楼主 #1 2018-07-20 16:28:34
awfans
已发帖子: 264
请问 荔枝派zero V3s主线u-boot 如何修改默认的串口为uart2(PB0/PB1) ?
git clone https://github.com/Lichee-Pi/u-boot.git -b v3s-spi-experimental
代码是上面这里下载到的.
默认是从 PB8,PB9 这组 UART0 输出的,
我现在想改到 PB0, PB1 这组 UART2 输出,
应该如何做到呢?
以下由 @哇酷小二 2021-02-10 添加
相关链接:
荔枝派zero V3S u-boot调试信息从UART1(PE21/PE22)输出没有成功,还遗留什么没有修改? (修改成功,方案在8楼)
http://whycan.com/t_1624.html
楼主 #2 2018-07-20 17:47:45
awfans
已发帖子: 264
Re: 请问 荔枝派zero V3s主线u-boot 如何修改默认的串口为uart2(PB0/PB1) ?
修改了这两个文件:
    modified:   arch/arm/dts/sun8i-v3s-licheepi-zero.dts
 * Copyright (C) 2016 Icenowy Zheng <icenowy@aosc.xyz>
 * This file is dual-licensed: you can use it either under the terms
 * of the GPL or the X11 license, at your option. Note that this dual
 * licensing only applies to this file, and not this project as a
 * whole.
 *  a) This file is free software; you can redistribute it and/or
 *     modify it under the terms of the GNU General Public License as
 *     published by the Free Software Foundation; either version 2 of the
 *     License, or (at your option) any later version.
 *     This file is distributed in the hope that it will be useful,
 *     but WITHOUT ANY WARRANTY; without even the implied warranty of
 *     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 *     GNU General Public License for more details.
 * Or, alternatively,
 *  b) Permission is hereby granted, free of charge, to any person
 *     obtaining a copy of this software and associated documentation
 *     files (the "Software"), to deal in the Software without
 *     restriction, including without limitation the rights to use,
 *     copy, modify, merge, publish, distribute, sublicense, and/or
 *     sell copies of the Software, and to permit persons to whom the
 *     Software is furnished to do so, subject to the following
 *     conditions:
 *     The above copyright notice and this permission notice shall be
 *     included in all copies or substantial portions of the Software.
 *     THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
 *     EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES
 *     OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
 *     NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
 *     HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
 *     WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
 *     FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
 *     OTHER DEALINGS IN THE SOFTWARE.
/dts-v1/;
#include "sun8i-v3s.dtsi"
	model = "Lichee Pi Zero";
	compatible = "licheepi,licheepi-zero", "allwinner,sun8i-v3s";
	aliases {
		serial0 = &uart0;
		serial2 = &uart2;
		spi0 = &spi0;
		ethernet0 = &emac;
	chosen {
		stdout-path = "serial2:115200n8";
&emac {
       phy = <&phy0>;
       phy-mode = "mii";
       allwinner,use-internal-phy;
       allwinner,leds-active-low;
       phy0: ethernet-phy@0 {
               reg = <1>;
&mmc0 {
	pinctrl-0 = <&mmc0_pins_a>;
	pinctrl-names = "default";
	broken-cd;
	bus-width = <4>;
	vmmc-supply = <&reg_vcc3v3>;
&spi0 {
&uart0 {
	pinctrl-0 = <&uart0_pins_a>;
&uart2 {
	pinctrl-0 = <&uart2_pins_a>;
&usb_otg {
	dr_mode = "otg";
&usbphy {
	usb0_id_det-gpio = <&pio 5 6 GPIO_ACTIVE_HIGH>;
    modified:   arch/arm/dts/sun8i-v3s.dtsi
 * whole.
 *     conditions:
#include <dt-bindings/clock/sun8i-v3s-ccu.h>
#include <dt-bindings/reset/sun8i-v3s-ccu.h>
#include <dt-bindings/interrupt-controller/arm-gic.h>
#include <dt-bindings/pinctrl/sun4i-a10.h>
	#address-cells = <1>;
	#size-cells = <1>;
	interrupt-parent = <&gic>;
	cpus {
		#size-cells = <0>;
		cpu@0 {
			compatible = "arm,cortex-a7";
			device_type = "cpu";
			reg = <0>;
			clocks = <&ccu CLK_CPU>;
	timer {
		compatible = "arm,armv7-timer";
		interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>,
			     <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>,
			     <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>,
			     <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>;
	clocks {
		#size-cells = <1>;
		ranges;
		osc24M: osc24M_clk {
			#clock-cells = <0>;
			compatible = "fixed-clock";
			clock-frequency = <24000000>;
		osc32k: osc32k_clk {
			#clock-cells = <0>;
			clock-frequency = <32768>;
	soc {
		compatible = "simple-bus";
		#size-cells = <1>;
		ranges;
		dma: dma-controller@01c02000 {
			compatible = "allwinner,sun8i-v3s-dma";
			reg = <0x01c02000 0x1000>;
			interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&ccu CLK_BUS_DMA>;
			resets = <&ccu RST_BUS_DMA>;
			#dma-cells = <1>;
		syscon: syscon@01c00000 {
			   compatible = "allwinner,sun8i-h3-syscon","syscon";
			   reg = <0x01c00000 0x34>;
		mmc0: mmc@01c0f000 {
			compatible = "allwinner,sun7i-a20-mmc";
			reg = <0x01c0f000 0x1000>;
			clocks = <&ccu CLK_BUS_MMC0>,
				 <&ccu CLK_MMC0>,
				 <&ccu CLK_MMC0_OUTPUT>,
				 <&ccu CLK_MMC0_SAMPLE>;
			clock-names = "ahb",
