内核版本:linux5.2
参考文章:
https://whycan.com/t_576.html#p1579
https://blog.csdn.net/qulang000/article/details/114686525
我在配置此屏幕时遇到问题发的帖子
https://whycan.com/t_6393.html
感谢大佬们的热心指导!
1、配置内核驱动
Device Drivers --->
[ * ] Staging drivers --->
<*> Support for small TFT LCD display modules --->
<*> FB driver for the ILI9341 LCD Controller
<*> Generic FB driver for TFT LCD displays
2、在sun8i-v3s-licheepi-zero.dts添加设备树节点。注意,reset、dc引脚可以自由选择,只要不跟其它驱动冲突即可。
&i2c0 {
112 status = "disable";
113
114 ns2009: ns2009@48 {
115 compatible = "nsiway,ns2009";
116 reg = <0x48>;
117 };
118 };
183 &spi0 {
184 status = "okay";
185 spi_lcd@0 {
186 #address-cells = <1>;
187 #size-cells = <1>;
188 rotate = <90>;
189 fps = <30>;
190 buswidth = <8>;
191 bgr;
192 dc-gpios = <&pio 1 5 GPIO_ACTIVE_HIGH>;
193 reset-gpios = <&pio 1 7 GPIO_ACTIVE_LOW>;
194 debug = <0x0>;
195 compatible = "ilitek,ili9341";
196 reg = <0>;
197 spi-max-frequency = <48000000>;
198 };
199 };3、修改drivers/staging/fbtft/fbtft-core.c文件中的fbtft_request_one_gpio函数
注意需要在该文件上引入下面头文件,否则编译报错。
#include <linux/of_gpio.h>
static int fbtft_request_one_gpio(struct fbtft_par *par,
76 const char *name, int index,
77 struct gpio_desc **gpiop)
78 {
79 /*
80 struct device *dev = par->info->device;
81 struct device_node *node = dev->of_node;
82 int ret = 0;
83
84 if (of_find_property(node, name, NULL)) {
85 *gpiop = devm_gpiod_get_index(dev, dev->driver->name, index,
86 GPIOD_OUT_HIGH);
87 if (IS_ERR(*gpiop)) {
88 ret = PTR_ERR(*gpiop);
89 dev_err(dev,
90 "Failed to request %s GPIO:%d\n", name, ret);
91 return ret;
92 }
93 fbtft_par_dbg(DEBUG_REQUEST_GPIOS, par, "%s: '%s' GPIO\n",
94 __func__, name);
95 }
96
97 return ret;
98 */
100 struct device *dev = par->info->device;
101 struct device_node *node = dev->of_node;
102 int gpio, flags, ret = 0;
103 enum of_gpio_flags of_flags;
104 char gpio_names[32];
105
106 //sprintf(gpio_names, "%s-gpios", name);
107 sprintf(gpio_names, "%s", name);
108 printk("@ gpio_names = %s\n", gpio_names);
109 if (of_find_property(node, gpio_names, NULL)) {
110 gpio = of_get_named_gpio_flags(node, gpio_names, index, &of_flags);
111 printk ("@ gpio = %d | ENOENT = %d | EPROBE_DEFER = %d \n", gpio, ENOENT, EPROBE_DEFER);
112 if (gpio == -ENOENT)
113 return 0;
114 if (gpio == -EPROBE_DEFER)
115 return gpio;
116 if (gpio < 0) {
117 dev_err(dev,
118 "failed to get '%s' from DT\n", gpio_names);
119 return gpio;
120 }
121
122 //active low translates to initially low
123 flags = (of_flags & OF_GPIO_ACTIVE_LOW) ? GPIOF_OUT_INIT_LOW :
124 GPIOF_OUT_INIT_HIGH;
125 ret = devm_gpio_request_one(dev, gpio, flags,
126 dev->driver->name);
127 if (ret) {
128 dev_err(dev,
129 "gpio_request_one('%s'=%d) failed with %d\n",
130 gpio_names, gpio, ret);
131 return ret;
132 }
133
134 *gpiop = gpio_to_desc(gpio);
135 fbtft_par_dbg(DEBUG_REQUEST_GPIOS, par, "%s: '%s' = GPIO%d\n",
136 __func__, gpio_names, gpio);
137 }
138 return ret;
139 }4、修改drivers/staging/fbtft/fbtft-core.c文件中的fbtft_reset函数
278 static void fbtft_reset(struct fbtft_par *par)
279 {
280 /*
281 if (!par->gpio.reset)
282 return;
283 fbtft_par_dbg(DEBUG_RESET, par, "%s()\n", __func__);
284 gpiod_set_value_cansleep(par->gpio.reset, 0);
285 usleep_range(20, 40);
286 gpiod_set_value_cansleep(par->gpio.reset, 1);
287 msleep(120);
288 */
289
290
291 if (!par->gpio.reset)
292 return;
293 fbtft_par_dbg(DEBUG_RESET, par, "%s()\n", __func__);
