楼主 # 2021-09-09 14:36:34
X3
已发帖子: 85
刚刚收到的全志AIC800开发板,接个串口打印LOG 试一试
全志AIC800 手册: aic800g3_datasheet_v1.4.pdf
A133 Datasheet: A133_documents/A133_Datasheet_V1.1.pdf
A133 User Manual: A133_documents/A133_User_Manual_V1.1.pdf
参考原理图1: SC3904Q-mb-V00-20112600.pdf (分立电源)
参考原理图2: aic800_ref_sip_lp4_32x1_v1_0.pdf (PMU AXP853)
开机log:
[94]HELLO! BOOT0 is starting!
[97]BOOT0 commit : dc54be6
[100]set pll start
[102]periph0 has been enabled
[105]set pll end
[107][pmu]: bus read error
[109][pmu]: bus read error
[117]vaild para:1  select dram para0
[121]board init ok
[123]DRAM BOOT DRIVE INFO: V0.19
[126]the chip id is 0x2400
[129]the chip id is 0x2400
[131]the chip id is 0x2400
[134]the chip id is 0x2400
[137]the chip id is 0x2400
[139]chip id check OK
[141]DRAM_VCC set to 1100 mv
[144]DRAM CLK =792 MHZ
[147]DRAM Type =8 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4)
[155]DRAM SIZE =1024 MBytes, para1 = 30fa, para2 = 4000000, dram_tpr13 = 6063
[167]DRAM simple test OK.
[170]dram size =1024
[172]chipid = 53002400
[174]nsi init ok 2020-4-7
[177]card no is 2
[179]sdcard 2 line count 8
[182][mmc]: mmc driver ver 2020-05-25 09:40
[191][mmc]: Wrong media type 0x0
[195][mmc]: ***Try SD card 2***
[198][mmc]: mmc 2 cmd 8 timeout, err 100
[202][mmc]: mmc 2 cmd 8 err 100
[206][mmc]: mmc 2 send if cond failed
[210][mmc]: mmc 2 cmd 55 timeout, err 100
[214][mmc]: mmc 2 cmd 55 err 100
[217][mmc]: mmc 2 send app cmd failed
[221][mmc]: ***Try MMC card 2***
[246][mmc]: RMCA OK!
[248][mmc]: mmc 2 bias 4
[251][mmc]: MMC 5.0
[253][mmc]: HSSDR52/SDR25 8 bit
[256][mmc]: 50000000 Hz
[259][mmc]: 7456 MB
[261][mmc]: ***SD/MMC 2 init OK!!!***
[315]Loading boot-pkg Succeed(index=0).
[319]Entry_name        = u-boot
[326]Entry_name        = monitor
[329]Entry_name        = scp
[337]set arisc reset to de-assert state
[341]Entry_name        = dtb
[345]tunning data addr:0x4a0003e8
[348]Jump to second Boot.
NOTICE:  BL3-1: v1.0(debug):cc1f5d7
NOTICE:  BL3-1: Built : 10:23:25, 2020-04-08
NOTICE:  BL3-1 commit: 8
ERROR:   Error initializing runtime service tspd_fast
NOTICE:  BL3-1: Preparing for EL3 exit to normal world
NOTICE:  BL3-1: Next image address = 0x4a000000
NOTICE:  BL3-1: Next image spsr = 0x1d3
U-Boot 2018.05-00002-g27dfc9348f (Nov 06 2020 - 08:19:02 +0000) Allwinner Technology
[00.428]CPU:   Allwinner Family
[00.431]Model: sun50iw10
I2C:   ready
[00.682]DRAM:  1 GiB
[00.685]Relocation Offset is: 35f17000
[00.714]secure enable bit: 0
[00.717][ARISC] :arisc initialize
[00.722][ARISC ERROR] :get [allwinner,sunxi-hwspinlock] device node error
CACHE: Misaligned operation at range [7ffa72c0, 7ffa75d8]
[00.733][ARISC] :arisc para ok
[SCP] :sunxi-arisc driver begin startup 2
[SCP] :0x1
[SCP] :arisc version: [9b9b85f5ab606cc93b4061ac38834cab8a191a28rid-]
[SCP] :arisc startup ready
[SCP] :arisc startup notify message feedback
[SCP] :send hard sync feedback message: 0x900200
[SCP] :sunxi-arisc driver v1.10 is starting
[00.763][ARISC] :sunxi-arisc driver startup succeeded
[00.769]pmu_axp81X_probe pmic_bus_read fail
[00.773]pmu_axp858_probe pmic_bus_read fail
[00.777]PMU: no found
[00.779]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=400Mhz
[00.786]init_clocks:finish
[00.788]not need merged sunxi overlay
[00.791]drv_disp_init
request pwm success, pwm8:pwm8:0x300a000.
pwm_request: err:this pwm has been requested!
[00.827]drv_disp_init finish
[00.835]gic: sec monitor mode
[00.838]flash init start
[00.840]workmode = 0,storage type = 2
[00.843][mmc]: mmc driver ver uboot2018:2020-5-25 9:26:00-20201021190
[00.857][mmc]: SUNXI SDMMC Controller Version:0x50300
[00.881][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 8
[00.888]sunxi flash init ok
[00.891]Loading Environment from SUNXI_FLASH... OK
[00.900]no secure os for keybox operation
[00.903]try to burn key
[00.907]out of usb burn from boot: not need burn key
[00.911]boot_gui_init:start
[00.915]set disp.dev2_output_type fail. using defval=0
[00.920]disp 1, clk: pll(490000000),clk(490000000),dclk(70000000) dsi_rate(490000000)
     clk real:pll(492000000),clk(492000000),dclk(70285714) dsi_rate(0)
[00.938]switch device: sel=1, type=1, mode=4, format=0, bits=0, eotf=4, cs=260
[00.944]boot_gui_init:finish
2764856 bytes read in 32 ms (82.4 MiB/s)
[00.999]read item0 copy0
[01.001]Item0 (Map) magic is bad
[01.004]the secure storage item0 copy0 magic is bad
[01.009]Item0 (Map) magic is bad
[01.011]the secure storage item0 copy1 magic is bad
[01.016]Item0 (Ma[01.018]soc ic_ver:0x0, qa_val:0x0, markid:0x53002400 dclk[0-9999]
p) magic is bad
[01.025]the secure storage map is empty
[01.028]no item name device_unlock in the map
[01.032]no item name fastboot_status_flag in the map
[01.037]sunxi secure storage has no flag
[01.043][mmc]: delete mmc-hs400-1_8v from dtb
[01.047][mmc]: delete mmc-hs200-1_8v from dtb
[01.051][mmc]: get max-frequency ok 50000000 Hz
[01.057](weak)update dtb dram start
[01.061]update dtb dram  end
[01.063]update dts
[01.065]no item name snum in the map
** Unrecognized filesystem type **
[01.078]load file(ULI/factory/snum.txt) error.
[01.082]no item name mac in the map
[01.095]load file(ULI/factory/mac.txt) error.
[01.099]no item name wifi_mac in the map
[01.113]load file(ULI/factory/wifi_mac.txt) error.
[01.117]no item name bt_mac in the map
[01.126]LCD open finish
[01.135]load file(ULI/factory/bt_mac.txt) error.
[01.140]no item name specialstr in the map
[01.153]load file(ULI/factory/specialstr.txt) error.
[01.166]update part info
[01.169]key 0
[01.173]misc partition found
[01.196]update bootcmd
[01.197]serial num is: 0c001415a0c0873228d
[03.212]partinfo: name boot, start 0x2a000, size 0x10000
[03.504]read data in addr ret = 1
[03.507]magic = AVB0
[03.509]major version = 1  minor version = 0
[03.513]authentication_data_block_size = 240
[03.517]auxiliary_data_block_size = d40
[03.521]vbmeta_size = 4224
[03.523]algorithm_type = 0
[03.526]flag = 0
[03.527]release tool = avbtool 1.1.0
[03.544]read data in addr ret = 1
[03.547]magic = AVB0
[03.550]major version = 1  minor version = 0
[03.554]authentication_data_block_size = 140
[03.558]auxiliary_data_block_size = 3c0
[03.561]vbmeta_size = 1536
[03.564]algorithm_type = 0
[03.566]flag = 0
[03.568]release tool = avbtool 1.1.0
[03.585]read data in addr ret = 1
[03.588]magic = AVB0
[03.590]major version = 1  minor version = 0
[03.594]authentication_data_block_size = 140
[03.598]auxiliary_data_block_size = 340
[03.602]vbmeta_size = 1408
[03.605]algorithm_type = 0
[03.607]flag = 0
[03.609]release tool = avbtool 1.1.0
[03.612]total_size = 7168
[03.615]alloc block = 17
[03.658]vbmeta hash is 318f52cb3e903d5eacdc4fc4d4f9d9156a94d1d9142b53f3ed945c788a49ddf2[03.668]in boot normal mode,pass normal para to cmdline
[03.674]android.hardware = sun50iw10p1
[03.677]line:56 dtbo_idx= 0
[03.679]dtbo_idx= 64
[03.759]partinfo: name dtbo, start 0x8c2000, size 0x1000
[03.814]Starting kernel ...
[03.816][mmc]: mmc exit start
[03.835][mmc]: mmc 2 exit ok
[    0.000000] Linux version 4.9.170 (keliang.liu@Exdroid019) (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05) ) #11 SMP PREEMPT Thu Aug 5 15:18:26 CST 2021
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] disp reserve base 0x7bf65080 ,size 0x3e8000
[    0.000000] cma: Reserved 8 MiB at 0x000000007f800000
[    0.000000] On node 0 totalpages: 262144
[    0.000000]   DMA zone: 4096 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 262144 pages, LIFO batch:31
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.0
[    0.000000] percpu: Embedded 23 pages/cpu @ffffffc03f704000 s53376 r8192 d32640 u94208
[    0.000000] pcpu-alloc: s53376 r8192 d32640 u94208 alloc=23*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 258048
[    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x05000000 initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p4 init=/init partitions=bootloader@mmcblk0p1:env@mmcblk0p2:boot@mmcblk0p3:super@mmcblk0p4:misc@mmcblk0p5:recovery@mmcblk0p6:cache@mmcblk0p7:vbmeta@mmcblk0p8:vbmeta_system@mmcblk0p9:vbmeta_vendor@mmcblk0p10:metadata@mmcblk0p11:private@mmcblk0p12:frp@mmcblk0p13:empty@mmcblk0p14:dtbo@mmcblk0p15:media_data@mmcblk0p16:UDISK@mmcblk0p17 cma=8M snum=0c001415a0c0873228d mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.vbmeta.avb_version=2.0 androidboot.vbmeta.hash_alg=sha256 androidboot.vbmeta.size=7168 androidboot.vbmeta.digest=318f52cb3e903d5eacdc4fc4d4f9d9156a94d1d9142b53f3ed945c788a49ddf2 androidboot.vbmeta.device_state=locked androidboot.mode=normal androidboot.serialno=0c001415a0c0873228d androidboot.hardware=sun50iw10p1 boot_type=2 androidboot.boot_type=2 androidboot.secure_os_exist=0 androidboot.trustchain=false gpt=1 uboot_message=2018.05-00002-g[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
[    0.000000] Memory: 977432K/1048576K available (11390K kernel code, 2192K rwdata, 4040K rodata, 4416K init, 599K bss, 62952K reserved, 8192K cma-reserved)
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008ba0000   ( 11392 KB)
[    0.000000]     .rodata : 0xffffff8008ba0000 - 0xffffff8008fa0000   (  4096 KB)
[    0.000000]       .init : 0xffffff8008fa0000 - 0xffffff80093f0000   (  4416 KB)
[    0.000000]       .data : 0xffffff80093f0000 - 0xffffff8009614008   (  2193 KB)
[    0.000000]        .bss : 0xffffff8009614008 - 0xffffff80096a9f18   (   600 KB)
[    0.000000]     fixed   : 0xffffffbefe7fb000 - 0xffffffbefec00000   (  4116 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf01000000   (    16 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc040000000   (  1024 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000]  Build-time adjustment of leaf fanout to 64.
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (virt).
[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.008151] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[    0.018200] pid_max: default: 32768 minimum: 301
[    0.023030] Security Framework initialized
[    0.026879] SELinux:  Initializing.
[    0.030473] SELinux:  Starting in permissive mode
[    0.035135] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
[    0.041697] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
[    0.049571] ftrace: allocating 34487 entries in 135 pages
[    0.133140] sched-energy: CPU device node has no sched-energy-costs
[    0.133781] Invalid sched_group_energy for CPU0
[    0.138319] CPU0: update cpu_capacity 1024
[    0.152424] ASID allocator initialised with 32768 entries
[    0.171319] BOOTEVENT:       171.309206: ON
[    0.199393] Detected VIPT I-cache on CPU1
[    0.199444] Invalid sched_group_energy for CPU1
[    0.199447] CPU1: update cpu_capacity 1024
[    0.199449] CPU1: Booted secondary processor [410fd034]
[    0.222760] Detected VIPT I-cache on CPU2
[    0.222788] Invalid sched_group_energy for CPU2
[    0.222790] CPU2: update cpu_capacity 1024
[    0.222793] CPU2: Booted secondary processor [410fd034]
[    0.246173] Detected VIPT I-cache on CPU3
[    0.246199] Invalid sched_group_energy for CPU3
[    0.246202] CPU3: update cpu_capacity 1024
[    0.246205] CPU3: Booted secondary processor [410fd034]
[    0.246287] Brought up 4 CPUs
[    0.296922] SMP: Total of 4 processors activated.
[    0.301614] CPU features: detected feature: 32-bit EL0 Support
[    0.307419] CPU features: detected feature: Kernel page table isolation (KPTI)
[    0.318435] CPU: All CPU(s) started at EL1
[    0.318690] alternatives: patching kernel code
[    0.323300] Invalid sched_group_energy for CPU3
[    0.327617] CPU3: update max cpu_capacity 1024
[    0.332032] Invalid sched_group_energy for Cluster3
[    0.336885] Invalid sched_group_energy for CPU2
[    0.341392] Invalid sched_group_energy for Cluster2
[    0.346245] Invalid sched_group_energy for CPU1
[    0.350752] Invalid sched_group_energy for Cluster1
[    0.355604] Invalid sched_group_energy for CPU0
[    0.360112] Invalid sched_group_energy for Cluster0
[    0.365495] CPU1: update max cpu_capacity 1024
[    0.370110] devtmpfs: initialized
[    0.411511] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.415650] futex hash table entries: 1024 (order: 5, 131072 bytes)
[    0.422448] atomic64_test: passed
[    0.425146] pinctrl core: initialized pinctrl subsystem
[    0.432406] NET: Registered protocol family 16
[    0.436190] dump_class_init,861, success
[    0.452075] cpuidle: using governor menu
[    0.453372] sunxi iommu: irq = 9
[    0.454362] vdso: 2 pages (1 code @ ffffff8008ba8000, 1 data @ ffffff80093f4000)
[    0.460988] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.469145] DMA: preallocated 256 KiB pool for atomic allocations
[    0.476973] sun50iw10p1-r-pinctrl r_pio: initialized sunXi PIO driver
[    0.497370] sun50iw10p1-pinctrl pio: initialized sunXi PIO driver
[    0.501908] iommu: Adding device 1c0e000.ve to group 0
[    0.510198] iommu: Adding device 6000000.disp to group 0
[    0.511091] iommu: Adding device 6480000.g2d to group 0
[    0.519109] iommu: Adding device csi0 to group 0
[    0.520097] iommu: Adding device csi1 to group 0
[    0.525349] iommu: Adding device 2108000.tdm to group 0
[    0.529935] iommu: Adding device 2100000.isp to group 0
[    0.535121] iommu: Adding device 2102000.isp to group 0
[    0.540159] iommu: Adding device 2110000.scaler to group 0
[    0.545620] iommu: Adding device 2110400.scaler to group 0
[    0.551078] iommu: Adding device 2110800.scaler to group 0
[    0.556531] iommu: Adding device 2110c00.scaler to group 0
[    0.600000] pwm module init!
[    0.605054] sunxi-pm debug v3.10
[    0.606600] SCSI subsystem initialized
[    0.607380] usbcore: registered new interface driver usbfs
[    0.611981] usbcore: registered new interface driver hub
[    0.617263] usbcore: registered new device driver usb
[    0.622367] sunxi_i2c_adap_init()2541 - init
[    0.626975] sunxi_i2c_probe()2289 - [i2c0] twi_drv_used = 0
[    0.631963] sunxi_i2c_probe()2293 - [i2c0] twi_pkt_interval = 0
[    0.637870] twi0 supply twi not found, using dummy regulator
[    0.643572] twi_request_gpio()453 - [i2c0] init name: twi0
[    0.649674] sunxi_i2c_probe()2289 - [i2c1] twi_drv_used = 0
[    0.654499] sunxi_i2c_probe()2293 - [i2c1] twi_pkt_interval = 0
[    0.660412] twi1 supply twi not found, using dummy regulator
[    0.666094] twi_request_gpio()453 - [i2c1] init name: twi1
[    0.672328] sunxi_i2c_probe()2289 - [i2c2] twi_drv_used = 0
[    0.677036] sunxi_i2c_probe()2293 - [i2c2] twi_pkt_interval = 0
[    0.682934] twi2 supply twi not found, using dummy regulator
[    0.688625] twi_request_gpio()453 - [i2c2] init name: twi2
[    0.694613] sunxi_i2c_probe()2289 - [i2c3] twi_drv_used = 0
[    0.699564] sunxi_i2c_probe()2293 - [i2c3] twi_pkt_interval = 0
[    0.705465] twi3 supply twi not found, using dummy regulator
[    0.711175] twi_request_gpio()453 - [i2c3] init name: twi3
[    0.717130] media: Linux media interface: v0.10
[    0.721121] Linux video capture interface: v2.00
[    0.726697] ion_parse_dt_heap_common: id 0 type 0 name sys_user align 1000
[    0.732719] ion_parse_dt_heap_common: id 4 type 4 name cma align 1000
[    0.739095] ion_parse_dt_heap_common: id 6 type 6 name secure align 1000
[    0.745898] drm config service not available: FFFFFFFF
[    0.750966] Advanced Linux Sound Architecture Driver Initialized.
[    0.757480] Bluetooth: Core ver 2.22
[    0.760371] NET: Registered protocol family 31
[    0.764732] Bluetooth: HCI device and connection manager initialized
[    0.771072] Bluetooth: HCI socket layer initialized
[    0.775919] Bluetooth: L2CAP socket layer initialized
[    0.780989] Bluetooth: SCO socket layer initialized
[    0.786576] ncs8801s init:*************************
[    0.790806] script_ncs8801s_gpio_init: ncs8801s is not used
[    0.796860] clocksource: Switched to clocksource arch_sys_counter
[    0.878522] VFS: Disk quotas dquot_6.6.0
[    0.878663] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.886439] udc_init,0
[    0.887689] NET: Registered protocol family 2
[    0.907057] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[    0.908533] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
[    0.915116] TCP: Hash tables configured (established 8192 bind 8192)
[    0.921381] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.927224] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.933870] NET: Registered protocol family 1
[    0.938155] Trying to unpack rootfs image as initramfs...
[    0.970882] Freeing initrd memory: 752K
[    0.972443] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.979415] audit: initializing netlink subsys (disabled)
[    0.982275] audit: type=2000 audit(0.809:1): initialized
[    0.988544] workingset: timestamp_bits=45 max_order=18 bucket_order=0
[    1.005716] Registering sdcardfs 0.1
[    1.006293] ntfs: driver 2.1.32 [Flags: R/W].
[    1.008505] fuse init (API version 7.26)
[    1.014127] SELinux:  Registering netfilter hooks
[    1.021080] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    1.023966] io scheduler noop registered
[    1.027907] io scheduler deadline registered
[    1.032358] io scheduler cfq registered (default)
[    1.038427] [DISP]disp_module_init
[    1.041335] [DISP] disp_init,line:2214:
[    1.043821] smooth display screen:1 type:1 mode:4
[    1.122701] [DISP] lcd_clk_config,line:dlk(70000000) dsi_rate(490000000)
[    1.122747]      clk real:pll(492000000),clk(492000000),dclk(70285714) dsi_rate(0)
[    1.124067] [DISP]disp_module_init finish
[    1.126052] uart uart0: get regulator failed
[    1.126066] uart0 supply uart not found, using dummy regulator
[    1.126317] uart0: ttyS0 at MMIO 0x5000000 (irq = 349, base_baud = 1500000) is a SUNXI
[    1.126334] sw_console_setup()1731 - console setup baud 115200 parity n bits 8, flow n
[    1.161164] console [ttyS0] enabled
[    1.170776] bootconsole [earlycon0] disabled
[    1.179882] uart uart1: get regulator failed
[    1.188005] uart1 supply uart not found, using dummy regulator
[    1.194841] uart1: ttyS1 at MMIO 0x5000400 (irq = 350, base_baud = 1500000) is a SUNXI
[    1.204772] misc dump reg init
[    1.209335] G2D: Module initialized.major:246
[    1.215517] [drm] Initialized
[    1.219052] Unable to detect cache hierarchy for CPU 0
[    1.238438] brd: module loaded
[    1.257606] loop: module loaded
[    1.262054] zram: Added device: zram0
[    1.266389] [NAND][NE] Not found valid nand node on dts
[    1.273345] sunxi-wlan soc@03000000:wlan@0: wlan_busnum (1)
[    1.279645] sunxi-wlan soc@03000000:wlan@0: Missing wlan_power.
[    1.286343] sunxi-wlan soc@03000000:wlan@0: wlan_power_name ((null))
[    1.293553] sunxi-wlan soc@03000000:wlan@0: Missing wlan_io_regulator.
[    1.300911] sunxi-wlan soc@03000000:wlan@0: io_regulator_name ((null))
[    1.308323] sunxi-wlan soc@03000000:wlan@0: wlan_regon gpio=357  mul-sel=1  pull=-1  drv_level=-1  data=0
[    1.319127] sunxi-wlan soc@03000000:wlan@0: get gpio chip_en failed
[    1.326204] sunxi-wlan soc@03000000:wlan@0: get gpio power_en failed
[    1.333381] sunxi-wlan soc@03000000:wlan@0: wlan_hostwake gpio=358  mul-sel=1  pull=-1  drv_level=-1  data=0
[    1.344538] sunxi-wlan soc@03000000:wlan@0: clk not config
[    1.350724] sunxi-wlan soc@03000000:wlan@0: dcxo not config
[    1.357037] sunxi-wlan soc@03000000:wlan@0: pinctrl_lookup_state(default) failed! return ffffffffffffffed
[    1.368876] [ADDR_MGT] addr_mgt_probe: success.
[    1.376050] it6612_init-<629>:it6612 init:*************************
[    1.383867] it6612_probe-<497>:it6612 probe:*************************
[    1.395476] twi_stop()514 - [i2c0] STOP can't sendout!
[    1.401252] sunxi_i2c_core_process()1751 - [i2c0] STOP failed!
[    1.407837] sunxi_i2c_do_xfer()1946 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4c)
[    1.417448] sunxi_i2c_do_xfer()1946 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4c)
[    1.427095] sunxi_i2c_do_xfer()1946 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x4c)
[    1.436730] sunxi_i2c_do_xfer()1946 - [i2c3] incomplete xfer (status: 0x20, dev addr: 0x4c)
[    1.446839] libphy: Fixed MDIO Bus: probed
[    1.451464] tun: Universal TUN/TAP device driver, 1.6
[    1.457171] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.465922] gmac-power0: NULL
[    1.469303] gmac-power1: NULL
[    1.472652] gmac-power2: NULL
[    1.476934] PPP generic driver version 2.4.2
[    1.482023] PPP BSD Compression module registered
[    1.487343] PPP Deflate Compression module registered
[    1.493051] PPP MPPE Compression module registered
[    1.498453] NET: Registered protocol family 24
[    1.503470] PPTP driver version 0.8.5
[    1.507972] usbcore: registered new interface driver rtl8150
[    1.514429] usbcore: registered new interface driver r8152
[    1.520688] usbcore: registered new interface driver asix
[    1.526836] usbcore: registered new interface driver ax88179_178a
[    1.533758] usbcore: registered new interface driver cdc_ether
[    1.540418] usbcore: registered new interface driver smsc75xx
[    1.546965] usbcore: registered new interface driver smsc95xx
[    1.553506] usbcore: registered new interface driver net1080
[    1.559938] usbcore: registered new interface driver cdc_subset
[    1.566674] usbcore: registered new interface driver zaurus
[    1.573017] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[    1.581430] usbcore: registered new interface driver cdc_ncm
[    1.587814] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.595525] get ehci0-controller, regulator_io is no nocare
[    1.601813] get ehci0-controller wakeup-source is fail.
