楼主 # 2022-02-09 18:02:11
岁月快快快
已发帖子: 61
f1c100s上跑xboot,移植gt911求助
如题,最近在移植gt911的驱动到f1c100s上,跑的xboot;
拷贝xboot主线z11s上的gt911的驱动/src/arch/arm32/mach-z11s/driver/ts-gt911.c 到f1c100s的目录中/src/arch/arm32/mach-f1c100s/driver/
,然后修改设备树文件sast-kk131.json:
加上:
"i2c-f1c100s@0x01c27800": {
	"clock-name": "link-i2c2",
	"clock-frequency": 400000,
	"reset": 82,
	"sda-gpio": 129,
	"sda-gpio-config": 4,
	"scl-gpio": 128,
	"scl-gpio-config": 4
"ts-gt911@0": {
	"i2c-bus": "i2c-f1c100s.2",
	"slave-address": 20,
	"interrupt-gpio": 137,
	"interrupt-gpio-config": 6,
	"reset-gpio": 138,
	"reset-gpio-config": 1
复位脚和中断脚用的是:PE10和PE9;iic用的是PE0和PE1;
设备树这样改不知道可以了吗?
要不要类似下面这样加上中断的定义?:
"irq-f1c100s-gpio@0x01f02a40": {
	"interrupt-base": 128,
	"interrupt-count": 6,
	"interrupt-parent": 40
要加上的话,interrupt-base、interrupt-count、interrupt-parent不知道代表什么含义,中断号吗?
另外不知道怎么在应用程序中读取坐标值,请路过的大神指点一二
最近编辑记录 岁月快快快 (2022-02-09 18:05:17)
#1 2022-02-09 18:39:34
xboot
已发帖子: 692
Re: f1c100s上跑xboot,移植gt911求助
只要关心这个配置,填如GPIO编号即可,中断号无需关心,系统会通过gpio_to_irq来获取具体的中断号
    "reset-gpio": 138,
GPIO 编号如下:
#define F1C100S_GPIOA0            (0)
#define F1C100S_GPIOA1            (1)
#define F1C100S_GPIOA2            (2)
#define F1C100S_GPIOA3            (3)
#define F1C100S_GPIOC0            (64)
#define F1C100S_GPIOC1            (65)
#define F1C100S_GPIOC2            (66)
#define F1C100S_GPIOC3            (67)
#define F1C100S_GPIOD0            (96)
#define F1C100S_GPIOD1            (97)
#define F1C100S_GPIOD2            (98)
#define F1C100S_GPIOD3            (99)
#define F1C100S_GPIOD4            (100)
#define F1C100S_GPIOD5            (101)
#define F1C100S_GPIOD6            (102)
#define F1C100S_GPIOD7            (103)
#define F1C100S_GPIOD8            (104)
#define F1C100S_GPIOD9            (105)
#define F1C100S_GPIOD10            (106)
#define F1C100S_GPIOD11            (107)
#define F1C100S_GPIOD12            (108)
#define F1C100S_GPIOD13            (109)
#define F1C100S_GPIOD14            (110)
#define F1C100S_GPIOD15            (111)
#define F1C100S_GPIOD16            (112)
#define F1C100S_GPIOD17            (113)
#define F1C100S_GPIOD18            (114)
#define F1C100S_GPIOD19            (115)
#define F1C100S_GPIOD20            (116)
#define F1C100S_GPIOD21            (117)
#define F1C100S_GPIOE0            (128)
#define F1C100S_GPIOE1            (129)
#define F1C100S_GPIOE2            (130)
#define F1C100S_GPIOE3            (131)
#define F1C100S_GPIOE4            (132)
#define F1C100S_GPIOE5            (133)
#define F1C100S_GPIOE6            (134)
#define F1C100S_GPIOE7            (135)
#define F1C100S_GPIOE8            (136)
#define F1C100S_GPIOE9            (137)
#define F1C100S_GPIOE10            (138)
#define F1C100S_GPIOE11            (139)
#define F1C100S_GPIOE12            (140)
#define F1C100S_GPIOF0            (160)
#define F1C100S_GPIOF1            (161)
#define F1C100S_GPIOF2            (162)
#define F1C100S_GPIOF3            (163)
#define F1C100S_GPIOF4            (164)
#define F1C100S_GPIOF5            (165)
#2 2022-02-09 18:41:04
xboot
已发帖子: 692
},要加上的话,interrupt-base、interrupt-count、interrupt-parent不知道代表什么含义,中断号吗?
这种更不需要关心了,这个给系统里的所有可中断的gpio,都注册一个中断,并生成中断号
楼主 #3 2022-02-09 19:15:09
岁月快快快
已发帖子: 61
@xboot
get,还有个问题,在应用程序中要调哪个接口来读取坐标值呢
#4 2022-02-09 19:46:14
xboot
已发帖子: 692
参考 cmd-event.c
楼主 #5 2022-02-10 14:46:52
岁月快快快
已发帖子: 61
xboot 说:
参考 cmd-event.c
get,多谢大佬
lol
最近编辑记录 岁月快快快 (2022-02-10 14:50:57)
#6 2023-05-26 22:17:11
Ary_Ye
大佬,请问你驱动成功了吗?我现在是启动log里面看到gt911已经检测到了,但是进到window里面还是没能触摸,想问一下你是怎么解决的。
