                        白嫖: https://github.com/aodzip/u-boot/tree/Allwinner-S3
可能是S3目前最好用的u-boot了
支持LCD,支持以太网,支持USB Gadget
LCD演示:
Fastboot演示:
./fel-flash.sh
sunxi-fel -p uboot output/images/u-boot-sunxi-with-spl.bin
fastboot oem format
fastboot flash loader output/images/u-boot-sunxi-with-spl.bin
fastboot flash esp output/images/boot.vfat
fastboot flash system output/images/rootfs.ext4
fastboot reboot以下是 @哇酷小二 2020-04-30 整理的修改记录:
https://github.com/u-boot/u-boot/commit/e4837da7828293ea49abc579f939c0f5c4b127c3
git diff e4837da7828293ea49abc579f939c0f5c4b127c3 c8aac3e1734b87c2800c05fd5428f3aae8d8ae73 > ~/uboot_s3_aodzip.diff
diff --git a/Kconfig b/Kconfig
index 8bae87e3f6..cc625d0253 100644
--- a/Kconfig
+++ b/Kconfig
@@ -589,9 +589,9 @@ config HAVE_SYS_TEXT_BASE
 config SYS_TEXT_BASE
 	depends on HAVE_SYS_TEXT_BASE
 	default 0x80800000 if ARCH_OMAP2PLUS || ARCH_K3
-	default 0x4a000000 if ARCH_SUNXI && !MACH_SUN9I && !MACH_SUN8I_V3S
+	default 0x4a000000 if ARCH_SUNXI && !MACH_SUN9I && (!MACH_SUN8I_V3S || !MACH_SUN8I_S3)
 	default 0x2a000000 if ARCH_SUNXI && MACH_SUN9I
-	default 0x42e00000 if ARCH_SUNXI && MACH_SUN8I_V3S
+	default 0x42e00000 if ARCH_SUNXI && (MACH_SUN8I_V3S || MACH_SUN8I_S3)
 	hex "Text Base"
 	help
 	  The address in memory that U-Boot will be running from, initially.
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile
index bb979550c4..bbe1887623 100644
--- a/arch/arm/dts/Makefile
+++ b/arch/arm/dts/Makefile
@@ -546,7 +546,9 @@ dtb-$(CONFIG_MACH_SUN8I_R40) += \
 	sun8i-r40-bananapi-m2-ultra.dtb \
 	sun8i-v40-bananapi-m2-berry.dtb
 dtb-$(CONFIG_MACH_SUN8I_V3S) += \
-	sun8i-v3s-licheepi-zero.dtb
+	sun8i-v3s-licheepi-zero.dtb
+dtb-$(CONFIG_MACH_SUN8I_S3) += \
+	sun8i-s3-generic.dtb
 dtb-$(CONFIG_MACH_SUN50I_H5) += \
 	sun50i-h5-bananapi-m2-plus.dtb \
 	sun50i-h5-emlid-neutis-n5-devboard.dtb \
diff --git a/arch/arm/dts/sun8i-s3-generic.dts b/arch/arm/dts/sun8i-s3-generic.dts
new file mode 100644
index 0000000000..c1aac3d5d4
--- /dev/null
+++ b/arch/arm/dts/sun8i-s3-generic.dts
@@ -0,0 +1,135 @@
+ * Copyright (C) 2020 Aodzip <aodzip@gmail.com>
+ * This file is dual-licensed: you can use it either under the terms
+ * of the GPL or the X11 license, at your option. Note that this dual
+ * licensing only applies to this file, and not this project as a
+ * whole.
+ *  a) This file is free software; you can redistribute it and/or
+ *     modify it under the terms of the GNU General Public License as
+ *     published by the Free Software Foundation; either version 2 of the
+ *     License, or (at your option) any later version.
+ *     This file is distributed in the hope that it will be useful,
+ *     but WITHOUT ANY WARRANTY; without even the implied warranty of
+ *     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+ *     GNU General Public License for more details.
+ * Or, alternatively,
+ *  b) Permission is hereby granted, free of charge, to any person
+ *     obtaining a copy of this software and associated documentation
+ *     files (the "Software"), to deal in the Software without
+ *     restriction, including without limitation the rights to use,
+ *     copy, modify, merge, publish, distribute, sublicense, and/or
+ *     sell copies of the Software, and to permit persons to whom the
+ *     Software is furnished to do so, subject to the following
+ *     conditions:
+ *     The above copyright notice and this permission notice shall be
+ *     included in all copies or substantial portions of the Software.
+ *     THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
+ *     EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES
+ *     OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
+ *     NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
+ *     HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
+ *     WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+ *     FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
+ *     OTHER DEALINGS IN THE SOFTWARE.
+/dts-v1/;
+#include "sun8i-s3.dtsi"
+#include "sunxi-common-regulators.dtsi"
+    model = "Allwinner S3 Generic Device";
+    compatible = "allwinner,sun8i-s3";
+    aliases {
+        serial0 = &uart0;
+    chosen {
+        stdout-path = "serial0:115200n8";
+    backlight: backlight {
+        compatible = "pwm-backlight";
+        pwms = <&pwm 0 50000 0>;
+        brightness-levels = <0 2 4 8 16 32 64 128 255>;
+        default-brightness-level = <8>;
+    panel-rgb@0 {
+        compatible = "simple-panel";
+        backlight = <&backlight>;
+        display-timings {
+            timing@0 {
+                clock-frequency = <50000000>;
+                hactive = <480>;
+                vactive = <272>;
+                hfront-porch = <2>;
+                hback-porch = <2>;
+                hsync-len = <41>;
+                vfront-porch = <2>;
+                vback-porch = <2>;
+                vsync-len = <10>;
+                hsync-active = <0>;
+                vsync-active = <0>;
+                de-active = <0>;
+                pixelclk-active = <1>;
+&emac {
+    phy-handle = <&int_mii_phy>;
+    phy-mode = "mii";
+    allwinner,use-internal-phy;
+    status = "okay";
+&mmc0 {
+    bus-width = <4>;
+    status = "okay";
+&mmc2 {
+    non-removable;
+    max-speed = <20000000>;
+    bus-width = <8>;
+    status = "okay";
+&spi0 {
+    status = "disabled";
+&uart0 {
+    status = "okay";
+&usb_otg {
+    status = "okay";
+&usbphy {
+    status = "okay";
+&ehci0 {
+    status = "okay";
+&ohci0 {
+    status = "okay";
+&pwm {
+    status = "okay";
diff --git a/arch/arm/dts/sun8i-s3.dtsi b/arch/arm/dts/sun8i-s3.dtsi
index 0000000000..282aadff11
--- /dev/null
+++ b/arch/arm/dts/sun8i-s3.dtsi
@@ -0,0 +1,157 @@
+ * whole.
