACKAGE_FFMPEG_ARCH_SUPPORTS=y # BR2_PACKAGE_FFMPEG is not set # BR2_PACKAGE_FLAC is not set # BR2_PACKAGE_FLITE is not set # BR2_PACKAGE_GMRENDER_RESURRECT is not set # BR2_PACKAGE_GSTREAMER is not set # BR2_PACKAGE_GSTREAMER1 is not set # BR2_PACKAGE_JACK1 is not set # BR2_PACKAGE_JACK2 is not set BR2_PACKAGE_KODI_ARCH_SUPPORTS=y # # kodi needs python w/ .py modules, a uClibc or glibc toolchain w/ C++, threads, wchar, dynamic library, gcc >= 4.8, host gcc >= 4.6 # # # kodi needs an OpenGL EGL backend with OpenGL support # # BR2_PACKAGE_LAME is not set # BR2_PACKAGE_MADPLAY is not set # BR2_PACKAGE_MIMIC is not set # # miraclecast needs systemd and a glibc toolchain w/ threads and wchar # # BR2_PACKAGE_MJPEGTOOLS is not set # BR2_PACKAGE_MODPLUGTOOLS is not set # BR2_PACKAGE_MOTION is not set # BR2_PACKAGE_MPD is not set # BR2_PACKAGE_MPD_MPC is not set # BR2_PACKAGE_MPG123 is not set # BR2_PACKAGE_MPV is not set # BR2_PACKAGE_MULTICAT is not set # BR2_PACKAGE_MUSEPACK is not set # BR2_PACKAGE_NCMPC is not set # # on2-8170-libs needs a glibc toolchain and a Linux kernel to be built # # BR2_PACKAGE_OPUS_TOOLS is not set BR2_PACKAGE_PULSEAUDIO_HAS_ATOMIC=y # BR2_PACKAGE_PULSEAUDIO is not set # BR2_PACKAGE_SOX is not set # BR2_PACKAGE_SQUEEZELITE is not set # BR2_PACKAGE_TOVID is not set # BR2_PACKAGE_TSTOOLS is not set # BR2_PACKAGE_TWOLAME is not set # BR2_PACKAGE_UDPXY is not set # BR2_PACKAGE_UPMPDCLI is not set # BR2_PACKAGE_V4L2GRAB is not set # # v4l2loopback needs a Linux kernel to be built # # BR2_PACKAGE_VLC is not set # BR2_PACKAGE_VORBIS_TOOLS is not set # BR2_PACKAGE_WAVPACK is not set # BR2_PACKAGE_YAVTA is not set # BR2_PACKAGE_YMPD is not set # # Compressors and decompressors # # BR2_PACKAGE_BROTLI is not set # BR2_PACKAGE_BZIP2 is not set # BR2_PACKAGE_LZ4 is not set # BR2_PACKAGE_LZIP is not set # BR2_PACKAGE_LZOP is not set # BR2_PACKAGE_P7ZIP is not set # BR2_PACKAGE_PIGZ is not set # BR2_PACKAGE_PIXZ is not set # BR2_PACKAGE_UNRAR is not set # BR2_PACKAGE_XZ is not set # BR2_PACKAGE_ZIP is not set # BR2_PACKAGE_ZSTD is not set # # Debugging, profiling and benchmark # # BR2_PACKAGE_BLKTRACE is not set # BR2_PACKAGE_BONNIE is not set # BR2_PACKAGE_CACHE_CALIBRATOR is not set # # clinfo needs an OpenCL provider # # # dacapo needs OpenJDK # # BR2_PACKAGE_DHRYSTONE is not set # BR2_PACKAGE_DIEHARDER is not set # BR2_PACKAGE_DMALLOC is not set # BR2_PACKAGE_DROPWATCH is not set # BR2_PACKAGE_DSTAT is not set # BR2_PACKAGE_DT is not set # BR2_PACKAGE_DUMA is not set # BR2_PACKAGE_FIO is not set BR2_PACKAGE_GDB_ARCH_SUPPORTS=y # # gdb/gdbserver needs a toolchain w/ threads, threads debug # BR2_PACKAGE_GOOGLE_BREAKPAD_ARCH_SUPPORTS=y # BR2_PACKAGE_GOOGLE_BREAKPAD is not set # BR2_PACKAGE_IOZONE is not set # BR2_PACKAGE_KEXEC is not set # # ktap needs a Linux kernel to be built # # BR2_PACKAGE_LATENCYTOP is not set # BR2_PACKAGE_LMBENCH is not set BR2_PACKAGE_LTP_TESTSUITE_ARCH_SUPPORTS=y # BR2_PACKAGE_LTP_TESTSUITE is not set BR2_PACKAGE_LTRACE_ARCH_SUPPORTS=y # BR2_PACKAGE_LTRACE is not set # BR2_PACKAGE_LTTNG_BABELTRACE is not set # # lttng-modules needs a Linux kernel to be built # # BR2_PACKAGE_LTTNG_TOOLS is not set # BR2_PACKAGE_MEMSTAT is not set # BR2_PACKAGE_NETPERF is not set # BR2_PACKAGE_NETSNIFF_NG is not set # # nmon needs a glibc toolchain # BR2_PACKAGE_OPROFILE_ARCH_SUPPORTS=y # BR2_PACKAGE_OPROFILE is not set # BR2_PACKAGE_PAX_UTILS is not set # # piglit needs glibc or musl # # BR2_PACKAGE_PV is not set # BR2_PACKAGE_RAMSMP is not set # BR2_PACKAGE_RAMSPEED is not set # BR2_PACKAGE_RT_TESTS is not set # BR2_PACKAGE_SPIDEV_TEST is not set # BR2_PACKAGE_STRACE is not set # BR2_PACKAGE_STRESS is not set # BR2_PACKAGE_STRESS_NG is not set # # sysdig needs a glibc or uclibc toolchain w/ C++, gcc >= 4.8, dynamic library and a Linux kernel to be built # # BR2_PACKAGE_TCF_AGENT is not set BR2_PACKAGE_TCF_AGENT_ARCH="arm" BR2_PACKAGE_TCF_AGENT_ARCH_SUPPORTS=y # BR2_PACKAGE_TINYMEMBENCH is not set # BR2_PACKAGE_TRACE_CMD is not set BR2_PACKAGE_TRINITY_ARCH_SUPPORTS=y # BR2_PACKAGE_TRINITY is not set # BR2_PACKAGE_UCLIBC_NG_TEST is not set # BR2_PACKAGE_VMTOUCH is not set # BR2_PACKAGE_WHETSTONE is not set # # Development tools # # BR2_PACKAGE_BINUTILS is not set # BR2_PACKAGE_BSDIFF is not set # BR2_PACKAGE_CHECK is not set BR2_PACKAGE_CMAKE_ARCH_SUPPORTS=y # BR2_PACKAGE_CMAKE_CTEST is not set # BR2_PACKAGE_CPPUNIT is not set # BR2_PACKAGE_CUNIT is not set # BR2_PACKAGE_CVS is not set # BR2_PACKAGE_CXXTEST is not set # BR2_PACKAGE_FLEX is not set # BR2_PACKAGE_GETTEXT is not set BR2_PACKAGE_PROVIDES_HOST_GETTEXT="host-gettext-tiny" # BR2_PACKAGE_GIT is not set # BR2_PACKAGE_GIT_CRYPT is not set # BR2_PACKAGE_GPERF is not set # BR2_PACKAGE_JO is not set # BR2_PACKAGE_JQ is not set # BR2_PACKAGE_LIBTOOL is not set # BR2_PACKAGE_MAKE is not set # BR2_PACKAGE_PKGCONF is not set # BR2_PACKAGE_SUBVERSION is not set # BR2_PACKAGE_TREE is not set # # Filesystem and flash utilities # # BR2_PACKAGE_ABOOTIMG is not set # # aufs-util needs a linux kernel and a toolchain w/ threads # # BR2_PACKAGE_AUTOFS is not set # BR2_PACKAGE_BTRFS_PROGS is not set # BR2_PACKAGE_CIFS_UTILS is not set # BR2_PACKAGE_CPIO is not set # BR2_PACKAGE_CRAMFS is not set # BR2_PACKAGE_CURLFTPFS is not set # BR2_PACKAGE_DAVFS2 is not set # BR2_PACKAGE_DOSFSTOOLS is not set # BR2_PACKAGE_E2FSPROGS is not set # BR2_PACKAGE_E2TOOLS is not set # BR2_PACKAGE_ECRYPTFS_UTILS is not set # BR2_PACKAGE_EXFAT is not set # BR2_PACKAGE_EXFAT_UTILS is not set # BR2_PACKAGE_F2FS_TOOLS is not set # BR2_PACKAGE_FLASHBENCH is not set # BR2_PACKAGE_FSCRYPTCTL is not set # BR2_PACKAGE_FWUP is not set # BR2_PACKAGE_GENEXT2FS is not set # BR2_PACKAGE_GENPART is not set # BR2_PACKAGE_GENROMFS is not set # BR2_PACKAGE_IMX_USB_LOADER is not set # BR2_PACKAGE_MMC_UTILS is not set # BR2_PACKAGE_MTD is not set # BR2_PACKAGE_MTOOLS is not set # BR2_PACKAGE_NFS_UTILS is not set # BR2_PACKAGE_NILFS_UTILS is not set # BR2_PACKAGE_NTFS_3G is not set # BR2_PACKAGE_SP_OOPS_EXTRACT is not set # BR2_PACKAGE_SQUASHFS is not set # BR2_PACKAGE_SSHFS is not set # BR2_PACKAGE_SUNXI_TOOLS is not set # BR2_PACKAGE_UDFTOOLS is not set # BR2_PACKAGE_UNIONFS is not set # BR2_PACKAGE_XFSPROGS is not set # # Fonts, cursors, icons, sounds and themes # # # Cursors # # BR2_PACKAGE_COMIX_CURSORS is not set # BR2_PACKAGE_OBSIDIAN_CURSORS is not set # # Fonts # # BR2_PACKAGE_BITSTREAM_VERA is not set # BR2_PACKAGE_CANTARELL is not set # BR2_PACKAGE_DEJAVU is not set # BR2_PACKAGE_FONT_AWESOME is not set # BR2_PACKAGE_GHOSTSCRIPT_FONTS is not set # BR2_PACKAGE_INCONSOLATA is not set BR2_PACKAGE_LIBERATION=y BR2_PACKAGE_LIBERATION_MONO=y BR2_PACKAGE_LIBERATION_SANS=y BR2_PACKAGE_LIBERATION_SERIF=y # # Icons # # BR2_PACKAGE_GOOGLE_MATERIAL_DESIGN_ICONS is not set # BR2_PACKAGE_HICOLOR_ICON_THEME is not set # # Sounds # # BR2_PACKAGE_SOUND_THEME_BOREALIS is not set # BR2_PACKAGE_SOUND_THEME_FREEDESKTOP is not set # # Themes # # # Games # # BR2_PACKAGE_ASCII_INVADERS is not set # BR2_PACKAGE_CHOCOLATE_DOOM is not set # BR2_PACKAGE_FLARE_ENGINE is not set # BR2_PACKAGE_GNUCHESS is not set # BR2_PACKAGE_LBREAKOUT2 is not set # BR2_PACKAGE_LTRIS is not set # # minetest needs X11 and an OpenGL provider # # BR2_PACKAGE_OPENTYRIAN is not set # BR2_PACKAGE_PRBOOM is not set # BR2_PACKAGE_SL is not set # # solarus needs OpenGL and a toolchain w/ C++, gcc >= 4.8, NPTL, dynamic library # # BR2_PACKAGE_STELLA is not set # # Graphic libraries and applications (graphic/text) # # # Graphic applications # # # cog needs wpewebkit and a toolchain w/ threads # # BR2_PACKAGE_FSWEBCAM is not set # BR2_PACKAGE_GHOSTSCRIPT is not set # # glmark2 needs an OpenGL or an openGL ES and EGL backend provided by mesa3d # # BR2_PACKAGE_GNUPLOT is not set # BR2_PACKAGE_JHEAD is not set # BR2_PACKAGE_LIBVA_UTILS is not set BR2_PACKAGE_NETSURF_ARCH_SUPPORTS=y # BR2_PACKAGE_NETSURF is not set # BR2_PACKAGE_PNGQUANT is not set # # qt5cinex needs an Open(E)GL-capable backend # # BR2_PACKAGE_RRDTOOL is not set # # stellarium needs Qt5 and an OpenGL provider # # BR2_PACKAGE_TESSERACT_OCR is not set # # Graphic libraries # # BR2_PACKAGE_CEGUI06 is not set # BR2_PACKAGE_DIRECTFB is not set # BR2_PACKAGE_EFL is not set # BR2_PACKAGE_FB_TEST_APP is not set # BR2_PACKAGE_FBDUMP is not set # BR2_PACKAGE_FBGRAB is not set # # fbterm needs a toolchain w/ C++, wchar, locale # BR2_PACKAGE_FBV=y BR2_PACKAGE_FBV_PNG=y BR2_PACKAGE_FBV_JPEG=y BR2_PACKAGE_FBV_GIF=y # BR2_PACKAGE_FREERDP is not set # BR2_PACKAGE_IMAGEMAGICK is not set # # linux-fusion needs a Linux kernel to be built # # BR2_PACKAGE_MESA3D is not set # BR2_PACKAGE_OCRAD is not set # BR2_PACKAGE_PSPLASH is not set # BR2_PACKAGE_SDL is not set # BR2_PACKAGE_SDL2 is not set # # Other GUIs # BR2_PACKAGE_QT5_JSCORE_AVAILABLE=y BR2_PACKAGE_QT5=y BR2_PACKAGE_QT5_VERSION_LATEST=y # BR2_PACKAGE_QT5_VERSION_5_6 is not set # # qt53d module needs an OpenGL-capable backend # BR2_PACKAGE_QT5BASE=y BR2_PACKAGE_QT5BASE_CUSTOM_CONF_OPTS="" BR2_PACKAGE_QT5BASE_CONFIG_FILE="" # BR2_PACKAGE_QT5BASE_EXAMPLES is not set BR2_PACKAGE_QT5BASE_NETWORK=y # BR2_PACKAGE_QT5BASE_CONCURRENT is not set BR2_PACKAGE_QT5BASE_SQL=y # BR2_PACKAGE_QT5BASE_MYSQL is not set # BR2_PACKAGE_QT5BASE_PSQL is not set BR2_PACKAGE_QT5BASE_SQLITE_NONE=y # BR2_PACKAGE_QT5BASE_SQLITE_QT is not set # BR2_PACKAGE_QT5BASE_SQLITE_SYSTEM is not set BR2_PACKAGE_QT5BASE_TEST=y BR2_PACKAGE_QT5BASE_XML=y BR2_PACKAGE_QT5BASE_GUI=y BR2_PACKAGE_QT5BASE_WIDGETS=y # # OpenGL support needs an OpenGL-capable backend # BR2_PACKAGE_QT5BASE_LINUXFB=y # # directfb backend available if directfb is enabled # # # X.org XCB backend available if X.org is enabled # # # eglfs backend available if OpenGL and EGL are enabled # BR2_PACKAGE_QT5BASE_DEFAULT_QPA="" BR2_PACKAGE_QT5BASE_PRINTSUPPORT=y # BR2_PACKAGE_QT5BASE_FONTCONFIG is not set # BR2_PACKAGE_QT5BASE_HARFBUZZ is not set # BR2_PACKAGE_QT5BASE_GIF is not set # BR2_PACKAGE_QT5BASE_JPEG is not set # BR2_PACKAGE_QT5BASE_PNG is not set # BR2_PACKAGE_QT5BASE_DBUS is not set # BR2_PACKAGE_QT5BASE_ICU is not set BR2_PACKAGE_QT5BASE_OPENSSL=y BR2_PACKAGE_QT5BASE_TSLIB=y # # qt5canvas3d needs an OpenGL-capable backend # BR2_PACKAGE_QT5CHARTS=y # # qt5connectivity needs neard and/or bluez(5)_utils # # BR2_PACKAGE_QT5DECLARATIVE is not set # BR2_PACKAGE_QT5ENGINIO is not set # # qt5graphicaleffects needs an OpenGL-capable backend # # BR2_PACKAGE_QT5IMAGEFORMATS is not set # BR2_PACKAGE_QT5LOCATION is not set # BR2_PACKAGE_QT5MULTIMEDIA is not set # BR2_PACKAGE_QT5QUICKCONTROLS is not set # BR2_PACKAGE_QT5QUICKCONTROLS2 is not set # BR2_PACKAGE_QT5SCRIPT is not set # BR2_PACKAGE_QT5SCXML is not set # BR2_PACKAGE_QT5SENSORS is not set BR2_PACKAGE_QT5SERIALBUS=y BR2_PACKAGE_QT5SERIALPORT=y BR2_PACKAGE_QT5SVG=y # BR2_PACKAGE_QT5TOOLS is not set # # qt5virtualkeyboard needs an OpenGL-capable backend # # BR2_PACKAGE_QT5VIRTUALKEYBOARD is not set # # qt5wayland needs an OpenGL-capable backend # # BR2_PACKAGE_QT5WEBCHANNEL is not set # BR2_PACKAGE_QT5WEBKIT is not set BR2_PACKAGE_QT5WEBENGINE_ARCH_SUPPORTS=y # # qt5webengine needs udev /dev management and a glibc toolchain w/ gcc >= 4.8, host gcc >= 4.8, threads, wchar # # # qt5webengine needs an OpenGL and EGL-capable backend # # BR2_PACKAGE_QT5WEBSOCKETS is not set # BR2_PACKAGE_QT5XMLPATTERNS is not set # # QT libraries and helper libraries # # BR2_PACKAGE_CUTELYST is not set # BR2_PACKAGE_GRANTLEE is not set # BR2_PACKAGE_KF5 is not set # BR2_PACKAGE_QEXTSERIALPORT is not set # BR2_PACKAGE_QJSON is not set # BR2_PACKAGE_QUAZIP is not set # BR2_PACKAGE_QWT is not set # # tekui needs a Lua interpreter and a toolchain w/ threads, dynamic library # # # weston needs udev and a toolchain w/ locale, threads, dynamic library, headers >= 3.0 # # BR2_PACKAGE_XORG7 is not set # # midori needs libgtk3 and a glibc toolchain w/ C++, gcc >= 6, host gcc >= 4.8 # # BR2_PACKAGE_QT_WEBKIT_KIOSK is not set # # vte needs an OpenGL or an OpenGL-EGL/wayland backend # # BR2_PACKAGE_XKEYBOARD_CONFIG is not