[    1.607936] sunxi ehci0-controller don't init wakeup source
[    1.614220] [sunxi-ehci0]: probe, pdev->name: 5101000.ehci0-controller, sunxi_ehci: 0xffffff8009695988, 0x:ffffff80097bc000, irq_no:164
[    1.627936] [sunxi-ehci0]: Not init ehci0
[    1.632585] get ehci1-controller, regulator_io is no nocare
[    1.639064] [sunxi-ehci1]: probe, pdev->name: 5200000.ehci1-controller, sunxi_ehci: 0xffffff8009695d10, 0x:ffffff80097d7000, irq_no:166
[    1.652795] 5200000.ehci1-controller supply drvvbus not found, using dummy regulator
[    1.661648] sunxi-ehci 5200000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.671866] sunxi-ehci 5200000.ehci1-controller: new USB bus registered, assigned bus number 1
[    1.682114] sunxi-ehci 5200000.ehci1-controller: irq 358, io mem 0xffffffc03dab0810
[    1.703547] sunxi-ehci 5200000.ehci1-controller: USB 0.0 started, EHCI 1.00
[    1.712466] hub 1-0:1.0: USB hub found
[    1.716739] hub 1-0:1.0: 1 port detected
[    1.722051] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.729362] get ohci0-controller, regulator_io is no nocare
[    1.735660] get ohci0-controller wakeup-source is fail.
[    1.741759] sunxi ohci0-controller don't init wakeup source
[    1.748166] [sunxi-ohci0]: probe, pdev->name: 5101000.ohci0-controller, sunxi_ohci: 0xffffff8009696420
[    1.758647] [sunxi-ohci0]: Not init ohci0
[    1.763278] get ohci1-controller, regulator_io is no nocare
[    1.769843] [sunxi-ohci1]: probe, pdev->name: 5200000.ohci1-controller, sunxi_ohci: 0xffffff80096967a8
[    1.780347] 5200000.ohci1-controller supply drvvbus not found, using dummy regulator
[    1.789192] sunxi-ohci 5200000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.799017] sunxi-ohci 5200000.ohci1-controller: new USB bus registered, assigned bus number 2
[    1.808791] sunxi-ohci 5200000.ohci1-controller: irq 359, io mem 0xffffffc03dab0c00
[    1.878552] hub 2-0:1.0: USB hub found
[    1.882821] hub 2-0:1.0: 1 port detected
[    1.888348] usbcore: registered new interface driver uas
[    1.894462] usbcore: registered new interface driver usb-storage
[    1.901298] usbcore: registered new interface driver ums-alauda
[    1.908023] usbcore: registered new interface driver ums-cypress
[    1.914849] usbcore: registered new interface driver ums-datafab
[    1.921669] usbcore: registered new interface driver ums_eneub6250
[    1.928688] usbcore: registered new interface driver ums-freecom
[    1.935508] usbcore: registered new interface driver ums-isd200
[    1.942234] usbcore: registered new interface driver ums-jumpshot
[    1.949152] usbcore: registered new interface driver ums-karma
[    1.955784] usbcore: registered new interface driver ums-onetouch
[    1.962721] usbcore: registered new interface driver ums-realtek
[    1.969549] usbcore: registered new interface driver ums-sddr09
[    1.976272] usbcore: registered new interface driver ums-sddr55
[    1.982999] usbcore: registered new interface driver ums-usbat
[    1.989701] usbcore: registered new interface driver usbserial
[    1.996477] usbcore: registered new interface driver option
[    2.002809] usbserial: USB Serial support registered for GSM modem (1-port)
[    2.010917] usb_serial_number:20080411
[    2.015900] sunxikbd_key_init: key0 vol= 210 code= 115
[    2.021704] sunxikbd_key_init: key1 vol= 410 code= 114
[    2.027496] sunxikbd_key_init: key2 vol= 590 code= 139
[    2.033292] sunxikbd_key_init: key3 vol= 750 code= 28
[    2.038985] sunxikbd_key_init: key4 vol= 880 code= 102
[    2.045114] input: sunxi-keyboard as /devices/virtual/input/input0
[    2.054173] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
[    2.061111] sunxi-rtc rtc: RTC enabled
[    2.065641] i2c /dev entries driver
[    2.070579] sunxi cedar version 0.1
[    2.074654] VE: install start!!!
[    2.074654]
[    2.080088] cedar_ve: cedar-ve the get irq is 347
[    2.085789] VE: get debugfs_mpp_root is NULL, please check mpp
[    2.085789]
[    2.094033] VE: sunxi ve debug register driver failed!
[    2.094033]
[    2.103701] device-mapper: uevent: version 1.0.3
[    2.109414] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[    2.119096] device-mapper: verity-avb: AVB error handler initialized with vbmeta device:
[    2.128320] Bluetooth: HCI UART driver ver 2.3
[    2.133336] Bluetooth: HCI UART protocol H4 registered
[    2.139125] Bluetooth: HCI UART protocol LL registered
[    2.144919] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    2.156174] sunxi-mmc sdc2: SD/MMC/SDIO Host Controller Driver(v3.46 2020-6-1 11:33-202006021635)
[    2.166314] sunxi-mmc sdc2: No vmmc regulator found
[    2.171822] sunxi-mmc sdc2: No vqmmc regulator found
[    2.177418] sunxi-mmc sdc2: No vdmmc regulator found
[    2.183017] sunxi-mmc sdc2: No vd33sw regulator found
[    2.188708] sunxi-mmc sdc2: No vd18sw regulator found
[    2.194403] sunxi-mmc sdc2: No vq33sw regulator found
[    2.200094] sunxi-mmc sdc2: No vq18sw regulator found
[    2.206387] sunxi-mmc sdc2: set host busy
[    2.210991] mmc:failed to get gpios
[    2.215201] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.240217] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.266897] sunxi-mmc sdc2: detmode:alway in(non removable)
[    2.266920] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.275286] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.276353] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.287208] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.287276] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.300121] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.344626] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
[    2.354060] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
[    2.363474] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.374356] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
[    2.383796] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
[    2.393207] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
[    2.402643] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
[    2.412374] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.46 2020-6-1 11:33-202006021635)
[    2.422465] sunxi-mmc sdc0: ***ctl-spec-caps*** 8
[    2.427776] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
[    2.438629] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
[    2.449890] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 8 timing MMC-HS(SDR20) dt B
[    2.460871] sunxi-mmc sdc0: No vmmc regulator found
[    2.460875] sunxi-mmc sdc0: No vqmmc regulator found
[    2.460880] sunxi-mmc sdc0: No vdmmc regulator found
[    2.460884] sunxi-mmc sdc0: No vd33sw regulator found
[    2.460888] sunxi-mmc sdc0: No vd18sw regulator found
[    2.460892] sunxi-mmc sdc0: No vq33sw regulator found
[    2.460896] sunxi-mmc sdc0: No vq18sw regulator found
[    2.466681] sunxi-mmc sdc0: set host busy
[    2.466745] sunxi-mmc sdc0: Got CD GPIO
[    2.467140] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.467167] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
[    2.483616] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.500583] sunxi-mmc sdc0: detmode:gpio irq
[    2.500610] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[    2.502210] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.46 2020-6-1 11:33-202006021635)
[    2.502287] sunxi-mmc sdc1: ***ctl-spec-caps*** 8
[    2.502341] sunxi-mmc sdc1: No vmmc regulator found
[    2.502346] sunxi-mmc sdc1: No vqmmc regulator found
[    2.502350] sunxi-mmc sdc1: No vdmmc regulator found
[    2.502354] sunxi-mmc sdc1: No vd33sw regulator found
[    2.502358] sunxi-mmc sdc1: No vd18sw regulator found
[    2.502362] sunxi-mmc sdc1: No vq33sw regulator found
[    2.502366] sunxi-mmc sdc1: No vq18sw regulator found
[    2.502869] sunxi-mmc sdc1: set host busy
[    2.502944] mmc:failed to get gpios
[    2.502969] sunxi-mmc sdc1: min-frequency:400000
[    2.503199] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.503223] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
[    2.517000] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.533617] sunxi-mmc sdc1: detmode:manually by software
[    2.534454] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[    2.534965] hidraw: raw HID events driver (C) Jiri Kosina
[    2.535286] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[    2.535312] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.537808] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.539712] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    2.540540] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    2.541368] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    2.542193] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    2.542231] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[    2.543879] usbcore: registered new interface driver usbhid
[    2.543881] usbhid: USB HID core driver
[    2.544434] ashmem: initialized
[    2.546264] optee: probing for conduit method from DT.
[    2.546271] optee: api uid mismatch
[    2.546694] usbcore: registered new interface driver snd-usb-audio
[    2.548450] u32 classifier
[    2.548453]     Actions configured
[    2.548464] Netfilter messages via NETLINK v0.30.
[    2.548481] nfnl_acct: registering with nfnetlink.
[    2.548796] nf_conntrack version 0.5.0 (8192 buckets, 32768 max)
[    2.549034] ctnetlink v0.93: registering with nfnetlink.
[    2.549626] xt_time: kernel timezone is -0000
[    2.549730] ipip: IPv4 and MPLS over IPv4 tunneling driver
[    2.550499] gre: GRE over IPv4 demultiplexor driver
[    2.550503] ip_gre: GRE over IPv4 tunneling driver
[    2.551719] IPv4 over IPsec tunneling driver
[    2.567675] ip_tables: (C) 2000-2006 Netfilter Core Team
[    2.567939] arp_tables: arp_tables: (C) 2002 David S. Miller
[    2.573110] Initializing XFRM netlink socket
[    2.573144] IPsec XFRM device driver
[    2.574268] NET: Registered protocol family 10
[    2.576111] mip6: Mobile IPv6
[    2.576145] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    2.585456] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    2.586908] NET: Registered protocol family 17
[    2.586941] NET: Registered protocol family 15
[    2.586975] l2tp_core: L2TP core driver, V2.0
[    2.586989] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[    2.589982] Registered cp15_barrier emulation handler
[    2.590001] Registered setend emulation handler
[    2.590946] registered taskstats version 1
[    2.605774] get usb_detect_mode is fail, 22
[    2.607059] sunxi-rtc rtc: setting system clock to 1970-01-01 00:00:05 UTC (5)
[    2.608114] usb1-vbus: disabling
[    2.608119] ALSA device list:
[    2.608122]   No soundcards found.
[    2.917934] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 8 timing MMC-DDR52 dt B
[    2.920431] Freeing unused kernel memory: 4416K
[    2.920525] Kernel init done
[    2.928995] init: init first stage started!
[    2.930355] init: [libfs_mgr]ReadFstabFromDt(): failed to read fstab from dt
[    2.932911] init: Using Android DT directory /proc/device-tree/firmware/android/
[    2.958459] mmc0: new DDR MMC card at address 0001
[    2.968423] mmcblk0: mmc0:0001 8WPD3R 7.28 GiB
[    2.977357] mmcblk0boot0: mmc0:0001 8WPD3R partition 1 4.00 MiB
[    2.987815] mmcblk0boot1: mmc0:0001 8WPD3R partition 2 4.00 MiB
[    2.998267] mmcblk0rpmb: mmc0:0001 8WPD3R partition 3 512 KiB
[    3.007053]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[    3.033971] init: [libfs_mgr]Created logical partition system on device /dev/block/dm-0
[    3.045005] init: [libfs_mgr]Created logical partition vendor on device /dev/block/dm-1
[    3.055862] init: [libfs_mgr]Created logical partition product on device /dev/block/dm-2
[    3.065980] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/by-name/metadata
[    3.075358] init: [libfs_mgr]Filesystem on /dev/block/by-name/metadata was not cleanly shutdown; state flags: 0x1, incompat feature flags: 0x46
[    3.090468] init: [libfs_mgr]check_fs(): mount(/dev/block/by-name/metadata,/metadata,ext4)=-1: No such file or directory
[    3.102913] init: [libfs_mgr]Not running /system/bin/e2fsck on /dev/block/mmcblk0p11 (executable not in system image)
[    3.121076] EXT4-fs (mmcblk0p11): recovery complete
[    3.127172] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: errors=panic
[    3.144387] EXT4-fs (dm-0): mounted filesystem without journal. Opts: barrier=1
[    3.163297] EXT4-fs (dm-1): mounted filesystem without journal. Opts: barrier=1
[    3.175873] EXT4-fs (dm-2): mounted filesystem without journal. Opts: barrier=1
[    3.203165] init: 12 output lines suppressed due to ratelimiting
[    3.218400] random: init: uninitialized urandom read (40 bytes read)
[    3.370630] random: init: uninitialized urandom read (40 bytes read)
[    3.395100] init: Loading SELinux policy
[    3.420120] SELinux: 8192 avtab hash slots, 22205 rules.
[    3.443382] SELinux: 8192 avtab hash slots, 22205 rules.
[    3.449411] SELinux:  1 users, 4 roles, 1369 types, 0 bools, 1 sens, 1024 cats
[    3.457596] SELinux:  97 classes, 22205 rules
[    3.467126] SELinux:  Completing initialization.
[    3.472360] SELinux:  Setting up existing superblocks.
[    3.611267] audit: type=1403 audit(6.503:2): policy loaded auid=4294967295 ses=4294967295
[    3.620814] selinux: SELinux: Loaded policy from /vendor/etc/selinux/precompiled_sepolicy
[    3.620814]
[    3.640703] selinux: SELinux:  Skipping /product/etc/selinux/product_file_contexts:  empty file
[    3.640703]
[    3.652508] selinux: SELinux: Loaded file_contexts
[    3.652508]
[    3.667333] random: init: uninitialized urandom read (40 bytes read)
[    3.733358] init: init second stage started!
[    3.787961] init: Using Android DT directory /proc/device-tree/firmware/android/
[    3.805203] selinux: SELinux:  Skipping /product/etc/selinux/product_file_contexts:  empty file
[    3.805203]
[    3.817106] selinux: SELinux: Loaded file_contexts
[    3.817106]
[    3.824233] init: Running restorecon...
[    3.850150] init: Overriding previous 'ro.' property 'pm.dexopt.shared':'speed' with new value 'quicken'
[    3.864801] selinux: avc:  denied  { set } for  scontext=u:r:vendor_init:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=1
[    3.864801]
[    3.882627] selinux: avc:  denied  { set } for  scontext=u:r:vendor_init:s0 tcontext=u:object_r:dalvik_prop:s0 tclass=property_service permissive=1
[    3.882627]
[    3.899392] init: Overriding previous 'ro.' property 'pm.dexopt.boot':'verify' with new value 'extract'
[    3.910084] init: Overriding previous 'ro.' property 'dalvik.vm.heapsize':'256m' with new value '512m'
[    4.138138] ueventd: ueventd started!
[    4.148831] selinux: SELinux:  Skipping /product/etc/selinux/product_file_contexts:  empty file
[    4.148831]
[    4.160705] selinux: SELinux: Loaded file_contexts
[    4.160705]
[    4.162085] apexd: Bootstrap subcommand detected
[    4.171959] apexd: Scanning /system/apex for embedded keys
[    4.174140] apexd: Scanning /product/apex for embedded keys
[    4.174358] apexd: ... does not exist. Skipping
[    4.174571] apexd: Scanning /system/apex looking for APEX packages.
[    4.174939] apexd: Found /system/apex/com.android.media
[    4.175407] apexd: Skipped when bootstrapping
[    4.175620] apexd: Found /system/apex/com.android.resolv
[    4.176075] apexd: Skipped when bootstrapping
[    4.176288] apexd: Found /system/apex/com.android.runtime.release
[    4.183055] apexd: 9 output lines suppressed due to ratelimiting
[    4.233369] ueventd: Parsing file /ueventd.rc...
[    4.240231] ueventd: Parsing file /vendor/ueventd.rc...
[    4.247299] ueventd: Parsing file /odm/ueventd.rc...
[    4.252990] ueventd: Unable to read config file '/odm/ueventd.rc': open() failed: No such file or directory
[    4.264050] ueventd: Parsing file /ueventd.sun50iw10p1.rc...
[    4.270511] ueventd: Unable to read config file '/ueventd.sun50iw10p1.rc': open() failed: No such file or directory
[    4.552809] ueventd: Coldboot took 0.268 seconds
[    4.595741] Registered swp emulation handler
[    4.674570] init: wait for '/dev/block/by-name/media_data' took 0ms
[    4.691638] FAT-fs (mmcblk0p16): bogus number of reserved sectors
[    4.698657] FAT-fs (mmcblk0p16): Can't find a valid FAT filesystem
[    4.707430] random: fast init done
[    4.749983] logd.auditd: start
[    4.779235] fsck.f2fs: Info: Fix the reported corruption.
[    4.779235]
[    4.787216] fsck.f2fs:       Info: No support kernel version!
[    4.787216]
[    4.795082] fsck.f2fs: Info: Segments per section = 1
[    4.795082]
[    4.802565] fsck.f2fs: Info: Sections per zone = 1
[    4.802565]
[    4.809892] fsck.f2fs: Info: sector size = 512
[    4.809892]
[    4.816651] fsck.f2fs: Info: total sectors = 6049759 (2953 MB)
[    4.816651]
[    4.824925] fsck.f2fs: Info: MKFS version
[    4.824925]
[    4.831180] fsck.f2fs:   "4.9.170 #11 SMP PREEMPT Thu Aug 5 15:18:26 CST 2021"
[    4.831180]
[    4.841122] fsck.f2fs: Info: FSCK version
[    4.841122]
[    4.847446] fsck.f2fs:   from "4.9.170 #11 SMP PREEMPT Thu Aug 5 15:18:26 CST 2021"
[    4.847446]
[    4.980878] F2FS-fs (mmcblk0p17): recover_inode: ino = 1b39, name = 46.proto, inline = b
[    4.990535] F2FS-fs (mmcblk0p17): recover_dentry: ino = 1b39, name = 46.proto, dir = cdb, err = 0
[    5.000564] F2FS-fs (mmcblk0p17): recover_data: ino = 1b39 (i_size: recover) recovered = 0, err = 0
[    5.010763] F2FS-fs (mmcblk0p17): recover_inode: ino = 1b3b, name = drop37.tmp, inline = b
[    5.022535] F2FS-fs (mmcblk0p17): recover_dentry: ino = 1b3b, name = drop37.tmp, dir = 58, err = 0
[    5.032665] F2FS-fs (mmcblk0p17): recover_data: ino = 1b3b (i_size: recover) recovered = 0, err = 0
[    5.042865] F2FS-fs (mmcblk0p17): recover_inode: ino = 1b3c, name = log-files.xml, inline = 1
[    5.053354] F2FS-fs (mmcblk0p17): recover_dentry: ino = 1b3c, name = log-files.xml, dir = 57, err = 0
[    5.063813] F2FS-fs (mmcblk0p17): recover_data: ino = 1b3c (i_size: recover) recovered = 1, err = 0
[    5.074018] F2FS-fs (mmcblk0p17): recover_inode: ino = 1b3e, name = drop37.tmp, inline = b
[    5.083380] F2FS-fs (mmcblk0p17): recover_dentry: ino = 1b3e, name = drop37.tmp, dir = 58, err = 0
[    5.093559] F2FS-fs (mmcblk0p17): recover_data: ino = 1b3e (i_size: recover) recovered = 0, err = 0
[    5.103763] F2FS-fs (mmcblk0p17): recover_inode: ino = 1b3f, name = log-files.xml, inline = 1
[    5.113389] F2FS-fs (mmcblk0p17): recover_dentry: ino = 1b3f, name = log-files.xml, dir = 57, err = 0
[    5.123828] F2FS-fs (mmcblk0p17): recover_data: ino = 1b3f (i_size: recover) recovered = 1, err = 0
[    5.134030] F2FS-fs (mmcblk0p17): recover_inode: ino = 1b40, name = 46_task.xml, inline = b
[    5.144205] F2FS-fs (mmcblk0p17): recover_dentry: ino = 1b40, name = 46_task.xml, dir = 87d, err = 0
[    5.154535] F2FS-fs (mmcblk0p17): recover_data: ino = 1b40 (i_size: recover) recovered = 0, err = 0
[    5.164738] F2FS-fs (mmcblk0p17): recover_inode: ino = 1b44, name = drop37.tmp, inline = b
[    5.174086] F2FS-fs (mmcblk0p17): recover_dentry: ino = 1b44, name = drop37.tmp, dir = 58, err = 0
[    5.184204] F2FS-fs (mmcblk0p17): recover_data: ino = 1b44 (i_size: recover) recovered = 0, err = 0
[    5.194406] F2FS-fs (mmcblk0p17): recover_inode: ino = 1b45, name = log-files.xml, inline = 1
[    5.204036] F2FS-fs (mmcblk0p17): recover_dentry: ino = 1b45, name = log-files.xml, dir = 57, err = 0
[    5.214474] F2FS-fs (mmcblk0p17): recover_data: ino = 1b45 (i_size: recover) recovered = 1, err = 0
[    5.224706] F2FS-fs (mmcblk0p17): recover_inode: ino = 1b47, name = drop37.tmp, inline = b
[    5.234055] F2FS-fs (mmcblk0p17): recover_dentry: ino = 1b47, name = drop37.tmp, dir = 58, err = 0
[    5.244165] F2FS-fs (mmcblk0p17): recover_data: ino = 1b47 (i_size: recover) recovered = 0, err = 0
[    5.254367] F2FS-fs (mmcblk0p17): recover_inode: ino = 1b48, name = log-files.xml, inline = 1
[    5.263987] F2FS-fs (mmcblk0p17): recover_dentry: ino = 1b48, name = log-files.xml, dir = 57, err = 0
[    5.274418] F2FS-fs (mmcblk0p17): recover_data: ino = 1b48 (i_size: recover) recovered = 1, err = 0
[    5.284620] F2FS-fs (mmcblk0p17): recover_inode: ino = 1b4a, name = drop37.tmp, inline = b
[    5.293959] F2FS-fs (mmcblk0p17): recover_dentry: ino = 1b4a, name = drop37.tmp, dir = 58, err = 0
[    5.304074] F2FS-fs (mmcblk0p17): recover_data: ino = 1b4a (i_size: recover) recovered = 0, err = 0
[    5.314276] F2FS-fs (mmcblk0p17): recover_inode: ino = 1b4b, name = log-files.xml, inline = 1
[    5.323898] F2FS-fs (mmcblk0p17): recover_dentry: ino = 1b4b, name = log-files.xml, dir = 57, err = 0
[    5.334335] F2FS-fs (mmcblk0p17): recover_data: ino = 1b4b (i_size: recover) recovered = 1, err = 0
[    5.351490] F2FS-fs (mmcblk0p17): checkpoint: version = 6e8c2f39
[    5.358441] F2FS-fs (mmcblk0p17): Mounted with checkpoint version = 6e8c2f39
[    5.369023] EXT4-fs (mmcblk0p7): Ignoring removed nomblk_io_submit option
[    5.382881] EXT4-fs (mmcblk0p7): recovery complete
[    5.388774] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[    5.516141] EXT4-fs (mmcblk0p7): Ignoring removed nomblk_io_submit option
[    5.525855] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: barrier=1,data=ordered,nomblk_io_submit,noauto_da_alloc,errors=panic
[    5.569367] init: 14 output lines suppressed due to ratelimiting
[    5.583708] zram0: detected capacity change from 0 to 760926208
[    5.627711] mkswap: Swapspace size: 743088k, UUID=b7c67a4f-02ba-4a2c-a078-0c665891b1c2
[    5.637636] Adding 743088k swap on /dev/block/zram0.  Priority:-1 extents:1 across:743088k SS
console:/ $ [    6.012945] usbcore: registered new interface driver uvcvideo
[    6.019484] USB Video Class driver (1.1.1)
[    6.251270] apexd: Marking APEXd as starting
[    6.257255] apexd: Scanning /system/apex for embedded keys
[    6.266316] apexd: Scanning /product/apex for embedded keys
[    6.272787] apexd: ... does not exist. Skipping
[    6.278024] apexd: Populating APEX database from mounts...
