楼主 # 2023-06-29 04:10:07
Xiaoci
已发帖子: 24
荔枝派V3S uboot+bsp+buildroot 启动失败怎么回事?
报错代码如下 我换其他根目录也不行
=> boot
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
reading /boot.scr
349 bytes read in 15 ms (22.5 KiB/s)
Executing script at 41900000
reading uImage
2467400 bytes read in 134 ms (17.6 MiB/s)
reading script.bin
32384 bytes read in 25 ms (1.2 MiB/s)
SCRIPT FAILED: continuing...
No controllers found
USB is stopped. Please issue 'usb start' first.
No ethernet found.
missing environment variable: bootfile
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-sunxi
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
No ethernet found.
楼主 #1 2023-07-02 03:22:47
Xiaoci
已发帖子: 24
Re: 荔枝派V3S uboot+bsp+buildroot 启动失败怎么回事?
根目录是没问题的我用主线linux测试过了,uboot 我重新编译了,boot.scr 我也改了怎么回事??
#2 2023-07-06 10:45:01
Lonson
同问,也是一样的问题
#3 2023-07-07 10:47:53
wj8331585
已发帖子: 44
没找到网卡,可以尝试从SD卡启动
#4 2023-07-07 20:15:54
zadair
设备树生成的有问题,重新生成一下
