如题,用d1s点一块4寸的720x720的spi屏,系统跑起来后,能看到fb0设备,但是用GPIO模拟spi发命令和数据的引脚上没有量到有波形,一直是高电平,log也没看到跑进过LCD_panel_init函数;
设备树lcd相关的配置:
&lcd0 {
/* part 1 */
lcd_used = <1>;
lcd_driver_name = "axs1832a_720x720";
/* part 2 */
lcd_if = <0>;
lcd_hv_if = <0>;
/* part 3 */
lcd_x = <720>;
lcd_y = <720>;
lcd_width = <71>;
lcd_height = <71>;
lcd_dclk_freq = <35>;
lcd_hbp = <40>;
lcd_ht = <770>;
lcd_hspw = <2>;
lcd_vbp = <19>;
lcd_vt = <749>;
lcd_vspw = <2>;
/* part 4 */
lcd_backlight = <100>;
lcd_pwm_used = <1>;
lcd_pwm_ch = <7>;
lcd_pwm_freq = <19000>;
lcd_pwm_pol = <0>;
lcd_pwm_max_limit = <255>;
lcd_lvds_if = <0>;
lcd_lvds_colordepth = <1>;
lcd_lvds_mode = <0>;
lcd_frm = <0>;
lcd_io_phase = <0x0000>;
lcd_gamma_en = <0>;
lcd_bright_curve_en = <0>;
lcd_cmap_en = <0>;
deu_mode = <0>;
lcdgamma4iep = <22>;
smart_color = <90>;
lcd_gpio_0 = <&pio PE 4 GPIO_ACTIVE_HIGH>;
lcd_gpio_1 = <&pio PD 22 GPIO_ACTIVE_HIGH>;
lcd_gpio_2 = <&pio PE 1 GPIO_ACTIVE_HIGH>;
lcd_gpio_3 = <&pio PE 0 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&rgb18_pins_a>;
pinctrl-1 = <&rgb18_pins_b>;
rgb18_pins_a: rgb18@0 {
pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", \
"PD6", "PD7", "PD8", "PD9", "PD10", "PD11", \
"PD12", "PD13", "PD14", "PD15", "PD16", "PD17", \
"PD18", "PD19", "PD20", "PD21";
function = "lcd0";
drive-strength = <30>;
bias-disable;
rgb18_pins_b: rgb18@1 {
function = "io_disabled";
bias-disable;
};屏驱动代码是拷贝了lichee/linux-5.4/drivers/video/fbdev/sunxi/disp2/disp/lcd/目录下的default_panel.c default_panel.h
在它的基础上加上SPI初始化代码的:
* Allwinner SoCs display driver.
* Copyright (C) 2016 Allwinner.
* This file is licensed under the terms of the GNU General Public
* License version 2. This program is licensed "as is" without any
* warranty of any kind, whether express or implied.
#include "axs1832a_720x720.h"
#define HIGH 1
#define LOW 0
static void LCD_power_on(u32 sel);
static void LCD_power_off(u32 sel);
static void LCD_bl_open(u32 sel);
static void LCD_bl_close(u32 sel);
static void LCD_panel_init(u32 sel);
static void LCD_panel_exit(u32 sel);
static void LCD_cfg_panel_info(struct panel_extend_para *info)
u32 i = 0, j = 0;
u32 items;
u8 lcd_gamma_tbl[][2] = {
/* {input value, corrected value} */
{0, 0},
{15, 15},
{30, 30},
{45, 45},
{60, 60},
{75, 75},
{90, 90},
{105, 105},
{120, 120},
{135, 135},
{150, 150},
{165, 165},
{180, 180},
{195, 195},
{210, 210},
{225, 225},
{240, 240},
{255, 255},
u32 lcd_cmap_tbl[2][3][4] = {
{LCD_CMAP_G0, LCD_CMAP_B1, LCD_CMAP_G2, LCD_CMAP_B3},
{LCD_CMAP_B0, LCD_CMAP_R1, LCD_CMAP_B2, LCD_CMAP_R3},
{LCD_CMAP_R0, LCD_CMAP_G1, LCD_CMAP_R2, LCD_CMAP_G3},
{LCD_CMAP_B3, LCD_CMAP_G2, LCD_CMAP_B1, LCD_CMAP_G0},
{LCD_CMAP_R3, LCD_CMAP_B2, LCD_CMAP_R1, LCD_CMAP_B0},
{LCD_CMAP_G3, LCD_CMAP_R2, LCD_CMAP_G1, LCD_CMAP_R0},
items = sizeof(lcd_gamma_tbl) / 2;
for (i = 0; i < items - 1; i++) {
u32 num = lcd_gamma_tbl[i + 1][0] - lcd_gamma_tbl[i][0];
for (j = 0; j < num; j++) {
u32 value = 0;
value =
lcd_gamma_tbl[i][1] +
((lcd_gamma_tbl[i + 1][1] -
lcd_gamma_tbl[i][1]) * j) / num;
info->lcd_gamma_tbl[lcd_gamma_tbl[i][0] + j] =
(value << 16) + (value << 8) + value;
info->lcd_gamma_tbl[255] =
(lcd_gamma_tbl[items - 1][1] << 16) +
(lcd_gamma_tbl[items - 1][1] << 8) + lcd_gamma_tbl[items - 1][1];
memcpy(info->lcd_cmap_tbl, lcd_cmap_tbl, sizeof(lcd_cmap_tbl));
static s32 LCD_open_flow(u32 sel)
/* open lcd power, and delay 50ms */
LCD_OPEN_FUNC(sel, LCD_power_on, 30);
/* open lcd power, than delay 200ms */
LCD_OPEN_FUNC(sel, LCD_panel_init, 50);
/* open lcd controller, and delay 100ms */
LCD_OPEN_FUNC(sel, sunxi_lcd_tcon_enable, 100);
