楼主 # 2022-04-01 18:03:01
Cadence
已发帖子: 71
u-boot spi-nand 的 spi-mem 框架调试
HELLO! BOOT0 is starting!
BOOT0 commit : 023b78d-dirty
set pll start
periph0 has been enabled
set pll end
[pmu]: bus read error
board init ok
ZQ value = 0x2f***********
get_pmu_exist() = -1
ddr_efuse_type: 0xa
[AUTO DEBUG] single rank and full DQ!
ddr_efuse_type: 0xa
[AUTO DEBUG] rank 0 row = 13
[AUTO DEBUG] rank 0 bank = 4
[AUTO DEBUG] rank 0 page size = 2 KB
DRAM BOOT DRIVE INFO: V0.24
DRAM CLK = 528 MHz
DRAM Type = 2 (2:DDR2,3:DDR3)
DRAMC read ODT  off.
DRAM ODT off.
ddr_efuse_type: 0xa
DRAM SIZE =64 M
DRAM simple test OK.
dram size =64
spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 16
Jump to second Boot.
U-Boot 2022.01-rc3-00096-gc0ffc12a70-dirty (Apr 01 2022 - 17:50:11 +0800)
DRAM:  64 MiB
drivers/spi/spi-uclass.c 527 0
[00.245]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
Loading Environment from nowhere... OK
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
riscv64-unknown-linux-gnu-gcc (C-SKY RISCV Tools V1.8.4 B20200702) 8.1.0
GNU ld (GNU Binutils) 2.32
=> mtd l
List of MTD devices:
* spi-nand0
  - device: spi-nand@0
  - parent: spi@4025000
  - driver: spi_nand
  - path: /spi@4025000/spi-nand@0
  - type: NAND flash
  - block size: 0x20000 bytes
  - min I/O: 0x800 bytes
  - OOB size: 64 bytes
  - OOB available: 24 bytes
=> mtd dump spi-nand0 0x100000 0x200
Size not on a page boundary (0x800), rounding to 0x800
Reading 2048 byte(s) (1 page(s)) at offset 0x00100000
Dump 2048 data bytes from 0x00100000:
0x00100000:     73 25 40 f1 2a 82 ae 84  93 01 00 00 97 e2 06 00
0x00100010:     83 b2 42 aa 73 90 52 30  73 10 40 30 c1 52 37 83
0x00100020:     02 00 1b 03 03 e8 33 71  53 00 0a 85 ef 00 c1 09
0x00100030:     2a 84 2a 81 ef 00 30 6e  97 e2 06 00 83 b2 02 cc
0x00100040:     05 43 2f a9 62 08 63 1e  09 00 ef 00 a1 08 23 bc
0x00100050:     91 14 23 b8 41 14 97 d2  06 00 83 b2 22 6c 2f a0
0x00100060:     02 0a 97 d2 06 00 83 b2  62 6b 05 43 2f a3 62 0c
0x00100070:     e3 1e 03 fe a2 81 05 43  33 13 43 00 83 b3 01 16
0x00100080:     b3 e3 63 00 23 b0 71 16  2f a0 02 0a 63 1b 09 10
0x00100090:     ef 00 d0 75 ef 00 d0 75  13 05 00 00 17 ef 06 00
0x001000a0:     03 3f 4f ac 02 9f 2a 89  ae 89 32 8a 4a 81 97 e2
0x001000b0:     06 00 83 b2 a2 90 b3 0f  5a 40 63 86 42 0b 52 83
0x001000c0:     17 ee 06 00 03 3e 0e 9d  33 0e 5e 40 b3 83 c2 01
0x001000d0:     03 bf 02 00 a1 02 23 30  e3 01 21 03 e3 ca 72 fe
