楼主 #1 2021-01-21 15:24:55
1157108955
在制作debian9.9根文件系统时出现了问题
大家好,我的板子是lichee zero,按照晕哥的教程成功用uboot+linux+buildroot制作了tf卡,成功开启。于是我接下来又按照Debian 9.9 (stretch) 文件系统制作想做一个debian的文件系统,因为那样可以包管理,比较方便。
我按照链接的教程做完了,然后插卡上电,却不断“五秒后重启”。串口连接电脑,有以下启动信息:
U-Boot SPL 2017.01-rc2 (Jan 19 2021 - 23:08:21)
DRAM: 64 MiB
Trying to boot from MMC1
U-Boot 2017.01-rc2 (Jan 19 2021 - 23:08:21 -0800) Allwinner Technology
Model: Lichee Pi Zero
DRAM:  64 MiB
MMC:   SUNXI SD/MMC: 0
In:    serial@01c28000
Out:   serial@01c28000
Err:   serial@01c28000
DRAM:  64 MiB
In:    serial@01c28000
Net:   No ethernet found.
No controllers found
reading zImage
3816728 bytes read in 198 ms (18.4 MiB/s)
9262 bytes read in 25 ms (361.3 KiB/s)
   Loading Device Tree to 42dfa000, end 42dff42d ... OK
[    0.000000] Linux version 4.10.15-licheepi-zero (francolin@ubuntu) (gcc version 7.5.0 (Ubuntu/Linaro 7.5.0-3ubuntu1~18.04) ) #1 SMP Wed Jan 20 00:50:08 PST 2021
[    0.000000] OF: fdt:Machine model: Lichee Pi Zero with Dock
[    0.000000] percpu: Embedded 14 pages/cpu @c3f63000 s24716 r8192 d24436 u57344
[    0.000000] Kernel command line: console=ttyS0,115200 panic=5 rootwait root=/dev/mmcblk0p2 earlyprintk rw  vt.global_cursor_default=0
[    0.000000] Memory: 55156K/65536K available (6144K kernel code, 199K rwdata, 1388K rodata, 1024K init, 259K bss, 10380K reserved, 0K cma-reserved, 0K highmem)
[    0.000000]       .data : 0xc0a00000 - 0xc0a31e40   ( 200 kB)
[    0.000000]        .bss : 0xc0a33000 - 0xc0a73f0c   ( 260 kB)
[    0.000000] 	Build-time adjustment of leaf fanout to 32.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=1
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (virt).
[    0.000138] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000353] Console: colour dummy device 80x30
[    0.000391] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000406] pid_max: default: 32768 minimum: 301
[    0.000537] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000547] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.001239] CPU: Testing write buffer coherency: ok
[    0.001634] /cpus/cpu@0 missing clock-frequency property
[    0.001656] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.002006] Setting up static identity map for 0x40100000 - 0x40100058
[    0.002732] smp: Bringing up secondary CPUs ...
[    0.002748] smp: Brought up 1 node, 1 CPU
[    0.002758] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[    0.002765] CPU: All CPU(s) started in SVC mode.
[    0.003538] devtmpfs: initialized
[    0.006373] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.006639] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.006667] futex hash table entries: 256 (order: 2, 16384 bytes)
[    0.006816] pinctrl core: initialized pinctrl subsystem
[    0.007792] NET: Registered protocol family 16
[    0.008224] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.009416] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.009432] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.021123] SCSI subsystem initialized
[    0.021380] usbcore: registered new interface driver usbfs
[    0.021462] usbcore: registered new interface driver hub
[    0.021569] usbcore: registered new device driver usb
[    0.021788] pps_core: LinuxPPS API ver. 1 registered
[    0.021798] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.021821] PTP clock support registered
[    0.022024] Advanced Linux Sound Architecture Driver Initialized.
