无限重启
[ 0.000000] vmalloc : 0xc4000000 - 0xff800000 ( 952 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc3e89000 ( 62 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0700000 (7136 kB)
[ 0.000000] .init : 0xc0900000 - 0xc0a00000 (1024 kB)
[ 0.000000] .data : 0xc0a00000 - 0xc0a3c240 ( 241 kB)
[ 0.000000] .bss : 0xc0a43ac0 - 0xc0a85d14 ( 265 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU event tracing is enabled.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000019] Switching to timer-based delay loop, resolution 41ns
[ 0.000186] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000428] Console: colour dummy device 80x30
[ 0.000863] console [tty0] enabled
[ 0.000900] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000939] pid_max: default: 32768 minimum: 301
[ 0.001078] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001108] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001733] CPU: Testing write buffer coherency: ok
[ 0.002129] /cpus/cpu@0 missing clock-frequency property
[ 0.002175] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002628] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.002826] Hierarchical SRCU implementation.
[ 0.003339] smp: Bringing up secondary CPUs ...
[ 0.003371] smp: Brought up 1 node, 1 CPU
[ 0.003390] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.003410] CPU: All CPU(s) started in SVC mode.
[ 0.004202] devtmpfs: initialized
[ 0.007518] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.007822] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.007878] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.008059] pinctrl core: initialized pinctrl subsystem
[ 0.008942] random: get_random_u32 called from bucket_table_alloc+0x110/0x238 with crng_init=0
[ 0.009120] NET: Registered protocol family 16
[ 0.009583] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.010853] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.010906] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.024985] SCSI subsystem initialized
[ 0.025350] usbcore: registered new interface driver usbfs
[ 0.025455] usbcore: registered new interface driver hub
[ 0.025568] usbcore: registered new device driver usb
[ 0.025846] pps_core: LinuxPPS API ver. 1 registered
[ 0.025875] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.025923] PTP clock support registered
[ 0.026153] Advanced Linux Sound Architecture Driver Initialized.
[ 0.026867] Bluetooth: Core ver 2.22
[ 0.026961] NET: Registered protocol family 31
[ 0.026983] Bluetooth: HCI device and connection manager initialized
[ 0.027013] Bluetooth: HCI socket layer initialized
[ 0.027036] Bluetooth: L2CAP socket layer initialized
[ 0.027080] Bluetooth: SCO socket layer initialized
[ 0.028273] clocksource: Switched to clocksource arch_sys_counter
[ 0.039245] NET: Registered protocol family 2
[ 0.039897] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.039954] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.039993] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.040139] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.040204] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.040440] NET: Registered protocol family 1
[ 0.041045] RPC: Registered named UNIX socket transport module.
[ 0.041085] RPC: Registered udp transport module.
[ 0.041103] RPC: Registered tcp transport module.
[ 0.041120] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.043128] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.052392] NFS: Registering the id_resolver key type
[ 0.052485] Key type id_resolver registered
[ 0.052504] Key type id_legacy registered
[ 0.052565] jffs2: version 2.2. (NAND) ?? 2001-2006 Red Hat, Inc.
[ 0.054033] random: fast init done
[ 0.057080] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.057139] io scheduler noop registered
[ 0.057158] io scheduler deadline registered
[ 0.057381] io scheduler cfq registered (default)
[ 0.057409] io scheduler mq-deadline registered
[ 0.057428] io scheduler kyber registered
[ 0.062009] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.132401] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.135678] console [ttyS0] disabled
[ 0.155981] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 36, base_baud = 1500000) is a U6_16550A
[ 0.772949] console [ttyS0] enabled
[ 0.797967] 1c28400.serial: ttyS1 at MMIO 0x1c28400 (irq = 37, base_baud = 1500000) is a U6_16550A
[ 0.828548] 1c28800.serial: ttyS2 at MMIO 0x1c28800 (irq = 38, base_baud = 1500000) is a U6_16550A
[ 0.842395] m25p80 spi32766.0: unrecognized JEDEC id bytes: 00, 00, 00
[ 0.849107] m25p80: probe of spi32766.0 failed with error -2
[ 0.855213] libphy: Fixed MDIO Bus: probed
[ 0.859920] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[ 0.865735] dwmac-sun8i 1c30000.ethernet: No regulator found
[ 0.871532] dwmac-sun8i 1c30000.ethernet: Will use internal PHY
[ 0.877555] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 148000 (expect 38000)
