全志的SOC,只要不是太老旧的芯片,里面都集成了2048bit的EFUSE,但此熔丝位的很多细节,并没有相关描述文档,这导致大家很难在实际项目中应用此功能,而且也缺乏灵活的烧写工具,基于此问题,我花了点时间扩展了下XFEL工具。
扩展的命令如下:
usage:
xfel extra efuse dump - Dump all of the efuse information
xfel extra efuse read32 <offset> - Read 32-bits value from efuse
xfel extra efuse write32 <offset> <value> - Write 32-bits value to efuse
xfel extra efuse write <offset> <file> - Write file to efuse
执行dump指令,显示如下信息:
chipid:(0x0000 128-bits)
93406000 0c004814 01426250 48671b4b
brom-conf-try:(0x0010 32-bits)
00000000
thermal-sensor:(0x0014 64-bits)
88fbc11a 01e9080f
ft-zone:(0x001c 128-bits)
898f1919 0f760f6c 3108126c 811a0a0e
tvout:(0x002c 32-bits)
0000028f
tvout-gamma:(0x0030 64-bits)
00000000 00000000
oem-program:(0x0038 64-bits)
00000000 00000000
write-protect:(0x0040 32-bits)
00000000
read-protect:(0x0044 32-bits)
00000000
reserved1:(0x0048 64-bits)
00000000 00000000
huk:(0x0050 192-bits)
00000000 00000000 00000000 00000000 00000000 00000000
reserved2:(0x0068 64-bits)
00000000 00000000
rotpk:(0x0070 256-bits)
00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
ssk:(0x0090 256-bits)
rssk:(0x00b0 128-bits)
hdcp-hash:(0x00c0 128-bits)
nv1:(0x00d0 32-bits)
00000000
nv2:(0x00d4 32-bits)
00000000
reserved3:(0x00d8 96-bits)
oem-program-secure:(0x00e4 224-bits)
可以通过write32 或者write指令来烧写熔丝。
全志加密引导功能可以通过烧写熔丝来启用,当然你也可以烧写自己的序列号,或者mac地址之类的,当然这个efuse还可以用来做防盗版,来实现一机一固件,简要说明下,就是在efuse里烧录本机固件的签名文件,而这个签名文件又是跟cpu序列号关联,可以采用ECDSA256签名算法,签名大小为512bit,64字节,比RSA的签名要小很多,而且强度够。
efuse分配信息如下:
static const struct sid_section_t {
char * name;
uint32_t offset;
uint32_t size_bits;
} sids[] = {
{ "chipid", 0x0000, 128 },
{ "brom-conf-try", 0x0010, 32 },
{ "thermal-sensor", 0x0014, 64 },
{ "ft-zone", 0x001c, 128 },
{ "tvout", 0x002c, 32 },
{ "tvout-gamma", 0x0030, 64 },
{ "oem-program", 0x0038, 64 },
{ "write-protect", 0x0040, 32 },
{ "read-protect", 0x0044, 32 },
{ "reserved1", 0x0048, 64 },
{ "huk", 0x0050, 192 },
{ "reserved2", 0x0068, 64 },
{ "rotpk", 0x0070, 256 },
{ "ssk", 0x0090, 256 },
{ "rssk", 0x00b0, 128 },
{ "hdcp-hash", 0x00c0, 128 },
{ "nv1", 0x00d0, 32 },
{ "nv2", 0x00d4, 32 },
{ "reserved3", 0x00d8, 96 },
{ "oem-program-secure", 0x00e4, 224 },
这是根据全志SDK总结而来。
牛 能抢到沙发不
最近编辑记录 david (2023-07-12 01:13:26)
只能写一次吗
写完会熔断吗?会不会因为写efuse不当导致芯片成砖
EFUSE写操作仅能由0 到 1,所以只要是保持0状态的bit,都是可以写入的,当你都搞成1了,就无力回天了,没办法变成0。熔丝熔断了,是个不可逆的物理过程。
现在XFEL支持了D1 / D1s / F133芯片的EFUSE读写操作
1,dump efuse
$ xfel extra efuse dump
93005c00 ac004814 01425a4c 1c5318cb
00000000
7906c10a 019db011
83883119 0ef00f02 2b06111c 87180a0b
00000285
00000000 00000000
00000000 00000000
00000000
00000000
00000000 00000000
00000000 00000000
00000000
00000000
2, write oem-program 1
$ xfel extra efuse write32 0x0038 0x11223344
00000000
7906c10a 019db011
00000285
00000000 00000000
