楼主 # 2021-05-29 19:55:51
cube
已发帖子: 288
集齐F1C马甲就能召唤神龙吗? 我试一试
#1 2021-05-29 20:03:39
TeveT
已发帖子: 148
Re: 集齐F1C马甲就能召唤神龙吗? 我试一试
一家人,整整齐齐
#2 2021-05-29 22:09:05
illusion
已发帖子: 81
是个狠人,全志F1C系列高级玩家……
楼主 #3 2021-05-29 23:26:23
cube
已发帖子: 288
F1C500s 是 32M DRAM:
[0]HELLO! BOOT0 is starting!
[2]boot0 commit : 80628dcde5dc4ecdc757a9e782c58d7cf1abf959
[60]dram size =32
[62]Reg pull reg_val=0x00000000,read=0x00000010
[66]Succeed in reading toc file head.
[69]The size of toc is 00054000.
[127]Reg pull reg_val=0x00000000,read=0x00000010
[136]Ready to disable icache.
[138]Jump to secend Boot.
F1C100s 和 F1C500s 只有一个寄存器值不同, DRAM大小一模一样.
tina sdk 可以直接跑在这两个芯片可能都会出错.
[60]dram size =32
U-Boot 2014.07 (Aug 21 2019 - 14:53:43) Allwinner Technology
uboot commit : 78cb55af380c57c0278162e241a9999cdc16e1d6
i2c_init: by cpux
[I2C-DEBUG]:i2c_set_clock() 354
[I2C-ERROR]:twi_send_clk_9pulse() 136 SDA is still Stuck Low, failed.
i2c_init ok
[0.187]pmbus:   ready
axp: get node[/soc/pmu0] error
axp_probe error
[0.193]PMU: cpux 408 Mhz,AXI=408 Mhz
PLL6=600 Mhz,AHB1=200 Mhz, APB1=100Mhz
key value = 4294967295, fel_key = [256,426]
DRAM:  32 MiB
Relocation Offset is: 01580000
int sunxi_dma_init---
irq enable
workmode = 0,storage type = 3
[0.260]spinor:	 0
flash size =0x4000 sectors
sunxi spinor is initing...int sunxi_dma_init---
irq enable
sunxi_dma_install_int ok
OK
spinor id:0x1840ef
spi_freq = 40000000
[0.278]sunxi flash init ok
spinor read: start 0x3e0, sector 0x20
used mbr [0], count = 8
spinor read: start 0x800, sector 0x200
env size is 256
env partition is too small!
can't enabled backup env functions
logo addr = 0x81f00000
spinor read: start 0x400, sector 0x400
sunxi_read_bootlogo: read bootlogo partition successful
do not find fastboot status flag
-total partitions:8-
bootlogo    : 4000          80000
env         : 84000         20000
boot        : a4000         300000
rootfs      : 3a4000        c00000
rootfs_data : fa4000        180000
misc        : 1124000       10000
private     : 1134000       10000
UDISK       : 1144000       0
spinor read: start 0x8d00, sector 0x4
disable nand error: FDT_ERR_BADPATH
## error: update_fdt_dram_para : FDT_ERR_NOTFOUND
PowerBus = 0( 2:vBus 3:acBus other: not exist)
