请问大家有在nano上玩过TV_OUT吗,我这加上这个输出编译出来的内核直接就panic,有人遇到过吗
[ 0.365685] para->mclk[MOD_CLK_LCD1CH0]=0xc180c300
[ 0.370731] para->mclk[MOD_CLK_LCD1CH1]=0xc180c400
[ 0.375685] disp tv init
[ 0.378351] tcon_clk=0xc180c300, tcon_clk_parent=0x0
[ 0.383530] tcon_clk=0xc180c300, tcon_clk_parent=0xc18043c0
[ 0.389278] tve_clk=0xc180c400, tve_clk_parent=0xc18043c0
[ 0.394893] disp al tv init
[ 0.400730] fetch script datadisp.screen2_output_type fail
[ 0.406711] fetch script datadisp.screen2_output_mode fail
[ 0.415092] fetch script datadisp.fb2_format fail
[ 0.420352] fetch script datadisp.fb2_scaler_mode_enable fail
[ 0.426587] fetch script datadisp.fb2_width fail
[ 0.431749] fetch script datadisp.fb2_height fail
[ 0.436647] disp_malloc fail, size=0x2a3000
[ 0.441053] disp_malloc fail!
[ 0.444484] Unable to handle kernel paging request at virtual address 00054920
[ 0.452043] pgd = c0004000
[ 0.454891] [00054920] *pgd=00000000
[ 0.458634] Internal error: Oops: 805 [#1] ARM
[ 0.463233] Modules linked in:
[ 0.466446] CPU: 0 PID: 1 Comm: swapper Not tainted 3.10.65 #11
[ 0.472550] task: c1832000 ti: c1834000 task.ti: c1834000
[ 0.478134] PC is at memcpy+0x244/0x330
[ 0.482119] LR is at 0xadc8ff9e
[ 0.485407] pc : [<c0166004>] lr : [<adc8ff9e>] psr: 20000013
[ 0.485407] sp : c1835c40 ip : ff9eaec8 fp : c1835d7c
[ 0.497230] r10: 000000ef r9 : ff9dacc8 r8 : ff99a8c7
[ 0.502625] r7 : ff97a6c6 r6 : ff96a5c7 r5 : ff94a2c4 r4 : ff93a2c4
[ 0.509340] r3 : ff9ca7c2 r2 : 00000460 r1 : c2854b58 r0 : 00054920
[ 0.516056] Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
[ 0.523564] Control: 0005317f Table: 80004000 DAC: 00000017
[ 0.529483]
[ 0.529483] PC: 0xc0165f84:
[ 0.533995] 5f84 cafffff9 e2411003 eaffffba e252201c ba00001f e92d03e0 f5d1f000 e2522060
[ 0.542484] 5fa4 f5d1f01c ba000002 f5d1f03c f5d1f05c f5d1f07c e8b100f0 e1a0382e e2522020
[ 0.550969] 5fc4 e8b15300 e1833804 e1a04824 e1844805 e1a05825 e1855806 e1a06826 e1866807
[ 0.559455] 5fe4 e1a07827 e1877808 e1a08828 e1888809 e1a09829 e189980c e1a0c82c e18cc80e
[ 0.567941] 6004 e8a013f8 aaffffe9 e3720060 aaffffe8 e8bd03e0 e212c01c 0a000005 e1a0382e
[ 0.576426] 6024 e491e004 e25cc004 e183380e e4803004 cafffff9 e2411002 eaffff8e e252201c
[ 0.584912] 6044 ba00001f e92d03e0 f5d1f000 e2522060 f5d1f01c ba000002 f5d1f03c f5d1f05c
[ 0.593398] 6064 f5d1f07c e8b100f0 e1a03c2e e2522020 e8b15300 e1833404 e1a04c24 e1844405
[ 0.601887]离线
裸机上玩过,不大了解linux的
可以输出接电视机上吗?
LinuxGo wrote:
可以输出接电视机上吗?
可以,本来就是接电视机的。
遇到和楼主一样的问题,发现居然是 F1C100s / F1C500 DRAM 内存不够引起的,用 F1C200s / F1C600s 代替就好了,FK浪费一天时间。
