楼主 # 2024-01-01 16:48:04
YuzukiTsuru
SyterKit 裸跑 H618 拉起 BL31 看看能不能直接拉起到 Linux 内核跳过 U-Boot
SyterKit 开源地址: https://github.com/YuzukiHD/SyterKit
目前支持的板子是 sipeed 的 longanpi-3h
先写一个 helloworld 拉起最小系统,适配了
extern sunxi_serial_t uart_dbg;
int main(void) {
    sunxi_serial_init(&uart_dbg);
    show_banner();
    sunxi_clk_init();
    sunxi_clk_dump();
    printk(LOG_LEVEL_INFO, "Hello World!\n");
    abort();
#1 2024-01-05 20:45:24
dso_2019
已发帖子: 39
Re: SyterKit 裸跑 H618 拉起 BL31 看看能不能直接拉起到 Linux 内核跳过 U-Boot
note: ‘memmove’ is declared in header ‘<string.h>’
/home/yang/arm/SyterKit-main/src/drivers/sun50iw9/sys-dram.c: Assembler messages:
/home/yang/arm/SyterKit-main/src/drivers/sun50iw9/sys-dram.c:39: Error: no such instruction: `isb sy'
/home/yang/arm/SyterKit-main/src/drivers/sun50iw9/sys-dram.c:43: Error: number of operands mismatch for `ds'
/home/yang/arm/SyterKit-main/src/drivers/sun50iw9/sys-dram.c:47: Error: no such instruction: `dmb sy'
make[2]: *** [src/drivers/sun50iw9/CMakeFiles/chip_drivers-obj.dir/build.make:76: src/drivers/sun50iw9/CMakeFiles/chip_drivers-obj.dir/sys-dram.c.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:540: src/drivers/sun50iw9/CMakeFiles/chip_drivers-obj.dir/all] Error 2
make: *** [Makefile:84: all] Error 2   编译报这个错