294 gpiod_set_value_cansleep(par->gpio.reset, 1);
295 usleep_range(20, 40);
296 gpiod_set_value_cansleep(par->gpio.reset, 0);
297 msleep(120);
298 gpiod_set_value_cansleep(par->gpio.reset, 1);
299 msleep(10);
300
301 }5、修改修改drivers/staging/fbtft/fbtft-core.c文件中的fbtft_request_gpios_dt函数里面,reset和dc引脚名称,从reset-gpios 和 dc-gpios 改为reset 和dc。
141 static int fbtft_request_gpios_dt(struct fbtft_par *par)
142 {
143 int i;
144 int ret;
145
146 if (!par->info->device->of_node)
147 return -EINVAL;
148
149
150 ret = fbtft_request_one_gpio(par, "reset", 0, &par->gpio.reset);
151 if (ret)
152 return ret;
153
154 ret = fbtft_request_one_gpio(par, "dc", 0, &par->gpio.dc);
155 if (ret)
156 return ret;
157
158 ret = fbtft_request_one_gpio(par, "rd-gpios", 0, &par->gpio.rd);
159 if (ret)
160 return ret;
161 ret = fbtft_request_one_gpio(par, "wr-gpios", 0, &par->gpio.wr);
162 if (ret)
163 return ret;
164 ret = fbtft_request_one_gpio(par, "cs-gpios", 0, &par->gpio.cs);
165 if (ret)
166 return ret;
167 ret = fbtft_request_one_gpio(par, "latch-gpios", 0, &par->gpio.latch);
168 if (ret)
169 return ret;
170 for (i = 0; i < 16; i++) {
171 ret = fbtft_request_one_gpio(par, "db-gpios", i,
172 &par->gpio.db[i]);
173 if (ret)
174 return ret;
175 ret = fbtft_request_one_gpio(par, "led-gpios", i,
176 &par->gpio.led[i]);
177 if (ret)
178 return ret;
179 ret = fbtft_request_one_gpio(par, "aux-gpios", i,
180 &par->gpio.aux[i]);
181 if (ret)
182 return ret;
183 }6、修改drivers/staging/fbtft/fbtft-bus.c 中的fbtft_write_vmem16_bus8函数,直接替换
int fbtft_write_vmem16_bus8(struct fbtft_par *par, size_t offset, size_t len)
u16 *vmem16;
__be16 *txbuf16 = par->txbuf.buf;
size_t remain;
size_t to_copy;
size_t tx_array_size;
int i;
int ret = 0;
size_t startbyte_size = 0;
fbtft_par_dbg(DEBUG_WRITE_VMEM, par, "%s(offset=%zu, len=%zu)\n",
__func__, offset, len);
remain = len / 2;
vmem16 = (u16 *)(par->info->screen_buffer + offset);
if (par->gpio.dc)
//printk("dc拉高!\n");
gpiod_set_value(par->gpio.dc, 1);
/* non buffered write */
if (!par->txbuf.buf)
return par->fbtftops.write(par, vmem16, len);
/* buffered write */
tx_array_size = par->txbuf.len / 2;
if (par->startbyte) {
txbuf16 = par->txbuf.buf + 1;
tx_array_size -= 2;
*(u8 *)(par->txbuf.buf) = par->startbyte | 0x2;
startbyte_size = 1;
while (remain) {
to_copy = min(tx_array_size, remain);
dev_dbg(par->info->device, "to_copy=%zu, remain=%zu\n",
to_copy, remain - to_copy);
for (i = 0; i < to_copy; i++)
txbuf16[i] = cpu_to_be16(vmem16[i]);
vmem16 = vmem16 + to_copy;
ret = par->fbtftops.write(par, par->txbuf.buf,
startbyte_size + to_copy * 2);
if (ret < 0)
return ret;
remain -= to_copy;
return ret;
}最后编译运行即可,启动log中会出现下面提示
[ 1.165809] fbtft_of_value: buswidth = 8
[ 1.169779] fbtft_of_value: debug = 0
[ 1.173438] fbtft_of_value: rotate = 90
[ 1.177267] fbtft_of_value: fps = 30
[ 1.215817] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.225921] mmc0: new high speed SDHC card at address 1234
[ 1.233279] mmcblk0: mmc0:1234 SA08G 7.21 GiB
[ 1.239976] mmcblk0: p1 p2
[ 1.475892] random: fast init done
[ 1.510864] Console: switching to colour frame buffer device 40x30
[ 1.517762] graphics fb0: fb_ili9341 frame buffer, 320x240, 150 KiB video memory, 16 KiB buffer memory, fps=33, spi0.0 at 48 MHz离线
接线
SPI屏 zero
3v3 3v3
GND GND
DC PWM1
RST 3v3
CS CS
CLK CLK
MISO MISO
MOSI MOSI
LED 3.3V
娃酷网就需要你这样的分享
记得spi FIFO只有64字节,楼主可以在刷屏时cat /proc/interrupts看看spi的中断次数不?