[    6.284849] apexd: Failed to walk /product/apex : Can't open /product/apex for reading : No such file or directory
[    6.297545] apexd: Found "/apex/com.android.runtime@1"
[    6.303622] apexd: Found "/apex/com.android.tzdata@290000000"
[    6.310561] apexd: 2 packages restored.
[    6.315174] apexd: Scanning /data/apex/sessions looking for sessions to be activated.
[    6.411385] vdc: Waited 0ms for vold
[    6.518051] type=1400 audit(9.410:3): avc: denied { setattr } for comm="init" name="audio_d" dev="mmcblk0p17" ino=118 scontext=u:r:vendor_init:s0 tcontext=u:object_r:audio_rw_data_file:s0 tclass=dir permissive=1
[    6.744413] logd.daemon: reinit
[    6.879128] treadahead: go to process_files
[    7.144183] file system registered
[    7.196410] using random self ethernet address
[    7.216963] using random host ethernet address
[    7.258698] healthd: No battery devices found
[    7.269546] healthd: battery none chg=
[    7.399923] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 01.00.06
[    7.624607] read descriptors
[    7.630433] read strings
[    7.694204] type=1400 audit(9.410:3): avc: denied { setattr } for comm="init" name="audio_d" dev="mmcblk0p17" ino=118 scontext=u:r:vendor_init:s0 tcontext=u:object_r:audio_rw_data_file:s0 tclass=dir permissive=1
[    7.716467] type=1400 audit(10.576:4): avc: denied { create } for comm="audio@2.0-servi" scontext=u:r:hal_audio_default:s0 tcontext=u:r:hal_audio_default:s0 tclass=tcp_socket permissive=1
[    7.735545] type=1400 audit(10.576:4): avc: denied { create } for comm="audio@2.0-servi" scontext=u:r:hal_audio_default:s0 tcontext=u:r:hal_audio_default:s0 tclass=tcp_socket permissive=1
[    7.754430] type=1400 audit(10.576:5): avc: denied { setopt } for comm="audio@2.0-servi" scontext=u:r:hal_audio_default:s0 tcontext=u:r:hal_audio_default:s0 tclass=tcp_socket permissive=1
[    7.773487] type=1400 audit(10.576:5): avc: denied { setopt } for comm="audio@2.0-servi" scontext=u:r:hal_audio_default:s0 tcontext=u:r:hal_audio_default:s0 tclass=tcp_socket permissive=1
[    7.792400] type=1400 audit(10.576:6): avc: denied { bind } for comm="audio@2.0-servi" scontext=u:r:hal_audio_default:s0 tcontext=u:r:hal_audio_default:s0 tclass=tcp_socket permissive=1
[    7.811260] type=1400 audit(10.576:6): avc: denied { bind } for comm="audio@2.0-servi" scontext=u:r:hal_audio_default:s0 tcontext=u:r:hal_audio_default:s0 tclass=tcp_socket permissive=1
[    9.047565]
[    9.047565] insmod_device_driver
[    9.047565]
[    9.447247] init: Received control message 'interface_start' for 'android.hardware.camera.provider@2.4::ICameraProvider/legacy/0' from pid: 1636 (/system/bin/hwservicemanager)
[    9.468869] init: starting service 'vendor.camera-provider-2-4'...
[    9.482033] init: couldn't write 1968 to /dev/cpuset/camera-daemon/tasks: No such file or directory
[    9.484341] init: Received control message 'interface_start' for 'android.hardware.camera.provider@2.4::ICameraProvider/legacy/0' from pid: 1636 (/system/bin/hwservicemanager)
[   10.880660] init: Service 'treadahead_process' (pid 1793) exited with status 0
[   10.889032] init: Sending signal 9 to service 'treadahead_process' (pid 1793) process group...
[   10.899342] libprocessgroup: Successfully killed process cgroup uid 0 pid 1793 in 0ms
[   11.063476] init: Opened file '/d/mmc0/mmc0:0001/ext_csd', flags 0
[   11.074690] pvrsrvkm: loading out-of-tree module taints kernel.
[   11.183654] pvrsrvkm gpu: set gpu core rate:504000000 freq:504000000-950000uV dfs:0x00000001
[   11.193185] pvrsrvkm gpu: set gpu core rate:504000000 freq:472500000-950000uV dfs:0x00000002
[   11.202727] pvrsrvkm gpu: set gpu core rate:504000000 freq:441000000-950000uV dfs:0x00000004
[   11.212273] pvrsrvkm gpu: set gpu core rate:252000000 freq:252000000-950000uV dfs:0x00000001
[   11.222109] pvrsrvkm gpu: idle:0 dvfs:0 power:0 No mode:1 volt:0 core:504000000
[   11.230481] PVR_K:  1815: Read BVNC 22.102.54.38 from HW device registers
[   11.238168] PVR_K:  1815: RGX Device registered with BVNC 22.102.54.38
[   11.246635] pvrsrvkm gpu: opp[1/4]: (252000000 Hz, 950000 uV)
[   11.253161] pvrsrvkm gpu: opp[2/4]: (441000000 Hz, 950000 uV)
[   11.259664] pvrsrvkm gpu: opp[3/4]: (472500000 Hz, 950000 uV)
[   11.266168] pvrsrvkm gpu: opp[4/4]: (504000000 Hz, 950000 uV)
[   11.273254] pvrsrvkm gpu: Cooling: power ops not registered, not enabling cooling
[   11.287553] [drm] Initialized pvr 1.11.5516664 20170530 on minor 0
[   11.297429] type=1400 audit(11.226:9): avc: denied { write } for comm="radio_monitor" name="uevent" dev="sysfs" ino=17766 scontext=u:r:radio_monitor:s0 tcontext=u:object_r:sysfs_usb:s0 tclass=file permissive=1
[   11.318545] type=1400 audit(14.186:10): avc: denied { read } for comm="pvrsrvctl" name="modules" dev="proc" ino=4026532037 scontext=u:r:pvr:s0 tcontext=u:object_r:proc_modules:s0 tclass=file permissive=1
[   11.320455] init: Service 'pvrsrvinit' (pid 1815) exited with status 0
[   11.320495] init: Sending signal 9 to service 'pvrsrvinit' (pid 1815) process group...
[   11.356477] type=1400 audit(14.186:10): avc: denied { read } for comm="pvrsrvctl" name="modules" dev="proc" ino=4026532037 scontext=u:r:pvr:s0 tcontext=u:object_r:proc_modules:s0 tclass=file permissive=1
[   11.377249] type=1400 audit(14.210:11): avc: denied { open } for comm="pvrsrvctl" path="/proc/modules" dev="proc" ino=4026532037 scontext=u:r:pvr:s0 tcontext=u:object_r:proc_modules:s0 tclass=file permissive=1
[   11.398756] type=1400 audit(14.210:11): avc: denied { open } for comm="pvrsrvctl" path="/proc/modules" dev="proc" ino=4026532037 scontext=u:r:pvr:s0 tcontext=u:object_r:proc_modules:s0 tclass=file permissive=1
[   11.419976] type=1400 audit(14.210:12): avc: denied { getattr } for comm="pvrsrvctl" path="/proc/modules" dev="proc" ino=4026532037 scontext=u:r:pvr:s0 tcontext=u:object_r:proc_modules:s0 tclass=file permissive=1
[   11.442822] PVR_K:  1820: RGX Firmware image 'rgx.fw.22.102.54.38' loaded
[   11.531105] random: crng init done
[   11.534939] random: 7 urandom warning(s) missed due to ratelimiting
[   15.118719] healthd: battery none chg=
[   15.136022] healthd: battery none chg=
[   15.143077] healthd: battery none chg=
[   15.512728] type=1400 audit(14.210:12): avc: denied { getattr } for comm="pvrsrvctl" path="/proc/modules" dev="proc" ino=4026532037 scontext=u:r:pvr:s0 tcontext=u:object_r:proc_modules:s0 tclass=file permissive=1
[   15.535725] type=1400 audit(1628148019.150:13): avc: denied { read } for comm="android.ui" name="state" dev="sysfs" ino=17470 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[   15.557312] type=1400 audit(1628148019.150:13): avc: denied { read } for comm="android.ui" name="state" dev="sysfs" ino=17470 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[   15.587460] init: processing action (sys.sysctl.extra_free_kbytes=*) from (/init.rc:806)
[   15.588917] binder: undelivered transaction 3238, process died.
[   15.592211] init: Service 'vendor.camera-provider-2-4' (pid 1968) exited with status 0
[   15.592271] init: Sending signal 9 to service 'vendor.camera-provider-2-4' (pid 1968) process group...
[   15.595255] libprocessgroup: Successfully killed process cgroup uid 1047 pid 1968 in 0ms
[   15.648771] type=1400 audit(1628148019.156:14): avc: denied { open } for comm="android.ui" path="/sys/devices/platform/ite66121/extcon/hdmi/state" dev="sysfs" ino=17470 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[   16.595374] acc_open
[   16.597964] acc_release
[   16.898462] init: Received control message 'interface_start' for 'android.hardware.wifi@1.0::IWifi/default' from pid: 1636 (/system/bin/hwservicemanager)
[   16.918746] init: starting service 'vendor.wifi_hal_legacy'...
[   16.932312] init: Received control message 'interface_start' for 'android.hardware.wifi@1.0::IWifi/default' from pid: 1636 (/system/bin/hwservicemanager)
[   17.201150] libphy: gmac0: probed
[   17.313934] sunxi-gmac gmac0 eth0: eth0: Type(7) PHY ID 001cc916 at 0 IRQ poll (gmac0-0:00)
[   17.787532] ======== XRADIO WIFI OPEN ========
[   17.807533] [XRADIO] Driver Label:XR_V02.16.84_P2P_HT40_01.40  Aug  5 2021 15:18:13
[   17.823649] [XRADIO] Allocated hw_priv @ ffffffc01a21d7a0
[   17.857781] sunxi-wlan soc@03000000:wlan@0: bus_index: 1
[   17.944695] [XRADIO] Detect SDIO card 1
[   17.944741] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   17.944868] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
[   17.963108] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   17.985035] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   17.987594] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.034429] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[   18.107520] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[   18.123847] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[   18.142165] mmc2: new high speed SDIO card at address 0001
[   18.162442] [SBUS] XRadio Device:sdio clk=50000000
[   18.185826] [XRADIO] XRADIO_HW_REV 1.0 detected.
[   18.227511] [XRADIO] xradio_update_dpllctrl: DPLL_CTRL Sync=0x01400000.
[   18.364005] [XRADIO] Bootloader complete
[   18.604222] [XRADIO] Firmware completed.
[   18.614345] [WSM] Firmware Label:XR_C09.08.52.64_DBG_02.100 2GHZ HT40 Jan  3 2020 13:14:37
[   18.634046] [XRADIO] Firmware Startup Done.
[   18.639208] [XRADIO_WRN] enable Multi-Rx!
[   18.653164] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[   18.744291] init: Received control message 'interface_start' for 'android.hardware.wifi.supplicant@1.0::ISupplicant/default' from pid: 1636 (/system/bin/hwservicemanager)
[   18.799602] init: starting service 'wpa_supplicant'...
[   18.836102] init: Created socket '/dev/socket/wpa_wlan0', mode 660, user 1010, group 1010
[   19.011470] capability: warning: `wpa_supplicant' uses 32-bit capabilities (legacy support in use)
[   19.164709] ieee80211_do_open: vif_type=2, p2p=0, ch=3, addr=94:17:db:1b:c0:08
[   19.180766] [STA] !!!xradio_vif_setup: id=0, type=2, p2p=0, addr=94:17:db:1b:c0:08
[   19.201771] [AP_WRN] BSS_CHANGED_ASSOC but driver is unjoined.
[   19.228723] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   19.620774] ieee80211_do_open: vif_type=10, p2p=0, ch=3, addr=94:17:db:1b:c0:09
[   19.630571] [STA] !!!xradio_vif_setup: id=2, type=10, p2p=0, addr=94:17:db:1b:c0:09
[   22.321365] init: processing action (sys.boot_completed=1) from (/init.rc:800)
[   22.337111] init: processing action (sys.boot_completed=1) from (/vendor/etc/init/hw/init.device.rc:44)
[   22.338745] sdcardfs version 2.0
[   22.338750] sdcardfs: dev_name -> /data/media
[   22.338754] sdcardfs: options -> fsuid=1023,fsgid=1023,multiuser,derive_gid,default_normal,unshared_obb,mask=6,userid=0,gid=1015
[   22.338760] sdcardfs: mnt -> ffffffc0169e8c60
[   22.338853] sdcardfs: mounted on top of /data/media type f2fs
[   22.342429] Remount options were mask=23,gid=9997 for vfsmnt ffffffc00ca5e720.
[   22.342445] sdcardfs : options - debug:1
[   22.342448] sdcardfs : options - gid:9997
[   22.342451] sdcardfs : options - mask:23
[   22.346855] Remount options were mask=7,gid=9997 for vfsmnt ffffffc00ca5f6e0.
[   22.346988] sdcardfs : options - debug:1
[   22.346993] sdcardfs : options - gid:9997
[   22.346995] sdcardfs : options - mask:7
[   22.348066] Remount options were mask=7,gid=9997 for vfsmnt ffffffc00ca60720.
[   22.348078] sdcardfs : options - debug:1
[   22.348082] sdcardfs : options - gid:9997
[   22.348085] sdcardfs : options - mask:7
[   22.519998] get ctp_power is fail, -22
[   22.539240] sunxi_ctp_startup: ctp_power_io is invalid.
[   22.545797] get ctp_gesture_wakeup fail, no gesture wakeup
[   22.566117] 1-005d supply ctp not found, using dummy regulator
[   22.739588] input: gt9xxnew_ts as /devices/virtual/input/input1
[   22.747633] <<-GTP-ERROR->> File PID != Ic PID, update aborted!
[   22.752218] init: Command 'insmod /vendor/modules/gt9xxnew_ts.ko' action=sys.boot_completed=1 (/vendor/etc/init/hw/init.device.rc:46) took 280ms and succeeded
[   22.795783] <<-GTP-ERROR->> [update_proc]Check *.bin file fail.
[   22.810689] init: Command 'insmod /vendor/modules/gt9xxnewdup_ts.ko' action=sys.boot_completed=1 (/vendor/etc/init/hw/init.device.rc:47) took 57ms and failed: finit_module for "/vendor/modules/gt9xxnewdup_ts.ko" failed: Operation not permitted
[   22.852183] selinux: SELinux: Skipping restorecon on directory(/data/system_ce/0)
[   22.852183]
[   22.870931] init: processing action (sys.boot_completed=1) from (/system/etc/init/aw_thermal.rc:10)
[   22.887257] init: starting service 'aw_thermal'...
[   22.948185] init: Command 'start aw_thermal' action=sys.boot_completed=1 (/system/etc/init/aw_thermal.rc:11) took 65ms and succeeded
[   23.010700] init: Async property child exited with status 0
[   23.027486] init: processing action (sys.boot_completed=1 && sys.logbootcomplete=1) from (/system/etc/init/bootstat.rc:78)
[   23.413615] [DISP] de_enhance_set_mode,line:474:
[   23.420573] para excess! mode = 0, enhance_mode = 0, format=255
[   23.433630] [DISP] de_enhance_set_mode,line:474:
[   23.438699] para excess! mode = 0, enhance_mode = 0, format=255
[   23.446241] [DISP] de_enhance_set_mode,line:474:
[   23.451289] para excess! mode = 0, enhance_mode = 0, format=255
[   23.458288] [DISP] de_enhance_set_mode,line:474:
[   23.463786] para excess! mode = 0, enhance_mode = 1, format=255
[   23.470716] [DISP] de_enhance_set_mode,line:474:
[   23.476049] para excess! mode = 0, enhance_mode = 0, format=255
[   23.483492] [DISP] de_enhance_set_mode,line:474:
[   23.488825] para excess! mode = 0, enhance_mode = 0, format=255
[   23.495781] [DISP] de_enhance_set_mode,line:474:
[   23.501095] para excess! mode = 0, enhance_mode = 1, format=255
[   23.508037] [DISP] de_enhance_set_mode,line:474:
[   23.513330] para excess! mode = 0, enhance_mode = 0, format=255
[   23.520781] [DISP] de_enhance_set_mode,line:474:
[   23.526116] para excess! mode = 0, enhance_mode = 0, format=255
[   23.533102] [DISP] de_enhance_set_mode,line:474:
[   23.538644] para excess! mode = 0, enhance_mode = 1, format=255
[   23.545640] [DISP] de_enhance_set_mode,line:474:
[   23.550909] para excess! mode = 0, enhance_mode = 0, format=255
[   23.573475] logd: logdr: UID=1036 GID=1023 PID=1890 b tail=0 logMask=19 pid=0 start=1628148019759408000ns timeout=0ns
[   25.334748] BOOTEVENT:     25334.731777: OFF
[   27.229633] apexd: Can't open /product/apex for reading : No such file or directory
[   27.851087] init: Received control message 'start' for 'gsid' from pid: 2014 (system_server)
[   27.861864] init: starting service 'gsid'...
[   27.940771] init: Received control message 'stop' for 'gsid' from pid: 2014 (system_server)
[   27.950691] init: Sending signal 9 to service 'gsid' (pid 3418) process group...
[   27.965229] libprocessgroup: Successfully killed process cgroup uid 0 pid 3418 in 5ms
[   27.979021] init: Service 'gsid' (pid 3418) received signal 9
[   28.008625] type=1400 audit(1628148019.156:15): avc: denied { getattr } for comm="android.ui" path="/sys/devices/platform/ite66121/extcon/hdmi/state" dev="sysfs" ino=17470 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[   28.036386] type=1400 audit(1628148031.653:16): avc: granted { read } for comm="main" name="u:object_r:net_dns_prop:s0" dev="tmpfs" ino=9680 scontext=u:r:untrusted_app_25:s0:c512,c768 tcontext=u:object_r:net_dns_prop:s0 tclass=file app=com.android.email
[   33.185142] type=1400 audit(1628148031.653:16): avc: granted { read } for comm="main" name="u:object_r:net_dns_prop:s0" dev="tmpfs" ino=9680 scontext=u:r:untrusted_app_25:s0:c512,c768 tcontext=u:object_r:net_dns_prop:s0 tclass=file app=com.android.email
[   33.210512] type=1400 audit(1628148036.830:17): avc: denied { dac_override } for comm="irqbalance" capability=1 scontext=u:r:shell:s0 tcontext=u:r:shell:s0 tclass=capability permissive=1
console:/ $
console:/ $
console:/ $
出厂固件是andorid
楼主 #1 2021-09-09 14:45:33
X3
已发帖子: 85
Re: 刚刚收到的全志AIC800开发板,接个串口打印LOG 试一试
楼主 #2 2021-09-09 14:46:07
X3
已发帖子: 85
[  113.670028] pwm device hdl is NULL
[  113.911255] sun50iw10p1-pinctrl pio: expect_func as:lvds3, but muxsel(3) is func:lvds2
[  113.920206] sun50iw10p1-pinctrl pio: expect_func as:lvds3, but muxsel(3) is func:lvds2
[  113.929135] sun50iw10p1-pinctrl pio: expect_func as:lvds3, but muxsel(3) is func:lvds2
[  113.938061] sun50iw10p1-pinctrl pio: expect_func as:lvds3, but muxsel(3) is func:lvds2
[  113.946986] sun50iw10p1-pinctrl pio: expect_func as:lvds3, but muxsel(3) is func:lvds2
[  113.955912] sun50iw10p1-pinctrl pio: expect_func as:lvds3, but muxsel(3) is func:lvds2
[  113.964838] sun50iw10p1-pinctrl pio: expect_func as:lvds3, but muxsel(3) is func:lvds2
[  113.973763] sun50iw10p1-pinctrl pio: expect_func as:lvds3, but muxsel(3) is func:lvds2
[  113.982689] sun50iw10p1-pinctrl pio: expect_func as:lvds3, but muxsel(3) is func:lvds2
[  113.991615] sun50iw10p1-pinctrl pio: expect_func as:lvds3, but muxsel(3) is func:lvds2
[  114.524214] sunxi_ohci_hcd_shutdown, ohci0-controller is disable, need not shutdown
[  114.532867] sunxi_ehci_hcd_shutdown, ehci0-controller is disable, need not shutdown
[  114.541722] reboot: Restarting system with command 'efex'
[4037]HELLO! BOOT0 is starting!
[4040]BOOT0 commit : dc54be6
[4043]set pll start
[4045]periph0 has been enabled
[4049]set pll end
[4051][pmu]: bus read error
[4054][pmu]: bus read error
[4061]vaild para:1  select dram para0
[4065]board init ok
[4067]rtc[3] value = 0xa102
[4070]DRAM BOOT DRIVE INFO: V0.19
[4073]the chip id is 0x2400
[4076]the chip id is 0x2400
[4079]the chip id is 0x2400
[4081]the chip id is 0x2400
[4084]the chip id is 0x2400
[4087]chip id check OK
[4089]DRAM_VCC set to 1100 mv
[4092]DRAM CLK =792 MHZ
[4095]DRAM Type =8 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4)
[4103]DRAM SIZE =1024 MBytes, para1 = 30fa, para2 = 4000000, dram_tpr13 = 6063
[4115]DRAM simple test OK.
[4118]dram size =1024
[4120]chipid = 53002400
[4122]nsi init ok 2020-4-7
[4126]card no is 2
[4128]sdcard 2 line count 8
[4130][mmc]: mmc driver ver 2020-05-25 09:40
[4140][mmc]: Wrong media type 0x0
[4143][mmc]: ***Try SD card 2***
[4148][mmc]: mmc 2 cmd 8 timeout, err 100
[4152][mmc]: mmc 2 cmd 8 err 100
[4155][mmc]: mmc 2 send if cond failed
[4159][mmc]: mmc 2 cmd 55 timeout, err 100
[4164][mmc]: mmc 2 cmd 55 err 100
[4167][mmc]: mmc 2 send app cmd failed
[4171][mmc]: ***Try MMC card 2***
[4195][mmc]: RMCA OK!
[4198][mmc]: mmc 2 bias 4
[4201][mmc]: MMC 5.0
[4203][mmc]: HSSDR52/SDR25 8 bit
[4206][mmc]: 50000000 Hz
[4209][mmc]: 7456 MB
[4211][mmc]: ***SD/MMC 2 init OK!!!***
[4265]Loading boot-pkg Succeed(index=0).
[4269]Entry_name        = u-boot
[4276]Entry_name        = monitor
[4280]Entry_name        = scp
[4288]set arisc reset to de-assert state
[4292]Entry_name        = dtb
[4296]tunning data addr:0x4a0003e8
[4299]Jump to second Boot.