				      "mmc",
				      "output",
				      "sample";
			resets = <&ccu RST_BUS_MMC0>;
			reset-names = "ahb";
			interrupts = <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>;
			status = "disabled";
			#size-cells = <0>;
		mmc1: mmc@01c10000 {
			reg = <0x01c10000 0x1000>;
			clocks = <&ccu CLK_BUS_MMC1>,
				 <&ccu CLK_MMC1>,
				 <&ccu CLK_MMC1_OUTPUT>,
				 <&ccu CLK_MMC1_SAMPLE>;
				      "mmc",
				      "output",
				      "sample";
			resets = <&ccu RST_BUS_MMC1>;
			interrupts = <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>;
			#size-cells = <0>;
		mmc2: mmc@01c11000 {
			reg = <0x01c11000 0x1000>;
			clocks = <&ccu CLK_BUS_MMC2>,
				 <&ccu CLK_MMC2>,
				 <&ccu CLK_MMC2_OUTPUT>,
				 <&ccu CLK_MMC2_SAMPLE>;
				      "mmc",
				      "output",
				      "sample";
			resets = <&ccu RST_BUS_MMC2>;
			interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>;
			#size-cells = <0>;
		usb_otg: usb@01c19000 {
			compatible = "allwinner,sun8i-h3-musb";
			reg = <0x01c19000 0x0400>;
			clocks = <&ccu CLK_BUS_OTG>;
			resets = <&ccu RST_BUS_OTG>;
			interrupts = <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>;
			interrupt-names = "mc";
			phys = <&usbphy 0>;
			phy-names = "usb";
			extcon = <&usbphy 0>;
		usbphy: phy@01c19400 {
			compatible = "allwinner,sun8i-v3s-usb-phy";
			reg = <0x01c19400 0x2c>,
			      <0x01c1a800 0x4>;
			reg-names = "phy_ctrl",
				    "pmu0";
			clocks = <&ccu CLK_USB_PHY0>;
			clock-names = "usb0_phy";
			resets = <&ccu RST_USB_PHY0>;
			reset-names = "usb0_reset";
			#phy-cells = <1>;
		ccu: clock@01c20000 {
			compatible = "allwinner,sun8i-v3s-ccu";
			reg = <0x01c20000 0x400>;
			clock-names = "hosc", "losc";
			#clock-cells = <1>;
			#reset-cells = <1>;
		rtc: rtc@01c20400 {
			compatible = "allwinner,sun6i-a31-rtc";
			reg = <0x01c20400 0x54>;
			interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>;
		pio: pinctrl@01c20800 {
			compatible = "allwinner,sun8i-v3s-pinctrl";
			reg = <0x01c20800 0x400>;
			interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>;
			gpio-controller;
			#gpio-cells = <3>;
			interrupt-controller;
			#interrupt-cells = <3>;
           emac_rgmii_pins: emac0@0 {
                   allwinner,pins = "PD0", "PD1", "PD2", "PD3",
                                   "PD4", "PD5", "PD7",
                                   "PD8", "PD9", "PD10",
                                   "PD12", "PD13", "PD15",
                                   "PD16", "PD17";
                   allwinner,function = "emac";
                   allwinner,drive = <SUN4I_PINCTRL_40_MA>;
                   allwinner,pull = <SUN4I_PINCTRL_NO_PULL>;
			uart0_pins_a: uart0@0 {
				pins = "PB8", "PB9";
				function = "uart0";
				bias-pull-up;
			uart2_pins_a: uart2@0 {
				pins = "PB0", "PB1";
				function = "uart2";
				bias-pull-up;
			mmc0_pins_a: mmc0@0 {
				pins = "PF0", "PF1", "PF2", "PF3",
				       "PF4", "PF5";
				function = "mmc0";
				drive-strength = <30>;
				bias-pull-up;
			spi0_pins: spi0 {
				function = "spi0";
		timer@01c20c00 {
			compatible = "allwinner,sun4i-a10-timer";
			reg = <0x01c20c00 0xa0>;
			interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&osc24M>;
		wdt0: watchdog@01c20ca0 {
			reg = <0x01c20ca0 0x20>;
			interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>;
		uart0: serial@01c28000 {
			reg = <0x01c28000 0x400>;
			interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>;
			reg-shift = <2>;
			reg-io-width = <4>;
		uart1: serial@01c28400 {
			reg = <0x01c28400 0x400>;
			interrupts = <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>;
			reg-shift = <2>;
			reg-io-width = <4>;
		uart2: serial@01c28800 {
			reg = <0x01c28800 0x400>;
			interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>;
			reg-shift = <2>;
			reg-io-width = <4>;
		spi0: spi@1c68000 {
			compatible = "allwinner,sun8i-h3-spi";
			reg = <0x01c68000 0x1000>;
			interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&ccu CLK_BUS_SPI0>, <&ccu CLK_SPI0>;
			clock-names = "ahb", "mod";
			pinctrl-0 = <&spi0_pins>;
			resets = <&ccu RST_BUS_SPI0>;
			#size-cells = <0>;
		emac: ethernet@1c30000 {
			compatible = "allwinner,sun8i-h3-emac";
			reg = <0x01c30000 0x104>, <0x01c00030 0x4>;
			reg-names = "emac", "syscon";
			interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>;
			resets = <&ccu RST_BUS_EMAC>, <&ccu RST_BUS_EPHY>;
			reset-names = "ahb", "ephy";
			clocks = <&ccu CLK_BUS_EMAC>, <&ccu CLK_BUS_EPHY>;
			clock-names = "ahb", "ephy";
			#size-cells = <0>;
		gic: interrupt-controller@01c81000 {
			compatible = "arm,cortex-a7-gic", "arm,cortex-a15-gic";
			reg = <0x01c81000 0x1000>,
			      <0x01c82000 0x1000>,
			      <0x01c84000 0x2000>,
			      <0x01c86000 0x2000>;
			interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>;
但是发现串口2并没有数据输出.