[    0.023813] clocksource: Switched to clocksource arch_sys_counter
[    0.034967] NET: Registered protocol family 2
[    0.035584] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.035614] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[    0.035638] TCP: Hash tables configured (established 1024 bind 1024)
[    0.035724] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.035769] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.035970] NET: Registered protocol family 1
[    0.036567] RPC: Registered named UNIX socket transport module.
[    0.036586] RPC: Registered udp transport module.
[    0.036592] RPC: Registered tcp transport module.
[    0.036597] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.038767] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[    0.047830] NFS: Registering the id_resolver key type
[    0.047884] Key type id_resolver registered
[    0.047893] Key type id_legacy registered
[    0.051897] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    0.051919] io scheduler noop registered
[    0.051927] io scheduler deadline registered
[    0.052113] io scheduler cfq registered (default)
[    0.056306] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.126981] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.130173] console [ttyS0] disabled
[    0.150455] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 34, base_baud = 1500000) is a U6_16550A
[    0.705765] console [ttyS0] enabled
[    0.709982] [drm] Initialized
[    0.714864] libphy: Fixed MDIO Bus: probed
[    0.719164] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.725772] ehci-platform: EHCI generic platform driver
[    0.731089] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.737314] ohci-platform: OHCI generic platform driver
[    0.742976] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[    0.752452] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
[    0.761396] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
[    0.768299] sun6i-rtc 1c20400.rtc: RTC enabled
[    0.772843] i2c /dev entries driver
[    0.777690] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input1
[    0.787255] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    0.853860] sunxi-mmc 1c0f000.mmc: base:0xc485f000 irq:23
[    0.903801] mmc0: host does not support reading read-only switch, assuming write-enable
[    0.913843] sunxi-mmc 1c10000.mmc: base:0xc4863000 irq:24
[    0.920199] usbcore: registered new interface driver usbhid
[    0.925856] usbhid: USB HID core driver
[    0.930409] mmc0: new high speed SDHC card at address e624
[    0.937626] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01c23000 not registered
[    0.945689] sun4i-codec 1c22c00.codec: Failed to register our card
[    0.952416] mmcblk0: mmc0:e624 SC32G 29.7 GiB
[    0.958796] NET: Registered protocol family 17
[    0.963404] Key type dns_resolver registered
[    0.967925] Registering SWP/SWPB emulation handler
[    0.974311]  mmcblk0: p1 p2
[    0.985163] usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    0.992972] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    0.998838] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[    1.007971] hub 1-0:1.0: USB hub found
[    1.011847] hub 1-0:1.0: 1 port detected
[    1.016629] using random self ethernet address
[    1.021125] using random host ethernet address
[    1.026678] usb0: HOST MAC f2:11:5c:a1:e5:da
[    1.030992] usb0: MAC fe:1f:a9:4e:6f:b8
[    1.034978] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[    1.042458] g_cdc gadget: g_cdc ready
[    1.048564] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[    1.057595] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 00:00:55 UTC (55)
[    1.065911] vcc5v0: disabling
[    1.068886] ALSA device list:
[    1.071850]   #0: V3s Audio Codec
[    1.080210] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[    1.091361] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[    1.114705] EXT4-fs (mmcblk0p2): recovery complete
[    1.119526] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.127795] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    1.144080] devtmpfs: mounted
[    1.148253] Freeing unused kernel memory: 1024K
/sbin/init: error while loading shared libraries: /usr/lib/arm-linux-gnueabihf/liblz4.so.1: file too short
[    1.324007] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00007f00
[    1.324007]
[    1.333151] CPU: 0 PID: 1 Comm: init Not tainted 4.10.15-licheepi-zero #1
[    1.339927] Hardware name: Allwinner sun8i Family
[    1.344666] [<c010e2a4>] (unwind_backtrace) from [<c010afa0>] (show_stack+0x10/0x14)
[    1.352411] [<c010afa0>] (show_stack) from [<c0335b78>] (dump_stack+0x88/0x9c)
[    1.359634] [<c0335b78>] (dump_stack) from [<c01a681c>] (panic+0xdc/0x248)
[    1.366509] [<c01a681c>] (panic) from [<c011e130>] (complete_and_exit+0x0/0x1c)
[    1.373813] [<c011e130>] (complete_and_exit) from [<c3833f70>] (0xc3833f70)
[    1.380774] Rebooting in 5 seconds..
