你好
我想在licheepi-zero中播放mp3,我执行了以下代码:
/usr/bin/mpg123 /etc/quran.mp3.但是扬声器没有声音
# /usr/bin/mpg123 /etc/quran.mp3
High Performance MPEG 1.0/2.0/2.5 Audio Player for Layers 1, 2 and 3
version 1.25.13; written and copyright by Michael Hipp and others
free software (LGPL) without any warranty but with best wishes
Directory: /etc/
Terminal control enabled, press 'h' for listing of keys and functions.
Playing MPEG stream 1 of 1: quran.mp3 ...
MPEG 1.0 L III vbr 48000 j-s
Title: Sourate al-fatiha - Maher Mai'iqli
Artist: Al Sheikh Maher Al Muaiqly
Album: Juzz A'ama avec invocations
[0:36] Decoding of quran.mp3 finished.
.执行以下代码时 :
startx /usr/bin/mpg123 /etc/quran.mp3.# startx /usr/bin/mpg123 /etc/quran.mp3
xauth: file /root/.serverauth.163 does not exist
X.Org X Server 1.20.10
X Protocol Version 11, Revision 0
Build Operating System: Linux 5.4.0-58-generic x86_64
Current Operating System: Linux Lanova-Consulting 4.10.15-licheepi-zero+ #5 SMP Tue Dec 29 18:29:59 +01 2020 armv7l
Kernel command line: console=ttyS0,115200 panic=5 console=ttyS0 rootwait root=/dev/mmcblk0p2 earlyprintk rw
Build Date: 29 December 2020 12:25:36PM
Current version of pixman: 0.40.0
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.1.log", Time: Thu Jan 1 00:02:18 1970
(==) Using config file: "/etc/X11/xorg.conf"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
.至于录像,他和我一起工作
startx /usr/bin/mpv /etc/videoplay.mp4.https://drive.google.com/file/d/1ZlFXsiMM-5yQTizij547Wof9ER3YseyB/view?usp=sharing/
最近编辑记录 rachid (2020-12-30 22:03:07)
首先确认是不是用alsa输出,
然后用tinymix 设置声卡寄存器:
请问全志V3s使用荔枝派最新的 linux 4.13-y 分支,如何支持声卡?
http://whycan.com/t_489.html#p1284
uuid wrote:
首先确认是不是用alsa输出,
然后用tinymix 设置声卡寄存器:
(出处:哇酷开发者社区【全志 V3S/F1C100s/X3】).
不幸的是声音不起作用
我已经执行了所有这些命令