#3 2018-07-20 18:21:12
所在地: 微信 whycan_cn
已发帖子: 9,249
修改 arch/arm/dts/sun8i-v3s.dtsi:
                function = "uart0";
                bias-pull-up;
                function = "uart2";
                bias-pull-up;
修改 include/configs/sunxi-common.h
#define CONFIG_CONS_INDEX              1       /* UART0 */
改为:
#define CONFIG_CONS_INDEX              3       /* UART2 */
按上面我的试一试.
楼主 #4 2018-07-20 22:42:15
awfans
已发帖子: 264
根据晕哥提示的修改, 接上串口 UART2 有显示,感觉只是spl 起来了,u-boot并没有启动:
U-Boot SPL 2017.01-rc2-00073-gdd6e874-dirty (Jul 20 2018 - 22:31:29)
DRAM: 64 MiB
Trying to boot from sunxi SPI
楼主 #5 2018-07-21 10:08:03
awfans
已发帖子: 264
diff --git a/arch/arm/dts/sun8i-v3s-licheepi-zero.dts b/arch/arm/dts/sun8i-v3s-licheepi-zero.dts
index 3aec3eb..14376f1 100644
--- a/arch/arm/dts/sun8i-v3s-licheepi-zero.dts
+++ b/arch/arm/dts/sun8i-v3s-licheepi-zero.dts
@@ -50,11 +50,12 @@
        aliases {
                serial0 = &uart0;
+               serial2 = &uart2;
                spi0 = &spi0;
        chosen {
-               stdout-path = "serial0:115200n8";
+               stdout-path = "serial2:115200n8";
@@ -77,6 +78,12 @@
+&uart2 {
+        pinctrl-0 = <&uart2_pins_a>;
+        pinctrl-names = "default";
+        status = "okay";
 &usb_otg {
        dr_mode = "otg";
diff --git a/arch/arm/dts/sun8i-v3s.dtsi b/arch/arm/dts/sun8i-v3s.dtsi
index 8ab3021..f3ebbc6 100644
--- a/arch/arm/dts/sun8i-v3s.dtsi
+++ b/arch/arm/dts/sun8i-v3s.dtsi
@@ -214,6 +214,12 @@
                                bias-pull-up;
+            uart2_pins_a: uart2@0 {
+                pins = "PB0", "PB1";
+                function = "uart2";
+                bias-pull-up;
                                       "PF4", "PF5";
diff --git a/include/configs/sun8i.h b/include/configs/sun8i.h
index 6ac42ac..d5b545f 100644
--- a/include/configs/sun8i.h
+++ b/include/configs/sun8i.h
@@ -27,6 +27,14 @@
        #define CONFIG_SUNXI_USB_PHYS   2
+#define CONFIG_BOOTCOMMAND   "sf probe 0 108000000; "                           \
+                             "sf read 0x41000000 0x0F0000 0x010000; "  \
+                             "sf read 0x41010000 0x300000 0x800000; " \
+                             "bootz 0x41010000 - 0x41000000"
+#define CONFIG_BOOTARGS      "console=ttyS2,115200 earlyprintk panic=5 rootwait mtdparts=spi32766.0:960k(uboot),64k(dtb),1M(background),1M(animation),8M(kernel),-(appendfs) root=/dev/ram0 rdinit=/init vt.global_cursor_default=0"
  * Include common sunxi configuration where most the settings are
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h
index fcecd0b..2b0d9ca 100644
--- a/include/configs/sunxi-common.h
+++ b/include/configs/sunxi-common.h
@@ -274,7 +274,7 @@ extern int soft_i2c_gpio_scl;
 #ifndef CONFIG_CONS_INDEX
-#define CONFIG_CONS_INDEX              1       /* UART0 */
+#define CONFIG_CONS_INDEX              3       /* UART0 */
 #ifdef CONFIG_REQUIRE_SERIAL_CONSOLE
U-Boot 2017.01-rc2-00073-gdd6e874-dirty (Jul 21 2018 - 09:56:51 +0800) Allwinner Technology
Model: Lichee Pi Zero
DRAM:  64 MiB
MMC:   SUNXI SD/MMC: 0
In:    serial@01c28800
Out:   serial@01c28800
Err:   serial@01c28800
Net:   No ethernet found.
