首先感谢aodzip大佬分享的开发包,让我这个菜鸟编译系统顺利了n倍,感谢晕哥提供的平台和各位大佬的帮助。
最近想跟着逸俊晨晖大佬的帖子,跑一下视频硬解码,结果每次编译后文件系统的挂载都有问题,后来发现只要在菜单勾选ffmpg选项,哪怕只选择h264解码也不行。(编译的文件系统14M左右)
看报错unable to read id index table是分区表没找到,导致挂载文件系统失败?
看论坛的帖子,知道开发包的文件系统分squashfs只读文件系统和overlay分区的可写文件系统来实现可读可写,会不会是文件系统变大超出分区了?
0x000000000000-0x000000080000 : "u-boot"
0x000000080000-0x000000600000 : "kernel.itb"
0x000000600000-0x000004600000 : "rom"           //squashfs只读文件系统
0x000004800000-0x000007800000 : "overlay"      //jffs2文件系统
应该改 buildroot-tiny200/board/allwinner/generic/genimage-nand.cfg  nand镜像分区配置?
还是改 buildroot-tiny200/board/allwinner/generic/uboot.env
         buildroot-tiny200/board/allwinner/generic/legacy/uboot.env 里面的环境变量?
板子:MangoPi R3 128M nand版
环境:buildroot-tiny200 (F1C100/200s) 开发包
下面是勾选配置和完整启动信息,那位大佬知道的话还请指点一二 ^_^!
U-Boot SPL 2020.07 (Jun 10 2021 - 15:57:37 +0800)
DRAM: 64 MiB
Trying to boot from MMC1
Trying to boot from MMC2
Trying to boot from sunxi SPI
SPI-NAND: GigaDevice GD5F1GQ4UAYIG
SPI-NAND: U-Boot address: 53248
U-Boot 2020.07 (Jun 10 2021 - 15:57:37 +0800) Allwinner Technology
DRAM:  64 MiB
In:    serial
Out:   serial
Err:   serial
unrecognized JEDEC id bytes: ff, c8, f1
List of MTD devices:
* spi-nand0
  - device: spi-nand@1
  - parent: spi@1c05000
  - driver: spi_nand
  - type: NAND flash
  - block size: 0x20000 bytes
  - min I/O: 0x800 bytes
  - OOB size: 64 bytes
  - OOB available: 31 bytes
Boot Device: spi
Boot Slot 0: empty
Boot Slot 1: spi-nand
DFU waiting on SPI-NAND...
musb-hdrc: peripheral reset irq lost!
Booting from SPI-NAND...
