楼主 #1 2020-10-30 15:45:23
hanzixi_angel
已发帖子: 54
V3s GT911驱动问题
Linux版本使用的是4.10.y;  因为设备树里面没有关于gt911的io配置;发现5.2.y的设备树里面有,将其移植过来,如下:
 &i2c0 {
     gt911: touchscreen@14 {
         compatible = "goodix,gt911";
         reg = <0x14>;
         interrupt-parent = <&pio>;
         interrupts = <1 3 IRQ_TYPE_EDGE_FALLING>; /* (PB3) */
         pinctrl-names = "default";
         //pinctrl-0 = <&i2c0_pins>;
         irq-gpios = <&pio 1 3 GPIO_ACTIVE_HIGH>; /* (PB3) */
         reset-gpios = <&pio 4 20 GPIO_ACTIVE_HIGH>; /* RST (PE20) */
         /* touchscreen-swapped-x-y */
在内核中勾选goodix的电容屏驱动,去除ns2009的电阻屏驱动
--- Touchscreens        │ │
  │ │              < >   ADS7846/TSC2046/AD7873 and AD(S)7843 based touchscreens                        │ │
  │ │              < >   AD7877 based touchscreens                                                      │ │
  │ │              < >   Analog Devices AD7879-1/AD7889-1 touchscreen interface                         │ │
  │ │              < >   Microchip AR1021 i2c touchscreen                                               │ │
  │ │              < >   Atmel mXT I2C Touchscreen                                                      │ │
  │ │              < >   AUO in-cell touchscreen using Pixcir ICs                                       │ │
  │ │              < >   BU21013 based touch panel controllers                                          │ │
  │ │              < >   chipone icn8318 touchscreen controller                                         │ │
  │ │              < >   cy8ctmg110 touchscreen                                                         │ │
  │ │              < >   Cypress TTSP touchscreen                                                       │ │
  │ │              < >   Cypress TrueTouch Gen4 Touchscreen Driver                                      │ │
  │ │              < >   Dynapro serial touchscreen                                                     │ │
  │ │              < >   Hampshire serial touchscreen                                                   │ │
  │ │              < >   EETI touchscreen panel support                                                 │ │
  │ │              < >   EETI eGalax multi-touch panel support                                          │ │
  │ │              < >   EETI eGalax serial touchscreen                                                 │ │
  │ │              < >   Fujitsu serial touchscreen                                                     │ │
  │ │              <*>   Goodix I2C touchscreen                                                         │ │
  │ │              < >   Ilitek ILI210X based touchscreen
  |   |              < >   Penmount serial touchscreen                                                    │ │
  │ │              < >   EDT FocalTech FT5x06 I2C Touchscreen support                                   │ │
  │ │              < >   Nsiway NS2009 touchscreen
然后编译内核和设备树  更新之后启动可以成功识别gt911电容屏   但是使用tslib和hexdump都不能获取到触摸数据;  没有任何数据;
然后测试电路,发现中断管脚一直都是低电平,测试其他正常能用的电容屏有触摸是才是低电平,平常是高电平,说明io这块应该是有问题的;
测试别人提供的内核镜像是正常的,说明触摸屏是没有问题;应该还是io配置或者驱动的问题;io配置我是使用的5.2.y内核的设备树配置,
驱动使用的是4.10.y自带的驱动;加载驱动的时候可以识别出电容屏,可以正常读取id;如下:
[    0.832410] usbcore: registered new interface driver lvs
[    0.837920] musb-sunxi 1c19000.usb: Invalid or missing 'dr_mode' property
[    0.844771] musb-sunxi: probe of 1c19000.usb failed with error -22
[    0.851842] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
[    0.858719] sun6i-rtc 1c20400.rtc: RTC enabled
[    0.863261] i2c /dev entries driver
[    0.867897] Goodix-TS 0-0014: I2C Address: 0x14
[    0.872471] Goodix-TS 0-0014: irq get irq GPIO: 0
[    0.877323] Goodix-TS 0-0014: rst get reset GPIO: 0
[    0.995912] Goodix-TS 0-0014: ID-> 911, version: 1060
[    1.001681] Goodix-TS 0-0014: Direct firmware load for goodix_911_cfg.bin failed with error -2
[    1.010886] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.036206] input: Goodix Capacitive TouchScreen as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0014/input/input0
[    1.074451] sunxi-mmc 1c0f000.mmc: base:0xc4061000 irq:23
[    1.082760] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01c23000 not registered
[    1.090833] sun4i-codec 1c22c00.codec: Failed to register our card
[    1.098291] NET: Registered protocol family 17
[    1.102858] Key type dns_resolver registered
其中有一个报错,提示加载固件goodix_911_cfg.bin失败,有人说这个不影响.