希望大家可以帮我看一下是什么问题
最近编辑记录 1157108955 (2021-01-21 15:26:00)
楼主 #2 2021-01-21 15:31:57
1157108955
Re: 在制作debian9.9根文件系统时出现了问题
可以看到有这样一个报错:/sbin/init: error while loading shared libraries: /usr/lib/arm-linux-gnueabihf/liblz4.so.1: file too short
可是我不知道是为什么,希望有懂的人可以帮我看一下
#3 2021-01-21 15:41:56
raspberryman
已发帖子: 503
检查文件大小是不是零字节,
然后可以在电脑模拟器上面跑一跑:
在 ubuntu@x86 用 chroot 到 ARM 平台的 rootfs
http://whycan.com/t_3251.html
(出处:哇酷开发者社区)
#4 2021-01-21 16:01:01
Kevincoooool
已发帖子: 39
没有正确弹出TF卡,要eject
#5 2021-01-22 09:27:07
风云剑
看起来如楼上几位所说,文件没copy成功。
我按照那个教程做过debain10,没问题,有兴趣可以试试。
这是我做的,比较大,压缩包500M。
链接: https://pan.baidu.com/s/1hZTClevmgj8ss8zsHqBdkg
提取码:nvxg
这个是比较小的版本,压缩包130M。
链接: https://pan.baidu.com/s/1TsvrBg0MdCDpPhfchd9peA
提取码:z5ot
#6 2021-01-22 09:54:48
lghtjpu
已发帖子: 41
请问有没有ubuntu core的制作教程啊
楼主 #7 2021-01-22 12:21:27
1157108955
风云剑 说:
这是我做的,比较大,压缩包500M。
提取码:nvxg
这个是比较小的版本,压缩包130M。
提取码:z5ot
谢谢你了,我已经启动成功
#8 2021-11-16 15:40:26
树莓学LINUX
已发帖子: 123
@风云剑
U-Boot SPL 2017.01-rc2 (Nov 15 2021 - 22:09:14)
DRAM: 64 MiB
U-Boot 2017.01-rc2 (Nov 15 2021 - 22:09:14 -0800) Allwinner Technology
DRAM:  64 MiB
In:    serial@01c28000
DRAM:  64 MiB
In:    serial@01c28000
reading zImage
4544624 bytes read in 231 ms (18.8 MiB/s)
13141 bytes read in 26 ms (493.2 KiB/s)
   Loading Device Tree to 42df9000, end 42dff354 ... OK
[    0.000000] Linux version 5.10.0-licheepi-zero (shumei@ubuntu) (arm-linux-gnueabihf-gcc (Linaro GCC 6.3-2017.02) 6.3.1 20170109, GNU ld (Linaro_Binutils-2017.02) 2.27.0.20161019) #20 SMP Mon Nov 15 19:27:52 PST 2021
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x0000000040000000-0x0000000043ffffff]
[    0.000000]   HighMem  empty
[    0.000000]   node   0: [mem 0x0000000040000000-0x0000000043ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x0000000043ffffff]
[    0.000000] percpu: Embedded 15 pages/cpu s30924 r8192 d22324 u61440
[    0.000000] Memory: 53624K/65536K available (7168K kernel code, 693K rwdata, 1784K rodata, 1024K init, 261K bss, 11912K reserved, 0K cma-reserved, 0K highmem)
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[    0.000000] random: get_random_bytes called from start_kernel+0x328/0x4bc with crng_init=0
[    0.000023] Switching to timer-based delay loop, resolution 41ns
[    0.000260] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000548] Console: colour dummy device 80x30
[    0.000616] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000639] pid_max: default: 32768 minimum: 301
[    0.000814] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.000834] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.001727] CPU: Testing write buffer coherency: ok
[    0.002164] /cpus/cpu@0 missing clock-frequency property
[    0.002196] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.003008] Setting up static identity map for 0x40100000 - 0x40100060
[    0.003247] rcu: Hierarchical SRCU implementation.