No controllers found
device 0 offset 0x110000, size 0x600000
SF: 6291456 bytes @ 0x110000 Read: OK
uboot 终于启动了.
最近编辑记录 awfans (2018-07-21 10:15:02)
#6 2018-11-09 14:47:26
无情一刀
已发帖子: 695
awfans 说:
DRAM: 64 MiB
我也是改为uart2  打印出来是和你的问你一样的 请问你是怎么解决的哦哦
#7 2018-11-09 14:58:06
所在地: 微信 whycan_cn
已发帖子: 9,249
无情一刀 说:
awfans 说:
DRAM: 64 MiB
看5楼图片
#8 2018-11-09 15:27:52
无情一刀
已发帖子: 695
我检查了两遍了 还是一样的结果
#9 2018-11-09 15:34:22
无情一刀
已发帖子: 695
                function = "uart0";
                bias-pull-up;
                function = "uart2";
                bias-pull-up;
这个也都是写了
#10 2018-11-09 15:42:32
所在地: 微信 whycan_cn
已发帖子: 9,249
这是我以前改的, 你再对比看看.
#11 2018-11-09 16:37:43
无情一刀
已发帖子: 695
我对比了下 确实是一样的了 除下面
#define CONFIG_BOOTCOMMAND   "sf probe 0; "                           \
                             "sf read 0x41800000 0x100000 0x10000; "  \
#define CONFIG_BOOTARGS      "console=ttyS2,115200 earlyprintk panic=5 rootwait " \
                             "mtdparts=spi32766.0:1M(uboot)ro,64k(dtb)ro,4M(kernel)ro,-(rootfs) root=31:03 rw rootfstype=jffs2"
我这里就是将ttyS0改为ttyS2 因为以前串口0的时候是没有问题的  所以就是改为ttyS2
其他的都是一样的了
#12 2018-11-09 16:43:14
所在地: 微信 whycan_cn
已发帖子: 9,249
无情一刀 说:
我对比了下 确实是一样的了 除下面
其他的都是一样的了
还没运行到此处, 看log才跑起 spl(uboot0), 还没有跑u-boot主程序呢.
你现在硬件 PB0, PB1 接对了?烧写有没有问题?
#13 2018-11-09 16:59:15
无情一刀
已发帖子: 695
无情一刀 说:
我对比了下 确实是一样的了 除下面
其他的都是一样的了
我以前没有改为串口2的时候  是可以看到企鹅的 可以跑起来   ,烧写还是按着以前串口0的烧写命令一样的  硬件我也看了原理图 没有问题
最近编辑记录 无情一刀 (2018-11-09 17:01:31)
#14 2018-11-09 17:03:49
所在地: 微信 whycan_cn
已发帖子: 9,249
看不出来是什么问题了,你再调试一下, 或者看看有没有路过的大神.
#15 2018-11-09 17:07:19
无情一刀
已发帖子: 695
因为这又是一块硬件  在没有改为串口2之前 这硬件是可以跑起来
#16 2018-11-09 17:12:06
basicdev
已发帖子: 159
无情一刀 说:
这么看来和硬件关系不大吧
#17 2018-11-09 17:27:12
无情一刀
已发帖子: 695
我现在好像是改错 因为这些文件在uboot和内核里面都有
#18 2018-11-09 17:44:47
lilo
已发帖子: 215
无情一刀 说:
https://whycan.cn/files/members/1116/123111.png
这也行...
u-boot和kernel完全是独立的,没有几毛钱关系, 引导kernel启动之后,u-boot就不存在了,
可以说二者水火不容.
#19 2018-11-09 17:56:47
无情一刀
已发帖子: 695
lilo 说:
无情一刀 说:
这也行...
可以说二者水火不容.
现在就是uboot起来了 好像就是内核还是串口0
现在就是应用程序是起来了
#20 2018-11-09 19:03:14
所在地: 微信 whycan_cn
已发帖子: 9,249
无情一刀 说:
lilo 说:
无情一刀 说:
这也行...
可以说二者水火不容.
https://whycan.cn/files/members/1116/33333333.png
现在就是应用程序是起来了
u-boot的bootargs参数 ttyS0 改为 ttyS2,
同时要在设备树开启 uart2.
#21 2018-11-09 19:14:08
无情一刀
已发帖子: 695
无情一刀 说:
lilo 说:
这也行...
可以说二者水火不容.
现在就是应用程序是起来了
同时要在设备树开启 uart2.
现在就是uboot和内核都可以有打印了  但是我的代码里面里面使用printf打印 没有出来  所以还要去查找配置文件系统的  打印输出 ,
#22 2018-11-09 19:33:54
无情一刀
已发帖子: 695
设置文件系统串口主要是在下面的截图在根文本系统/etc/inittab/
最近编辑记录 无情一刀 (2018-11-09 19:34:54)
#23 2018-11-09 21:03:44
所在地: 微信 whycan_cn
已发帖子: 9,249
无情一刀 说:
https://whycan.cn/files/members/1116/22222222.png
能进入命令行吗?能在命令行输入命令行吗?输入 ls cat 这些命令行有反应吗?
#24 2018-11-10 08:53:46
无情一刀
已发帖子: 695
无情一刀 说:
有反应的  就是设置下上面截图的地方 在文件系统中
#25 2018-11-10 09:52:51
所在地: 微信 whycan_cn
已发帖子: 9,249
无情一刀 说:
无情一刀 说:
那问题解决了?
