楼主 # 2023-03-14 09:49:10
Winston
T113-S3 一个很奇怪的USB问题
主控芯片为T113-S3,在Linux内核初始化的时候,总是会提示USB错误。百思不得其解,已经调试三天了,特来社区向大家讨论。
附上主要log信息:
 Populating /dev using udev: [    2.245205] usb 3-1.3: new high-speed USB device number 3 using ehci-platform
[    2.295512] udevd[122]: starting version 3.2.11
[    7.385144] usb 3-1.3: device descriptor read/64, error -110
[    7.435152] random: crng init done
[    7.479677] udevd[123]: starting eudev-3.2.11
[   22.745155] usb 3-1.3: device descriptor read/64, error -110
[   22.965147] usb 3-1.3: new high-speed USB device number 4 using ehci-platform
[   28.105164] usb 3-1.3: device descriptor read/64, error -110
udevadm settle failed
楼主 #1 2023-03-14 09:49:59
Winston
Re: T113-S3 一个很奇怪的USB问题
附上所有log信息
[I] AWBoot r6201 starting...
[I] SMHC: sdhci0 controller v50310 initialized
[I] SHMC: SD card detected
[I] FATFS: read sun8i-t113.dtb addr=44000000
[I] FATFS: read zImage addr=44800000
[I] booting linux...
[    0.000000] Linux version 6.0.1+ (fuxiaoer@DESKTOP-ICQ2N2B) (arm-none-linux-gnueabihf-gcc (Arm GNU Toolchain 12.2.Rel1 (Build arm-12.24)) 12.2.1 20221205, GNU ld (Arm GNU Toolchain 12.2.Rel1 (Build arm-12.24)) 2.39.0.20221210) #38 SMP Mon Mar 13 18:00:25 CST 2023
[    0.000000] OF: fdt: Machine model: MangoPi MQ-Dual
[    0.000000] cma: Reserved 16 MiB at 0x47000000
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x0000000040000000-0x0000000047ffffff]
[    0.000000]   HighMem  empty
[    0.000000]   node   0: [mem 0x0000000040000000-0x0000000047ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x0000000047ffffff]
[    0.000000] percpu: Embedded 11 pages/cpu s15508 r8192 d21356 u45056
[    0.000000] Kernel command line: mem=128M root=/dev/mmcblk0p2 rootfstype=ext4 init=/sbin/init rw rootwait console=ttyS4,115200
[    0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
[    0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[    0.000000] Memory: 99812K/131072K available (8192K kernel code, 949K rwdata, 2144K rodata, 1024K init, 269K bss, 14876K reserved, 16384K cma-reserved, 0K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=2.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000012] Switching to timer-based delay loop, resolution 41ns
[    0.000185] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000667] Console: colour dummy device 80x30
[    0.000708] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000724] pid_max: default: 32768 minimum: 301
[    0.000875] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.000886] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.001434] CPU: Testing write buffer coherency: ok
[    0.001741] /cpus/cpu@0 missing clock-frequency property
[    0.001770] /cpus/cpu@1 missing clock-frequency property
[    0.001780] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.002535] Setting up static identity map for 0x40100000 - 0x40100060
[    0.002678] rcu: Hierarchical SRCU implementation.
[    0.002682] rcu:     Max phase no-delay instances is 1000.
[    0.003198] smp: Bringing up secondary CPUs ...
[    0.003876] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.003999] smp: Brought up 1 node, 2 CPUs
[    0.004008] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[    0.004016] CPU: All CPU(s) started in SVC mode.