0x001000e0:     17 d3 06 00 03 33 03 58  97 e3 06 00 83 b3 03 bb
0x001000f0:     63 0b 73 06 7e 93 fe 93  a9 a8 03 3f 03 ff 0d 4e
0x00100100:     63 1b cf 01 03 3e 83 fe  03 3f 83 ff 7e 9f 7e 9e
0x00100110:     23 30 ee 01 3d a8 97 ee  06 00 83 be ae b8 fe 9e
0x00100120:     03 3f 03 ff 93 52 0f 02  13 7f ff 0f 09 4e 63 12
0x00100130:     cf 03 03 3e 83 fe 61 4f  b3 82 e2 03 b3 8a 5e 00
0x00100140:     83 32 83 ff 03 bf 8a 00  16 9f 7e 9f 7e 9e 23 30
0x00100150:     ee 01 61 03 e3 d3 63 fa  97 e2 06 00 83 b2 82 95
0x00100160:     fe 92 73 90 52 30 97 e2  06 00 83 b2 a2 92 fe 92
0x00100170:     17 d3 06 00 03 33 83 6f  7e 93 63 87 62 00 23 b0
0x00100180:     02 00 a1 02 e3 cd 62 fe  ef 10 40 05 ef 00 30 64
0x00100190:     97 d2 06 00 83 b2 82 70  b3 8e f2 01 4e 85 d2 85
0x001001a0:     82 8e 73 00 50 10 f5 bf  82 80 7d 55 7e 15 0d 05
0x001001b0:     82 80 7d 55 7e 15 0d 05  82 80 7d 55 7e 15 0d 05
0x001001c0:     82 80 7d 55 7e 15 0d 05  82 80 7d 55 7e 15 0d 05
0x001001d0:     82 80 7d 55 7e 15 0d 05  82 80 7d 55 7e 15 0d 05
0x001001e0:     82 80 97 16 00 00 93 86  66 bd 9c 62 b9 c3 b1 c5
0x001001f0:     98 61 09 e7 05 89 31 c1  01 45 82 80 03 b8 86 00
0x00100200:     83 b8 06 01 01 46 63 16  c8 00 7d 55 7e 15 39 05
0x00100210:     82 80 88 67 63 6c a7 00  94 6f b2 06 aa 96 63 77
0x00100220:     d7 00 9c 6b 89 8f 3e 97  98 e1 f9 b7 05 06 c6 97
0x00100230:     d9 bf 7d 55 7e 15 0d 05  82 80 7d 55 7e 15 09 05
0x00100240:     82 80 41 11 22 e0 06 e4  50 45 2a 84 23 28 05 00
0x00100250:     aa 85 01 45 ef 00 20 65  08 c8 a2 60 02 64 41 01
0x00100260:     82 80 81 47 63 13 f6 00  82 80 33 87 f5 00 83 46
0x00100270:     07 00 33 07 f5 00 85 07  23 00 d7 00 e5 b7 17 d5
0x00100280:     06 00 03 35 a5 4f 97 d7  06 00 83 b7 27 78 3c f5
0x00100290:     97 d7 06 00 83 b7 87 59  1c ed 97 d7 06 00 83 b7
0x001002a0:     67 60 1c f1 6f f0 ff f9  1d 71 a2 e8 ca e0 4e fc
0x001002b0:     37 04 00 be 17 d9 06 00  03 39 49 4c 97 e9 06 00
0x001002c0:     83 b9 c9 92 a6 e4 52 f8  56 f4 5a f0 5e ec 62 e8
0x001002d0:     66 e4 86 ec ae 8c 17 dc  06 00 03 3c ac 43 17 da
0x001002e0:     06 00 03 3a 2a 69 97 ea  06 00 83 ba aa 9b b3 04
0x001002f0:     85 00 13 0b 89 01 93 8b  89 00 63 60 4c 03 46 64
0x00100300:     e6 60 a6 64 06 69 e2 79  42 7a a2 7a 02 7b e2 6b
0x00100310:     42 6c a2 6c 25 61 6f 00  70 6c 03 b5 01 07 03 36
0x00100320:     0c 00 22 95 32 95 63 8c  0c 00 63 66 65 01 93 07
0x00100330:     09 08 63 fc a7 06 63 8a  ab 06 63 88 a9 06 83 37
