报错代码如下 我换其他根目录也不行
=> boot
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
reading /boot.scr
349 bytes read in 15 ms (22.5 KiB/s)
reading uImage
2467400 bytes read in 134 ms (17.6 MiB/s)
reading script.bin
32384 bytes read in 25 ms (1.2 MiB/s)
SCRIPT FAILED: continuing...
No controllers found
USB is stopped. Please issue 'usb start' first.
No ethernet found.
missing environment variable: bootfile
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-sunxi
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
No ethernet found.
根目录是没问题的我用主线linux测试过了,uboot 我重新编译了,boot.scr 我也改了怎么回事??
同问,也是一样的问题
没找到网卡,可以尝试从SD卡启动
设备树生成的有问题,重新生成一下
