I've been unsuccessfully trying to expose the Lichee Nano as an MTP device to a Linux Host using https://github.com/viveris/uMTP-Responder. First tried using GadgetFS and then FunctionFS. I'm using Icenowy's 4.15 kernel.
uMTPrd config
umtprd.conf.txt
Startup script
umtprd.conf.txt
Startup log
Linux .config config.txt
Has anyone had similar issues or gotten this to work?? Any help would be much appreciated
最近编辑记录 droptop (2022-08-02 17:03:02)
Was finally able to get an MTP device on my PC by switching to 5.2 and applying this patch
