楼主 # 2022-09-23 12:31:30
wupaul2001
已发帖子: 304
请教longan
大佬们好,我板上的PMU是AXP707, 但longanSDK里没这个PMU,只有AXP803, AXP806, AXP858, AXP2202。 请教我应该选那个?
[38145]fes begin:83e3c82
[38147]set pll start
[38149]periph0 has been enabled
[38153]set pll end
[38155][pmu]: bus read error
[38159]PMU: AXP803
[38179]vaild para:1  select dram para0
[38183]board init ok
[38185]beign to init dram
[38188]DRAM BOOT DRIVE INFO: V0.61
[38191]the chip id is 0x1400
[38194]the chip id is 0x1400
[38197]the chip id is 0x1400
[38200]the chip id is 0x1400
[38203]the chip id is 0x1400
[38206]chip id check OK
[38211]DRAM_VCC set to 1200 mv
[38241]DRAM retraining ten
[38271]DRAM retraining ten
[38302]DRAM retraining ten
[38331]DRAM retraining ten
[38335]init dram fail
用PhoenixSuit烧录时,串口打印这个,但DDR用dragonhd检测是正常的,现在怀疑是PMU问题,有大佬遇到过吗???
最近编辑记录 wupaul2001 (2022-09-23 12:46:22)
