楼主 #1 2018-10-02 04:32:57
Mitko
已发帖子: 219
针对Lichee Pi Zero的Debian问题。
我想在Lichee Pi Zero上运行Debian,来源:https://licheepizero.us/ 8. [Downloads]。但是所有图像都会出现以下错误:
U-Boot SPL 2017.01-rc2-00055-gc41fbfe7b5 (Jan 20 2017 - 00:39:08)
DRAM: 0 MiB
任何经过测试的SD卡图片?
#2 2018-10-02 08:45:13
已发帖子: 9,368
Re: 针对Lichee Pi Zero的Debian问题。
DRAM: 64 MiB
Trying to boot from MMC1
U-Boot 2017.01-rc2-00055-gc41fbfe7b5 (Jan 20 2017 - 00:39:08 +0800) Allwinner Te        chnology
Model: Lichee Pi Zero
DRAM:  64 MiB
MMC:   SUNXI SD/MMC: 0
In:    serial@01c28000
Out:   serial@01c28000
Err:   serial@01c28000
DRAM:  64 MiB
In:    serial@01c28000
Net:   No ethernet found.
No controllers found
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
reading /boot.scr
292 bytes read in 16 ms (17.6 KiB/s)
reading zImage
3987024 bytes read in 655 ms (5.8 MiB/s)
9262 bytes read in 28 ms (322.3 KiB/s)
   Loading Device Tree to 42dfa000, end 42dff42d ... OK
[    0.000000] Linux version 4.10.2-licheepi-zero+ (zp@ubuntu) (gcc version 6.3.1 20170109 (Linaro GCC 6.3-2017.02) ) #15 SMP Sat Apr 15 21:38:23 CST 2017
[    0.000000] OF: fdt:Machine model: Lichee Pi Zero with Dock
[    0.000000] percpu: Embedded 14 pages/cpu @c3dea000 s24652 r8192 d24500 u57344
[    0.000000] Kernel command line: console=ttyS0,115200 panic=5 console=tty0 rootwait root=/dev/mmcblk0p2 earlyprintk rw
[    0.000000] Memory: 53628K/64036K available (6144K kernel code, 213K rwdata, 1472K rodata, 1024K init, 260K bss, 10408K reserved, 0K cma-reserved, 0K highmem)
[    0.000000]       .data : 0xc0a00000 - 0xc0a35600   ( 214 kB)
[    0.000000]        .bss : 0xc0a37000 - 0xc0a781cc   ( 261 kB)
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=1
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (virt).
[    0.000152] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000361] Console: colour dummy device 80x30
[    0.000797] console [tty0] enabled
[    0.000839] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000878] pid_max: default: 32768 minimum: 301
[    0.001029] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.001057] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.001781] CPU: Testing write buffer coherency: ok
[    0.002221] /cpus/cpu@0 missing clock-frequency property
[    0.002266] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.002658] Setting up static identity map for 0x40100000 - 0x40100058
[    0.003459] smp: Bringing up secondary CPUs ...
[    0.003502] smp: Brought up 1 node, 1 CPU
[    0.003523] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[    0.003542] CPU: All CPU(s) started in SVC mode.
[    0.004354] devtmpfs: initialized
[    0.007272] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.007595] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.007651] futex hash table entries: 256 (order: 2, 16384 bytes)
[    0.007822] pinctrl core: initialized pinctrl subsystem
[    0.008867] NET: Registered protocol family 16
[    0.009372] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.010754] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.010805] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.022763] SCSI subsystem initialized
[    0.023094] usbcore: registered new interface driver usbfs
[    0.023177] usbcore: registered new interface driver hub
[    0.023304] usbcore: registered new device driver usb
[    0.023547] pps_core: LinuxPPS API ver. 1 registered
[    0.023573] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.023621] PTP clock support registered
[    0.023867] Advanced Linux Sound Architecture Driver Initialized.
[    0.025715] clocksource: Switched to clocksource arch_sys_counter
[    0.026585] simple-framebuffer 43e89000.framebuffer: framebuffer at 0x43e89000, 0x177000 bytes, mapped to 0xc4080000
[    0.026638] simple-framebuffer 43e89000.framebuffer: format=x8r8g8b8, mode=800x480x32, linelength=3200
[    0.033547] Console: switching to colour frame buffer device 100x30
[    0.043373] simple-framebuffer 43e89000.framebuffer: fb0: simplefb registered!
[    0.057294] NET: Registered protocol family 2
[    0.061700] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.065575] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[    0.069470] TCP: Hash tables configured (established 1024 bind 1024)
[    0.073311] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.077106] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.081022] NET: Registered protocol family 1
[    0.085318] RPC: Registered named UNIX socket transport module.
[    0.089097] RPC: Registered udp transport module.
[    0.092682] RPC: Registered tcp transport module.