NOTICE:  BL3-1: v1.0(debug):cc1f5d7
NOTICE:  BL3-1: Built : 10:23:25, 2020-04-08
NOTICE:  BL3-1 commit: 8
ERROR:   Error initializing runtime service tspd_fast
NOTICE:  BL3-1: Preparing for EL3 exit to normal world
NOTICE:  BL3-1: Next image address = 0x4a000000
NOTICE:  BL3-1: Next image spsr = 0x1d3
U-Boot 2018.05-00002-g27dfc9348f (Nov 06 2020 - 08:19:02 +0000) Allwinner Technology
[04.377]CPU:   Allwinner Family
[04.380]Model: sun50iw10
I2C:   ready
[04.625]DRAM:  1 GiB
[04.628]Relocation Offset is: 35f17000
[04.657]secure enable bit: 0
[04.660][ARISC] :arisc initialize
[04.665][ARISC ERROR] :get [allwinner,sunxi-hwspinlock] device node error
CACHE: Misaligned operation at range [7ffa72c0, 7ffa75d8]
[04.676][ARISC] :arisc para ok
[SCP] :sunxi-arisc driver begin startup 2
[SCP] :0x1
[SCP] :arisc version: [9b9b85f5ab606cc93b4061ac38834cab8a191a28rid-]
[SCP] :arisc startup ready
[SCP] :arisc startup notify message feedback
[SCP] :send hard sync feedback message: 0x900200
[SCP] :sunxi-arisc driver v1.10 is starting
[04.706][ARISC] :sunxi-arisc driver startup succeeded
[04.712]pmu_axp81X_probe pmic_bus_read fail
[04.716]pmu_axp858_probe pmic_bus_read fail
[04.720]PMU: no found
[04.722]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=400Mhz
[04.729]init_clocks:finish
[04.731]not need merged sunxi overlay
[04.734]drv_disp_init
request pwm success, pwm8:pwm8:0x300a000.
pwm_request: err:this pwm has been requested!
[04.770]drv_disp_init finish
[04.778]gic: sec monitor mode
[04.780]flash init start
[04.783]workmode = 0,storage type = 2
[04.786][mmc]: mmc driver ver uboot2018:2020-5-25 9:26:00-20201021190
[04.800][mmc]: SUNXI SDMMC Controller Version:0x50300
[04.824][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 8
[04.831]sunxi flash init ok
[04.834]Loading Environment from SUNXI_FLASH... OK
[04.843]no secure os for keybox operation
[04.846]try to burn key
[04.849]out of usb burn from boot: not need burn key
[04.854]boot_gui_init:start
[04.858]set disp.dev2_output_type fail. using defval=0
[04.863]disp 1, clk: pll(490000000),clk(490000000),dclk(70000000) dsi_rate(490000000)
[04.880]switch device: sel=1, type=1, mode=4, format=0, bits=0, eotf=4, cs=260
[04.887]boot_gui_init:finish
2764856 bytes read in 32 ms (82.4 MiB/s)
[04.941]read item0 copy0
[04.944]Item0 (Map) magic is bad
[04.947]the secure storage item0 copy0 magic is bad
[04.951]Item0 (Map) magic is bad
[04.954]the secure storage item0 copy1 magic is bad
[04.959]Item0 (Map)[04.960]soc ic_ver:0x0, qa_val:0x0, markid:0x53002400 dclk[0-9999]
 magic is bad
[04.968]the secure storage map is empty
[04.971]no item name device_unlock in the map
[04.975]no item name fastboot_status_flag in the map
[04.980]sunxi secure storage has no flag
[04.985][mmc]: delete mmc-hs400-1_8v from dtb
[04.989][mmc]: delete mmc-hs200-1_8v from dtb
[04.993][mmc]: get max-frequency ok 50000000 Hz
[04.999](weak)update dtb dram start
[05.003]update dtb dram  end
[05.006]update dts
[05.008]no item name snum in the map
** Unrecognized filesystem type **
[05.021]load file(ULI/factory/snum.txt) error.
[05.025]no item name mac in the map
[05.038]load file(ULI/factory/mac.txt) error.
[05.042]no item name wifi_mac in the map
[05.055]load file(ULI/factory/wifi_mac.txt) error.
[05.060]no item name bt_mac in the map
[05.069]LCD open finish
[05.078]load file(ULI/factory/bt_mac.txt) error.
[05.082]no item name specialstr in the map
[05.096]load file(ULI/factory/specialstr.txt) error.
[05.109]update part info
[05.112]key 0
[05.115]misc partition found
[05.137]bootmode[2]:0x5a
[05.139][mmc]: mmc exit start
[05.158][mmc]: mmc 2 exit ok
[4043]set pll start
[4049]set pll end
[4065]board init ok
[4067]rtc[2] value = 0x5aa5a55a
[4070]rtc[3] value = 0xb00f
[4073]eraly jump fel
刷机失败???
楼主 #3 2021-09-09 19:15:03
X3
已发帖子: 85
搞定
#4 2021-09-09 19:41:40
qianniao29
已发帖子: 29
AIC800又复活了?
#5 2021-09-12 09:51:20
xintian
AIC800开发板哪里买的?现在是索智在推?
#6 2021-09-12 10:38:43
夜阑卧听
已发帖子: 23
在哪里能买到开发板呢?
楼主 #7 2021-09-12 10:53:42
X3
已发帖子: 85
朋友送的,我也不知道他哪里弄来的。
#8 2021-09-12 20:15:19
arychen
已发帖子: 275
我也有3片  去年推的时候记得代理那买的,后来代码一直没跟上,就放弃直接上A133了。
#9 2021-09-26 14:23:09
kangxuebin
在哪里能买到开发板呢?
#10 2021-09-26 17:37:42
loveme758
太多了,不知道用哪个好了!
#11 2022-02-06 12:44:32
tigger
已发帖子: 172
https://www.panelook.cn/TV101WUM-NW1-BSD-detail_cn_87247.html
https://www.panelook.cn/upload/product/49718/201909219086.pdf
请问 SC3904Q-mb-V00-20112600.pdf 原理图里面的 CN9 可以接这个屏吗?
楼主 #12 2022-02-06 17:54:28
X3
已发帖子: 85
① ② 这个地方是对应 /dev/fb0  /dev/fb1 的
左边这个配置,lcd0,lcd1 对应 /dev/fb1,/dev/fb0
右边这个配置,lcd0,lcd1 对应 /dev/fb0,/dev/fb1
但是改成这样之后,
			dev0_screen_id           = <0>;
			dev1_screen_id           = <1>;
就变这样了:
root@TinaLinux:/# cat /sys/class/disp/disp/attr/disp
0
#13 2022-02-06 23:12:16
sniper33
已发帖子: 19
配置挺好的,很少听说这个型号啊
楼主 #14 2022-02-07 22:10:25
X3
已发帖子: 85
配置:
./build.sh config
编译uboot:
./build.sh brandy
或:
./build.sh bootloader
编译 dts:
./build.sh dts
编译 Linux:
./build.sh kernel
楼主 #15 2022-02-07 22:14:57
X3
已发帖子: 85
build/mkcommon.sh 添加:
rootfs)
                ACTION="mkrootfs;";
                module=rootfs;
                break;
之后:
#!/bin/bash
# scripts/mkcommon.sh
# (c) Copyright 2013
# Allwinner Technology Co., Ltd. <www.allwinnertech.com>
# James Deng <csjamesdeng@allwinnertech.com>
# This program is free software; you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
export LC_ALL=C
BR_SCRIPTS_DIR=$(cd $(dirname $0) && pwd)
BUILD_CONFIG=$BR_SCRIPTS_DIR/../.buildconfig
SKIP_BR=0
# source shflags
source ${BR_SCRIPTS_DIR}/shflags
if [ -f ${BUILD_CONFIG} ]; then
	. ${BUILD_CONFIG}
	LICHEE_TOP_DIR_NEW=$(cd $BR_SCRIPTS_DIR/.. && pwd)
	if [ "$LICHEE_TOP_DIR_NEW" != "$LICHEE_TOP_DIR" ]; then
		sed -i "s|$LICHEE_TOP_DIR|$LICHEE_TOP_DIR_NEW|g" ${BUILD_CONFIG}
		. ${BUILD_CONFIG}
	fi
fi
# define option, format:
#   'long option' 'default value' 'help message' 'short option'
# WARN: Don't modify default value, because we will check it later
DEFINE_string  'ic'       ''          'ic to build, e.g. V316'             'i'
DEFINE_string  'kernel'   ''          'Kernel to build, e.g. 3.3'          'k'
DEFINE_string  'board'    ''          'Board to build, e.g. evb'           'b'
DEFINE_string  'flash'    'default'   'flash to build, e.g. nor'           'n'
DEFINE_string  'os'       ''          'os to build, e.g. android bsp'      'o'
DEFINE_string  'module'   'all'       'Module to build, e.g. buildroot, kernel, uboot, clean' 'm'
DEFINE_boolean 'config'   false       'Config compile platfom'             'c'
DEFINE_boolean 'force'    false       'Force to build, clean some old files. ex, rootfs/' 'f'
FLAGS_HELP="Top level build script for lichee
Examples:
  1. Build lichee, it maybe config platform options, if
     you first use it. And it will pack firmware use default
     argument.
      $ ./build.sh
  2. Configurate platform option
      $ ./build.sh config
  3. Autoconfigurete
      $ ./build.sh autoconfig -i V316 -o bsp -n nor -b perf1
  4. Pack linux, dragonboard image
      $ ./build.sh pack[_<option>] e.g. debug, dump, prvt, verity
  5. Build lichee using command argument
      $ ./build.sh -i <ic> e.g. V316
  6. Build module using command argument
      $ ./build.sh -m <module>
  7. Build special kernel
      $ ./build.sh -k <kernel directly>
  8. Build forcely to clean rootfs dir
      $ ./build.sh -f
# Include base command!
source ${BR_SCRIPTS_DIR}/mkcmd.sh
# parse the command-line
FLAGS "$@" || exit $?
eval set -- "${FLAGS_ARGV}"
ic=${FLAGS_ic}
platform=${FLAGS_os}
kernel=${FLAGS_kernel}
board=${FLAGS_board}
flash=${FLAGS_flash}
module=${FLAGS_module}
config=${FLAGS_config}
force=""
################ Preset an empty command #################
function nfunc(){
	echo "Begin Action"
ACTION=":;"
################ Parse other arguments ###################
while [ $# -gt 0 ]; do
	case "$1" in
	config*)
		opt=${1##*_};
		if [ "${opt}" == "all" ]; then
			export CONFIG_ALL=${FLAGS_TRUE};
			export CONFIG_ALL=${FLAGS_FALSE};
		fi
		FLAGS_config=${FLAGS_TRUE};
		break;
	autoconfig)
		ACTION="mk_autoconfig;"
		break;
	saveconfig)
		if  [ -n "$LICHEE_KERN_DEFCONF_ABSOLUTE" ] && \
			[ -n "$LICHEE_KERN_DIR" ] && \
			[ -n "$LICHEE_ARCH" ]; then
			printf "\033[47;30mSave defconfig to $LICHEE_KERN_DEFCONF_ABSOLUTE...\033[0m\n"
			(cd $LICHEE_KERN_DIR && make ARCH=$LICHEE_ARCH savedefconfig && mv defconfig $LICHEE_KERN_DEFCONF_ABSOLUTE)
			if [ $? -ne 0 ]; then
				printf "\033[47;31mSave defconfig fail!!!\033[0m\n"
				exit 1
			fi
			printf "\033[47;30mComplete~\033[0m\n"
			exit 0
		fi
	gen*)
		opt=${1##*_};
		if [ "${opt}" == "config" ]; then
			cd kernel/${LICHEE_KERN_VER}/
			printf "\033[47;41mPrepare to use script to generate the android defconfig.\033[0m\n"
			ARCH=${LICHEE_ARCH} ./scripts/kconfig/merge_config.sh \
				 arch/${LICHEE_ARCH}/configs/${LICHEE_CHIP}smp_defconfig \
				 kernel/configs/android-base.config  \
				 kernel/configs/android-recommended.config  \
				 kernel/configs/sunxi-recommended.config
			if [ -f .config ]; then
				printf "\033[47;41mComplete the build config,save to ${LICHEE_KERN_VER}/.config !!!\033[0m\n"
				cp .config arch/${LICHEE_ARCH}/configs/${LICHEE_CHIP}smp_android_defconfig
			fi
			cd ..
			exit 0
			echo "Do not support this command!!"
			exit 1
		fi
		break;
	pack*)
		optlist=$(echo ${1#pack} | sed 's/_/ /g')
		mode=""
		for opt in $optlist; do
			case "$opt" in
				debug)
					mode="$mode -d card0"
				dump)
					mode="$mode -m dump"
				prvt)
					mode="$mode -f prvt"
				secure)
					mode="$mode -v secure"
				prev)
					mode="$mode -s prev_refurbish"
				crash)
					mode="$mode -m crashdump"
				vsp)
					mode="$mode -t vsp"
				raw)
					mode="$mode -w programmer"
				verity)
					mode="$mode --verity"
				signfel)
					mode="$mode --signfel"
					mk_error "Invalid pack option $opt"
					exit 1
			esac
		done
		######### Don't build other module, if pack firmware ########
		ACTION="mkpack ${mode};";
		module="";
		break;
	buildroot)
		ACTION="mkbr;";
		module=buildroot;
		break;
        rootfs)
                ACTION="mkrootfs;";
                module=rootfs;
                break;
	ramfs)
		ACTION="mkramfs;";
		module=ramfs;
		break;
	clean|distclean)
		ACTION="mk${1};";
		module="";
		break;
	bootloader)
		ACTION="mk${1};";
		module="bootloader";
		break;
	brandy)
		ACTION="mk${1};";
		module="brandy";
		break;
	kernel)
		ACTION="mkkernel;";
		module="kernel";
		break;
    dts)
        ACTION="mkdts;";
		module="";
        break
	esac;
	shift;
done
# if not .buildconfig or FLAGS_config equal FLAGS_TRUE, then mksetup.sh & exit
if [ ! -f ${BUILD_CONFIG}  -o  ${FLAGS_config} -eq ${FLAGS_TRUE} ]; then
	# If we do config, it must be clean the old env var.
	clean_old_env_var
	if [ "x$1" == "xautoconfig" ]; then
		tmp=${flash}
		mk_autoconfig ${ic} ${platform} ${board} ${tmp} ${kernel}
		exit 0;
	fi
	. ${BR_SCRIPTS_DIR}/mksetup.sh
	if [ ${FLAGS_config} -eq ${FLAGS_TRUE} ]; then
		exit 0;
	fi
fi
if [ ${FLAGS_force} -eq ${FLAGS_TRUE} ]; then
	force="f";
fi
if [ "x${LICHEE_LINUX_DEV}" = "xlongan" -o "x${LICHEE_LINUX_DEV}" = "xtinyos" ] ; then
	SKIP_BR=0;
	SKIP_BR=1;
fi
if [ -n "${platform}" -o -n "${ic}" \
	-o -n "${kernel}" -o -n "${board}" ]; then \
	if [ "${platform}" = "${ic}" ] ; then \
		platform="linux";
	fi
	if ! init_ic ${ic} || \
		! init_platforms ${platform} ; then \
		mk_error "Invalid platform '${FLAGS_platform}'";
		exit 1;
	fi
	if ! init_kern_ver ${kernel} ; then \
		mk_error "Invalid kernel '${FLAGS_kernel}'";
		exit 1;
	fi
	if [ ${FLAGS_board} ] && \
		! init_boards ${LICHEE_CHIP} ${board} ; then \
		mk_error "Invalid board '${FLAGS_board}'";
		exit 1;
	fi
fi
# mkdir output dir
check_output_dir
############### Append ',' end character #################
module="${module},"
while [ -n "${module}" ]; do
	act=${module%%,*};
	case ${act} in
		all*)
			ACTION="mklichee;";
			module="";
			break;
		uboot)
			ACTION="${ACTION}mkboot;";
		clean)
			ACTION="mkclean;";
			module="";
		distclean)
			ACTION="distclean;";
			module="";
	esac
	module=${module#*,};
done
# Execute the action list.
echo "ACTION List: ${ACTION}========"
action_exit_status=$?
while [ -n "${ACTION}" ]; do
	act=${ACTION%%;*};
	echo "Execute command: ${act} ${force}"
	${act} ${force}
	ACTION=${ACTION#*;};
done
exit ${action_exit_status}
编译根文件系统:
./build.sh rootfs
编译 Linux:
./build.sh kernel
修改文件 build/mkcmd.sh 函数的 mkrootfs( ),添加 rootfs_overlay/ 文件夹,这样每次执行 ./build.sh rootfs 都会把改文件夹的内容复制进去。
                        dragonboard)
                                prepare_dragonboard_toolchain
                                if [ -d ${LICHEE_DRAGONBAORD_DIR} ]; then
                                        echo "Regenerating dragonboard Rootfs..."
                                        cd ${LICHEE_DRAGONBAORD_DIR}; \
                                                if [ ! -d "./rootfs" ]; then \
                                                        echo "extract dragonboard rootfs.tar.gz"; \
                                                        tar zxf ./common/rootfs/rootfs.tar.gz; \
                                                fi
                                        echo ${LICHEE_DRAGONBAORD_DIR}/rootfs/lib/modules
                                        echo ${LICHEE_DRAGONBAORD_DIR}/rootfs_overlay/
                                        mkdir -p ${LICHEE_DRAGONBAORD_DIR}/rootfs_overlay/
                                        mkdir -p ${LICHEE_DRAGONBAORD_DIR}/rootfs/lib/modules
                                        rm -rf ${LICHEE_DRAGONBAORD_DIR}/rootfs/lib/modules/*
                                        cp -rf ${LICHEE_KERN_DIR}/output/lib/modules/* \
                                        cp -rf ${LICHEE_DRAGONBAORD_DIR}/rootfs_overlay/* \
                                        (cd ${LICHEE_DRAGONBAORD_DIR}/common/scripts; ./build.sh)
                                        [  $? -ne 0 ] && mk_error "build rootfs Failed" && return 1
                                        cp ${LICHEE_DRAGONBAORD_DIR}/rootfs.ext4 ${LICHEE_PLAT_OUT}
                                        mk_error "no ${LICHEE_PLATFORM} in lichee,please git clone it under lichee"
                                        exit 1
                                fi
楼主 #16 2022-02-07 23:53:22
X3
已发帖子: 85
果然在这个文档 [D1_Tina_Linux_存储_开发指南.pdf](https://whycan.com/files/202108/d1/D1_Tina_Linux_存储_开发指南.pdf) 找到 rootfs_data 了。
在 A100 的 SDK也找到这玩意,
**target/allwinner/xxx-a3/base-files/etc/config/fstab**
config 'global'
        option  anon_swap       '0'
        option  anon_mount      '0'
        option  auto_swap       '1'
        option  auto_mount      '1'
        option  delay_root      '5'
        option  check_fs        '1'
config 'mount'
        option  target          '/boot-res'
        option  device          '/dev/by-name/boot-res'
        option  options         'ro,sync'
        option  enabled         '1'
config 'mount'
        option  target          '/mnt/UDISK'
        option  device          '/dev/by-name/UDISK'
        option  options         'rw,async'
        option  enabled         '1'
config 'mount'
        option  target          '/overlay'
        option  device          '/dev/by-name/rootfs_data'
        option  options         'rw,sync'
        option  enabled         '1'
config 'mount'
        option  target          '/mnt/SDCARD'
        option  device          '/dev/mmcblk1'
        option  enabled         '1'
config 'mount'
        option  device          '/dev/mmcblk1p1'
        option  enabled         '1'
config 'mount'
        option  target          '/mnt/exUDISK'
        option  device          '/dev/sda1'
        option  enabled         '1'
config 'mount'
        option  device          '/dev/sda'
        option  enabled         '1'
**./device/config/chips/xxx/configs/a3/linux/sys_partition.fex**
; 说明: 脚本中的字符串区分大小写,用户可以修改"="后面的数值,但是不要修改前面的字符串
;                                   固件下载参数配置
;    mbr的大小, 以Kbyte为单位
[mbr]
size = 512
;                                              分区配置
;  partition 定义范例:
;    [partition]                ;  //表示是一个分区
;    name        = USERFS2      ; //分区名称
;    size        = 16384        ; //分区大小 单位: 扇区.分区表示个数最多2^31 * 512 = 2T
;    downloadfile = "123.fex"   ; //下载文件的路径和名称,可以使用相对路径,相对是指相对于image.cfg文件所在分区。也可以使用绝对路径
;    keydata     = 1            ; //私有数据分区,重新量产数据将不丢失
;    encrypt     = 1            ; //采用加密方式烧录,将提供数据加密,但损失烧录速度
;          = ?            ; //私有用法
;    verify      = 1            ; //要求量产完成后校验是否正确
; 注:1、name唯一, 不允许同名
;     2、name最大12个字符
;     3、size = 0, 将创建一个无大小的空分区
;     4、为了安全和效率考虑,分区大小最好保证为16M字节的整数倍
[partition_start]
[partition]
    name         = boot-resource
    size         = 512
    downloadfile = "boot-resource.fex"
    user_type    = 0x8000
[partition]
    name         = env
    size         = 1024
    downloadfile = "env.fex"
    user_type    = 0x8000
[partition]
    name         = env-redund
    size         = 1024
    user_type    = 0x8000
[partition]
    name         = boot
    size         = 30720
    downloadfile = "boot.fex"
    user_type    = 0x8000
[partition]
    name         = rootfs
    size         = 131072
    downloadfile = "rootfs.fex"
    user_type    = 0x8000
[partition]
    name         = rootfs_data
    ;size         = 61440
    size         = 8192
    user_type    = 0x8000
[partition]
    name         = private
    size         = 1024
    user_type    = 0x8000
;   recovery分区说明
;   如果启用了OTA升级,默认以boot_initramfs.img作为recovery.fex,否则recovery.fex为空
[partition]
    name         = recovery
    size         = 32768
    downloadfile = "recovery.fex"
    user_type    = 0x8000
;[partition]
;    name         = misc
;    size         = 1024
;    user_type    = 0x8000
[partition]
    name         = UDISK
    user_type    = 0x8100
rootfs_data 只有 size,没有 downloadfile。
楼主 #17 2022-02-09 12:37:14
X3
已发帖子: 85
输入 part list sunxi_flash 0 命令获取eMMC分区列表:
=> part list sunxi_flash 0
Partition Map for UNKNOWN device 0  --   Partition Type: EFI
Part    Start LBA       End LBA         Name
        Attributes
        Type GUID
        Partition GUID
  1     0x00012000      0x00019fff      "boot-resource"
        attrs:  0x8000000000000000
        type:   ebd0a0a2-b9e5-4433-87c0-68b6b72699c7
        guid:   a0085546-4166-744a-a353-fca9272b8e45
  2     0x0001a000      0x00021fff      "env"
        guid:   a0085546-4166-744a-a353-fca9272b8e46
  3     0x00022000      0x00031fff      "boot"
        guid:   a0085546-4166-744a-a353-fca9272b8e47
  4     0x00032000      0x00131fff      "rootfs"
        guid:   a0085546-4166-744a-a353-fca9272b8e48
  5     0x00132000      0x00139fff      "klog"
        guid:   a0085546-4166-744a-a353-fca9272b8e49
  6     0x0013a000      0x01d1efde      "UDISK"
        guid:   a0085546-4166-744a-a353-fca9272b8e4a
也可以先输入mmc info
=> mmc info
curr_device:2
Device: SUNXI SD/MMC
Manufacturer ID: 15
OEM: 100
Bus Speed: 50000000
Mode : MMC legacy
Rd Block Len: 512
MMC version 5.1
High Capacity: Yes
Capacity: 14.6 GiB
Bus Width: 8-bit DDR
Erase Group Size: 512 KiB
HC WP Group Size: 8 MiB
User Capacity: 14.6 GiB WRREL
Boot Capacity: 4 MiB ENH
RPMB Capacity: 4 MiB ENH
然后输入 mmc part
=> mmc part
Partition Map for MMC device 2  --   Partition Type: EFI
        Attributes
        Type GUID
        Partition GUID
一样可以获取分区列表。
然后手动执行:
run setargs_mmc
mmc read 45000000 0x00022000 0x10000
bootm 45000000
可以手动引导启动Linux:
=> printenv
aaa=bbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbb
boot_fastboot=fastboot
boot_normal=sunxi_flash read 45000000 boot;bootm 45000000
boot_recovery=sunxi_flash read 45000000 recovery;bootm 45000000
bootcmd=run setargs_mmc boot_normal
bootdelay=0
bootreason=unknow
ccc=ddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddz
cma=8M
console=ttyS0,115200
earlyprintk=sunxi-uart,0x05000000
fdtcontroladdr=7bed7240
fileaddr=40000000
filesize=2a3038
init=/init
initcall_debug=0
keybox_list=widevine,ec_key,ec_cert1,ec_cert2,ec_cert3,rsa_key,rsa_cert1,rsa_cert2,rsa_cert3
loglevel=8
mmc_root=/dev/mmcblk0p4
nand_root=/dev/nand0p4
partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:boot@mmcblk0p3:rootfs@mmcblk0p4:klog@mmcblk0p5:UDISK@mmcblk0p6
rotpk_status=0
setargs_mmc=setenv  bootargs earlyprintk=${earlyprintk} initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel} root=${mmc_root}  init=${init} partitions=${partitions} cma=${cma} snum=${snum} mac_addr=${mac} wifi_mac=${wifi_mac} bt_mac=${bt_mac} specialstr=${specialstr} gpt=1
setargs_nand=setenv bootargs earlyprintk=${earlyprintk} initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel} root=${nand_root} init=${init} partitions=${partitions} cma=${cma} snum=${snum} mac_addr=${mac} wifi_mac=${wifi_mac} bt_mac=${bt_mac} specialstr=${specialstr} gpt=1
snum=0c001415a0c08851e4d
Environment size: 1427/131068 bytes
=> run setargs_mmc
=> mmc read 45000000 0x00022000 0x10000
MMC read: dev # 2, block # 139264, count 65536 ... 65536 blocks read: OK
=> bootm 45000000
[282.345]in boot normal mode,pass normal para to cmdline
[282.351]android.hardware = sun50iw10p1
[282.354]androidboot.dtbo_idx  can't findAndroid's image name: sun50i_arm64
[282.432]Starting kernel ...