11223344 00000000
00000000
00000000
00000000 00000000
00000000 00000000
00000000
00000000
3, write oem-program 2
$ xfel extra efuse write32 0x003c 0x55667788
00000000
7906c10a 019db011
00000285
00000000 00000000
11223344 55667788
00000000
00000000
00000000 00000000
00000000 00000000
00000000
00000000
4, reboot and dump efuse again
00000000
7906c10a 019db011
00000285
00000000 00000000
11223344 55667788
00000000
00000000
00000000 00000000
00000000 00000000
00000000
00000000
太棒了,保留了这么多可写的bit,完全够用了
这个是可能的,比如你烧写了加密引导位,并且随便填了个rotpk的sha256值,那么你的芯片就永远无法启动了,没有合法的加密引导签名,谁都没辙,就变砖了。
但只要不碰到关键熔丝,还是没啥风险的,在操作之前,仔细确认EFUSE分配信息,就无伤大雅了。
efuse分配信息,其实也不是一成不变的,除了核心分配信息,基本都是随着SDK的而重新分配的,这些细节就只能去翻代码了。
有些efuse存储了全志出厂时的芯片校正信息,比如温度传感器校正参数,TVOUT校正,各种AD,DA,内部RC补偿等等,这些没有文档,只能自己去寻找蛛丝马迹了。
扩展XFEL,支持V851/V853芯片的EFUSE读写操作
62c07800 cc004820 0145c519 204e1a8c
00000000
2291c0f9 007c9279
100f1109 13210de2 00278600 00691510
reserved1:(0x002c 96-bits)
write-protect:(0x0038 32-bits)
00000000
read-protect:(0x003c 32-bits)
00000000
lcjs:(0x0040 32-bits)
00000000
reserved2:(0x0044 800-bits)
00000000
rotpk:(0x00a8 256-bits)
reserved3:(0x00c8 448-bits)
在F133芯片上,烧写ECDSA256 64字节签名文件到EFUSE,偏移为0x00c0区域,也就是2048bit的最后面的512bit,efuse前面的bit有各种隐藏用途,需小心使用,但后面的bit就随便整了。无需担心变砖。
经验证,是可以通过efuse来存储签名文件,并能够验签通过。
1,通过write指令烧写64字节签名文件,烧写到0xc0这个偏移位置
xfel extra efuse write 0x00c0 sign.bin
2,查看烧写好的efuse,发现0xc0偏移,已经储存了签名文件,与sign.bin的内容保持一致
00000000
7906c10a 019db011
00000285
00000000 00000000
11223344 55667788
00000000
00000000
00000000 00000000
00000000 00000000
e133aa93 7aaf3227 14b10f12 06b71c6c
ef80e46e
e0ba33d4
a6fe6c3c f65c2d60 915ae6c7
90ce9b07 94906489 3e39dce8 d06473aa 1dda2501 1f940484 36a770d8
3, 验签,将efuse里的签名读出来,用ECDSA256公钥进行验签,这里是对CPU唯一序列号的SHA256摘要进行验签。经过这样的操作,只要你没有ECDSA256私钥,你是无法生成正确的签名文件的,那么验签就无法通过。当别人想抄板或更换CPU,因序列号变了,且没有正确的签名,就无法启动运行,实现放盗版保护。
上面的验签过程,有两种应用场景,需求不同,思路也会不同。
第一种,自己的产品防盗版,没有升级需求,或者loader没有升级需求,也就是某部分固件,完全不变化,且需防盗版抄袭。
这种需求,你需要将CPU ID + 固件或者loader,两者所有信息进行sha256摘要运算,并用ECDSA256对SHA256的摘要进行签名,存储在EFUSE里。当别人复制产品时,复制了SPI NOR FLASH,复制了EFUSE 签名,因CPU ID不同,也无法正常验签。
第二种,自己是方案商仅出主控芯片,客户自行烧录生产,有固件及各种烧写工具。这种情况要求客户必须从你这里走芯片,而不能从市面上随便购买。
对于这种需求,仅需要对CPU ID 进行SHA256摘要运算,并用ECDSA256对SHA256的摘要进行签名,存储在EFUSE里,烧录好,出给客户就可以了。客户可以随便刷机,升级,但不能随便购买芯片。
当然,固件完整性,固件防逆向,这些需求,可结合坑网之前的讨论的帖子,来实现。
最后一句话,攻防手段千千万,但几千年来,唯一不变的,还是人心,人性。
@xboot
是不是还有一些对用户不可见的efuse,厂家提前编程的区域?
有厂家提前烧好的区域,比如chipid,thermal-sensor,但这些都还是可见的,全志在启用加密引导功能后,有部分EFUSE就不可见了,读取会直接返回0。
全志SOC,写EFUSE,必须通过SID控制器,通过寄存器操作来写入,但读取EFUSE,有两种方案,一种是比较简单的SRAM映射,直接用MMIO来访问就可以了,这里有个细节需要注意,仅支持word字访问,不支持byte字节访问,还有一种方案,就是用SID控制器来读取。
SRAM映射方案,只有在SOC重启时更新一次,所以,如果新写入了efuse,想不重启来查看的话,就需要用SID控制器来读取。
启用加密模式后,SID控制器访问也会受限,需要用SMC相关指令来访问,具体还没有研究加密后的SID控制器。
当烧写了加密引导,如果所有固件都引导失败了,会自动进入非加密模式的FEL。
chipid 0状态的bit 可以重写吗?