set # # Hardware handling # # # Firmware # # BR2_PACKAGE_AM33X_CM3 is not set # BR2_PACKAGE_ARMBIAN_FIRMWARE is not set # BR2_PACKAGE_B43_FIRMWARE is not set # BR2_PACKAGE_LINUX_FIRMWARE is not set # BR2_PACKAGE_MURATA_CYW_FW is not set # BR2_PACKAGE_RPI_BT_FIRMWARE is not set # BR2_PACKAGE_RPI_FIRMWARE is not set # BR2_PACKAGE_RPI_WIFI_FIRMWARE is not set # BR2_PACKAGE_SUNXI_BOARDS is not set # BR2_PACKAGE_TS4900_FPGA is not set # BR2_PACKAGE_UX500_FIRMWARE is not set # BR2_PACKAGE_WILC1000_FIRMWARE is not set # BR2_PACKAGE_WILINK_BT_FIRMWARE is not set # BR2_PACKAGE_ZD1211_FIRMWARE is not set # BR2_PACKAGE_18XX_TI_UTILS is not set # # a10disp needs a Linux kernel to be built # # BR2_PACKAGE_ACPICA is not set # BR2_PACKAGE_ACPID is not set # BR2_PACKAGE_ACPITOOL is not set # BR2_PACKAGE_AER_INJECT is not set # BR2_PACKAGE_AM335X_PRU_PACKAGE is not set # BR2_PACKAGE_AVRDUDE is not set # # bcache-tools needs udev /dev management # # # brickd needs udev /dev management, a toolchain w/ threads, wchar # # BR2_PACKAGE_BRLTTY is not set # BR2_PACKAGE_CBOOTIMAGE is not set # BR2_PACKAGE_CC_TOOL is not set # BR2_PACKAGE_CDRKIT is not set # BR2_PACKAGE_CRYPTSETUP is not set # BR2_PACKAGE_CWIID is not set # # dahdi-linux needs a Linux kernel to be built # # # dahdi-tools needs a toolchain w/ threads and a Linux kernel to be built # # BR2_PACKAGE_DBUS is not set # BR2_PACKAGE_DFU_UTIL is not set # BR2_PACKAGE_DMRAID is not set # # dt-utils needs udev /dev management # # BR2_PACKAGE_DTV_SCAN_TABLES is not set # BR2_PACKAGE_DUMP1090 is not set # BR2_PACKAGE_DVB_APPS is not set # BR2_PACKAGE_DVBSNOOP is not set # BR2_PACKAGE_EDID_DECODE is not set # # eudev needs eudev /dev management # # BR2_PACKAGE_EVEMU is not set BR2_PACKAGE_EVTEST=y # BR2_PACKAGE_FAN_CTRL is not set # BR2_PACKAGE_FCONFIG is not set # BR2_PACKAGE_FIS is not set BR2_PACKAGE_FLASHROM_ARCH_SUPPORTS=y # BR2_PACKAGE_FLASHROM is not set # BR2_PACKAGE_FMTOOLS is not set # BR2_PACKAGE_FREESCALE_IMX is not set # BR2_PACKAGE_FXLOAD is not set # BR2_PACKAGE_GADGETFS_TEST is not set # BR2_PACKAGE_GPM is not set # BR2_PACKAGE_GPSD is not set # BR2_PACKAGE_GPTFDISK is not set # BR2_PACKAGE_GVFS is not set # BR2_PACKAGE_HWDATA is not set # BR2_PACKAGE_HWLOC is not set # BR2_PACKAGE_INPUT_EVENT_DAEMON is not set # BR2_PACKAGE_IOSTAT is not set # BR2_PACKAGE_IPMITOOL is not set # BR2_PACKAGE_IRDA_UTILS is not set # BR2_PACKAGE_KBD is not set # BR2_PACKAGE_LCDPROC is not set # BR2_PACKAGE_LIBUBOOTENV is not set # BR2_PACKAGE_LIBUIO is not set # # linux-backports needs a Linux kernel to be built # # BR2_PACKAGE_LINUXCONSOLETOOLS is not set # BR2_PACKAGE_LIRC_TOOLS is not set # BR2_PACKAGE_LM_SENSORS is not set # BR2_PACKAGE_LSHW is not set # BR2_PACKAGE_LSSCSI is not set # BR2_PACKAGE_LSUIO is not set # BR2_PACKAGE_LUKSMETA is not set # BR2_PACKAGE_LVM2 is not set # # mali-t76x needs a glibc toolchain with armhf enabled # # BR2_PACKAGE_MDADM is not set # BR2_PACKAGE_MEMTESTER is not set # BR2_PACKAGE_MEMTOOL is not set # BR2_PACKAGE_MINICOM is not set # BR2_PACKAGE_NANOCOM is not set # BR2_PACKAGE_NEARD is not set # BR2_PACKAGE_NVME is not set # BR2_PACKAGE_OFONO is not set # # on2-8170-modules needs a Linux kernel to be built # # BR2_PACKAGE_OPEN2300 is not set # BR2_PACKAGE_OPENIPMI is not set # BR2_PACKAGE_OPENOCD is not set # # owl-linux needs a Linux kernel to be built # # BR2_PACKAGE_PARTED is not set # BR2_PACKAGE_PCIUTILS is not set # BR2_PACKAGE_PDBG is not set BR2_PACKAGE_PICOCOM=y # BR2_PACKAGE_PIFMRDS is not set # BR2_PACKAGE_PIGPIO is not set # BR2_PACKAGE_POWERTOP is not set # BR2_PACKAGE_PPS_TOOLS is not set # BR2_PACKAGE_PRU_SOFTWARE_SUPPORT is not set # # pulseview needs a toolchain w/ locale, wchar, threads, dynamic library, C++, gcc >= 4.9 # # BR2_PACKAGE_READ_EDID is not set # BR2_PACKAGE_RNG_TOOLS is not set # BR2_PACKAGE_RPI_USERLAND is not set # BR2_PACKAGE_RS485CONF is not set # BR2_PACKAGE_RTC_TOOLS is not set # # rtl8188eu needs a Linux kernel to be built # # # rtl8189fs needs a Linux kernel to be built # # # rtl8723bs needs a Linux kernel to be built # # # rtl8723bu needs a Linux kernel to be built # # # rtl8821au needs a Linux kernel to be built # # BR2_PACKAGE_SANE_BACKENDS is not set # BR2_PACKAGE_SDPARM is not set BR2_PACKAGE_SEDUTIL_ARCH_SUPPORTS=y # BR2_PACKAGE_SEDUTIL is not set # BR2_PACKAGE_SETSERIAL is not set # BR2_PACKAGE_SG3_UTILS is not set # # sigrok-cli needs a toolchain w/ locale, wchar, threads, dynamic library, gcc >= 4.7 # # BR2_PACKAGE_SISPMCTL is not set # BR2_PACKAGE_SMARTMONTOOLS is not set # BR2_PACKAGE_SMSTOOLS3 is not set # BR2_PACKAGE_SPI_TOOLS is not set # BR2_PACKAGE_SREDIRD is not set # BR2_PACKAGE_STATSERIAL is not set # BR2_PACKAGE_STM32FLASH is not set # # sunxi-cedarx needs a glibc toolchain # # # sunxi-mali needs an EABIhf glibc toolchain # # BR2_PACKAGE_SYSSTAT is not set # BR2_PACKAGE_TARGETCLI_FB is not set # # ti-gfx needs a glibc toolchain and a Linux kernel to be built # # # ti-sgx-km needs a Linux kernel to be built # # # ti-sgx-um needs the ti-sgx-km driver # # # ti-sgx-um needs a glibc toolchain w/ threads # # BR2_PACKAGE_TI_UIM is not set # BR2_PACKAGE_TI_UTILS is not set # BR2_PACKAGE_TRIGGERHAPPY is not set # BR2_PACKAGE_UBOOT_TOOLS is not set # BR2_PACKAGE_UBUS is not set # # uccp420wlan needs a Linux kernel >= 4.2 to be built # # # udisks needs udev /dev management # # # udisks needs a glibc toolchain w/ wchar, threads, dynamic library # # BR2_PACKAGE_UHUBCTL is not set # # upower needs udev /dev management # # BR2_PACKAGE_USB_MODESWITCH is not set # BR2_PACKAGE_USB_MODESWITCH_DATA is not set # # usbmount requires udev to be enabled # # # usbutils needs udev /dev management and toolchain w/ threads # # BR2_PACKAGE_W_SCAN is not set # BR2_PACKAGE_WIPE is not set # BR2_PACKAGE_XORRISO is not set # # xr819-xradio driver needs a Linux kernel to be built # # # Interpreter languages and scripting # # BR2_PACKAGE_4TH is not set # BR2_PACKAGE_ENSCRIPT is not set BR2_PACKAGE_HOST_ERLANG_ARCH_SUPPORTS=y BR2_PACKAGE_ERLANG_ARCH_SUPPORTS=y # BR2_PACKAGE_ERLANG is not set # BR2_PACKAGE_EXECLINE is not set # BR2_PACKAGE_FICL is not set BR2_PACKAGE_GAUCHE_ARCH_SUPPORTS=y # BR2_PACKAGE_GAUCHE is not set # BR2_PACKAGE_GUILE is not set # BR2_PACKAGE_HASERL is not set BR2_PACKAGE_JAMVM_ARCH_SUPPORTS=y # BR2_PACKAGE_JAMVM is not set # BR2_PACKAGE_JIMTCL is not set # BR2_PACKAGE_LUA is not set BR2_PACKAGE_PROVIDES_HOST_LUAINTERPRETER="host-lua" BR2_PACKAGE_LUAJIT_ARCH_SUPPORTS=y # BR2_PACKAGE_LUAJIT is not set # BR2_PACKAGE_MICROPYTHON is not set # BR2_PACKAGE_MOARVM is not set BR2_PACKAGE_HOST_MONO_ARCH_SUPPORTS=y BR2_PACKAGE_MONO_ARCH_SUPPORTS=y # BR2_PACKAGE_MONO is not set BR2_PACKAGE_HOST_OPENJDK_BIN_ARCH_SUPPORTS=y BR2_PACKAGE_OPENJDK_ARCH_SUPPORTS=y # # openjdk needs X.Org # # # openjdk needs glibc, and a toolchain w/ wchar, dynamic library, threads, C++ # # # openjdk does not support soft float configurations # # BR2_PACKAGE_PERL is not set # BR2_PACKAGE_PHP is not set # BR2_PACKAGE_PYTHON is not set BR2_PACKAGE_PYTHON3=y # BR2_PACKAGE_PYTHON3_PY_ONLY is not set BR2_PACKAGE_PYTHON3_PYC_ONLY=y # BR2_PACKAGE_PYTHON3_PY_PYC is not set # # core python3 modules # # # The following modules are unusual or require extra libraries # # BR2_PACKAGE_PYTHON3_BZIP2 is not set # BR2_PACKAGE_PYTHON3_CODECSCJK is not set # BR2_PACKAGE_PYTHON3_CURSES is not set # BR2_PACKAGE_PYTHON3_DECIMAL is not set # BR2_PACKAGE_PYTHON3_OSSAUDIODEV is not set # BR2_PACKAGE_PYTHON3_READLINE is not set # BR2_PACKAGE_PYTHON3_SSL is not set BR2_PACKAGE_PYTHON3_UNICODEDATA=y # BR2_PACKAGE_PYTHON3_SQLITE is not set # BR2_PACKAGE_PYTHON3_PYEXPAT is not set # BR2_PACKAGE_PYTHON3_XZ is not set # BR2_PACKAGE_PYTHON3_ZLIB is not set # # External python modules # # BR2_PACKAGE_PYTHON_AIOBLESCAN is not set # BR2_PACKAGE_PYTHON_AIOCOAP is not set # BR2_PACKAGE_PYTHON_AIOCONSOLE is not set # BR2_PACKAGE_PYTHON_AIODNS is not set # BR2_PACKAGE_PYTHON_AIOHTTP is not set # BR2_PACKAGE_PYTHON_AIOHTTP_CORS is not set # BR2_PACKAGE_PYTHON_AIOHTTP_JINJA2 is not set # BR2_PACKAGE_PYTHON_AIOHTTP_REMOTES is not set # BR2_PACKAGE_PYTHON_AIOHTTP_SECURITY is not set # BR2_PACKAGE_PYTHON_AIOHTTP_SESSION is not set # BR2_PACKAGE_PYTHON_AIOHTTP_SSE is not set # BR2_PACKAGE_PYTHON_AIOJOBS is not set # BR2_PACKAGE_PYTHON_AIOMONITOR is not set # BR2_PACKAGE_PYTHON_AIORWLOCK is not set # BR2_PACKAGE_PYTHON_ALSAAUDIO is not set # BR2_PACKAGE_PYTHON_ARGH is not set # BR2_PACKAGE_PYTHON_ARROW is not set # BR2_PACKAGE_PYTHON_ASN1CRYPTO is not set # BR2_PACKAGE_PYTHON_ASYNC_TIMEOUT is not set # BR2_PACKAGE_PYTHON_ATTRS is not set # BR2_PACKAGE_PYTHON_AUTOBAHN is not set # BR2_PACKAGE_PYTHON_AUTOMAT is not set # BR2_PACKAGE_PYTHON_BABEL is not set # BR2_PACKAGE_PYTHON_BACKCALL is not set # BR2_PACKAGE_PYTHON_BCRYPT is not set # BR2_PACKAGE_PYTHON_BEAUTIFULSOUP4 is not set # BR2_PACKAGE_PYTHON_BITSTRING is not set # BR2_PACKAGE_PYTHON_BOTTLE is not set # BR2_PACKAGE_PYTHON_CACHED_PROPERTY is not set # BR2_PACKAGE_PYTHON_CAN is not set # BR2_PACKAGE_PYTHON_CBOR is not set # BR2_PACKAGE_PYTHON_CCHARDET is not set # BR2_PACKAGE_PYTHON_CERTIFI is not set # BR2_PACKAGE_PYTHON_CFFI is not set # BR2_PACKAGE_PYTHON_CHARACTERISTIC is not set # BR2_PACKAGE_PYTHON_CHARDET is not set # BR2_PACKAGE_PYTHON_CHEROOT is not set # BR2_PACKAGE_PYTHON_CHERRYPY is not set # BR2_PACKAGE_PYTHON_CLICK is not set # BR2_PACKAGE_PYTHON_COLORAMA is not set # BR2_PACKAGE_PYTHON_CONFIGSHELL_FB is not set # BR2_PACKAGE_PYTHON_CONSTANTLY is not set # BR2_PACKAGE_PYTHON_COUCHDB is not set # BR2_PACKAGE_PYTHON_CRCMOD is not set # BR2_PACKAGE_PYTHON_CROSSBAR is not set # BR2_PACKAGE_PYTHON_CRYPTOGRAPHY is not set # BR2_PACKAGE_PYTHON_CSSSELECT is not set # BR2_PACKAGE_PYTHON_CSSUTILS is not set # BR2_PACKAGE_PYTHON_CYCLER is not set # BR2_PACKAGE_PYTHON_DAEMON is not set # BR2_PACKAGE_PYTHON_DAEMONIZE is not set # BR2_PACKAGE_PYTHON_DATAPROPERTY is not set # BR2_PACKAGE_PYTHON_DATEUTIL is not set # BR2_PACKAGE_PYTHON_DECORATOR is not set # BR2_PACKAGE_PYTHON_DIALOG3 is not set # BR2_PACKAGE_PYTHON_DICTTOXML is not set # BR2_PACKAGE_PYTHON_DJANGO is not set # BR2_PACKAGE_PYTHON_DOCKER is not set # BR2_PACKAGE_PYTHON_DOCKER_PYCREDS is not set # BR2_PACKAGE_PYTHON_DOCKERPTY is not set # BR2_PACKAGE_PYTHON_DOCOPT is not set # BR2_PACKAGE_PYTHON_DOCUTILS is not set # BR2_PACKAGE_PYTHON_DOMINATE is not set # BR2_PACKAGE_PYTHON_ECDSA is not set # BR2_PACKAGE_PYTHON_ENGINEIO is not set # BR2_PACKAGE_PYTHON_FALCON is not set # BR2_PACKAGE_PYTHON_FIRE is not set # BR2_PACKAGE_PYTHON_FLASK is not set # BR2_PACKAGE_PYTHON_FLASK_BABEL is not set # BR2_PACKAGE_PYTHON_FLASK_CORS is not set # BR2_PACKAGE_PYTHON_FLASK_JSONRPC is not set # BR2_PACKAGE_PYTHON_FLASK_LOGIN is not set # BR2_PACKAGE_PYTHON_FLASK_SQLALCHEMY is not set # BR2_PACKAGE_PYTHON_GOBJECT is not set # BR2_PACKAGE_PYTHON_GUNICORN is not set # BR2_PACKAGE_PYTHON_H2 is not set # BR2_PACKAGE_PYTHON_HIREDIS is not set # BR2_PACKAGE_PYTHON_HPACK is not set # BR2_PACKAGE_PYTHON_HTML5LIB is not set # BR2_PACKAGE_PYTHON_HTTPLIB2 is not set # BR2_PACKAGE_PYTHON_HUMANIZE is not set # BR2_PACKAGE_PYTHON_HYPERFRAME is not set # BR2_PACKAGE_PYTHON_HYPERLINK is not set # BR2_PACKAGE_PYTHON_IBMIOTF is not set # BR2_PACKAGE_PYTHON_IDNA is not set # BR2_PACKAGE_PYTHON_IFADDR is not set # BR2_PACKAGE_PYTHON_INCREMENTAL is not set # BR2_PACKAGE_PYTHON_INFLECTION is not set # BR2_PACKAGE_PYTHON_INFLUXDB is not set # BR2_PACKAGE_PYTHON_IOWAIT is not set # BR2_PACKAGE_PYTHON_IPTABLES is not set # BR2_PACKAGE_PYTHON_IPYTHON is not set # BR2_PACKAGE_PYTHON_IPYTHON_GENUTILS is not set # BR2_PACKAGE_PYTHON_ISO8601 is not set # BR2_PACKAGE_PYTHON_ITSDANGEROUS is not set # BR2_PACKAGE_PYTHON_JARACO_CLASSES is not set # BR2_PACKAGE_PYTHON_JEDI is not set # BR2_PACKAGE_PYTHON_JINJA2 is not set # BR2_PACKAGE_PYTHON_JSON_SCHEMA_VALIDATOR is not set # BR2_PACKAGE_PYTHON_JSONMODELS is not set # BR2_PACKAGE_PYTHON_JSONSCHEMA is not set # BR2_PACKAGE_PYTHON_KEYRING is not set # BR2_PACKAGE_PYTHON_LIBCONFIG is not set # BR2_PACKAGE_PYTHON_LIBUSB1 is not set # BR2_PACKAGE_PYTHON_LMDB is not set # BR2_PACKAGE_PYTHON_LOGBOOK is not set # BR2_PACKAGE_PYTHON_LXML is not set # BR2_PACKAGE_PYTHON_M2R is not set # BR2_PACKAGE_PYTHON_MAKO is not set # BR2_PACKAGE_PYTHON_MARKDOWN is not set # BR2_PACKAGE_PYTHON_MARKDOWN2 is not set # BR2_PACKAGE_PYTHON_MARKUPSAFE is not set # # python-matplotlib needs glibc or musl # # BR2_PACKAGE_PYTHON_MBSTRDECODER is not set # BR2_PACKAGE_PYTHON_MELD3 is not set # BR2_PACKAGE_PYTHON_MIMEPARSE is not set # BR2_PACKAGE_PYTHON_MISTUNE is not set # BR2_PACKAGE_PYTHON_MORE_ITERTOOLS is not set # BR2_PACKAGE_PYTHON_MSGPACK is not set # BR2_PACKAGE_PYTHON_MULTIDICT is not set # BR2_PACKAGE_PYTHON_MUTAGEN is not set # BR2_PACKAGE_PYTHON_MWCLIENT is not set # BR2_PACKAGE_PYTHON_MWSCRAPE2SLOB is not set # BR2_PACKAGE_PYTHON_NETADDR is not set # BR2_PACKAGE_PYTHON_NETIFACES is not set # BR2_PACKAGE_PYTHON_NETWORKX is not set BR2_PACKAGE_PYTHON_NUMPY_ARCH_SUPPORTS=y # # python-numpy needs glibc or musl # # BR2_PACKAGE_PYTHON_OAUTHLIB is not set # BR2_PACKAGE_PYTHON_PAHO_MQTT is not set # BR2_PACKAGE_PYTHON_PARAMIKO is not set # BR2_PACKAGE_PYTHON_PARSO is not set # BR2_PACKAGE_PYTHON_PASSLIB is not set # BR2_PACKAGE_PYTHON_PATHPY is not set # BR2_PACKAGE_PYTHON_PATHTOOLS is not set # BR2_PACKAGE_PYTHON_PATHVALIDATE is not set # BR2_PACKAGE_PYTHON_PERIPHERY is not set # BR2_PACKAGE_PYTHON_PEXPECT is not set # BR2_PACKAGE_PYTHON_PICKLESHARE is not set # BR2_PACKAGE_PYTHON_PIGPIO is not set # BR2_PACKAGE_PYTHON_PILLOW is not set # BR2_PACKAGE_PYTHON_PIP is not set # BR2_PACKAGE_PYTHON_PLY is not set # BR2_PACKAGE_PYTHON_PORTEND is not set # BR2_PACKAGE_PYTHON_POSIX_IPC is not set # BR2_PACKAGE_PYTHON_PRIORITY is not set # BR2_PACKAGE_PYTHON_PROMPT_TOOLKIT is not set # BR2_PACKAGE_PYTHON_PROTOBUF is not set # BR2_PACKAGE_PYTHON_PSUTIL is not set # BR2_PACKAGE_PYTHON_PSYCOPG2 is not set # BR2_PACKAGE_PYTHON_PTYPROCESS is not set # BR2_PACKAGE_PYTHON_PUDB is not set # BR2_PACKAGE_PYTHON_PY is not set # BR2_PACKAGE_PYTHON_PYASN is not set # BR2_PACKAGE_PYTHON_PYASN_MODULES is not set # BR2_PACKAGE_PYTHON_PYASN1 is not set # BR2_PACKAGE_PYTHON_PYASN1_MODULES is not set # BR2_PACKAGE_PYTHON_PYCAIRO is not set # BR2_PACKAGE_PYTHON_PYCARES is not set # BR2_PACKAGE_PYTHON_PYCLI is not set # BR2_PACKAGE_PYTHON_PYCPARSER is not set # BR2_PACKAGE_PYTHON_PYCRYPTO is not set # BR2_PACKAGE_PYTHON_PYCRYPTODOMEX is not set # BR2_PACKAGE_PYTHON_PYDAL is not set # BR2_PACKAGE_PYTHON_PYELFTOOLS is not set # BR2_PACKAGE_PYTHON_PYFTPDLIB is not set # BR2_PACKAGE_PYTHON_PYGAME is not set # BR2_PACKAGE_PYTHON_PYGMENTS is not set # BR2_PACKAGE_PYTHON_PYHAMCREST is not set # BR2_PACKAGE_PYTHON_PYICU is not set # BR2_PACKAGE_PYTHON_PYINOTIFY is not set # BR2_PACKAGE_PYTHON_PYJWT is not set # BR2_PACKAGE_PYTHON_PYLIBFTDI is not set # BR2_PACKAGE_PYTHON_PYLRU is not set # BR2_PACKAGE_PYTHON_PYMODBUS is not set # BR2_PACKAGE_PYTHON_PYMYSQL is not set # BR2_PACKAGE_PYTHON_PYNACL is not set # BR2_PACKAGE_PYTHON_PYOPENSSL is not set # BR2_PACKAGE_PYTHON_PYPARSING is not set # BR2_PACKAGE_PYTHON_PYPARTED is not set # BR2_PACKAGE_PYTHON_PYQRCODE is not set BR2_PACKAGE_PYTHON_PYQT5=y # BR2_PACKAGE_PYTHON_PYRATEMP is not set # BR2_PACKAGE_PYTHON_PYROUTE2 is not set # BR2_PACKAGE_PYTHON_PYSENDFILE is not set # BR2_PACKAGE_PYTHON_PYSMB is not set # BR2_PACKAGE_PYTHON_PYSMI is not set # BR2_PACKAGE_PYTHON_PYSNMP is not set # BR2_PACKAGE_PYTHON_PYSNMP_APPS is not set # BR2_PACKAGE_PYTHON_PYSNMP_MIBS is not set # BR2_PACKAGE_PYTHON_PYSOCKS is not set # BR2_PACKAGE_PYTHON_PYTABLEREADER is not set # BR2_PACKAGE_PYTHON_PYTABLEWRITER is not set # BR2_PACKAGE_PYTHON_PYTRIE is not set # BR2_PACKAGE_PYTHON_PYTZ is not set # # python-pyudev needs udev /dev management # # BR2_PACKAGE_PYTHON_PYUSB is not set # BR2_PACKAGE_PYTHON_PYXB is not set # BR2_PACKAGE_PYTHON_PYYAML is not set # BR2_PACKAGE_PYTHON_PYZMQ is not set # BR2_PACKAGE_PYTHON_RAVEN is not set # BR2_PACKAGE_PYTHON_REDIS is not set # BR2_PACKAGE_PYTHON_REENTRY is not set # BR2_PACKAGE_PYTHON_REMI is not set # BR2_PACKAGE_PYTHON_REQUEST_ID is not set # BR2_PACKAGE_PYTHON_REQUESTS is not set # BR2_PACKAGE_PYTHON_REQUESTS_OAUTHLIB is not set # BR2_PACKAGE_PYTHON_REQUESTS_TOOLBELT is not set # BR2_PACKAGE_PYTHON_RPI_GPIO is not set # BR2_PACKAGE_PYTHON_RTSLIB_FB is not set # BR2_PACKAGE_PYTHON_SCANDIR is not set # BR2_PACKAGE_PYTHON_SCAPY is not set # BR2_PACKAGE_PYTHON_SCAPY3K is not set # BR2_PACKAGE_PYTHON_SCHEDULE is not set # BR2_PACKAGE_PYTHON_SDNOTIFY is not set # BR2_PACKAGE_PYTHON_SECRETSTORAGE is not set # BR2_PACKAGE_PYTHON_SEE is not set # BR2_PACKAGE_PYTHON_SEMVER is not set # BR2_PACKAGE_PYTHON_SENTRY_SDK is not set # BR2_PACKAGE_PYTHON_SERIAL is not set # BR2_PACKAGE_PYTHON_SERIAL_ASYNCIO is not set # BR2_PACKAGE_PYTHON_SERVICE_IDENTITY is not set # BR2_PACKAGE_PYTHON_SETPROCTITLE is not set # BR2_PACKAGE_PYTHON_SETUPTOOLS is not set # BR2_PACKAGE_PYTHON_SH is not set # BR2_PACKAGE_PYTHON_SHUTILWHICH is not set # BR2_PACKAGE_PYTHON_SIMPLEAUDIO is not set # BR2_PACKAGE_PYTHON_SIMPLEGENERIC is not set # BR2_PACKAGE_PYTHON_SIMPLEJSON is not set # BR2_PACKAGE_PYTHON_SIMPLESQLITE is not set BR2_PACKAGE_PYTHON_SIP=y # BR2_PACKAGE_PYTHON_SIX is not set # BR2_PACKAGE_PYTHON_SLOB is not set # BR2_PACKAGE_PYTHON_SMBUS_CFFI is not set # BR2_PACKAGE_PYTHON_SOCKETIO is not set # BR2_PACKAGE_PYTHON_SORTEDCONTAINERS is not set # BR2_PACKAGE_PYTHON_SPIDEV is not set # BR2_PACKAGE_PYTHON_SQLALCHEMY is not set # # python-systemd needs systemd # # BR2_PACKAGE_PYTHON_TABLEDATA is not set # BR2_PACKAGE_PYTHON_TEMPORA is not set # BR2_PACKAGE_PYTHON_TERMCOLOR is not set # BR2_PACKAGE_PYTHON_TERMINALTABLES is not set # BR2_PACKAGE_PYTHON_TEXTTABLE is not set # BR2_PACKAGE_PYTHON_TINYRPC is not set # BR2_PACKAGE_PYTHON_TOMAKO is not set # BR2_PACKAGE_PYTHON_TOML is not set # BR2_PACKAGE_PYTHON_TORNADO is not set # BR2_PACKAGE_PYTHON_TRAITLETS is not set # BR2_PACKAGE_PYTHON_TREQ is not set # BR2_PACKAGE_PYTHON_TWISTED is not set # BR2_PACKAGE_PYTHON_TXAIO is not set # BR2_PACKAGE_PYTHON_TXDBUS is not set # BR2_PACKAGE_PYTHON_TXTORCON is not set # BR2_PACKAGE_PYTHON_TYPEPY is not set # BR2_PACKAGE_PYTHON_U_MSGPACK is not set # BR2_PACKAGE_PYTHON_UBJSON is not set # BR2_PACKAGE_PYTHON_UJSON is not set # BR2_PACKAGE_PYTHON_URLLIB3 is not set # BR2_PACKAGE_PYTHON_URWID is not set # BR2_PACKAGE_PYTHON_UVLOOP is not set # BR2_PACKAGE_PYTHON_VALIDATORS is not set # BR2_PACKAGE_PYTHON_VERSIONTOOLS is not set # BR2_PACKAGE_PYTHON_VISITOR is not set # BR2_PACKAGE_PYTHON_WATCHDOG is not set # BR2_PACKAGE_PYTHON_WCWIDTH is not set # BR2_PACKAGE_PYTHON_WEB2PY is not set # BR2_PACKAGE_PYTHON_WEBOB is not set # BR2_PACKAGE_PYTHON_WEBSOCKET_CLIENT is not set # BR2_PACKAGE_PYTHON_WEBSOCKETS is not set # BR2_PACKAGE_PYTHON_WERKZEUG is not set # BR2_PACKAGE_PYTHON_WHOOSH is not set # BR2_PACKAGE_PYTHON_WRAPT is not set # BR2_PACKAGE_PYTHON_WS4PY is not set # BR2_PACKAGE_PYTHON_WSACCEL is not set # BR2_PACKAGE_PYTHON_WTFORMS is not set # BR2_PACKAGE_PYTHON_XLIB is not set # BR2_PACKAGE_PYTHON_XLRD is not set # BR2_PACKAGE_PYTHON_XLSXWRITER is not set # BR2_PACKAGE_PYTHON_XLUTILS is not set # BR2_PACKAGE_PYTHON_XLWT is not set # BR2_PACKAGE_PYTHON_XMLTODICT is not set # BR2_PACKAGE_PYTHON_YARL is not set # BR2_PACKAGE_PYTHON_ZEROCONF is not set # BR2_PACKAGE_PYTHON_ZOPE_INTERFACE is not set # BR2_PACKAGE_RUBY is not set # BR2_PACKAGE_TCL is not set # # Libraries # # # Audio/Sound # # BR2_PACKAGE_ALSA_LIB is not set # BR2_PACKAGE_AUBIO is not set BR2_PACKAGE_AUDIOFILE=y # BR2_PACKAGE_BCG729 is not set # BR2_PACKAGE_CELT051 is not set BR2_PACKAGE_FDK_AAC_ARCH_SUPPORTS=y # BR2_PACKAGE_FDK_AAC is not set # BR2_PACKAGE_LIBAO is not set # BR2_PACKAGE_LIBASPLIB is not set # BR2_PACKAGE_LIBBROADVOICE is not set # BR2_PACKAGE_LIBCDAUDIO is not set # BR2_PACKAGE_LIBCDDB is not set # BR2_PACKAGE_LIBCDIO is not set # BR2_PACKAGE_LIBCDIO_PARANOIA is not set # BR2_PACKAGE_LIBCODEC2 is not set # BR2_PACKAGE_LIBCUE is not set # BR2_PACKAGE_LIBCUEFILE is not set # BR2_PACKAGE_LIBEBUR128 is not set # BR2_PACKAGE_LIBG7221 is not set # BR2_PACKAGE_LIBGSM is not set # BR2_PACKAGE_LIBID3TAG is not set # BR2_PACKAGE_LIBILBC is not set # BR2_PACKAGE_LIBLO is not set # BR2_PACKAGE_LIBMAD is not set # BR2_PACKAGE_LIBMODPLUG is not set # BR2_PACKAGE_LIBMPD is not set # BR2_PACKAGE_LIBMPDCLIENT is not set # BR2_PACKAGE_LIBREPLAYGAIN is not set # BR2_PACKAGE_LIBSAMPLERATE is not set # BR2_PACKAGE_LIBSIDPLAY2 is not set # BR2_PACKAGE_LIBSILK is not set # BR2_PACKAGE_LIBSNDFILE is not set # BR2_PACKAGE_LIBSOUNDTOUCH is not set # BR2_PACKAGE_LIBSOXR is not set # BR2_PACKAGE_LIBVORBIS is not set # BR2_PACKAGE_MP4V2 is not set BR2_PACKAGE_OPENAL_ARCH_SUPPORTS=y # BR2_PACKAGE_OPENAL is not set # BR2_PACKAGE_OPENCORE_AMR is not set # BR2_PACKAGE_OPUS is not set # BR2_PACKAGE_OPUSFILE is not set # BR2_PACKAGE_PORTAUDIO is not set # BR2_PACKAGE_SBC is not set # BR2_PACKAGE_SPANDSP is not set # BR2_PACKAGE_SPEEX is not set # BR2_PACKAGE_SPEEXDSP is not set # BR2_PACKAGE_TAGLIB is not set BR2_PACKAGE_TINYALSA=y # BR2_PACKAGE_TREMOR is not set # BR2_PACKAGE_VO_AACENC is not set BR2_PACKAGE_WEBRTC_AUDIO_PROCESSING_ARCH_SUPPORTS=y # BR2_PACKAGE_WEBRTC_AUDIO_PROCESSING is not set # # Compression and decompression # # BR2_PACKAGE_LIBARCHIVE is not set # BR2_PACKAGE_LIBSQUISH is not set # BR2_PACKAGE_LIBZIP is not set BR2_PACKAGE_LZO=y # BR2_PACKAGE_MINIZIP is not set # BR2_PACKAGE_SNAPPY is not set # BR2_PACKAGE_SZIP is not set BR2_PACKAGE_ZLIB_NG_ARCH_SUPPORTS=y BR2_PACKAGE_ZLIB=y BR2_PACKAGE_LIBZLIB=y # BR2_PACKAGE_ZLIB_NG is not set BR2_PACKAGE_HAS_ZLIB=y BR2_PACKAGE_PROVIDES_ZLIB="libzlib" BR2_PACKAGE_PROVIDES_HOST_ZLIB="host-libzlib" # BR2_PACKAGE_ZZIPLIB is not set # # Crypto # # BR2_PACKAGE_BEECRYPT is not set BR2_PACKAGE_BOTAN_ARCH_SUPPORTS=y # BR2_PACKAGE_BOTAN is not set # BR2_PACKAGE_CA_CERTIFICATES is not set # # cryptodev needs a Linux kernel to be built # # BR2_PACKAGE_GCR is not set # BR2_PACKAGE_GNUTLS is not set # BR2_PACKAGE_LIBASSUAN is not set # BR2_PACKAGE_LIBGCRYPT is not set BR2_PACKAGE_LIBGPG_ERROR_ARCH_SUPPORTS=y # BR2_PACKAGE_LIBGPG_ERROR is not set BR2_PACKAGE_LIBGPG_ERROR_SYSCFG="arm-unknown-linux-gnueabi" # BR2_PACKAGE_LIBGPGME is not set # BR2_PACKAGE_LIBKCAPI is not set # BR2_PACKAGE_LIBKSBA is not set # BR2_PACKAGE_LIBMCRYPT is not set # BR2_PACKAGE_LIBMHASH is not set # BR2_PACKAGE_LIBNSS is not set # BR2_PACKAGE_LIBP11 is not set # BR2_PACKAGE_LIBSCRYPT is not set # BR2_PACKAGE_LIBSECRET is not set # BR2_PACKAGE_LIBSHA1 is not set # BR2_PACKAGE_LIBSODIUM is not set # BR2_PACKAGE_LIBSSH is not set # BR2_PACKAGE_LIBSSH2 is not set # BR2_PACKAGE_LIBTOMCRYPT is not set # BR2_PACKAGE_LIBUECC is not set # BR2_PACKAGE_MBEDTLS is not set # BR2_PACKAGE_NETTLE is not set BR2_PACKAGE_OPENSSL=y BR2_PACKAGE_LIBOPENSSL=y # BR2_PACKAGE_LIBOPENSSL_BIN is not set # BR2_PACKAGE_LIBOPENSSL_ENGINES is not set # BR2_PACKAGE_LIBRESSL is not set BR2_PACKAGE_HAS_OPENSSL=y BR2_PACKAGE_PROVIDES_OPENSSL="libopenssl" BR2_PACKAGE_PROVIDES_HOST_OPENSSL="host-libopenssl" # BR2_PACKAGE_RHASH is not set # BR2_PACKAGE_TINYDTLS is not set # BR2_PACKAGE_TPM2_TSS is not set # BR2_PACKAGE_TROUSERS is not set # BR2_PACKAGE_USTREAM_SSL is not set # BR2_PACKAGE_WOLFSSL is not set # # Database # # BR2_PACKAGE_BERKELEYDB is not set # BR2_PACKAGE_GDBM is not set # BR2_PACKAGE_HIREDIS is not set # BR2_PACKAGE_KOMPEXSQLITE is not set # BR2_PACKAGE_LEVELDB is not set # BR2_PACKAGE_LIBGIT2 is not set # BR2_PACKAGE_MYSQL is not set # BR2_PACKAGE_POSTGRESQL is not set # BR2_PACKAGE_REDIS is not set # BR2_PACKAGE_SQLCIPHER is not set # BR2_PACKAGE_SQLITE is not set # BR2_PACKAGE_UNIXODBC is not set # # Filesystem # # BR2_PACKAGE_GAMIN is not set # BR2_PACKAGE_LIBCONFIG is not set # BR2_PACKAGE_LIBCONFUSE is not set # BR2_PACKAGE_LIBFUSE is not set # BR2_PACKAGE_LIBLOCKFILE is not set # BR2_PACKAGE_LIBNFS is not set # BR2_PACKAGE_LIBSYSFS is not set # BR2_PACKAGE_LOCKDEV is not set # BR2_PACKAGE_PHYSFS is not set # # Graphics # # BR2_PACKAGE_ASSIMP is not set # # at-spi2-atk depends on X.org # # # at-spi2-core depends on X.org # # BR2_PACKAGE_ATK is not set # BR2_PACKAGE_ATKMM is not set # BR2_PACKAGE_BULLET is not set # BR2_PACKAGE_CAIRO is not set # BR2_PACKAGE_CAIROMM is not set # # chipmunk needs an OpenGL backend # # BR2_PACKAGE_EXEMPI is not set # BR2_PACKAGE_EXIV2 is not set # BR2_PACKAGE_FONTCONFIG is not set BR2_PACKAGE_FREETYPE=y # BR2_PACKAGE_GD is not set # BR2_PACKAGE_GDK_PIXBUF is not set BR2_PACKAGE_GIFLIB=y # # granite needs libgtk3 and a toolchain w/ wchar, threads # # BR2_PACKAGE_GRAPHITE2 is not set # # gtkmm3 needs libgtk3 and a toolchain w/ C++, wchar, threads, gcc >= 4.9, host gcc >= 4.8 # # BR2_PACKAGE_HARFBUZZ is not set # BR2_PACKAGE_IJS is not set # BR2_PACKAGE_IMLIB2 is not set # # irrlicht needs X11 and an OpenGL provider # # BR2_PACKAGE_JASPER is not set BR2_PACKAGE_JPEG=y # BR2_PACKAGE_LIBJPEG is not set BR2_PACKAGE_JPEG_TURBO=y BR2_PACKAGE_HAS_JPEG=y BR2_PACKAGE_PROVIDES_JPEG="jpeg-turbo" # BR2_PACKAGE_KMSXX is not set # BR2_PACKAGE_LCMS2 is not set # BR2_PACKAGE_LENSFUN is not set # BR2_PACKAGE_LEPTONICA is not set # BR2_PACKAGE_LIBART is not set # BR2_PACKAGE_LIBDMTX is not set # BR2_PACKAGE_LIBDRM is not set # # libepoxy needs an OpenGL and/or OpenGL EGL backend # # BR2_PACKAGE_LIBEXIF is not set # # libfm needs X.org and a toolchain w/ wchar, threads, C++, gcc >= 4.8 # # BR2_PACKAGE_LIBFM_EXTRA is not set # # libfreeglut depends on X.org and needs an OpenGL backend # # BR2_PACKAGE_LIBFREEIMAGE is not set # BR2_PACKAGE_LIBGEOTIFF is not set # # libglew depends on X.org and needs an OpenGL backend # # # libglfw depends on X.org and needs an OpenGL backend # # # libglu needs an OpenGL backend # # BR2_PACKAGE_LIBGTA is not set # # libgtk3 needs an OpenGL or an OpenGL-EGL/wayland backend # # BR2_PACKAGE_LIBMEDIAART is not set # BR2_PACKAGE_LIBMNG is not set BR2_PACKAGE_LIBPNG=y # BR2_PACKAGE_LIBQRENCODE is not set # BR2_PACKAGE_LIBRAW is not set # BR2_PACKAGE_LIBRSVG is not set # # libsoil needs an OpenGL backend and a toolchain w/ dynamic library # # BR2_PACKAGE_LIBSVG is not set # BR2_PACKAGE_LIBSVG_CAIRO is not set # BR2_PACKAGE_LIBSVGTINY is not set # BR2_PACKAGE_LIBVA is not set # BR2_PACKAGE_LIBVIPS is not set # # libwpe needs a toolchain w/ C++, dynamic library and an OpenEGL-capable backend # # BR2_PACKAGE_MENU_CACHE is not set # BR2_PACKAGE_OPENCV is not set # BR2_PACKAGE_OPENCV3 is not set BR2_PACKAGE_OPENJPEG=y # BR2_PACKAGE_PANGO is not set # BR2_PACKAGE_PANGOMM is not set # BR2_PACKAGE_PIXMAN is not set # BR2_PACKAGE_POPPLER is not set # BR2_PACKAGE_TIFF is not set # BR2_PACKAGE_WAYLAND is not set BR2_PACKAGE_WEBKITGTK_ARCH_SUPPORTS=y # # webkitgtk needs libgtk3 and a glibc toolchain w/ C++, gcc >= 6, host gcc >= 4.8 # # BR2_PACKAGE_WEBP is not set # BR2_PACKAGE_WOFF2 is not set # # wpebackend-fdo needs a toolchain w/ C++, wchar, threads, dynamic library and an OpenEGL-capable Wayland backend # BR2_PACKAGE_WPEWEBKIT_ARCH_SUPPORTS=y # # wpewebkit needs an OpenGL ES w/ EGL-capable Wayland backend # # BR2_PACKAGE_ZBAR is not set # BR2_PACKAGE_ZXING_CPP is not set # # Hardware handling # # BR2_PACKAGE_ACSCCID is not set # BR2_PACKAGE_BCM2835 is not set # BR2_PACKAGE_C_PERIPHERY is not set # BR2_PACKAGE_CCID is not set # BR2_PACKAGE_DTC is not set BR2_PACKAGE_GNU_EFI_ARCH_SUPPORTS=y # BR2_PACKAGE_GNU_EFI is not set # BR2_PACKAGE_HACKRF is not set # # hidapi needs udev /dev management and a toolchain w/ NPTL threads # # BR2_PACKAGE_LCDAPI is not set # BR2_PACKAGE_LET_ME_CREATE is not set # BR2_PACKAGE_LIBAIO is not set # # libatasmart requires udev to be enabled # # BR2_PACKAGE_LIBCEC is not set # BR2_PACKAGE_LIBFREEFARE is not set # BR2_PACKAGE_LIBFTDI is not set # BR2_PACKAGE_LIBFTDI1 is not set # BR2_PACKAGE_LIBGPHOTO2 is not set # BR2_PACKAGE_LIBGPIOD is not set # # libgudev needs udev /dev handling and a toolchain w/ wchar, threads # # BR2_PACKAGE_LIBHID is not set # BR2_PACKAGE_LIBIIO is not set # # libinput needs udev /dev management and a toolchain w/ locale # # BR2_PACKAGE_LIBIQRF is not set # BR2_PACKAGE_LIBLLCP is not set # BR2_PACKAGE_LIBMBIM is not set # BR2_PACKAGE_LIBNFC is not set # BR2_PACKAGE_LIBPCIACCESS is not set # BR2_PACKAGE_LIBPHIDGET is not set # # libpri needs a kernel to be built # # BR2_PACKAGE_LIBQMI is not set # BR2_PACKAGE_LIBRAW1394 is not set # BR2_PACKAGE_LIBRTLSDR is not set # BR2_PACKAGE_LIBSERIAL is not set # BR2_PACKAGE_LIBSERIALPORT is not set # # libsigrok needs a toolchain w/ wchar, locale, threads, dynamic library, gcc >= 4.7 # # BR2_PACKAGE_LIBSIGROKDECODE is not set # BR2_PACKAGE_LIBSOC is not set # # libss7 needs a kernel to be built # # BR2_PACKAGE_LIBUSB is not set # BR2_PACKAGE_LIBUSBGX is not set # BR2_PACKAGE_LIBV4L is not set # BR2_PACKAGE_LIBXKBCOMMON is not set # BR2_PACKAGE_MRAA is not set # BR2_PACKAGE_MTDEV is not set # # ne10 needs a toolchain w/ neon # # BR2_PACKAGE_NEARDAL is not set # BR2_PACKAGE_OWFS is not set # BR2_PACKAGE_PCSC_LITE is not set BR2_PACKAGE_TSLIB=y # BR2_PACKAGE_URG is not set # BR2_PACKAGE_WIRINGPI is not set # # Javascript # # BR2_PACKAGE_ANGULARJS is not set # BR2_PACKAGE_BOOTSTRAP is not set # BR2_PACKAGE_DUKTAPE is not set # BR2_PACKAGE_EXPLORERCANVAS is not set # BR2_PACKAGE_FLOT is not set # BR2_PACKAGE_JQUERY is not set # BR2_PACKAGE_JSMIN is not set # BR2_PACKAGE_JSON_JAVASCRIPT is not set # # JSON/XML # # BR2_PACKAGE_BENEJSON is not set # BR2_PACKAGE_CJSON is not set # BR2_PACKAGE_EXPAT is not set # BR2_PACKAGE_EZXML is not set # BR2_PACKAGE_JANSSON is not set # BR2_PACKAGE_JOSE is not set # BR2_PACKAGE_JSMN is not set # BR2_PACKAGE_JSON_C is not set # BR2_PACKAGE_JSON_FOR_MODERN_CPP is not set # BR2_PACKAGE_JSON_GLIB is not set # BR2_PACKAGE_JSONCPP is not set # BR2_PACKAGE_LIBBSON is not set # BR2_PACKAGE_LIBFASTJSON is not set # BR2_PACKAGE_LIBJSON is not set # BR2_PACKAGE_LIBROXML is not set # BR2_PACKAGE_LIBUCL is not set # BR2_PACKAGE_LIBXML2 is not set # BR2_PACKAGE_LIBXMLPP is not set # BR2_PACKAGE_LIBXMLRPC is not set # BR2_PACKAGE_LIBXSLT is not set # BR2_PACKAGE_LIBYAML is not set # BR2_PACKAGE_MXML is not set # BR2_PACKAGE_PUGIXML is not set # BR2_PACKAGE_RAPIDJSON is not set # BR2_PACKAGE_RAPIDXML is not set # BR2_PACKAGE_RAPTOR is not set # BR2_PACKAGE_TINYXML is not set # BR2_PACKAGE_TINYXML2 is not set # BR2_PACKAGE_VALIJSON is not set # BR2_PACKAGE_XERCES is not set # BR2_PACKAGE_YAJL is not set # BR2_PACKAGE_YAML_CPP is not set # # Logging # # BR2_PACKAGE_EVENTLOG is not set # BR2_PACKAGE_GLOG is not set # BR2_PACKAGE_LIBLOG4C_LOCALTIME is not set # BR2_PACKAGE_LIBLOGGING is not set # BR2_PACKAGE_LOG4CPLUS is not set # BR2_PACKAGE_LOG4CPP is not set # BR2_PACKAGE_LOG4CXX is not set # BR2_PACKAGE_OPENTRACING_CPP is not set # BR2_PACKAGE_SPDLOG is not set # BR2_PACKAGE_ZLOG is not set # # Multimedia # # BR2_PACKAGE_BITSTREAM is not set # BR2_PACKAGE_KVAZAAR is not set # BR2_PACKAGE_LIBAACS is not set # BR2_PACKAGE_LIBASS is not set # BR2_PACKAGE_LIBBDPLUS is not set # BR2_PACKAGE_LIBBLURAY is not set # # libcamera needs udev and a toolchain w/ C++, threads, gcc >= 5 # # BR2_PACKAGE_LIBDCADEC is not set # BR2_PACKAGE_LIBDVBCSA is not set # BR2_PACKAGE_LIBDVBPSI is not set # BR2_PACKAGE_LIBDVBSI is not set # BR2_PACKAGE_LIBDVDCSS is not set # BR2_PACKAGE_LIBDVDNAV is not set # BR2_PACKAGE_LIBDVDREAD is not set # BR2_PACKAGE_LIBEBML is not set # BR2_PACKAGE_LIBHDHOMERUN is not set # # libimxvpuapi needs an i.MX platform with VPU support # # BR2_PACKAGE_LIBMATROSKA is not set # BR2_PACKAGE_LIBMMS is not set # BR2_PACKAGE_LIBMPEG2 is not set # BR2_PACKAGE_LIBOGG is not set BR2_PACKAGE_LIBOPENH264_ARCH_SUPPORTS=y # BR2_PACKAGE_LIBOPENH264 is not set # BR2_PACKAGE_LIBOPUSENC is not set # BR2_PACKAGE_LIBPLAYER is not set # BR2_PACKAGE_LIBTHEORA is not set # BR2_PACKAGE_LIBVPX is not set BR2_PACKAGE_LIBYUV=y # BR2_PACKAGE_LIVE555 is not set # BR2_PACKAGE_MEDIASTREAMER is not set # BR2_PACKAGE_X264 is not set # BR2_PACKAGE_X265 is not set # # Networking # # BR2_PACKAGE_AGENTPP is not set # BR2_PACKAGE_ALLJOYN is not set # BR2_PACKAGE_ALLJOYN_BASE is not set # BR2_PACKAGE_ALLJOYN_TCL is not set # BR2_PACKAGE_ALLJOYN_TCL_BASE is not set # BR2_PACKAGE_AZMQ is not set # BR2_PACKAGE_AZURE_IOT_SDK_C is not set # # batman-adv needs a Linux kernel to be built # # BR2_PACKAGE_C_ARES is not set BR2_PACKAGE_CANFESTIVAL_ARCH_SUPPORTS=y # BR2_PACKAGE_CANFESTIVAL is not set # BR2_PACKAGE_CGIC is not set # BR2_PACKAGE_CPPZMQ is not set # BR2_PACKAGE_CURLPP is not set # BR2_PACKAGE_CZMQ is not set # BR2_PACKAGE_DAQ is not set # BR2_PACKAGE_DAVICI is not set # BR2_PACKAGE_ENET is not set # BR2_PACKAGE_FILEMQ is not set # BR2_PACKAGE_FLICKCURL is not set # BR2_PACKAGE_FREERADIUS_CLIENT is not set # BR2_PACKAGE_GEOIP is not set # BR2_PACKAGE_GLIB_NETWORKING is not set # BR2_PACKAGE_GRPC is not set # BR2_PACKAGE_GSSDP is not set # BR2_PACKAGE_GUPNP is not set # BR2_PACKAGE_GUPNP_AV is not set # BR2_PACKAGE_GUPNP_DLNA is not set # BR2_PACKAGE_IBRCOMMON is not set # BR2_PACKAGE_IBRDTN is not set # BR2_PACKAGE_LIBCGI is not set # BR2_PACKAGE_LIBCGICC is not set # BR2_PACKAGE_LIBCOAP is not set # BR2_PACKAGE_LIBCPPRESTSDK is not set BR2_PACKAGE_LIBCURL=y BR2_PACKAGE_CURL=y BR2_PACKAGE_LIBCURL_VERBOSE=y BR2_PACKAGE_LIBCURL_PROXY_SUPPORT=y BR2_PACKAGE_LIBCURL_COOKIES_SUPPORT=y BR2_PACKAGE_LIBCURL_EXTRA_PROTOCOLS_FEATURES=y BR2_PACKAGE_LIBCURL_TLS_SUPPORT=y BR2_PACKAGE_LIBCURL_OPENSSL=y # BR2_PACKAGE_LIBDNET is not set # BR2_PACKAGE_LIBEXOSIP2 is not set # BR2_PACKAGE_LIBFCGI is not set # BR2_PACKAGE_LIBGSASL is not set # BR2_PACKAGE_LIBHTP is not set # BR2_PACKAGE_LIBHTTPPARSER is not set # BR2_PACKAGE_LIBIDN is not set # BR2_PACKAGE_LIBIDN2 is not set # BR2_PACKAGE_LIBISCSI is not set # BR2_PACKAGE_LIBKRB5 is not set # BR2_PACKAGE_LIBLDNS is not set # BR2_PACKAGE_LIBMAXMINDDB is not set # BR2_PACKAGE_LIBMBUS is not set # BR2_PACKAGE_LIBMEMCACHED is not set # BR2_PACKAGE_LIBMICROHTTPD is not set # BR2_PACKAGE_LIBMINIUPNPC is not set # BR2_PACKAGE_LIBMNL is not set BR2_PACKAGE_LIBMODBUS=y # BR2_PACKAGE_LIBNATPMP is not set # BR2_PACKAGE_LIBNDP is not set # BR2_PACKAGE_LIBNET is not set # BR2_PACKAGE_LIBNETFILTER_ACCT is not set # BR2_PACKAGE_LIBNETFILTER_CONNTRACK is not set # BR2_PACKAGE_LIBNETFILTER_CTHELPER is not set # BR2_PACKAGE_LIBNETFILTER_CTTIMEOUT is not set # BR2_PACKAGE_LIBNETFILTER_LOG is not set # BR2_PACKAGE_LIBNETFILTER_QUEUE is not set # BR2_PACKAGE_LIBNFNETLINK is not set # BR2_PACKAGE_LIBNFTNL is not set # BR2_PACKAGE_LIBNICE is not set BR2_PACKAGE_LIBNL=y # BR2_PACKAGE_LIBNL_TOOLS is not set # BR2_PACKAGE_LIBOAUTH is not set # BR2_PACKAGE_LIBOPING is not set # BR2_PACKAGE_LIBOSIP2 is not set # BR2_PACKAGE_LIBPAGEKITE is not set # BR2_PACKAGE_LIBPCAP is not set # BR2_PACKAGE_LIBPJSIP is not set # BR2_PACKAGE_LIBRSYNC is not set # BR2_PACKAGE_LIBSHAIRPLAY is not set # BR2_PACKAGE_LIBSHOUT is not set # BR2_PACKAGE_LIBSOCKETCAN is not set # BR2_PACKAGE_LIBSOUP is not set # BR2_PACKAGE_LIBSRTP is not set # BR2_PACKAGE_LIBSTROPHE is not set # BR2_PACKAGE_LIBTIRPC is not set # BR2_PACKAGE_LIBTORRENT is not set # BR2_PACKAGE_LIBTORRENT_RASTERBAR is not set # BR2_PACKAGE_LIBUPNP is not set # BR2_PACKAGE_LIBUPNP18 is not set # BR2_PACKAGE_LIBUPNPP is not set # BR2_PACKAGE_LIBURIPARSER is not set BR2_PACKAGE_LIBVNCSERVER=y # BR2_PACKAGE_LIBVNCSERVER_TIGHTPNG is not set # BR2_PACKAGE_LIBWEBSOCK is not set # BR2_PACKAGE_LIBWEBSOCKETS is not set # BR2_PACKAGE_LKSCTP_TOOLS is not set # BR2_PACKAGE_MONGOOSE is not set # BR2_PACKAGE_NANOMSG is not set # BR2_PACKAGE_NEON is not set # BR2_PACKAGE_NGHTTP2 is not set # BR2_PACKAGE_NORM is not set # # nss-myhostname needs a glibc toolchain # # # nss-pam-ldapd needs a glibc toolchain # # BR2_PACKAGE_OMNIORB is not set # BR2_PACKAGE_OPENLDAP is not set # BR2_PACKAGE_OPENMPI is not set # BR2_PACKAGE_OPENPGM is not set # BR2_PACKAGE_OPENZWAVE is not set # BR2_PACKAGE_ORTP is not set # BR2_PACKAGE_PAHO_MQTT_C is not set # BR2_PACKAGE_PAHO_MQTT_CPP is not set # BR2_PACKAGE_QDECODER is not set # BR2_PACKAGE_QPID_PROTON is not set # BR2_PACKAGE_RABBITMQ_C is not set # BR2_PACKAGE_RTMPDUMP is not set # BR2_PACKAGE_SLIRP is not set # BR2_PACKAGE_SNMPPP is not set # BR2_PACKAGE_SOFIA_SIP is not set # BR2_PACKAGE_THRIFT is not set # BR2_PACKAGE_USBREDIR is not set # BR2_PACKAGE_WAMPCC is not set # BR2_PACKAGE_WEBSOCKETPP is not set # BR2_PACKAGE_ZEROMQ is not set # BR2_PACKAGE_ZMQPP is not set # BR2_PACKAGE_ZYRE is not set # # Other # # BR2_PACKAGE_APR is not set # BR2_PACKAGE_APR_UTIL is not set # BR2_PACKAGE_ARGP_STANDALONE is not set # BR2_PACKAGE_ARMADILLO is not set # BR2_PACKAGE_ATF is not set # BR2_PACKAGE_BCTOOLBOX is not set # BR2_PACKAGE_BDWGC is not set # BR2_PACKAGE_BOOST is not set # BR2_PACKAGE_C_CAPNPROTO is not set # BR2_PACKAGE_CAPNPROTO is not set # BR2_PACKAGE_CLANG is not set # BR2_PACKAGE_CLAPACK is not set BR2_PACKAGE_CLASSPATH_ARCH_SUPPORTS=y # BR2_PACKAGE_CLASSPATH is not set # BR2_PACKAGE_CMOCKA is not set # BR2_PACKAGE_CPPCMS is not set # BR2_PACKAGE_CRACKLIB is not set # BR2_PACKAGE_DAWGDIC is not set # BR2_PACKAGE_DING_LIBS is not set # BR2_PACKAGE_EIGEN is not set # BR2_PACKAGE_ELFUTILS is not set # BR2_PACKAGE_ELL is not set # BR2_PACKAGE_FFTW is not set # BR2_PACKAGE_FLANN is not set # BR2_PACKAGE_FLATBUFFERS is not set # BR2_PACKAGE_FLATCC is not set # BR2_PACKAGE_GCONF is not set # BR2_PACKAGE_GFLAGS is not set # BR2_PACKAGE_GLI is not set # BR2_PACKAGE_GLIBMM is not set # BR2_PACKAGE_GLM is not set # BR2_PACKAGE_GMP is not set # BR2_PACKAGE_GSL is not set # BR2_PACKAGE_GTEST is not set BR2_PACKAGE_JEMALLOC_ARCH_SUPPORTS=y # BR2_PACKAGE_JEMALLOC is not set # # lapack/blas needs a toolchain w/ fortran # # BR2_PACKAGE_LIBARGTABLE2 is not set BR2_PACKAGE_LIBATOMIC_OPS_ARCH_SUPPORTS=y # BR2_PACKAGE_LIBATOMIC_OPS is not set # BR2_PACKAGE_LIBB64 is not set BR2_PACKAGE_LIBBSD_ARCH_SUPPORTS=y # BR2_PACKAGE_LIBBSD is not set # BR2_PACKAGE_LIBCAP is not set # BR2_PACKAGE_LIBCAP_NG is not set # # libcgroup needs a glibc toolchain w/ C++ # # BR2_PACKAGE_LIBCLC is not set # BR2_PACKAGE_LIBCOFI is not set # BR2_PACKAGE_LIBCORRECT is not set # BR2_PACKAGE_LIBCROCO is not set # BR2_PACKAGE_LIBCROSSGUID is not set # BR2_PACKAGE_LIBCSV is not set # BR2_PACKAGE_LIBDAEMON is not set # BR2_PACKAGE_LIBEE is not set # BR2_PACKAGE_LIBEV is not set # BR2_PACKAGE_LIBEVDEV is not set # BR2_PACKAGE_LIBEVENT is not set BR2_PACKAGE_LIBFFI=y # BR2_PACKAGE_LIBGEE is not set # BR2_PACKAGE_LIBGLIB2 is not set # BR2_PACKAGE_LIBGLOB is not set # BR2_PACKAGE_LIBICAL is not set # BR2_PACKAGE_LIBITE is not set # BR2_PACKAGE_LIBLINEAR is not set # BR2_PACKAGE_LIBLOKI is not set # BR2_PACKAGE_LIBNPTH is not set BR2_PACKAGE_LIBNSPR_ARCH_SUPPORT=y # BR2_PACKAGE_LIBNSPR is not set # BR2_PACKAGE_LIBPFM4 is not set # BR2_PACKAGE_LIBPLIST is not set # BR2_PACKAGE_LIBPTHREAD_STUBS is not set # BR2_PACKAGE_LIBPTHSEM is not set # BR2_PACKAGE_LIBPWQUALITY is not set BR2_PACKAGE_LIBSECCOMP_ARCH_SUPPORTS=y # BR2_PACKAGE_LIBSECCOMP is not set # BR2_PACKAGE_LIBSIGC is not set BR2_PACKAGE_LIBSIGSEGV_ARCH_SUPPORTS=y # BR2_PACKAGE_LIBSIGSEGV is not set # BR2_PACKAGE_LIBSPATIALINDEX is not set # BR2_PACKAGE_LIBTASN1 is not set # BR2_PACKAGE_LIBTOMMATH is not set # BR2_PACKAGE_LIBTPL is not set # BR2_PACKAGE_LIBUBOX is not set # BR2_PACKAGE_LIBUCI is not set BR2_PACKAGE_LIBUNWIND_ARCH_SUPPORTS=y # BR2_PACKAGE_LIBUNWIND is not set BR2_PACKAGE_LIBURCU_ARCH_SUPPORTS=y # BR2_PACKAGE_LIBURCU is not set # BR2_PACKAGE_LIBUV is not set # BR2_PACKAGE_LIGHTNING is not set # # linux-pam needs a uClibc or glibc toolchain w/ wchar, locale, dynamic library # # # liquid-dsp requires a glibc or musl toolchain w/ dynamic library # BR2_PACKAGE_LLVM_ARCH_SUPPORTS=y BR2_PACKAGE_LLVM_TARGET_ARCH="ARM" # BR2_PACKAGE_LLVM is not set # BR2_PACKAGE_LTTNG_LIBUST is not set # BR2_PACKAGE_MPC is not set # BR2_PACKAGE_MPDECIMAL is not set # BR2_PACKAGE_MPFR is not set # BR2_PACKAGE_MPIR is not set # BR2_PACKAGE_MSGPACK is not set # BR2_PACKAGE_MTDEV2TUIO is not set BR2_PACKAGE_OPENBLAS_DEFAULT_TARGET="ARMV5" BR2_PACKAGE_OPENBLAS_ARCH_SUPPORTS=y # BR2_PACKAGE_OPENBLAS is not set # BR2_PACKAGE_ORC is not set # BR2_PACKAGE_P11_KIT is not set # BR2_PACKAGE_POCO is not set BR2_PACKAGE_PROTOBUF_ARCH_SUPPORTS=y # BR2_PACKAGE_PROTOBUF is not set # BR2_PACKAGE_PROTOBUF_C is not set # BR2_PACKAGE_QHULL is not set # BR2_PACKAGE_QLIBC is not set # BR2_PACKAGE_RIEMANN_C_CLIENT is not set # BR2_PACKAGE_SHAPELIB is not set # BR2_PACKAGE_SKALIBS is not set # BR2_PACKAGE_SPHINXBASE is not set # BR2_PACKAGE_TINYCBOR is not set # BR2_PACKAGE_XAPIAN is not set # # Security # # # libselinux needs a glibc toolchain w/ threads, dynamic library # # # libsemanage needs a glibc toolchain w/ threads, dynamic library # # BR2_PACKAGE_LIBSEPOL is not set # BR2_PACKAGE_SAFECLIB is not set # # Text and terminal handling # # BR2_PACKAGE_AUGEAS is not set # BR2_PACKAGE_ENCHANT is not set # BR2_PACKAGE_FMT is not set # BR2_PACKAGE_ICU is not set # BR2_PACKAGE_LIBCLI is not set # BR2_PACKAGE_LIBEDIT is not set # BR2_PACKAGE_LIBENCA is not set # BR2_PACKAGE_LIBESTR is not set # BR2_PACKAGE_LIBFRIBIDI is not set # BR2_PACKAGE_LIBICONV is not set # BR2_PACKAGE_LIBUNISTRING is not set # BR2_PACKAGE_LINENOISE is not set BR2_PACKAGE_NCURSES=y BR2_PACKAGE_NCURSES_WCHAR=y BR2_PACKAGE_NCURSES_TARGET_PROGS=y BR2_PACKAGE_NCURSES_ADDITIONAL_TERMINFO="" # BR2_PACKAGE_NEWT is not set # BR2_PACKAGE_ONIGURUMA is not set # BR2_PACKAGE_PCRE is not set BR2_PACKAGE_PCRE2=y BR2_PACKAGE_PCRE2_16=y # BR2_PACKAGE_PCRE2_32 is not set BR2_PACKAGE_PCRE2_JIT_ARCH_SUPPORTS=y # BR2_PACKAGE_PCRE2_JIT is not set # BR2_PACKAGE_POPT is not set # BR2_PACKAGE_READLINE is not set # BR2_PACKAGE_SLANG is not set # BR2_PACKAGE_TCLAP is not set # BR2_PACKAGE_USTR is not set # # Mail # # BR2_PACKAGE_DOVECOT is not set # BR2_PACKAGE_EXIM is not set # BR2_PACKAGE_FETCHMAIL is not set # BR2_PACKAGE_HEIRLOOM_MAILX is not set # BR2_PACKAGE_LIBESMTP is not set # BR2_PACKAGE_MSMTP is not set # BR2_PACKAGE_MUTT is not set # # Miscellaneous # # BR2_PACKAGE_AESPIPE is not set # BR2_PACKAGE_BC is not set # BR2_PACKAGE_CLAMAV is not set # BR2_PACKAGE_COLLECTD is not set # # domoticz needs lua 5.3 and a toolchain w/ C++, gcc >= 4.8, NPTL, wchar, dynamic library # # BR2_PACKAGE_EMPTY is not set # BR2_PACKAGE_GOOGLEFONTDIRECTORY is not set # BR2_PACKAGE_GSETTINGS_DESKTOP_SCHEMAS is not set # BR2_PACKAGE_HAVEGED is not set # BR2_PACKAGE_LINUX_SYSCALL_SUPPORT is not set # BR2_PACKAGE_MCRYPT is not set # BR2_PACKAGE_MOBILE_BROADBAND_PROVIDER_INFO is not set # BR2_PACKAGE_PROJ is not set BR2_PACKAGE_QEMU_ARCH_SUPPORTS_TARGET=y # BR2_PACKAGE_QEMU is not set # BR2_PACKAGE_QPDF is not set # BR2_PACKAGE_SHARED_MIME_INFO is not set # BR2_PACKAGE_TASKD is not set # BR2_PACKAGE_XUTIL_UTIL_MACROS is not set # # Networking applications # # BR2_PACKAGE_AIRCRACK_NG is not set # BR2_PACKAGE_AOETOOLS is not set # BR2_PACKAGE_APACHE is not set # BR2_PACKAGE_ARGUS is not set # BR2_PACKAGE_ARP_SCAN is not set # BR2_PACKAGE_ARPTABLES is not set # BR2_PACKAGE_ASTERISK is not set # BR2_PACKAGE_ATFTP is not set # BR2_PACKAGE_AUTOSSH is not set # BR2_PACKAGE_AVAHI is not set # BR2_PACKAGE_AXEL is not set # BR2_PACKAGE_BABELD is not set # BR2_PACKAGE_BANDWIDTHD is not set # BR2_PACKAGE_BATCTL is not set # BR2_PACKAGE_BCUSDK is not set # BR2_PACKAGE_BIND is not set # BR2_PACKAGE_BIRD is not set # BR2_PACKAGE_BLUEZ_UTILS is not set # BR2_PACKAGE_BLUEZ5_UTILS is not set # BR2_PACKAGE_BMON is not set # BR2_PACKAGE_BOA is not set # BR2_PACKAGE_BOINC is not set # BR2_PACKAGE_BRCM_PATCHRAM_PLUS is not set # BR2_PACKAGE_BRIDGE_UTILS is not set # BR2_PACKAGE_BWM_NG is not set # BR2_PACKAGE_C_ICAP is not set # BR2_PACKAGE_CAN_UTILS is not set # BR2_PACKAGE_CANNELLONI is not set # BR2_PACKAGE_CHRONY is not set # BR2_PACKAGE_CIVETWEB is not set # BR2_PACKAGE_CONNMAN is not set # # connman-gtk needs libgtk3 and a glibc or uClibc toolchain w/ wchar, threads, resolver, dynamic library # # BR2_PACKAGE_CONNTRACK_TOOLS is not set # BR2_PACKAGE_CORKSCREW is not set # BR2_PACKAGE_CRDA is not set # BR2_PACKAGE_CTORRENT is not set # BR2_PACKAGE_CUPS is not set # BR2_PACKAGE_DANTE is not set # BR2_PACKAGE_DARKHTTPD is not set # BR2_PACKAGE_DEHYDRATED is not set # BR2_PACKAGE_DHCPCD is not set # BR2_PACKAGE_DHCPDUMP is not set BR2_PACKAGE_DNSMASQ=y BR2_PACKAGE_DNSMASQ_TFTP=y BR2_PACKAGE_DNSMASQ_DHCP=y # BR2_PACKAGE_DNSMASQ_DNSSEC is not set # BR2_PACKAGE_DNSMASQ_IDN is not set # BR2_PACKAGE_DNSMASQ_CONNTRACK is not set # BR2_PACKAGE_DRBD_UTILS is not set BR2_PACKAGE_DROPBEAR=y BR2_PACKAGE_DROPBEAR_CLIENT=y # BR2_PACKAGE_DROPBEAR_DISABLE_REVERSEDNS is not set BR2_PACKAGE_DROPBEAR_SMALL=y # BR2_PACKAGE_DROPBEAR_WTMP is not set # BR2_PACKAGE_DROPBEAR_LASTLOG is not set # BR2_PACKAGE_DROPBEAR_LEGACY_CRYPTO is not set BR2_PACKAGE_DROPBEAR_LOCALOPTIONS_FILE="" # BR2_PACKAGE_EBTABLES is not set # # ejabberd needs erlang, toolchain w/ C++ # # BR2_PACKAGE_ETHTOOL is not set # BR2_PACKAGE_FAIFA is not set # BR2_PACKAGE_FASTD is not set # BR2_PACKAGE_FCGIWRAP is not set # BR2_PACKAGE_FLANNEL is not set # BR2_PACKAGE_FPING is not set # BR2_PACKAGE_FREESWITCH is not set # BR2_PACKAGE_GERBERA is not set # BR2_PACKAGE_GESFTPSERVER is not set # BR2_PACKAGE_GLORYTUN is not set # # gupnp-tools needs libgtk3 # # BR2_PACKAGE_HANS is not set BR2_PACKAGE_HAPROXY_ARCH_SUPPORTS=y # BR2_PACKAGE_HAPROXY is not set # BR2_PACKAGE_HIAWATHA is not set BR2_PACKAGE_HOSTAPD=y BR2_PACKAGE_HOSTAPD_DRIVER_HOSTAP=y BR2_PACKAGE_HOSTAPD_DRIVER_NL80211=y # BR2_PACKAGE_HOSTAPD_DRIVER_RTW is not set # BR2_PACKAGE_HOSTAPD_DRIVER_WIRED is not set BR2_PACKAGE_HOSTAPD_HAS_WIFI_DRIVERS=y BR2_PACKAGE_HOSTAPD_ACS=y # BR2_PACKAGE_HOSTAPD_EAP is not set # BR2_PACKAGE_HOSTAPD_WPS is not set BR2_PACKAGE_HOSTAPD_VLAN=y BR2_PACKAGE_HOSTAPD_VLAN_DYNAMIC=y BR2_PACKAGE_HOSTAPD_VLAN_NETLINK=y # BR2_PACKAGE_HTTPING is not set # BR2_PACKAGE_I2PD is not set # BR2_PACKAGE_IBRDTN_TOOLS is not set # BR2_PACKAGE_IBRDTND is not set # BR2_PACKAGE_IFMETRIC is not set # BR2_PACKAGE_IFTOP is not set BR2_PACKAGE_IFUPDOWN_SCRIPTS=y # BR2_PACKAGE_IGD2_FOR_LINUX is not set # # igh-ethercat needs a Linux kernel to be built # # BR2_PACKAGE_IGMPPROXY is not set # BR2_PACKAGE_INADYN is not set # BR2_PACKAGE_IODINE is not set # BR2_PACKAGE_IPERF is not set # BR2_PACKAGE_IPERF3 is not set # BR2_PACKAGE_IPROUTE2 is not set # BR2_PACKAGE_IPSEC_TOOLS is not set # BR2_PACKAGE_IPSET is not set # BR2_PACKAGE_IPTABLES is not set # BR2_PACKAGE_IPTRAF_NG is not set # BR2_PACKAGE_IPUTILS is not set # BR2_PACKAGE_IRSSI is not set BR2_PACKAGE_IW=y # BR2_PACKAGE_IWD is not set # BR2_PACKAGE_JANUS_GATEWAY is not set # BR2_PACKAGE_KEEPALIVED is not set # BR2_PACKAGE_KISMET is not set # BR2_PACKAGE_KNOCK is not set # BR2_PACKAGE_LEAFNODE2 is not set # BR2_PACKAGE_LFT is not set # BR2_PACKAGE_LFTP is not set # BR2_PACKAGE_LIGHTTPD is not set # BR2_PACKAGE_LINKNX is not set # BR2_PACKAGE_LINKS is not set # BR2_PACKAGE_LINPHONE is not set # BR2_PACKAGE_LINUX_ZIGBEE is not set # BR2_PACKAGE_LINUXPTP is not set # BR2_PACKAGE_LLDPD is not set # BR2_PACKAGE_LRZSZ is not set # BR2_PACKAGE_LYNX is not set # BR2_PACKAGE_MACCHANGER is not set # BR2_PACKAGE_MEMCACHED is not set # BR2_PACKAGE_MII_DIAG is not set # BR2_PACKAGE_MINI_SNMPD is not set # BR2_PACKAGE_MINIDLNA is not set # BR2_PACKAGE_MINISSDPD is not set # BR2_PACKAGE_MJPG_STREAMER is not set # BR2_PACKAGE_MODEM_MANAGER is not set BR2_PACKAGE_MONGREL2_LIBC_SUPPORTS=y # BR2_PACKAGE_MONGREL2 is not set # BR2_PACKAGE_MONKEY is not set # BR2_PACKAGE_MOSH is not set # BR2_PACKAGE_MOSQUITTO is not set # BR2_PACKAGE_MROUTED is not set # BR2_PACKAGE_MTR is not set # BR2_PACKAGE_NBD is not set # BR2_PACKAGE_NCFTP is not set # BR2_PACKAGE_NDISC6 is not set # BR2_PACKAGE_NETATALK is not set # BR2_PACKAGE_NETPLUG is not set # BR2_PACKAGE_NETSNMP is not set # BR2_PACKAGE_NETSTAT_NAT is not set # # NetworkManager needs udev /dev management and a glibc toolchain w/ headers >= 3.2, dynamic library # # BR2_PACKAGE_NFACCT is not set # BR2_PACKAGE_NFTABLES is not set # BR2_PACKAGE_NGINX