Reading 5767168 byte(s) (2816 page(s)) at offset 0x00080000
## Loading kernel from FIT Image at 81000000 ...
   Using 'conf@0' configuration
   Trying 'kernel@0' kernel subimage
     Description:  Linux kernel
     Type:         Kernel Image
     Compression:  uncompressed
     Data Start:   0x810000cc
     Data Size:    4309048 Bytes = 4.1 MiB
     Architecture: ARM
     OS:           Linux
     Load Address: 0x80000000
     Entry Point:  0x80000000
     Hash algo:    crc32
     Hash value:   f1a8af74
   Verifying Hash Integrity ... crc32+ OK
## Loading fdt from FIT Image at 81000000 ...
   Trying 'fdt@0' fdt subimage
     Data Start:   0x8141c1e8
     Data Size:    15655 Bytes = 15.3 KiB
     Architecture: ARM
     Hash algo:    crc32
     Hash value:   7947cec8
   Booting using the fdt blob at 0x8141c1e8
   Loading Kernel Image
   Loading Device Tree to 80ff9000, end 80fffd26 ... OK
[    0.000000] Linux version 5.4.92 (root@8d496aa93fd6) (gcc version 8.4.0 (Buildroot -g22245a5-dirty)) #1 Thu Jun 10 15:58:19 CST 2021
[    0.000000] OF: fdt: Machine model: Widora MangoPi R3
[    0.000000] cma: Reserved 16 MiB at 0x83000000
[    0.000000] Kernel command line: console=ttyS0,115200 rootwait init=/preinit root=/dev/mtdblock2 rootfstype=squashfs overlayfsdev=/dev/mtdblock3 net.ifnames=0 vt.global_cursor_default=0
[    0.000000] Memory: 38736K/65536K available (6144K kernel code, 248K rwdata, 1676K rodata, 1024K init, 225K bss, 10416K reserved, 16384K cma-reserved)
[    0.000049] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000142] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000897] Console: colour dummy device 80x30
[    0.000992] Calibrating delay loop... 203.16 BogoMIPS (lpj=1015808)
[    0.070263] pid_max: default: 32768 minimum: 301
[    0.070804] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.070851] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.072786] CPU: Testing write buffer coherency: ok
[    0.074862] Setting up static identity map for 0x80100000 - 0x80100058
[    0.076053] devtmpfs: initialized
[    0.088203] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.088267] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
[    0.092586] pinctrl core: initialized pinctrl subsystem
[    0.095137] NET: Registered protocol family 16
[    0.098898] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.101302] cpuidle: using governor menu
[    0.145666] SCSI subsystem initialized
[    0.146068] usbcore: registered new interface driver usbfs
[    0.146227] usbcore: registered new interface driver hub
[    0.146389] usbcore: registered new device driver usb
[    0.146912] mc: Linux media interface: v0.10
[    0.147042] videodev: Linux video capture interface: v2.00
[    0.147176] pps_core: LinuxPPS API ver. 1 registered
[    0.147194] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.147260] PTP clock support registered
[    0.148360] ion_parse_dt_heap_common: id 4 type 4 name cma align 1000
[    0.149297] Advanced Linux Sound Architecture Driver Initialized.
[    0.151849] clocksource: Switched to clocksource timer
[    0.183688] thermal_sys: Registered thermal governor 'step_wise'
[    0.184503] NET: Registered protocol family 2
[    0.185993] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[    0.186070] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.186124] TCP bind hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.186171] TCP: Hash tables configured (established 1024 bind 1024)
[    0.186435] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
[    0.186493] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
[    0.187018] NET: Registered protocol family 1
[    0.189658] NetWinder Floating Point Emulator V0.97 (double precision)
[    0.191556] Initialise system trusted keyrings
[    0.192324] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[    0.214764] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.215423] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    0.337664] Key type asymmetric registered
[    0.337705] Asymmetric key parser 'x509' registered
[    0.337882] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    0.337908] io scheduler mq-deadline registered
[    0.337926] io scheduler kyber registered
[    0.354205] suniv-f1c100s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.379602] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.385922] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pa not found, using dummy regulator
[    0.387295] printk: console [ttyS0] disabled
[    0.407601] 1c25400.serial: ttyS0 at MMIO 0x1c25400 (irq = 27, base_baud = 6250000) is a 16550A
[    0.841418] printk: console [ttyS0] enabled
[    0.851177] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
[    0.872318] panel-simple panel: panel supply power not found, using dummy regulator
[    0.881965] SCSI Media Changer driver v0.25
[    0.887809] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
[    0.900714] spi-nand spi0.0: GigaDevice SPI NAND was found.
[    0.906419] spi-nand spi0.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
[    0.916009] 4 fixed-partitions partitions found on MTD device spi0.0
[    0.922475] Creating 4 MTD partitions on "spi0.0":
[    0.927313] 0x000000000000-0x000000080000 : "u-boot"
[    0.937742] 0x000000080000-0x000000600000 : "kernel.itb"
[    0.946595] random: fast init done
[    0.969643] 0x000000600000-0x000004600000 : "rom"
[    1.203317] 0x000004800000-0x000007800000 : "overlay"
[    1.380159] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.386811] ehci-platform: EHCI generic platform driver
[    1.392508] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.398733] ohci-platform: OHCI generic platform driver
[    1.404552] usbcore: registered new interface driver usb-storage
[    1.411526] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    1.425183] i2c /dev entries driver
[    1.429333] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
[    1.443175] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pe not found, using dummy regulator
[    1.454196] sun4i-csi 1cb0000.csi: Packed (RAW) format enabled.
[    1.462071] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.472136] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
[    1.510184] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[    1.519608] usbcore: registered new interface driver usbhid
[    1.525300] usbhid: USB HID core driver
[    1.529474] sunxi-cedar 1c0e000.video-codec: sunxi cedar version 0.01alpha
[    1.536807] sunxi-cedar 1c0e000.video-codec: cedar-ve the get irq is 20
[    1.548638] debugfs: Directory '1c23c00.codec' with parent 'F1C100s Audio Codec' already present!