0x00100340:     8c 00 09 47 13 f6 f7 0f  63 00 e6 04 8d 47 63 14
0x00100350:     f6 04 83 36 0c 01 a6 96  63 8b 0c 04 03 b7 0c 01
0x00100360:     63 e8 e6 00 83 b7 8c 01  b2 07 ba 97 63 f1 d7 04
0x00100370:     2a 86 97 05 05 00 93 85  65 84 17 05 00 00 13 05
0x00100380:     e5 56 ef a0 34 06 15 a0  81 93 61 47 b3 87 e7 02
0x00100390:     d6 97 94 67 c9 b7 97 05  05 00 93 85 25 82 17 05
0x001003a0:     00 00 13 05 25 52 ef a0  f4 03 61 0c b9 b7 93 05
0x001003b0:     75 04 14 e1 93 f5 05 fc  13 75 05 fc ef 00 50 41
0x001003c0:     ed b7 41 11 22 e0 81 47  32 84 06 e4 ef 00 40 1d
0x001003d0:     09 c4 1c 40 93 f7 f7 07  1c c0 a2 60 02 64 41 01
0x001003e0:     82 80 6f 00 a0 12 01 47  bd 48 b3 07 e5 00 33 88
0x001003f0:     e5 00 83 c7 07 01 03 48  08 00 63 04 17 03 05 07
0x00100400:     e3 85 07 ff 81 47 13 07  05 02 83 55 07 00 91 c7
0x00100410:     83 57 06 00 8d 8f 93 b7  17 00 09 07 81 c9 09 06
0x00100420:     ed b7 b3 87 07 41 93 b7  17 00 f1 bf 99 c6 03 66
0x00100430:     05 00 1d 06 32 97 61 9b  98 e2 89 c7 17 17 00 00
0x00100440:     23 3e a7 a0 3e 85 82 80  41 11 97 15 00 00 93 85
0x00100450:     65 a1 01 45 06 e4 ef f0  df d8 a2 60 97 17 00 00
0x00100460:     23 be 07 9e 41 01 82 80  5d 71 a2 e0 26 fc 86 e4
0x00100470:     4a f8 4e f4 52 f0 56 ec  17 14 00 00 13 04 04 9e
0x00100480:     1c 64 03 d7 05 00 b2 84  03 e9 07 01 3e 99 05 e7
0x00100490:     01 ee 01 44 22 85 a6 60  06 64 e2 74 42 79 a2 79
0x001004a0:     02 7a e2 6a 61 61 82 80  e1 07 1c e2 e3 e3 27 ff
0x001004b0:     23 b0 04 00 f9 bf 2a 8a  08 60 ae 89 19 cd b2 86
0x001004c0:     2e 86 d2 85 ef f0 3f f2  09 c9 91 c4 9c 60 63 e4
0x001004d0:     27 01 23 b0 04 00 00 60  75 bf 00 64 93 0a 81 00
0x001004e0:     61 04 63 65 24 01 e9 f4  6d b7 22 64 6d dc d6 86
0x001004f0:     4e 86 d2 85 22 85 ef f0  1f ef a2 67 63 e3 27 01
0x00100500:     02 e4 65 d5 c1 d8 a2 67  9c e0 69 b7 11 ed 7d 55
0x00100510:     7e 15 09 05 82 80 7d 55  7e 15 09 05 a2 70 02 74
0x00100520:     e2 64 42 69 45 61 82 80  fd d1 75 d2 79 71 22 f0
0x00100530:     26 ec 4a e8 06 f4 2e 84  0c 61 aa 84 22 85 32 89
0x00100540:     ef 00 20 27 9c 60 e3 08  f5 fc 30 00 a2 85 4a 85
0x00100550:     ef f0 9f f1 01 e5 83 57  04 00 d5 ff a2 65 8d c9
0x00100560:     93 85 05 02 ae 87 03 d7  07 00 89 07 6d ff 98 60
0x00100570:     33 86 b7 40 90 e0 63 61  c7 02 22 85 ef f0 7f ce
0x00100580:     a2 65 4a 85 41 46 c1 05  ef f0 bf cd 01 45 79 b7
0x00100590:     7d 55 7e 15 39 05 59 b7  7d 55 7e 15 15 05 bd bf
