楼主 # 2023-10-20 10:50:36
nufing
已发帖子: 95
请教高手, f1c200s 怎么通过 USB-rtl8192C 连接无线路由器 ?
8192C的驱动正常, 可以扫描周边 热点, 但 wpa_supplicant 连接热点时, 一直提示 Driver does not support authentication/association or connect commands,  实在找不到原因了. 有高手知道的, 请赐教一下.
ifconfig
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          collisions:0 txqueuelen:0
wlan0     Link encap:Ethernet  HWaddr 00:1D:43:20:00:11
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          collisions:0 txqueuelen:1000
wpa_supplicant -i wlan0 -c /etc/wpa_supplicant.conf & iwconfig
wlan0
rtw_wx_get_rts, rts_thresh=2347
[  869.744614] rtw_wx_get_frag, frag_len=2346
wlan0     unassociated  Mode:Auto  Frequency=2.412 GHz
          Access Point: Not-Associated
          RTS thr:off   Fragment thr:off
          Encryption key:off
          Power Management:off
          Link Quality=0/100  Signal level=0 dBm  Noise level=0 dBm
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
# nl80211: Driver does not support authentication/association or connect commands
nl80211: deinit ifname=wlan0 disabled_11b_rates=0
wlan0: Failed to initialize driver interface
楼主 #1 2023-10-20 11:13:06
nufing
已发帖子: 95
Re: 请教高手, f1c200s 怎么通过 USB-rtl8192C 连接无线路由器 ?
找到问题了,  要这样调用:  wpa_supplicant -B -i wlan0 -D wext -c /etc/wpa_supplicant.conf