no battery exist
sunxi_bmp_logo_display
spinor read: start 0x900, sector 0x40
spinor read: start 0x940, sector 0x1380
## Booting kernel from Legacy Image at 80007fc0 ...
   Image Name:   ARM OpenWrt Linux-3.10.65
   Data Size:    2588104 Bytes = 2.5 MiB
   Load Address: 80008000
   Entry Point:  80008000
   XIP Kernel Image ... OK
   reserving fdt memory region: addr=81000000 size=10000
   Using Device Tree in place at 81000000, end 8100f49f
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.10.65 (cube@ubuntu) (gcc version 6.4.1 (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) ) #203 Sat May 29 15:10:02 UTC 2021
[    0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
[    0.000000] Machine: Allwinner A1X (Device Tree), model: sun3iw1p1
[    0.000000] cma: CMA: failed to reserve 32 MiB
[    0.000000] On node 0 totalpages: 8192
[    0.000000] free_area_init_node: node 0, pgdat c0546bcc, node_mem_map c0574000
[    0.000000]   Normal zone: 64 pages used for memmap
[    0.000000]   Normal zone: 8192 pages, LIFO batch:0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 8128
[    0.000000] Kernel command line: enforcing=1 earlyprintk=sunxi-uart,0x01c25000 initcall_debug=0 console=ttyS1,115200 loglevel=8 root=/dev/mtdblock4 init=/pseudo_init rdinit=/rdinit partitions=bootlogo@mtdblock1:env@mtdblock2:boot@mtdblock3:rootfs@mtdblock4:rootfs_data@mtdblock5:misc@mtdblock6:private@mtdblock7:UDISK@mtdblock8 cma=32M fb_base=0x81f00000 androidboot.serialno=<NULL> boot_type=3
[    0.000000] Memory: 32MB = 32MB total
[    0.000000] Memory: 26748k/26748k available, 6020k reserved, 0K highmem
[    0.000000]     vmalloc : 0xc2800000 - 0xff000000   ( 968 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0441f84   (4328 kB)
[    0.000000]       .init : 0xc0442000 - 0xc046013c   ( 121 kB)
[    0.000000]       .data : 0xc0462000 - 0xc05474e8   ( 918 kB)
[    0.000000]        .bss : 0xc05474e8 - 0xc0573d00   ( 179 kB)
[    0.000000] NR_IRQS:256
[    0.000000] of_sunxi_clocks_init : sunxi_clk_base[0xf1c20000]
[    0.000000] pll_cpu-set_default_rate=552000000 success!
[    0.000000] pll_video-set_default_rate=297000000 success!
[    0.000000] pll_ddr-set_default_rate=312000000 success!
[    0.000000] timer_nr = 2 .......................
[    0.000000] timer_base = 0xF1C20C00, irq = 15 -----
[    0.000000] HZ = 100 JJJJJJJJJJJ
[    0.000000] rate / (prescale * HZ) = 15000
[    0.005324] Calibrating delay loop... 275.25 BogoMIPS (lpj=1376256)
[    0.075269] pid_max: default: 32768 minimum: 301
[    0.080445] Mount-cache hash table entries: 512
[    0.086432] CPU: Testing write buffer coherency: ok
[    0.092219] Setting up static identity map for 0xc0341dc0 - 0xc0341e18
[    0.101512] devtmpfs: initialized
[    0.106978] pinctrl core: initialized pinctrl subsystem
[    0.112842] NET: Registered protocol family 16
[    0.117992] DMA: failed to allocate 256 KiB pool for atomic coherent allocation
[    0.126064] dump_class_init,844, success
[    0.135040] sun3iw1p1-pinctrl pio: initialized sunXi PIO driver
[    0.158774] bio: create slab <bio-0> at 0
[    0.164297] pwm module init!
[    0.169095] SCSI subsystem initialized
[    0.173384] usbcore: registered new interface driver usbfs
[    0.179196] usbcore: registered new interface driver hub
[    0.185071] usbcore: registered new device driver usb
[    0.192771] gpio=140,mul_sel=6,pull=1,drv_level=-1,data=1
[    0.198732] sunxi_i2c_do_xfer()928 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x20)
[    0.207294] pcf857x 0-0020: retry commucation.7
[    0.212258] sunxi_i2c_do_xfer()928 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x20)
[    0.220785] pcf857x 0-0020: retry commucation.6
[    0.225764] sunxi_i2c_do_xfer()928 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x20)
[    0.234289] pcf857x 0-0020: retry commucation.5
[    0.239245] sunxi_i2c_do_xfer()928 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x20)
[    0.247766] pcf857x 0-0020: retry commucation.4
[    0.252744] sunxi_i2c_do_xfer()928 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x20)
[    0.261235] pcf857x 0-0020: retry commucation.3
[    0.266218] sunxi_i2c_do_xfer()928 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x20)
[    0.274740] pcf857x 0-0020: retry commucation.2
[    0.279699] sunxi_i2c_do_xfer()928 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x20)
[    0.288219] pcf857x 0-0020: retry commucation.1
[    0.293200] sunxi_i2c_do_xfer()928 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x20)
[    0.301723] pcf857x: probe of 0-0020 failed with error -70
[    0.309718] Linux video capture interface: v2.00
[    0.315105] Advanced Linux Sound Architecture Driver Initialized.
