楼主 #1 2020-09-27 10:39:34
kingreid
已发帖子: 57
v3s TF卡烧录问题-无限重启 日志!
无限重启
[    0.000000]       .data : 0xc0a00000 - 0xc0a3c240   ( 241 kB)
[    0.000000]        .bss : 0xc0a43ac0 - 0xc0a85d14   ( 265 kB)
[    0.000186] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000428] Console: colour dummy device 80x30
[    0.000863] console [tty0] enabled
[    0.000900] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000939] pid_max: default: 32768 minimum: 301
[    0.001078] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.001108] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.001733] CPU: Testing write buffer coherency: ok
[    0.002129] /cpus/cpu@0 missing clock-frequency property
[    0.002175] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.002628] Setting up static identity map for 0x40100000 - 0x40100060
[    0.002826] Hierarchical SRCU implementation.
[    0.003339] smp: Bringing up secondary CPUs ...
[    0.003371] smp: Brought up 1 node, 1 CPU
[    0.003390] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[    0.003410] CPU: All CPU(s) started in SVC mode.
[    0.004202] devtmpfs: initialized
[    0.007518] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.007822] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.007878] futex hash table entries: 256 (order: 2, 16384 bytes)
[    0.008059] pinctrl core: initialized pinctrl subsystem
[    0.008942] random: get_random_u32 called from bucket_table_alloc+0x110/0x238 with crng_init=0
[    0.009120] NET: Registered protocol family 16
[    0.009583] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.010853] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.010906] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.024985] SCSI subsystem initialized
[    0.025350] usbcore: registered new interface driver usbfs
[    0.025455] usbcore: registered new interface driver hub
[    0.025568] usbcore: registered new device driver usb
[    0.025846] pps_core: LinuxPPS API ver. 1 registered
[    0.025875] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.025923] PTP clock support registered
[    0.026153] Advanced Linux Sound Architecture Driver Initialized.
[    0.026867] Bluetooth: Core ver 2.22
[    0.026961] NET: Registered protocol family 31
[    0.026983] Bluetooth: HCI device and connection manager initialized
[    0.027013] Bluetooth: HCI socket layer initialized
[    0.027036] Bluetooth: L2CAP socket layer initialized
[    0.027080] Bluetooth: SCO socket layer initialized
[    0.028273] clocksource: Switched to clocksource arch_sys_counter
[    0.039245] NET: Registered protocol family 2
[    0.039897] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.039954] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[    0.039993] TCP: Hash tables configured (established 1024 bind 1024)
[    0.040139] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.040204] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.040440] NET: Registered protocol family 1
[    0.041045] RPC: Registered named UNIX socket transport module.
[    0.041085] RPC: Registered udp transport module.
[    0.041103] RPC: Registered tcp transport module.
[    0.041120] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.043128] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[    0.052392] NFS: Registering the id_resolver key type
[    0.052485] Key type id_resolver registered
[    0.052504] Key type id_legacy registered
[    0.052565] jffs2: version 2.2. (NAND) ?? 2001-2006 Red Hat, Inc.
[    0.054033] random: fast init done
[    0.057080] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    0.057139] io scheduler noop registered
[    0.057158] io scheduler deadline registered
[    0.057381] io scheduler cfq registered (default)
[    0.057409] io scheduler mq-deadline registered
[    0.057428] io scheduler kyber registered
[    0.062009] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.132401] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.135678] console [ttyS0] disabled
[    0.155981] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 36, base_baud = 1500000) is a U6_16550A
[    0.772949] console [ttyS0] enabled
[    0.797967] 1c28400.serial: ttyS1 at MMIO 0x1c28400 (irq = 37, base_baud = 1500000) is a U6_16550A
[    0.828548] 1c28800.serial: ttyS2 at MMIO 0x1c28800 (irq = 38, base_baud = 1500000) is a U6_16550A
[    0.842395] m25p80 spi32766.0: unrecognized JEDEC id bytes: 00, 00, 00
[    0.849107] m25p80: probe of spi32766.0 failed with error -2
[    0.855213] libphy: Fixed MDIO Bus: probed
[    0.859920] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[    0.865735] dwmac-sun8i 1c30000.ethernet: No regulator found
[    0.871532] dwmac-sun8i 1c30000.ethernet: Will use internal PHY
[    0.877555] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 148000 (expect 38000)
[    0.887187] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[    0.892904] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[    0.900156] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[    0.905822] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[    0.913066] dwmac-sun8i 1c30000.ethernet: COE Type 2