[    1.562557] sun4i-codec 1c23c00.codec: Codec <-> 1c23c00.codec mapping ok
[    1.578587] NET: Registered protocol family 17
[    1.583275] Key type dns_resolver registered
[    1.588662] Loading compiled-in X.509 certificates
[    1.607053] sun4i-drm soc:display-engine: bound 1e00000.display-frontend (ops 0xc073b278)
[    1.616110] sun4i-drm soc:display-engine: bound 1e60000.display-backend (ops 0xc073aab8)
[    1.625668] sun4i-drm soc:display-engine: bound 1c0c000.lcd-controller (ops 0xc0739658)
[    1.634256] sun4i-drm soc:display-engine: bound 1c0a000.tv-encoder (ops 0xc073a378)
[    1.642032] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.648633] [drm] No driver support for vblank timestamp query.
[    1.656340] [drm] Initialized sun4i-drm 1.0.0 20150629 for soc:display-engine on minor 0
[    1.665374] [drm] kms: can't enable cloning when we probably wanted to.
[    1.737113] Console: switching to colour frame buffer device 100x30
[    1.775979] sun4i-drm soc:display-engine: fb0: sun4i-drmdrmfb frame buffer device
[    1.784530] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    1.802354] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    1.809113] ALSA device list:
[    1.812215]   #0: F1C100s Audio Codec
[    1.816494] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    1.825227] cfg80211: failed to load regulatory.db
[    1.836565] unable to read id index table
[    1.840975] List of all partitions:
[    1.844663] 1f00             512 mtdblock0
[    1.844672]  (driver?)
[    1.851280] 1f01            5632 mtdblock1
[    1.851287]  (driver?)
[    1.857903] 1f02           65536 mtdblock2
[    1.857908]  (driver?)
[    1.864528] 1f03           49152 mtdblock3
[    1.864535]  (driver?)
[    1.871058] No filesystem could mount root, tried:
[    1.871063]  squashfs
[    1.875969]
[    1.879769] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,2)
[    1.888107] CPU: 0 PID: 1 Comm: swapper Not tainted 5.4.92 #1
[    1.893834] Hardware name: Allwinner suniv Family
[    1.898615] [<c010e1a8>] (unwind_backtrace) from [<c010b954>] (show_stack+0x10/0x14)
[    1.906385] [<c010b954>] (show_stack) from [<c06ee31c>] (panic+0xe8/0x2e4)
[    1.913278] [<c06ee31c>] (panic) from [<c090135c>] (mount_block_root+0x2bc/0x31c)
[    1.920760] [<c090135c>] (mount_block_root) from [<c0901568>] (prepare_namespace+0x128/0x188)
[    1.929289] [<c0901568>] (prepare_namespace) from [<c06f6154>] (kernel_init+0x8/0x108)
[    1.937204] [<c06f6154>] (kernel_init) from [<c01010e0>] (ret_from_fork+0x14/0x34)
[    1.944752] Exception stack(0xc2839fb0 to 0xc2839ff8)
[    1.949801] 9fa0:                                     00000000 00000000 00000000 00000000
[    1.957968] 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.966130] 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[    1.972739] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,2) ]---离线
嗯嗯,多谢晕哥解答,这是生成的镜像大小
是改 /board/widora/mangopi/r3/devicetree/linux下的devicetree.dts么?把ram分区调大么?
	spi-nand@0 {
		#address-cells = <1>;
		#size-cells = <1>;
		compatible = "spi-nand";
		reg = <0>;
		//status = "disabled";
		partitions {
			#size-cells = <1>;
			partition@0 {
				label = "u-boot";
				reg = <0x000000 0x80000>;
				read-only;
			partition@1 {
				label = "kernel.itb";
				reg = <0x80000 0x580000>;
				read-only;
			partition@2 {
				label = "rom";
				reg = <0x600000 0x4000000>;
				read-only;
			partition@3 {
				label = "overlay";
				reg = <0x4800000 0x3000000>;
	};应该是squashfs根文件系统系统超大了,你看下文件系统镜像文件多大,然后改dts文件,应该就可以了。
嗯嗯,多谢:D
请问楼主,你修改这个,就行了吗?我也出现和你一样的错误