/* open lcd backlight, and delay 0ms */
LCD_OPEN_FUNC(sel, LCD_bl_open, 0);
static s32 LCD_close_flow(u32 sel)
/* close lcd backlight, and delay 0ms */
LCD_CLOSE_FUNC(sel, LCD_bl_close, 0);
/* close lcd controller, and delay 0ms */
LCD_CLOSE_FUNC(sel, sunxi_lcd_tcon_disable, 0);
LCD_CLOSE_FUNC(sel, LCD_panel_exit, 200);
/* close lcd power, and delay 500ms */
LCD_CLOSE_FUNC(sel, LCD_power_off, 500);
/* config lcd_power pin to open lcd power0 */
sunxi_lcd_power_enable(sel, 0);
sunxi_lcd_pin_cfg(sel, 1);
/*#if defined(CONFIG_FPGA_V7_PLATFORM) || defined(CONFIG_FPGA_V4_PLATFORM)*/
/*struct disp_panel_para *panel_info =*/
/*kmalloc(sizeof(struct disp_panel_para), GFP_KERNEL | __GFP_ZERO);*/
/*bsp_disp_get_panel_info(sel, panel_info);*/
/*if (panel_info->lcd_if == LCD_IF_HV) {*/
/*writel(0x22222222, ioremap(0x0300b06c, 4));*/
/*writel(0x22222222, ioremap(0x0300b070, 4));*/
/*writel(0x22222222, ioremap(0x0300b074, 4));*/
/*writel(0x22222222, ioremap(0x0300b078, 4));*/
/*} else if(panel_info->lcd_if == LCD_IF_LVDS) {*/
/*writel(0x33333333, ioremap(0x0300b06c, 4));*/
/*writel(0x33333333, ioremap(0x0300b070, 4));*/
/*writel(0x33333333, ioremap(0x0300b074, 4));*/
/*writel(0x33333333, ioremap(0x0300b078, 4));*/
/*kfree(panel_info);*/
/*#endif*/
sunxi_lcd_pin_cfg(sel, 0);
/* config lcd_power pin to close lcd power0 */
sunxi_lcd_power_disable(sel, 0);
sunxi_lcd_pwm_enable(sel);
sunxi_lcd_backlight_enable(sel);
/* config lcd_bl_en pin to close lcd backlight */
sunxi_lcd_backlight_disable(sel);
sunxi_lcd_pwm_disable(sel);
static void SetCsPinLevel(u8 val)
if (val) {
sunxi_lcd_gpio_set_value(0, 1, 1);
} else {
sunxi_lcd_gpio_set_value(0, 1, 0);
static void SetClkPinLevel(u8 val)
if (val) {
sunxi_lcd_gpio_set_value(0, 3, 1);
} else {
sunxi_lcd_gpio_set_value(0, 3, 0);
static void SetMosiPinLevel(u8 val)
if (val) {
sunxi_lcd_gpio_set_value(0, 2, 1);
} else {
sunxi_lcd_gpio_set_value(0, 2, 0);
static void SetResetPinLevel(u8 val)
if (val) {
sunxi_lcd_gpio_set_value(0, 0, 1);
} else {
sunxi_lcd_gpio_set_value(0, 0, 0);
static void SpiWriteAddr(u8 dat)
u8 i;
SetCsPinLevel(HIGH);
SetClkPinLevel(LOW);
sunxi_lcd_delay_us(5);
SetCsPinLevel(LOW);
SetMosiPinLevel(LOW);
sunxi_lcd_delay_us(1);
SetClkPinLevel(HIGH);
for (i = 0; i < 8; i++) {
if (dat & 0x80) {
SetMosiPinLevel(HIGH);
} else {
dat <<= 1;
static void SpiWriteData(u8 dat)
u8 i;
if(dat & 0x80) {
} else {
dat <<= 1;
printk(KERN_INFO "=====================LCD_panel_init\n");
SpiWriteAddr(0x11);
sunxi_lcd_delay_ms(100);
SpiWriteAddr(0xBB);
SpiWriteData(0x00);
SpiWriteData(0x00);
SpiWriteData(0x00);
SpiWriteData(0x00);
SpiWriteData(0x00);
SpiWriteData(0x00);
SpiWriteData(0x5a);
SpiWriteData(0xa5);
SpiWriteData(0x0F);
SpiWriteAddr(0xc1);
SpiWriteData(0x73);
SpiWriteData(0x71);
SpiWriteData(0x02);
SpiWriteData(0x02);
SpiWriteData(0x71);
SpiWriteData(0x05);
SpiWriteData(0x06);
SpiWriteData(0x11);
SpiWriteData(0x55);
SpiWriteData(0x3F);
SpiWriteData(0xAA);
SpiWriteData(0xa0);
SpiWriteData(0x06);
SpiWriteData(0xFF);
SpiWriteData(0xFF);
SpiWriteData(0x7F);
SpiWriteData(0x4F);
SpiWriteData(0x52);
SpiWriteData(0x00);
SpiWriteData(0x4F);
SpiWriteData(0x52);
SpiWriteData(0x00);
SpiWriteData(0x96);
SpiWriteData(0x06);
SpiWriteData(0xC0);
SpiWriteData(0x01);
SpiWriteData(0x30);
SpiWriteData(0xC0);
SpiWriteData(0x01);
SpiWriteData(0x30);
SpiWriteAddr(0xc3);
SpiWriteData(0x05);
SpiWriteData(0x0A);
SpiWriteData(0x05);
SpiWriteData(0x0a);
SpiWriteData(0x00);
SpiWriteData(0xE0);
SpiWriteData(0x2E);
SpiWriteData(0x22);
SpiWriteData(0x1E);
SpiWriteData(0x78);
SpiWriteData(0x12);
SpiWriteData(0x22);
SpiWriteData(0x00);