is not set # BR2_PACKAGE_NGIRCD is not set # BR2_PACKAGE_NGREP is not set # BR2_PACKAGE_NLOAD is not set # BR2_PACKAGE_NMAP is not set # BR2_PACKAGE_NOIP is not set # BR2_PACKAGE_NTP is not set # BR2_PACKAGE_NUTTCP is not set # BR2_PACKAGE_ODHCP6C is not set # BR2_PACKAGE_ODHCPLOC is not set # BR2_PACKAGE_OLSR is not set # BR2_PACKAGE_OPEN_LLDP is not set # BR2_PACKAGE_OPEN_PLC_UTILS is not set # BR2_PACKAGE_OPENNTPD is not set # BR2_PACKAGE_OPENOBEX is not set # BR2_PACKAGE_OPENRESOLV is not set # BR2_PACKAGE_OPENSSH is not set # BR2_PACKAGE_OPENSWAN is not set # BR2_PACKAGE_OPENVPN is not set # BR2_PACKAGE_P910ND is not set # BR2_PACKAGE_PHIDGETWEBSERVICE is not set # BR2_PACKAGE_PHYTOOL is not set # BR2_PACKAGE_PIMD is not set # BR2_PACKAGE_PIXIEWPS is not set # BR2_PACKAGE_POUND is not set # BR2_PACKAGE_PPPD is not set # BR2_PACKAGE_PPTP_LINUX is not set # BR2_PACKAGE_PRIVOXY is not set # BR2_PACKAGE_PROFTPD is not set # # prosody needs the lua interpreter, dynamic library # # BR2_PACKAGE_PROXYCHAINS_NG is not set # BR2_PACKAGE_PTPD is not set # BR2_PACKAGE_PTPD2 is not set # BR2_PACKAGE_PURE_FTPD is not set # BR2_PACKAGE_PUTTY is not set # BR2_PACKAGE_QUAGGA is not set # # rabbitmq-server needs erlang # # BR2_PACKAGE_RADVD is not set # BR2_PACKAGE_REAVER is not set # BR2_PACKAGE_RP_PPPOE is not set # BR2_PACKAGE_RPCBIND is not set # BR2_PACKAGE_RSH_REDONE is not set # BR2_PACKAGE_RSYNC is not set # BR2_PACKAGE_RTORRENT is not set # BR2_PACKAGE_RTPTOOLS is not set # BR2_PACKAGE_RYGEL is not set # BR2_PACKAGE_S6_DNS is not set # BR2_PACKAGE_S6_NETWORKING is not set # BR2_PACKAGE_SAMBA4 is not set # BR2_PACKAGE_SCONESERVER is not set # BR2_PACKAGE_SER2NET is not set # BR2_PACKAGE_SHADOWSOCKS_LIBEV is not set # BR2_PACKAGE_SHAIRPORT_SYNC is not set # BR2_PACKAGE_SHELLINABOX is not set # BR2_PACKAGE_SMCROUTE is not set # BR2_PACKAGE_SNGREP is not set # BR2_PACKAGE_SNORT is not set # BR2_PACKAGE_SOCAT is not set # BR2_PACKAGE_SOCKETCAND is not set # BR2_PACKAGE_SOFTETHER is not set # BR2_PACKAGE_SPAWN_FCGI is not set # BR2_PACKAGE_SPICE_PROTOCOL is not set # BR2_PACKAGE_SQUID is not set # BR2_PACKAGE_SSHGUARD is not set # BR2_PACKAGE_SSHPASS is not set # BR2_PACKAGE_SSLH is not set # BR2_PACKAGE_STRONGSWAN is not set # BR2_PACKAGE_STUNNEL is not set # BR2_PACKAGE_SURICATA is not set # BR2_PACKAGE_TCPDUMP is not set # BR2_PACKAGE_TCPING is not set # BR2_PACKAGE_TCPREPLAY is not set # BR2_PACKAGE_THTTPD is not set # BR2_PACKAGE_TINC is not set # BR2_PACKAGE_TINYHTTPD is not set # BR2_PACKAGE_TOR is not set # BR2_PACKAGE_TRACEROUTE is not set # BR2_PACKAGE_TRANSMISSION is not set # BR2_PACKAGE_TUNCTL is not set # BR2_PACKAGE_TVHEADEND is not set # BR2_PACKAGE_UDPCAST is not set # BR2_PACKAGE_UFTP is not set # BR2_PACKAGE_UHTTPD is not set # BR2_PACKAGE_ULOGD is not set # BR2_PACKAGE_USHARE is not set # BR2_PACKAGE_USSP_PUSH is not set # BR2_PACKAGE_VDE2 is not set # # vdr needs a glibc toolchain w/ C++, dynamic library, NPTL, wchar, headers >= 3.9 # # BR2_PACKAGE_VNSTAT is not set # BR2_PACKAGE_VPNC is not set # BR2_PACKAGE_VSFTPD is not set # BR2_PACKAGE_VTUN is not set # BR2_PACKAGE_WAVEMON is not set # BR2_PACKAGE_WIREGUARD is not set # BR2_PACKAGE_WIRELESS_REGDB is not set # BR2_PACKAGE_WIRELESS_TOOLS is not set # BR2_PACKAGE_WIRESHARK is not set BR2_PACKAGE_WPA_SUPPLICANT=y BR2_PACKAGE_WPA_SUPPLICANT_NL80211=y # BR2_PACKAGE_WPA_SUPPLICANT_AP_SUPPORT is not set # BR2_PACKAGE_WPA_SUPPLICANT_AUTOSCAN is not set # BR2_PACKAGE_WPA_SUPPLICANT_EAP is not set # BR2_PACKAGE_WPA_SUPPLICANT_HOTSPOT is not set # BR2_PACKAGE_WPA_SUPPLICANT_DEBUG_SYSLOG is not set # BR2_PACKAGE_WPA_SUPPLICANT_WPS is not set BR2_PACKAGE_WPA_SUPPLICANT_CLI=y # BR2_PACKAGE_WPA_SUPPLICANT_WPA_CLIENT_SO is not set # BR2_PACKAGE_WPA_SUPPLICANT_PASSPHRASE is not set # BR2_PACKAGE_WPAN_TOOLS is not set # BR2_PACKAGE_XINETD is not set # BR2_PACKAGE_XL2TP is not set # # xtables-addons needs a Linux kernel to be built # # BR2_PACKAGE_ZNC is not set # # Package managers # # # ------------------------------------------------------- # # # Please note: # # # - Buildroot does *not* generate binary packages, # # # - Buildroot does *not* install any package database. # # # * # # # It is up to you to provide those by yourself if you # # # want to use any of those package managers. # # # * # # # See the manual: # # # http://buildroot.org/manual.html#faq-no-binary-packages # # # ------------------------------------------------------- # # BR2_PACKAGE_OPKG is not set # # Real-Time # BR2_PACKAGE_XENOMAI_COBALT_ARCH_SUPPORTS=y # BR2_PACKAGE_XENOMAI is not set # # Security # # # checkpolicy needs a glibc toolchain w/ threads, dynamic library # # BR2_PACKAGE_OPTEE_BENCHMARK is not set # BR2_PACKAGE_OPTEE_CLIENT is not set # # paxtest needs a glibc toolchain # # # policycoreutils needs a glibc toolchain w/ threads, dynamic library # # # refpolicy needs a glibc toolchain w/ threads, dynamic library # # # restorecond needs a toolchain w/ wchar, threads, dynamic library # # BR2_PACKAGE_SELINUX_PYTHON is not set # BR2_PACKAGE_SEMODULE_UTILS is not set # # setools needs a glibc toolchain w/ threads, C++, wchar, dynamic library # # # Shell and utilities # # # Shells # # BR2_PACKAGE_MKSH is not set # BR2_PACKAGE_ZSH is not set # # Utilities # # BR2_PACKAGE_AT is not set # BR2_PACKAGE_CCRYPT is not set # BR2_PACKAGE_DIALOG is not set # BR2_PACKAGE_DTACH is not set # BR2_PACKAGE_EASY_RSA is not set # BR2_PACKAGE_FILE is not set # BR2_PACKAGE_GNUPG is not set # BR2_PACKAGE_GNUPG2 is not set # BR2_PACKAGE_INOTIFY_TOOLS is not set # BR2_PACKAGE_LOCKFILE_PROGS is not set # BR2_PACKAGE_LOGROTATE is not set # BR2_PACKAGE_LOGSURFER is not set # BR2_PACKAGE_PDMENU is not set # BR2_PACKAGE_PINENTRY is not set # BR2_PACKAGE_RANGER is not set # BR2_PACKAGE_SCREEN is not set # BR2_PACKAGE_SUDO is not set # BR2_PACKAGE_TINI is not set # # tmux needs a toolchain w/ wchar, locale # # BR2_PACKAGE_XMLSTARLET is not set # BR2_PACKAGE_XXHASH is not set # # System tools # # BR2_PACKAGE_ACL is not set BR2_PACKAGE_ANDROID_TOOLS=y BR2_PACKAGE_ANDROID_TOOLS_FASTBOOT_GOOD_KERNEL_HEADERS=y # # fastboot needs a glibc toolchain w/ threads, dynamic library # # BR2_PACKAGE_ANDROID_TOOLS_ADB is not set BR2_PACKAGE_ANDROID_TOOLS_ADBD=y # BR2_PACKAGE_ATOP is not set # BR2_PACKAGE_ATTR is not set BR2_PACKAGE_AUDIT_ARCH_SUPPORTS=y # BR2_PACKAGE_AUDIT is not set # BR2_PACKAGE_CGROUPFS_MOUNT is not set # BR2_PACKAGE_CIRCUS is not set # BR2_PACKAGE_CPULOAD is not set # BR2_PACKAGE_DAEMON is not set # BR2_PACKAGE_DC3DD is not set # BR2_PACKAGE_DDRESCUE is not set # BR2_PACKAGE_DOCKER_CLI is not set # BR2_PACKAGE_DOCKER_COMPOSE is not set # # docker-containerd needs a glibc or musl toolchain w/ threads # # # docker-engine needs a glibc or musl toolchain w/ threads # # BR2_PACKAGE_DOCKER_PROXY is not set # BR2_PACKAGE_EFIBOOTMGR is not set BR2_PACKAGE_EFIVAR_ARCH_SUPPORTS=y # BR2_PACKAGE_EFIVAR is not set # # emlog needs a Linux kernel to be built # # BR2_PACKAGE_FTOP is not set # BR2_PACKAGE_GETENT is not set # BR2_PACKAGE_HTOP is not set BR2_PACKAGE_INITSCRIPTS=y # BR2_PACKAGE_IOTOP is not set # BR2_PACKAGE_IPRUTILS is not set # BR2_PACKAGE_IRQBALANCE is not set # BR2_PACKAGE_KEYUTILS is not set # BR2_PACKAGE_KMOD is not set # # kvmtool needs a glibc or musl toolchain w/ dynamic library # # BR2_PACKAGE_LIBOSTREE is not set # BR2_PACKAGE_LXC is not set # BR2_PACKAGE_MENDER is not set # BR2_PACKAGE_MONIT is not set # BR2_PACKAGE_NCDU is not set # BR2_PACKAGE_NUT is not set # # pamtester depends on linux-pam # # BR2_PACKAGE_PROCRANK_LINUX is not set # BR2_PACKAGE_PWGEN is not set # BR2_PACKAGE_QUOTA is not set # BR2_PACKAGE_QUOTATOOL is not set # BR2_PACKAGE_RAUC is not set # BR2_PACKAGE_S6 is not set # BR2_PACKAGE_S6_LINUX_INIT is not set # BR2_PACKAGE_S6_LINUX_UTILS is not set # BR2_PACKAGE_S6_PORTABLE_UTILS is not set # BR2_PACKAGE_S6_RC is not set # BR2_PACKAGE_SCRUB is not set # BR2_PACKAGE_SCRYPT is not set # BR2_PACKAGE_SMACK is not set # # supervisor needs the python interpreter # # BR2_PACKAGE_SWUPDATE is not set BR2_PACKAGE_SYSTEMD_ARCH_SUPPORTS=y BR2_PACKAGE_SYSTEMD_BOOTCHART_ARCH_SUPPORTS=y # BR2_PACKAGE_TPM_TOOLS is not set # BR2_PACKAGE_TPM2_ABRMD is not set # BR2_PACKAGE_TPM2_TOOLS is not set # BR2_PACKAGE_TPM2_TOTP is not set # # unscd needs a glibc toolchain # # BR2_PACKAGE_UTIL_LINUX is not set BR2_PACKAGE_XVISOR_ARCH_SUPPORTS=y # BR2_PACKAGE_XVISOR is not set # # Text editors and viewers # # BR2_PACKAGE_ED is not set # BR2_PACKAGE_JOE is not set # BR2_PACKAGE_MC is not set # BR2_PACKAGE_MOST is not set # BR2_PACKAGE_NANO is not set # BR2_PACKAGE_UEMACS is not set # # Filesystem images # # BR2_TARGET_ROOTFS_AXFS is not set # BR2_TARGET_ROOTFS_BTRFS is not set # BR2_TARGET_ROOTFS_CLOOP is not set # BR2_TARGET_ROOTFS_CPIO is not set # BR2_TARGET_ROOTFS_CRAMFS is not set # BR2_TARGET_ROOTFS_EXT2 is not set # BR2_TARGET_ROOTFS_F2FS is not set # # initramfs needs a Linux kernel to be built # # BR2_TARGET_ROOTFS_JFFS2 is not set # BR2_TARGET_ROOTFS_ROMFS is not set # BR2_TARGET_ROOTFS_SQUASHFS is not set BR2_TARGET_ROOTFS_TAR=y BR2_TARGET_ROOTFS_TAR_NONE=y # BR2_TARGET_ROOTFS_TAR_GZIP is not set # BR2_TARGET_ROOTFS_TAR_BZIP2 is not set # BR2_TARGET_ROOTFS_TAR_LZ4 is not set # BR2_TARGET_ROOTFS_TAR_LZMA is not set # BR2_TARGET_ROOTFS_TAR_LZO is not set # BR2_TARGET_ROOTFS_TAR_XZ is not set BR2_TARGET_ROOTFS_TAR_OPTIONS="" # BR2_TARGET_ROOTFS_UBI is not set # BR2_TARGET_ROOTFS_UBIFS is not set # BR2_TARGET_ROOTFS_YAFFS2 is not set # # Bootloaders # # BR2_TARGET_AFBOOT_STM32 is not set # BR2_TARGET_AT91BOOTSTRAP is not set # BR2_TARGET_AT91BOOTSTRAP3 is not set # BR2_TARGET_AT91DATAFLASHBOOT is not set # BR2_TARGET_BAREBOX is not set BR2_TARGET_GRUB2_ARCH_SUPPORTS=y # BR2_TARGET_GRUB2 is not set # BR2_TARGET_LPC32XXCDL is not set # BR2_TARGET_MXS_BOOTLETS is not set # BR2_TARGET_S500_BOOTLOADER is not set # BR2_TARGET_UBOOT is not set # # Host utilities # # BR2_PACKAGE_HOST_AESPIPE is not set BR2_PACKAGE_HOST_ANDROID_TOOLS=y # BR2_PACKAGE_HOST_ANDROID_TOOLS_FASTBOOT is not set BR2_PACKAGE_HOST_ANDROID_TOOLS_ADB=y # BR2_PACKAGE_HOST_ANDROID_TOOLS_EXT4_UTILS is not set # BR2_PACKAGE_HOST_BTRFS_PROGS is not set # BR2_PACKAGE_HOST_CARGO is not set # BR2_PACKAGE_HOST_CBOOTIMAGE is not set # BR2_PACKAGE_HOST_CHECKPOLICY is not set # BR2_PACKAGE_HOST_CHECKSEC is not set # BR2_PACKAGE_HOST_CMAKE is not set # BR2_PACKAGE_HOST_CRAMFS is not set # BR2_PACKAGE_HOST_CRYPTSETUP is not set # BR2_PACKAGE_HOST_DBUS_PYTHON is not set # BR2_PACKAGE_HOST_DFU_UTIL is not set # BR2_PACKAGE_HOST_DOS2UNIX is not set # BR2_PACKAGE_HOST_DOSFSTOOLS is not set # BR2_PACKAGE_HOST_DTC is not set # BR2_PACKAGE_HOST_E2FSPROGS is not set # BR2_PACKAGE_HOST_E2TOOLS is not set # BR2_PACKAGE_HOST_F2FS_TOOLS is not set # BR2_PACKAGE_HOST_FAKETIME is not set # BR2_PACKAGE_HOST_FATCAT is not set # BR2_PACKAGE_HOST_FWUP is not set # BR2_PACKAGE_HOST_GENEXT2FS is not set # BR2_PACKAGE_HOST_GENIMAGE is not set # BR2_PACKAGE_HOST_GENPART is not set # BR2_PACKAGE_HOST_GNUPG is not set BR2_PACKAGE_HOST_GO_TARGET_ARCH_SUPPORTS=y BR2_PACKAGE_HOST_GO_TARGET_CGO_LINKING_SUPPORTS=y BR2_PACKAGE_HOST_GO_HOST_ARCH_SUPPORTS=y BR2_PACKAGE_HOST_GO_BOOTSTRAP_ARCH_SUPPORTS=y BR2_PACKAGE_HOST_GOOGLE_BREAKPAD_ARCH_SUPPORTS=y # BR2_PACKAGE_HOST_GPTFDISK is not set # BR2_PACKAGE_HOST_IMAGEMAGICK is not set # BR2_PACKAGE_HOST_IMX_MKIMAGE is not set # BR2_PACKAGE_HOST_IMX_USB_LOADER is not set # BR2_PACKAGE_HOST_JQ is not set # BR2_PACKAGE_HOST_JSMIN is not set # BR2_PACKAGE_HOST_LIBP11 is not set # BR2_PACKAGE_HOST_LPC3250LOADER is not set # BR2_PACKAGE_HOST_LTTNG_BABELTRACE is not set # BR2_PACKAGE_HOST_MENDER_ARTIFACT is not set # BR2_PACKAGE_HOST_MFGTOOLS is not set # BR2_PACKAGE_HOST_MKPASSWD is not set # BR2_PACKAGE_HOST_MTD is not set # BR2_PACKAGE_HOST_MTOOLS is not set # BR2_PACKAGE_HOST_MXSLDR is not set # BR2_PACKAGE_HOST_OMAP_U_BOOT_UTILS is not set # BR2_PACKAGE_HOST_OPENOCD is not set # BR2_PACKAGE_HOST_OPKG_UTILS is not set # BR2_PACKAGE_HOST_PARTED is not set