HELLO! BOOT0 is starting!
BOOT0 commit : 023b78d-dirty
set pll start
periph0 has been enabled
set pll end
[pmu]: bus read error
board init ok
ZQ value = 0x2f***********
get_pmu_exist() = -1
ddr_efuse_type: 0xa
[AUTO DEBUG] single rank and full DQ!
ddr_efuse_type: 0xa
[AUTO DEBUG] rank 0 row = 13
[AUTO DEBUG] rank 0 bank = 4
[AUTO DEBUG] rank 0 page size = 2 KB
DRAM BOOT DRIVE INFO: V0.24
DRAM CLK = 528 MHz
DRAM Type = 2 (2:DDR2,3:DDR3)
DRAMC read ODT off.
DRAM ODT off.
ddr_efuse_type: 0xa
DRAM SIZE =64 M
DRAM simple test OK.
dram size =64
spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 16
Jump to second Boot.
U-Boot 2022.01-rc3-00096-gc0ffc12a70-dirty (Apr 01 2022 - 17:50:11 +0800)
DRAM: 64 MiB
drivers/spi/spi-uclass.c 527 0
[00.245]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
Loading Environment from nowhere... OK
In: serial
Out: serial
Err: serial
Net: No ethernet found.
riscv64-unknown-linux-gnu-gcc (C-SKY RISCV Tools V1.8.4 B20200702) 8.1.0
GNU ld (GNU Binutils) 2.32
=> mtd l
List of MTD devices:
* spi-nand0
- device: spi-nand@0
- parent: spi@4025000
- driver: spi_nand
- path: /spi@4025000/spi-nand@0
- type: NAND flash
- block size: 0x20000 bytes
- min I/O: 0x800 bytes
- OOB size: 64 bytes
- OOB available: 24 bytes
=> mtd dump spi-nand0 0x100000 0x200
Size not on a page boundary (0x800), rounding to 0x800
Reading 2048 byte(s) (1 page(s)) at offset 0x00100000
Dump 2048 data bytes from 0x00100000:
0x00100000: 73 25 40 f1 2a 82 ae 84 93 01 00 00 97 e2 06 00
0x00100010: 83 b2 42 aa 73 90 52 30 73 10 40 30 c1 52 37 83
0x00100020: 02 00 1b 03 03 e8 33 71 53 00 0a 85 ef 00 c1 09
0x00100030: 2a 84 2a 81 ef 00 30 6e 97 e2 06 00 83 b2 02 cc
0x00100040: 05 43 2f a9 62 08 63 1e 09 00 ef 00 a1 08 23 bc
0x00100050: 91 14 23 b8 41 14 97 d2 06 00 83 b2 22 6c 2f a0
0x00100060: 02 0a 97 d2 06 00 83 b2 62 6b 05 43 2f a3 62 0c
0x00100070: e3 1e 03 fe a2 81 05 43 33 13 43 00 83 b3 01 16
0x00100080: b3 e3 63 00 23 b0 71 16 2f a0 02 0a 63 1b 09 10
0x00100090: ef 00 d0 75 ef 00 d0 75 13 05 00 00 17 ef 06 00
0x001000a0: 03 3f 4f ac 02 9f 2a 89 ae 89 32 8a 4a 81 97 e2
0x001000b0: 06 00 83 b2 a2 90 b3 0f 5a 40 63 86 42 0b 52 83
0x001000c0: 17 ee 06 00 03 3e 0e 9d 33 0e 5e 40 b3 83 c2 01
0x001000d0: 03 bf 02 00 a1 02 23 30 e3 01 21 03 e3 ca 72 fe