[282.435][mmc]: mmc exit start
[282.454][mmc]: mmc 2 exit ok
[    0.000000] Linux version 4.9.170 (whycan@ubuntu) (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05) ) #2 SMP PREEMPT Mon Feb 7 21:04:51 CST 2022
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] disp reserve base 0x7bf65140 ,size 0x3e8000
[    0.000000] cma: Reserved 8 MiB at 0x000000007f800000
[    0.000000] On node 0 totalpages: 262144
[    0.000000]   DMA zone: 4096 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 262144 pages, LIFO batch:31
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.0
[    0.000000] percpu: Embedded 23 pages/cpu @ffffffc03f705000 s53376 r8192 d32640 u94208
[    0.000000] pcpu-alloc: s53376 r8192 d32640 u94208 alloc=23*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 258048
[    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x05000000 initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p4 init=/init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:boot@mmcblk0p3:rootfs@mmcblk0p4:klog@mmcblk0p5:UDISK@mmcblk0p6 cma=8M snum=0c001415a0c08851e4d mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.serialno=0c001415a0c08851e4d androidboot.hardware=sun50iw10p1 boot_type=2 androidboot.boot_type=2 androidboot.secure_os_exist=0 androidboot.trustchain=false gpt=1 uboot_message=2018.05(02/07/2022-22:08:09) disp_reserve=4096000,0x7bf65140 bootreason=unknow
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
[    0.000000] Memory: 975568K/1048576K available (11454K kernel code, 2200K rwdata, 4056K rodata, 4416K init, 602K bss, 64816K reserved, 8192K cma-reserved)
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008bb0000   ( 11456 KB)
[    0.000000]     .rodata : 0xffffff8008bb0000 - 0xffffff8008fb0000   (  4096 KB)
[    0.000000]       .init : 0xffffff8008fb0000 - 0xffffff8009400000   (  4416 KB)
[    0.000000]       .data : 0xffffff8009400000 - 0xffffff8009626008   (  2201 KB)
[    0.000000]        .bss : 0xffffff8009626008 - 0xffffff80096bc998   (   603 KB)
[    0.000000]     fixed   : 0xffffffbefe7fb000 - 0xffffffbefec00000   (  4116 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf01000000   (    16 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc040000000   (  1024 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000]  Build-time adjustment of leaf fanout to 64.
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (virt).
[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.008148] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[    0.018200] pid_max: default: 32768 minimum: 301
[    0.023032] Security Framework initialized
[    0.026879] SELinux:  Initializing.
[    0.030473] SELinux:  Starting in permissive mode
[    0.035135] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
[    0.041698] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
[    0.049568] ftrace: allocating 34576 entries in 136 pages
[    0.134306] sched-energy: CPU device node has no sched-energy-costs
[    0.134949] Invalid sched_group_energy for CPU0
[    0.139487] CPU0: update cpu_capacity 1024
[    0.153593] ASID allocator initialised with 32768 entries
[    0.172500] BOOTEVENT:       172.490624: ON
[    0.200562] Detected VIPT I-cache on CPU1
[    0.200612] Invalid sched_group_energy for CPU1
[    0.200615] CPU1: update cpu_capacity 1024
[    0.200618] CPU1: Booted secondary processor [410fd034]
[    0.223930] Detected VIPT I-cache on CPU2
[    0.223957] Invalid sched_group_energy for CPU2
[    0.223960] CPU2: update cpu_capacity 1024
[    0.223962] CPU2: Booted secondary processor [410fd034]
[    0.247343] Detected VIPT I-cache on CPU3
[    0.247368] Invalid sched_group_energy for CPU3
[    0.247371] CPU3: update cpu_capacity 1024
[    0.247374] CPU3: Booted secondary processor [410fd034]
[    0.247457] Brought up 4 CPUs
[    0.298093] SMP: Total of 4 processors activated.
[    0.302784] CPU features: detected feature: 32-bit EL0 Support
[    0.308590] CPU features: detected feature: Kernel page table isolation (KPTI)
[    0.319451] CPU: All CPU(s) started at EL1
[    0.319860] alternatives: patching kernel code
[    0.324468] Invalid sched_group_energy for CPU3
[    0.328787] CPU3: update max cpu_capacity 1024
[    0.333203] Invalid sched_group_energy for Cluster3
[    0.338055] Invalid sched_group_energy for CPU2
[    0.342562] Invalid sched_group_energy for Cluster2
[    0.347415] Invalid sched_group_energy for CPU1
[    0.351923] Invalid sched_group_energy for Cluster1
[    0.356775] Invalid sched_group_energy for CPU0
[    0.361282] Invalid sched_group_energy for Cluster0
[    0.366664] CPU1: update max cpu_capacity 1024
[    0.371280] devtmpfs: initialized
[    0.412713] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.416850] futex hash table entries: 1024 (order: 5, 131072 bytes)
[    0.423648] atomic64_test: passed
[    0.426348] pinctrl core: initialized pinctrl subsystem
[    0.433612] NET: Registered protocol family 16
[    0.437215] dump_class_init,861, success
[    0.453277] cpuidle: using governor menu
[    0.454604] sunxi iommu: irq = 9
[    0.455385] vdso: 2 pages (1 code @ ffffff8008bb8000, 1 data @ ffffff8009404000)
[    0.462180] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.470358] DMA: preallocated 256 KiB pool for atomic allocations
[    0.477994] sun50iw10p1-r-pinctrl r_pio: initialized sunXi PIO driver
[    0.498165] sun50iw10p1-pinctrl pio: initialized sunXi PIO driver
[    0.502646] iommu: Adding device 1c0e000.ve to group 0
[    0.510962] iommu: Adding device 6000000.disp to group 0
[    0.511860] iommu: Adding device 6480000.g2d to group 0
[    0.519814] iommu: Adding device csi0 to group 0
[    0.520855] iommu: Adding device csi1 to group 0
[    0.526118] iommu: Adding device 2108000.tdm to group 0
[    0.530686] iommu: Adding device 2100000.isp to group 0
[    0.535895] iommu: Adding device 2102000.isp to group 0
[    0.540921] iommu: Adding device 2110000.scaler to group 0
[    0.546382] iommu: Adding device 2110400.scaler to group 0
[    0.551848] iommu: Adding device 2110800.scaler to group 0
[    0.557291] iommu: Adding device 2110c00.scaler to group 0
[    0.600707] pwm module init!
[    0.605767] sunxi-pm debug v3.10
[    0.607253] SCSI subsystem initialized
[    0.608153] usbcore: registered new interface driver usbfs
[    0.612647] usbcore: registered new interface driver hub
[    0.617975] usbcore: registered new device driver usb
[    0.623128] sunxi_i2c_adap_init()2541 - init
[    0.627692] sunxi_i2c_probe()2289 - [i2c0] twi_drv_used = 0
[    0.632689] sunxi_i2c_probe()2293 - [i2c0] twi_pkt_interval = 0
[    0.638579] twi0 supply twi not found, using dummy regulator
[    0.644293] twi_request_gpio()453 - [i2c0] init name: twi0
[    0.650381] sunxi_i2c_probe()2289 - [i2c1] twi_drv_used = 0
[    0.655220] sunxi_i2c_probe()2293 - [i2c1] twi_pkt_interval = 0
[    0.661120] twi1 supply twi not found, using dummy regulator
[    0.666814] twi_request_gpio()453 - [i2c1] init name: twi1
[    0.673029] sunxi_i2c_probe()2289 - [i2c2] twi_drv_used = 0
[    0.677755] sunxi_i2c_probe()2293 - [i2c2] twi_pkt_interval = 0
[    0.683642] twi2 supply twi not found, using dummy regulator
[    0.689344] twi_request_gpio()453 - [i2c2] init name: twi2
[    0.695318] sunxi_i2c_probe()2289 - [i2c3] twi_drv_used = 0
[    0.700284] sunxi_i2c_probe()2293 - [i2c3] twi_pkt_interval = 0
[    0.706174] twi3 supply twi not found, using dummy regulator
[    0.711895] twi_request_gpio()453 - [i2c3] init name: twi3
[    0.717830] media: Linux media interface: v0.10
[    0.721836] Linux video capture interface: v2.00
[    0.727372] ion_parse_dt_heap_common: id 0 type 0 name sys_user align 1000
[    0.733437] ion_parse_dt_heap_common: id 4 type 4 name cma align 1000
[    0.739800] ion_parse_dt_heap_common: id 6 type 6 name secure align 1000
[    0.746618] drm config service not available: FFFFFFFF
[    0.751674] Advanced Linux Sound Architecture Driver Initialized.
[    0.758204] Bluetooth: Core ver 2.22
[    0.761081] NET: Registered protocol family 31
[    0.765453] Bluetooth: HCI device and connection manager initialized
[    0.771784] Bluetooth: HCI socket layer initialized
[    0.776638] Bluetooth: L2CAP socket layer initialized
[    0.781699] Bluetooth: SCO socket layer initialized
[    0.787283] ncs8801s init:*************************
[    0.791515] script_ncs8801s_gpio_init: ncs8801s is not used
[    0.797408] clocksource: Switched to clocksource arch_sys_counter
[    0.880067] VFS: Disk quotas dquot_6.6.0
[    0.880209] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.888007] udc_init,0
[    0.889217] NET: Registered protocol family 2
[    0.904277] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[    0.905752] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
[    0.912341] TCP: Hash tables configured (established 8192 bind 8192)
[    0.918594] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.924446] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.931083] NET: Registered protocol family 1
[    0.935380] Trying to unpack rootfs image as initramfs...
[    1.090254] Freeing initrd memory: 2544K
[    1.091674] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    1.098906] audit: initializing netlink subsys (disabled)
[    1.101725] audit: type=2000 audit(0.930:1): initialized
[    1.108074] workingset: timestamp_bits=45 max_order=18 bucket_order=0
[    1.125195] Registering sdcardfs 0.1
[    1.125754] ntfs: driver 2.1.32 [Flags: R/W].
[    1.127958] fuse init (API version 7.26)
[    1.133557] SELinux:  Registering netfilter hooks
[    1.140640] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    1.143450] io scheduler noop registered
[    1.147340] io scheduler deadline registered
[    1.151849] io scheduler cfq registered (default)
[    1.157892] [DISP]disp_module_init
[    1.160793] [DISP] disp_init,line:2260:
[    1.163270] smooth display screen:1 type:1 mode:4
[    1.251503] [DISP] lcd_clk_config,line:665:
[    1.251550]▒ʂ▒▒▒▒▒▒Jj
                        [    1.251550]      clk real:pll(492000000),clk(492000000),dclk(70285714) dsi_rate(0)
[    1.254601] [DISP]disp_module_init finish
[    1.256651] uart uart0: get regulator failed
[    1.256666] uart0 supply uart not found, using dummy regulator
[    1.256930] uart0: ttyS0 at MMIO 0x5000000 (irq = 349, base_baud = 1500000) is a SUNXI
[    1.256949] sw_console_setup()1731 - console setup baud 115200 parity n bits 8, flow n
[    1.289884] console [ttyS0] enabled
[    1.299414] bootconsole [earlycon0] disabled
[    1.308491] uart uart1: get regulator failed
[    1.316710] uart1 supply uart not found, using dummy regulator
[    1.323535] uart1: ttyS1 at MMIO 0x5000400 (irq = 350, base_baud = 1500000) is a SUNXI
[    1.333434] misc dump reg init
[    1.337990] G2D: Module initialized.major:246
[    1.344217] [drm] Initialized
[    1.347743] Unable to detect cache hierarchy for CPU 0
[    1.367056] brd: module loaded
[    1.386024] loop: module loaded
[    1.390441] zram: Added device: zram0
[    1.394826] [NAND][NE] Not found valid nand node on dts
[    1.401763] sunxi-wlan soc@03000000:wlan@0: wlan_busnum (1)
[    1.408105] sunxi-wlan soc@03000000:wlan@0: Missing wlan_power.
[    1.414785] sunxi-wlan soc@03000000:wlan@0: wlan_power_name ((null))
[    1.421953] sunxi-wlan soc@03000000:wlan@0: Missing wlan_io_regulator.
[    1.429313] sunxi-wlan soc@03000000:wlan@0: io_regulator_name ((null))
[    1.436721] sunxi-wlan soc@03000000:wlan@0: wlan_regon gpio=357  mul-sel=1  pull=-1  drv_level=-1  data=0
[    1.447527] sunxi-wlan soc@03000000:wlan@0: get gpio chip_en failed
[    1.454593] sunxi-wlan soc@03000000:wlan@0: get gpio power_en failed
[    1.461775] sunxi-wlan soc@03000000:wlan@0: wlan_hostwake gpio=358  mul-sel=1  pull=-1  drv_level=-1  data=0
[    1.472927] sunxi-wlan soc@03000000:wlan@0: clk not config
[    1.479119] sunxi-wlan soc@03000000:wlan@0: dcxo not config
[    1.485423] sunxi-wlan soc@03000000:wlan@0: pinctrl_lookup_state(default) failed! return ffffffffffffffed
[    1.497256] [ADDR_MGT] addr_mgt_probe: success.
[    1.504437] it6612_init-<629>:it6612 init:*************************
[    1.512198] it6612_probe-<497>:it6612 probe:*************************
[    1.525407] twi_stop()514 - [i2c0] STOP can't sendout!
[    1.531183] sunxi_i2c_core_process()1751 - [i2c0] STOP failed!
[    1.537762] sunxi_i2c_do_xfer()1946 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4c)
[    1.550267] twi_stop()524 - [i2c1] i2c state(0x0) isn't idle(0xf8)
[    1.557214] sunxi_i2c_core_process()1751 - [i2c1] STOP failed!
[    1.563828] sunxi_i2c_do_xfer()1946 - [i2c1] incomplete xfer (status: 0xff, dev addr: 0x4c)
[    1.586546] twi_stop()524 - [i2c2] i2c state(0x0) isn't idle(0xf8)
[    1.593493] sunxi_i2c_core_process()1751 - [i2c2] STOP failed!
[    1.600094] sunxi_i2c_do_xfer()1946 - [i2c2] incomplete xfer (status: 0xff, dev addr: 0x4c)
[    1.609737] sunxi_i2c_do_xfer()1946 - [i2c3] incomplete xfer (status: 0x20, dev addr: 0x4c)
[    1.619857] libphy: Fixed MDIO Bus: probed
[    1.624499] tun: Universal TUN/TAP device driver, 1.6
[    1.630191] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.638995] gmac-power0: NULL
[    1.642352] gmac-power1: NULL
[    1.645699] gmac-power2: NULL
[    1.649945] PPP generic driver version 2.4.2
[    1.655038] PPP BSD Compression module registered
[    1.660345] PPP Deflate Compression module registered
[    1.666050] PPP MPPE Compression module registered
[    1.671465] NET: Registered protocol family 24
[    1.676463] PPTP driver version 0.8.5
[    1.680959] usbcore: registered new interface driver rtl8150
[    1.687451] usbcore: registered new interface driver r8152
[    1.693703] usbcore: registered new interface driver asix
[    1.699847] usbcore: registered new interface driver ax88179_178a
[    1.706774] usbcore: registered new interface driver cdc_ether
[    1.713424] usbcore: registered new interface driver smsc75xx
[    1.719975] usbcore: registered new interface driver smsc95xx
[    1.726516] usbcore: registered new interface driver net1080
[    1.732949] usbcore: registered new interface driver cdc_subset
[    1.739685] usbcore: registered new interface driver zaurus
[    1.746019] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[    1.754450] usbcore: registered new interface driver cdc_ncm
[    1.760828] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.768546] get ehci0-controller, regulator_io is no nocare
[    1.774836] get ehci0-controller wakeup-source is fail.
[    1.780968] sunxi ehci0-controller don't init wakeup source
[    1.787258] [sunxi-ehci0]: probe, pdev->name: 5101000.ehci0-controller, sunxi_ehci: 0xffffff80096a7ac0, 0x:ffffff80097d6000, irq_no:164
[    1.800969] [sunxi-ehci0]: Not init ehci0
[    1.805620] get ehci1-controller, regulator_io is no nocare
[    1.812097] [sunxi-ehci1]: probe, pdev->name: 5200000.ehci1-controller, sunxi_ehci: 0xffffff80096a7e48, 0x:ffffff80097f1000, irq_no:166
[    1.825829] 5200000.ehci1-controller supply drvvbus not found, using dummy regulator
[    1.834680] sunxi-ehci 5200000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.844899] sunxi-ehci 5200000.ehci1-controller: new USB bus registered, assigned bus number 1
[    1.855124] sunxi-ehci 5200000.ehci1-controller: irq 358, io mem 0xffffffc03daa8410
[    1.874097] sunxi-ehci 5200000.ehci1-controller: USB 0.0 started, EHCI 1.00
[    1.883019] hub 1-0:1.0: USB hub found
[    1.887292] hub 1-0:1.0: 1 port detected
[    1.892591] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.899905] get ohci0-controller, regulator_io is no nocare
[    1.906203] get ohci0-controller wakeup-source is fail.
[    1.912304] sunxi ohci0-controller don't init wakeup source
[    1.918713] [sunxi-ohci0]: probe, pdev->name: 5101000.ohci0-controller, sunxi_ohci: 0xffffff80096a8558
[    1.929194] [sunxi-ohci0]: Not init ohci0
[    1.933850] get ohci1-controller, regulator_io is no nocare
[    1.940414] [sunxi-ohci1]: probe, pdev->name: 5200000.ohci1-controller, sunxi_ohci: 0xffffff80096a88e0
[    1.950925] 5200000.ohci1-controller supply drvvbus not found, using dummy regulator
[    1.959777] sunxi-ohci 5200000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.969602] sunxi-ohci 5200000.ohci1-controller: new USB bus registered, assigned bus number 2
[    1.979378] sunxi-ohci 5200000.ohci1-controller: irq 359, io mem 0xffffffc03daa8800
[    2.049105] hub 2-0:1.0: USB hub found
[    2.053374] hub 2-0:1.0: 1 port detected
[    2.058958] usbcore: registered new interface driver uas
[    2.065074] usbcore: registered new interface driver usb-storage
[    2.071905] usbcore: registered new interface driver ums-alauda
[    2.078628] usbcore: registered new interface driver ums-cypress
[    2.085454] usbcore: registered new interface driver ums-datafab
[    2.092273] usbcore: registered new interface driver ums_eneub6250
[    2.099292] usbcore: registered new interface driver ums-freecom
[    2.106110] usbcore: registered new interface driver ums-isd200
[    2.112841] usbcore: registered new interface driver ums-jumpshot
[    2.119758] usbcore: registered new interface driver ums-karma
[    2.126387] usbcore: registered new interface driver ums-onetouch
[    2.133324] usbcore: registered new interface driver ums-realtek
[    2.140149] usbcore: registered new interface driver ums-sddr09
[    2.146872] usbcore: registered new interface driver ums-sddr55
[    2.153599] usbcore: registered new interface driver ums-usbat
[    2.160302] usbcore: registered new interface driver usbserial
[    2.167079] usbcore: registered new interface driver option
[    2.173407] usbserial: USB Serial support registered for GSM modem (1-port)
[    2.181515] usb_serial_number:20080411
[    2.186509] sunxikbd_key_init: key0 vol= 210 code= 115
[    2.192313] sunxikbd_key_init: key1 vol= 410 code= 114
[    2.198105] sunxikbd_key_init: key2 vol= 590 code= 139
[    2.203900] sunxikbd_key_init: key3 vol= 750 code= 28
[    2.209599] sunxikbd_key_init: key4 vol= 880 code= 102
[    2.215720] input: sunxi-keyboard as /devices/virtual/input/input0
[    2.224761] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
[    2.231696] sunxi-rtc rtc: RTC enabled
[    2.236225] i2c /dev entries driver
[    2.241140] sunxi cedar version 0.1
[    2.245222] VE: install start!!!
[    2.245222]
[    2.250657] cedar_ve: cedar-ve the get irq is 347
[    2.256355] VE: get debugfs_mpp_root is NULL, please check mpp
[    2.256355]
[    2.264593] VE: sunxi ve debug register driver failed!
[    2.264593]
[    2.274256] device-mapper: uevent: version 1.0.3
[    2.279979] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[    2.289663] device-mapper: verity-avb: AVB error handler initialized with vbmeta device:
[    2.298884] Bluetooth: HCI UART driver ver 2.3
[    2.303901] Bluetooth: HCI UART protocol H4 registered
[    2.309695] Bluetooth: HCI UART protocol LL registered
[    2.315483] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    2.323590] sunxi_cpufreq_init: only one opp_table
[    2.329005] [cpu_freq] ERR: DEBUG: get cpu 0 device
[    2.334548] [cpu_freq] ERR: Unable to get regulator, use the dummy
[    2.341575] cpu0 supply dummy not found, using dummy regulator
[    2.348224] core: (null) get dummy regulator
[    2.354139] cpu cpu0: _set_opp_voltage: failed to set voltage (0 0 0 mV): -22
[    2.365620] sunxi-mmc sdc2: SD/MMC/SDIO Host Controller Driver(v3.46 2020-6-1 11:33-202006021635)
[    2.375745] sunxi-mmc sdc2: No vmmc regulator found
[    2.381246] sunxi-mmc sdc2: No vqmmc regulator found
[    2.386834] sunxi-mmc sdc2: No vdmmc regulator found
[    2.392426] sunxi-mmc sdc2: No vd33sw regulator found
[    2.398110] sunxi-mmc sdc2: No vd18sw regulator found
[    2.403799] sunxi-mmc sdc2: No vq33sw regulator found
[    2.409486] sunxi-mmc sdc2: No vq18sw regulator found
[    2.415796] sunxi-mmc sdc2: set host busy
[    2.420383] mmc:failed to get gpios
[    2.424562] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.450758] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.477436] sunxi-mmc sdc2: detmode:alway in(non removable)
[    2.477457] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.485809] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.486871] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.497706] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.497766] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.510593] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.555116] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
[    2.564538] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
[    2.573941] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.584794] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
[    2.594224] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
[    2.603624] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
[    2.613047] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
[    2.622726] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.46 2020-6-1 11:33-202006021635)
[    2.632803] sunxi-mmc sdc0: ***ctl-spec-caps*** 8
[    2.638105] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
[    2.648947] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
[    2.660177] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 8 timing MMC-HS(SDR20) dt B
[    2.671141] sunxi-mmc sdc0: No vmmc regulator found
[    2.671145] sunxi-mmc sdc0: No vqmmc regulator found
[    2.671149] sunxi-mmc sdc0: No vdmmc regulator found
[    2.671152] sunxi-mmc sdc0: No vd33sw regulator found
[    2.671156] sunxi-mmc sdc0: No vd18sw regulator found
[    2.671159] sunxi-mmc sdc0: No vq33sw regulator found
[    2.671163] sunxi-mmc sdc0: No vq18sw regulator found
[    2.676926] sunxi-mmc sdc0: set host busy
[    2.676986] sunxi-mmc sdc0: Got CD GPIO
[    2.677305] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.677329] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
[    2.690822] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.707696] sunxi-mmc sdc0: detmode:gpio irq
[    2.707719] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[    2.709234] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.46 2020-6-1 11:33-202006021635)
[    2.709310] sunxi-mmc sdc1: ***ctl-spec-caps*** 8
[    2.709356] sunxi-mmc sdc1: No vmmc regulator found
[    2.709359] sunxi-mmc sdc1: No vqmmc regulator found
[    2.709363] sunxi-mmc sdc1: No vdmmc regulator found
[    2.709366] sunxi-mmc sdc1: No vd33sw regulator found
[    2.709370] sunxi-mmc sdc1: No vd18sw regulator found
[    2.709373] sunxi-mmc sdc1: No vq33sw regulator found
[    2.709377] sunxi-mmc sdc1: No vq18sw regulator found
[    2.709898] sunxi-mmc sdc1: set host busy
[    2.709961] mmc:failed to get gpios
[    2.709982] sunxi-mmc sdc1: min-frequency:400000
[    2.710191] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.710213] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
[    2.724152] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.740827] sunxi-mmc sdc1: detmode:manually by software
[    2.741536] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.743984] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.745100] hidraw: raw HID events driver (C) Jiri Kosina
[    2.745632] sunxi-mmc sdc1: card claims to support voltages below defined range
[    2.748392] usbcore: registered new interface driver usbhid
[    2.748395] usbhid: USB HID core driver
[    2.748785] ashmem: initialized
[    2.750212] optee: probing for conduit method from DT.