要启用加密引导模式,需要将LCJS段里面的某个bit写1,就启用加密引导了,如果这个时候rotpk段还没有写入,那么全志的会引导任何一个加密引导固件,不进行任何校验,但只要写入了rotpk(非全0),就需要校验了。
rotpk,其实就是RSA2048公钥的SHA256摘要,总共256bit,这个在烧写时,必须保留好RSA2048私钥,否则就像锁门并焊死锁孔。
我觉得应该是可写的,只是还没有这样去操作过,此过程,跟全志芯片出厂时流程一致。之前实验过OEM段,多次写入,0值bit可以再次编程到1。
太牛了,导致我有一个铤而走险且大胆的想法。
这个brom完成的吗?如果 LCJS段里面的某个bit写1,而且写入了 写入了rotpk,那么我裸奔受影响吗?
受影响,我们常用的非加密模式引导头是egon,如果修改成加密引导,那么加密头就需要toc0,这个部分有些差异,toc头信息比egon信息要多一些,能否兼容,这个还没有深入研究,现在只知道,两个头信息不一样的,这些操作都是SBROM里面来实现的,而且全志的BROM有两套,一个是普通的BROM,另一个是SBROM,根据EFUSE配置,自动选择对应的BROM,SBROM也是可以dump出来的。前提是烧写LCJS后,用程序dump出来,FEL模式是无法dump SBROM,fel仅存在与非加密模式
在DUMP EFUSE后,有一个ft-zone字段,一直不能明白ft是啥意思,现在终于搞明白了,原来是final test (FT) stage的缩写,芯片终测后,写入的EFUSE值,总共128bit,具体是干啥的,就不得而知了。
最近编辑记录 xboot (2023-07-12 22:23:06)
TVOUT efuse是用于设置TVE模块的bias
0000028f
就是说编程 LCJS 之后,是启动SBROM,否则是启动BROM?
是的,关于rotpk,准确的表达是,全0,全1,或者没个字节都一样时,可以运行加密固件而不需要校验签名。只有每个字节,有一个不同时,才启用校验功能。
额,我发现加密安全引导漏洞了,我仅需将rotpk字段再次烧写为全1,那么就可以引导我自己的加密固件了,这全志的安全引导,真值得商榷。在加密模式只要可以引导自己的加密固件,那么所有的安全都形同虚设。
额,好吧,安全芯片,做好真心不太容易。
@xboot
chipid是efuse,那岂不是所有芯片的chipid都可以被修改成ffffff,那岂不是只要有ffffff设备的密钥或证书,就能全部运行了?
@xboot
是的,可以这么说,谁要愿意,可以去写一下chip id 看看
我来当小白鼠了,CHIP ID是可以改写的。在T113芯片上测试
先读取出厂的CHIP ID,前4个字节为93406000
将前4个字节修改为0xffffffff
$ xfel extra efuse write32 0x00 0xffffffff
再次查看芯片的CHIP ID,已经被修改为0xffffffff了。
ffffffff 0c004814 01426250 48671b4b
结论,关于CHIP ID,你真的可以用xfel工具,自己重写一个。如果全志出厂时,CHIP ID全0的话,你是真的可以完美复制出两个一模一样的芯片。
我印象中,当时还在研究D1,手上拿到了一颗F133样片,里面的SID就是全0,当时还很奇怪,为何没有SID呢,原来仅仅是没烧写。
一转眼,距离离研究D1芯片,已经过去2年了, 这该死的时间,也不慢一点。
最近编辑记录 xboot (2023-07-13 15:09:28)
翻了一下,当时的《全志D1芯片之终极探索》,尽然记录了这个异常的CHIP ID。算是在两年后给了一个交代。
chipid居然可以写,大为震惊。。
@xboot
楼主精通底层技术,赞一个。
这种需求,你需要将CPU ID + 固件或者loader,两者所有信息进行sha256摘要运算,并用ECDSA256对SHA256的摘要进行签名,存储在EFUSE里。当别人复制产品时,复制了SPI NOR FLASH,复制了EFUSE 签名,因CPU ID不同,也无法正常验签。第二种,自己是方案商仅出主控芯片,客户自行烧录生产,有固件及各种烧写工具。这种情况要求客户必须从你这里走芯片,而不能从市面上随便购买。
对于这种需求,仅需要对CPU ID 进行SHA256摘要运算,并用ECDSA256对SHA256的摘要进行签名,存储在EFUSE里,烧录好,出给客户就可以了。客户可以随便刷机,升级,但不能随便购买芯片。当然,固件完整性,固件防逆向,这些需求,可结合坑网之前的讨论的帖子,来实现。
请问应用程序验签的时候使用什么库?openssl吗?还是用SOC内嵌的安全算法?
最近编辑记录 wuyu (2023-12-18 14:59:38)
试过了,烧录roptk的时候会启用一个安全位,roptk部分的efuse就不可写了,0也不能写成1,而且SSK和HUK读取会变成0,应该是efuse硬连线限制了。
没烧录roptk的倒是可以直接使用,使用默认签名就行了。
@xboot
大佬,你说的LCJS段是什么啊,熔丝位里的某个字段吗?
@xboot
大侠,可以说得更详细点吗?
1,LCJS段在哪里?哪个地址?
2,在efuse的rotpk字段写入什么数据?这些数量怎样生成的?用什么工具?
3,要把BOOT0做成toc0(不是egon),用什么工具?
