楼主 # 2021-08-04 09:46:34
小果果
已发帖子: 61
esp-idf v4.3怎么设置gpio0输出时钟信号给rmii?
v3.3的SDK还有接口,到了v4.3就完全找不到接口了
#1 2021-08-05 10:19:08
夏雨夜寐
已发帖子: 85
Re: esp-idf v4.3怎么设置gpio0输出时钟信号给rmii?
在menuconfig里Ethernet里有选项
4.3RMII clock部分用宏做到hal里了
参考idf里hal部分
void emac_hal_lowlevel_init(emac_hal_context_t *hal);
#if CONFIG_ETH_RMII_CLK_INPUT
#if CONFIG_ETH_RMII_CLK_IN_GPIO == 0
    /* RMII clock (50MHz) input to GPIO0 */
    PIN_FUNC_SELECT(PERIPHS_IO_MUX_GPIO0_U, FUNC_GPIO0_EMAC_TX_CLK);
    PIN_INPUT_ENABLE(GPIO_PIN_MUX_REG[0]);
#else
#error "ESP32 EMAC only support input RMII clock to GPIO0"
#if CONFIG_ETH_RMII_CLK_OUTPUT
#if CONFIG_ETH_RMII_CLK_OUTPUT_GPIO0
    /* APLL clock output to GPIO0 (must be configured to 50MHz!) */
    PIN_FUNC_SELECT(PERIPHS_IO_MUX_GPIO0_U, FUNC_GPIO0_CLK_OUT1);
    PIN_INPUT_DISABLE(GPIO_PIN_MUX_REG[0]);
#elif CONFIG_ETH_RMII_CLK_OUT_GPIO == 16
    /* RMII CLK (50MHz) output to GPIO16 */
    PIN_FUNC_SELECT(PERIPHS_IO_MUX_GPIO16_U, FUNC_GPIO16_EMAC_CLK_OUT);
    PIN_INPUT_DISABLE(GPIO_PIN_MUX_REG[16]);
#elif CONFIG_ETH_RMII_CLK_OUT_GPIO == 17
    /* RMII CLK (50MHz) output to GPIO17 */
    PIN_FUNC_SELECT(PERIPHS_IO_MUX_GPIO17_U, FUNC_GPIO17_EMAC_CLK_OUT_180);
    PIN_INPUT_DISABLE(GPIO_PIN_MUX_REG[17]);
#endif // CONFIG_ETH_RMII_CLK_OUTPUT
    /* Clock configuration */
最近编辑记录 夏雨夜寐 (2021-08-05 10:20:59)
#2 2021-08-05 15:29:49
szchen2006
已发帖子: 216
  • 不通过:与技术无关
楼主 #3 2021-08-26 14:38:40
小果果
已发帖子: 61
@夏雨夜寐
最近没怎么上线,谢谢大佬