#26 2018-11-10 22:27:26
john78
已发帖子: 220
V3S u-boot调试信息从UART1输出没有成功,还遗留什么没有修改? (修改成功,方案在8楼)
(出处:哇酷开发者社区)
#27 2019-01-15 14:03:56
DavidV3s
已发帖子: 36
[13:56:14.987]ÊÕ¡û¡ô\0
[13:56:15.425]ÊÕ¡û¡ô¡U\0½¼À\0SPL 2017.01-rc2 (Jan 14 2019 - 21:52:58)
DRAM:\0\0MiB
Trying to boot from MMC1
[13:56:15.630]ÊÕ¡û¡ô¡\0U-Boot 2017.01-rc2 (Jan 14 2019 - 21:52:58 -0800) Allwinner Technologù
CPUz   Aüüÿéþþåò ^w÷ (WU^xI q~xq)
]ÿäåüz \éçèåå Pé zåòÿ
DRA]z  lp\0À\0\0W\0\0  WU^xI WD?]]Gz p
\0\0Detected w25q128bv with page size 256 Bùôå÷< åòá÷å ÷éúå t OéB< ôÿôáü q~ ]éB
\0%%º…À¸€¸œ\0- bad CRC, using default environment
y_Ïã\0õð á xppøtp`\0ØÆÀ\0ÆÞÜæÞØÀ\0\0ÞìÀàæÆÀÜ\0`x0)
[13:56:15.740]ÊÕ¡û¡ô`Œ°¼ŒŒà 33000kHz = 33000kHz: (1 * 3MHú * ~~) ? ~
[13:56:15.786]ÊÕ¡û¡ô\0\0   ÷åòéáü@pqærxp``\0ààp\0\0\0æÀàÀÀØ\0``Æ`p800
U-Boot 2017.01-rc2 (Jan 14 2019 - 21:52:58 -0800) Allwinner Technology
DRA]z  ~d À\0\0p\0\0\0\00\0\0\0C: 0
*** Warning - bad CRC, õ÷éþï äåîáõüô åþþéòÿþýåþô
Wåôôéþï õð á xppøtxp üçä çÿþ÷ÿüå (þìÀâæÆÀÜ\0`ð`\0\0ÀÞàÆØÞÆÆp\0f3000kHz =
[13:56:15.853]ÊÕ¡û¡ô 33000kHz: (1 * 3MHz * 66) / 6
In:    serial@01c28800
Err:   serial@01c2xx0p
Y—\0  No ethernet found.
starting USB>>>
^ÿ çÿþôòÿüüåò÷ îÿõþä
\00\0¸à\0ÆÀð\0ào stop autoboot:  2  0
=> ÀÀB  à€€`\0B <INTERRUPT~
}~ àB<pàüÀ€€À€Àظ€À€€€œ€˜€àðÀ€`\0ÀÞ`p€€À€Àظ€À€€€œ€˜€àðÀ\0€`\0ÀÞ`p€€À€Àظ€À€€€œ€˜€àðÀ<R\0UIIUAQù
=> ã8¼`\0€€Àظ€À€€€œ€˜€àðÀ<àÀÀð0¼`<R\0UIIUAQù
=> 8vÜ€À€€€œ€˜€àðÀ<ÀÀà\0<àÀÀðpƒ\0À€€€œ€˜€àðÀ\0ÀÀÀ<R\0UIIUAQù`
}~ |ððÀ€À\0€€€œ€˜€àðÀ\0ÀÀÀ<àÀÀðÀ€ÀÀ€À€€€œ€˜€àðÀ<R\0UIIUAQù
=> î8x8øÀ€ÀÀ€À€€€œ€˜€àðÀ<àÀÀðp€xÀÀ€ÀÀ€À€€€œ€˜€àðÀ<ÀÀ\0€xÀÀÀÀÀ€€€œ€˜€àðÀ<ÀÀ<R\0UIIUAQù`
#28 2019-01-15 14:05:37
DavidV3s
已发帖子: 36
这个乱码是因为什么
#29 2019-01-15 14:09:58
山无棱
已发帖子: 116
DavidV3s 说:
这个乱码是因为什么
是USB转TTL线吗?要么地线没有插好, 要么用了劣质的国产USB转TTL芯片,
当也有可能是板子的问题。
建议用 CP21XX线, 性价比很高, 基本没有发现仿冒品。
#30 2019-01-15 14:13:15
DavidV3s
已发帖子: 36
这个串口用在别的产品上,打印字符输出都正常
#31 2019-01-15 14:14:20
DavidV3s
已发帖子: 36
板子用flash加载也正常,我这个是烧写到TF卡上,TF卡我也换了几个了,都是一样
#32 2019-01-15 14:30:40
所在地: 微信 whycan_cn
已发帖子: 9,249
DavidV3s 说:
用 flash 启动串口正常,但是用 TF 串口就乱码?
