楼主 # 2022-08-26 17:10:38
dg
已发帖子: 38
stm32f446外接PSRAM的问题
板子
       单片机:STM32F446
       PSRAM: APS6404L    (PageSize=1024Bytes)
硬件接线
    PB2:       QSPI_CLK    6
    PC11:      QSPI_NCS    1
    PE7:       QSPI_IO0    5
    PE8:      QSPI_IO1    2
    PE9:     QSPI_IO2    3
    PE10:    QSPI_IO3    7
软件环境
        HAL库
问题:
1: 能通信上,但QPI模式只能工作在2线数据, 4线数据则数据不正确
2: 写入后立即读出同一地址的数据没问题;但往前读则读到的数据是最后写入的数据
    猜测是Page的机制问题,如何跨页读取?
初始化代码:
int QSPI_PSRAM_Init(void)
  QSPIHandle.Instance = QUADSPI;
  QSPIHandle.Init.ClockPrescaler     = 2;
  QSPIHandle.Init.FifoThreshold      = 4;
  QSPIHandle.Init.SampleShifting     = QSPI_SAMPLE_SHIFTING_NONE;
  QSPIHandle.Init.FlashSize          = 22;//64Mbits=8Mbtye=2^23.size取22。
  QSPIHandle.Init.ChipSelectHighTime = QSPI_CS_HIGH_TIME_2_CYCLE;
  QSPIHandle.Init.ClockMode          = QSPI_CLOCK_MODE_0;
  QSPIHandle.Init.FlashID            = QSPI_FLASH_ID_2;
  QSPIHandle.Init.DualFlash          = QSPI_DUALFLASH_DISABLE;       //禁止双闪存模式
  if (HAL_QSPI_Init(&QSPIHandle) != HAL_OK)
    return PSRAM_ERR_INIT;
  QSPI_PSRAM_Resetenable(&QSPIHandle);
  QSPI_PSRAM_Reset(&QSPIHandle);
  HAL_Delay(1);
  return PSRAM_OK;
void HAL_QSPI_MspInit(QSPI_HandleTypeDef* hqspi)
  GPIO_InitTypeDef GPIO_InitStruct = {0};
   //static DMA_HandleTypeDef hdma;
  if(hqspi->Instance==QUADSPI)
    /* USER CODE END QUADSPI_MspInit 0 */
    /* Peripheral clock enable */
    __HAL_RCC_QSPI_CLK_ENABLE();
    /* Reset the QuadSPI memory interface */
    __HAL_RCC_QSPI_FORCE_RESET();
    __HAL_RCC_QSPI_RELEASE_RESET();
    __HAL_RCC_GPIOB_CLK_ENABLE();
    __HAL_RCC_GPIOE_CLK_ENABLE();
    __HAL_RCC_GPIOC_CLK_ENABLE();
    /* Enable DMA clock */
    QSPI_DMA_CLK_ENABLE();
    /**QUADSPI GPIO Configuration
    PB2     ------> QUADSPI_CLK
    PE7     ------> QUADSPI_BK2_IO0
    PE8     ------> QUADSPI_BK2_IO1
    PE9     ------> QUADSPI_BK2_IO2
    PE10     ------> QUADSPI_BK2_IO3
    PC11     ------> QUADSPI_BK2_NCS
    GPIO_InitStruct.Pin = GPIO_PIN_2;
    GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
    GPIO_InitStruct.Pull = GPIO_PULLUP;
    GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
    GPIO_InitStruct.Alternate = GPIO_AF9_QSPI;
    HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
    GPIO_InitStruct.Pin = GPIO_PIN_7|GPIO_PIN_8|GPIO_PIN_9|GPIO_PIN_10;
    GPIO_InitStruct.Pull = GPIO_NOPULL; //GPIO_PULLUP;
    GPIO_InitStruct.Alternate = GPIO_AF10_QSPI;
    HAL_GPIO_Init(GPIOE, &GPIO_InitStruct);
    GPIO_InitStruct.Pin = GPIO_PIN_11;
    HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
    /* USER CODE BEGIN QUADSPI_MspInit 1 */
    /* USER CODE END QUADSPI_MspInit 1 */
    HAL_NVIC_SetPriority(QUADSPI_IRQn, 0x0F, 0);
    HAL_NVIC_EnableIRQ(QUADSPI_IRQn);
    //中断使能
    //__HAL_QSPI_ENABLE_IT(hqspi, QSPI_IT_TC);
读写代码
int QSPI_PSRAM_ReadPage(QSPI_HandleTypeDef *hQspi,uint8_t *pData,uint32_t FirstAddr, uint32_t BufSize)
	QSPI_Send_CMD(hQspi,PSRAM_CMD_READ_QUAD,FirstAddr,PSRAM_QPI_READ_DUMCYCLES,QSPI_INSTRUCTION_4_LINES,QSPI_ADDRESS_1_LINE,QSPI_ADDRESS_24_BITS,QSPI_DATA_2_LINES,BufSize);
	return _Read(hQspi,pData);
int QSPI_PSRAM_WritePage(QSPI_HandleTypeDef *hQspi,uint8_t *pData,uint32_t FirstAddr, uint32_t BufSize)
	QSPI_Send_CMD(hQspi,PSRAM_CMD_WRITE_QUAD,FirstAddr,PSRAM_QPI_WRITE_DUMCYCLES,QSPI_INSTRUCTION_4_LINES,QSPI_ADDRESS_1_LINE,QSPI_ADDRESS_24_BITS,QSPI_DATA_2_LINES,BufSize);
	hQspi->Instance->DLR = BufSize-1;
	return _Write(hQspi,pData);
测试代码:
这样读写是成功的:
	for (i=0; i<8; i++)
		memset(temp,i%0xff,1024);
		r1 = QSPI_PSRAM_WritePage(&QSPIHandle,(uint8_t*)temp,i*1024,1024);
		memset(temp, 0, 1024);
		r1 = QSPI_PSRAM_ReadPage(&QSPIHandle,(uint8_t*)temp, i*1024, 1024);
		//测试发现:写1块立即读该块,都是成功的!
		if (temp[123]!=(i%0xff))
			e++;
			printf("err:%d times, i=%d -->",e, i);    //只要不打这个就是好的
这样写,再读,读到的数据就总是最后写入的数据:
        //写入:
	for (i=0; i<8; i++)
        //读出:
	for (i=0; i<8; i++)
		if (temp[30]!=(i%0xff))
                   printf("%4d: ",i*1024);
		   ShowBuffer(temp,32);
#1 2022-08-26 18:32:02
海石生风
已发帖子: 525
Re: stm32f446外接PSRAM的问题
如果一个数据所占用的空间跨了两页,那么就要分两次写,第一次写到第一个页的结尾,第二次从下一个页开始写。
楼主 #2 2022-08-27 09:45:10
dg
已发帖子: 38
写入暂时没问题。主要是读出。
比如连续写了 1.2.3.4.5 共5页。
然后再回读第1页, 发现第1页是第5页的内容。
但如果 写1读1,写2读2,写5读5. 这样操作则数据都是正确的
楼主 #3 2022-08-27 10:01:01
dg
已发帖子: 38
从这个文件看来,PSRAM只需要不在同一次CS中,即可任意换页。
而我的设置,采用的是MCU自己产生的CS信号,量了下波形也是每次发命令就发的CS。
所以应该是可以换页的。不知何故。。。
