楼主 # 2023-10-20 10:50:36
nufing
已发帖子: 96
请教高手, f1c200s 怎么通过 USB-rtl8192C 连接无线路由器 ?
8192C的驱动正常, 可以扫描周边 热点, 但 wpa_supplicant 连接热点时, 一直提示 Driver does not support authentication/association or connect commands, 实在找不到原因了. 有高手知道的, 请赐教一下.
ifconfig
lo Link encap:Local Loopback
UP LOOPBACK RUNNING MTU:65536 Metric:1
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
wlan0 Link encap:Ethernet HWaddr 00:1D:43:20:00:11
UP BROADCAST MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:1000
wpa_supplicant -i wlan0 -c /etc/wpa_supplicant.conf & iwconfig
wlan0
rtw_wx_get_rts, rts_thresh=2347
[ 869.744614] rtw_wx_get_frag, frag_len=2346
wlan0 unassociated Mode:Auto Frequency=2.412 GHz
Access Point: Not-Associated
RTS thr:off Fragment thr:off
Encryption key:off
Power Management:off
Link Quality=0/100 Signal level=0 dBm Noise level=0 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
nl80211: Driver does not support authentication/association or connect commands
nl80211: deinit ifname=wlan0 disabled_11b_rates=0
wlan0: Failed to initialize driver interface
楼主 #1 2023-10-20 11:13:06
nufing
已发帖子: 96
Re: 请教高手, f1c200s 怎么通过 USB-rtl8192C 连接无线路由器 ?
找到问题了, 要这样调用: wpa_supplicant -B -i wlan0 -D wext -c /etc/wpa_supplicant.conf
