同样的Uboot和同样的Kernel同样的文件系统(我使用的同一张TF系统卡)Licheepi Zero 是可以显示上电信息的,包括我移植好的的Qt都是可以正常显示Qt例程的。但是这我的这块板子上却无法显示打印信息,甚至无法点亮。
后面通过对比发现了背光引脚有差别。
Licheepi和我的板子的背光电路对比图--不同点Lichee用的是PB4,我的板子用的是PB2:
由于有背光引脚的差别,所以我更改了uboot的LicheePi_Zero_800x480LCD_defconfig文件 CONFIG_VIDEO_LCD_BL_PWM="PB2" :
CONFIG_ARM=y
CONFIG_ARCH_SUNXI=y
# CONFIG_ARMV7_NONSEC is not set
CONFIG_MACH_SUN8I_V3S=y
CONFIG_DRAM_CLK=360
CONFIG_DRAM_ZQ=14779
CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:18,pclk_khz:33000,le:87,ri:40,up:31,lo:13,hs:1,vs:1,sync:3,vmode:0"
# CONFIG_VIDEO_LCD_BL_PWM_ACTIVE_LOW is not set
CONFIG_DEFAULT_DEVICE_TREE="sun8i-v3s-licheepi-zero"
# CONFIG_CONSOLE_MUX is not set
CONFIG_SPL=y
CONFIG_CMD_BOOTMENU=y
# CONFIG_CMD_IMLS is not set
CONFIG_CMD_MEMINFO=y
# CONFIG_CMD_FLASH is not set
# CONFIG_CMD_FPGA is not set
# CONFIG_NETDEVICES is not set
CONFIG_OF_LIBFDT_OVERLAY=y
所以上电之后是有看到屏幕亮的。也是有生成fb0的。不过还是没有打印信息,无法显示Qt例程
Licheepi和我这块板子的RGB接口的对比图,是完全一样的:
原理图:
RGB连接相关的
RGB屏幕是通用的40pin的引脚
设备树是licheepi zero的原版dts,没有做修改的:
#include "sun8i-v3s.dtsi"
model = "Lichee Pi Zero";
compatible = "licheepi,licheepi-zero", "allwinner,sun8i-v3s";
aliases {
serial0 = &uart0;
chosen {
&mmc0 {
pinctrl-0 = <&mmc0_pins_a>;
pinctrl-names = "default";
broken-cd;
bus-width = <4>;
vmmc-supply = <®_vcc3v3>;
&i2c0 {
ns2009: ns2009@48 {
compatible = "nsiway,ns2009";
reg = <0x48>;
&uart0 {
pinctrl-0 = <&uart0_pins_a>;
&usb_otg {
dr_mode = "otg";
&usbphy {
usb0_id_det-gpio = <&pio 5 6 GPIO_ACTIVE_HIGH>;
上电信息:
U-Boot SPL 2017.01-rc2 (Feb 19 2022 - 09:51:46)
DRAM: 64 MiB
Trying to boot from MMC1
U-Boot 2017.01-rc2 (Feb 19 2022 - 09:51:46 -0800) Allwinner Technology
Model: Lichee Pi Zero
DRAM: 64 MiB
MMC: SUNXI SD/MMC: 0
In: serial@01c28000
Out: serial@01c28000
Err: serial@01c28000
DRAM: 64 MiB
In: serial@01c28000
Net: No ethernet found.
No controllers found
reading zImage
3802128 bytes read in 201 ms (18 MiB/s)
reading sun8i-v3s-licheepi-zero.dtb
8581 bytes read in 26 ms (322.3 KiB/s)
Loading Device Tree to 42dfa000, end 42dff184 ... OK
[ 0.000000] Linux version 4.10.15-licheepi-zero (liefyuan@ubuntu) (gcc version 4.9.4 (Linaro GCC 4.9-2017.01) ) #1 SMP Sat Feb 19 02:38:26 PST 2022
[ 0.000000] OF: fdt:Machine model: Lichee Pi Zero
[ 0.000000] percpu: Embedded 14 pages/cpu @c3dea000 s24768 r8192 d24384 u57344
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 15883
[ 0.000000] Kernel command line: console=tty0 console=ttyS0,115200 panic=5 rootwait root=/dev/mmcblk0p2 earlyprintk rw vt.global_cursor_default=0
[ 0.000000] Memory: 53644K/64036K available (6144K kernel code, 199K rwdata, 1392K rodata, 1024K init, 260K bss, 10392K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] vmalloc : 0xc4000000 - 0xff800000 ( 952 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc3e89000 ( 62 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0700000 (7136 kB)
[ 0.000000] .init : 0xc0900000 - 0xc0a00000 (1024 kB)
[ 0.000000] .data : 0xc0a00000 - 0xc0a31ec0 ( 200 kB)
[ 0.000000] .bss : 0xc0a33000 - 0xc0a7405c ( 261 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (virt).
[ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000018] Switching to timer-based delay loop, resolution 41ns
[ 0.000139] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000352] Console: colour dummy device 80x30
[ 0.000783] console [tty0] enabled
[ 0.000823] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000862] pid_max: default: 32768 minimum: 301
[ 0.001011] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001038] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001759] CPU: Testing write buffer coherency: ok
[ 0.002208] /cpus/cpu@0 missing clock-frequency property
[ 0.002253] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002635] Setting up static identity map for 0x40100000 - 0x40100058
[ 0.003403] smp: Bringing up secondary CPUs ...