0x001000e0: 17 d3 06 00 03 33 03 58 97 e3 06 00 83 b3 03 bb
0x001000f0: 63 0b 73 06 7e 93 fe 93 a9 a8 03 3f 03 ff 0d 4e
0x00100100: 63 1b cf 01 03 3e 83 fe 03 3f 83 ff 7e 9f 7e 9e
0x00100110: 23 30 ee 01 3d a8 97 ee 06 00 83 be ae b8 fe 9e
0x00100120: 03 3f 03 ff 93 52 0f 02 13 7f ff 0f 09 4e 63 12
0x00100130: cf 03 03 3e 83 fe 61 4f b3 82 e2 03 b3 8a 5e 00
0x00100140: 83 32 83 ff 03 bf 8a 00 16 9f 7e 9f 7e 9e 23 30
0x00100150: ee 01 61 03 e3 d3 63 fa 97 e2 06 00 83 b2 82 95
0x00100160: fe 92 73 90 52 30 97 e2 06 00 83 b2 a2 92 fe 92
0x00100170: 17 d3 06 00 03 33 83 6f 7e 93 63 87 62 00 23 b0
0x00100180: 02 00 a1 02 e3 cd 62 fe ef 10 40 05 ef 00 30 64
0x00100190: 97 d2 06 00 83 b2 82 70 b3 8e f2 01 4e 85 d2 85
0x001001a0: 82 8e 73 00 50 10 f5 bf 82 80 7d 55 7e 15 0d 05
0x001001b0: 82 80 7d 55 7e 15 0d 05 82 80 7d 55 7e 15 0d 05
0x001001c0: 82 80 7d 55 7e 15 0d 05 82 80 7d 55 7e 15 0d 05
0x001001d0: 82 80 7d 55 7e 15 0d 05 82 80 7d 55 7e 15 0d 05
0x001001e0: 82 80 97 16 00 00 93 86 66 bd 9c 62 b9 c3 b1 c5
0x001001f0: 98 61 09 e7 05 89 31 c1 01 45 82 80 03 b8 86 00
0x00100200: 83 b8 06 01 01 46 63 16 c8 00 7d 55 7e 15 39 05
0x00100210: 82 80 88 67 63 6c a7 00 94 6f b2 06 aa 96 63 77
0x00100220: d7 00 9c 6b 89 8f 3e 97 98 e1 f9 b7 05 06 c6 97
0x00100230: d9 bf 7d 55 7e 15 0d 05 82 80 7d 55 7e 15 09 05
0x00100240: 82 80 41 11 22 e0 06 e4 50 45 2a 84 23 28 05 00
0x00100250: aa 85 01 45 ef 00 20 65 08 c8 a2 60 02 64 41 01
0x00100260: 82 80 81 47 63 13 f6 00 82 80 33 87 f5 00 83 46
0x00100270: 07 00 33 07 f5 00 85 07 23 00 d7 00 e5 b7 17 d5
0x00100280: 06 00 03 35 a5 4f 97 d7 06 00 83 b7 27 78 3c f5
0x00100290: 97 d7 06 00 83 b7 87 59 1c ed 97 d7 06 00 83 b7
0x001002a0: 67 60 1c f1 6f f0 ff f9 1d 71 a2 e8 ca e0 4e fc
0x001002b0: 37 04 00 be 17 d9 06 00 03 39 49 4c 97 e9 06 00
0x001002c0: 83 b9 c9 92 a6 e4 52 f8 56 f4 5a f0 5e ec 62 e8
0x001002d0: 66 e4 86 ec ae 8c 17 dc 06 00 03 3c ac 43 17 da
0x001002e0: 06 00 03 3a 2a 69 97 ea 06 00 83 ba aa 9b b3 04
0x001002f0: 85 00 13 0b 89 01 93 8b 89 00 63 60 4c 03 46 64
0x00100300: e6 60 a6 64 06 69 e2 79 42 7a a2 7a 02 7b e2 6b
0x00100310: 42 6c a2 6c 25 61 6f 00 70 6c 03 b5 01 07 03 36
0x00100320: 0c 00 22 95 32 95 63 8c 0c 00 63 66 65 01 93 07
0x00100330: 09 08 63 fc a7 06 63 8a ab 06 63 88 a9 06 83 37