+ *     conditions:
+/dts-v1/;
+#include "sun8i-v3s.dtsi"
+#include <dt-bindings/input/input.h>
+    #address-cells = <1>;
+    #size-cells = <1>;
+    interrupt-parent = <&gic>;
+    soc {
+        compatible = "simple-bus";
+        ranges;
+        syscon: syscon@1c00000 {
+            compatible = "allwinner,sun8i-v3s-system-controller", "allwinner,sun8i-h3-system-control", "syscon";
+            reg = <0x01c00000 0x1000>;
+        emac: ethernet@1c30000 {
+            compatible = "allwinner,sun8i-h3-emac";
+            syscon = <&syscon>;
+            reg = <0x01c30000 0x10000>;
+            interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>;
+            interrupt-names = "macirq";
+            resets = <&ccu RST_BUS_EMAC>;
+            reset-names = "stmmaceth";
+            clocks = <&ccu CLK_BUS_EMAC>;
+            clock-names = "stmmaceth";
+            mdio: mdio {
+                #size-cells = <0>;
+                compatible = "snps,dwmac-mdio";
+            mdio-mux {
+                compatible = "allwinner,sun8i-h3-mdio-mux";
+                mdio-parent-bus = <&mdio>;
+                /* Only one MDIO is usable at the time */
+                internal_mdio: mdio@1 {
+                    compatible = "allwinner,sun8i-h3-mdio-internal";
+                    reg = <1>;
+                    int_mii_phy: ethernet-phy@1 {
+                        compatible = "ethernet-phy-ieee802.3-c22";
+                        reg = <1>;
+                        clocks = <&ccu CLK_BUS_EPHY>;
+                        resets = <&ccu RST_BUS_EPHY>;
+                external_mdio: mdio@2 {
+                    reg = <2>;
+        ehci0: usb@01c1a000 {
+            compatible = "allwinner,sun8i-v3s-ehci", "generic-ehci";
+            reg = <0x01c1a000 0x100>;
+            interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>;
+            clocks = <&ccu CLK_BUS_EHCI0>, <&ccu CLK_BUS_OHCI0>;
+            resets = <&ccu RST_BUS_EHCI0>, <&ccu RST_BUS_OHCI0>;
+        ohci0: usb@01c1a400 {
+            compatible = "allwinner,sun8i-v3s-ohci", "generic-ohci";
+            reg = <0x01c1a400 0x100>;
+            interrupts = <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>;
+            clocks = <&ccu CLK_BUS_EHCI0>, <&ccu CLK_BUS_OHCI0>, <&ccu CLK_USB_OHCI0>;
+        spi0: spi@1c68000 {
+            compatible = "allwinner,sun8i-h3-spi";
+            reg = <0x01c68000 0x1000>;
+            interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>;
+            clocks = <&ccu CLK_BUS_SPI0>, <&ccu CLK_SPI0>;
+            clock-names = "ahb", "mod";
+            resets = <&ccu RST_BUS_SPI0>;
+        pwm: pwm@1c21400 {
+            compatible = "allwinner,sun5i-a13-pwm";
+            reg = <0x01c21400 0x8>;
+            clocks = <&osc24M>;
+            #pwm-cells = <3>;
+&usb_otg {
+    phys = <&usbphy>;
+    extcon = <&usbphy>;
+&usbphy {
+    #phy-cells = <0>;
diff --git a/arch/arm/include/asm/arch-sunxi/clock_sun6i.h b/arch/arm/include/asm/arch-sunxi/clock_sun6i.h
index ee387127f3..8001a81b8f 100644
--- a/arch/arm/include/asm/arch-sunxi/clock_sun6i.h
+++ b/arch/arm/include/asm/arch-sunxi/clock_sun6i.h
@@ -333,9 +333,14 @@ struct sunxi_ccm_reg {
 #define AHB_GATE_OFFSET_LCD1		5
 #define AHB_GATE_OFFSET_LCD0		4
 #else
+#if defined(CONFIG_MACH_SUN8I_V3S) || defined(CONFIG_MACH_SUN8I_S3)
+#define AHB_GATE_OFFSET_LCD1		5
+#define AHB_GATE_OFFSET_LCD0		4
+#else
 #define AHB_GATE_OFFSET_LCD1		4
 #define AHB_GATE_OFFSET_LCD0		3
+#endif
 #define CCM_NAND_CTRL_M(x)		((x) - 1)
 #define CCM_NAND_CTRL_N(x)		((x) << 16)
@@ -480,9 +485,14 @@ struct sunxi_ccm_reg {
 #define AHB_RESET_OFFSET_LCD1		5
 #define AHB_RESET_OFFSET_LCD0		4
 #else
+#define AHB_RESET_OFFSET_LCD1		5
+#define AHB_RESET_OFFSET_LCD0		4
+#else
 #define AHB_RESET_OFFSET_LCD1		4
 #define AHB_RESET_OFFSET_LCD0		3
+#endif
 /* ahb_reset2 offsets */
 #define AHB_RESET_OFFSET_EPHY		2
@@ -508,7 +518,12 @@ struct sunxi_ccm_reg {
 /* CCM bits common to all Display Engine 2.0 clock ctrl regs */
 #define CCM_DE2_CTRL_M(n)		((((n) - 1) & 0xf) << 0)
 #define CCM_DE2_CTRL_PLL_MASK		(3 << 24)
+#define CCM_DE2_CTRL_PLL6_2X		(2 << 24)
+#else
 #define CCM_DE2_CTRL_PLL6_2X		(0 << 24)
+#endif
 #define CCM_DE2_CTRL_PLL10		(1 << 24)
 #define CCM_DE2_CTRL_GATE		(0x1 << 31)
diff --git a/arch/arm/include/asm/arch-sunxi/display2.h b/arch/arm/include/asm/arch-sunxi/display2.h
index 7202d2756c..ad3a81dbde 100644
--- a/arch/arm/include/asm/arch-sunxi/display2.h
+++ b/arch/arm/include/asm/arch-sunxi/display2.h
@@ -137,4 +137,12 @@ struct de_csc {
 #define SUNXI_DE2_WH(w, h)			(((h - 1) << 16) | (w - 1))
+	#define SUNXI_DE2_MUX_CHAN_SZ_COUNT 2
+	#define SUNXI_DE2_BLD_ROUTE 2
+#else
+	#define SUNXI_DE2_MUX_CHAN_SZ_COUNT 1
+	#define SUNXI_DE2_BLD_ROUTE 1
+#endif
 #endif /* _SUNXI_DISPLAY2_H */
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig
index be0822bfb7..b7cb87a98f 100644
--- a/arch/arm/mach-sunxi/Kconfig
+++ b/arch/arm/mach-sunxi/Kconfig
@@ -262,7 +262,18 @@ config MACH_SUN8I_V3S
 	select SUNXI_DRAM_DW
 	select SUNXI_DRAM_DW_16BIT
 	select SUPPORT_SPL
-	select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT
+config MACH_SUN8I_S3
+	bool "sun8i (Allwinner S3)"
+	select CPU_V7A
+	select CPU_V7_HAS_NONSEC
+	select CPU_V7_HAS_VIRT
+	select ARCH_SUPPORT_PSCI
+	select SUNXI_GEN_SUN6I
+	select SUNXI_DRAM_DW
+	select SUNXI_DRAM_DW_16BIT
+	select SUPPORT_SPL
+	select SUNXI_DE2
 config MACH_SUN9I
 	bool "sun9i (Allwinner A80)"
@@ -321,6 +332,7 @@ config MACH_SUN8I
 	default y if MACH_SUNXI_H3_H5
 	default y if MACH_SUN8I_R40
 	default y if MACH_SUN8I_V3S
+	default y if MACH_SUN8I_S3
 config RESERVE_ALLWINNER_BOOT0_HEADER
 	bool "reserve space for Allwinner boot0 header"
@@ -437,7 +449,7 @@ config DRAM_ZQ
 	default 123 if MACH_SUN4I || MACH_SUN5I || MACH_SUN6I || \
 		       MACH_SUN8I_A23 || MACH_SUN8I_A33 || MACH_SUN8I_A83T
 	default 127 if MACH_SUN7I
-	default 14779 if MACH_SUN8I_V3S
+	default 14779 if MACH_SUN8I_V3S || MACH_SUN8I_S3
 	default 3881979 if MACH_SUNXI_H3_H5 || MACH_SUN8I_R40 || MACH_SUN50I_H6
 	default 4145117 if MACH_SUN9I
 	default 3881915 if MACH_SUN50I
@@ -755,6 +767,7 @@ config VIDEO_SUNXI