看看刷屏中断会不会太频繁了
看看刷屏中断会不会太频繁了
可以呀,但是我现在只是把屏幕配置好。我是打算把摄像头获取到的图像显示在屏幕上的,但是使用的时候遇到了问题。问题发在下面的帖子上。
https://whycan.com/t_3909.html
或者你告诉怎么刷屏
看看刷屏中断会不会太频繁了
你看下
# cat /proc/interrupts
CPU0
19: 7542 GIC-0 27 Level arch_timer
21: 0 GIC-0 50 Level timer@1c20c00
22: 0 GIC-0 82 Level 1c02000.dma-controller
23: 27439 GIC-0 92 Level sunxi-mmc
24: 0 GIC-0 103 Level musb-hdrc.1.auto
25: 0 GIC-0 104 Level ehci_hcd:usb1
26: 2 GIC-0 105 Level ohci_hcd:usb2
27: 0 GIC-0 72 Level 1c20400.rtc
29: 1021 GIC-0 116 Level sun6i-csi
34: 392 GIC-0 32 Level ttyS0
35: 1724 GIC-0 39 Level mv64xxx_i2c
36: 4082175 GIC-0 97 Level sun6i-spi
IPI0: 0 CPU wakeup interrupts
IPI1: 0 Timer broadcast interrupts
IPI2: 0 Rescheduling interrupts
IPI3: 0 Function call interrupts
IPI4: 0 CPU stop interrupts
IPI5: 0 IRQ work interrupts
IPI6: 0 completion interrupts
Err: 0离线
FIFO 刷屏这个中断次数确实挺高的
一帧320*240*2=153600字节
刷一帧153600/64=2400次
因为我现在F1C100S上在用DMA刷SPI TFT,但是感觉跟其他通道DMA有干扰,想看看主线的FIFO刷的效率
请问如果移植完是黑屏的怎么办 u-boot使用的默认的配置 没有lcd的
cat /dev/urandom > /dev/fb0
cat /dev/zero > /dev/fb0
使用第一条命令可以让屏幕出现雪花
使用第二条命令可以让屏幕变黑
说明屏幕移植成功
酷酷酷 说:请问如果移植完是黑屏的怎么办 u-boot使用的默认的配置 没有lcd的
cat /dev/zero > /dev/fb0使用第一条命令可以让屏幕出现雪花
使用第二条命令可以让屏幕变黑
说明屏幕移植成功
那有什么库可以显示图片的吗 还有就是控制台的输出是怎么输出在屏幕上的呀
fbv太难移植了 fbset好像又用不了
最近编辑记录 酷酷酷 (2021-05-03 21:34:41)
大佬,如果ili9341屏幕没有CS引脚该怎么办呢?
[ 0.860671] fbtft_of_value: buswidth = 8
[ 0.864653] fbtft_of_value: debug = 0
[ 0.868325] fbtft_of_value: rotate = 270
[ 0.872252] fbtft_of_value: fps = 10
[ 1.244063] graphics fb0: fb_ili9341 frame buffer, 320x240, 150 KiB video memory, 16 KiB DMA buffer memory, fps=10, spi32766.0 at 15 MHz
make menuconfig同样配置为什么启动时没有显示如上log信息?
在这之前还需要在meun里配置什么吗?