0x00100340: 8c 00 09 47 13 f6 f7 0f 63 00 e6 04 8d 47 63 14
0x00100350: f6 04 83 36 0c 01 a6 96 63 8b 0c 04 03 b7 0c 01
0x00100360: 63 e8 e6 00 83 b7 8c 01 b2 07 ba 97 63 f1 d7 04
0x00100370: 2a 86 97 05 05 00 93 85 65 84 17 05 00 00 13 05
0x00100380: e5 56 ef a0 34 06 15 a0 81 93 61 47 b3 87 e7 02
0x00100390: d6 97 94 67 c9 b7 97 05 05 00 93 85 25 82 17 05
0x001003a0: 00 00 13 05 25 52 ef a0 f4 03 61 0c b9 b7 93 05
0x001003b0: 75 04 14 e1 93 f5 05 fc 13 75 05 fc ef 00 50 41
0x001003c0: ed b7 41 11 22 e0 81 47 32 84 06 e4 ef 00 40 1d
0x001003d0: 09 c4 1c 40 93 f7 f7 07 1c c0 a2 60 02 64 41 01
0x001003e0: 82 80 6f 00 a0 12 01 47 bd 48 b3 07 e5 00 33 88
0x001003f0: e5 00 83 c7 07 01 03 48 08 00 63 04 17 03 05 07
0x00100400: e3 85 07 ff 81 47 13 07 05 02 83 55 07 00 91 c7
0x00100410: 83 57 06 00 8d 8f 93 b7 17 00 09 07 81 c9 09 06
0x00100420: ed b7 b3 87 07 41 93 b7 17 00 f1 bf 99 c6 03 66
0x00100430: 05 00 1d 06 32 97 61 9b 98 e2 89 c7 17 17 00 00
0x00100440: 23 3e a7 a0 3e 85 82 80 41 11 97 15 00 00 93 85
0x00100450: 65 a1 01 45 06 e4 ef f0 df d8 a2 60 97 17 00 00
0x00100460: 23 be 07 9e 41 01 82 80 5d 71 a2 e0 26 fc 86 e4
0x00100470: 4a f8 4e f4 52 f0 56 ec 17 14 00 00 13 04 04 9e
0x00100480: 1c 64 03 d7 05 00 b2 84 03 e9 07 01 3e 99 05 e7
0x00100490: 01 ee 01 44 22 85 a6 60 06 64 e2 74 42 79 a2 79
0x001004a0: 02 7a e2 6a 61 61 82 80 e1 07 1c e2 e3 e3 27 ff
0x001004b0: 23 b0 04 00 f9 bf 2a 8a 08 60 ae 89 19 cd b2 86
0x001004c0: 2e 86 d2 85 ef f0 3f f2 09 c9 91 c4 9c 60 63 e4
0x001004d0: 27 01 23 b0 04 00 00 60 75 bf 00 64 93 0a 81 00
0x001004e0: 61 04 63 65 24 01 e9 f4 6d b7 22 64 6d dc d6 86
0x001004f0: 4e 86 d2 85 22 85 ef f0 1f ef a2 67 63 e3 27 01
0x00100500: 02 e4 65 d5 c1 d8 a2 67 9c e0 69 b7 11 ed 7d 55
0x00100510: 7e 15 09 05 82 80 7d 55 7e 15 09 05 a2 70 02 74
0x00100520: e2 64 42 69 45 61 82 80 fd d1 75 d2 79 71 22 f0
0x00100530: 26 ec 4a e8 06 f4 2e 84 0c 61 aa 84 22 85 32 89
0x00100540: ef 00 20 27 9c 60 e3 08 f5 fc 30 00 a2 85 4a 85
0x00100550: ef f0 9f f1 01 e5 83 57 04 00 d5 ff a2 65 8d c9
0x00100560: 93 85 05 02 ae 87 03 d7 07 00 89 07 6d ff 98 60
0x00100570: 33 86 b7 40 90 e0 63 61 c7 02 22 85 ef f0 7f ce
0x00100580: a2 65 4a 85 41 46 c1 05 ef f0 bf cd 01 45 79 b7
0x00100590: 7d 55 7e 15 39 05 59 b7 7d 55 7e 15 15 05 bd bf