#33 2019-01-15 14:33:46
DavidV3s
已发帖子: 36
之前用flash启动过,后来flash拆坏掉了,就做成TF卡启动的了,现在启动就是乱码
#34 2019-01-15 14:35:04
DavidV3s
已发帖子: 36
晕哥,如果我单烧写uboot,不放内核和文件系统,串口是不是也能打印输出
#35 2019-01-15 14:46:46
所在地: 微信 whycan_cn
已发帖子: 9,249
DavidV3s 说:
是的, 烧u-boot串口就可以输出了。
#36 2019-01-18 21:48:46
DavidV3s
已发帖子: 36
U-Boot SPL 2017.01-rc2-g59058e5-dirty (Jan 18 2019 - 05:23:33)
DRAM: 64 MiB
U-Boot 2017.01-rc2-g59058e5-dirty (Jan 18 2019 - 05:23:33 -0800) Allwinner Technology
DRAM:  64 MiB
In:    serial@01c28800
DRAM:  64 MiB
In:    serial@01c28800
Hit any key to stop autoboot:  2  0
=> MC:   SUNXI SD/MMC: 0
Unknown command 'MC:' - try 'help'
=> SF: Detected w25q128bv with page size 252> MC:   SUNXI SD/MMC: >> SF: Detected w25q128bv with page size 252> MC:   SUNXI SD/MMC: >> SF: Detected w25q128bv with page size 252> MC:   SUNXI SD/MMC: >> SF: Detected w25q128bv with page size 252> MC:   SUNXI SD/MMC: >> SF: Detected w25q128bv with page size 252> MC:   SUNXI SD/MMC: >> SF: Detected w25q128bv with page size 252> MC:   SUNXI SD/MMC: >> SF: Detected w25q128bv with page size 252> MC:   SUNXI SD/MMC: >> SF: Detected w25q128bv with page size 252> MC:   SUNXI SD/MMC: >> SF: Detected w25q128bv with page size 252> MC:   SUNXI SD/MMC: >> SF: Detected w25q128bv with page size 252> MC:   SUNXI SD/MMC: >> SF: Detected w25q128bv with page size 252> MC:   SUNXI SD/MMC: >> SF: Detected w25q128bv with page size 252> MC:   SUNXI SD/MMC: >> SF: Detected w25q128bv with page size 252> MC:   SUNXI SD/MMC: >> SF: Detected w25q128bv with page size 252> MC:   SUNXI SD/MMC: >> SF: Detected w25q128bv with page size 252> MC:   SUNXI SD/MMC: >> SF: Detected w25q128bv with page s
#37 2019-01-18 21:50:06
DavidV3s
已发帖子: 36
@晕哥,波特率改成9600,显示没有乱码了,但是有报错。
#38 2019-01-18 22:04:55
所在地: 微信 whycan_cn
已发帖子: 9,249
DavidV3s 说:
可以输入吗?
#39 2019-01-18 22:27:38
DavidV3s
已发帖子: 36
#40 2019-01-18 22:28:42
DavidV3s
已发帖子: 36
不可以输入,一直循环打印这个。。。。。。。
#41 2019-01-18 22:29:55
DavidV3s
已发帖子: 36
@晕哥,这个卡在什么地方了?
#42 2019-01-18 22:35:13
所在地: 微信 whycan_cn
已发帖子: 9,249
只能换块板,或者换条usb线试一试了,usb线可能性大很多,可以逻辑分析仪先抓数据,如果逻辑分析仪抓到的数据没有问题,毫不犹豫换usb线
#43 2019-01-18 22:48:14
DavidV3s
已发帖子: 36
DRAM:  64 MiB
In:    serial@01c28800
device 0 offset 0xf0000, size 0x10000
SF: 65536 bytes @ 0xf0000 Read: OK
device 0 offset 0x300000, size 0x800000
SF: 8388608 bytes @ 0x300000 Read: OK
[22:44:34.025]发→◇ls
[22:44:41.809]发→◇l
#44 2019-01-19 16:28:53
DavidV3s
已发帖子: 36
FluxBB bbcode 测试 ,我对比了下,我下载的https://whycan.cn/files/201712/15/V3s_TFCard.7z,和你截图的log输出的大小不一样,这个有影响吗
#45 2019-01-19 16:37:39
所在地: 微信 whycan_cn
已发帖子: 9,249
环境不同,编译出来的文件尺寸有差异也正常,你用上面的固件串口输入输出正常吗?
#46 2019-01-19 16:39:12
DavidV3s
已发帖子: 36
uboot正常了,但是卡在Starting kernel ...这个地方不动了
#47 2019-01-19 16:44:01
DavidV3s
已发帖子: 36
看了下论坛的其他文章,可能的问题是:
1.串口设置不对
2.内核不对
1.串口是这么设置的
 * (C) Copyright 2014 Chen-Yu Tsai <wens@csie.org>
 * Configuration settings for the Allwinner A23 (sun8i) CPU
 * SPDX-License-Identifier:	GPL-2.0+
#ifndef __CONFIG_H
#define __CONFIG_H
 * A23 specific configuration
#ifdef CONFIG_USB_EHCI
#define CONFIG_USB_EHCI_SUNXI
#ifdef CONFIG_MACH_SUN8I_H3
	#define CONFIG_SUNXI_USB_PHYS	4
#elif defined CONFIG_MACH_SUN8I_A83T
	#define CONFIG_SUNXI_USB_PHYS	3
#elif defined CONFIG_MACH_SUN8I_V3S
	#define CONFIG_SUNXI_USB_PHYS	1
#else
#define CONFIG_BOOTCOMMAND   "setenv bootm_boot_mode sec;"      \
	"load mmc 0:1 0x41000000 zImage;"  \
	"load mmc 0:1 0x41800000 sun8i-v3s-licheepi-zero-dock.dtb;" \
	"bootz 0x41000000 - 0x41800000;"
#define CONFIG_BOOTARGS      "console=ttyS2,115200 panic=5 rootwait mtdparts=spi32766.0:1M(uboot)ro,64k(dtb)ro,6M(kernel)ro,-(rootfs) root=/dev/mmcblk0p2 earlyprintk rw"
#include <configs/sunxi-common.h>
#endif /* __CONFIG_H */
应该没问题。
2。内核有问题,但是是从你那个连接下载的,看你log输出正常,也应该没问题。
#48 2019-01-19 16:44:19
山无棱
已发帖子: 116
DavidV3s 说:
你是自己做的板子?还是荔枝派的板子?