各位大牛有没有搞成功的,我基本上寻遍了整个论坛,没有找到明确搞定gt911驱动的分享,希望各位大牛不吝赐教;
希望晕哥能指点一二,谢谢各位!
#2 2020-10-30 15:55:44
孤星泪
已发帖子: 235
Re: V3s GT911驱动问题
buildroot-tiny200 (F1C100/200s) 开发包近期更新内容 * 已支持DVP摄像头 *
http://whycan.com/t_5221.html
#3 2020-10-30 17:18:20
jkl
已发帖子: 265
Re: V3s GT911驱动问题
hanzixi_angel 说:
希望晕哥能指点一二,谢谢各位!
缺少固件是肯定不行的,固件里面有些对触摸芯片的配置参数,想办法把固件搞来才行。
#4 2020-10-30 17:28:33
jkl
已发帖子: 265
Re: V3s GT911驱动问题
淘宝上买了一个 GT911 触摸屏, 但是发现 无论用 evtest 还是 ts_print_raw 读出来的最大宽高都是800 x 480
http://whycan.com/t_2358.html
楼主 #5 2020-11-11 10:09:15
hanzixi_angel
已发帖子: 54
Re: V3s GT911驱动问题
经过多次对比测试推测定位已经是中断没有触发的原因    推测应该是中断配置的问题   对比测试linux5.2.y是可以正常使用的   对比查看linux/drivers/pinctrl/sunxi/pinctrl-sun8i-v3s.c中有关中断的配置跟Linux4.10.y是不一样的
5.2.y中如下:
static const struct sunxi_pinctrl_desc sun8i_v3s_pinctrl_data = {
     .pins = sun8i_v3s_pins,
     .npins = ARRAY_SIZE(sun8i_v3s_pins),
     .irq_banks = 2,
     .irq_bank_map = sun8i_v3s_pinctrl_irq_bank_map,
     .irq_read_needs_mux = true
4.10.y中如下:
    .irq_banks = 2,
在4.10.y中增加.irq_bank_base = 1即可正常触发中断
更改过后如下:
    .irq_banks = 2,
        .irq_bank_base = 1,
至此4.10.y可以正常触发触摸中断了,gt911可以正常读取坐标点数据;   鉴于4.10.y的一些坑  本人目前已经切到5.2.y系统   也顺应解决了usb otg不能自动切换的问题   大家有需要的可以参考下   此坑已填
#6 2021-03-27 23:35:20
mysteryli
已发帖子: 487
Re: V3s GT911驱动问题
hanzixi_angel 说:
5.2.y中如下:
     .irq_banks = 2,
4.10.y中如下:
    .irq_banks = 2,
更改过后如下:
    .irq_banks = 2,
        .irq_bank_base = 1,
楼主你最终自己写的驱动嘛,没有使用内核自带的驱动?我最近也在弄V3S+GT911这块东西,望不吝赐教
楼主 #7 2021-04-13 10:20:59
hanzixi_angel
已发帖子: 54
Re: V3s GT911驱动问题
mysteryli 说:
hanzixi_angel 说:
5.2.y中如下:
     .irq_banks = 2,
4.10.y中如下:
    .irq_banks = 2,
更改过后如下:
    .irq_banks = 2,
        .irq_bank_base = 1,
我使用的就是内核自带的gt911驱动   设备树是用的licheepi的   可以正常使用
#8 2021-04-13 20:50:59
mysteryli
已发帖子: 487
Re: V3s GT911驱动问题
hanzixi_angel 说:
mysteryli 说:
hanzixi_angel 说:
5.2.y中如下:
     .irq_banks = 2,
4.10.y中如下:
    .irq_banks = 2,
更改过后如下:
    .irq_banks = 2,
        .irq_bank_base = 1,
谢谢,我参照你的已经搞定了
