楼主 #1 2020-07-31 11:08:19
已发帖子: 856
使用github镜像站点提高clone速度
首先在chrome安装tampermonkey,然后在tampermonkey里添加以下脚本:
// ==UserScript==
// @icon         https://github.githubassets.com/favicon.ico
// @name         Github 镜像访问,加速下载
// @namespace    https://github.com/jadezi/github-accelerator/
// @version      1.1.1
// @description  GitHub 镜像,github 加速
// @author       jadezi
// @license      GPL License
// @match        *://github.com/*
// @require      https://cdn.bootcss.com/jquery/3.4.1/jquery.min.js
// @resource     mycss https://gitee.com/jadezi/github-accelerator-css/raw/master/index.css
// @grant        GM_addStyle
// @grant        GM_setClipboard
// @grant        GM_getResourceText
// ==/UserScript==
(function() {
    var clone = true;
    // var clone = false;
    var depth = true;
    // var depth = false;
    var mirror = true;
    // var mirror = false;
    var hide = false;
    var location = window.location.href;
    var mirror_url1 = "https://" + "github.com.cnpmjs.org";
    var mirror_url2 = "https://" + "hub.fastgit.org";
    var mirror_url3 = "https://" + "github.wuyanzheshui.workers.dev";
    var download_url1 = "https://download.fastgit.org";
    var str1 = "";
    if (clone) {
        str1 += "git clone ";
        if (depth) {
            str1 += "--depth=1 ";
    var a = location.split("/");
    var str2 = "/" + a[3] + "/" + a[4] + ".git";
    var clone_utl1 = str1 + mirror_url1 + str2;
    var clone_utl2 = str1 + mirror_url2 + str2;
    var str3 = window.location.pathname;
    var web_url1 = mirror_url1 + str3;
    var web_url2 = mirror_url2 + str3;
    var web_url3 = mirror_url3 + str3;
    var info = `
    <div class="user-ment">
    <button class="btn btn-primary" type="button" id="mirror-btn">镜像网址</button>
    <div class="collapse multi-collapse" id="collapse">
    <div class="user-card user-card-body">
    <div class="user-alert user-alert-warning" role="alert">clone、depth命令的插入可手动编辑代码关闭</div>
    <div class="user-alert user-alert-danger" style="color: #721c24;background-color: #f8d7da;border-color: #f5c6cb;" role="alert">镜像地址请不要登陆自己的账户,造成损失本人概不负责</div>
    <div class="user-input-group user-mb-3">
    <div class="user-input-group-prepend"><span class="user-input-group-text" id="inputGroup-sizing-default">快速克隆1:</span></div>
    <input id="clone_case_1" type="text" value="${clone_utl1}" data-autoselect="" class="user-form-control" aria-label="将此存储库克隆到 ${clone_utl1}" readonly aria-describedby="inputGroup-sizing-default">
    <div class="user-input-group-append">
    <button class="btn btn-outline-secondary" type="button" id="button-copy1"  data-container="body" data-toggle="popover" data-placement="bottom" data-content="复制成功">复制</button>
    </div>
    <a type="button"  href="${web_url1}" class="btn">快速浏览1</a>
    </div>
    <span class="user-input-group-text" id="inputGroup-sizing-default">快速克隆2:</span>
    </div>
    <input id="clone_case_2" type="text" value="${clone_utl2}" data-autoselect="" class="user-form-control" aria-label="将此存储库克隆到 ${clone_utl2}" readonly aria-describedby="inputGroup-sizing-default" >
    <button class="btn btn-outline-secondary" type="button" id="button-copy2"  data-container="body" data-toggle="popover" data-placement="bottom" data-content="复制成功">复制</button>
    </div>
    <a type="button" href="${web_url2}" class="btn">快速浏览2</a>
    </div>
    <span class="user-input-group-text" id="inputGroup-sizing-default">快速克隆3:</span>
    </div>
    <input type="text" data-autoselect="" class="user-form-control" aria-describedby="inputGroup-sizing-default" value="不支持clone,直接跳转--->" aria-label="" readonly="" >
    <a type="button" href="${web_url3}" class="btn">快速浏览3</a>
    </div>
    </div>
    </div>
    </div>`;
    $(".repository-content").prepend(info);
    $(".Box.Box--condensed").each(function () {
        $(this).find(".d-flex.Box-body>a").each(function () {
            var href = $(this).attr("href");
            var url1 = download_url1 + href;
            var url2 = mirror_url3 + href;
            var div1 = `<div class="user_download" style="display: flex;justify-content: flex-end;flex-grow: 1;"><div><a style="padding:4px;"  class="btn user-btn-link"  href="${url1}" rel="nofollow">快速下载1</a></div><div><a style="padding:4px"   class="btn user-btn-link" href="${url2}" rel="nofollow">快速下载2(推荐)</a></div></div>`
            $(this).after(div1);
        $(this).find(".d-block.Box-body>a").each(function () {
            var div1 = `<div class="user_download" style="display: flex;"><div><a style="padding:4px;"  class="btn user-btn-link"  href="${url1}" rel="nofollow">快速下载1</a></div><div><a style="padding:4px"   class="btn user-btn-link" href="${url2}" rel="nofollow">快速下载2(推荐)</a></div></div>`
    $(".mt-2.d-flex").each(function () {
        var url1 = mirror_url3 +"/"+a[3]+"/"+a[4]+ "/archive/master.zip";
        var span1 = `<a class="btn btn-outline get-repo-btn btn-block" rel="nofollow" href="${url1}">Fast Download ZIP</a>`;
        $(this).after(span1);
    // 复制按钮
    $("#button-copy1").on("click",function(){
        GM_setClipboard($("#clone_case_1").val())
        alert("复制成功")
    $("#button-copy2").on("click",function(){
        GM_setClipboard($("#clone_case_2").val())
        alert("复制成功")
    // 隐藏面板
    $("#mirror-btn").on("click", function () {
        if (!hide) {
            $("#collapse").hide();
        } else {
            $("#collapse").show();
        hide = !hide;
    function init(){
        if (!mirror) {
    // 初始化面板
    init()
    GM_addStyle(GM_getResourceText("mycss"));
然后在访问github时会出现以下界面,直接clone镜像站点即可:
访问速度如下,大概在400~500k/s的样子:
#2 2020-07-31 23:02:49
kesion
已发帖子: 45
Re: 使用github镜像站点提高clone速度
有那么神奇的操作,原理是什么,楼主讲一下把
楼主 #3 2020-08-01 07:33:13
已发帖子: 856
kesion 说:
很简单,tampermonkey的脚本修改github的页面,插入镜像站点链接
#4 2020-08-01 07:44:17
jiangchun9981
已发帖子: 170
不用这么麻烦,浏览器直接访问里面的镜像节点即可,别的操作一模一样
地址代码里面有了,这的人应该一眼能看懂
#5 2020-08-01 17:22:37
akinggw
已发帖子: 25
先从github上导入仓库到gitee上,然后就可以在gitee上操作了,这样就非常快
楼主 #6 2020-08-01 17:52:24
已发帖子: 856
akinggw 说:
试过代码量一大就不行了,比如linux内核之类的。会提示空间限制
#7 2020-09-27 18:09:32
thy442156388
所在地: 新疆乌鲁木齐
还是找个合适的梯子会比较好一点。