 	depends on !MACH_SUNXI_H3_H5
 	depends on !MACH_SUN8I_R40
 	depends on !MACH_SUN8I_V3S
+	depends on !MACH_SUN8I_S3
 	depends on !MACH_SUN9I
 	depends on !MACH_SUN50I
 	depends on !MACH_SUN50I_H6
diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c
index b487b265af..6aa28bbc3c 100644
--- a/arch/arm/mach-sunxi/board.c
+++ b/arch/arm/mach-sunxi/board.c
@@ -117,7 +117,7 @@ static int gpio_init(void)
 	sunxi_gpio_set_cfgpin(SUNXI_GPB(9), SUN8I_A83T_GPB_UART0);
 	sunxi_gpio_set_cfgpin(SUNXI_GPB(10), SUN8I_A83T_GPB_UART0);
 	sunxi_gpio_set_pull(SUNXI_GPB(10), SUNXI_GPIO_PULL_UP);
-#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUN8I_V3S)
+#elif CONFIG_CONS_INDEX == 1 && (defined(CONFIG_MACH_SUN8I_V3S) || defined(CONFIG_MACH_SUN8I_S3))
 	sunxi_gpio_set_cfgpin(SUNXI_GPB(8), SUN8I_V3S_GPB_UART0);
 	sunxi_gpio_set_cfgpin(SUNXI_GPB(9), SUN8I_V3S_GPB_UART0);
 	sunxi_gpio_set_pull(SUNXI_GPB(9), SUNXI_GPIO_PULL_UP);
diff --git a/arch/arm/mach-sunxi/cpu_info.c b/arch/arm/mach-sunxi/cpu_info.c
index ae4745bfec..060fbfc8a9 100644
--- a/arch/arm/mach-sunxi/cpu_info.c
+++ b/arch/arm/mach-sunxi/cpu_info.c
@@ -90,6 +90,8 @@ int print_cpuinfo(void)
 	printf("CPU:   Allwinner R40 (SUN8I %04x)\n", sunxi_get_sram_id());
 #elif defined CONFIG_MACH_SUN8I_V3S
 	printf("CPU:   Allwinner V3s (SUN8I %04x)\n", sunxi_get_sram_id());
+#elif defined CONFIG_MACH_SUN8I_S3
+	printf("CPU:   Allwinner S3 (SUN8I %04x)\n", sunxi_get_sram_id());
 #elif defined CONFIG_MACH_SUN9I
 	puts("CPU:   Allwinner A80 (SUN9I)\n");
 #elif defined CONFIG_MACH_SUN50I
diff --git a/arch/arm/mach-sunxi/dram_sunxi_dw.c b/arch/arm/mach-sunxi/dram_sunxi_dw.c
index 85e7a1874e..43db624d8b 100644
--- a/arch/arm/mach-sunxi/dram_sunxi_dw.c
+++ b/arch/arm/mach-sunxi/dram_sunxi_dw.c
@@ -727,6 +727,9 @@ unsigned long sunxi_dram_init(void)
 #elif defined(CONFIG_MACH_SUN8I_V3S)
 	/* TODO: set delays and mbus priority for V3s */
 	uint16_t socid = SOCID_H3;
+#elif defined(CONFIG_MACH_SUN8I_S3)
+	/* TODO: set delays and mbus priority for S3 */
+	uint16_t socid = SOCID_H3;
 #elif defined(CONFIG_MACH_SUN50I)
 	uint16_t socid = SOCID_A64;
 #elif defined(CONFIG_MACH_SUN50I_H5)
diff --git a/board/sunxi/board.c b/board/sunxi/board.c
index 6afea6ef42..769530412b 100644
--- a/board/sunxi/board.c
+++ b/board/sunxi/board.c
@@ -40,6 +40,7 @@
 #include <spl.h>
 #include <sy8106a.h>
 #include <asm/setup.h>
+#include <splash.h>
 #if defined CONFIG_VIDEO_LCD_PANEL_I2C && !(defined CONFIG_SPL_BUILD)
 /* So that we can use pin names in Kconfig and sunxi_name_to_gpio() */
@@ -501,6 +502,13 @@ static void mmc_pinmux_setup(int sdc)
 		sunxi_gpio_set_pull(SUNXI_GPC(24), SUNXI_GPIO_PULL_UP);
 		sunxi_gpio_set_drv(SUNXI_GPC(24), 2);
 #elif defined(CONFIG_MACH_SUN8I) || defined(CONFIG_MACH_SUN50I)
+#ifdef CONFIG_MACH_SUN8I_S3
+		for (pin = SUNXI_GPC(0); pin <= SUNXI_GPC(10); pin++) {
+			sunxi_gpio_set_cfgpin(pin, 2);
+			sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP);
+			sunxi_gpio_set_drv(pin, 2);
+#else
 		/* SDC2: PC5-PC6, PC8-PC16 */
 		for (pin = SUNXI_GPC(5); pin <= SUNXI_GPC(6); pin++) {
 			sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2);
@@ -513,6 +521,7 @@ static void mmc_pinmux_setup(int sdc)
+#endif
 #elif defined(CONFIG_MACH_SUN50I_H6)
 		/* SDC2: PC4-PC14 */
 		for (pin = SUNXI_GPC(4); pin <= SUNXI_GPC(14); pin++) {
@@ -916,3 +925,41 @@ int board_fit_config_name_match(const char *name)
 	return strcmp(name, cmp_str);
+#ifdef CONFIG_SPLASH_SCREEN
+static struct splash_location sunxi_splash_locations[] = {
+		.name = "mmc0_fs",
+		.storage = SPLASH_STORAGE_MMC,
+		.flags = SPLASH_STORAGE_FS,
+		.devpart = "0:1",
+		.name = "mmc1_fs",
+		.devpart = "1:1",
+int splash_screen_prepare(void)
+	return splash_source_load(sunxi_splash_locations,
+				  ARRAY_SIZE(sunxi_splash_locations));
+int initr_env_dynamic_default(void)
+	uint boot = sunxi_get_boot_device();
+	switch (boot) {
+		case BOOT_DEVICE_MMC1:
+			env_set("splashsource", "mmc0_fs");
+			break;
+		case BOOT_DEVICE_MMC2:
+			env_set("splashsource", "mmc1_fs");
+			break;
+	return 0;
+#endif
diff --git a/common/board_r.c b/common/board_r.c
index 0bbeaa7594..949169895d 100644
--- a/common/board_r.c
+++ b/common/board_r.c
@@ -777,6 +777,9 @@ static init_fnc_t init_sequence_r[] = {
 	initr_mmc,
 	initr_env,
+#ifdef CONFIG_ENV_DYNAMIC_DEFAULT
+	initr_env_dynamic_default,
+#endif
 #ifdef CONFIG_SYS_BOOTPARAMS_LEN
 	initr_malloc_bootparams,
diff --git a/configs/allwinner_s3_generic_defconfig b/configs/allwinner_s3_generic_defconfig
index 0000000000..2c368215ed
--- /dev/null
+++ b/configs/allwinner_s3_generic_defconfig
@@ -0,0 +1,54 @@
+CONFIG_ARM=y
+CONFIG_ARCH_SUNXI=y
+CONFIG_MACH_SUN8I_S3=y
+CONFIG_DEFAULT_DEVICE_TREE="sun8i-s3-generic"
+CONFIG_SPL=y
+CONFIG_CMD_BOOTMENU=y
+CONFIG_CMD_MEMINFO=y
+CONFIG_BOOTDELAY=0
+CONFIG_NETDEVICES=y
+CONFIG_SUN8I_EMAC=y
+CONFIG_NET_RANDOM_ETHADDR=y
+CONFIG_DM_SPI=y
+CONFIG_SUNXI_SPI=y
+CONFIG_MMC=y
+CONFIG_MMC_SUNXI_SLOT_EXTRA=2
+CONFIG_MMC0_CD_PIN="PF6"
+CONFIG_CMD_BMP=y
+CONFIG_VIDEO_BPP8=y
+CONFIG_VIDEO_SIMPLE=y
+CONFIG_VIDEO_DT_SIMPLEFB=y
+CONFIG_DM_REGULATOR=y
+CONFIG_REGULATOR_PWM=y
+CONFIG_DM_PWM=y
+CONFIG_PWM_SUNXI=y
+CONFIG_BACKLIGHT_PWM=y
+CONFIG_USB_GADGET_VBUS_DRAW=250
+CONFIG_USB_MUSB_GADGET=y
+CONFIG_USB_MUSB_SUNXI=y
+CONFIG_USB_MUSB_DISABLE_BULK_COMBINE_SPLIT=y
+CONFIG_USB_MUSB_PIO_ONLY=y
+CONFIG_USB_STORAGE=y
+CONFIG_PHY=y
+CONFIG_PHY_SUN4I_USB=y
+CONFIG_USB_EHCI_HCD=y
+CONFIG_USB_EHCI_GENERIC=y
+CONFIG_USB_OHCI_HCD=y
+CONFIG_USB_OHCI_GENERIC=y
+CONFIG_CMD_USB_MASS_STORAGE=y
+CONFIG_CMD_FASTBOOT=y
+CONFIG_FASTBOOT_FLASH_MMC=y
+CONFIG_FASTBOOT_FLASH_MMC_DEV=1
+CONFIG_FASTBOOT_CMD_OEM_FORMAT=y
diff --git a/drivers/clk/sunxi/Kconfig b/drivers/clk/sunxi/Kconfig
index 5ff101b993..c48717bbbc 100644
--- a/drivers/clk/sunxi/Kconfig
+++ b/drivers/clk/sunxi/Kconfig
@@ -52,11 +52,11 @@ config CLK_SUN8I_R40
 	  on Allwinner R40 SoC.
 config CLK_SUN8I_V3S
-	bool "Clock driver for Allwinner V3S"
-	default MACH_SUN8I_V3S
+	bool "Clock driver for Allwinner V3S/S3"
+	default MACH_SUN8I_V3S || MACH_SUN8I_S3
 	help
 	  This enables common clock driver support for platforms based
-	  on Allwinner V3S SoC.