SpiWriteData(0x00);
SpiWriteData(0x00);
SpiWriteData(0x0A);
SpiWriteData(0x0A);
SpiWriteData(0x10);
SpiWriteData(0x00);
SpiWriteData(0xF0);
SpiWriteData(0x18);
SpiWriteData(0x18);
SpiWriteData(0x40);
SpiWriteData(0x00);
SpiWriteData(0x22);
SpiWriteData(0x22);
SpiWriteData(0x0C);
SpiWriteData(0x00);
SpiWriteData(0xac);
SpiWriteData(0xca);
//11
SpiWriteAddr(0xCF);
SpiWriteData(0x47);
SpiWriteData(0x32);
SpiWriteData(0x00);
SpiWriteData(0x31);
SpiWriteData(0x55);
SpiWriteData(0x23);
SpiWriteData(0x12);
SpiWriteData(0x12);
SpiWriteData(0x51);
SpiWriteData(0x33);
SpiWriteData(0x00);
SpiWriteData(0x00);
SpiWriteData(0xFE);
SpiWriteData(0x01);
SpiWriteAddr(0xCD);
SpiWriteData(0x80);
SpiWriteData(0xd7);
SpiWriteData(0xad);
SpiWriteData(0x73);
SpiWriteData(0x00);
SpiWriteData(0x96);
SpiWriteData(0x0a);
SpiWriteData(0x01);
SpiWriteData(0x00);
SpiWriteData(0x14);
SpiWriteData(0x00);
SpiWriteData(0x04);
SpiWriteData(0xD0);
SpiWriteData(0xF8);
SpiWriteData(0x22);
SpiWriteData(0xD0);
SpiWriteData(0xE3);
SpiWriteData(0x22);
SpiWriteData(0x00);
SpiWriteAddr(0xd0);
SpiWriteData(0x01);
SpiWriteData(0x4A);
SpiWriteData(0xF8);
SpiWriteData(0x13);
SpiWriteData(0x20);
SpiWriteData(0x50);
SpiWriteData(0x07);
SpiWriteData(0xe8);
SpiWriteData(0x02);
SpiWriteData(0x07);
SpiWriteData(0x36);
SpiWriteData(0x05);
SpiWriteData(0x11);
SpiWriteData(0x0A);
SpiWriteData(0x64);
SpiWriteData(0x03);
SpiWriteData(0x03);
SpiWriteData(0x11);
SpiWriteData(0x64);
SpiWriteData(0x03);
SpiWriteData(0x00);
SpiWriteAddr(0xd3);
SpiWriteData(0x00);
SpiWriteData(0x3d);
SpiWriteData(0x40);
SpiWriteData(0x44);
SpiWriteData(0x46);
SpiWriteData(0x48);
SpiWriteData(0x4a);
SpiWriteData(0x49);
SpiWriteData(0x5c);
SpiWriteData(0x59);
SpiWriteData(0x59);
SpiWriteData(0x5a);
SpiWriteData(0x59);
SpiWriteData(0x5a);
SpiWriteData(0x5a);
SpiWriteData(0x7f);
SpiWriteData(0x94);
SpiWriteData(0xa0);
SpiWriteData(0xaa);
SpiWriteData(0xa6);
SpiWriteData(0xa7);
SpiWriteData(0xb5);
SpiWriteData(0xb2);
SpiWriteData(0xb5);
SpiWriteData(0xbe);
SpiWriteData(0xba);
SpiWriteData(0xb2);
SpiWriteData(0xb9);
SpiWriteData(0xc2);
SpiWriteAddr(0xd4);
SpiWriteData(0x00);
SpiWriteData(0x3d);
SpiWriteData(0x40);
SpiWriteData(0x44);
SpiWriteData(0x46);
SpiWriteData(0x48);
SpiWriteData(0x4a);
SpiWriteData(0x49);
SpiWriteData(0x5c);
SpiWriteData(0x59);
SpiWriteData(0x59);
SpiWriteData(0x5a);
SpiWriteData(0x59);
SpiWriteData(0x5a);
SpiWriteData(0x5a);
SpiWriteData(0x7f);
SpiWriteData(0x94);
SpiWriteData(0xa0);
SpiWriteData(0xaa);
SpiWriteData(0xa6);
SpiWriteData(0xa7);
SpiWriteData(0xb5);
SpiWriteData(0xb2);
SpiWriteData(0xb5);
SpiWriteData(0xbe);
SpiWriteData(0xba);
SpiWriteData(0xb2);
SpiWriteData(0xb9);
SpiWriteData(0xc2);
SpiWriteAddr(0xd5);
SpiWriteData(0x60);
SpiWriteData(0x60);
SpiWriteData(0x85);
SpiWriteData(0x60);
SpiWriteData(0x26);
SpiWriteData(0x44);
SpiWriteData(0x07);
SpiWriteData(0x07);
SpiWriteData(0x00);
SpiWriteData(0x07);
SpiWriteData(0x07);
SpiWriteData(0x00);
SpiWriteData(0x12);
SpiWriteData(0x4c);
SpiWriteData(0xD5);
SpiWriteData(0x15);
SpiWriteData(0x03);
SpiWriteData(0x03);
SpiWriteData(0x03);
SpiWriteData(0x03);
SpiWriteData(0x00);
SpiWriteData(0x03);
SpiWriteData(0x03);
SpiWriteData(0x00);
SpiWriteData(0xd0);
SpiWriteData(0xa2);
SpiWriteData(0x13);
SpiWriteData(0x60);
SpiWriteData(0x60);
SpiWriteData(0x00);
SpiWriteAddr(0xd6);
SpiWriteData(0x10);
SpiWriteData(0x32);
SpiWriteData(0x54);
SpiWriteData(0x76);
SpiWriteData(0x98);
SpiWriteData(0xBA);
SpiWriteData(0xDC);
SpiWriteData(0xFE);
SpiWriteData(0x01);
SpiWriteData(0x83);
SpiWriteData(0x00);
SpiWriteData(0x00);