BR2_PACKAGE_HOST_PATCHELF=y # BR2_PACKAGE_HOST_PKGCONF is not set # BR2_PACKAGE_HOST_PRU_SOFTWARE_SUPPORT is not set # BR2_PACKAGE_HOST_PWGEN is not set # BR2_PACKAGE_HOST_PYTHON_CYTHON is not set # BR2_PACKAGE_HOST_PYTHON_LXML is not set # BR2_PACKAGE_HOST_PYTHON_SIX is not set # BR2_PACKAGE_HOST_PYTHON_XLRD is not set BR2_PACKAGE_HOST_QEMU_ARCH_SUPPORTS=y BR2_PACKAGE_HOST_QEMU_SYSTEM_ARCH_SUPPORTS=y BR2_PACKAGE_HOST_QEMU_USER_ARCH_SUPPORTS=y # BR2_PACKAGE_HOST_QEMU is not set # BR2_PACKAGE_HOST_RASPBERRYPI_USBBOOT is not set # BR2_PACKAGE_HOST_RAUC is not set # BR2_PACKAGE_HOST_RCW is not set BR2_PACKAGE_HOST_RUSTC_ARCH_SUPPORTS=y BR2_PACKAGE_HOST_RUSTC_ARCH="arm" BR2_PACKAGE_HOST_RUSTC_ABI="eabi" # BR2_PACKAGE_HOST_RUSTC is not set BR2_PACKAGE_PROVIDES_HOST_RUSTC="host-rust-bin" # BR2_PACKAGE_HOST_SAM_BA is not set # BR2_PACKAGE_HOST_SQUASHFS is not set # BR2_PACKAGE_HOST_SUNXI_TOOLS is not set # BR2_PACKAGE_HOST_SWIG is not set # BR2_PACKAGE_HOST_TEGRARCM is not set BR2_PACKAGE_HOST_TI_CGT_PRU_ARCH_SUPPORTS=y # BR2_PACKAGE_HOST_TI_CGT_PRU is not set # BR2_PACKAGE_HOST_UBOOT_TOOLS is not set # BR2_PACKAGE_HOST_UTIL_LINUX is not set # BR2_PACKAGE_HOST_UTP_COM is not set # BR2_PACKAGE_HOST_VBOOT_UTILS is not set # BR2_PACKAGE_HOST_XORRISO is not set # BR2_PACKAGE_HOST_ZIP is not set # BR2_PACKAGE_HOST_ZSTD is not set # # Legacy config options # # # Legacy options removed in 2019.08 # # BR2_TARGET_TS4800_MBRBOOT is not set # BR2_PACKAGE_LIBAMCODEC is not set # BR2_PACKAGE_ODROID_SCRIPTS is not set # BR2_PACKAGE_ODROID_MALI is not set # BR2_PACKAGE_KODI_PLATFORM_AML is not set # BR2_GCC_VERSION_6_X is not set # BR2_GCC_VERSION_4_9_X is not set # BR2_GDB_VERSION_7_12 is not set # BR2_PACKAGE_XAPP_MKFONTDIR is not set # BR2_GDB_VERSION_8_0 is not set # BR2_KERNEL_HEADERS_4_20 is not set # BR2_KERNEL_HEADERS_5_0 is not set # # Legacy options removed in 2019.05 # # BR2_CSKY_DSP is not set # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_COMPOSITOR is not set # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_IQA is not set # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_OPENCV is not set # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_STEREO is not set # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_VCD is not set # BR2_PACKAGE_LUNIT is not set # BR2_PACKAGE_FFMPEG_FFSERVER is not set # BR2_PACKAGE_LIBUMP is not set # BR2_PACKAGE_SUNXI_MALI is not set # BR2_BINUTILS_VERSION_2_29_X is not set # BR2_BINUTILS_VERSION_2_28_X is not set # BR2_PACKAGE_GST_PLUGINS_BAD_PLUGIN_APEXSINK is not set # # Legacy options removed in 2019.02 # # BR2_PACKAGE_QT is not set # BR2_PACKAGE_QTUIO is not set # BR2_PACKAGE_PINENTRY_QT4 is not set # BR2_PACKAGE_POPPLER_QT is not set # BR2_PACKAGE_OPENCV3_WITH_QT is not set # BR2_PACKAGE_OPENCV_WITH_QT is not set # BR2_PACKAGE_AMD_CATALYST_CCCLE is not set # BR2_PACKAGE_SDL_QTOPIA is not set # BR2_PACKAGE_PYTHON_PYQT is not set # BR2_PACKAGE_GNURADIO_QTGUI is not set # BR2_PACKAGE_LUACRYPTO is not set # BR2_PACKAGE_TN5250 is not set # BR2_PACKAGE_BOOST_SIGNALS is not set # BR2_PACKAGE_FFTW_PRECISION_SINGLE is not set # BR2_PACKAGE_FFTW_PRECISION_DOUBLE is not set # BR2_PACKAGE_LUA_5_2 is not set # BR2_TARGET_GENERIC_PASSWD_MD5 is not set # # Legacy options removed in 2018.11 # # BR2_TARGET_XLOADER is not set # BR2_PACKAGE_TIDSP_BINARIES is not set # BR2_PACKAGE_DSP_TOOLS is not set # BR2_PACKAGE_GST_DSP is not set # BR2_PACKAGE_BOOTUTILS is not set # BR2_PACKAGE_EXPEDITE is not set # BR2_PACKAGE_MESA3D_OPENGL_TEXTURE_FLOAT is not set # BR2_KERNEL_HEADERS_4_10 is not set # BR2_KERNEL_HEADERS_4_11 is not set # BR2_KERNEL_HEADERS_4_12 is not set # BR2_KERNEL_HEADERS_4_13 is not set # BR2_KERNEL_HEADERS_4_15 is not set # BR2_KERNEL_HEADERS_4_17 is not set # BR2_PACKAGE_LIBNFTNL_XML is not set # BR2_KERNEL_HEADERS_3_2 is not set # BR2_KERNEL_HEADERS_4_1 is not set # BR2_KERNEL_HEADERS_4_16 is not set # BR2_KERNEL_HEADERS_4_18 is not set # # Legacy options removed in 2018.08 # # BR2_PACKAGE_DOCKER_ENGINE_STATIC_CLIENT is not set # BR2_PACKAGE_XSERVER_XORG_SERVER_V_1_19 is not set # BR2_PACKAGE_XPROTO_APPLEWMPROTO is not set # BR2_PACKAGE_XPROTO_BIGREQSPROTO is not set # BR2_PACKAGE_XPROTO_COMPOSITEPROTO is not set # BR2_PACKAGE_XPROTO_DAMAGEPROTO is not set # BR2_PACKAGE_XPROTO_DMXPROTO is not set # BR2_PACKAGE_XPROTO_DRI2PROTO is not set # BR2_PACKAGE_XPROTO_DRI3PROTO is not set # BR2_PACKAGE_XPROTO_FIXESPROTO is not set # BR2_PACKAGE_XPROTO_FONTCACHEPROTO is not set # BR2_PACKAGE_XPROTO_FONTSPROTO is not set # BR2_PACKAGE_XPROTO_GLPROTO is not set # BR2_PACKAGE_XPROTO_INPUTPROTO is not set # BR2_PACKAGE_XPROTO_KBPROTO is not set # BR2_PACKAGE_XPROTO_PRESENTPROTO is not set # BR2_PACKAGE_XPROTO_RANDRPROTO is not set # BR2_PACKAGE_XPROTO_RECORDPROTO is not set # BR2_PACKAGE_XPROTO_RENDERPROTO is not set # BR2_PACKAGE_XPROTO_RESOURCEPROTO is not set # BR2_PACKAGE_XPROTO_SCRNSAVERPROTO is not set # BR2_PACKAGE_XPROTO_VIDEOPROTO is not set # BR2_PACKAGE_XPROTO_WINDOWSWMPROTO is not set # BR2_PACKAGE_XPROTO_XCMISCPROTO is not set # BR2_PACKAGE_XPROTO_XEXTPROTO is not set # BR2_PACKAGE_XPROTO_XF86BIGFONTPROTO is not set # BR2_PACKAGE_XPROTO_XF86DGAPROTO is not set # BR2_PACKAGE_XPROTO_XF86DRIPROTO is not set # BR2_PACKAGE_XPROTO_XF86VIDMODEPROTO is not set # BR2_PACKAGE_XPROTO_XINERAMAPROTO is not set # BR2_PACKAGE_XPROTO_XPROTO is not set # BR2_PACKAGE_XPROTO_XPROXYMANAGEMENTPROTOCOL is not set # BR2_PACKAGE_GST1_PLUGINS_BAD_LIB_OPENGL_OPENGL is not set # BR2_PACKAGE_GST1_PLUGINS_BAD_LIB_OPENGL_GLES2 is not set # BR2_PACKAGE_GST1_PLUGINS_BAD_LIB_OPENGL_GLX is not set # BR2_PACKAGE_GST1_PLUGINS_BAD_LIB_OPENGL_EGL is not set # BR2_PACKAGE_GST1_PLUGINS_BAD_LIB_OPENGL_X11 is not set # BR2_PACKAGE_GST1_PLUGINS_BAD_LIB_OPENGL_WAYLAND is not set # BR2_PACKAGE_GST1_PLUGINS_BAD_LIB_OPENGL_DISPMANX is not set # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_AUDIOMIXER is not set # BR2_PACKAGE_GST1_PLUGINS_UGLY_PLUGIN_LAME is not set # BR2_PACKAGE_GST1_PLUGINS_UGLY_PLUGIN_MPG123 is not set # BR2_GDB_VERSION_7_11 is not set # BR2_GDB_VERSION_7_10 is not set # # Legacy options removed in 2018.05 # # BR2_PACKAGE_MEDIAART_BACKEND_NONE is not set # BR2_PACKAGE_MEDIAART_BACKEND_GDK_PIXBUF is not set # BR2_PACKAGE_TI_SGX_AM335X is not set # BR2_PACKAGE_TI_SGX_AM437X is not set # BR2_PACKAGE_TI_SGX_AM4430 is not set # BR2_PACKAGE_TI_SGX_AM5430 is not set # BR2_PACKAGE_JANUS_AUDIO_BRIDGE is not set # BR2_PACKAGE_JANUS_ECHO_TEST is not set # BR2_PACKAGE_JANUS_RECORDPLAY is not set # BR2_PACKAGE_JANUS_SIP_GATEWAY is not set # BR2_PACKAGE_JANUS_STREAMING is not set # BR2_PACKAGE_JANUS_TEXT_ROOM is not set # BR2_PACKAGE_JANUS_VIDEO_CALL is not set # BR2_PACKAGE_JANUS_VIDEO_ROOM is not set # BR2_PACKAGE_JANUS_MQTT is not set # BR2_PACKAGE_JANUS_RABBITMQ is not set # BR2_PACKAGE_JANUS_REST is not set # BR2_PACKAGE_JANUS_UNIX_SOCKETS is not set # BR2_PACKAGE_JANUS_WEBSOCKETS is not set # BR2_PACKAGE_IPSEC_SECCTX_DISABLE is not set # BR2_PACKAGE_IPSEC_SECCTX_ENABLE is not set # BR2_PACKAGE_IPSEC_SECCTX_KERNEL is not set # BR2_PACKAGE_LIBTFDI_CPP is not set # BR2_PACKAGE_JQUERY_UI_THEME_BLACK_TIE is not set # BR2_PACKAGE_JQUERY_UI_THEME_BLITZER is not set # BR2_PACKAGE_JQUERY_UI_THEME_CUPERTINO is not set # BR2_PACKAGE_JQUERY_UI_THEME_DARK_HIVE is not set # BR2_PACKAGE_JQUERY_UI_THEME_DOT_LUV is not set # BR2_PACKAGE_JQUERY_UI_THEME_EGGPLANT is not set # BR2_PACKAGE_JQUERY_UI_THEME_EXCITE_BIKE is not set # BR2_PACKAGE_JQUERY_UI_THEME_FLICK is not set # BR2_PACKAGE_JQUERY_UI_THEME_HOT_SNEAKS is not set # BR2_PACKAGE_JQUERY_UI_THEME_HUMANITY is not set # BR2_PACKAGE_JQUERY_UI_THEME_LE_FROG is not set # BR2_PACKAGE_JQUERY_UI_THEME_MINT_CHOC is not set # BR2_PACKAGE_JQUERY_UI_THEME_OVERCAST is not set # BR2_PACKAGE_JQUERY_UI_THEME_PEPPER_GRINDER is not set # BR2_PACKAGE_JQUERY_UI_THEME_REDMOND is not set # BR2_PACKAGE_JQUERY_UI_THEME_SMOOTHNESS is not set # BR2_PACKAGE_JQUERY_UI_THEME_SOUTH_STREET is not set # BR2_PACKAGE_JQUERY_UI_THEME_START is not set # BR2_PACKAGE_JQUERY_UI_THEME_SUNNY is not set # BR2_PACKAGE_JQUERY_UI_THEME_SWANKY_PURSE is not set # BR2_PACKAGE_JQUERY_UI_THEME_TRONTASTIC is not set # BR2_PACKAGE_JQUERY_UI_THEME_UI_DARKNESS is not set # BR2_PACKAGE_JQUERY_UI_THEME_UI_LIGHTNESS is not set # BR2_PACKAGE_JQUERY_UI_THEME_VADER is not set # BR2_PACKAGE_BLUEZ5_PLUGINS_HEALTH is not set # BR2_PACKAGE_BLUEZ5_PLUGINS_MIDI is not set # BR2_PACKAGE_BLUEZ5_PLUGINS_NFC is not set # BR2_PACKAGE_BLUEZ5_PLUGINS_SAP is not set # BR2_PACKAGE_BLUEZ5_PLUGINS_SIXAXIS is not set # BR2_PACKAGE_TRANSMISSION_REMOTE is not set # BR2_PACKAGE_LIBKCAPI_APPS is not set # BR2_PACKAGE_MPLAYER is not set # BR2_PACKAGE_MPLAYER_MPLAYER is not set # BR2_PACKAGE_MPLAYER_MENCODER is not set # BR2_PACKAGE_LIBPLAYER_MPLAYER is not set # BR2_PACKAGE_IQVLINUX is not set # BR2_BINFMT_FLAT_SEP_DATA is not set # BR2_bfin is not set # BR2_PACKAGE_KODI_ADSP_BASIC is not set # BR2_PACKAGE_KODI_ADSP_FREESURROUND is not set # # Legacy options removed in 2018.02 # # BR2_KERNEL_HEADERS_3_4 is not set # BR2_KERNEL_HEADERS_3_10 is not set # BR2_KERNEL_HEADERS_3_12 is not set # BR2_BINUTILS_VERSION_2_27_X is not set # BR2_PACKAGE_EEPROG is not set # BR2_PACKAGE_GNUPG2_GPGV2 is not set # BR2_PACKAGE_IMX_GPU_VIV_APITRACE is not set # BR2_PACKAGE_IMX_GPU_VIV_G2D is not set # # Legacy options removed in 2017.11 # # BR2_PACKAGE_RFKILL is not set # BR2_PACKAGE_UTIL_LINUX_RESET is not set # BR2_PACKAGE_POLICYCOREUTILS_AUDIT2ALLOW is not set # BR2_PACKAGE_POLICYCOREUTILS_RESTORECOND is not set # BR2_PACKAGE_SEPOLGEN is not set # BR2_PACKAGE_OPENOBEX_BLUEZ is not set # BR2_PACKAGE_OPENOBEX_LIBUSB is not set # BR2_PACKAGE_OPENOBEX_APPS is not set # BR2_PACKAGE_OPENOBEX_SYSLOG is not set # BR2_PACKAGE_OPENOBEX_DUMP is not set # BR2_PACKAGE_AICCU is not set # BR2_PACKAGE_UTIL_LINUX_LOGIN_UTILS is not set # # Legacy options removed in 2017.08 # # BR2_TARGET_GRUB is not set # BR2_PACKAGE_SIMICSFS is not set # BR2_BINUTILS_VERSION_2_26_X is not set BR2_XTENSA_OVERLAY_DIR="" BR2_XTENSA_CUSTOM_NAME="" # BR2_PACKAGE_HOST_MKE2IMG is not set BR2_TARGET_ROOTFS_EXT2_BLOCKS=0 BR2_TARGET_ROOTFS_EXT2_EXTRA_INODES=0 # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_CDXAPARSE is not set # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_DATAURISRC is not set # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_DCCP is not set # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_HDVPARSE is not set # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_MVE is not set # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_NUVDEMUX is not set # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_PATCHDETECT is not set # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_SDI is not set # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_TTA is not set # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_VIDEOMEASURE is not set # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_APEXSINK is not set # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_SDL is not set # BR2_PACKAGE_GST1_PLUGINS_UGLY_PLUGIN_MAD is not set # BR2_STRIP_none is not set # BR2_PACKAGE_BEECRYPT_CPP is not set # BR2_PACKAGE_SPICE_CLIENT is not set # BR2_PACKAGE_SPICE_GUI is not set # BR2_PACKAGE_SPICE_TUNNEL is not set # BR2_PACKAGE_INPUT_TOOLS is not set # BR2_PACKAGE_INPUT_TOOLS_INPUTATTACH is not set # BR2_PACKAGE_INPUT_TOOLS_JSCAL is not set # BR2_PACKAGE_INPUT_TOOLS_JSTEST is not set # BR2_TOOLCHAIN_EXTERNAL_CODESOURCERY_SH is not set # BR2_TOOLCHAIN_EXTERNAL_CODESOURCERY_X86 is not set # BR2_GCC_VERSION_4_8_X is not set # # Legacy options removed in 2017.05 # # BR2_PACKAGE_SUNXI_MALI_R2P4 is not set # BR2_PACKAGE_NODEJS_MODULES_COFFEESCRIPT is not set # BR2_PACKAGE_NODEJS_MODULES_EXPRESS is not set # BR2_PACKAGE_BLUEZ5_UTILS_GATTTOOL is not set # BR2_PACKAGE_OPENOCD_FT2XXX is not set # BR2_PACKAGE_KODI_RTMPDUMP is not set # BR2_PACKAGE_KODI_VISUALISATION_FOUNTAIN is not set # BR2_PACKAGE_PORTMAP is not set # BR2_BINUTILS_VERSION_2_25_X is not set # BR2_TOOLCHAIN_BUILDROOT_INET_RPC is