+	  on Allwinner V3S/S3 SoC.
 config CLK_SUN9I_A80
 	bool "Clock driver for Allwinner A80"
diff --git a/drivers/clk/sunxi/clk_v3s.c b/drivers/clk/sunxi/clk_v3s.c
index 789ac72026..2101efd11f 100644
--- a/drivers/clk/sunxi/clk_v3s.c
+++ b/drivers/clk/sunxi/clk_v3s.c
@@ -16,16 +16,22 @@ static struct ccu_clk_gate v3s_gates[] = {
 	[CLK_BUS_MMC0]		= GATE(0x060, BIT(8)),
 	[CLK_BUS_MMC1]		= GATE(0x060, BIT(9)),
 	[CLK_BUS_MMC2]		= GATE(0x060, BIT(10)),
+	[CLK_BUS_EMAC]		= GATE(0x060, BIT(17)),
 	[CLK_BUS_SPI0]		= GATE(0x060, BIT(20)),
 	[CLK_BUS_OTG]		= GATE(0x060, BIT(24)),
+	[CLK_BUS_EHCI0]		= GATE(0x060, BIT(26)),
+	[CLK_BUS_OHCI0]		= GATE(0x060, BIT(29)),
 	[CLK_BUS_UART0]		= GATE(0x06c, BIT(16)),
 	[CLK_BUS_UART1]		= GATE(0x06c, BIT(17)),
 	[CLK_BUS_UART2]		= GATE(0x06c, BIT(18)),
+	[CLK_BUS_EPHY]		= GATE(0x070, BIT(0)),
 	[CLK_SPI0]		= GATE(0x0a0, BIT(31)),
-	[CLK_USB_PHY0]          = GATE(0x0cc, BIT(8)),
+	[CLK_USB_PHY0] 		= GATE(0x0cc, BIT(8)),
+	[CLK_USB_OHCI0]		= GATE(0x0cc, BIT(16)),
 static struct ccu_reset v3s_resets[] = {
@@ -34,8 +40,13 @@ static struct ccu_reset v3s_resets[] = {
 	[RST_BUS_MMC0]		= RESET(0x2c0, BIT(8)),
 	[RST_BUS_MMC1]		= RESET(0x2c0, BIT(9)),
 	[RST_BUS_MMC2]		= RESET(0x2c0, BIT(10)),
+	[RST_BUS_EMAC]		= RESET(0x2c0, BIT(17)),
 	[RST_BUS_SPI0]		= RESET(0x2c0, BIT(20)),
 	[RST_BUS_OTG]		= RESET(0x2c0, BIT(24)),
+	[RST_BUS_EHCI0]		= RESET(0x2c0, BIT(26)),
+	[RST_BUS_OHCI0]		= RESET(0x2c0, BIT(29)),
+	[RST_BUS_EPHY]		= RESET(0x2c8, BIT(2)),
 	[RST_BUS_UART0]		= RESET(0x2d8, BIT(16)),
 	[RST_BUS_UART1]		= RESET(0x2d8, BIT(17)),
diff --git a/drivers/mmc/sunxi_mmc.c b/drivers/mmc/sunxi_mmc.c
index 9f426661c4..20a622dd2e 100644
--- a/drivers/mmc/sunxi_mmc.c
+++ b/drivers/mmc/sunxi_mmc.c
@@ -628,7 +628,7 @@ static int sunxi_mmc_probe(struct udevice *dev)
 	cfg->b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT;
 	cfg->f_min = 400000;
-	cfg->f_max = 52000000;
+	cfg->f_max = dev_read_u32_default(dev, "max-speed", 52000000);
 	priv->reg = (void *)dev_read_addr(dev);
 	priv->variant =
diff --git a/drivers/pwm/sunxi_pwm.c b/drivers/pwm/sunxi_pwm.c
index 8a55e4f461..154a5290ce 100644
--- a/drivers/pwm/sunxi_pwm.c
+++ b/drivers/pwm/sunxi_pwm.c
@@ -47,6 +47,9 @@ static int sunxi_pwm_config_pinmux(void)
 #ifdef CONFIG_MACH_SUN50I
 	sunxi_gpio_set_cfgpin(SUNXI_GPD(22), SUNXI_GPD_PWM);
+#endif
+	sunxi_gpio_set_cfgpin(SUNXI_GPB(4), SUN4I_GPB_PWM);
diff --git a/drivers/usb/musb-new/musb_core.c b/drivers/usb/musb-new/musb_core.c
index f678aa4826..2574a6fd4b 100644
--- a/drivers/usb/musb-new/musb_core.c
+++ b/drivers/usb/musb-new/musb_core.c
@@ -1875,6 +1875,7 @@ allocate_instance(struct device *dev,
 	musb->controller = dev;
+	musb->dyn_fifo = config->dyn_fifo;
 	return musb;
diff --git a/drivers/video/sunxi/sunxi_de2.c b/drivers/video/sunxi/sunxi_de2.c
index 8333ddc44c..13be7a11e0 100644
--- a/drivers/video/sunxi/sunxi_de2.c
+++ b/drivers/video/sunxi/sunxi_de2.c
@@ -23,12 +23,21 @@
 DECLARE_GLOBAL_DATA_PTR;
+enum {
+	/* Maximum LCD size we support */
+	LCD_MAX_WIDTH		= 1024,
+	LCD_MAX_HEIGHT		= 768,
+	LCD_MAX_LOG2_BPP	= VIDEO_BPP32,
+#else
 enum {
 	LCD_MAX_WIDTH		= 3840,
 	LCD_MAX_HEIGHT		= 2160,
+#endif
 static void sunxi_de2_composer_init(void)
@@ -43,13 +52,19 @@ static void sunxi_de2_composer_init(void)
 	reg_value &= ~(0x01 << 24);
 	writel(reg_value, SUNXI_SRAMC_BASE + 0x04);
+	unsigned int hz = 300000000;
+	int pll = clock_get_pll6() * 2;
+	int div = 1;
+	while ((pll / div) > hz)
+		div++;
+	writel(CCM_DE2_CTRL_GATE | CCM_DE2_CTRL_PLL6_2X | CCM_DE2_CTRL_M(div), &ccm->de_clk_cfg);
+#else
 	clock_set_pll10(432000000);
 	/* Set DE parent to pll10 */
 	clrsetbits_le32(&ccm->de_clk_cfg, CCM_DE2_CTRL_PLL_MASK,
 			CCM_DE2_CTRL_PLL10);
+#endif
 	/* Set ahb gating to pass */
 	setbits_le32(&ccm->ahb_reset1_cfg, 1 << AHB_RESET_OFFSET_DE);
 	setbits_le32(&ccm->ahb_gate1, 1 << AHB_GATE_OFFSET_DE);
@@ -74,14 +89,13 @@ static void sunxi_de2_mode_set(int mux, const struct display_timing *mode,
 	struct de_ui * const de_ui_regs =
 		(struct de_ui *)(de_mux_base +
 				 SUNXI_DE2_MUX_CHAN_REGS +
-				 SUNXI_DE2_MUX_CHAN_SZ * 1);
+				 SUNXI_DE2_MUX_CHAN_SZ * SUNXI_DE2_MUX_CHAN_SZ_COUNT);
 	struct de_csc * const de_csc_regs =
 		(struct de_csc *)(de_mux_base +
 				  SUNXI_DE2_MUX_DCSC_REGS);
 	u32 size = SUNXI_DE2_WH(mode->hactive.typ, mode->vactive.typ);
 	int channel;
 	u32 format;
 	/* enable clock */
 #ifdef CONFIG_MACH_SUN8I_H3
 	setbits_le32(&de_clk_regs->rst_cfg, (mux == 0) ? 1 : 4);
@@ -108,13 +122,12 @@ static void sunxi_de2_mode_set(int mux, const struct display_timing *mode,
 	writel(0x00000101, &de_bld_regs->fcolor_ctl);
-	writel(1, &de_bld_regs->route);
+	writel(SUNXI_DE2_BLD_ROUTE, &de_bld_regs->route);
 	writel(0, &de_bld_regs->premultiply);
 	writel(0xff000000, &de_bld_regs->bkcolor);
 	writel(0x03010301, &de_bld_regs->bld_mode[0]);
 	writel(size, &de_bld_regs->output_size);
 	writel(mode->flags & DISPLAY_FLAGS_INTERLACED ? 2 : 0,
 	       &de_bld_regs->out_ctl);
diff --git a/drivers/video/sunxi/sunxi_dw_hdmi.c b/drivers/video/sunxi/sunxi_dw_hdmi.c
index c87c919a52..949b41732e 100644
--- a/drivers/video/sunxi/sunxi_dw_hdmi.c
+++ b/drivers/video/sunxi/sunxi_dw_hdmi.c
@@ -395,6 +395,8 @@ U_BOOT_DRIVER(sunxi_dw_hdmi) = {
 	.priv_auto_alloc_size = sizeof(struct sunxi_dw_hdmi_priv),
+#if !defined(CONFIG_MACH_SUN8I_V3S) && !defined(CONFIG_MACH_SUN8I_S3)
 U_BOOT_DEVICE(sunxi_dw_hdmi) = {
 	.name = "sunxi_dw_hdmi"
+#endif
diff --git a/drivers/video/sunxi/sunxi_lcd.c b/drivers/video/sunxi/sunxi_lcd.c
index 619f5892f5..bc0a782a1c 100644
--- a/drivers/video/sunxi/sunxi_lcd.c
+++ b/drivers/video/sunxi/sunxi_lcd.c
@@ -24,7 +24,7 @@ struct sunxi_lcd_priv {
 static void sunxi_lcdc_config_pinmux(void)
-#ifdef CONFIG_MACH_SUN50I
+#if defined(CONFIG_MACH_SUN50I) || defined(CONFIG_MACH_SUN8I_V3S) || defined(CONFIG_MACH_SUN8I_S3)
 	int pin;
 	for (pin = SUNXI_GPD(0); pin <= SUNXI_GPD(21); pin++) {
@@ -144,7 +144,7 @@ U_BOOT_DRIVER(sunxi_lcd) = {
 	.priv_auto_alloc_size = sizeof(struct sunxi_lcd_priv),
 U_BOOT_DEVICE(sunxi_lcd) = {
 	.name = "sunxi_lcd"
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h
index 0ef289fd64..da3080cc32 100644
--- a/include/configs/sunxi-common.h
+++ b/include/configs/sunxi-common.h
@@ -144,12 +144,12 @@
 #define CONFIG_SYS_MMC_MAX_DEVICE	4
-#ifndef CONFIG_MACH_SUN8I_V3S
-/* 64MB of malloc() pool */
-#define CONFIG_SYS_MALLOC_LEN		(CONFIG_ENV_SIZE + (64 << 20))
-#else
 /* 2MB of malloc() pool */
 #define CONFIG_SYS_MALLOC_LEN		(CONFIG_ENV_SIZE + (2 << 20))
+#else
+/* 64MB of malloc() pool */
+#define CONFIG_SYS_MALLOC_LEN		(CONFIG_ENV_SIZE + (64 << 20))
@@ -301,19 +301,8 @@ extern int soft_i2c_gpio_scl;
 #define RAMDISK_ADDR_R	__stringify(SDRAM_OFFSET(FE00000))
 #else
- * 160M RAM (256M minimum minus 64MB heap + 32MB for u-boot, stack, fb, etc.
