楼主 # 2022-10-25 23:40:56
zhuolin
已发帖子: 22
da vinci 1.0a 3D打印机捡漏记录
最近朋友分享了一款3D打印机,淘宝捡漏居然只需要490元。想都不想,直接入手。
居然还是进口打印机,厂家叫做xyzprinting。
参数如下:
Printing Properties
Print Technology
FFF(Fused Filament Fabrication)
Max. Build Area (WxDxH)
7.9" x 7.9" x 7.9" (200 x 200 x 200 mm)
Layer Resolution
100 - 400 microns
XY Positioning Precision
X/Y 12.5 micron
Z Positioning Precision
Z : 0.0004 mm
Printing Software
XYZware
Supported File Formats
.stl, .3mf, XYZ Format (.3w), .nkg (.stl)
3D Builder Support
YES
Max. Moving Speed
Max. 120 mm/s
Material
Material Compatibility
PLA / ABS / Flexible
Filament Diameter
1.75 mm
Extruder (Standard)
Nozzle Diameter
0.4 mm
Number of Nozzles
1
Nozzle Temperature
Max. 235 °C / 455 °F
Print Bed
Print Bed
Non-removable Glass
Print Bed Temperature
40 ~ 90 °C / 104 ~ 194 °F
Hardware
Stepper Motors
1.8° HB Stepper Motors
User Interface
2.6" LCM
Language
Multilingual
Connectivity
USB 2.0 Cable
System Requirements
Operating Systems
Windows 7 / 8 / 8.1 / 10 (64 bits)
macOS 10.10 / 10.11 / 10.12 / 10.13 / 10.14
Minimum Hardware Requirements
For PC: CPU 4th Generation Intel® Core™ i5 Processor or more / RAM: 8GB/ Hard disk space: 20GB or more
For MAC: RAM: 8GB / Hard disk space: 20GB or more
Intel i9 series CPU not supported
Operating Requirements
Power Requirements
100V ~ 240V 200W
Operating Temperature
15 ~ 32 °C / 59 ~ 89.6 °F
Operation Humidity
30 ~ 60 % RH (no condensation)
Storage Temperature-Filament
10 ~ 40 °C / 50 ~ 104 °F
Size & Weight
Product Dimensions (WxDxH)
18.4" x 22" x 20" (468 x 558 x 510 mm)
Product Weight
24 kg (57.3 lbs)
Packed Dimensions (WxDxH)
22" x 23.2" x 27.6" (560 x 590 x 700 mm)
Packed Weight
27.5 kg (60.63 lbs)
眼花缭乱对吧,嘿嘿不明觉厉很强。。。
楼主 #1 2022-10-25 23:48:23
zhuolin
已发帖子: 22
Re: da vinci 1.0a 3D打印机捡漏记录
怀着激动忐忑的心情,终于收到货了,一大个箱子,起码有50公斤,我的小车根本塞不下,哼哧哼哧拿回家,这个累啊。。
所以,不出意外的话就要出意外了,忙着拆箱没拍照,可惜了。最后打开发现y轴同步光杆的固定座居然裂开了。。。晕。。
.jpg
没办法,这种捡漏商家一般是不会管的,无奈开拆!
.jpg
拆下固定座,先凑活这用502沾上,以后再打印一个换上,顶两天再说。502yyds!
