Ubuntu版本:
sudo apt-get install libopencv-dev
test.cpp
#include <opencv2/core/core.hpp>
#include <opencv2/highgui/highgui.hpp>
#include <iostream>
using namespace cv;
using namespace std;
int main( int argc, char** argv )
if( argc != 2)
cout <<" Usage: display_image ImageToLoadAndDisplay" << endl;
return -1;
Mat image;
image = imread(argv[1], CV_LOAD_IMAGE_COLOR); // Read the file
if(! image.data ) // Check for invalid input
cout << "Could not open or find the image" << std::endl ;
return -1;
namedWindow( "Display window", WINDOW_AUTOSIZE );// Create a window for display.
imshow( "Display window", image ); // Show our image inside it.
waitKey(0); // Wait for a keystroke in the window
编译命令行:
g++ -o test test.cpp -lopencv_core -lopencv_imgproc -lopencv_ximgproc -lopencv_highgui -lopencv_stitching -lopencv_imgcodecs
运行:
./test2 /usr/share/help/cs/cheese/figures/cheese.png
参考: https://docs.opencv.org/2.4/doc/tutorials/introduction/display_image/display_image.html
最近编辑记录 raspberryman (2021-02-25 12:00:32)
VC2017 版本:
1. 安装 VC2017
2. OpenCV官网下载 https://opencv.org/releases/ 预编译版本 opencv-4.5.1-vc14_vc15.exe
解压到 D盘
3. 把 D:\opencv\build\x64\vc15\bin 添加到系统PATH
4. 新建工程, 把 D:\opencv\build\include 添加到头文件目录, 把 D:\opencv\build\x64\vc15\lib 添加到库文件目录, 并且把 opencv_world451.lib / opencv_world451d.lib 添加到链接库
工程文件 test.cpp 代码在一楼,
5. 编译运行, 结果和一楼一样。
Qt 版本
1. 安装 VC2017
3. 下载安装 qt-opensource-windows-x86-5.12.3.exe 勾选 VC2017 x64 方案。
4. test.pro 工程文件添加以下代码:
INCLUDEPATH += D:\opencv\build\include
CONFIG(debug, debug|release) {
LIBS += -LD:\opencv\build\x64\vc15\lib -lopencv_world451d
} else {
5. 添加 test.cpp 代码到工程, 编译运行, 结果与一楼一样。
#include <opencv2/imgproc.hpp>
#include <iostream>
using namespace cv;
if( argc != 2)
return -1;
Mat image, image2;
//image = imread(argv[1], CV_LOAD_IMAGE_COLOR); // Read the file
image = imread(argv[1], IMREAD_GRAYSCALE); // Read the file
threshold(image, image2, 128, 255, THRESH_BINARY | THRESH_OTSU);
if(! image2.data ) // Check for invalid input
return -1;
namedWindow( "Display window", WINDOW_AUTOSIZE);// Create a window for display.
imshow( "Display window", image2); // Show our image inside it.
这个demo也不错 https://github.com/murtazahassan/Learn-OpenCV-cpp-in-4-Hours
还有视频教程 https://www.youtube.com/watch?v=2FYm3GOonhk
有人转发到b站: https://www.bilibili.com/video/BV1jA411H7gM
ubuntu编译要改下 main 函数的输出。
g++ -o Chapter8 Chapter8.cpp `pkg-config opencv --libs`