0x001005a0:     19 ed 7d 55 7e 15 09 05  82 80 7d 55 7e 15 09 05
0x001005b0:     a2 70 02 74 e2 64 42 69  a2 69 45 61 82 80 f5 d1
0x001005c0:     ed d2 79 71 2a 88 4e e4  2e 85 b2 89 c2 85 01 46
0x001005d0:     22 f0 26 ec 4a e8 06 f4  3e 89 ba 84 36 84 ef f0
0x001005e0:     bf e8 1d cd 63 85 09 00  5c 41 23 a0 f9 00 63 05
0x001005f0:     09 00 1c 65 23 30 f9 00  03 67 05 00 1c 60 18 e0
0x00100600:     03 66 05 00 63 e2 c7 02  cd d0 93 05 05 02 83 d7
0x00100610:     05 00 89 05 ed ff 26 85  ef f0 bf c4 01 45 49 bf
0x00100620:     7d 55 7e 15 39 05 69 b7  7d 55 7e 15 15 05 49 b7
0x00100630:     3d c5 41 11 22 e0 06 e4  97 17 00 00 93 87 07 82
0x00100640:     98 67 94 63 3e 84 03 28  07 01 13 16 08 02 01 92
0x00100650:     3a 96 63 e6 a6 00 97 17  00 00 23 b1 07 80 93 05
0x00100660:     05 02 83 d7 05 00 89 05  ed ff 83 66 05 00 9d 06
0x00100670:     b6 95 e1 99 b3 07 b5 40  bb 87 07 01 0d 8e 1c cb
0x00100680:     ef f0 3f be 00 64 01 45  10 48 93 05 84 01 21 36
0x00100690:     ef 00 60 21 48 c8 a2 60  02 64 41 01 82 80 82 80
0x001006a0:     1d 71 56 f4 97 0a 00 00  93 8a 4a 7b 03 b3 8a 00
0x001006b0:     86 ec a2 e8 a6 e4 ca e0  4e fc 52 f8 5a f0 5e ec
0x001006c0:     62 e8 66 e4 03 69 03 01  01 4e 1a 99 93 1e 0e 02
0x001006d0:     93 de fe 01 aa 9e 83 de  0e 00 05 2e e3 98 0e fe
0x001006e0:     02 1e 93 54 fe 01 93 0c  09 02 33 83 67 40 33 8a
0x001006f0:     9c 00 36 93 52 93 11 6e  63 61 6e 08 be 89 b5 9f
0x00100700:     23 20 f9 00 23 34 19 01  2a 8b 23 22 c9 00 13 05
0x00100710:     09 01 41 46 36 84 c2 8b  3a 8c ef f0 9f b4 26 86
0x00100720:     da 85 66 85 ef f0 ff b3  22 86 e2 85 52 85 ef f0
0x00100730:     5f b3 33 05 8a 00 4e 86  de 85 ef f0 9f b2 03 66
0x00100740:     09 00 03 b4 8a 00 01 45  1d 06 52 96 61 9a 01 9e
0x00100750:     10 c8 93 05 84 01 21 36  ef 00 e0 14 48 c8 01 45
0x00100760:     e6 60 46 64 a6 64 06 69  e2 79 42 7a a2 7a 02 7b
0x00100770:     e2 6b 42 6c a2 6c 25 61  82 80 7d 55 7e 15 25 05
0x00100780:     c5 b7 97 07 00 00 93 87  67 6d 9c 67 11 65 9c 4b
0x00100790:     1d 9d 02 15 01 91 01 15  82 80 7d 55 7e 15 0d 05
0x001007a0:     82 80 7d 55 7e 15 0d 05  82 80 6f f0 7f df 6f f0
0x001007b0:     ff d5 81 47 63 88 b7 00  13 97 17 00 2a 97 03 57
0x001007c0:     07 00 19 e3 3e 85 82 80  85 07 ed b7 93 f7 35 00
0x001007d0:     85 cb 1d c6 17 07 00 00  13 07 47 14 85 05 83 c7
0x001007e0:     f5 ff 7d 36 a9 8f 93 f7  f7 0f 8a 07 ba 97 9c 43
0x001007f0:     1b 55 85 00 3d 8d 01 25  01 c6 93 f7 35 00 f9 ff