最终,小心翼翼上电,点亮,哈哈
.jpg
楼主 #2 2022-10-25 23:50:10
zhuolin
已发帖子: 22
机器内部有打印测试的demo,先小试牛刀,看看答应质量怎么样,应该不能太差吧。毕竟原价350美元的机器呢:D
楼主 #3 2022-10-25 23:52:12
zhuolin
已发帖子: 22
.jpg
这层纹有点严重啊,还不如我的500快小树二代呢
楼主 #4 2022-10-25 23:54:09
zhuolin
已发帖子: 22
我的小树二代,非常便宜的一款打印机,不过吃灰很久了哦
.jpg
楼主 #5 2022-10-25 23:56:10
zhuolin
已发帖子: 22
安装上原厂的切片打印软件,这功能也太少了,一点灵活性没有,垃圾
楼主 #6 2022-10-25 23:58:45
zhuolin
已发帖子: 22
另外,这个打印机限定耗材,必须使用原厂的耗材,他的耗材装有eeprom芯片,记录耗材信息,不允许使用非官方耗材,这点太讨厌了。估计打印机都不赚钱,全靠耗材挣钱了。你要说便宜点也行,淘宝一盒正品190,谁用得起
楼主 #7 2022-10-26 00:02:04
zhuolin
已发帖子: 22
耗材盒底部的芯片,不识别到这个芯片打印机不打印,这不就和惠普等打印机厂商一样的行为嘛,卖硒鼓墨盒赚钱。
不过还好,已经有人破击了这个eeprom芯片,使用arduino刷写eeprom信息,来重置耗材,链接如下:
https://www.instructables.com/Da-Vinci-10-Filament-Reset/
楼主 #8 2022-10-26 00:03:10
zhuolin
已发帖子: 22
到目前为止,这个打印机捡漏还是让我十分的满意,哈哈,太划算了。
兄弟们就不要问链接了,已经卖完了,哈哈
楼主 #9 2022-10-26 00:05:04
zhuolin
已发帖子: 22
但是现在软件的限制还是太多,没有乐趣,所以,刷开源固件的时候到了。
誒,你说巧不巧,外网已经有 成熟的方案了,github链接如下,下一步等我做完再给大家分享过程,嘻嘻
https://github.com/luc-github/Repetier-Firmware-4-Davinci
#10 2022-10-26 12:29:45
xfdr0805
已发帖子: 312
这打印机至少10几年了,我们公司有一台,在仓库里角落里被我发现了,直接换了一个主板,按机器参数配置一下Marlin固件 编译下载进去就行了,不过这打印机本身精度就不高,打印出来不精细,后来又丢角落吃灰去了
#11 2022-10-26 15:18:43
卓林
已发帖子: 84
xfdr0805 说:
嘿嘿,老机器好处就是有你们这样的大佬折腾过,前人栽树后人乘凉,美滋滋
楼主 #12 2022-10-26 22:32:21
zhuolin
已发帖子: 22
终于下班了,回家接着搞。
楼主 #13 2022-10-26 22:36:46
zhuolin
已发帖子: 22
用跳线将两个插针连上后开机,内部程序将自己把原有固件删除,此时,它就变成了一个arduino due,这个arduino没有玩过,玩过的小伙伴可以讲讲性能怎么样。
.jpg
其实挺意外这种商品打印机居然是arduino开发的(对于现在这个烧录方法的揣测,不知道是不是)
楼主 #14 2022-10-26 22:42:38
zhuolin
已发帖子: 22
打开arduino 下载arduino due开发板支持。
按照github教程,打开Repetier工程,并替换要求的文件
紧接着就是编译上传,嘿嘿
楼主 #15 2022-10-26 22:46:14
zhuolin
已发帖子: 22
叮叮当当,看到这个画面你就成功啦
不要忘记,还有一部操作,选择setting->Load Fail-Safe按确认,到此打印机固件更新完成。
楼主 #16 2022-10-26 22:48:35
zhuolin
已发帖子: 22
接下来下载RepetierHost,配置打印机软件,完全是傻瓜操作。连接打印机,导入模型,开打!
不得不说,这软件比之前用cura好太多了,还能直接检测打印机状态,帅!
最近编辑记录 zhuolin (2022-10-26 22:56:06)
楼主 #17 2022-10-26 22:51:13
zhuolin
已发帖子: 22
楼上老大哥说得对,这打印精度确实不恭为,但是我觉得也可能是我打印参数啥都没有调整导致的,我相信好好调一调是可以打的更好的,加油
.jpg
#18 2022-10-27 14:21:39
小王子&木头人
还有货吗 我也想捡一台
#19 2022-10-28 08:59:48
卓林
已发帖子: 84
小王子&木头人 说:
还有货吗 我也想捡一台
没有咯,商家已经下架了
#20 2022-10-28 09:04:34
卓林
已发帖子: 84
持续参数修改中,效果稍微好了一点,层纹似乎有减少。
使用的是abs材料,打印温度240,热床100,速度30 ,可以看到表面还有气泡孔,怀疑可能是耗材过期了,准备重新买一卷,大家有没有性价比较高的耗材推荐呢?
#21 2022-10-28 09:23:47
卓林
已发帖子: 84
之后把机器带的材料换掉,用我自己的pla材料,重新测试,发现表面光滑的多了,打印温度220,热床60,速度30,神奇。
我原以为层纹是由于我平台晃动引起的(晃动的原因还没找到)
#22 2022-11-11 23:56:32
pliu20
朋友 我也入手了一台 但是没法翻墙  能分享下资料和经验吗  我的是2.0版本的