#49 2019-01-19 16:52:29
DavidV3s
已发帖子: 36
自己做的
#50 2019-01-19 16:54:19
所在地: 微信 whycan_cn
已发帖子: 9,249
DavidV3s 说:
自己做的
那你先去 u-boot  .config 里面把ddr和cpu频率都降下来再看,可能是你的板子跑不了那么高速度。
#51 2019-01-19 16:58:39
所在地: 微信 whycan_cn
已发帖子: 9,249
DavidV3s 说:
自己做的
https://whycan.cn/t_699.html
感觉你的问题和这个一毛一样
#52 2019-01-19 17:40:06
DavidV3s
已发帖子: 36
找了半天,没找到:)
#53 2019-01-19 18:28:05
DavidV3s
已发帖子: 36
晕哥,我俩的情况还不一样,我这个原因是串口的输入输出是自反馈电路,设计上的缺陷。我现在是切割开单独连接输入和输出,正常,能进入uboot,也能发送命令。从这个log日志看,跳转到内核后,打印就断掉了。
#54 2019-01-19 18:50:23
所在地: 微信 whycan_cn
已发帖子: 9,249
DavidV3s 说:
你的是flash还是TF卡启动,感觉是 zImage不完整引起,导致解压失败
#55 2019-01-19 20:19:12
DavidV3s
已发帖子: 36
TF卡,https://whycan.cn/files/201712/15/V3s_TFCard.7z,在这下载的,在下载Linux代码,等会编译下,拷进去试试。我也觉得是这个内核有问题,但是看你的LOG是正常的。
#56 2019-01-19 20:56:56
所在地: 微信 whycan_cn
已发帖子: 9,249
DavidV3s 说:
你到 电脑上面挂载,然后用md5sum 看下zImage校验码,看是不是与我上面的一致,怀疑你的文件不完整
#57 2019-01-19 21:22:06
DavidV3s
已发帖子: 36
1aa4f54699db1eb70650b8fd5cde5ab3  /media/ubuntu/D456-7CA0/zImage   ,我去,我是直接点击下载的啊,我用Ubuntu下载试试
#58 2019-01-19 21:31:10
所在地: 微信 whycan_cn
已发帖子: 9,249
DavidV3s 说:
再看下上面压缩包里面的md5值是多少
#59 2019-01-19 21:34:50
DavidV3s
已发帖子: 36
ubuntu@ubuntu:~/Downloads$ md5sum V3s_TFCard.7z
7c9007deeeacfb0c1e3475b2baae25ad  V3s_TFCard.7z
#60 2019-01-19 21:35:55
DavidV3s
已发帖子: 36
ubuntu@ubuntu:~/Downloads$ sha1sum V3s_TFCard.7z
43c635802438e26c8fe96ada66255b664d52cddd  V3s_TFCard.7z
#61 2019-01-19 23:32:12
DavidV3s
已发帖子: 36
  DTC     arch/arm/boot/dts/sun8i-a23-evb.dtb
In file included from arch/arm/boot/dts/sun8i-a23.dtsi:45:0,
                 from arch/arm/boot/dts/sun8i-a23-evb.dts:46:
arch/arm/boot/dts/sun8i-a23-a33.dtsi:47:54: fatal error: dt-bindings/interrupt-controller/arm-gic.h: No such file or directory
compilation terminated.
scripts/Makefile.lib:325: recipe for target 'arch/arm/boot/dts/sun8i-a23-evb.dtb' failed
make[1]: *** [arch/arm/boot/dts/sun8i-a23-evb.dtb] Error 1
arch/arm/Makefile:346: recipe for target 'dtbs' failed
make: *** [dtbs] Error 2
make: *** Waiting for unfinished jobs....