我已经完成了每一步 为什么显示器不显示?
https://whycan.com/t_6413.html
U-Boot 2017.01-rc2-00073-gdd6e8740dc-dirty (Jul 31 2022 - 11:52:11 +0700) Allwinner Technology
Model: Lichee Pi Zero
DRAM: 64 MiB
MMC: SUNXI SD/MMC: 0
SF: unrecognized JEDEC id bytes: 00, c2, 12
In: serial@01c28000
Out: serial@01c28000
Err: serial@01c28000
Net: No ethernet found.
No controllers found
reading zImage
4196800 bytes read in 232 ms (17.3 MiB/s)
12397 bytes read in 30 ms (403.3 KiB/s)
Loading Device Tree to 42df9000, end 42dff06c ... OK
[ 0.000000] Linux version 5.2.0-licheepi-zero (tevada@T420s) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #6 SMP Sun Jul 31 21:06:16 +07 2022
[ 0.000000] OF: fdt: Machine model: Lichee Pi Zero with Dock
[ 0.000000] percpu: Embedded 16 pages/cpu s34508 r8192 d22836 u65536
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: console=ttyS0,115200 panic=5 mtdparts=spi32766.0:1M(uboot),64k(dtb),4M(kernel),-(rootfs) rootwait root=/dev/mmcblk0p2 earlyprintk rw vt.global_cursor_default=0
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.000000] Memory: 55044K/65536K available (6144K kernel code, 301K rwdata, 1684K rodata, 1024K init, 254K bss, 10492K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] random: get_random_bytes called from start_kernel+0x300/0x48c with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[ 0.000019] Switching to timer-based delay loop, resolution 41ns
[ 0.000210] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000451] Console: colour dummy device 80x30
[ 0.000507] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000523] pid_max: default: 32768 minimum: 301
[ 0.000686] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.000703] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.001507] CPU: Testing write buffer coherency: ok
[ 0.002022] /cpus/cpu@0 missing clock-frequency property
[ 0.002048] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002815] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.003022] rcu: Hierarchical SRCU implementation.
[ 0.003567] smp: Bringing up secondary CPUs ...
[ 0.003586] smp: Brought up 1 node, 1 CPU
[ 0.003597] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.003604] CPU: All CPU(s) started in SVC mode.
[ 0.004683] devtmpfs: initialized
[ 0.008173] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.008494] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.008526] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[ 0.008770] pinctrl core: initialized pinctrl subsystem
[ 0.009804] NET: Registered protocol family 16
[ 0.010423] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.011687] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.011706] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.035081] SCSI subsystem initialized
[ 0.035244] usbcore: registered new interface driver usbfs
[ 0.035298] usbcore: registered new interface driver hub
[ 0.035418] usbcore: registered new device driver usb
[ 0.035651] mc: Linux media interface: v0.10
[ 0.035692] videodev: Linux video capture interface: v2.00
[ 0.035881] Advanced Linux Sound Architecture Driver Initialized.
[ 0.037188] clocksource: Switched to clocksource arch_sys_counter
[ 0.049291] NET: Registered protocol family 2
[ 0.050120] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.050160] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.050185] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.050209] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.050354] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.050406] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.050700] NET: Registered protocol family 1
[ 0.052563] Initialise system trusted keyrings
[ 0.052935] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.090419] Key type asymmetric registered
[ 0.090441] Asymmetric key parser 'x509' registered
[ 0.090541] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.090553] io scheduler mq-deadline registered
[ 0.090560] io scheduler kyber registered
[ 0.091569] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
[ 0.095297] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.164058] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.166389] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pb not found, using dummy regulator
[ 0.167563] printk: console [ttyS0] disabled
[ 0.187847] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 36, base_baud = 1500000) is a U6_16550A
[ 0.702720] printk: console [ttyS0] enabled
[ 0.731672] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
[ 0.742960] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.749580] ehci-platform: EHCI generic platform driver