[    2.750220] optee: api uid mismatch
[    2.750589] usbcore: registered new interface driver snd-usb-audio
[    2.752204] u32 classifier
[    2.752214]     Actions configured
[    2.752224] Netfilter messages via NETLINK v0.30.
[    2.752240] nfnl_acct: registering with nfnetlink.
[    2.752512] nf_conntrack version 0.5.0 (8192 buckets, 32768 max)
[    2.752722] ctnetlink v0.93: registering with nfnetlink.
[    2.753191] xt_time: kernel timezone is -0000
[    2.753286] ipip: IPv4 and MPLS over IPv4 tunneling driver
[    2.753944] gre: GRE over IPv4 demultiplexor driver
[    2.753947] ip_gre: GRE over IPv4 tunneling driver
[    2.755128] IPv4 over IPsec tunneling driver
[    2.755567] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[    2.755705] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[    2.755880] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[    2.756671] mmc2: new high speed SDIO card at address 0001
[    2.772606] ip_tables: (C) 2000-2006 Netfilter Core Team
[    2.772836] arp_tables: arp_tables: (C) 2002 David S. Miller
[    2.777839] Initializing XFRM netlink socket
[    2.777874] IPsec XFRM device driver
[    2.778560] NET: Registered protocol family 10
[    2.780144] mip6: Mobile IPv6
[    2.780172] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    2.789904] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    2.791247] NET: Registered protocol family 17
[    2.791275] NET: Registered protocol family 15
[    2.791307] l2tp_core: L2TP core driver, V2.0
[    2.791319] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[    2.794507] Registered cp15_barrier emulation handler
[    2.794520] Registered setend emulation handler
[    2.795293] registered taskstats version 1
[    2.807574] cpu cpu1: dev_pm_opp_set_prop_name: Already have prop-name a0
[    2.807582] cpu cpu2: dev_pm_opp_set_prop_name: Already have prop-name a0
[    2.807587] cpu cpu3: dev_pm_opp_set_prop_name: Already have prop-name a0
[    2.808154] get usb_detect_mode is fail, 22
[    2.811589] sunxi-rtc rtc: setting system clock to 1970-01-01 00:03:54 UTC (234)
[    2.812556] usb1-vbus: disabling
[    2.812560] ALSA device list:
[    2.812562]   No soundcards found.
[    2.815076] Freeing unused kernel memory: 4416K
[    2.815146] Kernel init done
[    3.160156] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 8 timing MMC-DDR52 dt B
[    3.171128] mmc0: new DDR MMC card at address 0001
[    3.177656] mmcblk0: mmc0:0001 AJTD4R 14.6 GiB
[/init]: getty is ttyS0
[    3.183829] mmcblk0boot0: mmc0:0001 AJTD4R partition 1 4.00 MiB
[/init]: RootDevice is "/dev/mmc[    3.192004] mmcblk0boot1: mmc0:0001 AJTD4R partition 2 4.00 MiB
blk0p4" , GPT_SUPPORT=1
[/init][    3.198163] random: fast init done
: Try to load EMMC ...
[/init]:[    3.207868] mmcblk0rpmb: mmc0:0001 AJTD4R partition 3 4.00 MiB
 Wait /dev/mmcblk0p4 ready ...
[    3.218609]  mmcblk0: p1 p2 p3 p4 p5 p6
e2fsck 1.42.12 (29-Aug-2014)
/dev/mmcblk0p4: recovering journal
/dev/mmcblk0p4: clean, 1167/8192 files, 28398/32768 blocks
[    4.212897] EXT4-fs (mmcblk0p4): barriers disabled
[    4.219477] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,barrier=0,data=ordered
mount: mounting proc on /proc failed: Device or resource busy
m[    4.326521] EXT4-fs (mmcblk0p4): re-mounted. Opts: nobarrier,noauto_da_alloc,data=ordered
ount: mounting sysfs on /sys failed: Device or resource busy
insmod: can't insert '/lib/modules/4.9.170/disp.ko': No such file or directory
boot-res device: /dev/mmcblk0p1
[    4.362603] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
login[1088]: root login on 'ttyS0'
nand activated #0
[    4.488990] get ctp_power is fail, -22
[    4.493264] sunxi_ctp_startup: ctp_power_io is invalid.
[    4.499206] get ctp_gesture_wakeup fail, no gesture wakeup
[    4.505396] 1-005d supply ctp not found, using dummy regulator
[    4.647197] twi_stop()524 - [i2c1] i2c state(0x0) isn't idle(0xf8)
[    4.654137] sunxi_i2c_core_process()1751 - [i2c1] STOP failed!
[    4.660773] sunxi_i2c_do_xfer()1946 - [i2c1] incomplete xfer (status: 0xff, dev addr: 0x5d)
[    4.673227] twi_stop()524 - [i2c1] i2c state(0x0) isn't idle(0xf8)
[    4.680166] sunxi_i2c_core_process()1751 - [i2c1] STOP failed!
[    4.686739] sunxi_i2c_do_xfer()1946 - [i2c1] incomplete xfer (status: 0xff, dev addr: 0x5d)
[    4.699397] twi_stop()524 - [i2c1] i2c state(0x0) isn't idle(0xf8)
[    4.706336] sunxi_i2c_core_process()1751 - [i2c1] STOP failed!
[    4.712911] sunxi_i2c_do_xfer()1946 - [i2c1] incomplete xfer (status: 0xff, dev addr: 0x5d)
[    4.725376] twi_stop()524 - [i2c1] i2c state(0x0) isn't idle(0xf8)
[    4.732315] sunxi_i2c_core_process()1751 - [i2c1] STOP failed!
[    4.738891] sunxi_i2c_do_xfer()1946 - [i2c1] incomplete xfer (status: 0xff, dev addr: 0x5d)
[    4.751377] twi_stop()524 - [i2c1] i2c state(0x0) isn't idle(0xf8)
[    4.758316] sunxi_i2c_core_process()1751 - [i2c1] STOP failed!
[    4.764894] sunxi_i2c_do_xfer()1946 - [i2c1] incomplete xfer (status: 0xff, dev addr: 0x5d)
[    4.774298] <<-GTP-ERROR->> I2C Read: 0x8140, 6 bytes failed, errcode: -70! Process reset.
[    4.877449] <<-GTP-ERROR->> GTP read version failed
[    4.882949] Read version failed.
[    4.889498] twi_stop()524 - [i2c1] i2c state(0x0) isn't idle(0xf8)
[    4.896635] sunxi_i2c_core_process()1751 - [i2c1] STOP failed!
[    4.903225] sunxi_i2c_do_xfer()1946 - [i2c1] incomplete xfer (status: 0xff, dev addr: 0x5d)
[    4.916026] twi_stop()524 - [i2c1] i2c state(0x0) isn't idle(0xf8)
[    4.922964] sunxi_i2c_core_process()1751 - [i2c1] STOP failed!
[    4.929537] sunxi_i2c_do_xfer()1946 - [i2c1] incomplete xfer (status: 0xff, dev addr: 0x5d)
[    4.942086] twi_stop()524 - [i2c1] i2c state(0x0) isn't idle(0xf8)
[    4.949025] sunxi_i2c_core_process()1751 - [i2c1] STOP failed!
[    4.955597] sunxi_i2c_do_xfer()1946 - [i2c1] incomplete xfer (status: 0xff, dev addr: 0x5d)
[    4.968198] twi_stop()524 - [i2c1] i2c state(0x0) isn't idle(0xf8)
[    4.975138] sunxi_i2c_core_process()1751 - [i2c1] STOP failed!
[    4.981713] sunxi_i2c_do_xfer()1946 - [i2c1] incomplete xfer (status: 0xff, dev addr: 0x5d)
[    4.994218] twi_stop()524 - [i2c1] i2c state(0x0) isn't idle(0xf8)
[    5.001157] sunxi_i2c_core_process()1751 - [i2c1] STOP failed!
[    5.007732] sunxi_i2c_do_xfer()1946 - [i2c1] incomplete xfer (status: 0xff, dev addr: 0x5d)
[    5.017135] <<-GTP-ERROR->> I2C Read: 0x8047, 240 bytes failed, errcode: -70! Process reset.
[    5.120780] <<-GTP-ERROR->> Read Config Failed, Using Default Resolution & INT Trigger!
[    5.144404] input: gt9xxnew_ts as /devices/virtual/input/input1
script_fetch device name is gt9xxnew_ts
Found tp device_name is gt9xxnew_ts, event num is 1
Found tp event num is /dev/input/event1
camera activated #0
camera not activated
root@dragonboard:~#
root@dragonboard:~#
root@dragonboard:~#
root@dragonboard:~# dragonboard(msg): core: parse script /boot/test_config.fex...
dragonboard(debug): the length of script is 10140
dragonboard(debug): allocate share memory segment for script buffer failed(Function not implemented)
dragonboard(error): core: parse script failed
[    9.260812]
[    9.260812] insmod_device_driver
[    9.260812]
-------swith to adb....
[   10.499075] file system registered
init adb main
[   10.525409] read descriptors
Handling main()
[   10.529305] read strings
-------swith to adb done!
[   11.696672] sunxi_set_cur_vol_work()403 WARN: get power supply failed
[   11.786942] android_work: sent uevent USB_STATE=CONNECTED
[   11.793039] sunxi_set_cur_vol_work()403 WARN: get power supply failed
[   11.919066] configfs-gadget gadget: high-speed config #1: c
[   11.925418] android_work: sent uevent USB_STATE=CONFIGURED
[   13.340062] adbd (1221): /proc/1221/oom_adj is deprecated, please use /proc/1221/oom_score_adj instead.
root@dragonboard:~#
root@dragonboard:~#
参考: Linux_U-Boot_开发指南.pdf
楼主 #18 2022-02-09 12:45:55
X3
已发帖子: 85
用uboot命令查看分区与文件:
切换到 eMMC:
=> mmc dev 2
[27.544][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 8
switch to partitions #0, OK
mmc2(part 0) is current device
再瞅一次分区:
=> mmc part
        Attributes
        Type GUID
        Partition GUID
然后就可以查看分区信息与文件了:
=> fatinfo mmc 2:1
Interface:  MMC
  Device 2: Vendor: Man 000015 Snr fc7e4f81 Rev: 0.3 Prod: AJTD4R
            Type: Removable Hard Disk
            Capacity: 14910.0 MB = 14.5 GB (30535680 x 512)
Filesystem: FAT16 "Volumn"
=> fatls mmc 2:1
   344813   font24.sft
   357443   font32.sft
            bat/
    10140   test_config.fex
            wavefile/
    10240   test_config.bin
      512   magic.bin
7 file(s), 2 dir(s)
楼主 #19 2022-02-12 20:21:43
X3
已发帖子: 85
[    2.126916] sunxi_cpufreq_init: only one opp_table
[    2.132333] [cpu_freq] ERR: DEBUG: get cpu 0 device
[    2.137870] [cpu_freq] ERR: Unable to get regulator, use the dummy
[    2.144908] cpu0 supply dummy not found, using dummy regulator
[    2.151558] core: (null) get dummy regulator
[    2.157473] cpu cpu0: _set_opp_voltage: failed to set voltage (0 0 0 mV): -22
[    2.168949] sunxi-mmc sdc2: SD/MMC/SDIO Host Controller Driver(v3.46 2020-6-1 11:33-202006021635)
[    2.179088] sunxi-mmc sdc2: No vmmc regulator found
[    2.184586] sunxi-mmc sdc2: No vqmmc regulator found
[    2.190182] sunxi-mmc sdc2: No vdmmc regulator found
[    2.195773] sunxi-mmc sdc2: No vd33sw regulator found
[    2.201466] sunxi-mmc sdc2: No vd18sw regulator found
[    2.207154] sunxi-mmc sdc2: No vq33sw regulator found
[    2.212847] sunxi-mmc sdc2: No vq18sw regulator found
[    2.219145] sunxi-mmc sdc2: set host busy
[    2.223737] mmc:failed to get gpios
[    2.227895] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.254174] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.280852] sunxi-mmc sdc2: detmode:alway in(non removable)
[    2.280872] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.289228] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.290290] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.301134] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.301196] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.314032] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.359182] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.361009] hidraw: raw HID events driver (C) Jiri Kosina
[    2.363340] usbcore: registered new interface driver usbhid
[    2.363342] usbhid: USB HID core driver
[    2.364587] ashmem: initialized
[    2.366234] optee: probing for conduit method from DT.
[    2.366243] optee: api uid mismatch
[    2.366618] usbcore: registered new interface driver snd-usb-audio
[    2.368138] u32 classifier
[    2.368140]     Actions configured
[    2.368149] Netfilter messages via NETLINK v0.30.
[    2.368164] nfnl_acct: registering with nfnetlink.
[    2.368442] nf_conntrack version 0.5.0 (8192 buckets, 32768 max)
[    2.368649] ctnetlink v0.93: registering with nfnetlink.
[    2.369104] xt_time: kernel timezone is -0000
[    2.369192] ipip: IPv4 and MPLS over IPv4 tunneling driver
[    2.369786] gre: GRE over IPv4 demultiplexor driver
[    2.369790] ip_gre: GRE over IPv4 tunneling driver
[    2.370771] IPv4 over IPsec tunneling driver
[    2.382389] ip_tables: (C) 2000-2006 Netfilter Core Team
[    2.382616] arp_tables: arp_tables: (C) 2002 David S. Miller
[    2.386681] Initializing XFRM netlink socket
[    2.386713] IPsec XFRM device driver
[    2.387400] NET: Registered protocol family 10
[    2.389329] mip6: Mobile IPv6
[    2.389358] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    2.391214] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    2.392529] NET: Registered protocol family 17
[    2.392555] NET: Registered protocol family 15
[    2.392584] l2tp_core: L2TP core driver, V2.0
[    2.392596] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[    2.396018] Registered cp15_barrier emulation handler
[    2.396030] Registered setend emulation handler
[    2.396805] registered taskstats version 1
[    2.409204] cpu cpu1: dev_pm_opp_set_prop_name: Already have prop-name a0
[    2.409211] cpu cpu2: dev_pm_opp_set_prop_name: Already have prop-name a0
[    2.409216] cpu cpu3: dev_pm_opp_set_prop_name: Already have prop-name a0
[    2.409798] get usb_detect_mode is fail, 22
[    2.413847] sunxi-rtc rtc: setting system clock to 1970-01-01 00:00:19 UTC (19)
[    2.414926] usb1-vbus: disabling
[    2.414931] ALSA device list:
[    2.414933]   No soundcards found.
[    2.589139] VFS: Cannot open root device "mmcblk0p4" or unknown-block(0,0): error -6
[    2.597912] Please append a correct "root=" boot option; here are the available partitions:
[    2.607329] 0100            8192 ram0  (driver?)
[    2.612552] 0101            8192 ram1  (driver?)
[    2.617776] 0102            8192 ram2  (driver?)
[    2.623002] 0103            8192 ram3  (driver?)
[    2.628238] 0104            8192 ram4 [    2.628301] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
[    2.632332] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
[    2.654012]  (driver?)
[    2.654069] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 8 timing MMC-HS(SDR20) dt B
[    2.667849] 0105            8192 ram5  (driver?)
[    2.671944] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 8 timing MMC-DDR52 dt B
[    2.683648] 0106            8192 ram6  (driver?)
[    2.688870] 0107            8192 ram7 [    2.688934] mmc0: new DDR MMC card at address 0001
[    2.689656] mmcblk0: mmc0:0001 8WPD3R 7.28 GiB
[    2.689956] mmcblk0boot0: mmc0:0001 8WPD3R partition 1 4.00 MiB
[    2.693658] mmcblk0boot1: mmc0:0001 8WPD3R partition 2 4.00 MiB
[    2.697293] mmcblk0rpmb: mmc0:0001 8WPD3R partition 3 512 KiB
[    2.723282]  (driver?)
[    2.723378]  mmcblk0: p1 p2 p3 p4 p5 p6
[    2.730501] 0108            8192 ram8  (driver?)
[    2.735716] 0109            8192 ram9  (driver?)
[    2.740936] 010a            8192 ram10  (driver?)
[    2.746248] 010b            8192 ram11  (driver?)
[    2.751565] 010c            8192 ram12  (driver?)
[    2.756871] 010d            8192 ram13  (driver?)
[    2.762182] 010e            8192 ram14  (driver?)
[    2.767504] 010f            8192 ram15  (driver?)
[    2.772830] b300         7634944 mmcblk0  driver: mmcblk
[    2.778836]   b301           16384 mmcblk0p1 a0085546-4166-744a-a353-fca9272b8e45
[    2.787265]   b302           16384 mmcblk0p2 a0085546-4166-744a-a353-fca9272b8e46
[    2.795700]   b303           32768 mmcblk0p3 a0085546-4166-744a-a353-fca9272b8e47
[    2.804130]   b304          524288 mmcblk0p4 a0085546-4166-744a-a353-fca9272b8e48
[    2.812565]   b305           16384 mmcblk0p5 a0085546-4166-744a-a353-fca9272b8e49
[    2.821005]   b306         6991855 mmcblk0p6 a0085546-4166-744a-a353-fca9272b8e4a
[    2.829443] b330             512 mmcblk0rpmb  (driver?)
[    2.835340] b320            4096 mmcblk0boot1  (driver?)
[    2.841338] b310            4096 mmcblk0boot0  (driver?)
[    2.847331] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[    2.856626] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.9.170 #3
[    2.863375] Hardware name: sun50iw10 (DT)
[    2.867879] Call trace:
[    2.870633] [<ffffff800808bfb8>] dump_backtrace+0x0/0x2b8
[    2.876702] [<ffffff800808c294>] show_stack+0x24/0x30
[    2.882382] [<ffffff800847c0e0>] dump_stack+0x90/0xb0
[    2.888062] [<ffffff80081c41c8>] panic+0x148/0x374
[    2.893448] [<ffffff8008fa1158>] mount_block_root+0x21c/0x2fc
[    2.899906] [<ffffff8008fa13f0>] mount_root+0x74/0x84
[    2.905583] [<ffffff8008fa1568>] prepare_namespace+0x168/0x1b0
[    2.912140] [<ffffff8008fa0d74>] kernel_init_freeable+0x1bc/0x1e0
[    2.918991] [<ffffff8008b8f410>] kernel_init+0x18/0x120
[    2.924864] [<ffffff80080834f0>] ret_from_fork+0x10/0x20
[    2.930831] SMP: stopping secondary CPUs
[    2.935248] Kernel Offset: disabled
[    2.939180] Memory Limit: none
[    2.942627] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[    2.952794] sunxi dump enabled
[    2.956222] dump regs done
[    2.959312] flush cache done
[    2.962560] crashdump enter
NOTICE:  sunxi_usb_dev_register
NOTICE:  sunxi_usb_main_loop
感觉这个AIC800的 SDC2 有问题,但是不确定是硬件问题,还是软件问题,需要文件系统的时候eMMC却没有就绪,但是最终挂载成功,系统却宕机了。
怪不得出厂的 rootfs 用 initramfs了。
楼主 #20 2022-02-12 20:46:42
X3
已发帖子: 85
Re: 刚刚收到的全志AIC800开发板,接个串口打印LOG 试一试
挂载文件系统延迟一点点,移到后面去就好了,
不知道怎么改。
楼主 #21 2022-02-12 21:28:43
X3
已发帖子: 85
./build.sh pack 打包:
make: Entering directory '/opt/sw509/longan/kernel/linux-4.9/modules/gpu'
make -j -C img-rgx/linux/rogue_km/build/linux/sunxi_linux BUILD=release
make[1]: Entering directory '/opt/sw509/longan/kernel/linux-4.9/modules/gpu/img-rgx/linux/rogue_km/build/linux/sunxi_linux'
******* Multiarch build: no
******* Primary arch:    target_aarch64
******* Secondary arch:  none
WARNING: You are not specifying how to find dependent libraries, e.g., by specifying SYSROOT.
The build may fail.
  Building modules, stage 2.
  MODPOST 2 modules
make[1]: Leaving directory '/opt/sw509/longan/kernel/linux-4.9/modules/gpu/img-rgx/linux/rogue_km/build/linux/sunxi_linux'
'img-rgx/linux/rogue_km/binary_sunxi_linux_release/target_aarch64/pvrsrvkm.ko' -> '/opt/sw509/longan/kernel/linux-4.9/output/lib/modules/4.9.170/pvrsrvkm.ko'
'img-rgx/linux/rogue_km/binary_sunxi_linux_release/target_aarch64/dc_sunxi.ko' -> '/opt/sw509/longan/kernel/linux-4.9/output/lib/modules/4.9.170/dc_sunxi.ko'
make: Leaving directory '/opt/sw509/longan/kernel/linux-4.9/modules/gpu'
[GPU]: ge8300 device driver has been built.
regenerate rootfs cpio
15757 blocks
15758 blocks
build_ramfs
Copy boot.img to output directory ...