[    0.004540] devtmpfs: initialized
[    0.008600] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.008798] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.008822] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.009404] pinctrl core: initialized pinctrl subsystem
[    0.010793] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.011849] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.012693] thermal_sys: Registered thermal governor 'step_wise'
[    0.012933] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.012946] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.021484] platform 5460000.tcon-top: Fixing up cyclic dependency with 5200000.mixer
[    0.021561] platform 5460000.tcon-top: Fixing up cyclic dependency with 5100000.mixer
[    0.021829] platform 5461000.lcd-controller: Fixing up cyclic dependency with 5460000.tcon-top
[    0.022183] platform 5470000.lcd-controller: Fixing up cyclic dependency with 5604000.tv-encoder
[    0.022244] platform 5470000.lcd-controller: Fixing up cyclic dependency with 5460000.tcon-top
[    0.023217] platform 7090000.rtc: Fixing up cyclic dependency with 7010000.clock-controller
[    0.032913] SCSI subsystem initialized
[    0.033368] usbcore: registered new interface driver usbfs
[    0.033419] usbcore: registered new interface driver hub
[    0.033460] usbcore: registered new device driver usb
[    0.033651] mc: Linux media interface: v0.10
[    0.033694] videodev: Linux video capture interface: v2.00
[    0.033769] pps_core: LinuxPPS API ver. 1 registered
[    0.033774] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.033789] PTP clock support registered
[    0.035146] clocksource: Switched to clocksource arch_sys_counter
[    0.042625] NET: Registered PF_INET protocol family
[    0.042817] IP idents hash table entries: 2048 (order: 2, 16384 bytes, linear)
[    0.043350] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[    0.043376] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.043387] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.043404] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[    0.043422] TCP: Hash tables configured (established 1024 bind 1024)
[    0.043502] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.043532] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.043690] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.044360] RPC: Registered named UNIX socket transport module.
[    0.044373] RPC: Registered udp transport module.
[    0.044377] RPC: Registered tcp transport module.
[    0.044380] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.046296] Initialise system trusted keyrings
[    0.046561] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[    0.051586] NFS: Registering the id_resolver key type
[    0.051700] Key type id_resolver registered
[    0.051705] Key type id_legacy registered
[    0.051768] NET: Registered PF_ALG protocol family
[    0.051776] Key type asymmetric registered
[    0.051781] Asymmetric key parser 'x509' registered
[    0.051909] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    0.051918] io scheduler mq-deadline registered
[    0.051923] io scheduler kyber registered
[    0.067368] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.076661] CAN device driver interface
[    0.077314] PPP generic driver version 2.4.2
[    0.077631] PPP BSD Compression module registered
[    0.077647] PPP Deflate Compression module registered
[    0.077922] PPP MPPE Compression module registered
[    0.077933] NET: Registered PF_PPPOX protocol family
[    0.078040] usbcore: registered new interface driver cdc_ether
[    0.078071] usbcore: registered new interface driver cdc_eem
[    0.078135] usbcore: registered new interface driver cdc_ncm
[    0.078162] usbcore: registered new interface driver r8153_ecm
[    0.078435] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.078446] ehci-platform: EHCI generic platform driver
[    0.078659] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.078682] ohci-platform: OHCI generic platform driver
[    0.078849] usbcore: registered new interface driver cdc_acm
[    0.078855] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    0.078881] usbcore: registered new interface driver cdc_wdm
[    0.078921] usbcore: registered new interface driver usb-storage
