楼主 #1 2021-01-15 18:04:59
lijianjian135
荔枝派nano运行Tina tvout问题
请问大家有在nano上玩过TV_OUT吗,我这加上这个输出编译出来的内核直接就panic,有人遇到过吗
[    0.365685] para->mclk[MOD_CLK_LCD1CH0]=0xc180c300
[    0.370731] para->mclk[MOD_CLK_LCD1CH1]=0xc180c400
[    0.375685] disp tv init
[    0.378351] tcon_clk=0xc180c300, tcon_clk_parent=0x0
[    0.383530] tcon_clk=0xc180c300, tcon_clk_parent=0xc18043c0
[    0.389278] tve_clk=0xc180c400, tve_clk_parent=0xc18043c0
[    0.394893] disp al tv init
[    0.400730] fetch script datadisp.screen2_output_type fail
[    0.406711] fetch script datadisp.screen2_output_mode fail
[    0.415092] fetch script datadisp.fb2_format fail
[    0.420352] fetch script datadisp.fb2_scaler_mode_enable fail
[    0.426587] fetch script datadisp.fb2_width fail
[    0.431749] fetch script datadisp.fb2_height fail
[    0.436647] disp_malloc fail, size=0x2a3000
[    0.441053] disp_malloc fail!
[    0.444484] Unable to handle kernel paging request at virtual address 00054920
[    0.452043] pgd = c0004000
[    0.454891] [00054920] *pgd=00000000
[    0.458634] Internal error: Oops: 805 [#1] ARM
[    0.463233] Modules linked in:
[    0.466446] CPU: 0 PID: 1 Comm: swapper Not tainted 3.10.65 #11
[    0.472550] task: c1832000 ti: c1834000 task.ti: c1834000
[    0.478134] PC is at memcpy+0x244/0x330
[    0.482119] LR is at 0xadc8ff9e
[    0.485407] pc : [<c0166004>]    lr : [<adc8ff9e>]    psr: 20000013
[    0.485407] sp : c1835c40  ip : ff9eaec8  fp : c1835d7c
[    0.497230] r10: 000000ef  r9 : ff9dacc8  r8 : ff99a8c7
[    0.502625] r7 : ff97a6c6  r6 : ff96a5c7  r5 : ff94a2c4  r4 : ff93a2c4
[    0.509340] r3 : ff9ca7c2  r2 : 00000460  r1 : c2854b58  r0 : 00054920
[    0.516056] Flags: nzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
[    0.523564] Control: 0005317f  Table: 80004000  DAC: 00000017
[    0.529483]
[    0.529483] PC: 0xc0165f84:
[    0.533995] 5f84  cafffff9 e2411003 eaffffba e252201c ba00001f e92d03e0 f5d1f000 e2522060
[    0.542484] 5fa4  f5d1f01c ba000002 f5d1f03c f5d1f05c f5d1f07c e8b100f0 e1a0382e e2522020
[    0.550969] 5fc4  e8b15300 e1833804 e1a04824 e1844805 e1a05825 e1855806 e1a06826 e1866807
[    0.559455] 5fe4  e1a07827 e1877808 e1a08828 e1888809 e1a09829 e189980c e1a0c82c e18cc80e
[    0.567941] 6004  e8a013f8 aaffffe9 e3720060 aaffffe8 e8bd03e0 e212c01c 0a000005 e1a0382e
[    0.576426] 6024  e491e004 e25cc004 e183380e e4803004 cafffff9 e2411002 eaffff8e e252201c
[    0.584912] 6044  ba00001f e92d03e0 f5d1f000 e2522060 f5d1f01c ba000002 f5d1f03c f5d1f05c
[    0.593398] 6064  f5d1f07c e8b100f0 e1a03c2e e2522020 e8b15300 e1833404 e1a04c24 e1844405
[    0.601887]
#2 2021-01-15 23:05:02
已发帖子: 596
Re: 荔枝派nano运行Tina tvout问题
裸机上玩过,不大了解linux的
#3 2021-01-16 08:09:18
LinuxGo
已发帖子: 88
可以输出接电视机上吗?
#4 2021-01-16 08:28:39
raspberryman
已发帖子: 503
LinuxGo 说:
可以输出接电视机上吗?
可以,本来就是接电视机的。
#5 2022-02-28 00:30:04
X3
已发帖子: 85
遇到和楼主一样的问题,发现居然是 F1C100s / F1C500 DRAM 内存不够引起的,用 F1C200s / F1C600s 代替就好了,FK浪费一天时间。