- * 32M uncompressed kernel, 16M compressed kernel, 1M fdt,
- * 1M script, 1M pxe and the ramdisk at the end.
-#define BOOTM_SIZE     __stringify(0xa000000)
-#define KERNEL_ADDR_R  __stringify(SDRAM_OFFSET(2000000))
-#define FDT_ADDR_R     __stringify(SDRAM_OFFSET(3000000))
-#define SCRIPT_ADDR_R  __stringify(SDRAM_OFFSET(3100000))
-#define PXEFILE_ADDR_R __stringify(SDRAM_OFFSET(3200000))
-#define RAMDISK_ADDR_R __stringify(SDRAM_OFFSET(3300000))
-#else
  * 64M RAM minus 2MB heap + 16MB for u-boot, stack, fb, etc.
  * 16M uncompressed kernel, 8M compressed kernel, 1M fdt,
@@ -325,6 +314,18 @@ extern int soft_i2c_gpio_scl;
 #define SCRIPT_ADDR_R  __stringify(SDRAM_OFFSET(1900000))
 #define PXEFILE_ADDR_R __stringify(SDRAM_OFFSET(1A00000))
 #define RAMDISK_ADDR_R __stringify(SDRAM_OFFSET(1B00000))
+#else
+ * 160M RAM (256M minimum minus 64MB heap + 32MB for u-boot, stack, fb, etc.
+ * 32M uncompressed kernel, 16M compressed kernel, 1M fdt,
+ * 1M script, 1M pxe and the ramdisk at the end.
+#define BOOTM_SIZE     __stringify(0xa000000)
+#define KERNEL_ADDR_R  __stringify(SDRAM_OFFSET(2000000))
+#define FDT_ADDR_R     __stringify(SDRAM_OFFSET(3000000))
+#define SCRIPT_ADDR_R  __stringify(SDRAM_OFFSET(3100000))
+#define PXEFILE_ADDR_R __stringify(SDRAM_OFFSET(3200000))
+#define RAMDISK_ADDR_R __stringify(SDRAM_OFFSET(3300000))
@@ -427,6 +428,14 @@ extern int soft_i2c_gpio_scl;
 #include <config_distro_bootcmd.h>
+#ifdef CONFIG_CMD_FASTBOOT
+#define FASTBOOT_SETTINGS \
+	"boot_targets=fel mmc_auto usb0 fastboot\0" \
+	"bootcmd_fastboot=fastboot usb 0\0"
+#else
+#endif
 #ifdef CONFIG_USB_KEYBOARD
 #define CONSOLE_STDIN_SETTINGS \
 	"preboot=usb start\0" \
@@ -436,11 +445,25 @@ extern int soft_i2c_gpio_scl;
 	"stdin=serial\0"
+#ifdef CONFIG_DM_VIDEO
+#define CONFIG_VIDEO_BMP_RLE8
+#define CONFIG_BMP_16BPP
+#define CONFIG_BMP_24BPP
+#define CONFIG_BMP_32BPP
+#define CONFIG_SPLASH_SCREEN
+#define CONFIG_SPLASH_SOURCE
+#define SPLASHIMAGE_ENV_SETTINGS "splashimage=" __stringify(SDRAM_OFFSET(2000000)) "\0"
+#define CONFIG_ENV_DYNAMIC_DEFAULT
+#else
+#endif
 #ifdef CONFIG_VIDEO
 #define CONSOLE_STDOUT_SETTINGS \
 	"stdout=serial,vga\0" \
 	"stderr=serial,vga\0"
-#elif CONFIG_DM_VIDEO
+#else
+#if CONFIG_DM_VIDEO && !defined(CONFIG_SPLASH_SCREEN)
 	"stdout=serial,vidconsole\0" \
 	"stderr=serial,vidconsole\0"
@@ -449,6 +472,7 @@ extern int soft_i2c_gpio_scl;
 	"stdout=serial\0" \
 	"stderr=serial\0"
+#endif
 #ifdef CONFIG_MTDIDS_DEFAULT
 #define SUNXI_MTDIDS_DEFAULT \
@@ -464,11 +488,18 @@ extern int soft_i2c_gpio_scl;
 #define SUNXI_MTDPARTS_DEFAULT
+#define PARTS_DEFAULT \
+	"name=loader,start=8k,size=1024k;" \
+	"name=esp,size=16M,bootable,uuid=${uuid_gpt_esp};" \
+	"name=system,size=-,uuid=${uuid_gpt_system};"
+#else
 	"name=loader1,start=8k,size=32k,uuid=${uuid_gpt_loader1};" \
 	"name=loader2,size=984k,uuid=${uuid_gpt_loader2};" \
 	"name=esp,size=128M,bootable,uuid=${uuid_gpt_esp};" \
+#endif
 #define UUID_GPT_ESP "c12a7328-f81f-11d2-ba4b-00a0c93ec93b"
@@ -490,6 +521,7 @@ extern int soft_i2c_gpio_scl;
 #define CONFIG_EXTRA_ENV_SETTINGS \
 	CONSOLE_ENV_SETTINGS \
+	SPLASHIMAGE_ENV_SETTINGS \
 	MEM_LAYOUT_ENV_SETTINGS \
 	DFU_ALT_INFO_RAM \
 	"fdtfile=" FDTFILE "\0" \
@@ -500,10 +532,12 @@ extern int soft_i2c_gpio_scl;
 	"uuid_gpt_system=" UUID_GPT_SYSTEM "\0" \
 	"partitions=" PARTS_DEFAULT "\0" \
 	BOOTCMD_SUNXI_COMPAT \
-	BOOTENV
+	BOOTENV \
+	FASTBOOT_SETTINGS
 #else /* ifndef CONFIG_SPL_BUILD */
 #endif /* _SUNXI_COMMON_CONFIG_H */
diff --git a/include/init.h b/include/init.h
index 2a33a3fd1e..95bb92f51c 100644
--- a/include/init.h
+++ b/include/init.h
@@ -203,6 +203,7 @@ int update_flash_size(int flash_size);
 int arch_early_init_r(void);
 void pci_init(void);
 int misc_init_r(void);
+int initr_env_dynamic_default(void);
 #if defined(CONFIG_VID)
 int init_func_vid(void);
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt
index 6908431d03..b3414bb3a0 100644
--- a/scripts/config_whitelist.txt
+++ b/scripts/config_whitelist.txt
@@ -426,6 +426,7 @@ CONFIG_ENV_ADDR_FLEX
 CONFIG_ENV_CALLBACK_LIST_DEFAULT
 CONFIG_ENV_CALLBACK_LIST_STATIC
 CONFIG_ENV_COMMON_BOOT
+CONFIG_ENV_DYNAMIC_DEFAULT
 CONFIG_ENV_EEPROM_IS_ON_I2C
 CONFIG_ENV_FLAGS_LIST_DEFAULT
 CONFIG_ENV_FLAGS_LIST_STATIC离线
是安卓那个fastboot工具吗?这个工具好用
是的,就是Android的fastboot
生产力级别的u-boot
最近编辑记录 aodzip (2020-04-21 12:16:16)
谢谢分享!