[    0.079003] usbcore: registered new interface driver ch341
[    0.079027] usbserial: USB Serial support registered for ch341-uart
[    0.081315] sun6i-rtc 7090000.rtc: registered as rtc0
[    0.081442] sun6i-rtc 7090000.rtc: setting system clock to 1970-01-02T00:00:08 UTC (86408)
[    0.081567] sun6i-rtc 7090000.rtc: RTC enabled
[    0.081867] i2c_dev: i2c /dev entries driver
[    0.083646] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    0.084722] sun8i-ce 3040000.crypto: Set mod clock to 300000000 (300 Mhz) from 400000000 (400 Mhz)
[    0.085031] sun8i-ce 3040000.crypto: will run requests pump with realtime priority
[    0.085749] sun8i-ce 3040000.crypto: will run requests pump with realtime priority
[    0.085970] sun8i-ce 3040000.crypto: will run requests pump with realtime priority
[    0.086146] sun8i-ce 3040000.crypto: will run requests pump with realtime priority
[    0.086277] sun8i-ce 3040000.crypto: Register cbc(aes)
[    0.086301] sun8i-ce 3040000.crypto: Register ecb(aes)
[    0.086310] sun8i-ce 3040000.crypto: Register cbc(des3_ede)
[    0.086319] sun8i-ce 3040000.crypto: Register ecb(des3_ede)
[    0.086348] sun8i-ce 3040000.crypto: CryptoEngine Die ID 0
[    0.087220] usbcore: registered new interface driver usbhid
[    0.087229] usbhid: USB HID core driver
[    0.088173] NET: Registered PF_PACKET protocol family
[    0.088201] can: controller area network core
[    0.088265] NET: Registered PF_CAN protocol family
[    0.088271] can: raw protocol
[    0.088278] can: broadcast manager protocol
[    0.088287] can: netlink gateway - max_hops=1
[    0.088391] Key type dns_resolver registered
[    0.088418] Key type ceph registered
[    0.088825] libceph: loaded (mon/osd proto 15/24)
[    0.088923] Registering SWP/SWPB emulation handler
[    0.089015] Loading compiled-in X.509 certificates
[    0.106904] sun20i-d1-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
[    0.128224] 2500400.serial: ttyS1 at MMIO 0x2500400 (irq = 231, base_baud = 1500000) is a 16550A
[    0.149533] 2500800.serial: ttyS2 at MMIO 0x2500800 (irq = 232, base_baud = 1500000) is a 16550A
[    0.170866] 2500c00.serial: ttyS3 at MMIO 0x2500c00 (irq = 233, base_baud = 1500000) is a 16550A
[    0.192314] 2501000.serial: ttyS4 at MMIO 0x2501000 (irq = 234, base_baud = 1500000) is a 16550A
[    1.154466] printk: console [ttyS4] enabled
[    1.179963] 2501400.serial: ttyS5 at MMIO 0x2501400 (irq = 235, base_baud = 1500000) is a 16550A
[    1.192237] phy phy-4100400.phy.0: Changing dr_mode to 1
[    1.193295] usb_phy_generic usb_phy_generic.1.auto: dummy supplies not allowed for exclusive requests
[    1.197634] ehci-platform 4101000.usb: EHCI Host Controller
[    1.207419] musb-hdrc musb-hdrc.2.auto: MUSB HDRC host driver
[    1.213553] ehci-platform 4200000.usb: EHCI Host Controller
[    1.224106] musb-hdrc musb-hdrc.2.auto: new USB bus registered, assigned bus number 2
[    1.224226] ehci-platform 4200000.usb: new USB bus registered, assigned bus number 3
[    1.232205] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.00
[    1.240576] ehci-platform 4101000.usb: new USB bus registered, assigned bus number 1
[    1.248010] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.256664] ohci-platform 4200400.usb: Generic Platform OHCI controller
[    1.262962] usb usb2: Product: MUSB HDRC host driver
[    1.262970] usb usb2: Manufacturer: Linux 6.0.1+ musb-hcd
[    1.279952] usb usb2: SerialNumber: musb-hdrc.2.auto
[    1.285593] hub 2-0:1.0: USB hub found
[    1.289395] hub 2-0:1.0: 1 port detected
[    1.293570] ehci-platform 4200000.usb: irq 239, io mem 0x04200000
[    1.300024] ehci-platform 4101000.usb: irq 237, io mem 0x04101000
[    1.301942] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    1.306496] ohci-platform 4200400.usb: new USB bus registered, assigned bus number 4
[    1.322304] ohci-platform 4200400.usb: irq 241, io mem 0x04200400
[    1.328554] ehci-platform 4200000.usb: USB 2.0 started, EHCI 1.00
[    1.328613] sunxi-mmc 4020000.mmc: Got CD GPIO
[    1.334867] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.00
[    1.347399] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.354631] usb usb3: Product: EHCI Host Controller
[    1.357012] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    1.359548] usb usb3: Manufacturer: Linux 6.0.1+ ehci_hcd