0x001005a0: 19 ed 7d 55 7e 15 09 05 82 80 7d 55 7e 15 09 05
0x001005b0: a2 70 02 74 e2 64 42 69 a2 69 45 61 82 80 f5 d1
0x001005c0: ed d2 79 71 2a 88 4e e4 2e 85 b2 89 c2 85 01 46
0x001005d0: 22 f0 26 ec 4a e8 06 f4 3e 89 ba 84 36 84 ef f0
0x001005e0: bf e8 1d cd 63 85 09 00 5c 41 23 a0 f9 00 63 05
0x001005f0: 09 00 1c 65 23 30 f9 00 03 67 05 00 1c 60 18 e0
0x00100600: 03 66 05 00 63 e2 c7 02 cd d0 93 05 05 02 83 d7
0x00100610: 05 00 89 05 ed ff 26 85 ef f0 bf c4 01 45 49 bf
0x00100620: 7d 55 7e 15 39 05 69 b7 7d 55 7e 15 15 05 49 b7
0x00100630: 3d c5 41 11 22 e0 06 e4 97 17 00 00 93 87 07 82
0x00100640: 98 67 94 63 3e 84 03 28 07 01 13 16 08 02 01 92
0x00100650: 3a 96 63 e6 a6 00 97 17 00 00 23 b1 07 80 93 05
0x00100660: 05 02 83 d7 05 00 89 05 ed ff 83 66 05 00 9d 06
0x00100670: b6 95 e1 99 b3 07 b5 40 bb 87 07 01 0d 8e 1c cb
0x00100680: ef f0 3f be 00 64 01 45 10 48 93 05 84 01 21 36
0x00100690: ef 00 60 21 48 c8 a2 60 02 64 41 01 82 80 82 80
0x001006a0: 1d 71 56 f4 97 0a 00 00 93 8a 4a 7b 03 b3 8a 00
0x001006b0: 86 ec a2 e8 a6 e4 ca e0 4e fc 52 f8 5a f0 5e ec
0x001006c0: 62 e8 66 e4 03 69 03 01 01 4e 1a 99 93 1e 0e 02
0x001006d0: 93 de fe 01 aa 9e 83 de 0e 00 05 2e e3 98 0e fe
0x001006e0: 02 1e 93 54 fe 01 93 0c 09 02 33 83 67 40 33 8a
0x001006f0: 9c 00 36 93 52 93 11 6e 63 61 6e 08 be 89 b5 9f
0x00100700: 23 20 f9 00 23 34 19 01 2a 8b 23 22 c9 00 13 05
0x00100710: 09 01 41 46 36 84 c2 8b 3a 8c ef f0 9f b4 26 86
0x00100720: da 85 66 85 ef f0 ff b3 22 86 e2 85 52 85 ef f0
0x00100730: 5f b3 33 05 8a 00 4e 86 de 85 ef f0 9f b2 03 66
0x00100740: 09 00 03 b4 8a 00 01 45 1d 06 52 96 61 9a 01 9e
0x00100750: 10 c8 93 05 84 01 21 36 ef 00 e0 14 48 c8 01 45
0x00100760: e6 60 46 64 a6 64 06 69 e2 79 42 7a a2 7a 02 7b
0x00100770: e2 6b 42 6c a2 6c 25 61 82 80 7d 55 7e 15 25 05
0x00100780: c5 b7 97 07 00 00 93 87 67 6d 9c 67 11 65 9c 4b
0x00100790: 1d 9d 02 15 01 91 01 15 82 80 7d 55 7e 15 0d 05
0x001007a0: 82 80 7d 55 7e 15 0d 05 82 80 6f f0 7f df 6f f0
0x001007b0: ff d5 81 47 63 88 b7 00 13 97 17 00 2a 97 03 57
0x001007c0: 07 00 19 e3 3e 85 82 80 85 07 ed b7 93 f7 35 00
0x001007d0: 85 cb 1d c6 17 07 00 00 13 07 47 14 85 05 83 c7
0x001007e0: f5 ff 7d 36 a9 8f 93 f7 f7 0f 8a 07 ba 97 9c 43
0x001007f0: 1b 55 85 00 3d 8d 01 25 01 c6 93 f7 35 00 f9 ff
=>离线