这个好,fastboot可以用的话就刚刚的了,uboot生产力加倍~~
给力阿,之前研究了很久DE2死活没调通,还是大佬厉害啊
!!!不错,这是我见过的最完美的uboot了。很硬核啊!!!
之前尝试编fastboot,无奈错误不少啊。
显示无忧~
网络无忧~
USB无忧~
刷机无忧~
大佬!!给力!!
不知道视频编解码怎么样?要是这个完全解决了,那要无敌啊
给SDC2加了时钟降速功能,为了兼容某些品牌SD NAND自己上报能跑50M结果真跑了50M存储控制器直接死机的问题。
这个不是uboot该考虑的事哈哈。
不错,有新的u-boot 支持,有多大?
感觉uboot加上LCD显示没有太大用,最多显示一下开机logo就行了
就是显示logo用的,不然你在kernel完全加载之前会白屏很长一段时间,用户体验差(除非你Kernel在几百毫秒内就能启动完成
这个在其他全志平台能用吗,比如 H3 和 H6
不能直接用,可以参考我的commit去修改
谢谢,fastboot 是用 apt 安装的吗,还是使用全志提供的那个二进制程序。
apt装的就可以,兼容的是标准的fastboot
谢谢,还有个问题要请教下,这个烧到 EMMC 和 TF 都支持了吗?
都支持
都支持
Nice,太棒了
Net:   phy interface0
eth0: ethernet@1c30000
Warning: usb_ether MAC addresses don't match:
Address in ROM is               de:ad:be:ef:00:01
Address in environment is       12:81:3e:a8:58:d8
, eth1: usb_ether
Bus usb@1c1a000: USB EHCI 1.00
Bus usb@1c1a400: USB OHCI 1.0
Bus usb@1c1b000: USB EHCI 1.00
Bus usb@1c1b400: USB OHCI 1.0
Bus usb@1c1c000: USB EHCI 1.00
Bus usb@1c1c400: USB OHCI 1.0
Bus usb@1c1d000: USB EHCI 1.00
Bus usb@1c1d400: USB OHCI 1.0
scanning bus usb@1c1a000 for devices... 1 USB Device(s) found
scanning bus usb@1c1a400 for devices... 1 USB Device(s) found
scanning bus usb@1c1b000 for devices... 1 USB Device(s) found
scanning bus usb@1c1b400 for devices... 1 USB Device(s) found
scanning bus usb@1c1c000 for devices... 1 USB Device(s) found
scanning bus usb@1c1c400 for devices... 1 USB Device(s) found
scanning bus usb@1c1d000 for devices... 1 USB Device(s) found
scanning bus usb@1c1d400 for devices... 1 USB Device(s) found
switch to partitions #0, OK
mmc1(part 0) is current device
** Unrecognized filesystem type **
MMC: no card present
Device 0: unknown device
musb-hdrc: peripheral reset irq lost!我在 H3 上试下了,串口这个提示信息和你截图的一样
但是我在 Ubuntu PC 中使用 sudo fastboot devices 检测不到设备,一直提示
$ sudo fastboot oem
< waiting for device >
现在是不是Ubuntu Pc 的 fastboot 的配置有问题
如果板子log停在 musb-hdrc: peripheral reset irq lost! 这里,是不是说明板子那边配置应该已经正常了,谢谢!
最近编辑记录 Daniel (2020-04-27 15:44:17)
Net: phy interface0
H3我不了解具体情况,我这个代码里存在部分专门为S3做的适配,H3用很可能出BUG。可能具体的一些调整操作要你自己来做了。
fastboot不认看看dmesg中有没有枚举设备,如果没有的话可能就有点麻烦
谢谢,看来是我 fastboot 配置的问题,用全志的 fastboot 可以识别并操作
$ sudo ./fastboot devices
02c001813ea858d8    fastboot
$ sudo ./fastboot oem format
OKAY [  0.008s]
finished. total time: 0.008s
这个不是uboot该考虑的事哈哈。
要让控制台的信息输出到4.3寸液晶屏,需要做哪些设置呢?
也就是可以脱离台式机电脑操作荔枝派zero
V3s可以使用吗?努力学习arm + linux系统中。。。。。。
可以用,
arch/arm/mach-sunxi/Kconfig 要添加一行 V3s 才能编译通过:
bool "sun8i (Allwinner V3s)"
select CPU_V7A
select SUPPORT_SPL
select SUNXI_DE2config MACH_SUN8I_S3
select CPU_V7A
select SUPPORT_SPL
select SUNXI_DE2
好像不支持 SPI FLASH, 大佬可以把这个代码合并进去吗?
https://github.com/Lichee-Pi/u-boot/commits/v3s-spi-experimental
支持adozip,支持fastboot!
能支持wifi吗,有调过ap6212的没有
等我有能测试SPI设备的时候再搞
为啥要支持Wi-Fi啊,大概是什么应用场景
这个可以用到f1c100s上吗?
这个好。
感谢楼主, V3s u-boot USB运行成功
请问楼主如果TF有两个分区,执行ums命令:
=> ums 0 mmc 0
** Invalid partition 1 **
会出现这个错误, 应该怎么破?
=> ums 0 mmc 0
** Invalid partition 1 **会出现这个错误, 应该怎么破?
把这个判断强行屏蔽起来就好了
index b7cb87a98f..3a46b14b05 100644
@@ -262,6 +262,7 @@ config MACH_SUN8I_V3S
        select SUPPORT_SPL
+       select SUNXI_DE2
diff --git a/cmd/usb_mass_storage.c b/cmd/usb_mass_storage.c
index c5c6899787..635246baf8 100644
--- a/cmd/usb_mass_storage.c
+++ b/cmd/usb_mass_storage.c
@@ -56,7 +56,7 @@ static int ums_init(const char *devtype, const char *devnums_part_str)
        char *s, *t, *devnum_part_str, *name;
        struct blk_desc *block_dev;
        disk_partition_t info;
-       int partnum;
+       int partnum = 0;
        int ret = -1;
        struct ums *ums_new;
@@ -71,13 +71,12 @@ static int ums_init(const char *devtype, const char *devnums_part_str)
                devnum_part_str = strsep(&t, ",");
                if (!devnum_part_str)
                        break;
                partnum = blk_get_device_part_str(devtype, devnum_part_str,
                                        &block_dev, &info, 1);
+#if 0
                if (partnum < 0)
                        goto cleanup;
+#endif
                /* Check if the argument is in legacy format. If yes,
                 * expose all partitions by setting the partnum = 0
                 * e.g. ums 0 mmc 0
diff --git a/disk/part.c b/disk/part.c
index 4cc2fc19f7..36818af610 100644
--- a/disk/part.c
+++ b/disk/part.c
@@ -580,8 +580,8 @@ int blk_get_device_part_str(const char *ifname, const char *dev_part_str,
        if (part != PART_AUTO) {
                ret = part_get_info(*dev_desc, part, info);
                if (ret) {
-                       printf("** Invalid partition %d **\n", part);
-                       goto cleanup;
+                       printf("** Invalid partition %d test **\n", part);
+//                     goto cleanup;
        } else {
@@ -632,7 +632,7 @@ int blk_get_device_part_str(const char *ifname, const char *dev_part_str,
                        " (expect \"" BOOT_PART_TYPE "\")\n",
                        info->type);
                ret  = -1;
-               goto cleanup;
+//             goto cleanup;
        (*dev_desc)->log2blksz = LOG2((*dev_desc)->blksz);
奇怪,我的荔枝派跑起来其它功能都正常,但是屏幕背光没有显示。
One problem with this u-boot - it overwrites loaded splash image with uboot version string.
我的也是没有背光, 这就尴尬了, 看代码好像是 dts 驱动pwm0 (PB4) 实现的, 荔枝派的原理图也是这么接, 可是就是不亮.
dylan 说:能支持wifi吗,有调过ap6212的没有
AP6212是什么级别的WiFi?有阉割吗?