[    1.366440] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    1.371438] usb usb3: SerialNumber: 4200000.usb
[    1.380077] cfg80211: failed to load regulatory.db
[    1.384769] ehci-platform 4101000.usb: USB 2.0 started, EHCI 1.00
[    1.389685] sunxi-mmc 4020000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
[    1.400013] hub 3-0:1.0: USB hub found
[    1.408214] hub 3-0:1.0: 1 port detected
[    1.412763] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.00
[    1.421085] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.428346] usb usb4: Product: Generic Platform OHCI controller
[    1.434268] usb usb4: Manufacturer: Linux 6.0.1+ ohci_hcd
[    1.439685] usb usb4: SerialNumber: 4200400.usb
[    1.444633] ohci-platform 4101400.usb: Generic Platform OHCI controller
[    1.445431] hub 4-0:1.0: USB hub found
[    1.455082] hub 4-0:1.0: 1 port detected
[    1.459632] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.00
[    1.467954] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.475204] usb usb1: Product: EHCI Host Controller
[    1.480085] usb usb1: Manufacturer: Linux 6.0.1+ ehci_hcd
[    1.485502] usb usb1: SerialNumber: 4101000.usb
[    1.490611] hub 1-0:1.0: USB hub found
[    1.494417] hub 1-0:1.0: 1 port detected
[    1.499033] ohci-platform 4101400.usb: new USB bus registered, assigned bus number 5
[    1.507070] ohci-platform 4101400.usb: irq 240, io mem 0x04101400
[    1.528833] mmc0: new high speed SDXC card at address 0001
[    1.535270] mmcblk0: mmc0:0001 JC2RT 59.6 GiB
[    1.542156]  mmcblk0: p1 p2 p3
[    1.579312] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.00
[    1.587618] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.594837] usb usb5: Product: Generic Platform OHCI controller
[    1.600763] usb usb5: Manufacturer: Linux 6.0.1+ ohci_hcd
[    1.606167] usb usb5: SerialNumber: 4101400.usb
[    1.611264] hub 5-0:1.0: USB hub found
[    1.615058] hub 5-0:1.0: 1 port detected
[    1.705166] usb 3-1: new high-speed USB device number 2 using ehci-platform
[    1.719273] EXT4-fs (mmcblk0p2): recovery complete
[    1.726524] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: disabled.
[    1.735497] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    1.742693] devtmpfs: mounted
[    1.746862] Freeing unused kernel image (initmem) memory: 1024K
[    1.752954] Run /sbin/init as init process
[    1.905760] usb 3-1: New USB device found, idVendor=1a86, idProduct=8091, bcdDevice= 2.10
[    1.913988] usb 3-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[    1.921160] usb 3-1: Product: USB HUB
[    1.925547] hub 3-1:1.0: USB hub found
[    1.929513] hub 3-1:1.0: 4 ports detected
[    2.010315] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: disabled.
Starting syslogd: OK
Starting klogd: OK
Running sysctl: OK
done
Saving random seed: OK
Starting network: Waiting for interface usb0 to appear.....[   43.465155] usb 3-1.3: device descriptor read/64, error -110
[   43.585271] usb 3-1-port3: attempt power cycle
.[   44.245153] usb 3-1.3: new high-speed USB device number 5 using ehci-platform
......... timeout!
run-parts: /etc/network/if-pre-up.d/wait_iface: exit status 1
FAIL
Starting ntpd: OK
Starting sshd: OK
Starting collectd: FAIL
Welcome to use T113
AllWinner T113 login: [   54.785153] usb 3-1.3: device not accepting address 5, error -110
[   54.885152] usb 3-1.3: new high-speed USB device number 6 using ehci-platform
[   65.425152] usb 3-1.3: device not accepting address 6, error -110
[   65.431390] usb 3-1-port3: unable to enumerate USB device
[   65.535151] usb 3-1.4: new high-speed USB device number 7 using ehci-platform
[   65.696250] usb 3-1.4: New USB device found, idVendor=2c7c, idProduct=0125, bcdDevice= 3.18
[   65.704612] usb 3-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   65.711943] usb 3-1.4: Product: Android
[   65.715801] usb 3-1.4: Manufacturer: Android
[   65.727124] cdc_ether 3-1.4:1.4 usb0: register 'cdc_ether' at usb-4200000.usb-1.4, CDC Ethernet Device, 8e:2f:7b:1c:34:44
楼主 #2 2023-03-14 09:57:39
Winston
简单分析一下问题,我的T113-S3,通过CH334 USB HUB芯片将USB1扩展成了四路,分别外接了移远EC20、USB有线网卡SR9900A;但是在插入电源自动开机的时候,总会出现USB错误,但不知道是系统的问题还是硬件设计的问题。
目前怀疑的问题如下所示:
1. 5V供电不足,5V供电采用的SY8303AIC只有3A的电流供电,理论上是够了,但是EC20在3.6V电压域峰值电流可以达到2A,是不是这里突然拉低导致初始化失败了呢?(其实我觉得不太可能是这个问题,因为我用示波器触发档位去测量,没有看到电压低于4.9V)