[    0.323321] cfg80211: Calling CRDA to update world regulatory domain
[    0.330754] Switching to clocksource sun3i high-res couter
[    0.356484] get det_vbus is fail, 84
[    0.361928] NET: Registered protocol family 2
[    0.368585] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[    0.375701] TCP bind hash table entries: 512 (order: -1, 2048 bytes)
[    0.382367] TCP: Hash tables configured (established 512 bind 512)
[    0.388941] TCP: reno registered
[    0.392337] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.398453] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.405527] NET: Registered protocol family 1
[    0.423545] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.430206] jffs2: version 2.2. 漏 2001-2006 Red Hat, Inc.
[    0.436762] msgmni has been set to 52
[    0.443775] io scheduler noop registered
[    0.448068] io scheduler cfq registered (default)
[    0.452946] [pm]aw_pm_init!
[    0.456217] [pm]valid
[    0.458710] [pm]valid
[    0.461449] [DISP]disp_module_init
[    0.526640] pll_freq=297000000HZ, lcd_dclk_freq=20000000HZ, clk_div=14
[    0.534016] *******************************
[    0.538443] ***
[    0.540318] *** LCD Panel Parameter Check
[    0.544473] ***
[    0.546340] ***             by guozhenjie
[    0.550539] ***
[    0.552411] ********************************
[    0.556861] ***
[    0.558732] *** Interface:
[    0.561304] *** Parallel HV Panel
[    0.565028] *** Lcd Frm to RGB666
[    0.568513] ***
[    0.570382] *** Timing:
[    0.572955] *** lcd_x:      800
[    0.576231] *** lcd_y:      480
[    0.579540] *** lcd_ht:     928
[    0.582817] *** lcd_hbp:    88
[    0.586005] *** lcd_vt:     525
[    0.589311] *** lcd_vbp:    32
[    0.592501] *** lcd_hspw:   48
[    0.595688] *** lcd_vspw:   3
[    0.598820] *** lcd_frame_frq:  41Hz
[    0.602536] ***
[    0.604407] *** WRN03: Recommend "lcd_dclk_frq = 29"
[    0.609560] ***
[    0.611430] *** LCD Panel Parameter Check End
[    0.615938] *******************************
[    0.620387] num_screens=1
[    0.623176] screen_id=0
[    0.625754] para->mclk[MOD_CLK_LCD1CH0]=0xc180c300
[    0.630771] para->mclk[MOD_CLK_LCD1CH1]=0xc180c400
[    0.635725] disp tv init
[    0.638432] tcon_clk=0xc180c300, tcon_clk_parent=0x0
[    0.643567] tcon_clk=0xc180c300, tcon_clk_parent=0xc18043c0
[    0.649351] tve_clk=0xc180c400, tve_clk_parent=0xc18043c0
[    0.654919] disp al tv init
[    0.660585] fetch script datadisp.screen2_output_type fail
[    0.666663] fetch script datadisp.screen2_output_mode fail
[    0.674907] fetch script datadisp.fb2_format fail
[    0.680160] fetch script datadisp.fb2_scaler_mode_enable fail
[    0.686390] fetch script datadisp.fb2_width fail
[    0.691546] fetch script datadisp.fb2_height fail
[    0.696450] disp_malloc fail, size=0x2ee000
[    0.700855] disp_malloc fail!