孤星泪 说:奇怪,我的荔枝派跑起来其它功能都正常,但是屏幕背光没有显示。
修改这个文件: drivers/video/sunxi/sunxi_lcd.c
        int pin;
#define SUN8I_V3S_GPE_LCD 3
        for (pin = SUNXI_GPE(0); pin <= SUNXI_GPE(24); pin++) {
                if (pin >= SUNXI_GPE(20) && pin <= SUNXI_GPE(22))
                        continue; /* These pins are not LCD */
                sunxi_gpio_set_cfgpin(pin, SUN8I_V3S_GPE_LCD);
        printf("init v3s gpio e for lcd\n");
                sunxi_gpio_set_cfgpin(pin, SUNXI_GPD_LCD0);
                sunxi_gpio_set_drv(pin, 3);
        printf("init s3 gpio e for lcd\n");
}然后命令行运行:
fatload usb 0:1 0x43000000 800x480.bmp;bmp display 0x43000000 0 0
屏幕有反应了, 但是显示还不正常.
为什么从 S3 的datasheet里面找不到 DE2 相关的寄存器相关信息呢?
马前卒 说:孤星泪 说:奇怪,我的荔枝派跑起来其它功能都正常,但是屏幕背光没有显示。
static void sunxi_lcdc_config_pinmux(void) { #if defined(CONFIG_MACH_SUN50I) || defined(CONFIG_MACH_SUN8I_V3S) || defined(CONFIG_MACH_SUN8I_S3) int pin; #if defined(CONFIG_MACH_SUN8I_V3S) #define SUN8I_V3S_GPE_LCD 3 for (pin = SUNXI_GPE(0); pin <= SUNXI_GPE(24); pin++) { if (pin >= SUNXI_GPE(20) && pin <= SUNXI_GPE(22)) continue; /* These pins are not LCD */ sunxi_gpio_set_cfgpin(pin, SUN8I_V3S_GPE_LCD); } printf("init v3s gpio e for lcd\n"); #elif defined(CONFIG_MACH_SUN8I_S3) for (pin = SUNXI_GPD(0); pin <= SUNXI_GPD(21); pin++) { sunxi_gpio_set_cfgpin(pin, SUNXI_GPD_LCD0); sunxi_gpio_set_drv(pin, 3); } printf("init s3 gpio e for lcd\n"); #endif #endif }然后命令行运行:
屏幕有反应了, 但是显示还不正常.
v3s 修改设备树里lcd的参数,图片能显示正常。
但uboot启动时lcd还是没亮的,另外U盘也不支持;
感谢白嫖
大佬,用你的uboot启动内核出现下面错误,需要做哪些设置呢
[    1.862149] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[    1.870417] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.1.0 #26
[    1.876332] Hardware name: Allwinner sun8i Family
[    1.881076] [<c010ece0>] (unwind_backtrace) from [<c010b76c>] (show_stack+0x10/0x14)
[    1.888831] [<c010b76c>] (show_stack) from [<c075ee50>] (dump_stack+0x84/0x98)
[    1.896062] [<c075ee50>] (dump_stack) from [<c011dba4>] (panic+0x110/0x2b8)
[    1.903032] [<c011dba4>] (panic) from [<c0a0130c>] (mount_block_root+0x1a0/0x288)
[    1.910521] [<c0a0130c>] (mount_block_root) from [<c0a01538>] (mount_root+0x144/0x160)
[    1.918442] [<c0a01538>] (mount_root) from [<c0a016a4>] (prepare_namespace+0x150/0x194)
[    1.926452] [<c0a016a4>] (prepare_namespace) from [<c07773c8>] (kernel_init+0x8/0x10c)
[    1.934376] [<c07773c8>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
[    1.941944] Exception stack(0xc6833fb0 to 0xc6833ff8)
[    1.946997] 3fa0:                                     00000000 00000000 00000000 00000000
[    1.955177] 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.963353] 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[    1.969981] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---感谢感谢
好像有些重要信息被你截取掉了……发一下完整的log吧。
感觉一般 unable to mount rootfs 都是 kernel 没配置好的问题,和 u-boot 可能没关系?
最近编辑记录 unturned3 (2021-05-12 17:37:29)
yangshuwei 说:大佬,用你的uboot启动内核出现下面错误,需要做哪些设置呢
U-Boot SPL 2020.04-00497-gc8aac3e-dirty (May 12 2021 - 17:32:37 +0800)
DRAM: 128 MiB
Trying to boot from FEL
U-Boot 2020.04-00497-gc8aac3e-dirty (May 12 2021 - 17:32:37 +0800) Allwinner Technology
CPU:   Allwinner S3 (SUN8I 1681)
Model: Allwinner S3 Generic Device
DRAM:  128 MiB
MMC:   mmc@01c0f000: 0, mmc@01c11000: 1
Loading Environment from FAT... Card did not respond to voltage select!
Error (-2): cannot determine file size
In:    serial
Out:   serial
Err:   serial
Net:   phy interface0
Warning: ethernet@1c30000 (eth0) using random MAC address - 02:60:b1:57:c3:3c
Warning: usb_ether using MAC address from ROM
, eth1: usb_ether
Bus usb@01c1a000: USB EHCI 1.00
Bus usb@01c1a400: USB OHCI 1.0
scanning bus usb@01c1a000 for devices... 1 USB Device(s) found
scanning bus usb@01c1a400 for devices... 1 USB Device(s) found
4672328 bytes read in 215 ms (20.7 MiB/s)
14088 bytes read in 3 ms (4.5 MiB/s)
   Loading Device Tree to 42df9000, end 42dff707 ... OK
[    0.000000] Linux version 5.1.0 (root@debian8) (gcc version 6.4.1 20170707 (Linaro GCC 6.4-2017.08)) #26 SMP Tue Jun 18 13:58:52 HKT 2019
[    0.000000] OF: fdt: Machine model: hqembed s3 lcd050ips
[    0.000000] cma: Reserved 16 MiB at 0x47000000
[    0.000000] percpu: Embedded 16 pages/cpu s34572 r8192 d22772 u65536
[    0.000000] Kernel command line:
[    0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] Memory: 102556K/131072K available (7168K kernel code, 326K rwdata, 1712K rodata, 1024K init, 253K bss, 12132K reserved, 16384K cma-reserved, 0K highmem)
[    0.000000] random: get_random_bytes called from start_kernel+0x2a0/0x42c with crng_init=0
[    0.000212] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000451] Console: colour dummy device 80x30
[    0.000721] printk: console [tty0] enabled
[    0.000775] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000804] pid_max: default: 32768 minimum: 301
[    0.001008] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.001040] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.001795] *** VALIDATE proc ***
[    0.002040] *** VALIDATE cgroup1 ***
[    0.002071] *** VALIDATE cgroup2 ***
[    0.002097] CPU: Testing write buffer coherency: ok
[    0.002634] /cpus/cpu@0 missing clock-frequency property
[    0.002682] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.003564] Setting up static identity map for 0x40100000 - 0x40100060
[    0.003818] rcu: Hierarchical SRCU implementation.
[    0.004425] smp: Bringing up secondary CPUs ...
[    0.004470] smp: Brought up 1 node, 1 CPU
[    0.004488] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[    0.004504] CPU: All CPU(s) started in SVC mode.
[    0.005443] devtmpfs: initialized
[    0.009381] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.009719] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.009774] futex hash table entries: 256 (order: 2, 16384 bytes)
[    0.010780] pinctrl core: initialized pinctrl subsystem
[    0.012139] NET: Registered protocol family 16
[    0.013672] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.014892] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.014940] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.044538] SCSI subsystem initialized
[    0.044865] usbcore: registered new interface driver usbfs
[    0.044954] usbcore: registered new interface driver hub
[    0.045084] usbcore: registered new device driver usb
[    0.045368] media: Linux media interface: v0.10
[    0.045430] videodev: Linux video capture interface: v2.00
[    0.045495] pps_core: LinuxPPS API ver. 1 registered
[    0.045512] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.045558] PTP clock support registered
[    0.045857] Advanced Linux Sound Architecture Driver Initialized.
[    0.046569] Bluetooth: Core ver 2.22
[    0.046687] NET: Registered protocol family 31
[    0.046708] Bluetooth: HCI device and connection manager initialized
[    0.046740] Bluetooth: HCI socket layer initialized
[    0.046759] Bluetooth: L2CAP socket layer initialized
[    0.046799] Bluetooth: SCO socket layer initialized
[    0.047685] clocksource: Switched to clocksource arch_sys_counter
[    0.060511] NET: Registered protocol family 2
[    0.061276] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[    0.061343] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.061388] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[    0.061419] TCP: Hash tables configured (established 1024 bind 1024)
[    0.061592] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.061662] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.061934] NET: Registered protocol family 1
[    0.062963] RPC: Registered named UNIX socket transport module.