[ 0.755100] ehci-platform 1c1a000.usb: EHCI Host Controller
[ 0.760774] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[ 0.768731] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[ 0.797213] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[ 0.804423] hub 1-0:1.0: USB hub found
[ 0.808377] hub 1-0:1.0: 1 port detected
[ 0.812959] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.819279] ohci-platform: OHCI generic platform driver
[ 0.824817] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[ 0.831558] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[ 0.839555] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[ 0.912278] hub 2-0:1.0: USB hub found
[ 0.916125] hub 2-0:1.0: 1 port detected
[ 0.923471] usbcore: registered new interface driver usb-storage
[ 0.930748] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
[ 0.940032] sun6i-rtc 1c20400.rtc: registered as rtc0
[ 0.945094] sun6i-rtc 1c20400.rtc: RTC enabled
[ 0.949816] i2c /dev entries driver
[ 0.954200] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 0.962886] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
[ 0.999313] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[ 1.006575] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
[ 1.041672] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB
[ 1.049759] usbcore: registered new interface driver usbhid
[ 1.055335] usbhid: USB HID core driver
[ 1.059383] fbtft_of_value: buswidth = 8
[ 1.063311] fbtft_of_value: debug = 0
[ 1.066969] fbtft_of_value: rotate = 90
[ 1.070841] fbtft_of_value: fps = 30
[ 1.084058] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.095947] mmc0: new high speed SD card at address e624
[ 1.103110] mmcblk0: mmc0:e624 SU02G 1.84 GiB
[ 1.108669] mmc1: queuing unknown CIS tuple 0x01 (3 bytes)
[ 1.119178] mmcblk0: p1 p2
[ 1.125484] mmc1: queuing unknown CIS tuple 0x1a (5 bytes)
[ 1.134200] mmc1: queuing unknown CIS tuple 0x1b (8 bytes)
[ 1.141570] mmc1: queuing unknown CIS tuple 0x80 (1 bytes)
[ 1.147100] mmc1: queuing unknown CIS tuple 0x81 (1 bytes)
[ 1.152699] mmc1: queuing unknown CIS tuple 0x82 (1 bytes)
[ 1.158256] mmc1: new high speed SDIO card at address 0001
[ 1.364748] random: fast init done
[ 1.400120] Console: switching to colour frame buffer device 40x30
[ 1.407009] graphics fb0: fb_ili9341 frame buffer, 320x240, 150 KiB video memory, 16 KiB buffer memory, fps=33, spi0.0 at 48 MHz
[ 1.420661] sun4i-codec 1c22c00.codec: ASoC: codec-analog@01c23000 not registered
[ 1.428304] sun4i-codec 1c22c00.codec: Failed to register our card
[ 1.435554] Initializing XFRM netlink socket
[ 1.439995] NET: Registered protocol family 17
[ 1.448384] Registering SWP/SWPB emulation handler
[ 1.464852] Loading compiled-in X.509 certificates
[ 1.480779] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 1.492236] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.498078] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[ 1.512457] random: crng init done
[ 1.519802] hub 3-0:1.0: USB hub found
[ 1.524108] hub 3-0:1.0: 1 port detected
[ 1.530974] debugfs: Directory '1c22c00.codec' with parent 'V3s Audio Codec' already present!
[ 1.539665] sun4i-codec 1c22c00.codec: ASoC: Failed to create component debugfs directory: -17
[ 1.549756] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[ 1.558304] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01T00:05:48 UTC (348)
[ 1.566671] vcc5v0: disabling
[ 1.569728] ALSA device list:
[ 1.572699] #0: V3s Audio Codec
[ 1.615172] EXT4-fs (mmcblk0p2): recovery complete
[ 1.622057] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.630315] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 1.638526] devtmpfs: mounted
[ 1.642696] Freeing unused kernel memory: 1024K
[ 1.647461] Run /sbin/init as init process
[ 1.745748] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Starting syslogd: OK
Starting klogd: OK
Running sysctl: OK
Saving random seed: OK
Starting network: OK
Welcome to Buildroot for the LicheePi Zero
licheepi-zero login: 最近编辑记录 tevada2010 (2022-07-31 22:23:24)
@酷酷酷
解决了吗?我也想问配置好驱动系统就能输出显示到屏上了吗?
楼主有没有遇到过一会就死机了
[ 76.400003] Unable to handle kernel paging request at virtual address c4000000
[ 76.410644] pgd = b12b71ea
[ 76.414521] [c4000000] *pgd=00000000
[ 76.419283] Internal error: Oops: 5 [#1] ARM
[ 76.425835] Modules linked in:
[ 76.430065] CPU: 0 PID: 0 Comm: swapper Not tainted 5.7.1 #12
[ 76.438074] Hardware name: Allwinner suniv Family
[ 76.445061] PC is at sun6i_spi_handler+0x110/0x150
[ 76.452141] LR is at 0xc4000001
遇到驱动问题,真的很搞死人。。。。