[    0.704288] Unable to handle kernel paging request at virtual address 0005dfc0
[    0.711847] pgd = c0004000
[    0.714694] [0005dfc0] *pgd=00000000
[    0.718502] Internal error: Oops: 805 [#1] ARM
[    0.723102] Modules linked in:
[    0.726315] CPU: 0 PID: 1 Comm: swapper Not tainted 3.10.65 #203
[    0.732507] task: c1832000 ti: c1834000 task.ti: c1834000
[    0.738097] PC is at memcpy+0x244/0x330
[    0.742087] LR is at 0xadc8ff9e
[    0.745376] pc : [<c0125564>]    lr : [<adc8ff9e>]    psr: 20000013
[    0.745376] sp : c1835c40  ip : ff9eaec8  fp : c1835d7c
[    0.757200] r10: 000000ef  r9 : ff9dacc8  r8 : ff99a8c7
[    0.762595] r7 : ff97a6c6  r6 : ff96a5c7  r5 : ff94a2c4  r4 : ff93a2c4
[    0.769310] r3 : ff9ca7c2  r2 : 00000460  r1 : c2854b58  r0 : 0005dfc0
[    0.776027] Flags: nzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
[    0.783535] Control: 0005317f  Table: 80004000  DAC: 00000017
[    0.789454]
[    0.789454] PC: 0xc01254e4:
[    0.793966] 54e4  cafffff9 e2411003 eaffffba e252201c ba00001f e92d03e0 f5d1f000 e2522060
[    0.802457] 5504  f5d1f01c ba000002 f5d1f03c f5d1f05c f5d1f07c e8b100f0 e1a0382e e2522020
[    0.810942] 5524  e8b15300 e1833804 e1a04824 e1844805 e1a05825 e1855806 e1a06826 e1866807
[    0.819425] 5544  e1a07827 e1877808 e1a08828 e1888809 e1a09829 e189980c e1a0c82c e18cc80e
[    0.827909] 5564  e8a013f8 aaffffe9 e3720060 aaffffe8 e8bd03e0 e212c01c 0a000005 e1a0382e
[    0.836393] 5584  e491e004 e25cc004 e183380e e4803004 cafffff9 e2411002 eaffff8e e252201c
[    0.844878] 55a4  ba00001f e92d03e0 f5d1f000 e2522060 f5d1f01c ba000002 f5d1f03c f5d1f05c
[    0.853363] 55c4  f5d1f07c e8b100f0 e1a03c2e e2522020 e8b15300 e1833404 e1a04c24 e1844405
[    0.861850]
[    0.861850] SP: 0xc1835bc0:
[    0.866362] 5bc0  c0546bcc 81f00000 c1835bfc c1835bd8 c006e17c c006d4e4 c0125564 20000013
[    0.874846] 5be0  ffffffff c1835c2c c1835d7c c1835bf8 c000f4b8 c000a1a0 0005dfc0 c2854b58
[    0.883329] 5c00  00000460 ff9ca7c2 ff93a2c4 ff94a2c4 ff96a5c7 ff97a6c6 ff99a8c7 ff9dacc8
[    0.891813] 5c20  000000ef c1835d7c ff9eaec8 c1835c40 adc8ff9e c0125564 20000013 ffffffff
[    0.900297] 5c40  0005dfc0 c1835d88 000001e0 0004b036 00000000 0005dfc0 c18f0800 c0158590
[    0.908780] 5c60  c054abf8 00000000 00000001 00000140 00000140 000000f0 c280a000 c280a036
[    0.917264] 5c80  000001e0 00000320 00000000 00000320 c001c89c 00000000 00000000 00000000
[    0.925748] 5ca0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    0.934232]
[    0.934232] IP: 0xff9eae48:
[    0.938745] ae48  ******** ******** ******** ******** ******** ******** ******** ********
[    0.947239] ae68  ******** ******** ******** ******** ******** ******** ******** ********
[    0.955723] ae88  ******** ******** ******** ******** ******** ******** ******** ********
[    0.964207] aea8  ******** ******** ******** ******** ******** ******** ******** ********
[    0.972691] aec8  ******** ******** ******** ******** ******** ******** ******** ********
[    0.981174] aee8  ******** ******** ******** ******** ******** ******** ******** ********
[    0.989658] af08  ******** ******** ******** ******** ******** ******** ******** ********
[    0.998141] af28  ******** ******** ******** ******** ******** ******** ******** ********
[    1.006627]
[    1.006627] FP: 0xc1835cfc:
