楼主 # 2022-08-02 16:41:26
droptop
已发帖子: 23
Trying to turn the Lichee Pi Nano into a USB gadget
I've been unsuccessfully trying to expose the Lichee Nano as an MTP device to  a Linux Host using https://github.com/viveris/uMTP-Responder. First tried using GadgetFS and then FunctionFS. I'm using Icenowy's 4.15 kernel.
uMTPrd config
umtprd.conf.txt
Startup script
umtprd.conf.txt
Linux .config config.txt
Has anyone had similar issues or gotten this to work?? Any help would be much appreciated
最近编辑记录 droptop (2022-08-02 17:03:02)
楼主 #1 2022-08-03 17:56:08
droptop
已发帖子: 23
Re: Trying to turn the Lichee Pi Nano into a USB gadget
Was finally able to get an MTP device on my PC by switching to 5.2 and applying this patch