SpiWriteData(0x07);
SpiWriteData(0x07);
SpiWriteData(0x00);
SpiWriteData(0x07);
SpiWriteData(0x07);
SpiWriteData(0x00);
SpiWriteData(0x03);
SpiWriteData(0x03);
SpiWriteData(0x03);
SpiWriteData(0x03);
SpiWriteData(0x03);
SpiWriteData(0x30);
SpiWriteData(0x10);
SpiWriteData(0x33);
SpiWriteData(0x77);
SpiWriteData(0x77);
SpiWriteData(0x40);
SpiWriteAddr(0xdd);
SpiWriteData(0x1d);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1e);
SpiWriteData(0x1f);
SpiWriteData(0x02);
SpiWriteData(0x00);
SpiWriteData(0x0c);
SpiWriteData(0x0e);
SpiWriteData(0x08);
SpiWriteData(0x0a);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteAddr(0xd9);
SpiWriteData(0x1c);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1e);
SpiWriteData(0x1f);
SpiWriteData(0x03);
SpiWriteData(0x01);
SpiWriteData(0x0d);
SpiWriteData(0x0f);
SpiWriteData(0x09);
SpiWriteData(0x0b);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteAddr(0xd7);
SpiWriteData(0x1d);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1e);
SpiWriteData(0x00);
SpiWriteData(0x02);
SpiWriteData(0x0a);
SpiWriteData(0x08);
SpiWriteData(0x0e);
SpiWriteData(0x0c);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteAddr(0xd8);
SpiWriteData(0x1c);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1e);
SpiWriteData(0x01);
SpiWriteData(0x03);
SpiWriteData(0x0b);
SpiWriteData(0x09);
SpiWriteData(0x0f);
SpiWriteData(0x0d);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteData(0x1f);
SpiWriteAddr(0xc4);
SpiWriteData(0x54);
SpiWriteData(0x00);
SpiWriteAddr(0xDF);
SpiWriteData(0x22);
SpiWriteData(0x03);
SpiWriteData(0x33);
SpiWriteData(0xf1);
SpiWriteData(0x33);
SpiWriteData(0x08);
SpiWriteData(0x02);
SpiWriteData(0x17);
SpiWriteData(0x00);
SpiWriteData(0x00);
SpiWriteData(0x20);
SpiWriteData(0x17);
SpiWriteAddr(0xCE);
SpiWriteData(0x01);
SpiWriteData(0x09);
SpiWriteData(0xF0);
SpiWriteData(0xF0);
SpiWriteData(0x03);
SpiWriteData(0x03);
SpiWriteData(0x04);
SpiWriteData(0x04);
SpiWriteData(0x04);
SpiWriteData(0x05);
SpiWriteData(0x06);
SpiWriteData(0x07);
SpiWriteData(0x08);
SpiWriteData(0x09);
SpiWriteData(0x0A);
SpiWriteData(0x0B);
SpiWriteData(0x0C);
SpiWriteData(0x0D);
SpiWriteData(0x0E);
SpiWriteData(0x0F);
SpiWriteData(0x10);
SpiWriteData(0x11);
SpiWriteData(0x12);
SpiWriteData(0x13);
SpiWriteData(0x14);
SpiWriteData(0x15);
SpiWriteData(0x16);
SpiWriteData(0x17);
SpiWriteData(0x18);
sunxi_lcd_delay_ms(200);
SpiWriteAddr(0x29);
return;
/* sel: 0:lcd0; 1:lcd1 */
static s32 LCD_user_defined_func(u32 sel, u32 para1, u32 para2, u32 para3)
struct __lcd_panel axs1832a_720x720_pannel = {
/* panel driver name, must mach the lcd_drv_name in sys_config.fex */
.name = "axs1832a_720x720",
.func = {
.cfg_panel_info = LCD_cfg_panel_info,
.cfg_open_flow = LCD_open_flow,
.cfg_close_flow = LCD_close_flow,
.lcd_user_defined_func = LCD_user_defined_func,
};static void LCD_panel_init(u32 sel)
LCD_panel_init函数里面有加了打印信息,但是log里面没看到有打印出来,模拟spi的IO口上也没有量到有波形,说明并未跑进LCD_panel_init函数;
打印log:
[113]HELLO! BOOT0 is starting!
[116]BOOT0 commit : 88480af
[118]set pll start
[120]fix vccio detect value:0xc0
[123]periph0 has been enabled
[126]set pll end
[128][pmu]: bus read error
[130]board init ok
[132]ZQ value = 0x2f
[134]get_pmu_exist() = -1
[137]ddr_efuse_type: 0xa
[139]trefi:7.8ms
[141][AUTO DEBUG] single rank and full DQ!
[145]ddr_efuse_type: 0xa
[147]trefi:7.8ms
[149][AUTO DEBUG] rank 0 row = 13
[153][AUTO DEBUG] rank 0 bank = 4
[156][AUTO DEBUG] rank 0 page size = 2 KB
[160]DRAM BOOT DRIVE INFO: V0.33
[163]DRAM CLK = 528 MHz
[165]DRAM Type = 2 (2:DDR2,3:DDR3)
[168]DRAMC read ODT off.
[171]DRAM ODT off.
