各位,求助个问题,谢谢了。
按照教程编译了uboot,dtb和zimage三个文件,文件系统加入了Qt5,编译通过了,然后烧到tf卡上,但是启动以后打印以下信息,最后无法进入,哪位朋友给指导一下,非常感谢。
U-Boot SPL 2017.01-rc2-00057-g32ab180-dirty (Feb 16 2021 - 18:25:24)
DRAM: 64 MiB
Trying to boot from MMC1
U-Boot 2017.01-rc2-00057-g32ab180-dirty (Feb 16 2021 - 18:25:24 +0800) Allwinner Technology
Model: Lichee Pi Zero
DRAM: 64 MiB
MMC: SUNXI SD/MMC: 0
In: serial@01c28000
Out: serial@01c28000
Err: serial@01c28000
DRAM: 64 MiB
In: serial@01c28000
Net: No ethernet found.
No controllers found
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
reading /sun8i-v3s-licheepi-zero.dtb
11187 bytes read in 26 ms (419.9 KiB/s)
USB is stopped. Please issue 'usb start' first.
No ethernet found.
missing environment variable: bootfile
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-sunxi
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
No ethernet found.
=>离线
没有 boot.scr
没有 boot.scr
感谢回复,我是按照论坛教程编译的,没有提到和生成boot.scr,这个文件在哪里生成的?
奔跑的孩子 说:没有 boot.scr
这个是修改 sun8i.h 的版本:
荔枝派Zero V3s开发板入坑记录 (TF/SD卡启动)(主线Linux,主线u-boot)
http://whycan.com/t_561.html
boot.scr 参考这个帖子:
为新设备构建主线u-boot
http://whycan.com/t_5474.html#p55106
