楼主 #1 2020-08-04 22:19:45
明月照我沟渠
已发帖子: 121
这种数码管字体 littlevgl / lvgl 计时器/倒计时器 界面如何?
楼主 #2 2020-08-04 22:20:53
明月照我沟渠
已发帖子: 121
Re: 这种数码管字体 littlevgl / lvgl 计时器/倒计时器 界面如何?
楼主 #3 2020-08-04 22:28:46
明月照我沟渠
已发帖子: 121
#4 2020-08-05 01:04:48
已发帖子: 1,139
你这个资源正是我要找的,非常感谢!
楼主 #5 2020-08-05 08:38:38
明月照我沟渠
已发帖子: 121
达克罗德 说:
你这个资源正是我要找的,非常感谢!
一起学习共同进步.
楼主 #6 2020-08-05 09:03:34
明月照我沟渠
已发帖子: 121
又找到一个段码字体: https://fontmeme.com/fonts/seven-segment-font/
ttf段码字体本站下载: seven-segment.zip
littlevgl 字体生成:
lv_font_conv --no-compress --format lvgl --font "D:\8899\7 Segment.ttf" -o font_segment_64.c --bpp 4 --size 64 --symbols "0123456789abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ " -r 0x20-0x7F
	lv_obj_t* label2 = lv_label_create(button2, NULL);
	lv_obj_set_style_local_text_font(label2, LV_LABEL_PART_MAIN, LV_STATE_DEFAULT, &font_segment_64);
	lv_label_set_text(label2, "0123456789");
	lv_obj_t* button3 = lv_btn_create(lv_scr_act(), NULL);
	lv_obj_set_pos(button3, 150, 250);
	lv_obj_set_size(button3, 500, 64);
	lv_obj_t* label3 = lv_label_create(button3, NULL);
	lv_obj_set_style_local_text_font(label3, LV_LABEL_PART_MAIN, LV_STATE_DEFAULT, &font_segment_64);
	lv_label_set_text(label3, "ABCDEFGHIJK");
楼主 #7 2020-08-05 10:39:36
明月照我沟渠
已发帖子: 121
代码:
void lv_test2()
	lv_task_create(task2, 1000, LV_TASK_PRIO_LOWEST, NULL);
	lv_obj_t* button2 = lv_btn_create(lv_scr_act(), NULL);
	lv_obj_set_pos(button2, 10, 10);
	lv_obj_set_size(button2, 550, 64);
	lv_obj_set_style_local_text_color(label2, LV_LABEL_PART_MAIN, LV_STATE_DEFAULT, LV_COLOR_GREEN);
	lv_label_set_text(label2, "2020-07-05 10:17:33");
	lv_obj_set_pos(button3, 10, 80);
	lv_obj_set_style_local_text_color(label3, LV_LABEL_PART_MAIN, LV_STATE_DEFAULT, LV_COLOR_RED);
	lv_obj_t* label4 = lv_label_create(lv_scr_act(), NULL);
	lv_obj_set_pos(label4, 10, 250);
	lv_obj_set_size(label4, 650, 128);
	lv_obj_set_style_local_text_font(label4, LV_LABEL_PART_MAIN, LV_STATE_DEFAULT, &font_segment_128);
	lv_obj_set_style_local_text_color(label4, LV_LABEL_PART_MAIN, LV_STATE_DEFAULT, LV_COLOR_BLUE);
	lv_label_set_text(label4, "2020-07-05");
字体生成:
lv_font_conv --no-compress --format lvgl --font "D:\8899\7 Segment.ttf" -o font_segment_128.c --bpp 4 --size 128 --symbols "0123456789abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ: " -r 0x20-0x7F
楼主 #8 2020-08-05 11:29:18
明月照我沟渠
已发帖子: 121
void task2(lv_task_t* task)
	char strdate[16];
	char strtime[16];
	time_t t = time(NULL);
	struct tm tm = *localtime(&t);
	snprintf(strdate, sizeof(strdate) - 1, "%04d-%02d-%02d", tm.tm_year + 1900, tm.tm_mon + 1, tm.tm_mday);
	snprintf(strtime, sizeof(strtime) - 1, "%02d:%02d:%02d", tm.tm_hour, tm.tm_min, tm.tm_sec);
	lv_label_set_text(labelDate, strdate);
	lv_label_set_text(labelTime, strtime);
void lv_test2()
	labelDate = lv_label_create(lv_scr_act(), NULL);