[172]ddr_efuse_type: 0xa
[175]DRAM SIZE =64 M
[177]dram_tpr4:0x0
[179]PLL_DDR_CTRL_REG:0xf8002b00
[182]DRAM_CLK_REG:0xc0000000
[185][TIMING DEBUG] MR2= 0x0
[189]DRAM simple test OK.
[191]dram size =64
[193]card no is 0
[195]sdcard 0 line count 4
[197][mmc]: mmc driver ver 2021-04-2 16:45
[207][mmc]: Wrong media type 0x0
[210][mmc]: ***Try SD card 0***
[218][mmc]: HSSDR52/SDR25 4 bit
[221][mmc]: 50000000 Hz
[224][mmc]: 15240 MB
[225][mmc]: ***SD/MMC 0 init OK!!!***
[275]Loading boot-pkg Succeed(index=0).
[278]Entry_name = opensbi
[281]Entry_name = u-boot
[285]Entry_name = dtb
[288]mmc not para
▒289]Jump to second Boot.
U-Boot 2018.05-g24521d6 (Feb 11 2022 - 08:52:39 +0000) Allwinner Technology
[00.299]DRAM: 64 MiB
[00.301]Relocation Offset is: 01ee7000
[00.306]secure enable bit: 0
[00.309]CPU=720 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
[00.315]flash init start
[00.317]workmode = 0,storage type = 1
[00.321][mmc]: mmc driver ver uboot2018:2021-11-19 15:38:00
[00.326][mmc]: get sdc_type fail and use default host:tm1.
[00.333][mmc]: can't find node "mmc0",will add new node
[00.338][mmc]: fdt err returned <no error>
[00.342][mmc]: Using default timing para
[00.345][mmc]: SUNXI SDMMC Controller Version:0x50310
[00.363][mmc]: card_caps:0x3000000a
[00.366][mmc]: host_caps:0x3000003f
[00.369]sunxi flash init ok
[00.372]line:703 init_clocks
[00.375]drv_disp_init
request pwm success, pwm7:pwm7:0x2000c00.
[00.396]drv_disp_init finish
[00.399]boot_gui_init:start
[00.402]set disp.dev2_output_type fail. using defval=0
[00.409]boot_gui_init:finish
partno erro : can't find partition bootloader
54 bytes read in 1 ms (52.7 KiB/s)
[00.425]bmp_name=bootlogo.bmp size 38454
38454 bytes read in 3 ms (12.2 MiB/s)
[00.444]Loading Environment from SUNXI_FLASH... OK
[00.466]out of usb burn from boot: not need burn key
[00.500]Item0 (Map) magic is bad
[00.503]the secure storage item0 copy0 magic is bad
[00.537]Item0 (Map) magic is bad
[00.540]the secure storage item0 copy1 magic is bad
[00.545]Item0 (Map) magic is bad
partno erro : can't find partition private
root_partition is rootfs
set root to /dev/mmcblk0p5
[00.557]update part info
[00.560]update bootcmd
[00.563]change working_fdt 0x42aa6da0 to 0x42a86da0
disable nand error: FDT_ERR_BADPATH
No reserved memory region found in source FDT
FDT ERROR:get muxsel err returned FDT_ERR_INTERNAL
sunxi_pwm_pin_set_state, fdt_set_all_pin, ret=-1
[00.600]LCD open finish
[00.614]update dts
noncached_alloc(): addr = 0x42c8a080
noncached_alloc(): addr = 0x42c8a0c0
noncached_alloc(): addr = 0x42c8a100
noncached_alloc(): addr = 0x42c8a940
geth_sys_init:634: get node 'gmac0' error
geth_sys_init fail!
[00.635]Board Net Initialization Failed
[00.638]No ethernet found.
[01.941]no vendor_boot partition is found
Android's image name: d1s-nezha
Detect comp none
[01.958]
[01.960][mmc]: MMC Device 2 not found
[01.964][mmc]: mmc 2 not find, so not exit
** 2 printk messages dropped **
DMA32 [mem 0x0000000040000000-0x0000000043ffffff]
Normal empty
Movable zone start for each node
Early memory node ranges
node 0: [mem 0x0000000040000000-0x0000000043ffffff]
Initmem setup node 0 [mem 0x0000000040000000-0x0000000043ffffff]
On node 0 totalpages: 16384
DMA32 zone: 224 pages used for memmap
DMA32 zone: 0 pages reserved
DMA32 zone: 16384 pages, LIFO batch:3
elf_hwcap is 0x20112d
pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
pcpu-alloc: [0] 0
Built 1 zonelists, mobility grouping on. Total pages: 16160
Kernel command line: earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p5 init=/pseudo_init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:recovery@mmcblk0p6:rootfs_data@mmcblk0p7:UDISK@mmcblk0p8 cma=0M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun20iw1p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.05-g24521d6(02/11/2022-08:52:39) mbr_
Dentry cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
Inode-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
Sorting __ex_table...
mem auto-init: stack:off, heap alloc:off, heap free:off
Memory: 55728K/65536K available (4316K kernel code, 397K rwdata, 1681K rodata, 140K init, 229K bss, 9808K reserved, 0K cma-reserved)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
rcu: Preemptible hierarchical RCU implementation.