[ 0.887187] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[ 0.892904] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[ 0.900156] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[ 0.905822] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[ 0.913066] dwmac-sun8i 1c30000.ethernet: COE Type 2
[ 0.918037] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[ 0.925047] libphy: stmmac: probed
[ 0.930526] usbcore: registered new interface driver rtl8192cu
[ 0.936396] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.943058] ehci-platform: EHCI generic platform driver
[ 0.948653] ehci-platform 1c1a000.usb: EHCI Host Controller
[ 0.954291] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[ 0.962293] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[ 0.998293] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[ 1.005569] hub 1-0:1.0: USB hub found
[ 1.009547] hub 1-0:1.0: 1 port detected
[ 1.014090] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.020415] ohci-platform: OHCI generic platform driver
[ 1.026003] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[ 1.032767] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[ 1.040745] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[ 1.113451] hub 2-0:1.0: USB hub found
[ 1.117300] hub 2-0:1.0: 1 port detected
[ 1.124952] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[ 1.134638] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
[ 1.143732] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
[ 1.150673] sun6i-rtc 1c20400.rtc: RTC enabled
[ 1.155243] i2c /dev entries driver
[ 1.160244] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input1
[ 1.169816] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.238330] sunxi-mmc 1c0f000.mmc: base:0xc423b000 irq:23
[ 1.285355] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.295357] mmc0: new high speed SD card at address 21e9
[ 1.301238] sunxi-mmc 1c10000.mmc: base:0xc4251000 irq:24
[ 1.307707] usbcore: registered new interface driver usbhid
[ 1.313402] usbhid: USB HID core driver
[ 1.318035] mmcblk0: mmc0:21e9 APPSD 1.88 GiB
[ 1.324728] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01c23000 not registered
[ 1.332825] sun4i-codec 1c22c00.codec: Failed to register our card
[ 1.339353] mmcblk0: p1 p2
[ 1.347474] NET: Registered protocol family 17
[ 1.352195] Key type dns_resolver registered
[ 1.356629] Registering SWP/SWPB emulation handler
[ 1.366198] simple-framebuffer 43e89000.framebuffer: framebuffer at 0x43e89000, 0x177000 bytes, mapped to 0xc4400000
[ 1.376900] simple-framebuffer 43e89000.framebuffer: format=x8r8g8b8, mode=800x480x32, linelength=3200
[ 1.393261] Console: switching to colour frame buffer device 100x30
[ 1.409605] simple-framebuffer 43e89000.framebuffer: fb0: simplefb registered!
[ 1.422127] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 1.441347] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.451183] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[ 1.464421] hub 3-0:1.0: USB hub found
[ 1.472416] hub 3-0:1.0: 1 port detected
[ 1.481624] using random self ethernet address
[ 1.490007] using random host ethernet address
[ 1.499278] usb0: HOST MAC 9e:b6:87:db:91:df
[ 1.507232] usb0: MAC 76:47:05:34:5b:7a
[ 1.514701] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[ 1.525796] g_cdc gadget: g_cdc ready
[ 1.535657] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[ 1.547990] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 00:00:17 UTC (17)
[ 1.560071] vcc5v0: disabling
[ 1.566668] ALSA device list:
[ 1.573254] #0: V3s Audio Codec
[ 1.581697] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[ 1.595038] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[ 1.610385] mmc1: new high speed SDIO card at address 0001
[ 1.625221] EXT4-fs (mmcblk0p2): warning: mounting fs with errors, running e2fsck is recommended
[ 1.643322] EXT4-fs (mmcblk0p2): recovery complete
[ 1.651865] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.663755] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 1.681167] EXT4-fs error (device mmcblk0p2): ext4_iget:4711: inode #64769: comm swapper/0: checksum invalid
[ 1.699736] devtmpfs: error mounting -74
[ 1.708715] Freeing unused kernel memory: 1024K
[ 1.717150] EXT4-fs error (device mmcblk0p2): ext4_iget:4711: inode #64784: comm swapper/0: checksum invalid
[ 1.735595] Starting init: /sbin/init exists but couldn't execute it (error -74)
[ 1.930700] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000200
[ 1.930700]
[ 1.947201] CPU: 0 PID: 1 Comm: sh Not tainted 4.13.16-licheepi-zero #5
[ 1.957577] Hardware name: Allwinner sun8i Family
[ 1.966084] [<c010e794>] (unwind_backtrace) from [<c010b418>] (show_stack+0x10/0x14)
[ 1.977812] [<c010b418>] (show_stack) from [<c06cffc4>] (dump_stack+0x88/0x9c)
[ 1.989068] [<c06cffc4>] (dump_stack) from [<c011b708>] (panic+0xdc/0x248)
[ 1.999983] [<c011b708>] (panic) from [<c011e22c>] (complete_and_exit+0x0/0x1c)
[ 2.011322] [<c011e22c>] (complete_and_exit) from [<c3831f70>] (0xc3831f70)
[ 2.022334] Rebooting in 5 seconds..
根文件系统有问题,没有执行权限或者文件不正确。
制作根文件系统时候执行
# chmod +x /sbin/init
我也出现这个问题。怎么解决?
根文件系统有问题.