[    1.011141] 5cfc  000001e0 ffffffff 00000000 00000000 00000320 000001e0 00000000 00000000
[    1.019623] 5d1c  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.028104] 5d3c  00000320 000001e0 00000000 00000000 00000000 00000000 c05592f8 00000000
[    1.036586] 5d5c  00000000 c0559568 c0559570 c0559568 00000004 c1835ddc c1835d80 c0159300
[    1.045070] 5d7c  c0157e10 c0559570 00000001 00000000 00000000 00000002 00000320 000001e0
[    1.053552] 5d9c  00000320 000001e0 00000000 00000000 00000000 c0154b30 c05592f8 c185f800
[    1.062035] 5dbc  c185f810 c047ce34 00000000 c045bf18 00000000 c1835dfc c1835de0 c0156540
[    1.070519] 5ddc  c01588a8 c185f810 c055cbc4 00000000 c047ce34 c1835e0c c1835e00 c01a4744
[    1.079005]
[    1.079005] R1: 0xc2854ad8:
[    1.083517] 4ad8  2376ff0e 2073ff0d 2173ff0b 2372ff0b 2273ff0b 2272ff0b 2170ff0b 206fff0a
[    1.092004] 4af8  2170ff0c 2170ff0c 206dff0c 206cff0c 206cff0d 206cff0d 206aff0d 1f6aff0d
[    1.100492] 4b18  1f6aff0d 216aff0d 1f68ff0d 1e65ff0b 1e65ff0a 1f66ff0a 6c94ff0b a7c2ff62
[    1.108980] 4b38  a2c4ff9c a2c4ff93 a5c7ff94 a6c6ff96 a8c7ff97 acc8ff99 aec8ff9d adc8ff9e
[    1.117468] 4b58  adc8ff9f b1cbff9f b1ccffa3 b1ccffa3 b4ceffa5 b2ccffa8 b3ceffa6 b8cdffa7
[    1.125956] 4b78  bbcfffad bcd0ffb0 bed2ffb1 bed0ffb3 bfd1ffb3 c1d3ffb4 c3d5ffb6 c5d5ffb8
[    1.134444] 4b98  c8d9ffbb c9daffbf cbdcffc0 c8d8ffc2 cad9ffbf ccdbffc1 cddcffc3 cedeffc4
[    1.142932] 4bb8  d0e0ffc3 d0e0ffc4 d0e0ffc4 d2e3ffc4 d1e3ffc8 d3e4ffc8 d1e2ffca d0e0ffc8
[    1.151423]
[    1.151423] R3: 0xff9ca742:
[    1.155935] a740  ******** ******** ******** ******** ******** ******** ******** ********
[    1.164420] a760  ******** ******** ******** ******** ******** ******** ******** ********
[    1.172904] a780  ******** ******** ******** ******** ******** ******** ******** ********
[    1.181388] a7a0  ******** ******** ******** ******** ******** ******** ******** ********
[    1.189871] a7c0  ******** ******** ******** ******** ******** ******** ******** ********
[    1.198355] a7e0  ******** ******** ******** ******** ******** ******** ******** ********
[    1.206838] a800  ******** ******** ******** ******** ******** ******** ******** ********
[    1.215322] a820  ******** ******** ******** ******** ******** ******** ******** ********
[    1.223805] a840  ******** ******** ******** ******** ******** ******** ******** ********
[    1.232291]
[    1.232291] R4: 0xff93a244:
[    1.236803] a244  ******** ******** ******** ******** ******** ******** ******** ********
[    1.245287] a264  ******** ******** ******** ******** ******** ******** ******** ********
[    1.253770] a284  ******** ******** ******** ******** ******** ******** ******** ********
[    1.262254] a2a4  ******** ******** ******** ******** ******** ******** ******** ********
[    1.270738] a2c4  ******** ******** ******** ******** ******** ******** ******** ********
[    1.279222] a2e4  ******** ******** ******** ******** ******** ******** ******** ********
[    1.287705] a304  ******** ******** ******** ******** ******** ******** ******** ********
[    1.296189] a324  ******** ******** ******** ******** ******** ******** ******** ********
[    1.304675]
[    1.304675] R5: 0xff94a244:
[    1.309188] a244  ******** ******** ******** ******** ******** ******** ******** ********