	lv_obj_set_pos(labelDate, 10, 160);
	lv_obj_set_size(labelDate, 650, 128);
	lv_obj_set_style_local_text_font(labelDate, LV_LABEL_PART_MAIN, LV_STATE_DEFAULT, &font_segment_64);
	lv_obj_set_style_local_text_color(labelDate, LV_LABEL_PART_MAIN, LV_STATE_DEFAULT, LV_COLOR_BLUE);
	lv_label_set_text(labelDate, "");
	labelTime = lv_label_create(lv_scr_act(), NULL);
	lv_obj_set_pos(labelTime, 10, 220);
	lv_obj_set_size(labelTime, 650, 128);
	lv_obj_set_style_local_text_font(labelTime, LV_LABEL_PART_MAIN, LV_STATE_DEFAULT, &font_segment_128);
	lv_obj_set_style_local_text_color(labelTime, LV_LABEL_PART_MAIN, LV_STATE_DEFAULT, LV_COLOR_BLUE);
	lv_label_set_text(labelTime, "");
	lv_task_create(task2, 900, LV_TASK_PRIO_LOWEST, NULL);
	//lv_task_ready(task2);
#9 2020-08-05 11:31:31
已发帖子: 1,139
这字体真好看
楼主 #10 2020-08-05 11:33:00
明月照我沟渠
已发帖子: 121
达克罗德 说:
这字体真好看
不完美, 因为不等宽.
我去找一个等宽字体看看.
楼主 #11 2020-08-05 11:49:00
明月照我沟渠
已发帖子: 121
终于找到一个等宽的段码字体: https://www.1001fonts.com/monospaced+lcd-fonts.html
本站下载: digital-7.zip
#12 2020-08-07 10:00:52
xfdr0805
已发帖子: 336
这个不错
楼主 #13 2020-08-07 21:24:34
明月照我沟渠
已发帖子: 121
lv_font_conv --no-compress --format lvgl --font "D:\8899\digital-7\digital-7 (mono).ttf" -o lv_font_segment_24.c --bpp 4 --size 24 --symbols "0123456789abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ: " -r 0x20-0x7F
lv_font_conv --no-compress --format lvgl --font "D:\8899\digital-7\digital-7 (mono).ttf" -o lv_font_segment_32.c --bpp 4 --size 32 --symbols "0123456789abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ: " -r 0x20-0x7F
lv_font_conv --no-compress --format lvgl --font "D:\8899\digital-7\digital-7 (mono).ttf" -o lv_font_segment_48.c --bpp 4 --size 48 --symbols "0123456789abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ: " -r 0x20-0x7F
lv_font_conv --no-compress --format lvgl --font "D:\8899\digital-7\digital-7 (mono).ttf" -o lv_font_segment_64.c --bpp 4 --size 64 --symbols "0123456789abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ: " -r 0x20-0x7F
lv_font_conv --no-compress --format lvgl --font "D:\8899\digital-7\digital-7 (mono).ttf" -o lv_font_segment_128.c --bpp 4 --size 128 --symbols "0123456789abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ: " -r 0x20-0x7F
#14 2020-08-11 09:51:20
这数码管字体漂亮~~
#15 2020-10-25 20:38:39
孤星泪
已发帖子: 235
smartcar 说:
这数码管字体漂亮~~
+1 确实阔以阔以
#16 2020-10-25 20:51:31
sea18c
实用,顶
#17 2020-10-26 13:52:18
armstrong
已发帖子: 290
好帖子!标记一下。
#18 2021-04-28 14:54:06
honami520
这种字体还是很有魅力的
#19 2022-01-06 10:26:35
BALABALA
这是什么字体
#20 2022-01-10 17:39:45
九重天
已发帖子: 26
LvglFontTool字体工具更新V0.4版本
https://whycan.com/t_5106.html
也可以用阿里兄这个软件转换。
#21 2022-01-10 20:03:06
memory
已发帖子: 651
九重天 说:
也可以用阿里兄这个软件转换。
LVGL 字库在线生成: https://debugdump.com/topic/935
#23 2022-06-19 19:55:03
musich
已发帖子: 253
这个字体好看。
#25 2022-06-25 17:14:21
笔走天下
已发帖子: 126
这id真好听