[    0.003806] smp: Bringing up secondary CPUs ...
[    0.003834] smp: Brought up 1 node, 1 CPU
[    0.003847] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[    0.003856] CPU: All CPU(s) started in SVC mode.
[    0.004536] devtmpfs: initialized
[    0.008293] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.008670] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.008706] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[    0.008946] pinctrl core: initialized pinctrl subsystem
[    0.010255] NET: Registered protocol family 16
[    0.010793] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.012011] thermal_sys: Registered thermal governor 'step_wise'
[    0.012380] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.012406] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.033755] SCSI subsystem initialized
[    0.033949] usbcore: registered new interface driver usbfs
[    0.034022] usbcore: registered new interface driver hub
[    0.034143] usbcore: registered new device driver usb
[    0.034379] mc: Linux media interface: v0.10
[    0.034422] videodev: Linux video capture interface: v2.00
[    0.034690] Advanced Linux Sound Architecture Driver Initialized.
[    0.036024] clocksource: Switched to clocksource arch_sys_counter
[    0.048278] NET: Registered protocol family 2
[    0.049133] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    0.049184] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.049213] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[    0.049237] TCP: Hash tables configured (established 1024 bind 1024)
[    0.049391] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.049447] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.049732] NET: Registered protocol family 1
[    0.051389] Initialise system trusted keyrings
[    0.051779] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[    0.138621] Key type asymmetric registered
[    0.138658] Asymmetric key parser 'x509' registered
[    0.138758] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    0.138776] io scheduler mq-deadline registered
[    0.138787] io scheduler kyber registered
[    0.139758] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
[    0.143695] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.214063] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.216777] sun8i-v3s-pinctrl 1c20800.pinctrl: supply vcc-pb not found, using dummy regulator
[    0.218037] printk: console [ttyS0] disabled
[    0.238366] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 44, base_baud = 1500000) is a U6_16550A
[    0.791207] printk: console [ttyS0] enabled
[    0.800832] sun8i-v3s-pinctrl 1c20800.pinctrl: supply vcc-pc not found, using dummy regulator
[    0.811034] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.817696] ehci-platform: EHCI generic platform driver
[    0.823272] ehci-platform 1c1a000.usb: EHCI Host Controller
[    0.828961] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    0.836926] ehci-platform 1c1a000.usb: irq 34, io mem 0x01c1a000
[    0.866009] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    0.873278] hub 1-0:1.0: USB hub found
[    0.877244] hub 1-0:1.0: 1 port detected
[    0.881883] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.888225] ohci-platform: OHCI generic platform driver
[    0.893779] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    0.900527] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[    0.908501] ohci-platform 1c1a400.usb: irq 35, io mem 0x01c1a400
[    0.981140] hub 2-0:1.0: USB hub found
[    0.984991] hub 2-0:1.0: 1 port detected
[    0.992360] usbcore: registered new interface driver usb-storage
[    0.999731] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
[    1.009678] sun6i-rtc 1c20400.rtc: registered as rtc0