./scripts/build.sh
longan/kernel/linux-4.9/scripts/build.sh
#!/bin/bash
set -e
localpath=$(cd $(dirname $0) && pwd)
build_system=lichee
[ -d $localpath/../../../device/config/chips ] && build_system=longan
[ -d $localpath/../../tools/pack/chips ] && build_system=lichee
echo "build_system: $build_system"
#Setup common variables
export ARCH=arm
export CROSS_COMPILE=arm-linux-gnueabi-
if [ -n "`echo ${LICHEE_CHIP} | grep "sun5[0-9]i"`" ] && \
        [ "x${LICHEE_ARCH}" = "xarm64" ]; then
    export ARCH=arm64
    export CROSS_COMPILE=aarch64-linux-gnu-
fi
if [ -n "${LICHEE_TOOLCHAIN_PATH}" \
        -a -d "${LICHEE_TOOLCHAIN_PATH}" ]; then
    GCC=$(find ${LICHEE_TOOLCHAIN_PATH} -perm /a+x -a -regex '.*-gcc');
    export CROSS_COMPILE="${GCC%-*}-";
elif [ -n "${LICHEE_CROSS_COMPILER}" ]; then
    export CROSS_COMPILE="${LICHEE_CROSS_COMPILER}-"
fi
MAKE="make"
if [ -n "$ANDROID_CLANG_PATH" ]; then
    MAKE="make CC=$LICHEE_TOP_DIR/../$ANDROID_CLANG_PATH/clang"
    ARCH_PREFIX=arm
    [ "x$ARCH" == "xarm64" ] && ARCH_PREFIX=aarch64
    if [ -n "$ANDROID_TOOLCHAIN_PATH" ]; then
        export CROSS_COMPILE=$LICHEE_TOP_DIR/../$ANDROID_TOOLCHAIN_PATH/$ARCH_PREFIX-linux-android-
        export CLANG_TRIPLE=$ARCH_PREFIX-linux-gnu-
    fi
fi
export AS=${CROSS_COMPILE}as
export LD=${CROSS_COMPILE}ld
export CC=${CROSS_COMPILE}gcc
export AR=${CROSS_COMPILE}ar
export NM=${CROSS_COMPILE}nm
export STRIP=${CROSS_COMPILE}strip
export OBJCOPY=${CROSS_COMPILE}objcopy
export OBJDUMP=${CROSS_COMPILE}objdump
export LOCALVERSION=""
export MKBOOTIMG=${LICHEE_TOOLS_DIR}/pack/pctools/linux/android/mkbootimg
if [ "x$CCACHE_DIR" != "x" ];then
    CCACHE_Y="ccache "
fi
KERNEL_VERSION=`${MAKE} -s kernelversion -C ./`
LICHEE_KDIR=`pwd`
LICHEE_MOD_DIR=${LICHEE_KDIR}/output/lib/modules/${KERNEL_VERSION}
export LICHEE_KDIR
update_kern_ver()
    if [ -r include/generated/utsrelease.h ]; then
        KERNEL_VERSION=`cat include/generated/utsrelease.h |awk -F\" '{print $2}'`
    fi
do_init_to_dts()
        local DTC_SRC_PATH=${LICHEE_KERN_DIR}/arch/${ARCH}/boot/dts
        if [ "x${ARCH}" == "xarm64" ]; then
                DTC_SRC_PATH=${DTC_SRC_PATH}/sunxi
        fi
        local DTC_DEP_BOARD1=${DTC_SRC_PATH}/.board.dtb.d.dtc.tmp
        local DTC_SRC_BOARD1=${DTC_SRC_PATH}/.board.dtb.dts.tmp
        local DTC_DEP_BOARD=${DTC_SRC_PATH}/.${LICHEE_CHIP}-${LICHEE_BOARD}.dtb.d.dtc.tmp
        local DTC_SRC_BOARD=${DTC_SRC_PATH}/.${LICHEE_CHIP}-${LICHEE_BOARD}.dtb.dts.tmp
        local DTC_DEP_BUSSINESS=${DTC_SRC_PATH}/.${LICHEE_CHIP}-${LICHEE_BUSSINESS}.dtb.d.dtc.tmp
        local DTC_SRC_BUSSINESS=${DTC_SRC_PATH}/.${LICHEE_CHIP}-${LICHEE_BUSSINESS}.dtb.dts.tmp
        local DTC_DEP_COMMON=${DTC_SRC_PATH}/.${LICHEE_CHIP}-soc.dtb.d.dtc.tmp
        local DTC_SRC_COMMON=${DTC_SRC_PATH}/.${LICHEE_CHIP}-soc.dtb.dts.tmp
        local DTC_COMPILER=${LICHEE_KERN_DIR}/scripts/dtc/dtc
        local DTC_INI_FILE_BASE=${LICHEE_BOARD_CONFIG_DIR}/sys_config.fex
        local DTC_INI_FILE=output/sys_config_fix.fex
        cp $DTC_INI_FILE_BASE $DTC_INI_FILE
        sed -i "s/\(\[dram\)_para\(\]\)/\1\2/g" $DTC_INI_FILE
        sed -i "s/\(\[nand[0-9]\)_para\(\]\)/\1\2/g" $DTC_INI_FILE
        if [ ! -f $DTC_COMPILER ]; then
                echo "Script_to_dts: Can not find dtc compiler.\n"
                exit 1
        fi
        if [ -f $DTC_DEP_BOARD1 ]; then
                printf "Script_to_dts: use board special dts file board.dts\n"
                DTC_DEP_FILE=${DTC_DEP_BOARD1}
                DTC_SRC_FILE=${DTC_SRC_BOARD1}
        elif [ -f $DTC_DEP_BOARD ]; then
                printf "Script_to_dts: use board special dts file ${LICHEE_CHIP}-${LICHEE_BOARD}.dts\n"
                DTC_DEP_FILE=${DTC_DEP_BOARD}
                DTC_SRC_FILE=${DTC_SRC_BOARD}
        elif [ -f $DTC_DEP_BUSSINESS ]; then
                printf "Script_to_dts: use bussiness special dts file ${LICHEE_CHIP}-${LICHEE_BUSSINESS}.dts\n"
                DTC_DEP_FILE=${DTC_DEP_BUSSINESS}
                DTC_SRC_FILE=${DTC_SRC_BUSSINESS}
                printf "Script_to_dts: use common dts file ${LICHEE_CHIP}-soc.dts\n"
                DTC_DEP_FILE=${DTC_DEP_COMMON}
                DTC_SRC_FILE=${DTC_SRC_COMMON}
        fi
        local DTC_FLAGS="-W no-unit_address_vs_reg"
        if [ -d ${LICHEE_CHIP_CONFIG_DIR}/dtbo ];  then
                echo "sunxi_dtb create"
                $DTC_COMPILER ${DTC_FLAGS} -@ -O dtb -o ${LICHEE_KERN_DIR}/output/sunxi.dtb     \
                        -b 0                    \
                        -i $DTC_SRC_PATH        \
                        -F $DTC_INI_FILE        \
                        -d $DTC_DEP_FILE $DTC_SRC_FILE
                $DTC_COMPILER -p 2048 ${DTC_FLAGS} -O dtb -o ${LICHEE_KERN_DIR}/output/sunxi.dtb        \
                        -b 0                    \
                        -i $DTC_SRC_PATH        \
                        -F $DTC_INI_FILE        \
        fi
                echo "Conver script to dts failed"
                exit 1
        fi
        #restore the orignal dtsi
        if [ "x${LICHEE_LINUX_DEV}" = "xdragonboard" \
                -o "x${LICHEE_LINUX_DEV}" = "xdragonmat" ]; then
                local DTS_PATH=${LICHEE_KERN_DIR}/arch/${ARCH}/boot/dts
                [ "x${ARCH}" = "xarm64" ] && DTS_PATH=${LICHEE_KERN_DIR}/arch/${ARCH}/boot/dts/sunxi
                if [ -f ${DTS_PATH}/${LICHEE_CHIP}_bak.dtsi ];then
                        rm -f ${DTS_PATH}/${LICHEE_CHIP}.dtsi
                        mv  ${DTS_PATH}/${LICHEE_CHIP}_bak.dtsi  ${DTS_PATH}/${LICHEE_CHIP}.dtsi
                fi
        fi
        printf "Conver script to dts ok.\n"
        # It'is used for debug dtb
        $DTC_COMPILER ${DTC_FLAGS} -I dtb -O dts -o ${LICHEE_KERN_DIR}/output/.sunxi.dts ${LICHEE_KERN_DIR}/output/sunxi.dtb
        return
show_help()
    printf "
    Build script for Lichee platform
    Invalid Options:
    help         - show this help
    kernel       - build kernel
    modules      - build kernel module in modules dir
    clean        - clean kernel and modules
build_nand()
    NAND_ROOT=${LICHEE_KDIR}/modules/nand
    ${MAKE} -C modules/nand LICHEE_MOD_DIR=${LICHEE_MOD_DIR} \
        LICHEE_KDIR=${LICHEE_KDIR} \
        CONFIG_CHIP_ID=${CONFIG_CHIP_ID} install
gpu_message()
    echo -ne "\033[34;1m"
    echo "[GPU]: $1"
    echo -ne "\033[0m"
build_gpu()
    GPU_TYPE=`fgrep CONFIG_SUNXI_GPU_TYPE ${LICHEE_KDIR}/.config 2>/dev/null | cut -d \" -f 2`
    if [ "X$GPU_TYPE" = "XNone" -o "X$GPU_TYPE" = "X" ]; then
        gpu_message "No GPU type is configured in ${LICHEE_KDIR}/.config."
        return
    fi
    gpu_message "Building $GPU_TYPE device driver..."
    if [ "X${LICHEE_PLATFORM}" = "Xandroid" -o "X${LICHEE_PLATFORM}" = "Xsecureandroid" ] ; then
        TMP_OUT=$OUT
        TMP_TOP=$TOP
        unset OUT
        unset TOP
    fi
    ${MAKE} -C modules/gpu LICHEE_MOD_DIR=${LICHEE_MOD_DIR} LICHEE_KDIR=${LICHEE_KDIR}
        export OUT=$TMP_OUT
        export TOP=$TMP_TOP
    fi
    gpu_message "$GPU_TYPE device driver has been built."
clean_gpu()
        gpu_message "No GPU type is configured in .config."
        return
    fi
    gpu_message "Cleaning $GPU_TYPE device driver..."
    ${MAKE} -C modules/gpu LICHEE_MOD_DIR=${LICHEE_MOD_DIR} LICHEE_KDIR=${LICHEE_KDIR} clean
    gpu_message "$GPU_TYPE device driver has been cleaned."
build_check()
    if [ "x$SUNXI_CHECK" = "x1" ];then
        SUNXI_SPARSE_CHECK=1
        SUNXI_SMATCH_CHECK=1
        SUNXI_STACK_CHECK=1
    fi
    if [ "x$SUNXI_SPARSE_CHECK" = "x1" ] && [ -f ../tools/codecheck/sparse/sparse ];then
        echo "\n\033[0;31;1mBuilding Round for sparse check...\033[0m\n\n"
        CHECK="../tools/codecheck/sparse/sparse"
        ${MAKE} CHECK=${CHECK} ARCH=${ARCH} CROSS_COMPILE="${CCACHE_Y}${CROSS_COMPILE}" -j${LICHEE_JLEVEL} \
                C=2 all modules 2>&1|tee output/build_sparse.txt
        cat output/build_sparse.txt|egrep -w '(warn|error|warning)' >output/warn_sparse.txt
    fi
    if [ "x$SUNXI_SMATCH_CHECK" = "x1" ]&& [ -f ../tools/codecheck/smatch/smatch ];then
        echo "\n\033[0;31;1mBuilding Round for smatch check...\033[0m\n\n"
        CHECK="../tools/codecheck/smatch/smatch --full-path --no-data -p=kkernel"
                C=2 all modules 2>&1|tee output/build_smatch.txt
        cat output/build_smatch.txt|egrep -w '(warn|error|warning)' >output/warn_smatch.txt
    fi
    if [ "x$SUNXI_STACK_CHECK" = "x1" ];then
        ${MAKE} ARCH=${ARCH} CROSS_COMPILE="${CCACHE_Y}${CROSS_COMPILE}" -j${LICHEE_JLEVEL} checkstack 2>&1 \
                |tee output/warn_stack.txt
    fi
build_dts(){
    if [ ! -f .config ] ; then
        printf "\n\033[0;31;1mUsing default config ${LICHEE_KERN_DEFCONF_ABSOLUTE} ...\033[0m\n\n"
        ${MAKE} ARCH=${ARCH} defconfig KBUILD_DEFCONFIG=${LICHEE_KERN_DEFCONF_RELATIVE}
    fi
    echo "---build dts for ${LICHEE_CHIP} ${LICHEE_BOARD}-----"
    if [ "x${ARCH}" = "xarm" ];then
        dts_path="arch/arm/boot/dts"
        dts_path="arch/arm64/boot/dts/sunxi"
        prefix="sunxi/"
    fi
    dtb_file=board.dtb
    dts_file=board.dts
    if [ ! -f $dts_path/$dts_file ];then
        dtb_file="${LICHEE_CHIP}-${LICHEE_BOARD}.dtb"
        dts_file="${LICHEE_CHIP}-${LICHEE_BOARD}.dts"
    fi
        dts_file="${LICHEE_CHIP}-soc.dts"
        dtb_file="${LICHEE_CHIP}-soc.dtb"
    fi
    ${MAKE} ARCH=${ARCH} ${prefix}${dtb_file}
build_kernel()
    echo "Building kernel"
    cd ${LICHEE_KDIR}
    rm -rf output/
    echo "${LICHEE_MOD_DIR}"
    mkdir -p ${LICHEE_MOD_DIR}
    # uImage is arm architecture specific target
    local arch_target=""
    if [ "${ARCH}" = "arm" ]; then
        arch_target="uImage dtbs"
        arch_target="all"
    fi
    #exchange sdc0 and sdc2 for dragonBoard card boot
    local check_cardboot=false
    local SYS_CONFIG_FILE=""
    if [ "x$build_system" == "xlichee" ]; then
        [ "x${LICHEE_PLATFORM}" == "xdragonboard" -o "x${LICHEE_PLATFORM}" == "xdragonmat" ] && check_cardboot=true
        SYS_CONFIG_FILE=$localpath/../../tools/pack/chips/${LICHEE_CHIP}/configs/${LICHEE_BOARD}/sys_config.fex
        [ "x${LICHEE_PLATFORM}" == "xlinux" ] && [ "x${LICHEE_LINUX_DEV}" == "xdragonboard" -o "x${LICHEE_LINUX_DEV}" == "xdragonmat" ] && check_cardboot=true
        SYS_CONFIG_FILE=${LICHEE_BOARD_CONFIG_DIR}/sys_config.fex
    fi
    if [ "x$check_cardboot" == "xtrue" ]; then
        local DTS_PATH=./arch/${ARCH}/boot/dts
        [ "x$ARCH" == "xarm64" ] && DTS_PATH=$DTS_PATH/sunxi
        fi
        # if find dragonboard_test=1 in sys_config.fex ,then will exchange sdc0 and sdc2
        local card_boot=$(awk -F= '/^dragonboard_test[[:space:]]*=/{gsub(/[[:blank:]]*/,"",$2);print $2}' $SYS_CONFIG_FILE)
        if [ "x$card_boot" == "x1" ]; then
            echo "exchange sdc0 and sdc2 for dragonboard card boot"
            ./scripts/exchange-sdc0-sdc2-for-dragonboard.sh ${DTS_PATH}/${LICHEE_CHIP}.dtsi
        fi
    fi
    fi
    if [ "x$PACK_TINY_ANDROID" = "xtrue" ]; then
        ARCH=${ARCH} scripts/kconfig/merge_config.sh .config \
            linaro/configs/sunxi-tinyandroid.conf
    fi
    if [ "x$PACK_BSPTEST" != "x" -o "x$BUILD_SATA" != "x" -o "x$LICHEE_LINUX_DEV" = "xsata" ]; then
            if [ -f linaro/configs/sunxi-common.conf ];then
            fi
            if [ -f linaro/configs/sunxi-sata.conf ];then
        fi
        if [ -f linaro/configs/sunxi-sata-${LICHEE_CHIP}.conf ];then
        fi
        if [ -f linaro/configs/sunxi-sata-${ARCH}.conf ];then
        fi
    fi
    ${MAKE} ARCH=${ARCH} CROSS_COMPILE="${CCACHE_Y}${CROSS_COMPILE}" -j${LICHEE_JLEVEL} ${arch_target} modules
    build_check
    update_kern_ver
    do_init_to_dts
    #The Image is origin binary from vmlinux.
    if [ -f arch/${ARCH}/boot/Image ]; then
        cp -vf arch/${ARCH}/boot/Image output/bImage
    fi
    if [ -f arch/${ARCH}/boot/zImage ] || [ -f arch/${ARCH}/boot/uImage ]; then
        cp -vf arch/${ARCH}/boot/[zu]Image output/
    fi
    if [ -f arch/${ARCH}/boot/Image.gz ]; then
        cp -vf arch/${ARCH}/boot/Image.gz output/
    fi
    echo "Copy rootfs.cpio.gz for ${ARCH}"
        cp -f rootfs_32bit.cpio.gz output/rootfs.cpio.gz
        cp -f rootfs.cpio.gz output/rootfs.cpio.gz
    fi
    cp .config output/
    tar -jcf output/vmlinux.tar.bz2 vmlinux
    for file in $(find drivers sound crypto block fs security net -name "*.ko"); do
        cp $file ${LICHEE_MOD_DIR}
    done
    cp -f Module.symvers ${LICHEE_MOD_DIR}
build_modules()
    echo "Building modules"
    if [ ! -f include/generated/utsrelease.h ]; then
        printf "Please build kernel first!\n"
        exit 1
    fi
    update_kern_ver
    build_nand
    build_gpu
regen_rootfs_cpio()
    echo "regenerate rootfs cpio"
    cd ${LICHEE_KDIR}/output
    if [ -x "../scripts/build_rootfs.sh" ]; then
        ../scripts/build_rootfs.sh e ./rootfs.cpio.gz > /dev/null
        echo "No such file: scripts/build_rootfs.sh"
        exit 1
    fi
    mkdir -p ./skel/lib/modules/${KERNEL_VERSION}
    if [ -e ${LICHEE_MOD_DIR}/nand.ko ]; then
        cp ${LICHEE_MOD_DIR}/nand.ko ./skel/lib/modules/${KERNEL_VERSION}
        if [ $? -ne 0 ]; then
            echo "copy nand module error: $?"
            exit 1
        fi
    fi
    ko_file=`find ./skel/lib/modules/$KERNEL_VERSION/ -name *.ko`
    if [ ! -z "$ko_file" ]; then
            ${STRIP} -d ./skel/lib/modules/$KERNEL_VERSION/*.ko
    fi
    rm -f rootfs.cpio.gz
    ../scripts/build_rootfs.sh c rootfs.cpio.gz > /dev/null
    rm -rf skel
    cd - > /dev/null
build_ramfs()
    local bss_sz=0;
    local bss_offset=0;
    local bss_size=0;
    local CHIP="";
    local BIMAGE="output/bImage";
    local RAMDISK="output/rootfs.cpio.gz";
    local DTB="output/sunxi.dtb";
    local BASE="";
    local RAMDISK_OFFSET="";
    local KERNEL_OFFSET="";
    # update rootfs.cpio.gz with new module files
    regen_rootfs_cpio
    CHIP=`echo ${LICHEE_CHIP} | sed -e 's/.*\(sun[0-9x]*i\).*/\1/g'`;
    if [ "${CHIP}" = "sun9i" ]; then
        BASE="0x20000000";
        BASE="0x40000000";
    fi
        KERNEL_OFFSET="0x8000";
    elif [ "${ARCH}" = "arm64" ]; then
        KERNEL_OFFSET="0x80000";
    fi
    if [ -f vmlinux ]; then
        bss_offset=`${CROSS_COMPILE}readelf -S vmlinux | \
            awk  '/\.bss/ {print $5}'`;
        bss_size=`${CROSS_COMPILE}readelf -S vmlinux | \
            awk  '/\.bss/ {print $6}'`;
        # If linux-4.9 the bss_size will be in next line
        if [ -z "$bss_size" ]; then
                 awk  '/\.bss/ {getline var; print var}' | awk '{print $1}'`;
        fi
        bss_sz=$[ $((16#$bss_offset))+$((16#$bss_size))]
    fi
    # If the size of bImage larger than 16M, will offset 0x02000000
    if [ ${bss_sz} -gt $((16#1000000)) ]; then
        RAMDISK_OFFSET="0x02000000";
        RAMDISK_OFFSET="0x01000000";
    fi
    DTB_OFFSET="0x04000000";
    ${MKBOOTIMG} --kernel ${BIMAGE} \
        --ramdisk ${RAMDISK} \
        --dtb ${DTB} \
        --board ${CHIP}_${ARCH} \
        --base ${BASE} \
        --kernel_offset ${KERNEL_OFFSET} \
        --ramdisk_offset ${RAMDISK_OFFSET} \
        --dtb_offset ${DTB_OFFSET} \
        --header_version 0x2 \
        -o output/boot.img
    # If uboot use *bootm* to boot kernel, we should use uImage.
    echo build_ramfs
    echo "Copy boot.img to output directory ..."
    cp output/boot.img ${LICHEE_PLAT_OUT}
    cp output/vmlinux.tar.bz2 ${LICHEE_PLAT_OUT}
    if [ -f output/zImage ] || [ -f output/uImage ]; then
        cp output/[zu]Image ${LICHEE_PLAT_OUT}
    fi
    if [ ! -f output/arisc ]; then
        echo "arisc" > output/arisc
    fi
    cp output/arisc ${LICHEE_PLAT_OUT}
    cp output/.sunxi.dts ${LICHEE_PLAT_OUT}
    cp output/sunxi.dtb ${LICHEE_PLAT_OUT}
gen_output()
    if [ "x${LICHEE_PLATFORM}" = "xandroid" ] ; then
        echo "Copy modules to target ..."
        rm -rf ${LICHEE_PLAT_OUT}/lib
        cp -rf ${LICHEE_KDIR}/output/* ${LICHEE_PLAT_OUT}
        return
    fi
    if [ -d ${LICHEE_BR_OUT}/target ] ; then
        local module_dir="${LICHEE_BR_OUT}/target/lib/modules"
        rm -rf ${module_dir}
        mkdir -p ${module_dir}
        cp -rf ${LICHEE_MOD_DIR} ${module_dir}
    fi
    echo "$0"
clean_kernel()
    clarg="clean"
    if [ "x$1" == "xdistclean" ]; then
        clarg="distclean"
    fi
    echo "Cleaning kernel, arg: $clarg ..."
    ${MAKE} ARCH=${ARCH} "$clarg"
    rm -rf output/*
    echo
clean_modules()
    echo "Cleaning modules ..."
    clean_gpu
    echo
#                      Main Runtine
case "$1" in
    kernel)
        build_kernel
    modules)
        build_modules
    clean|distclean)
        clean_modules
        clean_kernel "$1"
    dts)
        build_dts
        build_kernel
        build_modules
        build_ramfs
        gen_output
        echo -e "\n\033[0;31;1m${LICHEE_CHIP} compile Kernel successful\033[0m\n\n"
esac
继续跟踪, 执行 ./build.sh 之后,是根据 longan/kernel/linux-4.9/rootfs.cpio.gz 为基础,再把 ko 文件打包到里面去,建立新的 longan/kernel/linux-4.9/output/rootfs.cpio.gz  。
楼主 #22 2022-02-12 22:45:26
X3
已发帖子: 85
重新打包: make_ext4fs -l 128M -s out/pack_out/rootfs3.fex test/dragonboard/rootfs
屏蔽 build/pack 的 函数 function do_prepare()
#不删除 out/pack_out/ 目录
	if [ "x" != "x${LICHEE_PACK_OUT_DIR}" ]; then
		rm -rf ${LICHEE_PACK_OUT_DIR}
	fi
再将 device/config/chips/t509/configs/a3/dragonboard/sys_partition.fex 里面的 rootfs.fex 改为 rootfs3.fex
接着执行 ./build.sh pack 打包烧录,一切正常。
楼主 #23 2022-02-13 13:19:33
X3
已发帖子: 85
根据 kernel/linux-4.9/rootfs/init
#!/bin/sh
mount -t proc proc /proc
mount -t sysfs sysfs /sys
mount -t devtmpfs none /dev
exec < /dev/console > /dev/console 2>&1
for parm in $(cat /proc/cmdline); do
        case $parm in
        ramfs)
                RAMFS_MODE=1
        root=*)
                ROOT_DEVICE=`echo $parm | awk -F\= '{print $2}'`
        console=*)
                CONSOLE_DEVICE=`echo $parm | awk -F\= '{print $2}' | awk -F\, '{print $1}'`
        gpt=*)
                GPT_SUPPORT=`echo $parm | awk -F\= '{print $2}'`
        esac
done
if [ "x$ROOT_DEVICE" = "x" ]; then
        ROOT_DEVICE=autoconfig
fi
echo [$0]: "getty is $CONSOLE_DEVICE"
echo [$0]: RootDevice is \"$ROOT_DEVICE\" , GPT_SUPPORT=$GPT_SUPPORT
#set the default device for autoconfig
if [ "x$GPT_SUPPORT" = "x1" ]; then
        NAND_DEF_DEVICE=nand0p5
        SDMMC_DEF_DEVICE=mmcblk0p5
        NAND_DEF_DEVICE=nandd
        SDMMC_DEF_DEVICE=mmcblk0p7
fi
# $1: the name of block device
wait_for_ready()
        CNT=10
        while true; do
                if [ -b $1 ]; then
                        return 0
                fi
                echo [$0]: Wait $1 ready ...