[ 0.003441] smp: Brought up 1 node, 1 CPU
[ 0.003461] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.003480] CPU: All CPU(s) started in SVC mode.
[ 0.004292] devtmpfs: initialized
[ 0.007065] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.007394] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.007450] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.007619] pinctrl core: initialized pinctrl subsystem
[ 0.008628] NET: Registered protocol family 16
[ 0.009145] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.010530] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.010583] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.021744] SCSI subsystem initialized
[ 0.022056] usbcore: registered new interface driver usbfs
[ 0.022143] usbcore: registered new interface driver hub
[ 0.022251] usbcore: registered new device driver usb
[ 0.022481] pps_core: LinuxPPS API ver. 1 registered
[ 0.022507] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.022552] PTP clock support registered
[ 0.022781] Advanced Linux Sound Architecture Driver Initialized.
[ 0.024635] clocksource: Switched to clocksource arch_sys_counter
[ 0.025519] simple-framebuffer 43e89000.framebuffer: framebuffer at 0x43e89000, 0x177000 bytes, mapped to 0xc4080000
[ 0.025575] simple-framebuffer 43e89000.framebuffer: format=x8r8g8b8, mode=800x480x32, linelength=3200
[ 0.032445] Console: switching to colour frame buffer device 100x30
[ 0.042280] simple-framebuffer 43e89000.framebuffer: fb0: simplefb registered!
[ 0.056112] NET: Registered protocol family 2
[ 0.060537] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.064424] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.068335] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.072206] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.076017] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.079942] NET: Registered protocol family 1
[ 0.084196] RPC: Registered named UNIX socket transport module.
[ 0.087972] RPC: Registered udp transport module.
[ 0.091569] RPC: Registered tcp transport module.
[ 0.095075] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.100819] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.113466] NFS: Registering the id_resolver key type
[ 0.117124] Key type id_resolver registered
[ 0.120501] Key type id_legacy registered
[ 0.128066] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.131652] io scheduler noop registered
[ 0.135302] io scheduler deadline registered
[ 0.139037] io scheduler cfq registered (default)
[ 0.146958] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.220589] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.227702] console [ttyS0] disabled
[ 0.251513] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 31, base_baud = 1500000) is a U6_16550A
[ 0.849668] console [ttyS0] enabled
[ 0.857394] [drm] Initialized
[ 0.865700] libphy: Fixed MDIO Bus: probed
[ 0.873366] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.883369] ehci-platform: EHCI generic platform driver
[ 0.892037] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.901556] ohci-platform: OHCI generic platform driver
[ 0.910541] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[ 0.923570] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
[ 0.933861] sun6i-rtc 1c20400.rtc: RTC enabled
[ 0.941724] i2c /dev entries driver
[ 0.949856] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input0
[ 0.962900] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.034676] sunxi-mmc 1c0f000.mmc: base:0xc405d000 irq:23
[ 1.044499] usbcore: registered new interface driver usbhid
[ 1.053739] usbhid: USB HID core driver
[ 1.062946] NET: Registered protocol family 17
[ 1.071178] Key type dns_resolver registered
[ 1.079113] Registering SWP/SWPB emulation handler
[ 1.096170] usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 1.107867] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.117340] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 1.130128] hub 1-0:1.0: USB hub found
[ 1.137753] hub 1-0:1.0: 1 port detected
[ 1.146222] using random self ethernet address
[ 1.154227] using random host ethernet address
[ 1.163251] usb0: HOST MAC 7a:9f:d6:3d:50:50
[ 1.171075] usb0: MAC 16:32:ce:d6:cb:bf
[ 1.178247] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[ 1.189030] g_cdc gadget: g_cdc ready
[ 1.196264] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 00:00:04 UTC (4)
[ 1.207940] vcc3v0: disabling
[ 1.214341] vcc5v0: disabling
[ 1.220652] ALSA device list:
[ 1.226865] No soundcards found.
[ 1.237600] Waiting for root device /dev/mmcblk0p2...
[ 1.312673] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.326209] mmc0: new high speed SD card at address 0001
[ 1.335610] mmcblk0: mmc0:0001 SD 1.83 GiB
[ 1.344555] mmcblk0: p1 p2
[ 1.350622] musb-hdrc musb-hdrc.1.auto: VBUS_ERROR in b_idle (80, <SessEnd), retry #0, port1 00000100
[ 1.395850] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[ 1.408590] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[ 1.441994] random: fast init done
[ 1.529301] EXT4-fs (mmcblk0p2): recovery complete
[ 1.542584] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.554155] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 1.570173] devtmpfs: mounted
[ 1.577985] Freeing unused kernel memory: 1024K
[ 1.698749] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
Starting logging: OK
Starting network: OK
libpng warning: iCCP: known incorrect sRGB profile
[ 5.395060] random: crng init done
希望大佬指点一下迷津,谢谢了。
我也遇到过的,飞线把PB2电阻的另外一段接到PB4,就可以显示出来了
进入Linux之后串口还能输入吗?
不行啊,还是显示不出来任何打印信息
进入Linux之后串口还能输入吗?
可以啊,在串口可以正常输入各种命令啊。现在就是在屏幕上啥都没有,不知道啥问题。
PB2不可以PWM,飞线或者改改驱动
https://whycan.com/files/members/5198/2.png
PB2不可以PWM,飞线或者改改驱动
已经改了驱动了,肉眼可见屏幕是亮了,但是,现在是没有打印信息。
问题解决了,是板子的RGB接口有虚焊导致的。