[    1.014798] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01T00:02:05 UTC (125)
[    1.022985] sun6i-rtc 1c20400.rtc: RTC enabled
[    1.027699] i2c /dev entries driver
[    1.032733] sun8i-v3s-pinctrl 1c20800.pinctrl: supply vcc-pe not found, using dummy regulator
[    1.043575] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.052592] sun4i-ss 1c15000.crypto: Die ID 7
[    1.057492] sun8i-v3s-pinctrl 1c20800.pinctrl: supply vcc-pf not found, using dummy regulator
[    1.067617] sun8i-v3s-pinctrl 1c20800.pinctrl: supply vcc-pg not found, using dummy regulator
[    1.080941] usbcore: registered new interface driver usbhid
[    1.086665] usbhid: USB HID core driver
[    1.090694] fb_st7789v spi0.0: fbtft_property_value: buswidth = 8
[    1.096860] fb_st7789v spi0.0: fbtft_property_value: debug = 0
[    1.102692] fb_st7789v spi0.0: fbtft_property_value: rotate = 270
[    1.108806] fb_st7789v spi0.0: fbtft_property_value: fps = 60
[    1.126129] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[    1.133444] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB
[    1.175712] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.185664] mmc0: new high speed SDHC card at address 59b4
[    1.192312] mmcblk0: mmc0:59b4 SDU1  29.5 GiB
[    1.200125]  mmcblk0: p1 p2
[    1.649028] random: fast init done
[    1.674127] Console: switching to colour frame buffer device 40x30
[    1.681142] graphics fb0: fb_st7789v frame buffer, 320x240, 150 KiB video memory, 4 KiB buffer memory, fps=100, spi0.0 at 96 MHz
[    1.699607] Initializing XFRM netlink socket
[    1.703933] NET: Registered protocol family 17
[    1.726126] Registering SWP/SWPB emulation handler
[    1.731037] Loading compiled-in X.509 certificates
[    1.744658] usb_phy_generic usb_phy_generic.1.auto: supply vcc not found, using dummy regulator
[    1.754842] musb-hdrc musb-hdrc.2.auto: MUSB HDRC host driver
[    1.760763] musb-hdrc musb-hdrc.2.auto: new USB bus registered, assigned bus number 3
[    1.769862] hub 3-0:1.0: USB hub found
[    1.773735] hub 3-0:1.0: 1 port detected
[    1.779500] ALSA device list:
[    1.782497]   No soundcards found.
[    1.793093] List of all partitions:
[    1.796762] b300        30924800 mmcblk0
[    1.796770]  driver: mmcblk
[    1.803573]   b301           32768 mmcblk0p1 fb599233-01
[    1.803577]
[    1.810415]   b302        30891008 mmcblk0p2 fb599233-02
[    1.810418]
[    1.817230] No filesystem could mount root, tried:
[    1.817234]  ext3
[    1.822105]  ext2
[    1.824028]  ext4
[    1.825966]  vfat
[    1.827889]
[    1.831303] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,2)
[    1.839736] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.10.0-licheepi-zero #20
[    1.846948] Hardware name: Allwinner sun8i Family
[    1.851686] [<c010d92c>] (unwind_backtrace) from [<c010a348>] (show_stack+0x10/0x14)
[    1.859431] [<c010a348>] (show_stack) from [<c074df90>] (dump_stack+0x98/0xac)
[    1.866651] [<c074df90>] (dump_stack) from [<c074c494>] (panic+0x110/0x2fc)
[    1.873613] [<c074c494>] (panic) from [<c0a01488>] (mount_block_root+0x308/0x330)
[    1.881093] [<c0a01488>] (mount_block_root) from [<c0a01678>] (prepare_namespace+0x150/0x18c)
[    1.889613] [<c0a01678>] (prepare_namespace) from [<c075044c>] (kernel_init+0x8/0x118)
[    1.897526] [<c075044c>] (kernel_init) from [<c0100148>] (ret_from_fork+0x14/0x2c)
[    1.905086] Exception stack(0xc0c3bfb0 to 0xc0c3bff8)
[    1.910135] bfa0:                                     00000000 00000000 00000000 00000000
[    1.918305] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.926473] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[    1.933095] Rebooting in 5 seconds..
我把比较小的包解压到第二分区,第一分区的东西都没动,使用的是5.1的内核,报错是这个,请问可能是什么问题