  AR      drivers/mtd/built-in.o
  AR      drivers/built-in.o
这个文件是怎么生成的,看源代码里面是没有。
#62 2019-01-21 13:41:36
DavidV3s
已发帖子: 36
U-Boot 2017.01-rc2 (Jan 20 2019 - 20:58:24 -0800) Allwinner Technology
DRAM:  64 MiB
In:    serial@01c28000
Out:   serial@01c28000
Err:   serial@01c28000
[13:38:32.024]ÊÕ¡û¡ô 1
[13:38:33.025]ÊÕ¡û¡ô 0
[13:38:33.097]ÊÕ¡û¡ôreading zImage
3987592 bytes read in 206 ms (18.5 MiB/s)
11986 bytes read in 26 ms (450.2 KiB/s)
   Loading Device Tree to 42dfa000, end 42dffed1 ... OK
[    0.000000] Linux version 4.13.16-licheepi-zero (ubuntu@ubuntu) (gcc version 7.3.0 (Ubuntu/Linaro 7.3.0-27ubuntu1~18.04)) #2 SMP Sun Jan 20 18:46:21 PST 2019
[    0.000000] percpu: Embedded 16 pages/cpu @c3de6000 s33868 r8192 d23476 u65536
[    0.000000] Kernel command line: console=ttyS0,115200 panic=5 rootwait root=/dev/mmcblk0p2 earlyprintk rw  vt.global_cursor_default=0
[    0.000000] Memory: 53580K/64036K available (6144K kernel code, 217K rwdata, 1456K rodata, 1024K init, 264K bss, 10456K reserved, 0K cma-reserved, 0K highmem)
[    0.000000]       .data : 0xc0a00000 - 0xc0a367c0   ( 218 kB)
[    0.000000]        .bss : 0xc0a3da78 - 0xc0a7fc2c   ( 265 kB)
[    0.000000] 	RCU event tracing is enabled.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
这是用串口0输出的log,看来改成串口2,内核里面没有改成功。
#63 2019-01-21 13:45:07
所在地: 微信 whycan_cn
已发帖子: 9,249
@DavidV3s 是没有然后了吗?  61楼那个问题怎么解决的?
#64 2019-01-21 13:55:50
DavidV3s
已发帖子: 36
出现用户登录了,加载完整。61楼的问题,我重新git clone 了下,可能是下载不完成。
#65 2019-01-21 13:57:37
DavidV3s
已发帖子: 36
晕哥,内核打印改成串口2,还有什么地方需要修改的吗?我现在,串口0和串口2都接上电脑了,串口2还是卡在Starting kernel ...,串口0也没有输出
#66 2019-01-21 14:05:59
所在地: 微信 whycan_cn
已发帖子: 9,249
DavidV3s 说:
你是如何修改成 串口2输出的? bootargs ?
#67 2019-01-21 14:13:46
DavidV3s
已发帖子: 36
按照5楼的方法
#68 2019-01-21 14:42:39
所在地: 微信 whycan_cn
已发帖子: 9,249
DavidV3s 说:
按照5楼的方法
然而从 62 楼 你的 log:
还是 串口0 /dev/ttyS0
#69 2019-01-21 14:48:34
DavidV3s
已发帖子: 36
62楼,我是用串口0 的方法输出的,我板子上也是飞线到串口0的,然后我改成串口2,发现串口2还是卡在Starting kernel ...这个地方
#70 2019-01-21 14:50:12
DavidV3s
已发帖子: 36
https://whycan.cn/t_728.html,然后我试了这个方法,也是卡在Starting kernel ...这个地方
#71 2019-01-21 15:01:29
所在地: 微信 whycan_cn
已发帖子: 9,249
DavidV3s 说:
那只能怀疑你的zImage不完整了
改完之后, 显示解压失败了?
#72 2019-01-21 15:06:27
DavidV3s
已发帖子: 36
但是我这个zImage,是同一个啊,我只是修改了Uboot的串口输出,原来是uart0输出,我改成UART2输出,UART0的就正常加载输出,UART2的就卡在Starting kernel ...这个地方,说明这个zImage是没有问题的,我如果直接写输出端口的地址是不是能直接输出?又要芯片手册,头大。
#73 2019-01-21 15:33:05
DavidV3s
已发帖子: 36
修改 arch/arm/boot/compressed/misc.c:
static inline uint32_t read32(uint32_t addr)
    return( *((volatile uint32_t *)(addr)) );
static inline void write32(uint32_t addr, uint32_t value)
    *((volatile uint32_t *)(addr)) = value;
void sys_uart_putc(char c)
    [ins]unsigned int addr = 0x01c28800;[/ins]
    while((read32(addr + 0x7c) & (0x1 << 1)) == 0);
    write32(addr + 0x00, c);
static void putstr(const char *ptr)
    char c;
    while ((c = *ptr++) != '\0') {
        if (c == '\n')
            sys_uart_putc('\r');
        sys_uart_putc(c);
    flush();
U-Boot 2017.01-rc2 (Jan 20 2019 - 19:52:07 -0800) Allwinner Technology
DRAM:  64 MiB
In:    serial@01c28800
reading zImage
3987592 bytes read in 207 ms (18.4 MiB/s)
更新下,直接写输出串口2 的地址没有问题,zImage解压正常
#74 2019-01-21 15:41:22
所在地: 微信 whycan_cn
已发帖子: 9,249
那现在正常了吗? 还是一样?
#75 2019-01-21 15:42:12
DavidV3s
已发帖子: 36
还是一样,Uncompressing Linux... done, booting the kernel. 出现这个后,下面就没有输出了。
#76 2019-01-21 15:53:26
所在地: 微信 whycan_cn
已发帖子: 9,249
DavidV3s 说:
你恢复到 ttyS0 控制台, 然后操作 /dev/ttyS2, 看能否输入输出,
如果可以,说明硬件接口和设备树都没有问题,
如果不行可以, 说明上面的都可能有问题。
#77 2021-02-10 08:43:22
落日余晖
已发帖子: 34
DavidV3s 说:
请问这个问题最后解决了吗?
#78 2024-01-24 14:01:35
wl989898
已发帖子: 35
新内核都用设备树了,真怀念210开发板时代