                CNT=`expr $CNT - 1`
                if [ $CNT -eq 0 ]; then
                        echo [$0]: $1 is not available!
                        return 1
                fi
                sleep 1
        done
# $1: The block device
do_mount()
        e2fsck -y $1
        mount -o rw,noatime,nodiratime,norelatime,noauto_da_alloc,barrier=0,data=ordered -t ext4 $1 /mnt
                echo [$0]: Failed to mount $1!
        fi
load_nand()
        echo [$0]: Try to load Nand ...
        NAND_MODULE=/lib/modules/$(uname -r)/nand.ko
        if [ ! -f $NAND_MODULE ]; then
                echo [$0]: $NAND_MODULE does not exist!
#               return 1
        fi
        insmod $NAND_MODULE
                echo [$0]: $NAND_MODULE is invalid!
#               return 2
        fi
        wait_for_ready $1
        if [ $? -eq 0 ]; then
                do_mount $1
        fi
load_emmc()
        echo [$0]: Try to load EMMC ...
        wait_for_ready $1
                do_mount $1
        fi
case $ROOT_DEVICE in
        /dev/nand*|/dev/system)
                load_nand $ROOT_DEVICE
        /dev/mmc*)
                load_emmc $ROOT_DEVICE
        autoconfig*)
                sleep 1;
                echo [$0]: default device $SDMMC_DEF_DEVICE $NAND_DEF_DEVICE
                if cat /proc/partitions|grep "$SDMMC_DEF_DEVICE" >/dev/null;then
                        magic_num=$(hexdump -s 1292 -n 2 -x /dev/$SDMMC_DEF_DEVICE|head -1|awk '{print $2 }')
                        echo $magic_num|grep "f30a" >/dev/null
                                echo [$0]: "magic_num[f30a] match!!!"
                                load_emmc /dev/$SDMMC_DEF_DEVICE
                        fi
                        load_nand /dev/$NAND_DEF_DEVICE
                fi
                echo [$0]: "Use default type"
esac
[ -x /mnt/init ] && exec switch_root /mnt /init
/sbin/getty -L $CONSOLE_DEVICE 115200 vt100 -n -l /bin/ash
先根据 bootargs 参数:
[    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x05000000 initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p4 init=/init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:boot@mmcblk0p3:rootfs@mmcblk0p4:klog@mmcblk0p5:UDISK@mmcblk0p6 cma=8M snum=0c001415a0c0876220d mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.serialno=0c001415a0c0876220d androidboot.hardware=sun50iw10p1 boot_type=2 androidboot.boot_type=2 androidboot.secure_os_exist=0 androidboot.trustchain=false gpt=1 uboot_message=2018.05(02/07/2022-22:08:09) disp_reserve=4096000,0x7bf65080 bootreason=unknow
① 找出 root dev /dev/mmcblk0p4 然后挂载到 /mnt 目录,
② 如果存在 /mnt/init 并可执行,那么switch_root 到 /mnt/目录,并执行 /init 命令
③ 确保 rootfs 存在 /dev/console /dev/null 设备文件
楼主 #24 2022-02-13 19:37:55
X3
已发帖子: 85
cat /dev/fb1 > fb1.rgb
电脑用 yuview 显示framebuffer图像,颜色格式 BGRA。
楼主 #25 2022-02-13 21:04:52
X3
已发帖子: 85
编译 longan,配置为 android 编译环境:
sw509@ubuntu:/opt/sw509/longan$ ./build.sh config
Welcome to mkscript setup progress
All available platform:
   0. android
   1. linux
Choice [linux]: 0
All available ic:
   0. a133
   1. t509
Choice [t509]: 1
All available board:
   0. a3
   1. demo
   2. demo2
   3. fpga
   4. qa
   5. srandway
   6. ver
Choice [a3]: 0
INFO: kernel defconfig: generate /opt/sw509/longan/kernel/linux-4.9/.config by /opt/sw509/longan/kernel/linux-4.9/arch/arm64/configs/sun50iw10p1smp_t509_android_defconfig
*** Default configuration is based on 'sun50iw10p1smp_t509_android_defconfig'
# configuration written to .config
编译for安卓内核:
ACTION List: mklichee;========
Execute command: mklichee
INFO: ----------------------------------------
INFO: build lichee ...
INFO: chip: sun50iw10p1
INFO: platform: android
INFO: kernel: linux-4.9
INFO: board: a3
INFO: output: /opt/sw509/longan/out/t509/a3/android
INFO: build dtbo ...
debug: main,line:309
15757 blocks
15758 blocks
build_ramfs
sun50iw10p1 compile Kernel successful
INFO: build kernel OK.
INFO: build rootfs ...
INFO: skip make rootfs for android
INFO: build lichee OK.
sw509@ubuntu:/opt/sw509/android$ source build/envsetup.sh
including device/softwinner/common/vendorsetup.sh
longan project path: /opt/sw509/longan
sw509@ubuntu:/opt/sw509/android$ lunch
You're building on Linux
Lunch menu... pick a combo:
     1. aosp_arm-eng
     2. aosp_arm64-eng
     3. aosp_blueline-userdebug
     4. aosp_bonito-userdebug
     5. aosp_car_arm-userdebug
     6. aosp_car_arm64-userdebug
     7. aosp_car_x86-userdebug
     8. aosp_car_x86_64-userdebug
     9. aosp_cf_arm64_phone-userdebug
     10. aosp_cf_x86_64_phone-userdebug
     11. aosp_cf_x86_auto-userdebug
     12. aosp_cf_x86_phone-userdebug
     13. aosp_cf_x86_tv-userdebug
     14. aosp_crosshatch-userdebug
     15. aosp_marlin-userdebug
     16. aosp_sailfish-userdebug
     17. aosp_sargo-userdebug
     18. aosp_taimen-userdebug
     19. aosp_walleye-userdebug
     20. aosp_walleye_test-userdebug
     21. aosp_x86-eng
     22. aosp_x86_64-eng
     23. beagle_x15-userdebug
     24. ceres_b1-eng
     25. ceres_b1-user
     26. ceres_b1-userdebug
     27. ceres_b3-eng
     28. ceres_b3-user
     29. ceres_b3-userdebug
     30. ceres_c3-eng
     31. ceres_c3-user
     32. ceres_c3-userdebug
     33. ceres_c4-eng
     34. ceres_c4-user
     35. ceres_c4-userdebug
     36. ceres_perf1-user
     37. ceres_perf1-userdebug
     38. ceres_perf2-user
     39. ceres_perf2-userdebug
     40. ceres_qa-user
     41. ceres_qa-userdebug
     42. ceres_verify-user
     43. ceres_verify-userdebug
     44. fuchsia_arm64-eng
     45. fuchsia_x86_64-eng
     46. hikey-userdebug
     47. hikey64_only-userdebug
     48. hikey960-userdebug
     49. hikey960_tv-userdebug
     50. hikey_tv-userdebug
     51. m_e_arm-userdebug
     52. mini_emulator_arm64-userdebug
     53. mini_emulator_x86-userdebug
     54. mini_emulator_x86_64-userdebug
     55. pluto_a3-eng
     56. pluto_a3-user
     57. pluto_a3-userdebug
     58. pluto_demo-eng
     59. pluto_demo-user
     60. pluto_demo-userdebug
     61. pluto_demo2-eng
     62. pluto_demo2-user
     63. pluto_demo2-userdebug
     64. pluto_qa-eng
     65. pluto_qa-userdebug
     66. poplar-eng
     67. poplar-user
     68. poplar-userdebug
     69. qemu_trusty_arm64-userdebug
     70. uml-userdebug
Which would you like? [aosp_arm-eng] 55
PLATFORM_VERSION_CODENAME=REL
PLATFORM_VERSION=10
TARGET_PRODUCT=pluto_a3
TARGET_BUILD_VARIANT=eng
TARGET_BUILD_TYPE=release
TARGET_ARCH=arm
TARGET_ARCH_VARIANT=armv7-a-neon
TARGET_CPU_VARIANT=cortex-a7
HOST_ARCH=x86_64
HOST_2ND_ARCH=x86
HOST_OS=linux
HOST_OS_EXTRA=Linux-5.4.0-97-generic-x86_64-Ubuntu-18.04.2-LTS
HOST_CROSS_OS=windows
HOST_CROSS_ARCH=x86
HOST_CROSS_2ND_ARCH=x86_64
HOST_BUILD_TYPE=release
BUILD_ID=QP1A.191105.004
OUT_DIR=out
sw509@ubuntu:/opt/sw509/android$ make
PLATFORM_VERSION=10
TARGET_ARCH=arm
HOST_ARCH=x86_64
HOST_2ND_ARCH=x86
HOST_OS=linux
HOST_CROSS_ARCH=x86
OUT_DIR=out
[ 99% 11233/11247] glob vendor.nxp.nxpnfc-V1.0-java.prof
安卓编译,保证 android 的同级目录有 longan 即可。
最近编辑记录 X3 (2022-02-13 21:06:20)
楼主 #26 2022-02-14 13:57:08
X3
已发帖子: 85
./build.sh brandy 之后,devicetree居然是这个配置:
CONFIG_OF_BOARD:        │
  │ If this option is enabled, the device tree will be provided by                                             │
  │ the board at runtime if the board supports it, instead of being                                            │
  │ bundled with the image.        │
  │ Symbol: OF_BOARD [=y]        │
  │ Type  : boolean        │
  │ Prompt: Provided by the board at runtime        │
  │   Location:        │
  │     -> Device Tree Control        │
  │       -> Provider of DTB for DT control (<choice> [=y])                                                    │
  │   Defined at dts/Kconfig:88        │
  │   Depends on: <choice> && !SANDBOX [=n]
http://www.wowotech.net/x_project/bubblegum_uboot_device_tree.html
@wowo:谢谢wowo的解答,这样理解也是很有道理。
我考虑的是对于arm soc,boot和kernel看到的设备其实是一样的,而且本来boot就会去修改kernel的dtb(cmdline、ram/initramfs start&sizee),并传递给kernel,分成两份有点重复。
我自己对这个问题的进展:
如果定义了CONFIG_OF_SEPARATE,uboot会去编译CONFIG_DEFAULT_DEVICE_TREE,倒是可以把这个路径指向内核的dts文件,就是目录跨得有点多;
另外还有一个CONFIG_OF_BOARD选项,可以在代码里去指定dtb文件内存地址,不过搜索了uboot目录,几乎没有厂家用这个选项。
当然也听说uboot解析和修改dtb文件效率并不高,分成一大一小不知道会不会更快一些了。
看起来, uboot 和 kernel 应该是共用设备树 。
CONFIG_SUNXI_FDT_ADDR=44000000
# CONFIG_SUNXI_FDT_SAVE is not set
CONFIG_SUNXI_TURNNING_FLASH=y
CONFIG_SUNXI_TURNNING_DRAM=y
# CONFIG_SUNXI_OTA_TURNNING is not set
# CONFIG_SUNXI_DEBUG is not set
# CONFIG_SUNXI_NOR_IMG is not set
CONFIG_SYS_CLK_FREQ=1008000000
CONFIG_SUNXI_ARM64=y
楼主 #27 2022-02-14 18:28:51
X3
已发帖子: 85
Win32 用 FASTBOOT 烧写 A100 eMMC
https://bbs.aw-ol.com/topic/1027
① 准备 fastboot_and_usbdriver.zip
② 电脑USB连接A100 otg,
③ A100 按住 s 上电进入 uboot 命令行,输入 fastboot 命令
④ 电脑出现一个 Android Phone 的USB设备则以驱动,如果未驱动则安装①里面的usbdriver
⑤ 电脑运行① fastboot.exe 命令:
1) 列设备: fastboot devices
2)擦除eMMC分区: fastboot erase xxxx (分区名)
3)烧录文件到eMMC分区: fastboot flash xxx yyyy (xxxx是分区名,yyyy是文件名)
4)重启: fastboot reboot
1644829748964-40254869-a377-42fe-bd91-25f505604946-image[1].png1644829837780-a1db2794-fd48-43a2-80a3-f7b8db759dfa-18b5517d324f249ad025f12f085d203[1].png
最近编辑记录 X3 (2022-02-14 18:30:11)
楼主 #29 2022-02-14 21:31:39
X3
已发帖子: 85
me@ubuntu:/opt/sw509/android$ source build/envsetup.sh
me@ubuntu:/opt/sw509/android$ lunch 55
PLATFORM_VERSION=10
TARGET_ARCH=arm
HOST_ARCH=x86_64
HOST_2ND_ARCH=x86
HOST_OS=linux
HOST_CROSS_ARCH=x86
OUT_DIR=out
me@ubuntu:/opt/sw509/android$ make
PLATFORM_VERSION=10
TARGET_ARCH=arm
HOST_ARCH=x86_64
HOST_2ND_ARCH=x86
HOST_OS=linux
HOST_CROSS_ARCH=x86
OUT_DIR=out
[100% 148/148] out/soong/.bootstrap/bin/soong_build out/soong/build.ninja
cedarc config go file start
cedarx config go file start
sdkVersion: 29
board: pluto
Platform config has NOT been set. Please check it.
cryptolevel: 3
playreadytype:
registry_table has NOT been set. Please check it.
Include_dirs has NOT been set. Please check it.
sdkVersion: 29
board: pluto
[ 56% 353/621] including hardware/aw/camera/Android.mk ...
hardware/aw/camera/3_4/allwinnertech/libAWIspApi/Android.mk:23: warning: Use ceres include libisp_new!
hardware/aw/camera/3_4/allwinnertech/libAWIspApi/libisp_new/Android.mk:66: warning: Use pluto libisp_new!
[ 58% 362/621] including hardware/aw/playready/Android.mk ...
hardware/aw/playready/lib/Android.mk:17: warning: libplayreadydrmplugin=nonsecure/lib32/libplayreadydrmplugin.so
hardware/aw/playready/lib/Android.mk:40: warning: libplayreadydrmplugin=nonsecure/lib64/libplayreadydrmplugin.so
hardware/aw/playready/lib/Android.mk:63: warning: libplayreadypk=nonsecure/lib32/libplayreadypk.so
hardware/aw/playready/lib/Android.mk:87: warning: libplayreadypk=nonsecure/lib64/libplayreadypk.so
[ 99% 620/621] finishing build rules ...
platform_testing/build/tasks/tests/instrumentation_test_list.mk: warning: continuous_instrumentation_tests: Unknown installed file for module 'NexusLauncherOutOfProcTests'
platform_testing/build/tasks/tests/instrumentation_test_list.mk: warning: continuous_instrumentation_tests: Unknown installed file for module 'NexusLauncherDebug'
platform_testing/build/tasks/tests/instrumentation_test_list.mk: warning: continuous_instrumentation_tests: Unknown installed file for module 'NexusLauncherTests'
platform_testing/build/tasks/tests/platform_test_list.mk: warning: platform_tests: Unknown installed file for module 'LauncherRotationStressTest'
platform_testing/build/tasks/tests/platform_test_list.mk: warning: platform_tests: Unknown installed file for module 'PlatformScenarioTests'
FAILED: ninja: 'device/softwinner/pluto-a3/kernel', needed by 'out/target/product/pluto-a3/kernel', missing and no known rule to make it
20:35:31 ninja failed with: exit status 1
#### failed to build some targets (01:47 (mm:ss)) ####
一脸茫然。。。
楼主 #30 2022-02-14 21:33:19
X3
已发帖子: 85
me@ubuntu:/opt/sw509/android$ cp ../longan/out/t509/a3/android/bImage device/softwinner/pluto-a3/kernel
me@ubuntu:/opt/sw509/android$ cp ../longan/out/t509/a3/android/* device/softwinner/pluto-a3/
缺啥复制啥,好险 make 可以继续了。。。
楼主 #31 2022-02-14 22:14:40
X3
已发帖子: 85
    fi
make_ext4fs  不能打包有设备文件的文件夹, 比如 /dev/console,/dev/null 就不能打包成 ext4 文件系统了。
用 mkfs.ext4 可以:
mkfs.ext4 -d /opt/a133/buildroot/output/target -r 1 -N 0 -m 5 -L "rootfs" -O ^64bit rootfs4a.fex "72M"
/opt/a133/buildroot/output/target 需要:
① 把 /sbin/init 复制到 /init
② 存在 /dev/console,/dev/null 等设备文件
这样就可以用 dragon 命令打包成 img文件了。
楼主 #32 2022-02-15 10:12:07
X3
已发帖子: 85
X3 说:
晕,居然是执行 extract-bsp 代替这个命令,掩面泪过,浪费一天时间。
楼主 #33 2022-02-15 11:47:51
X3
已发帖子: 85
$ lunch 55
$ extract-bsp
$ make
$ pack
总结一下,就是这几步了。
楼主 #34 2022-02-16 10:45:46
X3
已发帖子: 85
# insmod /lib/modules/4.9.170/pvrsrvkm.ko
[   42.148898] pvrsrvkm gpu: set gpu core rate:504000000 freq:504000000 dfs:0x00000001
[   42.157608] pvrsrvkm gpu: set gpu core rate:504000000 freq:472500000 dfs:0x00000002
[   42.166236] pvrsrvkm gpu: set gpu core rate:504000000 freq:441000000 dfs:0x00000004
[   42.174857] pvrsrvkm gpu: set gpu core rate:252000000 freq:252000000 dfs:0x00000001
[   42.183663] PVR_K:  1129: Read BVNC 22.102.54.38 from HW device registers
[   42.191314] PVR_K:  1129: RGX Device initialised with BVNC 22.102.54.38
[   42.200260] [drm] Initialized pvr 1.10.5260539 20170530 on minor 0
# insmod /lib/modules/4.9.170/dc_sunxi.ko
[   50.899788] Found usable fbdev device ():
[   50.899788] range (physical) = 0xff800000-0xfffd0000
[   50.899788] size (bytes)     = 0x7d0000
[   50.899788] xres x yres      = 1280x800
[   50.899788] xres x yres (v)  = 1280x1600
[   50.899788] img pix fmt      = 89
[   50.899788] flipping?        = 1
mount -t debugfs none /sys/kernel/debug
可是这个目录并没有文件:
cat /sys/kernel/debug/sunxi_gpu/dump
参考: Linux_GPU_开发指南.pdf
楼主 #35 2022-02-18 00:04:13
X3
已发帖子: 85
  partition_name  : private
  partition_size  : 1024
  partition_name  : recovery
  partition_size  : 32768
  downloadfile  : recovery.fex
  recovery.fex size : 24 byte
  partition_name  : UDISK
/opt/sw509/tina/scripts/pack_img.sh: line 1466: [: Feb: integer expression expected
/opt/sw509/tina/scripts/pack_img.sh: line 1472: [: Feb: integer expression expected
/opt/sw509/tina/scripts/pack_img.sh: line 1484: [: Feb: integer expression expected
ERROR: boot0 files are all invalid files, now exit
楼主 #36 2022-02-18 15:42:26
X3
已发帖子: 85
[ctp_para]
ctp_used = 1
ctp_name = "ft5x_ts"
ctp_twi_id = 0
ctp_twi_addr = 0x38
ctp_screen_max_x = 800
ctp_screen_max_y = 480
ctp_revert_x_flag = 0
ctp_revert_y_flag = 0
ctp_exchange_x_y_flag = 0
ctp_int_port = port:PB03<5><default><default><default>
ctp_wakeup = port:PB04<1><default><default><1>
ctp_io_port = port:PB03<0><default><default><default>
[ctp_list_para]
ctp_det_used = 1
ft5x_ts = 1
gt82x = 0
gslX680 = 0
gt9xx_ts = 0
FT6336 驱动不了,无法中断,尴尬。
楼主 #37 2022-05-22 18:59:54
X3
已发帖子: 85
开始怼 ubuntu18.04,
(WW) Warning, couldn't open module fbdev
(EE) Failed to load module "fbdev" (module does not exist, 0)
Fatal server error:
(EE) no screens found(EE)
So I installed the missing fbdev module (took me some time to figure out the exact name):
解决方案:
sudo apt install xserver-xorg-video-fbdev
参考: https://askubuntu.com/questions/1213538/ee-no-screens-found-when-startx
#38 2022-05-24 19:37:08
qianniao29
已发帖子: 29
楼主有渠道可以买这颗芯片吗,也想做块板子玩玩
#39 2023-01-06 14:11:05
benlypan
已发帖子: 49
@X3
您好,请问AIC800G3的SDK能发我一份吗?主要是 spl, u-boot 和 linux-kernel 源码
楼主 #40 2023-05-07 12:48:05
X3
已发帖子: 85
test/dragonboard/rootfs/
修改文件系统
楼主 #41 2023-05-23 09:03:50
X3
已发帖子: 85
掉坑里面了
添加一个预置apk
vendor/aw/public/prebuild/apk/Meeting/Android.mk
# ESFileExplorer
LOCAL_PATH := $(call my-dir)
include $(CLEAR_VARS)
LOCAL_MODULE := Meeting2
LOCAL_MODULE_TAGS := optional
LOCAL_CERTIFICATE := PRESIGNED
#LOCAL_PRODUCT_MODULE := true
LOCAL_DEX_PREOPT := false
#LOCAL_MODULE_PATH := $(TARGET_OUT_VENDOR)/preinstall
LOCAL_MODULE_CLASS := APPS
LOCAL_MODULE_SUFFIX := $(COMMON_ANDROID_PACKAGE_SUFFIX)
LOCAL_SRC_FILES := Meeting2.apk
#LOCAL_PROPRIETARY_MODULE := true
include $(BUILD_PREBUILT)
不小心开启了 LOCAL_PRODUCT_MODULE := true
但是,后来客户不想要这个预置apk了,
device/softwinner/x3-dock2/x3_dock2.mk
禁用了 #PRODUCT_PACKAGES += Meeting2
发现无论怎么make,烧录进去之后发现预置的apk还是自动启动了。
一顿狂搜之后,发现 make productimage 可以强制更新 product.img
$ make productimage
/bin/bash: line 0: cd: too many arguments
PLATFORM_VERSION=10
TARGET_PRODUCT=x3_dock2
TARGET_ARCH=arm64
TARGET_ARCH_VARIANT=armv8-a
TARGET_CPU_VARIANT=generic
TARGET_2ND_ARCH=arm
TARGET_2ND_ARCH_VARIANT=armv8-a
TARGET_2ND_CPU_VARIANT=generic
HOST_ARCH=x86_64
HOST_2ND_ARCH=x86
HOST_OS=linux
HOST_OS_EXTRA=Linux-5.4.0-148-generic-x86_64-Ubuntu-18.04.6-LTS
HOST_CROSS_ARCH=x86
OUT_DIR=out
[100% 82/82] Target product fs image: out/target/product/x3-dock2/product.img
#### build completed successfully (27 seconds) ####
然后按照原来的流程 make && pack 就OK了。
参考: https://gist.github.com/h1code2/d2b8626643b456b3e714ce4a94904b59#file-android_compile_common-md
楼主 #42 2023-05-23 09:09:07
X3
已发帖子: 85
因为 Android.mk 开启 LOCAL_PRODUCT_MODULE := true 会导致 apk打包到 system.img,
即使 device/softwinner/x3-dock2/x3_dock2.mk 关闭此 apk ,
如果不执行 make systemimage 会导致 system.img 一直不更新,所以怎么烧录原来的apk还在里面。
楼主 #43 2023-05-27 21:35:15
X3
已发帖子: 85
读寄存器:
echo 0x05096318 > /sys/class/misc/sunxi-reg/rw/dump
cat /sys/class/misc/sunxi-reg/rw/dump
写寄存器:
echo "0x05096318 0x4c8230A0" > /sys/class/misc/sunxi-reg/rw/write
楼主 #44 2023-06-25 18:16:19
X3
已发帖子: 85
Package libcedarx is missing dependencies for the following libraries:
libasound.so.2
libuapi.so
出现这种问题:
make package/libs/alsa-lib/clean && make package/libs/alsa-lib/install
make package/allwinner/libuapi/clean && make package/allwinner/libuapi/install