[    1.317672] a264  ******** ******** ******** ******** ******** ******** ******** ********
[    1.326155] a284  ******** ******** ******** ******** ******** ******** ******** ********
[    1.334639] a2a4  ******** ******** ******** ******** ******** ******** ******** ********
[    1.343122] a2c4  ******** ******** ******** ******** ******** ******** ******** ********
[    1.351605] a2e4  ******** ******** ******** ******** ******** ******** ******** ********
[    1.360090] a304  ******** ******** ******** ******** ******** ******** ******** ********
[    1.368573] a324  ******** ******** ******** ******** ******** ******** ******** ********
[    1.377060]
[    1.377060] R6: 0xff96a547:
[    1.381572] a544  ******** ******** ******** ******** ******** ******** ******** ********
[    1.390055] a564  ******** ******** ******** ******** ******** ******** ******** ********
[    1.398539] a584  ******** ******** ******** ******** ******** ******** ******** ********
[    1.407023] a5a4  ******** ******** ******** ******** ******** ******** ******** ********
[    1.415507] a5c4  ******** ******** ******** ******** ******** ******** ******** ********
[    1.423990] a5e4  ******** ******** ******** ******** ******** ******** ******** ********
[    1.432475] a604  ******** ******** ******** ******** ******** ******** ******** ********
[    1.440959] a624  ******** ******** ******** ******** ******** ******** ******** ********
[    1.449443] a644  ******** ******** ******** ******** ******** ******** ******** ********
[    1.457929]
[    1.457929] R7: 0xff97a646:
[    1.462441] a644  ******** ******** ******** ******** ******** ******** ******** ********
[    1.470925] a664  ******** ******** ******** ******** ******** ******** ******** ********
[    1.479408] a684  ******** ******** ******** ******** ******** ******** ******** ********
[    1.487891] a6a4  ******** ******** ******** ******** ******** ******** ******** ********
[    1.496374] a6c4  ******** ******** ******** ******** ******** ******** ******** ********
[    1.504858] a6e4  ******** ******** ******** ******** ******** ******** ******** ********
[    1.513342] a704  ******** ******** ******** ******** ******** ******** ******** ********
[    1.521826] a724  ******** ******** ******** ******** ******** ******** ******** ********
[    1.530309] a744  ******** ******** ******** ******** ******** ******** ******** ********
[    1.538796]
[    1.538796] R8: 0xff99a847:
[    1.543308] a844  ******** ******** ******** ******** ******** ******** ******** ********
[    1.551792] a864  ******** ******** ******** ******** ******** ******** ******** ********
[    1.560276] a884  ******** ******** ******** ******** ******** ******** ******** ********
[    1.568760] a8a4  ******** ******** ******** ******** ******** ******** ******** ********
[    1.577243] a8c4  ******** ******** ******** ******** ******** ******** ******** ********
[    1.585726] a8e4  ******** ******** ******** ******** ******** ******** ******** ********
[    1.594209] a904  ******** ******** ******** ******** ******** ******** ******** ********
[    1.602694] a924  ******** ******** ******** ******** ******** ******** ******** ********
[    1.611177] a944  ******** ******** ******** ******** ******** ******** ******** ********