Tasks RCU enabled.
rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
NR_IRQS: 0, nr_irqs: 0, preallocated irqs: 0
plic: mapped 200 interrupts with 1 handlers for 2 contexts.
riscv_timer_init_dt: Registering clocksource cpuid [0] hartid [0]
clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
sched_clock: 64 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
riscv_timer_clockevent depends on broadcast, but no broadcast function available
clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
ASID allocator initialised with 65536 entries
rcu: Hierarchical SRCU implementation.
devtmpfs: initialized
random: get_random_u32 called from bucket_table_alloc.isra.27+0xfe/0x120 with crng_init=0
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
futex hash table entries: 256 (order: 0, 6144 bytes, linear)
pinctrl core: initialized pinctrl subsystem
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic allocations
cpuidle: using governor menu
rtc_ccu: sunxi ccu init OK
clock: sunxi ccu init OK
iommu: Default domain type: Translated
sunxi iommu: irq = 4
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
videodev: Linux video capture interface: v2.00
Advanced Linux Sound Architecture Driver Initialized.
pwm module init!
g2d 5410000.g2d: Adding to iommu group 0
G2D: rcq version initialized.major:252
clocksource: Switched to clocksource riscv_clocksource
sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
NET: Registered protocol family 2
tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
TCP established hash table entries: 512 (order: 0, 4096 bytes, linear)
TCP bind hash table entries: 512 (order: 0, 4096 bytes, linear)
TCP: Hash tables configured (established 512 bind 512)
UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
spi spi0: spi0 supply spi not found, using dummy regulator
sunxi_spi_resource_get()2151 - [spi0] SPI MASTER MODE
sunxi_spi_resource_get()2189 - Failed to get sample mode
sunxi_spi_resource_get()2194 - Failed to get sample delay
sunxi_spi_resource_get()2198 - sample_mode:-1431633921 sample_delay:-1431633921
sunxi_spi_clk_init()2240 - [spi0] mclk 100000000
sunxi_spi_probe()2653 - [spi0]: driver probe succeed, base ffffffd004058000, irq 31
workingset: timestamp_bits=62 max_order=14 bucket_order=0
squashfs: version 4.0 (2009/01/31) Phillip Lougher
ntfs: driver 2.1.32 [Flags: R/W].
io scheduler mq-deadline registered
io scheduler kyber registered
[DISP]disp_module_init
disp 5000000.disp: Adding to iommu group 0
[DISP] parser_disp_init_para,line:1430:
of_property_read fb0_width fail
[DISP] disp_init,line:2386:
smooth display screen:0 type:1 mode:4
display_fb_request,fb_id:0
Freeing logo buffer memory: 1500K
disp_al_manager_apply ouput_type:1
[DISP] lcd_clk_config,line:732:
disp 0, clk: pll(210000000),clk(210000000),dclk(35000000) dsi_rate(210000000)
clk real:pll(288000000),clk(288000000),dclk(48000000) dsi_rate(0)
sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
[DISP]disp_module_init finish
sunxi_sid_init()551 - insmod ok
pwm-regulator: supplied by regulator-dummy
sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
uart uart0: get regulator failed
uart uart0: uart0 supply uart not found, using dummy regulator
uart0: ttyS0 at MMIO 0x2500000 (irq = 18, base_baud = 1500000) is a SUNXI
sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
printk: console [ttyS0] enabled
misc dump reg init
sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=131 assert=1
sun8iw20-pinctrl 2000000.pinctrl: pin PE3 already requested by 2500000.uart; cannot claim for 2000000.pinctrl:131
sun8iw20-pinctrl 2000000.pinctrl: pin-131 (2000000.pinctrl:131) status -22
sunxi-rfkill soc@3000000:rfkill@0: can't request wlan_regon gpio 131
sunxi-rfkill: probe of soc@3000000:rfkill@0 failed with error -22
[ADDR_MGT] addr_mgt_probe: module version: v1.0.10
[ADDR_MGT] addr_mgt_probe: success.
sunxi-spinand: AW SPINand MTD Layer Version: 2.0 20201228
sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.10 20200306
sunxi-spinand-phy: not detect any munufacture from id table
sunxi-spinand-phy: get spi-nand Model from fdt fail
sunxi-spinand-phy: get phy info from fdt fail
sunxi-spinand-phy: not detect munufacture from fdt
sunxi-spinand-phy: detect munufacture from id table: Micron
sunxi-spinand-phy: detect spinand id: ffff242c ffffffff
sunxi-spinand-phy: ========== arch info ==========
sunxi-spinand-phy: Model: MT29F2G01ABAGDWB
sunxi-spinand-phy: Munufacture: Micron
sunxi-spinand-phy: DieCntPerChip: 1
sunxi-spinand-phy: BlkCntPerDie: 2048
sunxi-spinand-phy: PageCntPerBlk: 64
sunxi-spinand-phy: SectCntPerPage: 4
sunxi-spinand-phy: OobSizePerPage: 64
sunxi-spinand-phy: BadBlockFlag: 0x0
sunxi-spinand-phy: OperationOpt: 0x8f
sunxi-spinand-phy: MaxEraseTimes: 65000
sunxi-spinand-phy: EccFlag: 0x0
sunxi-spinand-phy: EccType: 6
sunxi-spinand-phy: EccProtectedType: 5
sunxi-spinand-phy: ========================================
sunxi-spinand-phy:
sunxi-spinand-phy: ========== physical info ==========
sunxi-spinand-phy: TotalSize: 256 M
sunxi-spinand-phy: SectorSize: 512 B
sunxi-spinand-phy: PageSize: 2 K
sunxi-spinand-phy: BlockSize: 128 K
sunxi-spinand-phy: OOBSize: 64 B
sunxi-spinand-phy:
sunxi-spinand-phy: ========== logical info ==========
sunxi-spinand-phy: PageSize: 4 K
sunxi-spinand-phy: BlockSize: 256 K
sunxi-spinand-phy: OOBSize: 128 B
sunxi-spinand-phy: MT29F2G01ABAGDWB reset rx bit width to 1
sunxi-spinand-phy: MT29F2G01ABAGDWB reset tx bit width to 1
sunxi-spinand-phy: block lock register: 0x00
sunxi-spinand-phy: feature register: 0x10
sunxi-spinand-phy: sunxi physic nand init end
Creating 4 MTD partitions on "sunxi_mtd_nand":
0x000000000000-0x000000100000 : "boot0"
0x000000100000-0x000000500000 : "uboot"
random: fast init done
0x000000500000-0x000000600000 : "secure_storage"
0x000000600000-0x000010000000 : "sys"
random: crng init done
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
sunxi-ehci: EHCI SUNXI driver
get ehci1-controller wakeup-source is fail.