not set BR2_TARGET_ROOTFS_EXT2_EXTRA_BLOCKS=0 # BR2_PACKAGE_SYSTEMD_KDBUS is not set # BR2_PACKAGE_POLARSSL is not set # BR2_NBD_CLIENT is not set # BR2_NBD_SERVER is not set # BR2_PACKAGE_GMOCK is not set # BR2_KERNEL_HEADERS_4_8 is not set # BR2_KERNEL_HEADERS_3_18 is not set # BR2_GLIBC_VERSION_2_22 is not set # # Legacy options removed in 2017.02 # # BR2_PACKAGE_PERL_DB_FILE is not set # BR2_KERNEL_HEADERS_4_7 is not set # BR2_KERNEL_HEADERS_4_6 is not set # BR2_KERNEL_HEADERS_4_5 is not set # BR2_KERNEL_HEADERS_3_14 is not set # BR2_TOOLCHAIN_EXTERNAL_MUSL_CROSS is not set # BR2_UCLIBC_INSTALL_TEST_SUITE is not set # BR2_TOOLCHAIN_EXTERNAL_BLACKFIN_UCLINUX is not set # BR2_PACKAGE_MAKEDEVS is not set # BR2_TOOLCHAIN_EXTERNAL_ARAGO_ARMV7A is not set # BR2_TOOLCHAIN_EXTERNAL_ARAGO_ARMV5TE is not set # BR2_PACKAGE_SNOWBALL_HDMISERVICE is not set # BR2_PACKAGE_SNOWBALL_INIT is not set # BR2_GDB_VERSION_7_9 is not set # # Legacy options removed in 2016.11 # # BR2_PACKAGE_PHP_SAPI_CLI_CGI is not set # BR2_PACKAGE_PHP_SAPI_CLI_FPM is not set # BR2_PACKAGE_WVSTREAMS is not set # BR2_PACKAGE_WVDIAL is not set # BR2_PACKAGE_WEBKITGTK24 is not set # BR2_PACKAGE_TORSMO is not set # BR2_PACKAGE_SSTRIP is not set # BR2_KERNEL_HEADERS_4_3 is not set # BR2_KERNEL_HEADERS_4_2 is not set # BR2_PACKAGE_KODI_ADDON_XVDR is not set # BR2_PACKAGE_IPKG is not set # BR2_GCC_VERSION_4_7_X is not set # BR2_BINUTILS_VERSION_2_24_X is not set # BR2_PACKAGE_WESTON_RPI is not set # BR2_GCC_VERSION_4_8_ARC is not set # BR2_KERNEL_HEADERS_4_0 is not set # BR2_KERNEL_HEADERS_3_19 is not set # BR2_PACKAGE_LIBEVAS_GENERIC_LOADERS is not set # BR2_PACKAGE_ELEMENTARY is not set # BR2_LINUX_KERNEL_CUSTOM_LOCAL is not set # # Legacy options removed in 2016.08 # # BR2_PACKAGE_EFL_JP2K is not set # BR2_PACKAGE_SYSTEMD_COMPAT is not set # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_LIVEADDER is not set # BR2_PACKAGE_LIBFSLVPUWRAP is not set # BR2_PACKAGE_LIBFSLPARSER is not set # BR2_PACKAGE_LIBFSLCODEC is not set # BR2_PACKAGE_UBOOT_TOOLS_MKIMAGE_FIT_SIGNATURE_SUPPORT is not set # BR2_PTHREADS_OLD is not set # BR2_BINUTILS_VERSION_2_23_X is not set # BR2_TOOLCHAIN_BUILDROOT_EGLIBC is not set # BR2_GDB_VERSION_7_8 is not set # # Legacy options removed in 2016.05 # # BR2_PACKAGE_OPENVPN_CRYPTO_POLARSSL is not set # BR2_PACKAGE_NGINX_HTTP_SPDY_MODULE is not set # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_RTP is not set # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_MPG123 is not set # BR2_TOOLCHAIN_EXTERNAL_CODESOURCERY_POWERPC is not set # BR2_TOOLCHAIN_EXTERNAL_CODESOURCERY_POWERPC_E500V2 is not set # BR2_x86_i386 is not set # BR2_PACKAGE_QT5QUICK1 is not set BR2_TARGET_UBOOT_CUSTOM_PATCH_DIR="" # BR2_PACKAGE_XDRIVER_XF86_INPUT_VOID is not set # BR2_KERNEL_HEADERS_3_17 is not set # BR2_GDB_VERSION_7_7 is not set # BR2_PACKAGE_FOOMATIC_FILTERS is not set # BR2_PACKAGE_SAMBA is not set # BR2_PACKAGE_KODI_WAVPACK is not set # BR2_PACKAGE_KODI_RSXS is not set # BR2_PACKAGE_KODI_GOOM is not set # BR2_PACKAGE_SYSTEMD_ALL_EXTRAS is not set # BR2_GCC_VERSION_4_5_X is not set # BR2_PACKAGE_SQLITE_READLINE is not set # # Legacy options removed in 2016.02 # # BR2_PACKAGE_DOVECOT_BZIP2 is not set # BR2_PACKAGE_DOVECOT_ZLIB is not set # BR2_PACKAGE_E2FSPROGS_FINDFS is not set # BR2_PACKAGE_OPENPOWERLINK_DEBUG_LEVEL is not set # BR2_PACKAGE_OPENPOWERLINK_KERNEL_MODULE is not set # BR2_PACKAGE_OPENPOWERLINK_LIBPCAP is not set # BR2_LINUX_KERNEL_SAME_AS_HEADERS is not set # BR2_PACKAGE_CUPS_PDFTOPS is not set # BR2_KERNEL_HEADERS_3_16 is not set # BR2_PACKAGE_PYTHON_PYXML is not set # BR2_ENABLE_SSP is not set # BR2_PACKAGE_DIRECTFB_CLE266 is not set # BR2_PACKAGE_DIRECTFB_UNICHROME is not set # BR2_PACKAGE_LIBELEMENTARY is not set # BR2_PACKAGE_LIBEINA is not set # BR2_PACKAGE_LIBEET is not set # BR2_PACKAGE_LIBEVAS is not set # BR2_PACKAGE_LIBECORE is not set # BR2_PACKAGE_LIBEDBUS is not set # BR2_PACKAGE_LIBEFREET is not set # BR2_PACKAGE_LIBEIO is not set # BR2_PACKAGE_LIBEMBRYO is not set # BR2_PACKAGE_LIBEDJE is not set # BR2_PACKAGE_LIBETHUMB is not set # BR2_PACKAGE_INFOZIP is not set # BR2_BR2_PACKAGE_NODEJS_0_10_X is not set # BR2_BR2_PACKAGE_NODEJS_0_12_X is not set # BR2_BR2_PACKAGE_NODEJS_4_X is not set # # Legacy options removed in 2015.11 # # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_REAL is not set # BR2_PACKAGE_MEDIA_CTL is not set # BR2_PACKAGE_SCHIFRA is not set # BR2_PACKAGE_ZXING is not set # BR2_PACKAGE_BLACKBOX is not set # BR2_KERNEL_HEADERS_3_0 is not set # BR2_KERNEL_HEADERS_3_11 is not set # BR2_KERNEL_HEADERS_3_13 is not set # BR2_KERNEL_HEADERS_3_15 is not set # BR2_PACKAGE_DIRECTFB_EXAMPLES_ANDI is not set # BR2_PACKAGE_DIRECTFB_EXAMPLES_BLTLOAD is not set # BR2_PACKAGE_DIRECTFB_EXAMPLES_CPULOAD is not set # BR2_PACKAGE_DIRECTFB_EXAMPLES_DATABUFFER is not set # BR2_PACKAGE_DIRECTFB_EXAMPLES_DIOLOAD is not set # BR2_PACKAGE_DIRECTFB_EXAMPLES_DOK is not set # BR2_PACKAGE_DIRECTFB_EXAMPLES_DRIVERTEST is not set # BR2_PACKAGE_DIRECTFB_EXAMPLES_FIRE is not set # BR2_PACKAGE_DIRECTFB_EXAMPLES_FLIP is not set # BR2_PACKAGE_DIRECTFB_EXAMPLES_FONTS is not set # BR2_PACKAGE_DIRECTFB_EXAMPLES_INPUT is not set # BR2_PACKAGE_DIRECTFB_EXAMPLES_JOYSTICK is not set # BR2_PACKAGE_DIRECTFB_EXAMPLES_KNUCKLES is not set # BR2_PACKAGE_DIRECTFB_EXAMPLES_LAYER is not set # BR2_PACKAGE_DIRECTFB_EXAMPLES_MATRIX is not set # BR2_PACKAGE_DIRECTFB_EXAMPLES_MATRIX_WATER is not set # BR2_PACKAGE_DIRECTFB_EXAMPLES_NEO is not set # BR2_PACKAGE_DIRECTFB_EXAMPLES_NETLOAD is not set # BR2_PACKAGE_DIRECTFB_EXAMPLES_PALETTE is not set # BR2_PACKAGE_DIRECTFB_EXAMPLES_PARTICLE is not set # BR2_PACKAGE_DIRECTFB_EXAMPLES_PORTER is not set # BR2_PACKAGE_DIRECTFB_EXAMPLES_STRESS is not set # BR2_PACKAGE_DIRECTFB_EXAMPLES_TEXTURE is not set # BR2_PACKAGE_DIRECTFB_EXAMPLES_VIDEO is not set # BR2_PACKAGE_DIRECTFB_EXAMPLES_VIDEO_PARTICLE is not set # BR2_PACKAGE_DIRECTFB_EXAMPLES_WINDOW is not set # BR2_PACKAGE_KOBS_NG is not set # BR2_PACKAGE_SAWMAN is not set # BR2_PACKAGE_DIVINE is not set # # Legacy options removed in 2015.08 # # BR2_PACKAGE_KODI_PVR_ADDONS is not set # BR2_BINUTILS_VERSION_2_23_2 is not set # BR2_BINUTILS_VERSION_2_24 is not set # BR2_BINUTILS_VERSION_2_25 is not set # BR2_PACKAGE_PERF is not set # BR2_BINUTILS_VERSION_2_22 is not set # BR2_PACKAGE_GPU_VIV_BIN_MX6Q is not set # BR2_TARGET_UBOOT_NETWORK is not set # # Legacy options removed in 2015.05 # # BR2_TARGET_ROOTFS_JFFS2_NANDFLASH_512_16K is not set # BR2_TARGET_ROOTFS_JFFS2_NANDFLASH_2K_128K is not set # BR2_PACKAGE_MONO_20 is not set # BR2_PACKAGE_MONO_40 is not set # BR2_PACKAGE_MONO_45 is not set # BR2_CIVETWEB_WITH_LUA is not set # BR2_PACKAGE_TIFF_TIFF2PDF is not set # BR2_PACKAGE_TIFF_TIFFCP is not set # BR2_LINUX_KERNEL_EXT_RTAI_PATCH is not set # BR2_TARGET_GENERIC_PASSWD_DES is not set # BR2_PACKAGE_GTK2_THEME_HICOLOR is not set # BR2_PACKAGE_VALGRIND_PTRCHECK is not set # # Legacy options removed in 2015.02 # # BR2_PACKAGE_LIBGC is not set # BR2_PACKAGE_WDCTL is not set # BR2_PACKAGE_UTIL_LINUX_ARCH is not set # BR2_PACKAGE_UTIL_LINUX_DDATE is not set # BR2_PACKAGE_RPM_BZIP2_PAYLOADS is not set # BR2_PACKAGE_RPM_XZ_PAYLOADS is not set # BR2_PACKAGE_M4 is not set # BR2_PACKAGE_FLEX_BINARY is not set # BR2_PACKAGE_BISON is not set # BR2_PACKAGE_GOB2 is not set # BR2_PACKAGE_DISTCC is not set # BR2_PACKAGE_HASERL_VERSION_0_8_X is not set # BR2_PACKAGE_STRONGSWAN_TOOLS is not set # BR2_PACKAGE_XBMC_ADDON_XVDR is not set # BR2_PACKAGE_XBMC_PVR_ADDONS is not set # BR2_PACKAGE_XBMC is not set # BR2_PACKAGE_XBMC_ALSA_LIB is not set # BR2_PACKAGE_XBMC_AVAHI is not set # BR2_PACKAGE_XBMC_DBUS is not set # BR2_PACKAGE_XBMC_LIBBLURAY is not set # BR2_PACKAGE_XBMC_GOOM is not set # BR2_PACKAGE_XBMC_RSXS is not set # BR2_PACKAGE_XBMC_LIBCEC is not set # BR2_PACKAGE_XBMC_LIBMICROHTTPD is not set # BR2_PACKAGE_XBMC_LIBNFS is not set # BR2_PACKAGE_XBMC_RTMPDUMP is not set # BR2_PACKAGE_XBMC_LIBSHAIRPLAY is not set # BR2_PACKAGE_XBMC_LIBSMBCLIENT is not set # BR2_PACKAGE_XBMC_LIBTHEORA is not set # BR2_PACKAGE_XBMC_LIBUSB is not set # BR2_PACKAGE_XBMC_LIBVA is not set # BR2_PACKAGE_XBMC_WAVPACK is not set # BR2_PREFER_STATIC_LIB is not set # # Legacy options removed in 2014.11 # # BR2_x86_generic is not set # BR2_GCC_VERSION_4_4_X is not set # BR2_sparc_sparchfleon is not set # BR2_sparc_sparchfleonv8 is not set # BR2_sparc_sparcsfleon is not set # BR2_sparc_sparcsfleonv8 is not set # BR2_PACKAGE_LINUX_FIRMWARE_XC5000 is not set # BR2_PACKAGE_LINUX_FIRMWARE_CXGB4 is not set # BR2_PACKAGE_LINUX_FIRMWARE_IWLWIFI_3160_7260_7 is not set # BR2_PACKAGE_LINUX_FIRMWARE_IWLWIFI_3160_7260_8 is not set # # Legacy options removed in 2014.08 # # BR2_PACKAGE_LIBELF is not set # BR2_KERNEL_HEADERS_3_8 is not set # BR2_PACKAGE_GETTEXT_TOOLS is not set # BR2_PACKAGE_PROCPS is not set # BR2_BINUTILS_VERSION_2_20_1 is not set # BR2_BINUTILS_VERSION_2_21 is not set # BR2_BINUTILS_VERSION_2_23_1 is not set # BR2_UCLIBC_VERSION_0_9_32 is not set # BR2_GCC_VERSION_4_3_X is not set # BR2_GCC_VERSION_4_6_X is not set # BR2_GDB_VERSION_7_4 is not set # BR2_GDB_VERSION_7_5 is not set # BR2_BUSYBOX_VERSION_1_19_X is not set # BR2_BUSYBOX_VERSION_1_20_X is not set # BR2_BUSYBOX_VERSION_1_21_X is not set # BR2_PACKAGE_LIBV4L_DECODE_TM6000 is not set # BR2_PACKAGE_LIBV4L_IR_KEYTABLE is not set # BR2_PACKAGE_LIBV4L_V4L2_COMPLIANCE is not set # BR2_PACKAGE_LIBV4L_V4L2_CTL is not set # BR2_PACKAGE_LIBV4L_V4L2_DBG is not set # # Legacy options removed in 2014.05 # # BR2_PACKAGE_EVTEST_CAPTURE is not set # BR2_KERNEL_HEADERS_3_6 is not set # BR2_KERNEL_HEADERS_3_7 is not set # BR2_PACKAGE_VALA is not set BR2_PACKAGE_TZDATA_ZONELIST="" # BR2_PACKAGE_LUA_INTERPRETER_EDITING_NONE is not set # BR2_PACKAGE_LUA_INTERPRETER_READLINE is not set # BR2_PACKAGE_LUA_INTERPRETER_LINENOISE is not set # BR2_PACKAGE_DVB_APPS_UTILS is not set # BR2_KERNEL_HEADERS_SNAP is not set # BR2_ROOTFS_DEVICE_CREATION_DYNAMIC_UDEV is not set # BR2_PACKAGE_UDEV is not set # BR2_PACKAGE_UDEV_RULES_GEN is not set # BR2_PACKAGE_UDEV_ALL_EXTRAS is not set # # Legacy options removed in 2014.02 # # BR2_sh2 is not set # BR2_sh3 is not set # BR2_sh3eb is not set # BR2_KERNEL_HEADERS_3_1 is not set # BR2_KERNEL_HEADERS_3_3 is not set # BR2_KERNEL_HEADERS_3_5 is not set # BR2_GDB_VERSION_7_2 is not set # BR2_GDB_VERSION_7_3 is not set # BR2_PACKAGE_CCACHE is not set # BR2_HAVE_DOCUMENTATION is not set # BR2_PACKAGE_AUTOMAKE is not set # BR2_PACKAGE_AUTOCONF is not set # BR2_PACKAGE_XSTROKE is not set # BR2_PACKAGE_LZMA is not set # BR2_PACKAGE_TTCP is not set # BR2_PACKAGE_LIBNFC_LLCP is not set # BR2_PACKAGE_MYSQL_CLIENT is not set # BR2_PACKAGE_SQUASHFS3 is not set # BR2_TARGET_ROOTFS_SQUASHFS3 is not set # BR2_PACKAGE_NETKITBASE is not set # BR2_PACKAGE_NETKITTELNET is not set # BR2_PACKAGE_LUASQL is not set # BR2_PACKAGE_LUACJSON is not set # # Legacy options removed in 2013.11 # # BR2_PACKAGE_LVM2_DMSETUP_ONLY is not set # BR2_PACKAGE_QT_JAVASCRIPTCORE is not set # BR2_PACKAGE_MODULE_INIT_TOOLS is not set BR2_TARGET_UBOOT_CUSTOM_GIT_REPO_URL="" BR2_TARGET_UBOOT_CUSTOM_GIT_VERSION="" BR2_LINUX_KERNEL_CUSTOM_GIT_REPO_URL="" BR2_LINUX_KERNEL_CUSTOM_GIT_VERSION="" # # Legacy options removed in 2013.08 # # BR2_ARM_OABI is not set # BR2_PACKAGE_DOSFSTOOLS_DOSFSCK is not set # BR2_PACKAGE_DOSFSTOOLS_DOSFSLABEL is not set # BR2_PACKAGE_DOSFSTOOLS_MKDOSFS is not set # BR2_ELF2FLT is not set # BR2_VFP_FLOAT is not set # BR2_PACKAGE_GCC_TARGET is not set # BR2_HAVE_DEVFILES is not set
buildroot服务器下载: buildroot-2019.08.tar.gz
/usr/share/font 目录下的字体文件吧
不会是单独拷贝吧?
配置文件里这样的
# Fonts
# BR2_PACKAGE_BITSTREAM_VERA is not set
# BR2_PACKAGE_CANTARELL is not set
# BR2_PACKAGE_DEJAVU is not set
# BR2_PACKAGE_FONT_AWESOME is not set
# BR2_PACKAGE_GHOSTSCRIPT_FONTS is not set
# BR2_PACKAGE_INCONSOLATA is not set
BR2_PACKAGE_LIBERATION=y
BR2_PACKAGE_LIBERATION_MONO=y
BR2_PACKAGE_LIBERATION_SANS=y
BR2_PACKAGE_LIBERATION_SERIF=y
最近编辑记录 笨企鹅 (2020-08-29 19:32:51)
手动拷贝就行,我记得是 msyh.ttf