[    1.619664]
[    1.619664] R9: 0xff9dac48:
[    1.624176] ac48  ******** ******** ******** ******** ******** ******** ******** ********
[    1.632660] ac68  ******** ******** ******** ******** ******** ******** ******** ********
[    1.641144] ac88  ******** ******** ******** ******** ******** ******** ******** ********
[    1.649628] aca8  ******** ******** ******** ******** ******** ******** ******** ********
[    1.658112] acc8  ******** ******** ******** ******** ******** ******** ******** ********
[    1.666595] ace8  ******** ******** ******** ******** ******** ******** ******** ********
[    1.675079] ad08  ******** ******** ******** ******** ******** ******** ******** ********
[    1.683563] ad28  ******** ******** ******** ******** ******** ******** ******** ********
[    1.692056] Process swapper (pid: 1, stack limit = 0xc18341b8)
[    1.698066] Stack: (0xc1835c40 to 0xc1836000)
[    1.702599] 5c40: 0005dfc0 c1835d88 000001e0 0004b036 00000000 0005dfc0 c18f0800 c0158590
[    1.711002] 5c60: c054abf8 00000000 00000001 00000140 00000140 000000f0 c280a000 c280a036
[    1.719403] 5c80: 000001e0 00000320 00000000 00000320 c001c89c 00000000 00000000 00000000
[    1.727803] 5ca0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.736203] 5cc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.744603] 5ce0: 00000000 00000000 ff000001 00000000 00000000 00000000 00000320 000001e0
[    1.753003] 5d00: ffffffff 00000000 00000000 00000320 000001e0 00000000 00000000 00000000
[    1.761404] 5d20: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000320
[    1.769804] 5d40: 000001e0 00000000 00000000 00000000 00000000 c05592f8 00000000 00000000
[    1.778207] 5d60: c0559568 c0559570 c0559568 00000004 c1835ddc c1835d80 c0159300 c0157e10
[    1.786607] 5d80: c0559570 00000001 00000000 00000000 00000002 00000320 000001e0 00000320
[    1.795009] 5da0: 000001e0 00000000 00000000 00000000 c0154b30 c05592f8 c185f800 c185f810
[    1.803412] 5dc0: c047ce34 00000000 c045bf18 00000000 c1835dfc c1835de0 c0156540 c01588a8
[    1.811815] 5de0: c185f810 c055cbc4 00000000 c047ce34 c1835e0c c1835e00 c01a4744 c01563e0
[    1.820218] 5e00: c1835e34 c1835e10 c01a3518 c01a4738 c185f810 c185f844 c047ce34 00000000
[    1.828621] 5e20: 00000000 c045bf18 c1835e54 c1835e38 c01a366c c01a33e4 00000000 c047ce34
[    1.837024] 5e40: c01a3618 00000000 c1835e7c c1835e58 c01a1b68 c01a3628 c1823f4c c185c870
[    1.845428] 5e60: c18d4e14 c047ce34 c18d4de0 c0537f48 c1835e8c c1835e80 c01a2fc8 c01a1af0
[    1.853832] 5e80: c1835ebc c1835e90 c01a2bf8 c01a2fb8 c03f672a c0460008 c1835ebc c047ce34
[    1.862235] 5ea0: c03f672a 00000000 c0460008 00000000 c1835ee4 c1835ec0 c01a3c1c c01a2ac0
[    1.870638] 5ec0: c0559080 c03f672a 00000000 c0460008 00000000 c045bf18 c1835ef4 c1835ee8
[    1.879041] 5ee0: c01a4ca4 c01a3b84 c1835f1c c1835ef8 c044f410 c01a4c68 c03f672a c01a3b84
[    1.887445] 5f00: c1835f1c c1834000 c044f334 c0547500 c1835f5c c1835f20 c000a4d4 c044f344
[    1.895847] 5f20: 00000006 00000006 0000005a c05c4169 c003b8a0 00000007 c0547500 0000005a
[    1.904251] 5f40: c0460008 c045bf10 c045bf18 00000000 c1835f94 c1835f60 c0442c0c c000a3c8
[    1.912652] 5f60: 00000006 00000006 c04424d0 00000000 00000000 c033cb4c 00000000 00000000