sunxi ehci1-controller don't init wakeup source
[sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xffffffe00068b870, 0x:ffffffd00406f000, irq_no:31
sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply drvvbus not found, using dummy regulator
sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
sunxi-ehci 4200000.ehci1-controller: irq 49, io mem 0x04200000
sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
sunxi-ohci: OHCI SUNXI driver
get ohci1-controller wakeup-source is fail.
sunxi ohci1-controller don't init wakeup source
[sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xffffffe00068bc38
sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply drvvbus not found, using dummy regulator
sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
sunxi-ohci 4200400.ohci1-controller: irq 50, io mem 0x04200400
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
sunxi-rtc 7090000.rtc: errata__fix_alarm_day_reg_default_value(): ALARM0_DAY_REG=0, set it to 1
sunxi-rtc 7090000.rtc: registered as rtc0
sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:00:04 UTC (4)
sunxi-rtc 7090000.rtc: sunxi rtc probed
i2c /dev entries driver
IR NEC protocol handler initialized
uvcvideo: Unable to create debugfs directory
usbcore: registered new interface driver uvcvideo
USB Video Class driver (1.1.1)
sunxi cedar version 1.1
sunxi-cedar 1c0e000.ve: Adding to iommu group 0
VE: install start!!!
VE: cedar-ve the get irq is 6
VE: install end!!!
VE: sunxi_cedar_probe
sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
sunxi-mmc 4020000.sdmmc: No vmmc regulator found
sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
sunxi-mmc 4020000.sdmmc: Got CD GPIO
sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
sunxi-mmc 4020000.sdmmc: detmode:gpio irq
sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
sunxi-mmc 4021000.sdmmc: No vmmc regulator found
sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
sunxi-mmc 4021000.sdmmc: detmode:manually by software
sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
ashmem: initialized
exFAT: Version 1.3.0
mmc0: host does not support reading read-only switch, assuming write-enable
[AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
[AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished
sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
mmc0: new high speed SDHC card at address 59b4
sid_rd_ver_reg()254 - ver >= 4, soc ver:5
[SNDCODEC][sunxi_card_init][583]:card init finished
sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
mmcblk0: mmc0:59b4 14.9 GiB
mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input0
[SNDCODEC][sunxi_card_dev_probe][836]:register card finished
NET: Registered protocol family 10
[SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
Segment Routing with IPv6
NET: Registered protocol family 17
sunxi-i2c sunxi-i2c2: sunxi-i2c2 supply twi not found, using dummy regulator
sunxi-i2c sunxi-i2c2: probe success
sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
get ehci0-controller wakeup-source is fail.
sunxi ehci0-controller don't init wakeup source
[sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xffffffe00068b0e0, 0x:ffffffd004875000, irq_no:2e
[sunxi-ehci0]: Not init ehci0
get ohci0-controller wakeup-source is fail.
sunxi ohci0-controller don't init wakeup source
[sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xffffffe00068b4a8
[sunxi-ohci0]: Not init ohci0
clk: Not disabling unused clocks
ALSA device list:
platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
#0: audiocodec
alloc_fd: slot 0 not NULL!
cfg80211: failed to load regulatory.db
VFS: Mounted root (squashfs filesystem) readonly on device 179:5.
devtmpfs: mounted
Freeing unused kernel memory: 140K
This architecture does not have kernel memory protection.
Run /pseudo_init as init process
mount: mounting none on /dev failed: Device or resource busy
mount: mounting /dev/by-name/rootfs_data on /overlay failed: No such device
Mount Failed: formating /dev/by-name/rootfs_data to ext4 ...
/pseudo_init: line 395: mkfs.ext4: not found
can't run '/etc/preinit': No such file or directory
mount: mounting proc on /proc failed: Device or resource busy
mount: mounting tmpfs on /run failed: No such file or directory
hostname: can't open '/etc/hostname': No such file or directory
------run rc.preboot file-----
/etc/init.d/rcS: line 136: mkfs.ext4: not found
------run rc.modules file-----
------run rc.final file-----
file system registered
configfs-gadget 4100000.udc-controller: failed to start g1: -19
sh: write error: No such device
read descriptors
read strings
insmod_host_driver
[ehci0-controller]: sunxi_usb_enable_ehci
sunxi-ehci 4101000.ehci0-controller: 4101000.ehci0-controller supply hci not found, using dummy regulator
sunxi-ehci 4101000.ehci0-controller: EHCI Host Controller
sunxi-ehci 4101000.ehci0-controller: new USB bus registered, assigned bus number 3
sunxi-ehci 4101000.ehci0-controller: irq 46, io mem 0x04101000
sunxi-ehci 4101000.ehci0-controller: USB 2.0 started, EHCI 1.00
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
[ohci0-controller]: sunxi_usb_enable_ohci
sunxi-ohci 4101400.ohci0-controller: 4101400.ohci0-controller supply hci not found, using dummy regulator
sunxi-ohci 4101400.ohci0-controller: OHCI Host Controller
sunxi-ohci 4101400.ohci0-controller: new USB bus registered, assigned bus number 4
sunxi-ohci 4101400.ohci0-controller: irq 47, io mem 0x04101400
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 1 port detected
host_chose finished!
nice: can't execute '/usr/bin/story_ota_bin': No such file or directory
------run profile file-----
_____ _ __ _
|_ _||_| ___ _ _ | | |_| ___ _ _ _ _
| | _ | || | | |__ | || || | ||_'_|
| | | || | || _ | |_____||_||_|_||___||_,_|
|_| |_||_|_||_|_| Tina is Based on OpenWrt!