[    0.918037] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[    0.925047] libphy: stmmac: probed
[    0.930526] usbcore: registered new interface driver rtl8192cu
[    0.936396] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.943058] ehci-platform: EHCI generic platform driver
[    0.948653] ehci-platform 1c1a000.usb: EHCI Host Controller
[    0.954291] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    0.962293] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[    0.998293] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    1.005569] hub 1-0:1.0: USB hub found
[    1.009547] hub 1-0:1.0: 1 port detected
[    1.014090] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.020415] ohci-platform: OHCI generic platform driver
[    1.026003] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    1.032767] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[    1.040745] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[    1.113451] hub 2-0:1.0: USB hub found
[    1.117300] hub 2-0:1.0: 1 port detected
[    1.124952] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[    1.134638] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
[    1.143732] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
[    1.150673] sun6i-rtc 1c20400.rtc: RTC enabled
[    1.155243] i2c /dev entries driver
[    1.160244] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input1
[    1.169816] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.238330] sunxi-mmc 1c0f000.mmc: base:0xc423b000 irq:23
[    1.285355] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.295357] mmc0: new high speed SD card at address 21e9
[    1.301238] sunxi-mmc 1c10000.mmc: base:0xc4251000 irq:24
[    1.307707] usbcore: registered new interface driver usbhid
[    1.313402] usbhid: USB HID core driver
[    1.318035] mmcblk0: mmc0:21e9 APPSD 1.88 GiB
[    1.324728] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01c23000 not registered
[    1.332825] sun4i-codec 1c22c00.codec: Failed to register our card
[    1.339353]  mmcblk0: p1 p2
[    1.347474] NET: Registered protocol family 17
[    1.352195] Key type dns_resolver registered
[    1.356629] Registering SWP/SWPB emulation handler
[    1.366198] simple-framebuffer 43e89000.framebuffer: framebuffer at 0x43e89000, 0x177000 bytes, mapped to 0xc4400000
[    1.376900] simple-framebuffer 43e89000.framebuffer: format=x8r8g8b8, mode=800x480x32, linelength=3200
[    1.393261] Console: switching to colour frame buffer device 100x30
[    1.409605] simple-framebuffer 43e89000.framebuffer: fb0: simplefb registered!
[    1.422127] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    1.441347] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    1.451183] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[    1.464421] hub 3-0:1.0: USB hub found
[    1.472416] hub 3-0:1.0: 1 port detected
[    1.481624] using random self ethernet address
[    1.490007] using random host ethernet address
[    1.499278] usb0: HOST MAC 9e:b6:87:db:91:df
[    1.507232] usb0: MAC 76:47:05:34:5b:7a
[    1.514701] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[    1.525796] g_cdc gadget: g_cdc ready
[    1.535657] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[    1.547990] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 00:00:17 UTC (17)
[    1.560071] vcc5v0: disabling
[    1.566668] ALSA device list:
[    1.573254]   #0: V3s Audio Codec
[    1.581697] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[    1.595038] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[    1.610385] mmc1: new high speed SDIO card at address 0001
[    1.625221] EXT4-fs (mmcblk0p2): warning: mounting fs with errors, running e2fsck is recommended
[    1.643322] EXT4-fs (mmcblk0p2): recovery complete
[    1.651865] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.663755] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    1.681167] EXT4-fs error (device mmcblk0p2): ext4_iget:4711: inode #64769: comm swapper/0: checksum invalid
[    1.699736] devtmpfs: error mounting -74
[    1.708715] Freeing unused kernel memory: 1024K
[    1.717150] EXT4-fs error (device mmcblk0p2): ext4_iget:4711: inode #64784: comm swapper/0: checksum invalid
[    1.735595] Starting init: /sbin/init exists but couldn't execute it (error -74)
[    1.930700] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000200
[    1.930700]
[    1.947201] CPU: 0 PID: 1 Comm: sh Not tainted 4.13.16-licheepi-zero #5
[    1.957577] Hardware name: Allwinner sun8i Family
[    1.966084] [<c010e794>] (unwind_backtrace) from [<c010b418>] (show_stack+0x10/0x14)
[    1.977812] [<c010b418>] (show_stack) from [<c06cffc4>] (dump_stack+0x88/0x9c)
[    1.989068] [<c06cffc4>] (dump_stack) from [<c011b708>] (panic+0xdc/0x248)
[    1.999983] [<c011b708>] (panic) from [<c011e22c>] (complete_and_exit+0x0/0x1c)
[    2.011322] [<c011e22c>] (complete_and_exit) from [<c3831f70>] (0xc3831f70)
[    2.022334] Rebooting in 5 seconds..
#2 2020-09-27 11:12:34
孤星泪
已发帖子: 235
Re: v3s TF卡烧录问题-无限重启 日志!
根文件系统有问题,没有执行权限或者文件不正确。
#3 2020-09-27 11:28:39
JasonWoo
已发帖子: 84
制作根文件系统时候执行
# chmod +x /sbin/init
#4 2021-01-17 21:47:56
leefei
已发帖子: 53
我也出现这个问题。怎么解决?
#5 2021-01-17 21:50:18
九重天
已发帖子: 27
根文件系统有问题.
