楼主 # 2024-03-24 10:57:39
memory
已发帖子: 656
真是渣渣,T113-S3 tplayerdemo 测试播放1280x720视频,两小时就挂了
64 bytes from 183.2.193.224: seq=2593 ttl=56 time=52.159 ms
64 bytes from 183.2.193.224: seq=2594 ttl=56 time=9.867 ms
64 bytes from 183.2.193.224: seq=2595 ttl=56 time=9.895 ms
[1970-01-01 02:22:37] WARNING: cedarc <waitInterruptDecoder:748>: wait ve interrupt timeout. ret = 0
64 bytes from 183.2.193.224: seq=2596 ttl=56 time=10.993 ms
64 bytes from 183.2.193.224: seq=2597 ttl=56 time=30.195 ms
64 bytes from 183.2.193.224: seq=2598 ttl=56 time=12.402 ms
64 bytes from 183.2.193.224: seq=2599 ttl=56 time=6.879 ms
64 bytes from 183.2.193.224: seq=2600 ttl=56 time=12.246 ms
64 bytes from 183.2.193.224: seq=2601 ttl=56 time=21.728 ms
64 bytes from 183.2.193.224: seq=2602 ttl=56 time=17.808 ms
64 bytes from 183.2.193.224: seq=2603 ttl=56 time=6.241 ms
64 bytes from 183.2.193.224: seq=2604 ttl=56 time=20.518 ms
64 bytes from 183.2.193.224: seq=2605 ttl=56 time=9.801 ms
64 bytes from 183.2.193.224: seq=2606 ttl=56 time=11.661 ms
64 bytes from 183.2.193.224: seq=2607 ttl=56 time=8.761 ms
64 bytes from 183.2.193.224: seq=2608 ttl=56 time=16.567 ms
64 bytes from 183.2.193.224: seq=2609 ttl=56 time=7.684 ms
64 bytes from 183.2.193.224: seq=2610 ttl=56 time=47.762 ms
64 bytes from 183.2.193.224: seq=2611 ttl=56 time=16.499 ms
64 bytes from 183.2.193.224: seq=2612 ttl=56 time=25.055 ms
64 bytes from 183.2.193.224: seq=2613 ttl=56 time=13.752 ms
64 bytes from 183.2.193.224: seq=2614 ttl=56 time=11.462 ms
64 bytes from 183.2.193.224: seq=2615 ttl=56 time=7.686 ms
[1970-01-01 02:22:57] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3143162 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
64 bytes from 183.2.193.224: seq=2616 ttl=56 time=5.880 ms
[1970-01-01 02:22:58] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3143162 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
64 bytes from 183.2.193.224: seq=2617 ttl=56 time=41.615 ms
[1970-01-01 02:22:59] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3143162 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
楼主 #1 2024-03-24 10:59:05
memory
已发帖子: 656
Re: 真是渣渣,T113-S3 tplayerdemo 测试播放1280x720视频,两小时就挂了
RTL8723DS WIFI测试了12小时都正常
#2 2024-05-17 13:34:25
已发帖子: 9,401
改大这个初始化参数试一试: VideoConf.nVbvBufferSize
	if(Decoder->ScaleDownEn > 0){
		VideoConf.nVbvBufferSize = 1*1024*1024;
		VideoConf.bScaleDownEn = 1;
		VideoConf.nHorizonScaleDownRatio = 1;
		VideoConf.nVerticalScaleDownRatio = 1;
	VideoConf.eOutputPixelFormat  = Decoder->decode_format;
    VideoConf.nDeInterlaceHoldingFrameBufferNum = GetConfigParamterInt("pic_4di_num", 2);
    VideoConf.nDisplayHoldingFrameBufferNum = GetConfigParamterInt("pic_4list_num", 3);
    VideoConf.nRotateHoldingFrameBufferNum = GetConfigParamterInt("pic_4rotate_num", 0);
    VideoConf.nDecodeSmoothFrameBufferNum = GetConfigParamterInt("pic_4smooth_num", 3);
    VideoConf.memops = Decoder->memops;
    nRet = InitializeVideoDecoder(Decoder->pVideoDec, &VideoInfo, &VideoConf);
#3 2024-05-17 13:54:37
armstrong
已发帖子: 290
扩大VideoConf.nVbvBufferSize参数,是不是能延长到4小时才挂掉?
#4 2025-03-10 21:11:21
chenyinchang
memory 说:
所以是WIFI断连的问题导致挂掉的么?
楼主 #5 2025-05-25 20:51:32
memory
已发帖子: 656
可能和DRAM内存频率有关系,从792M降低到600M貌似正常多了。
参考:【FAQ1448】 awplayer通路播放卡顿分析方法.pdf