[    1.921054] 5f80: 00000000 00000000 c1835fac c1835f98 c033cb5c c0442a78 00000000 c033cb4c
[    1.929455] 5fa0: 00000000 c1835fb0 c000f930 c033cb5c 00000000 00000000 00000000 00000000
[    1.937855] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.946255] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
[    1.954634] Backtrace:
[    1.957276] [<c0157e00>] (Display_Fb_Request+0x0/0x814) from [<c0159300>] (Fb_Init+0xa68/0xc24)
[    1.966220] [<c0158898>] (Fb_Init+0x0/0xc24) from [<c0156540>] (disp_probe+0x170/0x1f0)
[    1.974466] [<c01563d0>] (disp_probe+0x0/0x1f0) from [<c01a4744>] (platform_drv_probe+0x1c/0x20)
[    1.983468]  r7:c047ce34 r6:00000000 r5:c055cbc4 r4:c185f810
[    1.989378] [<c01a4728>] (platform_drv_probe+0x0/0x20) from [<c01a3518>] (driver_probe_device+0x144/0x1f8)
[    1.999283] [<c01a33d4>] (driver_probe_device+0x0/0x1f8) from [<c01a366c>] (__driver_attach+0x54/0x94)
[    2.008811]  r9:c045bf18 r8:00000000 r7:00000000 r6:c047ce34 r5:c185f844
r4:c185f810
[    2.017027] [<c01a3618>] (__driver_attach+0x0/0x94) from [<c01a1b68>] (bus_for_each_dev+0x88/0x98)
[    2.026204]  r7:00000000 r6:c01a3618 r5:c047ce34 r4:00000000
[    2.032105] [<c01a1ae0>] (bus_for_each_dev+0x0/0x98) from [<c01a2fc8>] (driver_attach+0x20/0x28)
[    2.041105]  r6:c0537f48 r5:c18d4de0 r4:c047ce34
[    2.045935] [<c01a2fa8>] (driver_attach+0x0/0x28) from [<c01a2bf8>] (bus_add_driver+0x148/0x220)
[    2.054957] [<c01a2ab0>] (bus_add_driver+0x0/0x220) from [<c01a3c1c>] (driver_register+0xa8/0x124)
[    2.064132]  r8:00000000 r7:c0460008 r6:00000000 r5:c03f672a r4:c047ce34
[    2.071110] [<c01a3b74>] (driver_register+0x0/0x124) from [<c01a4ca4>] (platform_driver_register+0x4c/0x60)
[    2.081078]  r9:c045bf18 r8:00000000 r7:c0460008 r6:00000000 r5:c03f672a
r4:c0559080
[    2.089322] [<c01a4c58>] (platform_driver_register+0x0/0x60) from [<c044f410>] (disp_module_init+0xdc/0x128)
[    2.099409] [<c044f334>] (disp_module_init+0x0/0x128) from [<c000a4d4>] (do_one_initcall+0x11c/0x148)
[    2.108850]  r6:c0547500 r5:c044f334 r4:c1834000
[    2.113689] [<c000a3b8>] (do_one_initcall+0x0/0x148) from [<c0442c0c>] (kernel_init_freeable+0x1a4/0x1e4)
[    2.123513] [<c0442a68>] (kernel_init_freeable+0x0/0x1e4) from [<c033cb5c>] (kernel_init+0x10/0xe8)
[    2.132776]  r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c033cb4c
r4:00000000
[    2.141006] [<c033cb4c>] (kernel_init+0x0/0xe8) from [<c000f930>] (ret_from_fork+0x14/0x24)
[    2.149567]  r5:c033cb4c r4:00000000
[    2.153324] Code: e1a09829 e189980c e1a0c82c e18cc80e (e8a013f8)
[    2.159782] ---[ end trace 7c1a1d285d2959a2 ]---
[    2.164615] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[    2.164615]
最近编辑记录 cube (2021-05-29 23:34:57)
楼主 #4 2021-06-03 10:29:52
cube
已发帖子: 288
再凑两片.
楼主 #5 2021-06-12 17:01:42
cube
已发帖子: 288
F1C600 唱戏机主板包邮50元, 报哇酷网网友45元包邮, 可以接7寸(800x480)显示屏
https://whycan.com/t_6616.html#p64192
(出处:哇酷开发者社区)
#6 2022-02-28 09:38:00
X3
已发帖子: 84
@cube
遇到和楼主一样的问题,发现居然是 F1C100s / F1C500 DRAM 内存不够引起的,用 F1C200s / F1C600s 代替就好了,FK浪费一天时间。
#7 2022-11-14 11:02:14
gmyu
已发帖子: 60
cube 说:
(出处:哇酷开发者社区)
楼主这个买了两块,点了屏幕后一直吃灰,对f1c这么熟悉,能不能出个教程。
btw,这个按键搞出来了么? 看你咸鱼还有卖,怎么不搞一搞。
#8 2022-11-14 11:04:07
gmyu
已发帖子: 60
我有AT070TN93的屏幕,怼上就能用,可惜了触摸部分。
#9 2022-11-17 14:15:50
hcc018
E200  C300 C800还没有凑齐
全志F系列芯片代理,价格优势,欢迎邮件咨询。