[    0.063014] RPC: Registered udp transport module.
[    0.063027] RPC: Registered tcp transport module.
[    0.063039] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.065572] Initialise system trusted keyrings
[    0.066040] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[    0.074652] NFS: Registering the id_resolver key type
[    0.074732] Key type id_resolver registered
[    0.074747] Key type id_legacy registered
[    0.074822] Key type asymmetric registered
[    0.074839] Asymmetric key parser 'x509' registered
[    0.074923] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.074949] io scheduler mq-deadline registered
[    0.074963] io scheduler kyber registered
[    0.080848] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.155292] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.157957] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pb not found, using dummy regulator
[    0.179495] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 38, base_baud = 1500000) is a U6_16550A
[    0.753955] printk: console [ttyS0] enabled
[    0.758879] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
[    0.790342] 1c28400.serial: ttyS1 at MMIO 0x1c28400 (irq = 39, base_baud = 1500000) is a U6_16550A
[    0.821347] 1c28800.serial: ttyS2 at MMIO 0x1c28800 (irq = 40, base_baud = 1500000) is a U6_16550A
[    0.855012] libphy: Fixed MDIO Bus: probed
[    0.859295] CAN device driver interface
[    0.863756] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[    0.869683] dwmac-sun8i 1c30000.ethernet: No regulator found
[    0.876005] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 148000 (expect 38000)
[    0.885544] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[    0.892806] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[    0.900052] dwmac-sun8i 1c30000.ethernet: COE Type 2
[    0.905020] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[    0.911824] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[    0.917484] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[    0.923178] dwmac-sun8i 1c30000.ethernet (unnamed net_device) (uninitialized): device MAC address 36:c2:66:0a:5f:7a
[    0.933876] libphy: stmmac: probed
[    0.938114] dwmac-sun8i 1c30000.ethernet: Found internal PHY node
[    0.944460] libphy: mdio_mux: probed
[    0.948171] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY
[    0.954543] dwmac-sun8i 1c30000.ethernet: Powering internal PHY
[    0.961791] libphy: mdio_mux: probed
[    0.965874] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.972550] ehci-platform: EHCI generic platform driver
[    0.978149] ehci-platform 1c1a000.usb: EHCI Host Controller
[    0.983805] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    0.992111] ehci-platform 1c1a000.usb: irq 28, io mem 0x01c1a000
[    1.027683] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    1.035006] hub 1-0:1.0: USB hub found
[    1.039016] hub 1-0:1.0: 1 port detected
[    1.043749] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.050119] ohci-platform: OHCI generic platform driver
[    1.055717] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    1.062469] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[    1.070696] ohci-platform 1c1a400.usb: irq 29, io mem 0x01c1a400
[    1.142865] hub 2-0:1.0: USB hub found
[    1.146738] hub 2-0:1.0: 1 port detected
[    1.152098] usbcore: registered new interface driver usb-storage
[    1.158451] usbcore: registered new interface driver usbserial_generic
[    1.165041] usbserial: USB Serial support registered for generic
[    1.171705] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    1.183336] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    1.189218] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[    1.198518] hub 3-0:1.0: USB hub found
[    1.202389] hub 3-0:1.0: 1 port detected
[    1.207877] dummy_hcd dummy_hcd.0: USB Host+Gadget Emulator, driver 02 May 2005
[    1.215239] dummy_hcd dummy_hcd.0: Dummy host controller
[    1.220622] dummy_hcd dummy_hcd.0: new USB bus registered, assigned bus number 4
[    1.229237] hub 4-0:1.0: USB hub found
[    1.233118] hub 4-0:1.0: 1 port detected
[    1.239053] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
[    1.248397] sun6i-rtc 1c20400.rtc: registered as rtc0
[    1.253482] sun6i-rtc 1c20400.rtc: RTC enabled
[    1.258258] i2c /dev entries driver
[    1.263490] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pe not found, using dummy regulator
[    1.276934] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.285075] Bluetooth: HCI UART driver ver 2.3
[    1.289586] Bluetooth: HCI UART protocol H4 registered
[    1.295735] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
[    1.307099] sunxi-mmc 1c0f000.mmc: Got CD GPIO
[    1.337314] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[    1.346235] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
[    1.376139] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB
[    1.383490] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
[    1.404163] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.417189] mmc0: new high speed SDHC card at address aaaa
[    1.423216] sunxi-mmc 1c11000.mmc: initialized, max. request size: 16384 KB
[    1.431901] usbcore: registered new interface driver usbhid
[    1.437506] usbhid: USB HID core driver
[    1.444127] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
[    1.452638] sun4i-codec 1c22c00.codec: ASoC: codec-analog@01c23000 not registered
[    1.460378] sun4i-codec 1c22c00.codec: Failed to register our card
[    1.467001]  mmcblk0: p1 p2
[    1.473302] NET: Registered protocol family 17
[    1.477970] can: controller area network core (rev 20170425 abi 9)
[    1.484306] NET: Registered protocol family 29
[    1.488826] can: raw protocol (rev 20170425)
[    1.493105] can: broadcast manager protocol (rev 20170425 t)
[    1.498798] can: netlink gateway (rev 20170425) max_hops=1
[    1.504648] Key type dns_resolver registered
[    1.509035] Registering SWP/SWPB emulation handler
[    1.514404] mmc1: new high speed SDIO card at address 0001
[    1.521203] Loading compiled-in X.509 certificates
[    1.534613] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[    1.543405] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01T03:47:00 UTC (13620)
[    1.552055] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    1.563844] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    1.570681] vcc5v0: disabling
[    1.573672] ALSA device list:
[    1.576645]   #0: V3s Audio Codec
[    1.580931] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    1.589710] cfg80211: failed to load regulatory.db
[    1.595277] VFS: Cannot open root device "(null)" or unknown-block(0,0): error -6
[    1.602946] Please append a correct "root=" boot option; here are the available partitions:
[    1.611360] b300        15558144 mmcblk0
[    1.611365]  driver: mmcblk
[    1.618197]   b301           51200 mmcblk0p1 33c8c247-01
[    1.618199]
[    1.625003]   b302        15505408 mmcblk0p2 33c8c247-02
[    1.625005]
[    1.631830] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[    1.640098] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.1.0 #26
[    1.646013] Hardware name: Allwinner sun8i Family
[    1.650756] [<c010ece0>] (unwind_backtrace) from [<c010b76c>] (show_stack+0x10/0x14)
[    1.658511] [<c010b76c>] (show_stack) from [<c075ee50>] (dump_stack+0x84/0x98)
[    1.665743] [<c075ee50>] (dump_stack) from [<c011dba4>] (panic+0x110/0x2b8)
[    1.672714] [<c011dba4>] (panic) from [<c0a0130c>] (mount_block_root+0x1a0/0x288)
[    1.680203] [<c0a0130c>] (mount_block_root) from [<c0a01538>] (mount_root+0x144/0x160)
[    1.688123] [<c0a01538>] (mount_root) from [<c0a016a4>] (prepare_namespace+0x150/0x194)
[    1.696133] [<c0a016a4>] (prepare_namespace) from [<c07773c8>] (kernel_init+0x8/0x10c)
[    1.704055] [<c07773c8>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
[    1.711625] Exception stack(0xc6833fb0 to 0xc6833ff8)
[    1.716678] 3fa0:                                     00000000 00000000 00000000 00000000
[    1.724857] 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.733034] 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[    1.739662] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---离线
大佬牛皮啊,超感谢大佬的贡献
奇怪,我的背光也亮不起来。
奇怪,我的背光也亮不起来。
以前玩过,pwm感觉是有bug,用uboot命令行
gpio set pb4
就可以点亮屏幕。
fastboot oem format这个学到了, 真好用
流氓兔 说:好像不支持 SPI FLASH, 大佬可以把这个代码合并进去吗?
等我有能测试SPI设备的时候再搞
基本全了,只差SPI FLASH
大家好你们好!
你能帮我设置连接到 S3 MCU PD0-PD21 端口的 LCD 显示器吗? 我已经克隆了这个存储库,但是 LCD 引脚上没有任何活动。 我应该检查什么才能确定,液晶显示器没问题。 硬件看起来不错。
先感谢您
期待您的回复。
@哇酷小二
不,这些引脚上没有任何活动。
大佬,我好奇你的开机logo实现了吗?不知道能不能运行
