我的启动卡rootfs分区是1GB,文件系统格式为ext4,这个是在TinaSDK里面配置的,另外还重新配置了sys_partition.fex文件:
我拷贝Qt5安装文件夹的压缩包到启动卡里面去,再把压缩包解压出来,就出现了大量的
Cannot mkdir: No space left on device
报错
部分错误:
tar: qt5.12.9-arm-t113/qml: Cannot mkdir: No space left on device
tar: qt5.12.9-arm-t113/qml/QtCharts/designer/default/SplineSeries.qml: Cannot open: No such file or directory
tar: qt5.12.9-arm-t113/qml/QtCharts/designer/default/LineSeries.qml: Cannot open: No such file or directory
tar: qt5.12.9-arm-t113/qml/QtCharts/designer/default/PolarAreaSeries.qml: Cannot open: No such file or directory
tar: qt5.12.9-arm-t113/qml/QtCharts/designer/default/StackedBarSeries.qml: Cannot open: No such file or directory
tar: qt5.12.9-arm-t113/qml/QtCharts/designer/default/AreaSeries.qml: Cannot open: No such file or directory
tar: qt5.12.9-arm-t113/qml/QtCharts/designer/default/BoxPlotSeries.qml: Cannot open: No such file or directory
tar: qt5.12.9-arm-t113/qml/QtCharts/designer/default/HorizontalPercentBarSeries.qml: Cannot open: No such file or directory
tar: qt5.12.9-arm-t113/qml/QtCharts/designer/default/BarSeries.qml: Cannot open: No such file or directory
tar: qt5.12.9-arm-t113/qml/QtCharts/designer/default/PolarSplineSeries.qml: Cannot open: No such file or directory
tar: qt5.12.9-arm-t113/qml/QtCharts/designer/default/PolarLineSeries.qml: Cannot open: No such file or directory
tar: qt5.12.9-arm-t113/qml/QtCharts/designer/default/PolarScatterSeries.qml: Cannot open: No such file or directory
tar: qt5.12.9-arm-t113/qml/QtCharts/designer/default/ScatterSeries.qml: Cannot open: No such file or directory
tar: qt5.12.9-arm-t113/qml/QtCharts/libqtchartsqml2.so: Cannot open: No such file or directory
tar: qt5.12.9-arm-t113/qml/QtCharts/plugins.qmltypes: Cannot open: No such file or directory
tar: Exiting with failure status due to previous errors
我直接拷贝Qt安装文件到启动卡也是会报错,所以我就先压缩,把压缩包拷贝到启动卡里面去没有问题,然后解压的时候才出现。
这是我使用GParted软件查看SD卡分区的截图,/dev/sdb5是1GB的ext4分区。
如下是我查看的结果,/dev/sdb5分区就是rootfs分区。奇怪的是1GB的分区大小只有6016个inodes,有没有大佬知道?
liefyuan@ubuntu:/media/liefyuan/57f8f4bc-abf4-655f-bf67-946fc0f9f25b/opt/qt5.12.9-arm-t113/examples$ df -i
Filesystem Inodes IUsed IFree IUse% Mounted on
udev 1784537 520 1784017 1% /dev
tmpfs 1792228 786 1791442 1% /run
/dev/sda1 6496256 2324896 4171360 36% /
tmpfs 1792228 9 1792219 1% /dev/shm
tmpfs 1792228 5 1792223 1% /run/lock
tmpfs 1792228 17 1792211 1% /sys/fs/cgroup
tmpfs 1792228 35 1792193 1% /run/user/1000
/dev/sdb1 0 0 0 - /media/liefyuan/Volumn
/dev/sdb5 6016 6016 0 100% /media/liefyuan/57f8f4bc-abf4-655f-bf67-946fc0f9f25b
/dev/sdb7 6288 11 6277 1% /media/liefyuan/280c157f-8c2e-4d5e-a838-c73b3e13d956
liefyuan@ubuntu:/media/liefyuan/57f8f4bc-abf4-655f-bf67-946fc0f9f25b/opt/qt5.12.9-arm-t113/examples$ df -k
Filesystem 1K-blocks Used Available Use% Mounted on
udev 7138148 0 7138148 0% /dev
tmpfs 1433784 9588 1424196 1% /run
/dev/sda1 102094168 72437412 24447568 75% /
tmpfs 7168912 252 7168660 1% /dev/shm
tmpfs 5120 4 5116 1% /run/lock
tmpfs 7168912 0 7168912 0% /sys/fs/cgroup
tmpfs 1433784 76 1433708 1% /run/user/1000
/dev/sdb1 8151 42 8109 1% /media/liefyuan/Volumn
/dev/sdb5 1046968 248480 782104 25% /media/liefyuan/57f8f4bc-abf4-655f-bf67-946fc0f9f25b
/dev/sdb7 21586 14 21081 1% /media/liefyuan/280c157f-8c2e-4d5e-a838-c73b3e13d956
/dev/sdb8 28473856 24 28457448 1% /media/liefyuan/fcb51570-6dd7-4b8d-b0f7-2c15b18cac56
在Tina系统中的文件系统配置:
sys_partition.fex文件的配置:
; 说明: 脚本中的字符串区分大小写,用户可以修改"="后面的数值,但是不要修改前面的字符串
; 固件下载参数配置
; mbr的大小, 以Kbyte为单位
[mbr]
size = 16384
; 分区配置
; partition 定义范例:
; [partition] ; //表示是一个分区
; name = USERFS2 ; //分区名称
; size = 16384 ; //分区大小 单位: 扇区.分区表示个数最多2^31 * 512 = 2T
; downloadfile = "123.fex" ; //下载文件的路径和名称,可以使用相对路径,相对是指相对于image.cfg文件所在分区。也可以使用绝对路径
; keydata = 1 ; //私有数据分区,重新量产数据将不丢失
; encrypt = 1 ; //采用加密方式烧录,将提供数据加密,但损失烧录速度
; user_type = ? ; //私有用法
; verify = 1 ; //要求量产完成后校验是否正确
; 注:1、name唯一, 不允许同名
; 2、name最大12个字符
; 3、size = 0, 将创建一个无大小的空分区
; 4、align to logical block size(504 sectors), leb size = 2*(1 nand phy block size - 1 phy page size)
[partition_start]
[partition]
name = boot-resource
size = 504
downloadfile = "boot-resource.fex"
user_type = 0x8000
[partition]
name = env
size = 504
downloadfile = "env.fex"
user_type = 0x8000
[partition]
name = env-redund
size = 504
user_type = 0x8000
[partition]
name = boot
size = 8064
downloadfile = "boot.fex"
user_type = 0x8000
[partition]
name = rootfs
size = 2097152
downloadfile = "rootfs.fex"
user_type = 0x8000
;[partition]
; name = dsp0
; size = 2048
; downloadfile = "dsp0.fex"
; user_type = 0x8000
;[partition]
; name = recovery
; size = 16128
; ;downloadfile = "recovery.fex"
[partition]
name = private
size = 10240
user_type = 0x8000
[partition]
name = rootfs_data
size = 50400
user_type = 0x8000
[partition]
name = UDISK
user_type = 0x8100
Tina配置这里,ext4的选项里面将节点数由6000改到100000就可以了
完结了!
最近编辑记录 liefyuan (2022-10-09 21:58:06)
https://whycan.com/files/members/6625/360截图1848110687106137.png
https://whycan.com/files/members/6625/360截图1733101761100104.png
完结了!
更改100000, 会报如下的错误
Creating filesystem with parameters:
Block size: 4096
Blocks per group: 32768
Inodes per group: 100000
Inode size: 256
Journal blocks: 0
Label:
Blocks: 12288
Block groups: 1
Reserved blocks: 0
Reserved block group size: 7
error: ext4_allocate_best_fit_partial: failed to allocate 412 blocks, out of space?
Makefile:249: recipe for target 'mkfs-ext4-root' failed
make[5]: *** [mkfs-ext4-root] Error 1
make[5]: Leaving directory '/home/chengqi/Projects/Tina-Linux/target/allwinner/generic/image'
Makefile:26: recipe for target 'install' failed
make[4]: *** [install] Error 2
make[4]: Leaving directory '/home/chengqi/Projects/Tina-Linux/target/allwinner/t113-mq_r'
Makefile:13: recipe for target 'install' failed
make[3]: *** [install] Error 2
make[3]: Leaving directory '/home/chengqi/Projects/Tina-Linux/target/allwinner'
target/Makefile:21: recipe for target 'target/allwinner/install' failed
make[2]: *** [target/allwinner/install] Error 2
make[2]: Leaving directory '/home/chengqi/Projects/Tina-Linux'
target/Makefile:17: recipe for target '/home/chengqi/Projects/Tina-Linux/out/t113-mq_r/staging_dir/target/stamp/.target_install' failed
make[1]: *** [/home/chengqi/Projects/Tina-Linux/out/t113-mq_r/staging_dir/target/stamp/.target_install] Error 2
make[1]: Leaving directory '/home/chengqi/Projects/Tina-Linux'
Build failed - please re-run with -j1 to see the real error message
/home/chengqi/Projects/Tina-Linux/build/toplevel.mk:304: recipe for target 'world' failed
make: *** [world] Error 1
[4]+ Done $T/tools/build/buildserver --path $T 2> /dev/null 1>&2
#### make failed to build some targets (01:07 (mm:ss)) ####
最近编辑记录 blizzard_chen (2023-01-15 17:44:35)
inodes问题已经解决,编译出来的qt5.12.9-arm-t113拷贝到了T113的tf卡的root_fs下,新建了个/opt的目录。并按照要求增加了/etc/profile文件
关于QT部分的内容。现在的问题是./analogclock,屏幕没有任何变化,但是也没有报错。
请各位大神支持。
@blizzard_chen
我编译成功了,上板子运行的时候报这个错怎么改?
Error loading shared library libstdc++.so.6: No such file or directory
最近编辑记录 10*****231 (2023-05-10 18:47:32)
@blizzard_chen
拷贝这个库文件到lib目录
最近编辑记录 a32425262 (2024-04-17 09:39:16)