Tina Linux (Neptune, 61CC0487)
root@TinaLinux:/#
root@TinaLinux:/#
root@TinaLinux:/# ls /dev/
ashmem kmsg mtd2 snd
bus mmcblk0 mtd2ro sunxi-reg
by-name mmcblk0p1 mtd3 sunxi_pwm0
cedar_dev mmcblk0p2 mtd3ro sunxi_soc_info
console mmcblk0p3 mtdblock0 tty
cpu_dma_latency mmcblk0p4 mtdblock1 ttyS0
disp mmcblk0p5 mtdblock2 ubi_ctrl
fb0 mmcblk0p6 mtdblock3 urandom
full mmcblk0p7 null usb-ffs
g2d mmcblk0p8 ptmx video4
gpiochip0 mtd0 pts zero
i2c-2 mtd0ro random
input mtd1 rtc0
ion mtd1ro shm
root@TinaLinux:/# cat /sys/class/
addr_mgt/ ieee80211/ scsi_host/
android_usb/ input/ sound/
bdi/ iommu/ spi_master/
block/ mem/ sunxi_dump/
cedar_ve/ misc/ sunxi_info/
devlink/ mmc_host/ sunxi_pwm_char_class/
disp/ mtd/ tty/
dma/ net/ ubi/
g2d/ power_supply/ udc/
gpio/ pwm/ udc_reg/
graphics/ rc/ usb_role/
hci_reg/ regulator/ video4linux/
hwmon/ rtc/ wakeup/
i2c-adapter/ scsi_device/
i2c-dev/ scsi_disk/
root@TinaLinux:/# cat /sys/class/graphics/fb0/
bits_per_pixel mode state
blank modes stride
console name subsystem/
cursor pan uevent
dev power/ virtual_size
device/ rotate waiting_for_supplier
root@TinaLinux:/# cat /sys/class/graphics/fb0/mode
mode modes
root@TinaLinux:/# cat /sys/class/graphics/fb0/modes
U:720x720p-60
root@TinaLinux:/#有大佬知道是什么原因吗?
驱动配置信息:
根据log定位到drivers/video/fbdev/sunxi/disp2/disp/dev_disp_debugfs.c中:
int dispdbg_init(void)
my_dispdbg_root = debugfs_create_dir("dispdbg", NULL);
printk(KERN_INFO "[%s] %s: %d\n", __FILE__, __FUNCTION__, __LINE__);
if (!debugfs_create_file
("command", 0644, my_dispdbg_root, NULL, &command_ops))
goto Fail;
("name", 0644, my_dispdbg_root, NULL, &name_ops))
goto Fail;
("start", 0644, my_dispdbg_root, NULL, &start_ops))
goto Fail;
("param", 0644, my_dispdbg_root, NULL, ¶m_ops))
goto Fail;
("info", 0644, my_dispdbg_root, NULL, &info_ops))
goto Fail;
("dbglvl", 0644, my_dispdbg_root, NULL, &dbglvl_ops))
goto Fail;
#if defined(CONFIG_SUNXI_MPP)
if (debugfs_mpp_root) {
if (!debugfs_create_file("vo", 0644, debugfs_mpp_root, NULL,
&vo_ops))
goto Fail;
#endif /*endif CONFIG_SUNXI_MPP */
Fail:
debugfs_remove_recursive(my_dispdbg_root);
my_dispdbg_root = NULL;
return -ENOENT;
static const struct file_operations start_ops = {
.write = dispdbg_start_write,
.read = dispdbg_start_read,
.open = dispdbg_start_open,
.release = dispdbg_start_release,
static ssize_t dispdbg_start_write(struct file *file, const char __user *buf,
size_t count, loff_t *ppos)
if (count >= sizeof(dispdbg_priv.start))
if (copy_from_user(dispdbg_priv.start, buf, count)) {
pr_warn("copy_from_user fail\n");
if (dispdbg_priv.start[count - 1] == 0x0A)
dispdbg_priv.start[count - 1] = 0;
dispdbg_priv.start[count] = 0;
dispdbg_process();
return count;
static void dispdbg_process(void)
if (!strncmp(dispdbg_priv.command, "enable", 6)) {
lcd->enable(lcd);
}调用的层次是
dispdbg_init()
("start", 0644, my_dispdbg_root, NULL, &start_ops));
dispdbg_start_write();
dispdbg_process();
lcd->enable(lcd);
在lcd->enable(lcd)中最后会调用到LCD_panel_init函数;
log看到的是只执行了:
start_ops里的.wrire函数dispdbg_start_write没有执行到,导致了LCD_panel_init函数没有被执行;
是要在应用程序里面操作fb0设备才会执行dispdbg_start_write 进行初始化?
但是用cat /dev/urandom > /dev/fb0 并没有看到dispdbg_start_write被执行到的log;
哇酷小二 wrote:
是 NV3052C 驱动芯片吗?
不是,是公司弄的一颗芯片......
哇酷小二 wrote:
岁月快快快 wrote:
哇酷小二 wrote:
是 NV3052C 驱动芯片吗?
不是,是公司弄的一颗芯片......
逻辑分析仪搭一下,很容易判断问题的。
不是时序的问题,是初始化函数都没跑进去,发不了spi初始化数据。。。
修改了uboot的屏驱动和设备树,就可以初始化了,这样的话不就是内核里面的屏驱动没起作用
最近编辑记录 岁月快快快 (2022-04-29 11:14:24)