2. USB走线干扰问题,在PCB上5VDCDC的连线和USB的连线重复了一段,可不可能是这个问题引入了DCDC的噪声呢?
3. USB阻抗问题,可能90欧姆双端阻抗不稳定,导致通讯失败? (可是他有时候又能成功)
神奇的测试:
   为了排除上述的问题,我通过外部电源直接给5V供电,发现好像这个问题没有出现了,现在让人更自闭了……
#3 2023-03-14 10:05:08
uuid
已发帖子: 45
大概率还是电源问题,可以试一试4G模块单独供电先试一试。
#4 2023-03-14 10:05:56
mysteryli
已发帖子: 481
那不是确定了是PCB设计缺陷了嘛
楼主 #5 2023-03-14 10:07:32
Winston
uuid 说:
目前的4G模组已经是单独供电了 哈哈,我把原理图附上
楼主 #6 2023-03-14 11:08:33
Winston
mysteryli 说:
那不是确定了是PCB设计缺陷了嘛
主要不知道是什么缺陷,无从下手了,不确定是电源带来的干扰 还是其他的干扰
#7 2023-03-14 13:05:14
wechat微信:whycan_cn
所在地: 你猜
已发帖子: 3,378
Winston 说:
mysteryli 说:
那不是确定了是PCB设计缺陷了嘛
用芒果开发板 + USB HUB 试一试,
如果还不行,那怀疑是不是USB端点不够?
#8 2023-03-14 23:42:46
wupaul2001
已发帖子: 259
电源问题,换个好点的电源就没事了,我的产品也遇到
楼主 #9 2023-03-15 10:06:17
Winston
wupaul2001 说:
ok谢谢!目前也是打算换电源.
#10 2023-07-09 01:06:23
wupaul2001
已发帖子: 259
Winston 说:
wupaul2001 说:
ok谢谢!目前也是打算换电源.
最近又遇到了,把设备树usb_otg设为disabled好了
#11 2023-07-29 14:24:02
已发帖子: 1,214
wupaul2001 说:
Winston 说:
wupaul2001 说:
ok谢谢!目前也是打算换电源.
没找到usb_otg这个变量,在内核设备树里关于usb0的是这样的,usb_port_type = 0已经算是device了,但调适口还是有那些信息。
   0     &usbc0 {        │  sys_config.fex*
   1     device_type = "usbc0";        │  sys_partition.fex*
   2     usb_port_type = <0x0>;        │  uboot-board.dts*
   3     usb_detect_type = <0x0>;        │~
   4 /*  usb_detect_mode = <0>;        │~
   5     usb_id_gpio = <&pio PB 8 GPIO_ACTIVE_HIGH>;                                                     │~
   6     enable-active-high;        │~
   7     usb_det_vbus_gpio = <&pio PB 9 GPIO_ACTIVE_HIGH>; */                                            │~
   8     usb_wakeup_suspend = <0>;        │~
   9     usb_serial_unique = <0>;        │~
  10     usb_serial_number = "20080411";        │~
  11     rndis_wceis = <1>;        │~
  12     status = "okay";        │~
  13 };
最近编辑记录 Gentlepig (2023-07-29 14:24:22)
#12 2023-07-31 09:26:27
已发帖子: 1,214
警告信息如下:
[   12.136914] sunxi_vbus_det_work()3493 WARN: get power supply failed
[   12.196217] sunxi_set_cur_vol_work()489 WARN: get power supply failed