[    0.096169] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.101936] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[    0.114545] NFS: Registering the id_resolver key type
[    0.118207] Key type id_resolver registered
[    0.121580] Key type id_legacy registered
[    0.124935] nform: OHCI generic platform driver
[    0.925360] usbcore: registered new interface driver usb-storage
[    0.934648] usbcore: registered new interface driver ums-freecom
[    0.944226] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[    0.956992] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
[    0.969364] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
[    0.979656] sun6i-rtc 1c20400.rtc: RTC enabled
[    0.987605] i2c /dev entries driver
[    0.995973] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input1
[    1.009110] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.075765] sunxi-mmc 1c0f000.mmc: base:0xc405f000 irq:23
[    1.131237] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.143169] mmc0: new SDHC card at address 0001
[    1.151917] sunxi-mmc 1c10000.mmc: base:0xc4063000 irq:24
[    1.162026] usbcore: registered new interface driver usbhid
[    1.171318] usbhid: USB HID core driver
[    1.179780] mmcblk0: mmc0:0001 SD 14.9 GiB
[    1.189875] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01c23000 not registered
[    1.201785] sun4i-codec 1c22c00.codec: Failed to register our card
[    1.213049]  mmcblk0: p1 p2
[    1.223697] NET: Registered protocol family 17
[    1.232001] Key type dns_resolver registered
[    1.239914] Registering SWP/SWPB emulation handler
[    1.253371] usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    1.265061] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    1.274600] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[    1.287557] hub 1-0:1.0: USB hub found
[    1.295130] hub 1-0:1.0: 1 port detected
[    1.303582] using random self ethernet address
[    1.311702] using random host ethernet address
[    1.320729] usb0: HOST MAC xx:xx:xx:xx:xx:xx
[    1.328629] usb0: MAC xx:xx:xx:xx:xx:xx
[    1.335969] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[    1.346932] g_cdc gadget: g_cdc ready
[    1.356609] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[    1.369155] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 00:00:12 UTC (12)
[    1.381007] vcc5v0: disabling
[    1.387472] ALSA device list:
[    1.393721]   #0: V3s Audio Codec
[    1.402019] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[    1.415078] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[    1.430785] mmc1: new high speed SDIO card at address 0001
[    1.478521] random: fast init done
[    1.709675] random: crng init done
[    4.101521] EXT4-fs (mmcblk0p2): recovery complete
[    4.130481] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    4.141875] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    4.161077] devtmpfs: mounted
[    4.168668] Freeing unused kernel memory: 1024K
[    4.499261] systemd[1]: RTC configured in localtime, applying delta of 480 minutes to system time.
[    4.523503] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[    4.544278] systemd[1]: Detected architecture 'arm'.
[    4.639521] systemd[1]: Failed to insert module 'autofs4'
[    4.648857] systemd[1]: Failed to insert module 'ipv6'
[    4.672185] systemd[1]: Set hostname to <licheepi>.
[    5.284713] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[    5.296880] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    5.308323] systemd[1]: Expecting device dev-ttyS0.device...
[    5.321874] systemd[1]: Starting Remote File Systems (Pre).
[    5.334977] systemd[1]: Reached target Remote File Systems (Pre).
[    7.055402] r8723bs: loading out-of-tree module taints kernel.
[    7.075256] RTL8723BS: module init start
[    7.082134] RTL8723BS: rtl8723bs v4.3.5.5_12290.20140916_BTCOEX20140507-4E40
[    7.092049] RTL8723BS: rtl8723bs BT-Coex version = BTCOEX20140507-4E40
[    7.102512] pnetdev = c31d8000
[    7.155216] RTL8723BS: rtw_ndev_init(wlan0)
[    7.180137] RTL8723BS: module init ret =0
[    7.244716] systemd-udevd[89]: starting version 215
[    7.653647] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    8.493048] Adding 131068k swap on /swap.  Priority:-1 extents:2 across:139260k SS
[    8.562660] ns2009: module license 'unspecified' taints kernel.
[    8.562665] Disabling lock debugging due to kernel taint
[    8.562764] ns2009: Unknown symbol devm_kmalloc (err 0)
[    9.246994] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[    9.879675] systemd-journald[82]: Received request to flush runtime journal from PID 1
[   15.923648] rtl8723bs: accquire FW from file:rtlwifi/rtl8723bs_nic.bin
Debian GNU/Linux 8 licheepi ttyS0
licheepi login: [   20.077981] RTL8723BS: nolinked power save enter
licheepi login: licheepi
Password:
Last login: Tue Jun 20 09:09:42 CST 2017 from desktop-xxxx.lan on pts/0
Linux licheepi 4.10.2-licheepi-zero+ #15 SMP Sat Apr 15 21:38:23 CST 2017 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
licheepi@licheepi:~$
正常的启动信息是这样的,
DRAM: 0 MiB 看起来是硬件有问题, 没有检测到 DRAM ?
#3 2018-10-02 09:26:24
已发帖子: 9,368
wget https://github.com/qq516333132/v3s_image/raw/master/brmin_dd.tar.bz2
tar xvf brmin_dd.tar.bz2
sudo dd if=brmin_dd/lichee_zero-brmin_alpha.dd of=/dev/sdx
sync
我按上面的流程走一遍,一切正常!
参考: https://steward-fu.github.io/website/mcu/lichee-zero/flash_image_sd.htm
楼主 #4 2018-10-03 00:05:05
Mitko
已发帖子: 219
是。坏电容C60。
SVREF_C60
20181002183225
PCB显示R45,C60位于上方。
我按上面的流程走一遍,一切正常!
没有以太网端口。任何支持以太网的内核?
#5 2018-10-03 00:44:08
路人甲
已发帖子: 202
有以太网口,集成了MAC+ PHY.
楼主 #6 2018-10-03 02:34:41
Mitko
已发帖子: 219
路人甲 说:
有以太网口,集成了MAC+ PHY.
是,集成了MAC+ PHY.
这里描述了通过USB:【Tutorial】PC share network to Zero via USB
root@LicheePi:/# ifconfig
          collisions:0 txqueuelen:1000
usb0      Link encap:Ethernet  HWaddr 1e:ff:f7:0a:3c:f8
          inet addr:192.168.2.100  Bcast:192.168.2.255  Mask:255.255.255.0
          RX packets:27604 errors:0 dropped:1 overruns:0 frame:0
          TX packets:14099 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:34656566 (33.0 MiB)  TX bytes:1160029 (1.1 MiB)
#7 2018-10-03 06:41:38
路人甲
已发帖子: 202
可以,在usb开启 gadget与RNDIS驱动就可以了。
楼主 #8 2018-10-03 11:57:53
Mitko
已发帖子: 219
路人甲 说:
更喜欢真正的以太网端口。
任何准备好的U-boot +内核包括:Licheepi Zero Ethernet适配指南 ?
#9 2018-10-03 13:12:25
路人甲
已发帖子: 202
Mitko 说:
路人甲 说:
更喜欢真正的以太网端口。
对,按照上面的步骤一步一步,可以把 Ethernet 搞定。
楼主 #10 2018-10-03 14:58:03
Mitko
已发帖子: 219
路人甲 说:
没有必要从愚蠢的答案,如果你不能为这个主题贡献一些有意义的东西,你的评论不受欢迎。
Update: 以太网安装文章产生:
/opt/gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-gcc: 1: /opt/gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-gcc: ELF: not found
/opt/gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-gcc: 1: /opt/gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-gcc: Syntax error: Unterminated quoted string
Kbuild:20: recipe for target 'kernel/bounds.s' failed
make[1]: *** [kernel/bounds.s] Error 2
Makefile:1061: recipe for target 'prepare0' failed
make: *** [prepare0] Error 2
最近编辑记录 Mitko (2018-10-04 00:51:41)
#11 2018-10-04 22:15:23
awfans
已发帖子: 264
Mitko 说:
路人甲 说:
Update: 以太网安装文章产生:
https://whycan.cn/t_864.html#p3468
是不是你的系统是 64bit, gcc 是 32bit 的
试一试下面的命令:
sudo apt-get install lsb-core
apt-get install lib32z1 lib32ncurses5
apt-get install lib32stdc++6
楼主 #12 2018-10-08 03:26:20
Mitko
已发帖子: 219
谢谢你的建议。该内核有效,但初始化有点慢:
[    7.124107] libphy: 1c30000.ethernet: probed
[    7.140363] Generic PHY 1c30000.ethernet-0:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=1c30000.ethernet-0:01, irq=-1)
[    7.152181] sun8i-emac 1c30000.ethernet: device MAC address slot 0 02:00:f3:57:6b:57
[    7.160421] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[    8.008771] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
[   16.836255] random: crng init done
[   17.603973] sun8i-emac 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[   28.747272] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01
您还拥有3.3 V,1.8 V和1.2 V的V3S最大功率电流 ?
#13 2018-10-08 14:27:25
没测过, 看到Q群别的网友测过V3s核心板, 20mA@5.0V
楼主 #14 2018-10-08 16:38:39
Mitko
已发帖子: 219
smartcar 说:
20 mA @ 5V看起来很低。我刚刚测量了我的电路板 (@ 5V, SD-card):
-  Uboot加载110-120 mA
- 以太网初始化:180-210 mA
- 正常工作(启用以太网):140-180 mA
@晕哥。注意到你有V3S定制板,你能测量1.8 V和1.2 V的电流吗?
#15 2018-10-08 16:46:14
已发帖子: 9,368
改天我测一下电流.
